504,278 active members
6,263 visitors online
Results 1 to 4 of 4
    Sep 2019
    4
    old machine new computer...
    I have an older Taig micro mill and a StepMasterNC 4axis LE all works on the old computer with mach2 but the 4th axis because the previous owner never set it up. So I upgraded the computer with a 8th intel PC with a PCI express card with a parallel port and that seams to be working but now with mach3 on this new PC I cant get the micro mill to jog or do anything. I copied the pin settings from mach2 and still nothing. I also tried to use the driver test in the mach3 folder and it tells me there is nothing there? I am still in the pre mill stage and learning. I got surfcam up and running to make models in because I do have some background with 3d printing and that part was a bit simple for me. but the stepper motor controller stuff has got me stuck. anyone have some knowledge they would like to share that would be great.
    Thanks in advance.
    Sep 2019
    4
    Re: old machine new computer...
    Found this XML file on a UK website not sure how to use it though. it is supposed to be for the stepmasterNC 4 axis LE controller
    <?xml version="1.0" encoding="ISO-8859-1"?>
    <profile>
    <Preferences>
    <PulseSpeed>0</PulseSpeed>
    <Profile>Mach3M10mm</Profile>
    <Layout>LSCES1024X.set</Layout>
    <FirstRun>1</FirstRun>
    <Units>0</Units>
    <Serial>0</Serial>
    <Port2Input>0</Port2Input>
    <GeckoMode>0</GeckoMode>
    <USBINPUTS>16</USBINPUTS>
    <USBOUTPUTS>16</USBOUTPUTS>
    <Port2On>0</Port2On>
    <Port1On>1</Port1On>
    <Port1Add>888</Port1Add>
    <Port2Add>632</Port2Add>
    <MaxCL>0</MaxCL>
    <MaxNC10>0</MaxNC10>
    <Motor0Active>1</Motor0Active>
    <Motor0DirNeg>1</Motor0DirNeg>
    <Motor0DirPort>1</Motor0DirPort>
    <Motor0DirPin>3</Motor0DirPin>
    <Motor0StepNeg>1</Motor0StepNeg>
    <Motor0StepPort>1</Motor0StepPort>
    <Motor0StepPin>2</Motor0StepPin>
    <Motor1Active>1</Motor1Active>
    <Motor1DirNeg>1</Motor1DirNeg>
    <Motor1DirPort>1</Motor1DirPort>
    <Motor1DirPin>5</Motor1DirPin>
    <Motor1StepNeg>0</Motor1StepNeg>
    <Motor1StepPort>1</Motor1StepPort>
    <Motor1StepPin>4</Motor1StepPin>
    <Motor2Active>1</Motor2Active>
    <Motor2DirNeg>1</Motor2DirNeg>
    <Motor2DirPort>1</Motor2DirPort>
    <Motor2DirPin>7</Motor2DirPin>
    <Motor2StepNeg>0</Motor2StepNeg>
    <Motor2StepPort>1</Motor2StepPort>
    <Motor2StepPin>6</Motor2StepPin>
    <Motor3Active>1</Motor3Active>
    <Motor3DirNeg>1</Motor3DirNeg>
    <Motor3DirPort>1</Motor3DirPort>
    <Motor3DirPin>9</Motor3DirPin>
    <Motor3StepNeg>0</Motor3StepNeg>
    <Motor3StepPort>1</Motor3StepPort>
    <Motor3StepPin>8</Motor3StepPin>
    <Motor4Active>0</Motor4Active>
    <Motor4DirNeg>0</Motor4DirNeg>
    <Motor4DirPort>0</Motor4DirPort>
    <Motor4DirPin>0</Motor4DirPin>
    <Motor4StepNeg>0</Motor4StepNeg>
    <Motor4StepPort>0</Motor4StepPort>
    <Motor4StepPin>0</Motor4StepPin>
    <Motor5Active>0</Motor5Active>
    <Motor5DirNeg>0</Motor5DirNeg>
    <Motor5DirPort>0</Motor5DirPort>
    <Motor5DirPin>0</Motor5DirPin>
    <Motor5StepNeg>0</Motor5StepNeg>
    <Motor5StepPort>0</Motor5StepPort>
    <Motor5StepPin>0</Motor5StepPin>
    <Motor6Active>0</Motor6Active>
    <Motor6DirNeg>0</Motor6DirNeg>
    <Motor6DirPort>0</Motor6DirPort>
    <Motor6DirPin>0</Motor6DirPin>
    <Motor6StepNeg>0</Motor6StepNeg>
    <Motor6StepPort>0</Motor6StepPort>
    <Motor6StepPin>0</Motor6StepPin>
    <Input0Active>0</Input0Active>
    <Input0Port>0</Input0Port>
    <Input0Pin>0</Input0Pin>
    <Input0Neg>0</Input0Neg>
    <Input0Emulated>0</Input0Emulated>
    <Input0EmuKey>0</Input0EmuKey>
    <Input1Active>0</Input1Active>
    <Input1Port>0</Input1Port>
    <Input1Pin>0</Input1Pin>
    <Input1Neg>0</Input1Neg>
    <Input1Emulated>0</Input1Emulated>
    <Input1EmuKey>0</Input1EmuKey>
    <Input2Active>0</Input2Active>
    <Input2Port>0</Input2Port>
    <Input2Pin>0</Input2Pin>
    <Input2Neg>0</Input2Neg>
    <Input2Emulated>0</Input2Emulated>
    <Input2EmuKey>0</Input2EmuKey>
    <Input3Active>0</Input3Active>
    <Input3Port>0</Input3Port>
    <Input3Pin>0</Input3Pin>
    <Input3Neg>0</Input3Neg>
    <Input3Emulated>0</Input3Emulated>
    <Input3EmuKey>0</Input3EmuKey>
    <Input4Active>0</Input4Active>
    <Input4Port>0</Input4Port>
    <Input4Pin>0</Input4Pin>
    <Input4Neg>0</Input4Neg>
    <Input4Emulated>0</Input4Emulated>
    <Input4EmuKey>0</Input4EmuKey>
    <Input5Active>0</Input5Active>
    <Input5Port>0</Input5Port>
    <Input5Pin>0</Input5Pin>
    <Input5Neg>0</Input5Neg>
    <Input5Emulated>0</Input5Emulated>
    <Input5EmuKey>0</Input5EmuKey>
    <Input6Active>0</Input6Active>
    <Input6Port>0</Input6Port>
    <Input6Pin>0</Input6Pin>
    <Input6Neg>0</Input6Neg>
    <Input6Emulated>0</Input6Emulated>
    <Input6EmuKey>0</Input6EmuKey>
    <Input7Active>0</Input7Active>
    <Input7Port>0</Input7Port>
    <Input7Pin>0</Input7Pin>
    <Input7Neg>0</Input7Neg>
    <Input7Emulated>0</Input7Emulated>
    <Input7EmuKey>0</Input7EmuKey>
    <Input8Active>0</Input8Active>
    <Input8Port>0</Input8Port>
    <Input8Pin>0</Input8Pin>
    <Input8Neg>0</Input8Neg>
    <Input8Emulated>0</Input8Emulated>
    <Input8EmuKey>0</Input8EmuKey>
    <Input9Active>0</Input9Active>
    <Input9Port>0</Input9Port>
    <Input9Pin>0</Input9Pin>
    <Input9Neg>0</Input9Neg>
    <Input9Emulated>0</Input9Emulated>
    <Input9EmuKey>0</Input9EmuKey>
    <Input10Active>0</Input10Active>
    <Input10Port>0</Input10Port>
    <Input10Pin>0</Input10Pin>
    <Input10Neg>0</Input10Neg>
    <Input10Emulated>0</Input10Emulated>
    <Input10EmuKey>0</Input10EmuKey>
    <Input11Active>0</Input11Active>
    <Input11Port>0</Input11Port>
    <Input11Pin>0</Input11Pin>
    <Input11Neg>0</Input11Neg>
    <Input11Emulated>0</Input11Emulated>
    <Input11EmuKey>0</Input11EmuKey>
    <Input12Active>0</Input12Active>
    <Input12Port>0</Input12Port>
    <Input12Pin>0</Input12Pin>
    <Input12Neg>0</Input12Neg>
    <Input12Emulated>0</Input12Emulated>
    <Input12EmuKey>0</Input12EmuKey>
    <Input13Active>0</Input13Active>
    <Input13Port>0</Input13Port>
    <Input13Pin>0</Input13Pin>
    <Input13Neg>0</Input13Neg>
    <Input13Emulated>0</Input13Emulated>
    <Input13EmuKey>0</Input13EmuKey>
    <Input14Active>0</Input14Active>
    <Input14Port>0</Input14Port>
    <Input14Pin>0</Input14Pin>
    <Input14Neg>0</Input14Neg>
    <Input14Emulated>0</Input14Emulated>
    <Input14EmuKey>0</Input14EmuKey>
    <Input15Active>0</Input15Active>
    <Input15Port>0</Input15Port>
    <Input15Pin>0</Input15Pin>
    <Input15Neg>0</Input15Neg>
    <Input15Emulated>0</Input15Emulated>
    <Input15EmuKey>0</Input15EmuKey>
    <Input16Active>0</Input16Active>
    <Input16Port>0</Input16Port>
    <Input16Pin>0</Input16Pin>
    <Input16Neg>0</Input16Neg>
    <Input16Emulated>0</Input16Emulated>
    <Input16EmuKey>0</Input16EmuKey>
    <Input17Active>0</Input17Active>
    <Input17Port>0</Input17Port>
    <Input17Pin>0</Input17Pin>
    <Input17Neg>0</Input17Neg>
    <Input17Emulated>0</Input17Emulated>
    <Input17EmuKey>0</Input17EmuKey>
    <Input18Active>0</Input18Active>
    <Input18Port>0</Input18Port>
    <Input18Pin>0</Input18Pin>
    <Input18Neg>0</Input18Neg>
    <Input18Emulated>0</Input18Emulated>
    <Input18EmuKey>0</Input18EmuKey>
    <Input19Active>0</Input19Active>
    <Input19Port>0</Input19Port>
    <Input19Pin>0</Input19Pin>
    <Input19Neg>0</Input19Neg>
    <Input19Emulated>0</Input19Emulated>
    <Input19EmuKey>0</Input19EmuKey>
    <Input20Active>0</Input20Active>
    <Input20Port>0</Input20Port>
    <Input20Pin>0</Input20Pin>
    <Input20Neg>0</Input20Neg>
    <Input20Emulated>0</Input20Emulated>
    <Input20EmuKey>0</Input20EmuKey>
    <Input21Active>0</Input21Active>
    <Input21Port>0</Input21Port>
    <Input21Pin>0</Input21Pin>
    <Input21Neg>0</Input21Neg>
    <Input21Emulated>0</Input21Emulated>
    <Input21EmuKey>0</Input21EmuKey>
    <Input22Active>0</Input22Active>
    <Input22Port>1</Input22Port>
    <Input22Pin>13</Input22Pin>
    <Input22Neg>0</Input22Neg>
    <Input22Emulated>0</Input22Emulated>
    <Input22EmuKey>0</Input22EmuKey>
    <Input23Active>0</Input23Active>
    <Input23Port>0</Input23Port>
    <Input23Pin>0</Input23Pin>
    <Input23Neg>0</Input23Neg>
    <Input23Emulated>0</Input23Emulated>
    <Input23EmuKey>0</Input23EmuKey>
    <Input24Active>0</Input24Active>
    <Input24Port>0</Input24Port>
    <Input24Pin>0</Input24Pin>
    <Input24Neg>0</Input24Neg>
    <Input24Emulated>0</Input24Emulated>
    <Input24EmuKey>0</Input24EmuKey>
    <Input25Active>1</Input25Active>
    <Input25Port>1</Input25Port>
    <Input25Pin>10</Input25Pin>
    <Input25Neg>1</Input25Neg>
    <Input25Emulated>0</Input25Emulated>
    <Input25EmuKey>0</Input25EmuKey>
    <Input26Active>0</Input26Active>
    <Input26Port>0</Input26Port>
    <Input26Pin>0</Input26Pin>
    <Input26Neg>0</Input26Neg>
    <Input26Emulated>0</Input26Emulated>
    <Input26EmuKey>0</Input26EmuKey>
    <Input27Active>0</Input27Active>
    <Input27Port>0</Input27Port>
    <Input27Pin>0</Input27Pin>
    <Input27Neg>0</Input27Neg>
    <Input27Emulated>0</Input27Emulated>
    <Input27EmuKey>0</Input27EmuKey>
    <Input28Active>0</Input28Active>
    <Input28Port>0</Input28Port>
    <Input28Pin>0</Input28Pin>
    <Input28Neg>0</Input28Neg>
    <Input28Emulated>0</Input28Emulated>
    <Input28EmuKey>0</Input28EmuKey>
    <Input29Active>0</Input29Active>
    <Input29Port>0</Input29Port>
    <Input29Pin>0</Input29Pin>
    <Input29Neg>0</Input29Neg>
    <Input29Emulated>0</Input29Emulated>
    <Input29EmuKey>0</Input29EmuKey>
    <Input30Active>0</Input30Active>
    <Input30Port>0</Input30Port>
    <Input30Pin>0</Input30Pin>
    <Input30Neg>0</Input30Neg>
    <Input30Emulated>0</Input30Emulated>
    <Input30EmuKey>0</Input30EmuKey>
    <Input31Active>0</Input31Active>
    <Input31Port>0</Input31Port>
    <Input31Pin>0</Input31Pin>
    <Input31Neg>0</Input31Neg>
    <Input31Emulated>0</Input31Emulated>
    <Input31EmuKey>0</Input31EmuKey>
    <Input32Active>0</Input32Active>
    <Input32Port>0</Input32Port>
    <Input32Pin>0</Input32Pin>
    <Input32Neg>0</Input32Neg>
    <Input32Emulated>0</Input32Emulated>
    <Input32EmuKey>0</Input32EmuKey>
    <Input33Active>0</Input33Active>
    <Input33Port>0</Input33Port>
    <Input33Pin>0</Input33Pin>
    <Input33Neg>0</Input33Neg>
    <Input33Emulated>0</Input33Emulated>
    <Input33EmuKey>0</Input33EmuKey>
    <Input34Active>0</Input34Active>
    <Input34Port>0</Input34Port>
    <Input34Pin>0</Input34Pin>
    <Input34Neg>0</Input34Neg>
    <Input34Emulated>0</Input34Emulated>
    <Input34EmuKey>0</Input34EmuKey>
