547,443 active members*
1,699 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma VACIII D11 ALARM 20
Results 1 to 9 of 9
    Aug 2018
    3
    "1058-20 ALARM A Heat Sink Overload" presents at power up (cold machine) and communication with the drive. Drive LED's M1 and M2 as well as green LED 9 are on solid. Have exhausted maintenance manual and tech support troubleshooting tips up to changing out control PCB, which I don't have Any suggestions greatly appreciated.
    Oct 2009
    90
    Re: Okuma VACIII D11 ALARM 20
    Check and clean the fans behind the vac unit. you have tu remove the vac unit. Then you can reach them..
    Aug 2012
    163
    Hello, we repair Okuma drives, power supplies, etc. If you want to discuss this, you can email me at kevin1@cnctechnical.com...this is usually a pretty inexpensive fix and one of the few where we will do a "parts and labor" repair to avoid the expense of a full refurbish repair cost.
    Aug 2018
    3
    Thanks for the replies. Yes, I have cleaned the heat sink and verified the fan is good. The alarm presents immediately at power up, machine cold.
    Aug 2012
    163
    If you want to repair, we would need to set you up in our system as a customer, send you a repair order which you would send in with the control board. Please send me your contact info (to my email in the last post) and I will contact you to discuss options.
    Oct 2015
    24
    I give my "thumbs up" to Kevin at CNC Technical, he helped me out with trouble shooting and a replacement board for our Okuma this spring.
    Aug 2018
    3
    cncts11, I have narrowed the problem down to heat damage on the PCB at the circuit that monitors the heat sink and motor thermal switches. What would I be looking at for turn around time on a repair of this nature?. I have attached a photo.
    Aug 2012
    163
    Sorry, been out of the office the last few days - if all that is needed is the repair of the alarm 20 (no wash cycle, other repairs/updates, etc.), then it would be a same day turnaround or worst case, next day (sometimes we don't get the stuff until early afternoon and to receive it in, get it on a bench, repair it and test it might not be possible before UPS comes back for pickup). Under normal circumstances though, we usually can do it.
    Jan 2010
    5
    Quote Originally Posted by edwart28 View Post
    Hello,
    Did you solve problem?
    What parts you replace?
  1. okuma alarm 937
    By RINES in forum Okuma
    Last Post: 06-30-2021, 08:46 PM
  2. okuma lr 15 cpu alarm
    By pedro pinto in forum Okuma
    Last Post: 04-13-2018, 02:53 PM
  3. Replies: 23
    Last Post: 11-22-2011, 08:26 AM
  4. Okuma VACA303/ VACIII Manual Needed
    By markedwin in forum Machinery Manuals / Brochures
    Last Post: 10-18-2011, 07:14 PM
