600,838 active members*
3,498 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma Z axis machine set
    Hello, I got a Okuma Cadet V4020 mill with osp 5020M controll. My first milling machine ever. My machine shop had only Okuma cnc lathes till now. So to move in that mill i had to take off the motor and lower the spindle. Once it was inside I put the motor back, but now the motor encoder is not in the same position to the ball screw or the machine data. How do I adjust the machine setting?
    Re: Okuma Z axis machine set
    Quote Originally Posted by Aylmer View Post
    As you removed and reinstalled the spindle motor,
    the motor encoder position is likely misaligned relative to the machine’s absolute positioning system.
    Quote Originally Posted by cncmakers001 View Post
    Yes, do you know how to reset it?