    <Input35Active>0</Input35Active>
    <Input35Port>0</Input35Port>
    <Input35Pin>0</Input35Pin>
    <Input35Neg>0</Input35Neg>
    <Input35Emulated>0</Input35Emulated>
    <Input35EmuKey>0</Input35EmuKey>
    <Input36Active>0</Input36Active>
    <Input36Port>0</Input36Port>
    <Input36Pin>0</Input36Pin>
    <Input36Neg>0</Input36Neg>
    <Input36Emulated>0</Input36Emulated>
    <Input36EmuKey>0</Input36EmuKey>
    <Input37Active>0</Input37Active>
    <Input37Port>0</Input37Port>
    <Input37Pin>0</Input37Pin>
    <Input37Neg>0</Input37Neg>
    <Input37Emulated>0</Input37Emulated>
    <Input37EmuKey>0</Input37EmuKey>
    <Input38Active>0</Input38Active>
    <Input38Port>0</Input38Port>
    <Input38Pin>0</Input38Pin>
    <Input38Neg>0</Input38Neg>
    <Input38Emulated>0</Input38Emulated>
    <Input38EmuKey>0</Input38EmuKey>
    <Input39Active>0</Input39Active>
    <Input39Port>0</Input39Port>
    <Input39Pin>0</Input39Pin>
    <Input39Neg>0</Input39Neg>
    <Input39Emulated>0</Input39Emulated>
    <Input39EmuKey>0</Input39EmuKey>
    <Input40Active>0</Input40Active>
    <Input40Port>0</Input40Port>
    <Input40Pin>0</Input40Pin>
    <Input40Neg>0</Input40Neg>
    <Input40Emulated>0</Input40Emulated>
    <Input40EmuKey>0</Input40EmuKey>
    <Input41Active>0</Input41Active>
    <Input41Port>0</Input41Port>
    <Input41Pin>0</Input41Pin>
    <Input41Neg>0</Input41Neg>
    <Input41Emulated>0</Input41Emulated>
    <Input41EmuKey>0</Input41EmuKey>
    <Input42Active>0</Input42Active>
    <Input42Port>0</Input42Port>
    <Input42Pin>0</Input42Pin>
    <Input42Neg>0</Input42Neg>
    <Input42Emulated>0</Input42Emulated>
    <Input42EmuKey>0</Input42EmuKey>
    <Input43Active>0</Input43Active>
    <Input43Port>0</Input43Port>
    <Input43Pin>0</Input43Pin>
    <Input43Neg>0</Input43Neg>
    <Input43Emulated>0</Input43Emulated>
    <Input43EmuKey>0</Input43EmuKey>
    <Input44Active>0</Input44Active>
    <Input44Port>0</Input44Port>
    <Input44Pin>0</Input44Pin>
    <Input44Neg>0</Input44Neg>
    <Input44Emulated>0</Input44Emulated>
    <Input44EmuKey>0</Input44EmuKey>
    <Input45Active>0</Input45Active>
    <Input45Port>0</Input45Port>
    <Input45Pin>0</Input45Pin>
    <Input45Neg>0</Input45Neg>
    <Input45Emulated>0</Input45Emulated>
    <Input45EmuKey>0</Input45EmuKey>
    <Input46Active>0</Input46Active>
    <Input46Port>0</Input46Port>
    <Input46Pin>0</Input46Pin>
    <Input46Neg>0</Input46Neg>
    <Input46Emulated>0</Input46Emulated>
    <Input46EmuKey>0</Input46EmuKey>
    <Input47Active>0</Input47Active>
    <Input47Port>0</Input47Port>
    <Input47Pin>0</Input47Pin>
    <Input47Neg>0</Input47Neg>
    <Input47Emulated>0</Input47Emulated>
    <Input47EmuKey>0</Input47EmuKey>
    <Input48Active>0</Input48Active>
    <Input48Port>0</Input48Port>
    <Input48Pin>0</Input48Pin>
    <Input48Neg>0</Input48Neg>
    <Input48Emulated>0</Input48Emulated>
    <Input48EmuKey>0</Input48EmuKey>
    <Input49Active>0</Input49Active>
    <Input49Port>0</Input49Port>
    <Input49Pin>0</Input49Pin>
    <Input49Neg>0</Input49Neg>
    <Input49Emulated>0</Input49Emulated>
    <Input49EmuKey>0</Input49EmuKey>
    <Input50Active>0</Input50Active>
    <Input50Port>0</Input50Port>
    <Input50Pin>0</Input50Pin>
    <Input50Neg>0</Input50Neg>
    <Input50Emulated>0</Input50Emulated>
    <Input50EmuKey>0</Input50EmuKey>
    <Input51Active>0</Input51Active>
    <Input51Port>0</Input51Port>
    <Input51Pin>0</Input51Pin>
    <Input51Neg>0</Input51Neg>
    <Input51Emulated>0</Input51Emulated>
    <Input51EmuKey>0</Input51EmuKey>
    <Input52Active>0</Input52Active>
    <Input52Port>0</Input52Port>
    <Input52Pin>0</Input52Pin>
    <Input52Neg>0</Input52Neg>
    <Input52Emulated>0</Input52Emulated>
    <Input52EmuKey>0</Input52EmuKey>
    <Output0Active>0</Output0Active>
    <Output0Port>0</Output0Port>
    <Output0Pin>0</Output0Pin>
    <Output0Neg>0</Output0Neg>
    <Output1Active>1</Output1Active>
    <Output1Port>1</Output1Port>
    <Output1Pin>1</Output1Pin>
    <Output1Neg>0</Output1Neg>
    <Output2Active>0</Output2Active>
    <Output2Port>0</Output2Port>
    <Output2Pin>0</Output2Pin>
    <Output2Neg>0</Output2Neg>
    <Output3Active>0</Output3Active>
    <Output3Port>0</Output3Port>
    <Output3Pin>0</Output3Pin>
    <Output3Neg>0</Output3Neg>
    <Output4Active>0</Output4Active>
    <Output4Port>0</Output4Port>
    <Output4Pin>0</Output4Pin>
    <Output4Neg>0</Output4Neg>
    <Output5Active>0</Output5Active>
    <Output5Port>0</Output5Port>
    <Output5Pin>0</Output5Pin>
    <Output5Neg>0</Output5Neg>
    <Output6Active>0</Output6Active>
    <Output6Port>0</Output6Port>
    <Output6Pin>0</Output6Pin>
    <Output6Neg>0</Output6Neg>
    <Output7Active>1</Output7Active>
    <Output7Port>1</Output7Port>
    <Output7Pin>16</Output7Pin>
    <Output7Neg>0</Output7Neg>
    <Output8Active>1</Output8Active>
    <Output8Port>1</Output8Port>
    <Output8Pin>17</Output8Pin>
    <Output8Neg>1</Output8Neg>
    <Output9Active>0</Output9Active>
    <Output9Port>0</Output9Port>
    <Output9Pin>0</Output9Pin>
    <Output9Neg>0</Output9Neg>
    <Output10Active>0</Output10Active>
    <Output10Port>0</Output10Port>
    <Output10Pin>0</Output10Pin>
    <Output10Neg>0</Output10Neg>
    <Output11Active>0</Output11Active>
    <Output11Port>0</Output11Port>
    <Output11Pin>0</Output11Pin>
    <Output11Neg>0</Output11Neg>
    <Output12Active>0</Output12Active>
    <Output12Port>0</Output12Port>
    <Output12Pin>0</Output12Pin>
    <Output12Neg>0</Output12Neg>
    <Output13Active>0</Output13Active>
    <Output13Port>1</Output13Port>
    <Output13Pin>1</Output13Pin>
    <Output13Neg>0</Output13Neg>
    <Output14Active>0</Output14Active>
    <Output14Port>0</Output14Port>
    <Output14Pin>0</Output14Pin>
    <Output14Neg>0</Output14Neg>
    <Output15Active>0</Output15Active>
    <Output15Port>0</Output15Port>
    <Output15Pin>0</Output15Pin>
    <Output15Neg>0</Output15Neg>
    <Output16Active>0</Output16Active>
    <Output16Port>0</Output16Port>
    <Output16Pin>0</Output16Pin>
    <Output16Neg>0</Output16Neg>
    <Output17Active>0</Output17Active>
    <Output17Port>0</Output17Port>
    <Output17Pin>0</Output17Pin>
    <Output17Neg>0</Output17Neg>
    <Output18Active>0</Output18Active>
    <Output18Port>0</Output18Port>
    <Output18Pin>0</Output18Pin>
    <Output18Neg>0</Output18Neg>
    <Output19Active>0</Output19Active>
    <Output19Port>0</Output19Port>
    <Output19Pin>0</Output19Pin>
    <Output19Neg>0</Output19Neg>
    <Output20Active>0</Output20Active>
    <Output20Port>0</Output20Port>
    <Output20Pin>0</Output20Pin>
    <Output20Neg>0</Output20Neg>
    <Output21Active>0</Output21Active>
    <Output21Port>0</Output21Port>
    <Output21Pin>0</Output21Pin>
    <Output21Neg>0</Output21Neg>
    <Output22Active>0</Output22Active>
    <Output22Port>0</Output22Port>
    <Output22Pin>0</Output22Pin>
    <Output22Neg>0</Output22Neg>
    <Output23Active>0</Output23Active>
    <Output23Port>0</Output23Port>
    <Output23Pin>0</Output23Pin>
    <Output23Neg>0</Output23Neg>
    <Output24Active>0</Output24Active>
    <Output24Port>0</Output24Port>
    <Output24Pin>0</Output24Pin>
    <Output24Neg>0</Output24Neg>
    <Output25Active>0</Output25Active>
    <Output25Port>0</Output25Port>
    <Output25Pin>0</Output25Pin>
    <Output25Neg>0</Output25Neg>
    <Output26Active>0</Output26Active>
    <Output26Port>0</Output26Port>
    <Output26Pin>0</Output26Pin>
    <Output26Neg>0</Output26Neg>
    <Output27Active>0</Output27Active>
    <Output27Port>0</Output27Port>
    <Output27Pin>0</Output27Pin>
    <Output27Neg>0</Output27Neg>
    <Output28Active>0</Output28Active>
    <Output28Port>0</Output28Port>
    <Output28Pin>0</Output28Pin>
    <Output28Neg>0</Output28Neg>
    <Output29Active>0</Output29Active>
    <Output29Port>0</Output29Port>
    <Output29Pin>0</Output29Pin>
    <Output29Neg>0</Output29Neg>
    <Output30Active>0</Output30Active>
    <Output30Port>0</Output30Port>
    <Output30Pin>0</Output30Pin>
    <Output30Neg>0</Output30Neg>
    <Encoder0Active>0</Encoder0Active>
    <Encoder0APort>0</Encoder0APort>
    <Encoder0APin>0</Encoder0APin>
    <Encoder0BPort>0</Encoder0BPort>
    <Encoder0BPin>0</Encoder0BPin>
    <Encoder0Cal>1.00</Encoder0Cal>
    <Encoder1Active>0</Encoder1Active>
    <Encoder1APort>0</Encoder1APort>
    <Encoder1APin>0</Encoder1APin>
    <Encoder1BPort>0</Encoder1BPort>
    <Encoder1BPin>0</Encoder1BPin>
    <Encoder1Cal>1.00</Encoder1Cal>
    <Encoder2Active>0</Encoder2Active>
    <Encoder2APort>0</Encoder2APort>
    <Encoder2APin>0</Encoder2APin>
    <Encoder2BPort>0</Encoder2BPort>
    <Encoder2BPin>0</Encoder2BPin>
    <Encoder2Cal>1.00</Encoder2Cal>
    <Encoder3Active>0</Encoder3Active>
    <Encoder3APort>0</Encoder3APort>
    <Encoder3APin>0</Encoder3APin>
    <Encoder3BPort>0</Encoder3BPort>
    <Encoder3BPin>0</Encoder3BPin>
    <Encoder3Cal>1.00</Encoder3Cal>
    <Encoder4Active>0</Encoder4Active>
    <Encoder4APort>0</Encoder4APort>
    <Encoder4APin>0</Encoder4APin>
    <Encoder4BPort>0</Encoder4BPort>
    <Encoder4BPin>0</Encoder4BPin>
    <Encoder4Cal>1.00</Encoder4Cal>
    <Encoder5Active>0</Encoder5Active>
    <Encoder5APort>0</Encoder5APort>
    <Encoder5APin>0</Encoder5APin>
    <Encoder5BPort>0</Encoder5BPort>
    <Encoder5BPin>0</Encoder5BPin>
    <Encoder5Cal>1.00</Encoder5Cal>
    <Encoder6Active>0</Encoder6Active>
    <Encoder6APort>0</Encoder6APort>
    <Encoder6APin>0</Encoder6APin>
    <Encoder6BPort>0</Encoder6BPort>
    <Encoder6BPin>0</Encoder6BPin>
    <Encoder6Cal>1.00</Encoder6Cal>
    <Encoder7Active>0</Encoder7Active>
    <Encoder7APort>0</Encoder7APort>
    <Encoder7APin>0</Encoder7APin>
    <Encoder7BPort>0</Encoder7BPort>
    <Encoder7BPin>0</Encoder7BPin>
    <Encoder7Cal/>
    <Configured>1</Configured>
    <SlavePrim>0</SlavePrim>
    <Slave>-1</Slave>
    <AxisKeys0>39</AxisKeys0>
    <AxisKeys1>37</AxisKeys1>
    <AxisKeys2>38</AxisKeys2>
    <AxisKeys3>40</AxisKeys3>
    <AxisKeys4>33</AxisKeys4>
    <AxisKeys5>34</AxisKeys5>
    <AxisKeys6>36</AxisKeys6>
    <AxisKeys7>35</AxisKeys7>
    <AxisKeys8>999</AxisKeys8>
    <AxisKeys9>999</AxisKeys9>
    <AxisKeys10>999</AxisKeys10>
    <AxisKeys11>999</AxisKeys11>
    <DROHotKey>999</DROHotKey>
    <ListKey>0</ListKey>
    <MDIHotKey>999</MDIHotKey>
    <GCodeHotKey>999</GCodeHotKey>
    <OEM1>-1</OEM1>
    <OEM2>-1</OEM2>
    <OEM3>-1</OEM3>
    <OEM4>-1</OEM4>
    <OEM5>-1</OEM5>
    <OEM6>-1</OEM6>
    <PulseWidth>2</PulseWidth>
    <DirPulse>0</DirPulse>
    <BackX>2.5e-002</BackX>
    <BackY>2.5e-002</BackY>
    <BackZ>6.25e-002</BackZ>
    <BackA>0.</BackA>
    <BackB>0.</BackB>
    <BackC>0.</BackC>
    <BackSpeed>5.</BackSpeed>
    <BB>0.0</BB>
    <BR>0.0</BR>
    <BG>0.0</BG>
    <FB>1.0</FB>
    <FR>0.0</FR>
    <FG>0.0</FG>
    <RB>0.0</RB>
    <RR>1.0</RR>
    <RG>0.0</RG>
    <AB>0.7</AB>
    <AR>0.7</AR>
    <AG>0.2</AG>
    <EG>1.0</EG>
    <ER>1.0</ER>
    <EB>0.0</EB>
    <JogFollow>0</JogFollow>
    <G92Off>0</G92Off>
    <RadiusCompOff>1</RadiusCompOff>
    <Debounce>0</Debounce>
    <PlasmaMode>0</PlasmaMode>
    <NoAngle>1</NoAngle>
    <AAngular>1</AAngular>
    <BAngular>1</BAngular>
    <CAngular>1</CAngular>
    <IndexDebounce>0</IndexDebounce>
    <DROPERSIST>0</DROPERSIST>
    <DwellinMilli>0</DwellinMilli>
    <IJMode>1</IJMode>
    <INIT>G80,G21</INIT>
    <InitAllResets>0</InitAllResets>
    <AutoScreens>0</AutoScreens>
    <TORCHVON>0</TORCHVON>
    <TORCHVOLTS>0</TORCHVOLTS>
    <HWSAFE>1</HWSAFE>
    <ShortRot>0</ShortRot>
    <LookAhead>20</LookAhead>
    <WatchDog>1</WatchDog>
    <Plane>0</Plane>
    <MPG1>0</MPG1>
    <MPG2>0</MPG2>
    <HotKeysPersist>0</HotKeysPersist>
    <HoldInput1>0</HoldInput1>
    <M3s>5349</M3s>
    <UseCR>0</UseCR>
    <PlasmaHome>0</PlasmaHome>
    <Homann>0</Homann>
    <UseSLS>0</UseSLS>
    <Dist0>6.6e+005</Dist0>
    <Dist1>6.e+005</Dist1>
    <Dist2>2.5e+005</Dist2>
    <Dist3>1.1e+004</Dist3>
    <Dist4>0.</Dist4>
    <Dist5>0.</Dist5>
    <OverMode2>0</OverMode2>
    <BitPack1>0</BitPack1>
    <BitPack1Reg>16</BitPack1Reg>
    <BitPackOut>0</BitPackOut>
    <BitPackOutReg>16</BitPackOutReg>
    <LaserPort>1</LaserPort>
    <LaserBaud>9600</LaserBaud>
    <LaserStops>1</LaserStops>
    <LaserData>1</LaserData>
    <LaserInit>></LaserInit>
    <LaserCommand>></LaserCommand>
    <MacroPump>0</MacroPump>
    <VelMode>0</VelMode>
    <VelPer1>5.</VelPer1>
    <VelPer2>5.</VelPer2>
    <MPGFeed>1.e+002</MPGFeed>
    <ModSpindleCal>1.638e+004</ModSpindleCal>
    <ModSpindleOn>0</ModSpindleOn>
    <ModSpindleReg>64</ModSpindleReg>
    <ShuttleAccel>2048</ShuttleAccel>
    <Flash>1</Flash>
    <ImmediateOff>0</ImmediateOff>
    <UseSafeZ>0</UseSafeZ>
    <AdvancedComp>1</AdvancedComp>
    <TorchOff>0</TorchOff>
    <LaserStandby>0</LaserStandby>
    <RaiseLower>0</RaiseLower>
    <OEMDUAL>0</OEMDUAL>
    <IncBuffer>5</IncBuffer>
    <Formula0>x</Formula0>
    <Formula1>y</Formula1>
    <Formula2>z</Formula2>
    <Formula3>a</Formula3>
    <Formula4>b</Formula4>
    <Formula5>c</Formula5>
    <Formular>0</Formular>
    <PanelOut>249</PanelOut>
    <nModBusReg>0</nModBusReg>
    <ModBusRegOn>0</ModBusRegOn>
    <Tool>0</Tool>
    <Sherline>0</Sherline>
    <ToolPost>1</ToolPost>
    <RapidOverRide>0</RapidOverRide>
    <XCLength>1.3e+003</XCLength>
    <YCLength>1.3e+003</YCLength>
    <ZCLength>1.3e+003</ZCLength>
    <ToolPostOffset>0.</ToolPostOffset>
    <OEM7>-1</OEM7>
    <OEM8>-1</OEM8>
    <OEM9>-1</OEM9>
    <OEM10>-1</OEM10>
    <OEM11>-1</OEM11>
    <OEM12>-1</OEM12>
    <OEM13>-1</OEM13>
    <OEM14>-1</OEM14>
    <OEM15>-1</OEM15>
    <MPGVel0>1.e+002</MPGVel0>
    <MPGVel1>1.e+002</MPGVel1>
    <MPGVel2>1.e+002</MPGVel2>
    <MPGVel3>1.e+002</MPGVel3>
    <MPGVel4>1.e+002</MPGVel4>
    <MPGVel5>1.e+002</MPGVel5>
    <MPGVel6>1.e+002</MPGVel6>
    <ByPassFeed>1.e+003</ByPassFeed>
    <XMapOn>0</XMapOn>
    <YMapOn>0</YMapOn>
    <ZMapOn>0</ZMapOn>
    <SecondsOn>7771065</SecondsOn>
    <SerialType>0</SerialType>
    <SpinAverage>0</SpinAverage>
    <Dig4Axis>0</Dig4Axis>
    <DigLetter>0</DigLetter>
    <CutType>0</CutType>
    <InfeedType>0</InfeedType>
    <LastWizard>C:\Mach3\Addons\Cut spline or gear\Spline or gear.set</LastWizard>
    <Z25D>0</Z25D>
    <ModBus>0</ModBus>
    <ChargeAlwaysOn>0</ChargeAlwaysOn>
    <ToolFlip>0</ToolFlip>
    <SpinCCW>9</SpinCCW>
    <SpinCW>7</SpinCW>
    <Flood>8</Flood>
    <Mist>10</Mist>
    <SpinActual>0</SpinActual>
    <SpinDelayCW>2.</SpinDelayCW>
    <SpinDelayCCW>2.</SpinDelayCCW>
    <SpinDownCW>1.</SpinDownCW>
    <SpinDownCCW>2.</SpinDownCCW>
    <StockSize>50</StockSize>
    <ShowSolid>0</ShowSolid>
    <RapidFeed>1.e+003</RapidFeed>
    <MatRed>0.</MatRed>
    <MatGreen>0.1</MatGreen>
    <MatBlue>0.1</MatBlue>
    <SpinP>0.25</SpinP>
    <SpinI>1.</SpinI>
    <SpinD>0.3</SpinD>
    <SpinClosed>0</SpinClosed>
    <MinPerPass>0.1</MinPerPass>
    <NoSpindle>0</NoSpindle>
    <NoFlood>0</NoFlood>
    <PWMin>0</PWMin>
    <PULLEY>1</PULLEY>
    <SPEED1>1000</SPEED1>
    <SPEED2>2000</SPEED2>
    <SPEED3>4000</SPEED3>
    <SPEED4>8000</SPEED4>
    <LSPEED1>0</LSPEED1>
    <LSPEED2>0</LSPEED2>
    <LSPEED3>0</LSPEED3>
    <LSPEED4>0</LSPEED4>
    <PWM>0</PWM>
    <RefSpeed0>20</RefSpeed0>
    <RefSpeed1>20</RefSpeed1>
    <RefSpeed2>20</RefSpeed2>
    <RefSpeed3>20</RefSpeed3>
    <RefSpeed4>20</RefSpeed4>
    <RefSpeed5>20</RefSpeed5>
    <M0SoftRamp>0.5</M0SoftRamp>
    <M1SoftRamp>0.5</M1SoftRamp>
    <M2SoftRamp>0.5</M2SoftRamp>
    <M3SoftRamp>1.</M3SoftRamp>
    <M4SoftRamp>1.</M4SoftRamp>
    <M5SoftRamp>1.</M5SoftRamp>
    <FeedInc>5.</FeedInc>
    <DepthLastPass>0.</DepthLastPass>
    <InFeed>29.5</InFeed>
    <Spring>1.</Spring>
    <MinDepth>1.e-003</MinDepth>
    <XClear>0.1</XClear>
    <ZClear>0.1</ZClear>
    <CutDepth>0.1</CutDepth>
    <Chamfer>0.</Chamfer>
    <DepthFirstPass>0.1</DepthFirstPass>
    <M0Max>5.</M0Max>
    <M1Max>2.</M1Max>
    <M2Max>3.</M2Max>
    <M3Max>100.</M3Max>
    <M4Max>100.</M4Max>
    <M5Max>100.</M5Max>
    <M0Min>-5.</M0Min>
    <M1Min>-2.5</M1Min>
    <M2Min>-1.</M2Min>
    <M3Min>-100.</M3Min>
    <M4Min>-100.</M4Min>
    <M5Min>-100.</M5Min>
    <M0Neg>0</M0Neg>
    <M1Neg>0</M1Neg>
    <M2Neg>0</M2Neg>
    <M3Neg>0</M3Neg>
    <M4Neg>0</M4Neg>
    <M5Neg>0</M5Neg>
    <M0AutoZero>1</M0AutoZero>
    <M1AutoZero>1</M1AutoZero>
    <M2AutoZero>1</M2AutoZero>
    <M3AutoZero>1</M3AutoZero>
    <M4AutoZero>1</M4AutoZero>
    <M5AutoZero>1</M5AutoZero>
    <M0Rev>0</M0Rev>
    <M1Rev>0</M1Rev>
    <M2Rev>0</M2Rev>
    <M3Rev>0</M3Rev>
    <M4Rev>0</M4Rev>
    <M5Rev>0</M5Rev>
    <M6Rev>0</M6Rev>
    <OffPersist>0</OffPersist>
    <Diameter>0</Diameter>
    <OffDialogs>0</OffDialogs>
    <G54Back>0</G54Back>
    <GougeCheck>0</GougeCheck>
    <AxisToMotor0>0</AxisToMotor0>
    <AxisToMotor1>1</AxisToMotor1>
    <AxisToMotor2>2</AxisToMotor2>
    <AxisToMotor3>3</AxisToMotor3>
    <AxisToMotor4>4</AxisToMotor4>
    <AxisToMotor5>5</AxisToMotor5>
    <AxisToMotor6>6</AxisToMotor6>
    <JogActive>1</JogActive>
    <BLState0>1</BLState0>
    <BLState1>0</BLState1>
    <BLState2>0</BLState2>
    <BLState3>1</BLState3>
    <BLState4>0</BLState4>
    <BLState5>0</BLState5>
    <SlowMode>0</SlowMode>
    <JogPersist>1</JogPersist>
    <ToolRotations>0</ToolRotations>
    <SoftLimit>0</SoftLimit>
    <JogMode>0</JogMode>
    <JogMode2>0</JogMode2>
    <EncJogAxis2>2</EncJogAxis2>
    <TaperRatio>1.</TaperRatio>
    <XStart>0</XStart>
    <YStart>0</YStart>
    <ZStart>0</ZStart>
    <AStart>0</AStart>
    <BStart>0</BStart>
    <CStart>0</CStart>
    <SpinInc>10</SpinInc>
    <Enc0>0.</Enc0>
    <Enc1>0.</Enc1>
    <Enc2>0.</Enc2>
    <Enc3>0.</Enc3>
    <TangentalControl>0</TangentalControl>
    <BaudRate>9600</BaudRate>
    <ComPort>1</ComPort>
    <NoPlunge>0</NoPlunge>
    <PlungeLimit>60</PlungeLimit>
    <AutoTool>0</AutoTool>
    <AutoSpindle>0</AutoSpindle>
    <LaserMode>0</LaserMode>
    <FeedMode>0</FeedMode>
    <OriginSphere>0</OriginSphere>
    <m_3dCompass>1</m_3dCompass>
    <Boundries>0</Boundries>
    <ToolPosition>1</ToolPosition>
    <AParallel>0</AParallel>
    <ZINHPersist>0</ZINHPersist>
    <OVPersist>1</OVPersist>
    <BacklashOn>0</BacklashOn>
    <PathMode>2</PathMode>
    <ThrottleFunc>2</ThrottleFunc>
    <JoyOn>0</JoyOn>
    <PWMBase>5000</PWMBase>
    <JogSpeed>50.</JogSpeed>
    <G73PullBack>0.1</G73PullBack>
    <CVFeedOn>0</CVFeedOn>
    <CVFeedRate>1.</CVFeedRate>
    <AtoX>0.</AtoX>
    <AtoY>0.</AtoY>
    <AtoZ>0.</AtoZ>
    <OEMDRO0>0.</OEMDRO0>
    <OEMLED0>1</OEMLED0>
    <OEMDRO1>4.</OEMDRO1>
    <OEMLED1>0</OEMLED1>
    <OEMDRO2>9.e-004</OEMDRO2>
    <OEMLED2>0</OEMLED2>
    <OEMDRO3>4000.</OEMDRO3>
    <OEMLED3>1</OEMLED3>
    <OEMDRO4>0.125</OEMDRO4>
    <OEMLED4>1</OEMLED4>
    <OEMDRO5>763.9</OEMDRO5>
    <OEMLED5>0</OEMLED5>
    <OEMDRO6>2.8</OEMDRO6>
    <OEMLED6>0</OEMLED6>
    <OEMDRO7>4.</OEMDRO7>
    <OEMLED7>0</OEMLED7>
    <OEMDRO8>100.</OEMDRO8>
    <OEMLED8>1</OEMLED8>
    <OEMDRO9>100.</OEMDRO9>
    <OEMLED9>0</OEMLED9>
    <OEMDRO10>5.</OEMDRO10>
    <OEMLED10>0</OEMLED10>
    <OEMDRO11>0.</OEMDRO11>
    <OEMLED11>0</OEMLED11>
    <OEMDRO12>2.</OEMDRO12>
    <OEMLED12>0</OEMLED12>
    <OEMDRO13>0.</OEMDRO13>
    <OEMLED13>0</OEMLED13>
    <OEMDRO14>5.</OEMDRO14>
    <OEMLED14>0</OEMLED14>
    <OEMDRO15>-1.</OEMDRO15>
    <OEMLED15>0</OEMLED15>
    <OEMDRO16>0.125</OEMDRO16>
    <OEMLED16>1</OEMLED16>
    <OEMDRO17>-0.25</OEMDRO17>
    <OEMLED17>0</OEMLED17>
    <OEMDRO18>100.</OEMDRO18>
    <OEMLED18>0</OEMLED18>
    <OEMDRO19>0.</OEMDRO19>
    <OEMLED19>0</OEMLED19>
    <OEMDRO20>5.</OEMDRO20>
    <OEMLED20>1</OEMLED20>
    <OEMDRO21>0.</OEMDRO21>
    <OEMLED21>0</OEMLED21>
    <OEMDRO22>3.</OEMDRO22>
    <OEMLED22>1</OEMLED22>
    <OEMDRO23>0.1</OEMDRO23>
    <OEMLED23>0</OEMLED23>
    <OEMDRO24>70.</OEMDRO24>
    <OEMLED24>0</OEMLED24>
    <OEMDRO25>1.4</OEMDRO25>
    <OEMLED25>1</OEMLED25>
    <OEMDRO26>0.1</OEMDRO26>
    <OEMLED26>0</OEMLED26>
    <OEMDRO27>0.9</OEMDRO27>
    <OEMLED27>0</OEMLED27>
    <OEMDRO28>0.25</OEMDRO28>
    <OEMLED28>0</OEMLED28>
    <OEMDRO29>0.</OEMDRO29>
    <OEMLED29>0</OEMLED29>
    <OEMDRO30>5.</OEMDRO30>
    <OEMLED30>0</OEMLED30>
    <OEMDRO31>0.</OEMDRO31>
    <OEMLED31>1</OEMLED31>
    <OEMDRO32>0.9375</OEMDRO32>
    <OEMLED32>1</OEMLED32>
    <OEMDRO33>0.</OEMDRO33>
    <OEMLED33>0</OEMLED33>
    <OEMDRO34>180.</OEMDRO34>
    <OEMLED34>0</OEMLED34>
    <OEMDRO35>0.1</OEMDRO35>
    <OEMLED35>0</OEMLED35>
    <OEMDRO36>0.5</OEMDRO36>
    <OEMLED36>0</OEMLED36>
    <OEMDRO37>0.2</OEMDRO37>
    <OEMLED37>0</OEMLED37>
    <OEMDRO38>50.</OEMDRO38>
    <OEMLED38>0</OEMLED38>
    <OEMDRO39>0.</OEMDRO39>
    <OEMLED39>0</OEMLED39>
    <OEMDRO40>0.</OEMDRO40>
    <OEMLED40>0</OEMLED40>
    <OEMDRO41>0.</OEMDRO41>
    <OEMLED41>1</OEMLED41>
    <OEMDRO42>1.5</OEMDRO42>
    <OEMLED42>0</OEMLED42>
    <OEMDRO43>0.5</OEMDRO43>
    <OEMLED43>1</OEMLED43>
    <OEMDRO44>0.1</OEMDRO44>
    <OEMLED44>0</OEMLED44>
    <OEMDRO45>1.</OEMDRO45>
    <OEMLED45>0</OEMLED45>
    <OEMDRO46>0.125</OEMDRO46>
    <OEMLED46>0</OEMLED46>
    <OEMDRO47>0.</OEMDRO47>
    <OEMLED47>0</OEMLED47>
    <OEMDRO48>0.</OEMDRO48>
    <OEMLED48>0</OEMLED48>
    <OEMDRO49>0.</OEMDRO49>
    <OEMLED49>0</OEMLED49>
    <OEMDRO50>1.</OEMDRO50>
    <OEMLED50>1</OEMLED50>
    <OEMDRO51>3.</OEMDRO51>
    <OEMLED51>0</OEMLED51>
    <OEMDRO52>6.</OEMDRO52>
    <OEMLED52>0</OEMLED52>
    <OEMDRO53>-6.7e-002</OEMDRO53>
    <OEMLED53>0</OEMLED53>
    <OEMDRO54>-0.25</OEMDRO54>
    <OEMLED54>0</OEMLED54>
    <OEMDRO55>-0.25</OEMDRO55>
    <OEMLED55>0</OEMLED55>
    <OEMDRO56>0.125</OEMDRO56>
    <OEMLED56>0</OEMLED56>
    <OEMDRO57>20.</OEMDRO57>
    <OEMLED57>0</OEMLED57>
    <OEMDRO58>80.</OEMDRO58>
    <OEMLED58>0</OEMLED58>
    <OEMDRO59>1.</OEMDRO59>
    <OEMLED59>0</OEMLED59>
    <OEMDRO60>0.</OEMDRO60>
    <OEMLED60>1</OEMLED60>
    <OEMDRO61>0.</OEMDRO61>
    <OEMLED61>1</OEMLED61>
    <OEMDRO62>3.</OEMDRO62>
    <OEMLED62>1</OEMLED62>
    <OEMDRO63>3.</OEMDRO63>
    <OEMLED63>0</OEMLED63>
    <OEMDRO64>0.5</OEMDRO64>
    <OEMLED64>0</OEMLED64>
    <OEMDRO65>0.375</OEMDRO65>
    <OEMLED65>0</OEMLED65>
    <OEMDRO66>5.</OEMDRO66>
    <OEMLED66>0</OEMLED66>
    <OEMDRO67>0.125</OEMDRO67>
    <OEMLED67>0</OEMLED67>
    <OEMDRO68>0.125</OEMDRO68>
    <OEMLED68>0</OEMLED68>
    <OEMDRO69>2.5e-002</OEMDRO69>
    <OEMLED69>0</OEMLED69>
    <OEMDRO70>3.</OEMDRO70>
    <OEMLED70>0</OEMLED70>
    <OEMDRO71>6.</OEMDRO71>
    <OEMLED71>1</OEMLED71>
    <OEMDRO72>3.</OEMDRO72>
    <OEMLED72>0</OEMLED72>
    <OEMDRO73>3.</OEMDRO73>
    <OEMLED73>0</OEMLED73>
    <OEMDRO74>0.</OEMDRO74>
    <OEMLED74>0</OEMLED74>
    <OEMDRO75>0.</OEMDRO75>
    <OEMLED75>1</OEMLED75>
    <OEMDRO76>0.5</OEMDRO76>
    <OEMLED76>0</OEMLED76>
    <OEMDRO77>0.125</OEMDRO77>
    <OEMLED77>1</OEMLED77>
    <OEMDRO78>0.125</OEMDRO78>
    <OEMLED78>0</OEMLED78>
    <OEMDRO79>0.</OEMDRO79>
    <OEMLED79>0</OEMLED79>
    <OEMDRO80>5.</OEMDRO80>
    <OEMLED80>0</OEMLED80>
    <OEMDRO81>10.</OEMDRO81>
    <OEMLED81>0</OEMLED81>
    <OEMDRO82>69.</OEMDRO82>
    <OEMLED82>0</OEMLED82>
    <OEMDRO83>1.e-002</OEMDRO83>
    <OEMLED83>1</OEMLED83>
    <OEMDRO84>0.</OEMDRO84>
    <OEMLED84>0</OEMLED84>
    <OEMDRO85>0.</OEMDRO85>
    <OEMLED85>0</OEMLED85>
    <OEMDRO86>0.5</OEMDRO86>
    <OEMLED86>1</OEMLED86>
    <OEMDRO87>0.2</OEMDRO87>
    <OEMLED87>0</OEMLED87>
    <OEMDRO88>0.1</OEMDRO88>
    <OEMLED88>1</OEMLED88>
    <OEMDRO89>0.</OEMDRO89>
    <OEMLED89>0</OEMLED89>
    <OEMDRO90>1.</OEMDRO90>
    <OEMLED90>0</OEMLED90>
    <OEMDRO91>0.</OEMDRO91>
    <OEMLED91>0</OEMLED91>
    <OEMDRO92>0.</OEMDRO92>
    <OEMLED92>0</OEMLED92>
    <OEMDRO93>0.</OEMDRO93>
    <OEMLED93>0</OEMLED93>
    <OEMDRO94>0.</OEMDRO94>
    <OEMLED94>0</OEMLED94>
    <OEMDRO95>0.</OEMDRO95>
    <OEMLED95>0</OEMLED95>
    <OEMDRO96>0.</OEMDRO96>
    <OEMLED96>0</OEMLED96>
    <OEMDRO97>0.</OEMDRO97>
    <OEMLED97>0</OEMLED97>
    <OEMDRO98>0.</OEMDRO98>
    <OEMLED98>0</OEMLED98>
    <OEMDRO99>25.</OEMDRO99>
    <OEMLED99>0</OEMLED99>
    <OEMDRO100>0.</OEMDRO100>
    <OEMLED100>1</OEMLED100>
    <OEMDRO101>0.</OEMDRO101>
    <OEMLED101>0</OEMLED101>
    <OEMDRO102>1.</OEMDRO102>
    <OEMLED102>0</OEMLED102>
    <OEMDRO103>30.</OEMDRO103>
    <OEMLED103>0</OEMLED103>
    <OEMDRO104>4.</OEMDRO104>
    <OEMLED104>0</OEMLED104>
    <OEMDRO105>0.75</OEMDRO105>
    <OEMLED105>0</OEMLED105>
    <OEMDRO106>0.125</OEMDRO106>
    <OEMLED106>0</OEMLED106>
    <OEMDRO107>0.25</OEMDRO107>
    <OEMLED107>0</OEMLED107>
    <OEMDRO108>0.</OEMDRO108>
    <OEMLED108>0</OEMLED108>
    <OEMDRO109>0.</OEMDRO109>
    <OEMLED109>0</OEMLED109>
    <OEMDRO110>0.</OEMDRO110>
    <OEMLED110>1</OEMLED110>
    <OEMDRO111>0.</OEMDRO111>
    <OEMLED111>0</OEMLED111>
    <OEMDRO112>0.5</OEMDRO112>
    <OEMLED112>1</OEMLED112>
    <OEMDRO113>0.5</OEMDRO113>
    <OEMLED113>0</OEMLED113>
    <OEMDRO114>0.25</OEMDRO114>
    <OEMLED114>0</OEMLED114>
    <OEMDRO115>0.5</OEMDRO115>
    <OEMLED115>0</OEMLED115>
    <OEMDRO116>0.</OEMDRO116>
    <OEMLED116>0</OEMLED116>
    <OEMDRO117>0.125</OEMDRO117>
    <OEMLED117>0</OEMLED117>
    <OEMDRO118>0.125</OEMDRO118>
    <OEMLED118>0</OEMLED118>
    <OEMDRO119>0.</OEMDRO119>
    <OEMLED119>0</OEMLED119>
    <OEMDRO120>0.</OEMDRO120>
    <OEMLED120>0</OEMLED120>
    <OEMDRO121>0.</OEMDRO121>
    <OEMLED121>1</OEMLED121>
    <OEMDRO122>1.25</OEMDRO122>
    <OEMLED122>0</OEMLED122>
    <OEMDRO123>2.5</OEMDRO123>
    <OEMLED123>1</OEMLED123>
    <OEMDRO124>10.</OEMDRO124>
    <OEMLED124>0</OEMLED124>
    <OEMDRO125>0.125</OEMDRO125>
    <OEMLED125>0</OEMLED125>
    <OEMDRO126>0.</OEMDRO126>
    <OEMLED126>1</OEMLED126>
    <OEMDRO127>0.</OEMDRO127>
    <OEMLED127>0</OEMLED127>
    <OEMDRO128>0.</OEMDRO128>
    <OEMLED128>0</OEMLED128>
    <OEMDRO129>0.</OEMDRO129>
    <OEMLED129>0</OEMLED129>
    <OEMDRO130>0.</OEMDRO130>
    <OEMLED130>0</OEMLED130>
    <OEMDRO131>0.</OEMDRO131>
    <OEMLED131>0</OEMLED131>
    <OEMDRO132>0.</OEMDRO132>
    <OEMLED132>0</OEMLED132>
    <OEMDRO133>0.</OEMDRO133>
    <OEMLED133>0</OEMLED133>
    <OEMDRO134>0.</OEMDRO134>
    <OEMLED134>0</OEMLED134>
    <OEMDRO135>0.</OEMDRO135>
    <OEMLED135>0</OEMLED135>
    <OEMDRO136>0.</OEMDRO136>
    <OEMLED136>0</OEMLED136>
    <OEMDRO137>0.</OEMDRO137>
    <OEMLED137>0</OEMLED137>
    <OEMDRO138>0.</OEMDRO138>
    <OEMLED138>0</OEMLED138>
    <OEMDRO139>0.</OEMDRO139>
    <OEMLED139>0</OEMLED139>
    <OEMDRO140>1.</OEMDRO140>
    <OEMLED140>0</OEMLED140>
    <OEMDRO141>1.</OEMDRO141>
    <OEMLED141>0</OEMLED141>
    <OEMDRO142>2.</OEMDRO142>
    <OEMLED142>0</OEMLED142>
    <OEMDRO143>3.</OEMDRO143>
    <OEMLED143>0</OEMLED143>
    <OEMDRO144>4.</OEMDRO144>
    <OEMLED144>0</OEMLED144>
    <OEMDRO145>0.</OEMDRO145>
    <OEMLED145>0</OEMLED145>
    <OEMDRO146>0.</OEMDRO146>
    <OEMLED146>0</OEMLED146>
    <OEMDRO147>0.</OEMDRO147>
    <OEMLED147>0</OEMLED147>
    <OEMDRO148>0.</OEMDRO148>
    <OEMLED148>0</OEMLED148>
    <OEMDRO149>0.</OEMDRO149>
    <OEMLED149>0</OEMLED149>
    <OEMDRO150>0.</OEMDRO150>
    <OEMLED150>0</OEMLED150>
    <OEMDRO151>0.</OEMDRO151>
    <OEMLED151>0</OEMLED151>
    <OEMDRO152>0.</OEMDRO152>
    <OEMLED152>0</OEMLED152>
    <OEMDRO153>0.</OEMDRO153>
    <OEMLED153>0</OEMLED153>
    <OEMDRO154>0.</OEMDRO154>
    <OEMLED154>0</OEMLED154>
    <OEMDRO155>0.</OEMDRO155>
    <OEMLED155>0</OEMLED155>
    <OEMDRO156>0.</OEMDRO156>
    <OEMLED156>0</OEMLED156>
    <OEMDRO157>0.</OEMDRO157>
    <OEMLED157>0</OEMLED157>
    <OEMDRO158>0.</OEMDRO158>
    <OEMLED158>0</OEMLED158>
    <OEMDRO159>0.</OEMDRO159>
    <OEMLED159>0</OEMLED159>
    <OEMDRO160>0.1</OEMDRO160>
    <OEMLED160>0</OEMLED160>
    <OEMDRO161>0.125</OEMDRO161>
    <OEMLED161>0</OEMLED161>
    <OEMDRO162>0.5</OEMDRO162>
    <OEMLED162>0</OEMLED162>
    <OEMDRO163>0.</OEMDRO163>
    <OEMLED163>0</OEMLED163>
    <OEMDRO164>0.</OEMDRO164>
    <OEMLED164>0</OEMLED164>
    <OEMDRO165>0.</OEMDRO165>
    <OEMLED165>0</OEMLED165>
    <OEMDRO166>0.</OEMDRO166>
    <OEMLED166>0</OEMLED166>
    <OEMDRO167>0.</OEMDRO167>
    <OEMLED167>0</OEMLED167>
    <OEMDRO168>0.</OEMDRO168>
    <OEMLED168>0</OEMLED168>
    <OEMDRO169>0.</OEMDRO169>
    <OEMLED169>0</OEMLED169>
    <OEMDRO170>2.</OEMDRO170>
    <OEMLED170>1</OEMLED170>
    <OEMDRO171>5.</OEMDRO171>
    <OEMLED171>0</OEMLED171>
    <OEMDRO172>0.</OEMDRO172>
    <OEMLED172>0</OEMLED172>
    <OEMDRO173>0.</OEMDRO173>
    <OEMLED173>0</OEMLED173>
    <OEMDRO174>0.5</OEMDRO174>
    <OEMLED174>0</OEMLED174>
    <OEMDRO175>0.1</OEMDRO175>
    <OEMLED175>0</OEMLED175>
    <OEMDRO176>0.1</OEMDRO176>
    <OEMLED176>1</OEMLED176>
    <OEMDRO177>0.</OEMDRO177>
    <OEMLED177>1</OEMLED177>
    <OEMDRO178>0.1</OEMDRO178>
    <OEMLED178>0</OEMLED178>
    <OEMDRO179>0.</OEMDRO179>
    <OEMLED179>0</OEMLED179>
    <OEMDRO180>0.</OEMDRO180>
    <OEMLED180>0</OEMLED180>
    <OEMDRO181>0.</OEMDRO181>
    <OEMLED181>0</OEMLED181>
    <OEMDRO182>0.</OEMDRO182>
    <OEMLED182>0</OEMLED182>
    <OEMDRO183>0.</OEMDRO183>
    <OEMLED183>0</OEMLED183>
    <OEMDRO184>0.</OEMDRO184>
    <OEMLED184>0</OEMLED184>
    <OEMDRO185>0.</OEMDRO185>
    <OEMLED185>0</OEMLED185>
    <OEMDRO186>0.</OEMDRO186>
    <OEMLED186>0</OEMLED186>
    <OEMDRO187>0.</OEMDRO187>
    <OEMLED187>0</OEMLED187>
    <OEMDRO188>0.</OEMDRO188>
    <OEMLED188>0</OEMLED188>
    <OEMDRO189>0.</OEMDRO189>
    <OEMLED189>0</OEMLED189>
    <OEMDRO190>0.</OEMDRO190>
    <OEMLED190>0</OEMLED190>
    <OEMDRO191>0.</OEMDRO191>
    <OEMLED191>0</OEMLED191>
    <OEMDRO192>0.</OEMDRO192>
    <OEMLED192>0</OEMLED192>
    <OEMDRO193>0.</OEMDRO193>
    <OEMLED193>0</OEMLED193>
    <OEMDRO194>0.</OEMDRO194>
    <OEMLED194>0</OEMLED194>
    <OEMDRO195>0.</OEMDRO195>
    <OEMLED195>0</OEMLED195>
    <OEMDRO196>0.</OEMDRO196>
    <OEMLED196>0</OEMLED196>
    <OEMDRO197>0.</OEMDRO197>
    <OEMLED197>0</OEMLED197>
    <OEMDRO198>0.</OEMDRO198>
    <OEMLED198>0</OEMLED198>
    <OEMDRO199>0.</OEMDRO199>
    <OEMLED199>0</OEMLED199>
    <OEMDRO200>0.</OEMDRO200>
    <OEMLED200>0</OEMLED200>
    <OEMDRO201>0.</OEMDRO201>
    <OEMLED201>0</OEMLED201>
    <OEMDRO202>0.</OEMDRO202>
    <OEMLED202>0</OEMLED202>
    <OEMDRO203>0.</OEMDRO203>
    <OEMLED203>0</OEMLED203>
    <OEMDRO204>0.</OEMDRO204>
    <OEMLED204>0</OEMLED204>
    <OEMDRO205>0.</OEMDRO205>
    <OEMLED205>0</OEMLED205>
    <OEMDRO206>0.</OEMDRO206>
    <OEMLED206>0</OEMLED206>
    <OEMDRO207>0.</OEMDRO207>
    <OEMLED207>0</OEMLED207>
    <OEMDRO208>0.</OEMDRO208>
    <OEMLED208>0</OEMLED208>
    <OEMDRO209>0.</OEMDRO209>
    <OEMLED209>0</OEMLED209>
    <OEMDRO210>0.</OEMDRO210>
    <OEMLED210>0</OEMLED210>
    <OEMDRO211>0.</OEMDRO211>
    <OEMLED211>0</OEMLED211>
    <OEMDRO212>0.</OEMDRO212>
    <OEMLED212>0</OEMLED212>
    <OEMDRO213>0.</OEMDRO213>
    <OEMLED213>0</OEMLED213>
    <OEMDRO214>0.</OEMDRO214>
    <OEMLED214>0</OEMLED214>
    <OEMDRO215>0.</OEMDRO215>
    <OEMLED215>0</OEMLED215>
    <OEMDRO216>0.</OEMDRO216>
    <OEMLED216>0</OEMLED216>
    <OEMDRO217>0.</OEMDRO217>
    <OEMLED217>0</OEMLED217>
    <OEMDRO218>0.</OEMDRO218>
    <OEMLED218>0</OEMLED218>
    <OEMDRO219>0.</OEMDRO219>
    <OEMLED219>0</OEMLED219>
    <OEMDRO220>0.</OEMDRO220>
    <OEMLED220>0</OEMLED220>
    <OEMDRO221>0.</OEMDRO221>
    <OEMLED221>0</OEMLED221>
    <OEMDRO222>0.</OEMDRO222>
    <OEMLED222>0</OEMLED222>
    <OEMDRO223>0.</OEMDRO223>
    <OEMLED223>0</OEMLED223>
    <OEMDRO224>0.</OEMDRO224>
    <OEMLED224>0</OEMLED224>
    <OEMDRO225>0.</OEMDRO225>
    <OEMLED225>0</OEMLED225>
    <OEMDRO226>0.</OEMDRO226>
    <OEMLED226>0</OEMLED226>
    <OEMDRO227>0.</OEMDRO227>
    <OEMLED227>0</OEMLED227>
    <OEMDRO228>0.</OEMDRO228>
    <OEMLED228>0</OEMLED228>
    <OEMDRO229>0.</OEMDRO229>
    <OEMLED229>0</OEMLED229>
    <OEMDRO230>0.</OEMDRO230>
    <OEMLED230>0</OEMLED230>
    <OEMDRO231>2.e-002</OEMDRO231>
    <OEMLED231>0</OEMLED231>
    <OEMDRO232>2.</OEMDRO232>
    <OEMLED232>0</OEMLED232>
    <OEMDRO233>4.e-003</OEMDRO233>
    <OEMLED233>0</OEMLED233>
    <OEMDRO234>11000.</OEMDRO234>
    <OEMLED234>0</OEMLED234>
    <OEMDRO235>0.</OEMDRO235>
    <OEMLED235>0</OEMLED235>
    <OEMDRO236>11000.</OEMDRO236>
    <OEMLED236>0</OEMLED236>
    <OEMDRO237>88.</OEMDRO237>
    <OEMLED237>0</OEMLED237>
    <OEMDRO238>0.</OEMDRO238>
    <OEMLED238>0</OEMLED238>
    <OEMDRO239>0.</OEMDRO239>
    <OEMLED239>0</OEMLED239>
    <OEMDRO240>0.</OEMDRO240>
    <OEMLED240>0</OEMLED240>
    <OEMDRO241>0.</OEMDRO241>
    <OEMLED241>0</OEMLED241>
    <OEMDRO242>0.</OEMDRO242>
    <OEMLED242>0</OEMLED242>
    <OEMDRO243>0.</OEMDRO243>
    <OEMLED243>0</OEMLED243>
    <OEMDRO244>0.</OEMDRO244>
    <OEMLED244>0</OEMLED244>
    <OEMDRO245>0.</OEMDRO245>
    <OEMLED245>0</OEMLED245>
    <OEMDRO246>0.</OEMDRO246>
    <OEMLED246>0</OEMLED246>
    <OEMDRO247>0.</OEMDRO247>
    <OEMLED247>0</OEMLED247>
    <OEMDRO248>0.</OEMDRO248>
    <OEMLED248>0</OEMLED248>
    <OEMDRO249>0.</OEMDRO249>
    <OEMLED249>0</OEMLED249>
    <OEMDRO250>0.</OEMDRO250>
    <OEMLED250>0</OEMLED250>
    <OEMDRO251>0.</OEMDRO251>
    <OEMLED251>0</OEMLED251>
    <OEMDRO252>0.</OEMDRO252>
    <OEMLED252>0</OEMLED252>
    <OEMDRO253>0.</OEMDRO253>
    <OEMLED253>0</OEMLED253>
    <OEMDRO254>0.</OEMDRO254>
    <OEMLED254>0</OEMLED254>
    <OEMDRO255>0.</OEMDRO255>
    <OEMLED255>0</OEMLED255>
    <JogInc>0.1</JogInc>
    <JogSlide>0.1</JogSlide>
    <THCMax>1.</THCMax>
    <THCMin>0.2</THCMin>
    <RadiusA>0.</RadiusA>
    <RadiusB>0.</RadiusB>
    <RadiusC>0.</RadiusC>
    <LiftLevel>1.</LiftLevel>
    <LiftAngle>45.</LiftAngle>
    <InhibitDepth>-0.5</InhibitDepth>
    <LaserXGrid>0.</LaserXGrid>
    <LaserYGrid>0.</LaserYGrid>
    <LaserAGrid>0.</LaserAGrid>
    <JogInc0>1.</JogInc0>
    <JogInc1>0.1</JogInc1>
    <JogInc2>1.e-002</JogInc2>
    <JogInc3>1.e-003</JogInc3>
    <JogInc4>1.25e-004</JogInc4>
    <JogInc5>1.</JogInc5>
    <JogInc6>0.1</JogInc6>
    <JogInc7>1.e-002</JogInc7>
    <JogInc8>1.e-003</JogInc8>
    <JogInc9>1.25e-004</JogInc9>
    <THCSpeed>20.</THCSpeed>
    <BlendFactor>180.</BlendFactor>
    <M0RefHome>0</M0RefHome>
    <M1RefHome>0</M1RefHome>
    <M2RefHome>0</M2RefHome>
    <M3RefHome>0</M3RefHome>
    <M4RefHome>0</M4RefHome>
    <M5RefHome>0</M5RefHome>
    <MRU10>E:\Jigs\StepperMotor\Profile IN.nc</MRU10>
    <MRU9>E:\Jigs\StepperMotor\Drill3mm.txt</MRU9>
    <MRU8>E:\VSD\Pocket3mmEnd.txt</MRU8>
    <MRU7>E:\Jigs\110v socket.tap</MRU7>
    <MRU6>E:\MM2000-HW.tap</MRU6>
    <MRU5>E:\Jigs\DRO350\FrontHoles3mm.txt</MRU5>
    <MRU4>F:\G-Code files\60.txt</MRU4>
    <MRU3>F:\G-Code files\Cup Holder Cross-2 [Clear].txt</MRU3>
    <MRU2>F:\G-Code files\Engraved Floral-3.txt</MRU2>
    <MRU1>F:\G-Code files\Chains-14 [Clear].txt</MRU1>
    <Vel0>10.</Vel0>
    <Acc0>45.</Acc0>
    <Steps0>1259.84</Steps0>
    <Vel1>10.</Vel1>
    <Acc1>45.</Acc1>
    <Steps1>314.96</Steps1>
    <Vel2>7.5</Vel2>
    <Acc2>30.</Acc2>
    <Steps2>314.96</Steps2>
    <FrontRear>0.</FrontRear>
    <GExt>*.txt</GExt>
    <GPath>F:\G-Code files\60.txt</GPath>
    <Vel3>15.</Vel3>
    <Acc3>45.</Acc3>
    <Steps3>320.</Steps3>
    <Password>MicroMill</Password>
    <Locked>0</Locked>
    <Voices>0</Voices>
    <Sounds>0</Sounds>
    <DXFNOZS>0</DXFNOZS>
    <DXFAsDrawn>1</DXFAsDrawn>
    <DXFLathe>0</DXFLathe>
    <DXFReturn>0</DXFReturn>
    <DXFOpto>1</DXFOpto>
    <NoTHC>0</NoTHC>
    <DXFPlasma>0</DXFPlasma>
    <DXFClear>1.</DXFClear>
    <DXFTol>0.1</DXFTol>
    <Triplets>C:\dig</Triplets>
    <AutoLimit>0</AutoLimit>
    <ToolPersist>0</ToolPersist>
    <KeepRef>0</KeepRef>
    <TurnRevArc>1</TurnRevArc>
    <DROFont>Arial</DROFont>
    <LabelFont>Arial</LabelFont>
    <CodeFont>Arial</CodeFont>
    <VelPer3>5.</VelPer3>
    <TouchX>0.</TouchX>
    <G20X>0.</G20X>
    <G20Y>0.</G20Y>
    <G20Z>0.</G20Z>
    <G20A>0.</G20A>
    <G20B>0.</G20B>
    <G20C>0.</G20C>
    <EncJogAxis3>2</EncJogAxis3>
    <Boxed>1</Boxed>
    <Rot360>0</Rot360>
    <PierceDelay>1.</PierceDelay>
    <SerialServo>0</SerialServo>
    <DefDir>C:\Mach3</DefDir>
    <NewPath>0</NewPath>
    <m_SafeZ>0.</m_SafeZ>
    <SafeZStop>0</SafeZStop>
    <SafeZType>0</SafeZType>
    <UseDiam>0</UseDiam>
    <ToolLines>0</ToolLines>
    <NURBS>1</NURBS>
    <HiRes>0</HiRes>
    <DelinChar>12</DelinChar>
    <UDP>0</UDP>
    <SPINREV1>0</SPINREV1>
    <SPINREV2>0</SPINREV2>
    <SPINREV3>0</SPINREV3>
    <SPINREV4>0</SPINREV4>
    <SPEED5>25000</SPEED5>
    <LSPEED5>0</LSPEED5>
    <SPINREV5>0</SPINREV5>
    <SPEED6>25000</SPEED6>
    <LSPEED6>0</LSPEED6>
    <SPINREV6>0</SPINREV6>
    <SPEED7>25000</SPEED7>
    <LSPEED7>0</LSPEED7>
    <SPINREV7>0</SPINREV7>
    <SPEED8>25000</SPEED8>
    <LSPEED8>0</LSPEED8>
    <SPINREV8>0</SPINREV8>
    <SPEED9>25000</SPEED9>
    <LSPEED9>0</LSPEED9>
    <SPINREV9>0</SPINREV9>
    <SPEED10>25000</SPEED10>
    <LSPEED10>0</LSPEED10>
    <SPINREV10>0</SPINREV10>
    <SPEED11>25000</SPEED11>
    <LSPEED11>0</LSPEED11>
    <SPINREV11>0</SPINREV11>
    <SPEED12>25000</SPEED12>
    <LSPEED12>0</LSPEED12>
    <SPINREV12>0</SPINREV12>
    <SPEED13>25000</SPEED13>
    <LSPEED13>0</LSPEED13>
    <SPINREV13>0</SPINREV13>
    <SPEED14>25000</SPEED14>
    <LSPEED14>0</LSPEED14>
    <SPINREV14>0</SPINREV14>
    <SPEED15>25000</SPEED15>
    <LSPEED15>0</LSPEED15>
    <SPINREV15>0</SPINREV15>
    <SPEED16>25000</SPEED16>
    <LSPEED16>0</LSPEED16>
    <SPINREV16>0</SPINREV16>
    <SPEED17>25000</SPEED17>
    <LSPEED17>0</LSPEED17>
    <SPINREV17>0</SPINREV17>
    <SPEED18>25000</SPEED18>
    <LSPEED18>0</LSPEED18>
    <SPINREV18>0</SPINREV18>
    <SPEED19>25000</SPEED19>
    <LSPEED19>0</LSPEED19>
    <SPINREV19>0</SPINREV19>
    <SPEED20>25000</SPEED20>
    <LSPEED20>0</LSPEED20>
    <SPINREV20>0</SPINREV20>
    <SPEED21>25000</SPEED21>
    <LSPEED21>0</LSPEED21>
    <SPINREV21>0</SPINREV21>
    <SPEED22>25000</SPEED22>
    <LSPEED22>0</LSPEED22>
    <SPINREV22>0</SPINREV22>
    <SPEED23>25000</SPEED23>
    <LSPEED23>0</LSPEED23>
    <SPINREV23>0</SPINREV23>
    <SPEED24>25000</SPEED24>
    <LSPEED24>0</LSPEED24>
    <SPINREV24>0</SPINREV24>
    <SPEED25>25000</SPEED25>
    <LSPEED25>0</LSPEED25>
    <SPINREV25>0</SPINREV25>
    <EncJogAxis1>0</EncJogAxis1>
    <IGNORETOOL>1</IGNORETOOL>
    <DROLOCK>0</DROLOCK>
    <ModPlug>0</ModPlug>
    <Syskey1>1</Syskey1>
    <CVUseAngle>0</CVUseAngle>
    <CVDegrees>0.</CVDegrees>
    <KeyClick>1</KeyClick>
    <THC5>0</THC5>
    <M30SpinOff>1</M30SpinOff>
    <AutoCalcs>0</AutoCalcs>
    <ButtonFont>Arial</ButtonFont>
    <OVSpinInc>10</OVSpinInc>
    <MenuOff>0</MenuOff>
    <Running>1</Running>
    <LastUser>James Buxton</LastUser>
    <TCPMODBUS>0</TCPMODBUS>
    <Steps6>1.</Steps6>
    <M9After>0</M9After>
    <DwellTrigger>0</DwellTrigger>
    <IgnoreMacros>0</IgnoreMacros>
    <ZBar>1</ZBar>
    <ROTSOFT>1</ROTSOFT>
    <PROBETLO>0</PROBETLO>
    <SlaveHome>0</SlaveHome>
    <LockFROs>1</LockFROs>
    <JogHeat>0</JogHeat>
    <M7Delay>0.</M7Delay>
    <M8Delay>0.</M8Delay>
    <SPINRATIO1>1.</SPINRATIO1>
    <SPINRATIO2>1.</SPINRATIO2>
    <SPINRATIO3>1.</SPINRATIO3>
    <SPINRATIO4>1.</SPINRATIO4>
    <SPINRATIO5>1.</SPINRATIO5>
    <SPINRATIO6>1.</SPINRATIO6>
    <SPINRATIO7>1.</SPINRATIO7>
    <SPINRATIO8>1.</SPINRATIO8>
    <SPINRATIO9>1.</SPINRATIO9>
    <SPINRATIO10>1.</SPINRATIO10>
    <SPINRATIO11>1.</SPINRATIO11>
    <SPINRATIO12>1.</SPINRATIO12>
    <SPINRATIO13>1.</SPINRATIO13>
    <SPINRATIO14>1.</SPINRATIO14>
    <SPINRATIO15>1.</SPINRATIO15>
    <SPINRATIO16>1.</SPINRATIO16>
    <SPINRATIO17>1.</SPINRATIO17>
    <SPINRATIO18>1.</SPINRATIO18>
    <SPINRATIO19>1.</SPINRATIO19>
    <SPINRATIO20>1.</SPINRATIO20>
    <SPINRATIO21>1.</SPINRATIO21>
    <SPINRATIO22>1.</SPINRATIO22>
    <SPINRATIO23>1.</SPINRATIO23>
    <SPINRATIO24>1.</SPINRATIO24>
    <SPINRATIO25>1.</SPINRATIO25>
    <OEMDRO2_0>0.</OEMDRO2_0>
    <OEMLED2_0>0</OEMLED2_0>
    <OEMDRO2_1>0.</OEMDRO2_1>
    <OEMLED2_1>0</OEMLED2_1>
    <OEMDRO2_2>0.</OEMDRO2_2>
    <OEMLED2_2>0</OEMLED2_2>
    <OEMDRO2_3>0.</OEMDRO2_3>
    <OEMLED2_3>0</OEMLED2_3>
    <OEMDRO2_4>0.</OEMDRO2_4>
    <OEMLED2_4>0</OEMLED2_4>
    <OEMDRO2_5>0.</OEMDRO2_5>
    <OEMLED2_5>0</OEMLED2_5>
    <OEMDRO2_6>0.</OEMDRO2_6>
    <OEMLED2_6>0</OEMLED2_6>
    <OEMDRO2_7>0.</OEMDRO2_7>
    <OEMLED2_7>0</OEMLED2_7>
    <OEMDRO2_8>0.</OEMDRO2_8>
    <OEMLED2_8>0</OEMLED2_8>
    <OEMDRO2_9>0.</OEMDRO2_9>
    <OEMLED2_9>0</OEMLED2_9>
    <OEMDRO2_10>0.</OEMDRO2_10>
    <OEMLED2_10>0</OEMLED2_10>
    <OEMDRO2_11>0.</OEMDRO2_11>
    <OEMLED2_11>0</OEMLED2_11>
    <OEMDRO2_12>0.</OEMDRO2_12>
    <OEMLED2_12>0</OEMLED2_12>
    <OEMDRO2_13>0.</OEMDRO2_13>
    <OEMLED2_13>0</OEMLED2_13>
    <OEMDRO2_14>0.</OEMDRO2_14>
    <OEMLED2_14>0</OEMLED2_14>
    <OEMDRO2_15>0.</OEMDRO2_15>
    <OEMLED2_15>0</OEMLED2_15>
    <OEMDRO2_16>0.</OEMDRO2_16>
    <OEMLED2_16>0</OEMLED2_16>
    <OEMDRO2_17>0.</OEMDRO2_17>
    <OEMLED2_17>0</OEMLED2_17>
    <OEMDRO2_18>0.</OEMDRO2_18>
    <OEMLED2_18>0</OEMLED2_18>
    <OEMDRO2_19>0.</OEMDRO2_19>
    <OEMLED2_19>0</OEMLED2_19>
    <OEMDRO2_20>0.</OEMDRO2_20>
    <OEMLED2_20>0</OEMLED2_20>
    <OEMDRO2_21>0.</OEMDRO2_21>
    <OEMLED2_21>0</OEMLED2_21>
    <OEMDRO2_22>0.</OEMDRO2_22>
    <OEMLED2_22>0</OEMLED2_22>
    <OEMDRO2_23>0.</OEMDRO2_23>
    <OEMLED2_23>0</OEMLED2_23>
    <OEMDRO2_24>0.</OEMDRO2_24>
    <OEMLED2_24>0</OEMLED2_24>
    <OEMDRO2_25>0.</OEMDRO2_25>
    <OEMLED2_25>0</OEMLED2_25>
    <OEMDRO2_26>0.</OEMDRO2_26>
    <OEMLED2_26>0</OEMLED2_26>
    <OEMDRO2_27>0.</OEMDRO2_27>
    <OEMLED2_27>0</OEMLED2_27>
    <OEMDRO2_28>0.</OEMDRO2_28>
    <OEMLED2_28>0</OEMLED2_28>
    <OEMDRO2_29>0.</OEMDRO2_29>
    <OEMLED2_29>0</OEMLED2_29>
    <OEMDRO2_30>0.</OEMDRO2_30>
    <OEMLED2_30>0</OEMLED2_30>
    <OEMDRO2_31>0.</OEMDRO2_31>
    <OEMLED2_31>0</OEMLED2_31>
    <OEMDRO2_32>0.</OEMDRO2_32>
    <OEMLED2_32>0</OEMLED2_32>
    <OEMDRO2_33>0.</OEMDRO2_33>
    <OEMLED2_33>0</OEMLED2_33>
    <OEMDRO2_34>0.</OEMDRO2_34>
    <OEMLED2_34>0</OEMLED2_34>
    <OEMDRO2_35>0.</OEMDRO2_35>
    <OEMLED2_35>0</OEMLED2_35>
    <OEMDRO2_36>0.</OEMDRO2_36>
    <OEMLED2_36>0</OEMLED2_36>
    <OEMDRO2_37>0.</OEMDRO2_37>
    <OEMLED2_37>0</OEMLED2_37>
    <OEMDRO2_38>0.</OEMDRO2_38>
    <OEMLED2_38>0</OEMLED2_38>
    <OEMDRO2_39>0.</OEMDRO2_39>
    <OEMLED2_39>0</OEMLED2_39>
    <OEMDRO2_40>0.</OEMDRO2_40>
    <OEMLED2_40>0</OEMLED2_40>
    <OEMDRO2_41>0.</OEMDRO2_41>
    <OEMLED2_41>0</OEMLED2_41>
    <OEMDRO2_42>0.</OEMDRO2_42>
    <OEMLED2_42>0</OEMLED2_42>
    <OEMDRO2_43>0.</OEMDRO2_43>
    <OEMLED2_43>0</OEMLED2_43>
    <OEMDRO2_44>0.</OEMDRO2_44>
    <OEMLED2_44>0</OEMLED2_44>
    <OEMDRO2_45>0.</OEMDRO2_45>
    <OEMLED2_45>0</OEMLED2_45>
    <OEMDRO2_46>0.</OEMDRO2_46>
    <OEMLED2_46>0</OEMLED2_46>
    <OEMDRO2_47>0.</OEMDRO2_47>
    <OEMLED2_47>0</OEMLED2_47>
    <OEMDRO2_48>0.</OEMDRO2_48>
    <OEMLED2_48>0</OEMLED2_48>
    <OEMDRO2_49>0.</OEMDRO2_49>
    <OEMLED2_49>0</OEMLED2_49>
    <OEMDRO2_50>0.</OEMDRO2_50>
    <OEMLED2_50>0</OEMLED2_50>
    <OEMDRO2_51>0.</OEMDRO2_51>
    <OEMLED2_51>0</OEMLED2_51>
    <OEMDRO2_52>0.</OEMDRO2_52>
    <OEMLED2_52>0</OEMLED2_52>
    <OEMDRO2_53>0.</OEMDRO2_53>
    <OEMLED2_53>0</OEMLED2_53>
    <OEMDRO2_54>0.</OEMDRO2_54>
    <OEMLED2_54>0</OEMLED2_54>
    <OEMDRO2_55>0.</OEMDRO2_55>
    <OEMLED2_55>0</OEMLED2_55>
    <OEMDRO2_56>0.</OEMDRO2_56>
    <OEMLED2_56>0</OEMLED2_56>
    <OEMDRO2_57>0.</OEMDRO2_57>
    <OEMLED2_57>0</OEMLED2_57>
    <OEMDRO2_58>0.</OEMDRO2_58>
    <OEMLED2_58>0</OEMLED2_58>
    <OEMDRO2_59>0.</OEMDRO2_59>
    <OEMLED2_59>0</OEMLED2_59>
    <OEMDRO2_60>0.</OEMDRO2_60>
    <OEMLED2_60>0</OEMLED2_60>
    <OEMDRO2_61>0.</OEMDRO2_61>
    <OEMLED2_61>0</OEMLED2_61>
    <OEMDRO2_62>0.</OEMDRO2_62>
    <OEMLED2_62>0</OEMLED2_62>
    <OEMDRO2_63>0.</OEMDRO2_63>
    <OEMLED2_63>0</OEMLED2_63>
    <OEMDRO2_64>0.</OEMDRO2_64>
    <OEMLED2_64>0</OEMLED2_64>
    <OEMDRO2_65>0.</OEMDRO2_65>
    <OEMLED2_65>0</OEMLED2_65>
    <OEMDRO2_66>0.</OEMDRO2_66>
    <OEMLED2_66>0</OEMLED2_66>
    <OEMDRO2_67>0.</OEMDRO2_67>
    <OEMLED2_67>0</OEMLED2_67>
    <OEMDRO2_68>0.</OEMDRO2_68>
    <OEMLED2_68>0</OEMLED2_68>
    <OEMDRO2_69>0.</OEMDRO2_69>
    <OEMLED2_69>0</OEMLED2_69>
    <OEMDRO2_70>0.</OEMDRO2_70>
    <OEMLED2_70>0</OEMLED2_70>
    <OEMDRO2_71>0.</OEMDRO2_71>
    <OEMLED2_71>0</OEMLED2_71>
    <OEMDRO2_72>0.</OEMDRO2_72>
    <OEMLED2_72>0</OEMLED2_72>
    <OEMDRO2_73>0.</OEMDRO2_73>
    <OEMLED2_73>0</OEMLED2_73>
    <OEMDRO2_74>0.</OEMDRO2_74>
    <OEMLED2_74>0</OEMLED2_74>
    <OEMDRO2_75>0.</OEMDRO2_75>
    <OEMLED2_75>0</OEMLED2_75>
    <OEMDRO2_76>0.</OEMDRO2_76>
    <OEMLED2_76>0</OEMLED2_76>
    <OEMDRO2_77>0.</OEMDRO2_77>
    <OEMLED2_77>0</OEMLED2_77>
    <OEMDRO2_78>0.</OEMDRO2_78>
    <OEMLED2_78>0</OEMLED2_78>
    <OEMDRO2_79>0.</OEMDRO2_79>
    <OEMLED2_79>0</OEMLED2_79>
    <OEMDRO2_80>0.</OEMDRO2_80>
    <OEMLED2_80>0</OEMLED2_80>
    <OEMDRO2_81>0.</OEMDRO2_81>
    <OEMLED2_81>0</OEMLED2_81>
    <OEMDRO2_82>0.</OEMDRO2_82>
    <OEMLED2_82>0</OEMLED2_82>
    <OEMDRO2_83>0.</OEMDRO2_83>
    <OEMLED2_83>0</OEMLED2_83>
    <OEMDRO2_84>0.</OEMDRO2_84>
    <OEMLED2_84>0</OEMLED2_84>
    <OEMDRO2_85>0.</OEMDRO2_85>
    <OEMLED2_85>0</OEMLED2_85>
    <OEMDRO2_86>0.</OEMDRO2_86>
    <OEMLED2_86>0</OEMLED2_86>
    <OEMDRO2_87>0.</OEMDRO2_87>
    <OEMLED2_87>0</OEMLED2_87>
    <OEMDRO2_88>0.</OEMDRO2_88>
    <OEMLED2_88>0</OEMLED2_88>
    <OEMDRO2_89>0.</OEMDRO2_89>
    <OEMLED2_89>0</OEMLED2_89>
    <OEMDRO2_90>0.</OEMDRO2_90>
    <OEMLED2_90>0</OEMLED2_90>
    <OEMDRO2_91>0.</OEMDRO2_91>
    <OEMLED2_91>0</OEMLED2_91>
    <OEMDRO2_92>0.</OEMDRO2_92>
    <OEMLED2_92>0</OEMLED2_92>
    <OEMDRO2_93>0.</OEMDRO2_93>
    <OEMLED2_93>0</OEMLED2_93>
    <OEMDRO2_94>0.</OEMDRO2_94>
    <OEMLED2_94>0</OEMLED2_94>
    <OEMDRO2_95>0.</OEMDRO2_95>
    <OEMLED2_95>0</OEMLED2_95>
    <OEMDRO2_96>0.</OEMDRO2_96>
    <OEMLED2_96>0</OEMLED2_96>
    <OEMDRO2_97>0.</OEMDRO2_97>
    <OEMLED2_97>0</OEMLED2_97>
    <OEMDRO2_98>0.</OEMDRO2_98>
    <OEMLED2_98>0</OEMLED2_98>
    <OEMDRO2_99>0.</OEMDRO2_99>
    <OEMLED2_99>0</OEMLED2_99>
    <OEMDRO2_100>0.</OEMDRO2_100>
    <OEMLED2_100>0</OEMLED2_100>
    <OEMDRO2_101>0.</OEMDRO2_101>
    <OEMLED2_101>0</OEMLED2_101>
    <OEMDRO2_102>0.</OEMDRO2_102>
    <OEMLED2_102>0</OEMLED2_102>
    <OEMDRO2_103>0.</OEMDRO2_103>
    <OEMLED2_103>0</OEMLED2_103>
    <OEMDRO2_104>0.</OEMDRO2_104>
    <OEMLED2_104>0</OEMLED2_104>
    <OEMDRO2_105>0.</OEMDRO2_105>
    <OEMLED2_105>0</OEMLED2_105>
    <OEMDRO2_106>0.</OEMDRO2_106>
    <OEMLED2_106>0</OEMLED2_106>
    <OEMDRO2_107>0.</OEMDRO2_107>
    <OEMLED2_107>0</OEMLED2_107>
    <OEMDRO2_108>0.</OEMDRO2_108>
    <OEMLED2_108>0</OEMLED2_108>
    <OEMDRO2_109>0.</OEMDRO2_109>
    <OEMLED2_109>0</OEMLED2_109>
    <OEMDRO2_110>0.</OEMDRO2_110>
    <OEMLED2_110>0</OEMLED2_110>
    <OEMDRO2_111>0.</OEMDRO2_111>
    <OEMLED2_111>0</OEMLED2_111>
    <OEMDRO2_112>0.</OEMDRO2_112>
    <OEMLED2_112>0</OEMLED2_112>
    <OEMDRO2_113>0.</OEMDRO2_113>
    <OEMLED2_113>0</OEMLED2_113>
    <OEMDRO2_114>0.</OEMDRO2_114>
    <OEMLED2_114>0</OEMLED2_114>
    <OEMDRO2_115>0.</OEMDRO2_115>
    <OEMLED2_115>0</OEMLED2_115>
    <OEMDRO2_116>0.</OEMDRO2_116>
    <OEMLED2_116>0</OEMLED2_116>
    <OEMDRO2_117>0.</OEMDRO2_117>
    <OEMLED2_117>0</OEMLED2_117>
    <OEMDRO2_118>0.</OEMDRO2_118>
    <OEMLED2_118>0</OEMLED2_118>
    <OEMDRO2_119>0.</OEMDRO2_119>
    <OEMLED2_119>0</OEMLED2_119>
    <OEMDRO2_120>0.</OEMDRO2_120>
    <OEMLED2_120>0</OEMLED2_120>
    <OEMDRO2_121>0.</OEMDRO2_121>
    <OEMLED2_121>0</OEMLED2_121>
    <OEMDRO2_122>0.</OEMDRO2_122>
    <OEMLED2_122>0</OEMLED2_122>
    <OEMDRO2_123>0.</OEMDRO2_123>
    <OEMLED2_123>0</OEMLED2_123>
    <OEMDRO2_124>0.</OEMDRO2_124>
    <OEMLED2_124>0</OEMLED2_124>
    <OEMDRO2_125>0.</OEMDRO2_125>
    <OEMLED2_125>0</OEMLED2_125>
    <OEMDRO2_126>0.</OEMDRO2_126>
    <OEMLED2_126>0</OEMLED2_126>
    <OEMDRO2_127>0.</OEMDRO2_127>
    <OEMLED2_127>0</OEMLED2_127>
    <OEMDRO2_128>0.</OEMDRO2_128>
    <OEMLED2_128>0</OEMLED2_128>
    <OEMDRO2_129>0.</OEMDRO2_129>
    <OEMLED2_129>0</OEMLED2_129>
    <OEMDRO2_130>0.</OEMDRO2_130>
    <OEMLED2_130>0</OEMLED2_130>
    <OEMDRO2_131>0.</OEMDRO2_131>
    <OEMLED2_131>0</OEMLED2_131>
    <OEMDRO2_132>0.</OEMDRO2_132>
    <OEMLED2_132>0</OEMLED2_132>
    <OEMDRO2_133>0.</OEMDRO2_133>
    <OEMLED2_133>0</OEMLED2_133>
    <OEMDRO2_134>0.</OEMDRO2_134>
    <OEMLED2_134>0</OEMLED2_134>
    <OEMDRO2_135>0.</OEMDRO2_135>
    <OEMLED2_135>0</OEMLED2_135>
    <OEMDRO2_136>0.</OEMDRO2_136>
    <OEMLED2_136>0</OEMLED2_136>
    <OEMDRO2_137>0.</OEMDRO2_137>
    <OEMLED2_137>0</OEMLED2_137>
    <OEMDRO2_138>0.</OEMDRO2_138>
    <OEMLED2_138>0</OEMLED2_138>
    <OEMDRO2_139>0.</OEMDRO2_139>
    <OEMLED2_139>0</OEMLED2_139>
    <OEMDRO2_140>0.</OEMDRO2_140>
    <OEMLED2_140>0</OEMLED2_140>
    <OEMDRO2_141>0.</OEMDRO2_141>
    <OEMLED2_141>0</OEMLED2_141>
    <OEMDRO2_142>0.</OEMDRO2_142>
    <OEMLED2_142>0</OEMLED2_142>
    <OEMDRO2_143>0.</OEMDRO2_143>
    <OEMLED2_143>0</OEMLED2_143>
    <OEMDRO2_144>0.</OEMDRO2_144>
    <OEMLED2_144>0</OEMLED2_144>
    <OEMDRO2_145>0.</OEMDRO2_145>
    <OEMLED2_145>0</OEMLED2_145>
    <OEMDRO2_146>0.</OEMDRO2_146>
    <OEMLED2_146>0</OEMLED2_146>
    <OEMDRO2_147>0.</OEMDRO2_147>
    <OEMLED2_147>0</OEMLED2_147>
    <OEMDRO2_148>0.</OEMDRO2_148>
    <OEMLED2_148>0</OEMLED2_148>
    <OEMDRO2_149>0.</OEMDRO2_149>
    <OEMLED2_149>0</OEMLED2_149>
    <OEMDRO2_150>0.</OEMDRO2_150>
    <OEMLED2_150>0</OEMLED2_150>
    <OEMDRO2_151>0.</OEMDRO2_151>
    <OEMLED2_151>0</OEMLED2_151>
    <OEMDRO2_152>0.</OEMDRO2_152>
    <OEMLED2_152>0</OEMLED2_152>
    <OEMDRO2_153>0.</OEMDRO2_153>
    <OEMLED2_153>0</OEMLED2_153>
    <OEMDRO2_154>0.</OEMDRO2_154>
    <OEMLED2_154>0</OEMLED2_154>
    <OEMDRO2_155>0.</OEMDRO2_155>
    <OEMLED2_155>0</OEMLED2_155>
    <OEMDRO2_156>0.</OEMDRO2_156>
    <OEMLED2_156>0</OEMLED2_156>
    <OEMDRO2_157>0.</OEMDRO2_157>
    <OEMLED2_157>0</OEMLED2_157>
    <OEMDRO2_158>0.</OEMDRO2_158>
    <OEMLED2_158>0</OEMLED2_158>
    <OEMDRO2_159>0.</OEMDRO2_159>
    <OEMLED2_159>0</OEMLED2_159>
    <OEMDRO2_160>0.</OEMDRO2_160>
    <OEMLED2_160>0</OEMLED2_160>
    <OEMDRO2_161>0.</OEMDRO2_161>
    <OEMLED2_161>0</OEMLED2_161>
    <OEMDRO2_162>0.</OEMDRO2_162>
    <OEMLED2_162>0</OEMLED2_162>
    <OEMDRO2_163>0.</OEMDRO2_163>
    <OEMLED2_163>0</OEMLED2_163>
    <OEMDRO2_164>0.</OEMDRO2_164>
    <OEMLED2_164>0</OEMLED2_164>
    <OEMDRO2_165>0.</OEMDRO2_165>
    <OEMLED2_165>0</OEMLED2_165>
    <OEMDRO2_166>0.</OEMDRO2_166>
    <OEMLED2_166>0</OEMLED2_166>
    <OEMDRO2_167>0.</OEMDRO2_167>
    <OEMLED2_167>0</OEMLED2_167>
    <OEMDRO2_168>0.</OEMDRO2_168>
    <OEMLED2_168>0</OEMLED2_168>
    <OEMDRO2_169>0.</OEMDRO2_169>
    <OEMLED2_169>0</OEMLED2_169>
    <OEMDRO2_170>0.</OEMDRO2_170>
    <OEMLED2_170>0</OEMLED2_170>
    <OEMDRO2_171>0.</OEMDRO2_171>
    <OEMLED2_171>0</OEMLED2_171>
    <OEMDRO2_172>0.</OEMDRO2_172>
    <OEMLED2_172>0</OEMLED2_172>
    <OEMDRO2_173>0.</OEMDRO2_173>
    <OEMLED2_173>0</OEMLED2_173>
    <OEMDRO2_174>0.</OEMDRO2_174>
    <OEMLED2_174>0</OEMLED2_174>
    <OEMDRO2_175>0.</OEMDRO2_175>
    <OEMLED2_175>0</OEMLED2_175>
    <OEMDRO2_176>0.</OEMDRO2_176>
    <OEMLED2_176>0</OEMLED2_176>
    <OEMDRO2_177>0.</OEMDRO2_177>
    <OEMLED2_177>0</OEMLED2_177>
    <OEMDRO2_178>0.</OEMDRO2_178>
    <OEMLED2_178>0</OEMLED2_178>
    <OEMDRO2_179>0.</OEMDRO2_179>
    <OEMLED2_179>0</OEMLED2_179>
    <OEMDRO2_180>0.</OEMDRO2_180>
    <OEMLED2_180>0</OEMLED2_180>
    <OEMDRO2_181>0.</OEMDRO2_181>
    <OEMLED2_181>0</OEMLED2_181>
    <OEMDRO2_182>0.</OEMDRO2_182>
    <OEMLED2_182>0</OEMLED2_182>
    <OEMDRO2_183>0.</OEMDRO2_183>
    <OEMLED2_183>0</OEMLED2_183>
    <OEMDRO2_184>0.</OEMDRO2_184>
    <OEMLED2_184>0</OEMLED2_184>
    <OEMDRO2_185>0.</OEMDRO2_185>
    <OEMLED2_185>0</OEMLED2_185>
    <OEMDRO2_186>0.</OEMDRO2_186>
    <OEMLED2_186>0</OEMLED2_186>
    <OEMDRO2_187>0.</OEMDRO2_187>
    <OEMLED2_187>0</OEMLED2_187>
    <OEMDRO2_188>0.</OEMDRO2_188>
    <OEMLED2_188>0</OEMLED2_188>
    <OEMDRO2_189>0.</OEMDRO2_189>
    <OEMLED2_189>0</OEMLED2_189>
    <OEMDRO2_190>0.</OEMDRO2_190>
    <OEMLED2_190>0</OEMLED2_190>
    <OEMDRO2_191>0.</OEMDRO2_191>
    <OEMLED2_191>0</OEMLED2_191>
    <OEMDRO2_192>0.</OEMDRO2_192>
    <OEMLED2_192>0</OEMLED2_192>
    <OEMDRO2_193>0.</OEMDRO2_193>
    <OEMLED2_193>0</OEMLED2_193>
    <OEMDRO2_194>0.</OEMDRO2_194>
    <OEMLED2_194>0</OEMLED2_194>
    <OEMDRO2_195>0.</OEMDRO2_195>
    <OEMLED2_195>0</OEMLED2_195>
    <OEMDRO2_196>0.</OEMDRO2_196>
    <OEMLED2_196>0</OEMLED2_196>
    <OEMDRO2_197>0.</OEMDRO2_197>
    <OEMLED2_197>0</OEMLED2_197>
    <OEMDRO2_198>0.</OEMDRO2_198>
    <OEMLED2_198>0</OEMLED2_198>
    <OEMDRO2_199>0.</OEMDRO2_199>
    <OEMLED2_199>0</OEMLED2_199>
    <OEMDRO2_200>0.</OEMDRO2_200>
    <OEMLED2_200>0</OEMLED2_200>
    <OEMDRO2_201>0.</OEMDRO2_201>
    <OEMLED2_201>0</OEMLED2_201>
    <OEMDRO2_202>0.</OEMDRO2_202>
    <OEMLED2_202>0</OEMLED2_202>
    <OEMDRO2_203>0.</OEMDRO2_203>
    <OEMLED2_203>0</OEMLED2_203>
    <OEMDRO2_204>0.</OEMDRO2_204>
    <OEMLED2_204>0</OEMLED2_204>
    <OEMDRO2_205>0.</OEMDRO2_205>
    <OEMLED2_205>0</OEMLED2_205>
    <OEMDRO2_206>0.</OEMDRO2_206>
    <OEMLED2_206>0</OEMLED2_206>
    <OEMDRO2_207>0.</OEMDRO2_207>
    <OEMLED2_207>0</OEMLED2_207>
    <OEMDRO2_208>0.</OEMDRO2_208>
    <OEMLED2_208>0</OEMLED2_208>
    <OEMDRO2_209>0.</OEMDRO2_209>
    <OEMLED2_209>0</OEMLED2_209>
    <OEMDRO2_210>0.</OEMDRO2_210>
    <OEMLED2_210>0</OEMLED2_210>
    <OEMDRO2_211>0.</OEMDRO2_211>
    <OEMLED2_211>0</OEMLED2_211>
    <OEMDRO2_212>0.</OEMDRO2_212>
    <OEMLED2_212>0</OEMLED2_212>
    <OEMDRO2_213>0.</OEMDRO2_213>
    <OEMLED2_213>0</OEMLED2_213>
    <OEMDRO2_214>0.</OEMDRO2_214>
    <OEMLED2_214>0</OEMLED2_214>
    <OEMDRO2_215>0.</OEMDRO2_215>
    <OEMLED2_215>0</OEMLED2_215>
    <OEMDRO2_216>0.</OEMDRO2_216>
    <OEMLED2_216>0</OEMLED2_216>
    <OEMDRO2_217>0.</OEMDRO2_217>
    <OEMLED2_217>0</OEMLED2_217>
    <OEMDRO2_218>0.</OEMDRO2_218>
    <OEMLED2_218>0</OEMLED2_218>
    <OEMDRO2_219>0.</OEMDRO2_219>
    <OEMLED2_219>0</OEMLED2_219>
    <OEMDRO2_220>0.</OEMDRO2_220>
    <OEMLED2_220>0</OEMLED2_220>
    <OEMDRO2_221>0.</OEMDRO2_221>
    <OEMLED2_221>0</OEMLED2_221>
    <OEMDRO2_222>0.</OEMDRO2_222>
    <OEMLED2_222>0</OEMLED2_222>
    <OEMDRO2_223>0.</OEMDRO2_223>
    <OEMLED2_223>0</OEMLED2_223>
    <OEMDRO2_224>0.</OEMDRO2_224>
    <OEMLED2_224>0</OEMLED2_224>
    <OEMDRO2_225>0.</OEMDRO2_225>
    <OEMLED2_225>0</OEMLED2_225>
    <OEMDRO2_226>0.</OEMDRO2_226>
    <OEMLED2_226>0</OEMLED2_226>
    <OEMDRO2_227>0.</OEMDRO2_227>
    <OEMLED2_227>0</OEMLED2_227>
    <OEMDRO2_228>0.</OEMDRO2_228>
    <OEMLED2_228>0</OEMLED2_228>
    <OEMDRO2_229>0.</OEMDRO2_229>
    <OEMLED2_229>0</OEMLED2_229>
    <OEMDRO2_230>0.</OEMDRO2_230>
    <OEMLED2_230>0</OEMLED2_230>
    <OEMDRO2_231>0.</OEMDRO2_231>
    <OEMLED2_231>0</OEMLED2_231>
    <OEMDRO2_232>0.</OEMDRO2_232>
    <OEMLED2_232>0</OEMLED2_232>
    <OEMDRO2_233>0.</OEMDRO2_233>
    <OEMLED2_233>0</OEMLED2_233>
    <OEMDRO2_234>0.</OEMDRO2_234>
    <OEMLED2_234>0</OEMLED2_234>
    <OEMDRO2_235>0.</OEMDRO2_235>
    <OEMLED2_235>0</OEMLED2_235>
    <OEMDRO2_236>0.</OEMDRO2_236>
    <OEMLED2_236>0</OEMLED2_236>
    <OEMDRO2_237>0.</OEMDRO2_237>
    <OEMLED2_237>0</OEMLED2_237>
    <OEMDRO2_238>0.</OEMDRO2_238>
    <OEMLED2_238>0</OEMLED2_238>
    <OEMDRO2_239>0.</OEMDRO2_239>
    <OEMLED2_239>0</OEMLED2_239>
    <OEMDRO2_240>0.</OEMDRO2_240>
    <OEMLED2_240>0</OEMLED2_240>
    <OEMDRO2_241>0.</OEMDRO2_241>
    <OEMLED2_241>0</OEMLED2_241>
    <OEMDRO2_242>0.</OEMDRO2_242>
    <OEMLED2_242>0</OEMLED2_242>
    <OEMDRO2_243>0.</OEMDRO2_243>
    <OEMLED2_243>0</OEMLED2_243>
    <OEMDRO2_244>0.</OEMDRO2_244>
    <OEMLED2_244>0</OEMLED2_244>
    <OEMDRO2_245>0.</OEMDRO2_245>
    <OEMLED2_245>0</OEMLED2_245>
    <OEMDRO2_246>0.</OEMDRO2_246>
    <OEMLED2_246>0</OEMLED2_246>
    <OEMDRO2_247>0.</OEMDRO2_247>
    <OEMLED2_247>0</OEMLED2_247>
    <OEMDRO2_248>0.</OEMDRO2_248>
    <OEMLED2_248>0</OEMLED2_248>
    <OEMDRO2_249>0.</OEMDRO2_249>
    <OEMLED2_249>0</OEMLED2_249>
    <OEMDRO2_250>0.</OEMDRO2_250>
    <OEMLED2_250>0</OEMLED2_250>
    <OEMDRO2_251>0.</OEMDRO2_251>
    <OEMLED2_251>0</OEMLED2_251>
    <OEMDRO2_252>0.</OEMDRO2_252>
    <OEMLED2_252>0</OEMLED2_252>
    <OEMDRO2_253>0.</OEMDRO2_253>
    <OEMLED2_253>0</OEMLED2_253>
    <OEMDRO2_254>0.</OEMDRO2_254>
    <OEMLED2_254>0</OEMLED2_254>
    <OEMDRO2_255>0.</OEMDRO2_255>
    <OEMLED2_255>0</OEMLED2_255>
    <OEMDRO2_256>0.</OEMDRO2_256>
    <OEMLED2_256>0</OEMLED2_256>
    <OEMDRO2_257>0.</OEMDRO2_257>
    <OEMLED2_257>0</OEMLED2_257>
    <OEMDRO2_258>0.</OEMDRO2_258>
    <OEMLED2_258>0</OEMLED2_258>
    <OEMDRO2_259>0.</OEMDRO2_259>
    <OEMLED2_259>0</OEMLED2_259>
    <OEMDRO2_260>0.</OEMDRO2_260>
    <OEMLED2_260>0</OEMLED2_260>
    <OEMDRO2_261>0.</OEMDRO2_261>
    <OEMLED2_261>0</OEMLED2_261>
    <OEMDRO2_262>0.</OEMDRO2_262>
    <OEMLED2_262>0</OEMLED2_262>
    <OEMDRO2_263>0.</OEMDRO2_263>
    <OEMLED2_263>0</OEMLED2_263>
    <OEMDRO2_264>0.</OEMDRO2_264>
    <OEMLED2_264>0</OEMLED2_264>
    <OEMDRO2_265>0.</OEMDRO2_265>
    <OEMLED2_265>0</OEMLED2_265>
    <OEMDRO2_266>0.</OEMDRO2_266>
    <OEMLED2_266>0</OEMLED2_266>
    <OEMDRO2_267>0.</OEMDRO2_267>
    <OEMLED2_267>0</OEMLED2_267>
    <OEMDRO2_268>0.</OEMDRO2_268>
    <OEMLED2_268>0</OEMLED2_268>
    <OEMDRO2_269>0.</OEMDRO2_269>
    <OEMLED2_269>0</OEMLED2_269>
    <OEMDRO2_270>0.</OEMDRO2_270>
    <OEMLED2_270>0</OEMLED2_270>
    <OEMDRO2_271>0.</OEMDRO2_271>
    <OEMLED2_271>0</OEMLED2_271>
    <OEMDRO2_272>0.</OEMDRO2_272>
    <OEMLED2_272>0</OEMLED2_272>
    <OEMDRO2_273>0.</OEMDRO2_273>
    <OEMLED2_273>0</OEMLED2_273>
    <OEMDRO2_274>0.</OEMDRO2_274>
    <OEMLED2_274>0</OEMLED2_274>
    <OEMDRO2_275>0.</OEMDRO2_275>
    <OEMLED2_275>0</OEMLED2_275>
    <OEMDRO2_276>0.</OEMDRO2_276>
    <OEMLED2_276>0</OEMLED2_276>
    <OEMDRO2_277>0.</OEMDRO2_277>
    <OEMLED2_277>0</OEMLED2_277>
    <OEMDRO2_278>0.</OEMDRO2_278>
    <OEMLED2_278>0</OEMLED2_278>
    <OEMDRO2_279>0.</OEMDRO2_279>
    <OEMLED2_279>0</OEMLED2_279>
    <OEMDRO2_280>0.</OEMDRO2_280>
    <OEMLED2_280>0</OEMLED2_280>
    <OEMDRO2_281>0.</OEMDRO2_281>
    <OEMLED2_281>0</OEMLED2_281>
    <OEMDRO2_282>0.</OEMDRO2_282>
    <OEMLED2_282>0</OEMLED2_282>
    <OEMDRO2_283>0.</OEMDRO2_283>
    <OEMLED2_283>0</OEMLED2_283>
    <OEMDRO2_284>0.</OEMDRO2_284>
    <OEMLED2_284>0</OEMLED2_284>
    <OEMDRO2_285>0.</OEMDRO2_285>
    <OEMLED2_285>0</OEMLED2_285>
    <OEMDRO2_286>0.</OEMDRO2_286>
    <OEMLED2_286>0</OEMLED2_286>
    <OEMDRO2_287>0.</OEMDRO2_287>
    <OEMLED2_287>0</OEMLED2_287>
    <OEMDRO2_288>0.</OEMDRO2_288>
    <OEMLED2_288>0</OEMLED2_288>
    <OEMDRO2_289>0.</OEMDRO2_289>
    <OEMLED2_289>0</OEMLED2_289>
    <OEMDRO2_290>0.</OEMDRO2_290>
    <OEMLED2_290>0</OEMLED2_290>
    <OEMDRO2_291>0.</OEMDRO2_291>
    <OEMLED2_291>0</OEMLED2_291>
    <OEMDRO2_292>0.</OEMDRO2_292>
    <OEMLED2_292>0</OEMLED2_292>
    <OEMDRO2_293>0.</OEMDRO2_293>
    <OEMLED2_293>0</OEMLED2_293>
    <OEMDRO2_294>0.</OEMDRO2_294>
    <OEMLED2_294>0</OEMLED2_294>
    <OEMDRO2_295>0.</OEMDRO2_295>
    <OEMLED2_295>0</OEMLED2_295>
    <OEMDRO2_296>0.</OEMDRO2_296>
    <OEMLED2_296>0</OEMLED2_296>
    <OEMDRO2_297>0.</OEMDRO2_297>
    <OEMLED2_297>0</OEMLED2_297>
    <OEMDRO2_298>0.</OEMDRO2_298>
    <OEMLED2_298>0</OEMLED2_298>
    <OEMDRO2_299>0.</OEMDRO2_299>
    <OEMLED2_299>0</OEMLED2_299>
    <OEMDRO2_300>0.</OEMDRO2_300>
    <OEMLED2_300>0</OEMLED2_300>
    <OEMDRO2_301>0.</OEMDRO2_301>
    <OEMLED2_301>0</OEMLED2_301>
    <OEMDRO2_302>0.</OEMDRO2_302>
    <OEMLED2_302>0</OEMLED2_302>
    <OEMDRO2_303>0.</OEMDRO2_303>
    <OEMLED2_303>0</OEMLED2_303>
    <OEMDRO2_304>0.</OEMDRO2_304>
    <OEMLED2_304>0</OEMLED2_304>
    <OEMDRO2_305>0.</OEMDRO2_305>
    <OEMLED2_305>0</OEMLED2_305>
    <OEMDRO2_306>0.</OEMDRO2_306>
    <OEMLED2_306>0</OEMLED2_306>
    <OEMDRO2_307>0.</OEMDRO2_307>
    <OEMLED2_307>0</OEMLED2_307>
    <OEMDRO2_308>0.</OEMDRO2_308>
    <OEMLED2_308>0</OEMLED2_308>
    <OEMDRO2_309>0.</OEMDRO2_309>
    <OEMLED2_309>0</OEMLED2_309>
    <OEMDRO2_310>0.</OEMDRO2_310>
    <OEMLED2_310>0</OEMLED2_310>
    <OEMDRO2_311>0.</OEMDRO2_311>
    <OEMLED2_311>0</OEMLED2_311>
    <OEMDRO2_312>0.</OEMDRO2_312>
    <OEMLED2_312>0</OEMLED2_312>
    <OEMDRO2_313>0.</OEMDRO2_313>
    <OEMLED2_313>0</OEMLED2_313>
    <OEMDRO2_314>0.</OEMDRO2_314>
    <OEMLED2_314>0</OEMLED2_314>
    <OEMDRO2_315>0.</OEMDRO2_315>
    <OEMLED2_315>0</OEMLED2_315>
    <OEMDRO2_316>0.</OEMDRO2_316>
    <OEMLED2_316>0</OEMLED2_316>
    <OEMDRO2_317>0.</OEMDRO2_317>
    <OEMLED2_317>0</OEMLED2_317>
    <OEMDRO2_318>0.</OEMDRO2_318>
    <OEMLED2_318>0</OEMLED2_318>
    <OEMDRO2_319>0.</OEMDRO2_319>
    <OEMLED2_319>0</OEMLED2_319>
    <OEMDRO2_320>0.</OEMDRO2_320>
    <OEMLED2_320>0</OEMLED2_320>
    <OEMDRO2_321>0.</OEMDRO2_321>
    <OEMLED2_321>0</OEMLED2_321>
    <OEMDRO2_322>0.</OEMDRO2_322>
    <OEMLED2_322>0</OEMLED2_322>
    <OEMDRO2_323>0.</OEMDRO2_323>
    <OEMLED2_323>0</OEMLED2_323>
    <OEMDRO2_324>0.</OEMDRO2_324>
    <OEMLED2_324>0</OEMLED2_324>
    <OEMDRO2_325>0.</OEMDRO2_325>
    <OEMLED2_325>0</OEMLED2_325>
    <OEMDRO2_326>0.</OEMDRO2_326>
    <OEMLED2_326>0</OEMLED2_326>
    <OEMDRO2_327>0.</OEMDRO2_327>
    <OEMLED2_327>0</OEMLED2_327>
    <OEMDRO2_328>0.</OEMDRO2_328>
    <OEMLED2_328>0</OEMLED2_328>
    <OEMDRO2_329>0.</OEMDRO2_329>
    <OEMLED2_329>0</OEMLED2_329>
    <OEMDRO2_330>0.</OEMDRO2_330>
    <OEMLED2_330>0</OEMLED2_330>
    <OEMDRO2_331>0.</OEMDRO2_331>
    <OEMLED2_331>0</OEMLED2_331>
    <OEMDRO2_332>0.</OEMDRO2_332>
    <OEMLED2_332>0</OEMLED2_332>
    <OEMDRO2_333>0.</OEMDRO2_333>
    <OEMLED2_333>0</OEMLED2_333>
    <OEMDRO2_334>0.</OEMDRO2_334>
    <OEMLED2_334>0</OEMLED2_334>
    <OEMDRO2_335>0.</OEMDRO2_335>
    <OEMLED2_335>0</OEMLED2_335>
    <OEMDRO2_336>0.</OEMDRO2_336>
    <OEMLED2_336>0</OEMLED2_336>
    <OEMDRO2_337>0.</OEMDRO2_337>
    <OEMLED2_337>0</OEMLED2_337>
    <OEMDRO2_338>0.</OEMDRO2_338>
    <OEMLED2_338>0</OEMLED2_338>
    <OEMDRO2_339>0.</OEMDRO2_339>
    <OEMLED2_339>0</OEMLED2_339>
    <OEMDRO2_340>0.</OEMDRO2_340>
    <OEMLED2_340>0</OEMLED2_340>
    <OEMDRO2_341>0.</OEMDRO2_341>
    <OEMLED2_341>0</OEMLED2_341>
    <OEMDRO2_342>0.</OEMDRO2_342>
    <OEMLED2_342>0</OEMLED2_342>
    <OEMDRO2_343>0.</OEMDRO2_343>
    <OEMLED2_343>0</OEMLED2_343>
    <OEMDRO2_344>0.</OEMDRO2_344>
    <OEMLED2_344>0</OEMLED2_344>
    <OEMDRO2_345>0.</OEMDRO2_345>
    <OEMLED2_345>0</OEMLED2_345>
    <OEMDRO2_346>0.</OEMDRO2_346>
    <OEMLED2_346>0</OEMLED2_346>
    <OEMDRO2_347>0.</OEMDRO2_347>
    <OEMLED2_347>0</OEMLED2_347>
    <OEMDRO2_348>0.</OEMDRO2_348>
    <OEMLED2_348>0</OEMLED2_348>
    <OEMDRO2_349>0.</OEMDRO2_349>
    <OEMLED2_349>0</OEMLED2_349>
    <OEMDRO2_350>0.</OEMDRO2_350>
    <OEMLED2_350>0</OEMLED2_350>
    <OEMDRO2_351>0.</OEMDRO2_351>
    <OEMLED2_351>0</OEMLED2_351>
    <OEMDRO2_352>0.</OEMDRO2_352>
    <OEMLED2_352>0</OEMLED2_352>
    <OEMDRO2_353>0.</OEMDRO2_353>
    <OEMLED2_353>0</OEMLED2_353>
    <OEMDRO2_354>0.</OEMDRO2_354>
    <OEMLED2_354>0</OEMLED2_354>
    <OEMDRO2_355>0.</OEMDRO2_355>
    <OEMLED2_355>0</OEMLED2_355>
    <OEMDRO2_356>0.</OEMDRO2_356>
    <OEMLED2_356>0</OEMLED2_356>
    <OEMDRO2_357>0.</OEMDRO2_357>
    <OEMLED2_357>0</OEMLED2_357>
    <OEMDRO2_358>0.</OEMDRO2_358>
    <OEMLED2_358>0</OEMLED2_358>
    <OEMDRO2_359>0.</OEMDRO2_359>
    <OEMLED2_359>0</OEMLED2_359>
    <OEMDRO2_360>0.</OEMDRO2_360>
    <OEMLED2_360>0</OEMLED2_360>
    <OEMDRO2_361>0.</OEMDRO2_361>
    <OEMLED2_361>0</OEMLED2_361>
    <OEMDRO2_362>0.</OEMDRO2_362>
    <OEMLED2_362>0</OEMLED2_362>
    <OEMDRO2_363>0.</OEMDRO2_363>
    <OEMLED2_363>0</OEMLED2_363>
    <OEMDRO2_364>0.</OEMDRO2_364>
    <OEMLED2_364>0</OEMLED2_364>
    <OEMDRO2_365>0.</OEMDRO2_365>
    <OEMLED2_365>0</OEMLED2_365>
    <OEMDRO2_366>0.</OEMDRO2_366>
    <OEMLED2_366>0</OEMLED2_366>
    <OEMDRO2_367>0.</OEMDRO2_367>
    <OEMLED2_367>0</OEMLED2_367>
    <OEMDRO2_368>0.</OEMDRO2_368>
    <OEMLED2_368>0</OEMLED2_368>
    <OEMDRO2_369>0.</OEMDRO2_369>
    <OEMLED2_369>0</OEMLED2_369>
    <OEMDRO2_370>0.</OEMDRO2_370>
    <OEMLED2_370>0</OEMLED2_370>
    <OEMDRO2_371>0.</OEMDRO2_371>
    <OEMLED2_371>0</OEMLED2_371>
    <OEMDRO2_372>0.</OEMDRO2_372>
    <OEMLED2_372>0</OEMLED2_372>
    <OEMDRO2_373>0.</OEMDRO2_373>
    <OEMLED2_373>0</OEMLED2_373>
    <OEMDRO2_374>0.</OEMDRO2_374>
    <OEMLED2_374>0</OEMLED2_374>
    <OEMDRO2_375>0.</OEMDRO2_375>
    <OEMLED2_375>0</OEMLED2_375>
    <OEMDRO2_376>0.</OEMDRO2_376>
    <OEMLED2_376>0</OEMLED2_376>
    <OEMDRO2_377>0.</OEMDRO2_377>
    <OEMLED2_377>0</OEMLED2_377>
    <OEMDRO2_378>0.</OEMDRO2_378>
    <OEMLED2_378>0</OEMLED2_378>
    <OEMDRO2_379>0.</OEMDRO2_379>
    <OEMLED2_379>0</OEMLED2_379>
    <OEMDRO2_380>0.</OEMDRO2_380>
    <OEMLED2_380>0</OEMLED2_380>
    <OEMDRO2_381>0.</OEMDRO2_381>
    <OEMLED2_381>0</OEMLED2_381>
    <OEMDRO2_382>0.</OEMDRO2_382>
    <OEMLED2_382>0</OEMLED2_382>
    <OEMDRO2_383>0.</OEMDRO2_383>
    <OEMLED2_383>0</OEMLED2_383>
    <OEMDRO2_384>0.</OEMDRO2_384>
    <OEMLED2_384>0</OEMLED2_384>
    <OEMDRO2_385>0.</OEMDRO2_385>
    <OEMLED2_385>0</OEMLED2_385>
    <OEMDRO2_386>0.</OEMDRO2_386>
    <OEMLED2_386>0</OEMLED2_386>
    <OEMDRO2_387>0.</OEMDRO2_387>
    <OEMLED2_387>0</OEMLED2_387>
    <OEMDRO2_388>0.</OEMDRO2_388>
    <OEMLED2_388>0</OEMLED2_388>
    <OEMDRO2_389>0.</OEMDRO2_389>
    <OEMLED2_389>0</OEMLED2_389>
    <OEMDRO2_390>0.</OEMDRO2_390>
    <OEMLED2_390>0</OEMLED2_390>
    <OEMDRO2_391>0.</OEMDRO2_391>
    <OEMLED2_391>0</OEMLED2_391>
    <OEMDRO2_392>0.</OEMDRO2_392>
    <OEMLED2_392>0</OEMLED2_392>
    <OEMDRO2_393>0.</OEMDRO2_393>
    <OEMLED2_393>0</OEMLED2_393>
    <OEMDRO2_394>0.</OEMDRO2_394>
    <OEMLED2_394>0</OEMLED2_394>
    <OEMDRO2_395>0.</OEMDRO2_395>
    <OEMLED2_395>0</OEMLED2_395>
    <OEMDRO2_396>0.</OEMDRO2_396>
    <OEMLED2_396>0</OEMLED2_396>
    <OEMDRO2_397>0.</OEMDRO2_397>
    <OEMLED2_397>0</OEMLED2_397>
    <OEMDRO2_398>0.</OEMDRO2_398>
    <OEMLED2_398>0</OEMLED2_398>
    <OEMDRO2_399>0.</OEMDRO2_399>
    <OEMLED2_399>0</OEMLED2_399>
    <OEMDRO2_400>0.</OEMDRO2_400>
    <OEMLED2_400>0</OEMLED2_400>
    <OEMDRO2_401>0.</OEMDRO2_401>
    <OEMLED2_401>0</OEMLED2_401>
    <OEMDRO2_402>0.</OEMDRO2_402>
    <OEMLED2_402>0</OEMLED2_402>
    <OEMDRO2_403>0.</OEMDRO2_403>
    <OEMLED2_403>0</OEMLED2_403>
    <OEMDRO2_404>0.</OEMDRO2_404>
    <OEMLED2_404>0</OEMLED2_404>
    <OEMDRO2_405>0.</OEMDRO2_405>
    <OEMLED2_405>0</OEMLED2_405>
    <OEMDRO2_406>0.</OEMDRO2_406>
    <OEMLED2_406>0</OEMLED2_406>
    <OEMDRO2_407>0.</OEMDRO2_407>
    <OEMLED2_407>0</OEMLED2_407>
    <OEMDRO2_408>0.</OEMDRO2_408>
    <OEMLED2_408>0</OEMLED2_408>
    <OEMDRO2_409>0.</OEMDRO2_409>
    <OEMLED2_409>0</OEMLED2_409>
    <OEMDRO2_410>0.</OEMDRO2_410>
    <OEMLED2_410>0</OEMLED2_410>
    <OEMDRO2_411>0.</OEMDRO2_411>
    <OEMLED2_411>0</OEMLED2_411>
    <OEMDRO2_412>0.</OEMDRO2_412>
    <OEMLED2_412>0</OEMLED2_412>
    <OEMDRO2_413>0.</OEMDRO2_413>
    <OEMLED2_413>0</OEMLED2_413>
    <OEMDRO2_414>0.</OEMDRO2_414>
    <OEMLED2_414>0</OEMLED2_414>
    <OEMDRO2_415>0.</OEMDRO2_415>
    <OEMLED2_415>0</OEMLED2_415>
    <OEMDRO2_416>0.</OEMDRO2_416>
    <OEMLED2_416>0</OEMLED2_416>
    <OEMDRO2_417>0.</OEMDRO2_417>
    <OEMLED2_417>0</OEMLED2_417>
    <OEMDRO2_418>0.</OEMDRO2_418>
    <OEMLED2_418>0</OEMLED2_418>
    <OEMDRO2_419>0.</OEMDRO2_419>
    <OEMLED2_419>0</OEMLED2_419>
    <OEMDRO2_420>0.</OEMDRO2_420>
    <OEMLED2_420>0</OEMLED2_420>
    <OEMDRO2_421>0.</OEMDRO2_421>
    <OEMLED2_421>0</OEMLED2_421>
    <OEMDRO2_422>0.</OEMDRO2_422>
    <OEMLED2_422>0</OEMLED2_422>
    <OEMDRO2_423>0.</OEMDRO2_423>
    <OEMLED2_423>0</OEMLED2_423>
    <OEMDRO2_424>0.</OEMDRO2_424>
    <OEMLED2_424>0</OEMLED2_424>
    <OEMDRO2_425>0.</OEMDRO2_425>
    <OEMLED2_425>0</OEMLED2_425>
    <OEMDRO2_426>0.</OEMDRO2_426>
    <OEMLED2_426>0</OEMLED2_426>
    <OEMDRO2_427>0.</OEMDRO2_427>
    <OEMLED2_427>0</OEMLED2_427>
    <OEMDRO2_428>0.</OEMDRO2_428>
    <OEMLED2_428>0</OEMLED2_428>
    <OEMDRO2_429>0.</OEMDRO2_429>
    <OEMLED2_429>0</OEMLED2_429>
    <OEMDRO2_430>0.</OEMDRO2_430>
    <OEMLED2_430>0</OEMLED2_430>
    <OEMDRO2_431>0.</OEMDRO2_431>
    <OEMLED2_431>0</OEMLED2_431>
    <OEMDRO2_432>0.</OEMDRO2_432>
    <OEMLED2_432>0</OEMLED2_432>
    <OEMDRO2_433>0.</OEMDRO2_433>
    <OEMLED2_433>0</OEMLED2_433>
    <OEMDRO2_434>0.</OEMDRO2_434>
    <OEMLED2_434>0</OEMLED2_434>
    <OEMDRO2_435>0.</OEMDRO2_435>
    <OEMLED2_435>0</OEMLED2_435>
    <OEMDRO2_436>0.</OEMDRO2_436>
    <OEMLED2_436>0</OEMLED2_436>
    <OEMDRO2_437>0.</OEMDRO2_437>
    <OEMLED2_437>0</OEMLED2_437>
    <OEMDRO2_438>0.</OEMDRO2_438>
    <OEMLED2_438>0</OEMLED2_438>
    <OEMDRO2_439>0.</OEMDRO2_439>
    <OEMLED2_439>0</OEMLED2_439>
    <OEMDRO2_440>0.</OEMDRO2_440>
    <OEMLED2_440>0</OEMLED2_440>
    <OEMDRO2_441>0.</OEMDRO2_441>
    <OEMLED2_441>0</OEMLED2_441>
    <OEMDRO2_442>0.</OEMDRO2_442>
    <OEMLED2_442>0</OEMLED2_442>
    <OEMDRO2_443>0.</OEMDRO2_443>
    <OEMLED2_443>0</OEMLED2_443>
    <OEMDRO2_444>0.</OEMDRO2_444>
    <OEMLED2_444>0</OEMLED2_444>
    <OEMDRO2_445>0.</OEMDRO2_445>
    <OEMLED2_445>0</OEMLED2_445>
    <OEMDRO2_446>0.</OEMDRO2_446>
    <OEMLED2_446>0</OEMLED2_446>
    <OEMDRO2_447>0.</OEMDRO2_447>
    <OEMLED2_447>0</OEMLED2_447>
    <OEMDRO2_448>0.</OEMDRO2_448>
    <OEMLED2_448>0</OEMLED2_448>
    <OEMDRO2_449>0.</OEMDRO2_449>
    <OEMLED2_449>0</OEMLED2_449>
    <OEMDRO2_450>0.</OEMDRO2_450>
    <OEMLED2_450>0</OEMLED2_450>
    <OEMDRO2_451>0.</OEMDRO2_451>
    <OEMLED2_451>0</OEMLED2_451>
    <OEMDRO2_452>0.</OEMDRO2_452>
    <OEMLED2_452>0</OEMLED2_452>
    <OEMDRO2_453>0.</OEMDRO2_453>
    <OEMLED2_453>0</OEMLED2_453>
    <OEMDRO2_454>0.</OEMDRO2_454>
    <OEMLED2_454>0</OEMLED2_454>
    <OEMDRO2_455>0.</OEMDRO2_455>
    <OEMLED2_455>0</OEMLED2_455>
    <OEMDRO2_456>0.</OEMDRO2_456>
    <OEMLED2_456>0</OEMLED2_456>
    <OEMDRO2_457>0.</OEMDRO2_457>
    <OEMLED2_457>0</OEMLED2_457>
    <OEMDRO2_458>0.</OEMDRO2_458>
    <OEMLED2_458>0</OEMLED2_458>
    <OEMDRO2_459>0.</OEMDRO2_459>
    <OEMLED2_459>0</OEMLED2_459>
    <OEMDRO2_460>0.</OEMDRO2_460>
    <OEMLED2_460>0</OEMLED2_460>
    <OEMDRO2_461>0.</OEMDRO2_461>
    <OEMLED2_461>0</OEMLED2_461>
    <OEMDRO2_462>0.</OEMDRO2_462>
    <OEMLED2_462>0</OEMLED2_462>
    <OEMDRO2_463>0.</OEMDRO2_463>
    <OEMLED2_463>0</OEMLED2_463>
    <OEMDRO2_464>0.</OEMDRO2_464>
    <OEMLED2_464>0</OEMLED2_464>
    <OEMDRO2_465>0.</OEMDRO2_465>
    <OEMLED2_465>0</OEMLED2_465>
    <OEMDRO2_466>0.</OEMDRO2_466>
    <OEMLED2_466>0</OEMLED2_466>
    <OEMDRO2_467>0.</OEMDRO2_467>
    <OEMLED2_467>0</OEMLED2_467>
    <OEMDRO2_468>0.</OEMDRO2_468>
    <OEMLED2_468>0</OEMLED2_468>
    <OEMDRO2_469>0.</OEMDRO2_469>
    <OEMLED2_469>0</OEMLED2_469>
    <OEMDRO2_470>0.</OEMDRO2_470>
    <OEMLED2_470>0</OEMLED2_470>
    <OEMDRO2_471>0.</OEMDRO2_471>
    <OEMLED2_471>0</OEMLED2_471>
    <OEMDRO2_472>0.</OEMDRO2_472>
    <OEMLED2_472>0</OEMLED2_472>
    <OEMDRO2_473>0.</OEMDRO2_473>
    <OEMLED2_473>0</OEMLED2_473>
    <OEMDRO2_474>0.</OEMDRO2_474>
    <OEMLED2_474>0</OEMLED2_474>
    <OEMDRO2_475>0.</OEMDRO2_475>
    <OEMLED2_475>0</OEMLED2_475>
    <OEMDRO2_476>0.</OEMDRO2_476>
    <OEMLED2_476>0</OEMLED2_476>
    <OEMDRO2_477>0.</OEMDRO2_477>
    <OEMLED2_477>0</OEMLED2_477>
    <OEMDRO2_478>0.</OEMDRO2_478>
    <OEMLED2_478>0</OEMLED2_478>
    <OEMDRO2_479>0.</OEMDRO2_479>
    <OEMLED2_479>0</OEMLED2_479>
    <OEMDRO2_480>0.</OEMDRO2_480>
    <OEMLED2_480>0</OEMLED2_480>
    <OEMDRO2_481>0.</OEMDRO2_481>
    <OEMLED2_481>0</OEMLED2_481>
    <OEMDRO2_482>0.</OEMDRO2_482>
    <OEMLED2_482>0</OEMLED2_482>
    <OEMDRO2_483>0.</OEMDRO2_483>
    <OEMLED2_483>0</OEMLED2_483>
    <OEMDRO2_484>0.</OEMDRO2_484>
    <OEMLED2_484>0</OEMLED2_484>
    <OEMDRO2_485>0.</OEMDRO2_485>
    <OEMLED2_485>0</OEMLED2_485>
    <OEMDRO2_486>0.</OEMDRO2_486>
    <OEMLED2_486>0</OEMLED2_486>
    <OEMDRO2_487>0.</OEMDRO2_487>
    <OEMLED2_487>0</OEMLED2_487>
    <OEMDRO2_488>0.</OEMDRO2_488>
    <OEMLED2_488>0</OEMLED2_488>
    <OEMDRO2_489>0.</OEMDRO2_489>
    <OEMLED2_489>0</OEMLED2_489>
    <OEMDRO2_490>0.</OEMDRO2_490>
    <OEMLED2_490>0</OEMLED2_490>
    <OEMDRO2_491>0.</OEMDRO2_491>
    <OEMLED2_491>0</OEMLED2_491>
    <OEMDRO2_492>0.</OEMDRO2_492>
    <OEMLED2_492>0</OEMLED2_492>
    <OEMDRO2_493>0.</OEMDRO2_493>
    <OEMLED2_493>0</OEMLED2_493>
    <OEMDRO2_494>0.</OEMDRO2_494>
    <OEMLED2_494>0</OEMLED2_494>
    <OEMDRO2_495>0.</OEMDRO2_495>
    <OEMLED2_495>0</OEMLED2_495>
    <OEMDRO2_496>0.</OEMDRO2_496>
    <OEMLED2_496>0</OEMLED2_496>
    <OEMDRO2_497>0.</OEMDRO2_497>
    <OEMLED2_497>0</OEMLED2_497>
    <OEMDRO2_498>0.</OEMDRO2_498>
    <OEMLED2_498>0</OEMLED2_498>
    <OEMDRO2_499>0.</OEMDRO2_499>
    <OEMLED2_499>0</OEMLED2_499>
    <OEMDRO2_500>0.</OEMDRO2_500>
    <OEMLED2_500>0</OEMLED2_500>
    <OEMDRO2_501>0.</OEMDRO2_501>
    <OEMLED2_501>0</OEMLED2_501>
    <OEMDRO2_502>0.</OEMDRO2_502>
    <OEMLED2_502>0</OEMLED2_502>
    <OEMDRO2_503>0.</OEMDRO2_503>
    <OEMLED2_503>0</OEMLED2_503>
    <OEMDRO2_504>0.</OEMDRO2_504>
    <OEMLED2_504>0</OEMLED2_504>
    <OEMDRO2_505>0.</OEMDRO2_505>
    <OEMLED2_505>0</OEMLED2_505>
    <OEMDRO2_506>0.</OEMDRO2_506>
    <OEMLED2_506>0</OEMLED2_506>
    <OEMDRO2_507>0.</OEMDRO2_507>
    <OEMLED2_507>0</OEMLED2_507>
    <OEMDRO2_508>0.</OEMDRO2_508>
    <OEMLED2_508>0</OEMLED2_508>
    <OEMDRO2_509>0.</OEMDRO2_509>
    <OEMLED2_509>0</OEMLED2_509>
    <OEMDRO2_510>0.</OEMDRO2_510>
    <OEMLED2_510>0</OEMLED2_510>
    <OEMDRO2_511>0.</OEMDRO2_511>
    <OEMLED2_511>0</OEMLED2_511>
    <OEMDRO2_512>0.</OEMDRO2_512>
    <OEMLED2_512>0</OEMLED2_512>
    <OEMDRO2_513>0.</OEMDRO2_513>
    <OEMLED2_513>0</OEMLED2_513>
    <OEMDRO2_514>0.</OEMDRO2_514>
    <OEMLED2_514>0</OEMLED2_514>
    <OEMDRO2_515>0.</OEMDRO2_515>
    <OEMLED2_515>0</OEMLED2_515>
    <OEMDRO2_516>0.</OEMDRO2_516>
    <OEMLED2_516>0</OEMLED2_516>
    <OEMDRO2_517>0.</OEMDRO2_517>
    <OEMLED2_517>0</OEMLED2_517>
    <OEMDRO2_518>0.</OEMDRO2_518>
    <OEMLED2_518>0</OEMLED2_518>
    <OEMDRO2_519>0.</OEMDRO2_519>
    <OEMLED2_519>0</OEMLED2_519>
    <OEMDRO2_520>0.</OEMDRO2_520>
    <OEMLED2_520>0</OEMLED2_520>
    <OEMDRO2_521>0.</OEMDRO2_521>
    <OEMLED2_521>0</OEMLED2_521>
    <OEMDRO2_522>0.</OEMDRO2_522>
    <OEMLED2_522>0</OEMLED2_522>
    <OEMDRO2_523>0.</OEMDRO2_523>
    <OEMLED2_523>0</OEMLED2_523>
    <OEMDRO2_524>0.</OEMDRO2_524>
    <OEMLED2_524>0</OEMLED2_524>
    <OEMDRO2_525>0.</OEMDRO2_525>
    <OEMLED2_525>0</OEMLED2_525>
    <OEMDRO2_526>0.</OEMDRO2_526>
    <OEMLED2_526>0</OEMLED2_526>
    <OEMDRO2_527>0.</OEMDRO2_527>
    <OEMLED2_527>0</OEMLED2_527>
    <OEMDRO2_528>0.</OEMDRO2_528>
    <OEMLED2_528>0</OEMLED2_528>
    <OEMDRO2_529>0.</OEMDRO2_529>
    <OEMLED2_529>0</OEMLED2_529>
    <OEMDRO2_530>0.</OEMDRO2_530>
    <OEMLED2_530>0</OEMLED2_530>
    <OEMDRO2_531>0.</OEMDRO2_531>
    <OEMLED2_531>0</OEMLED2_531>
    <OEMDRO2_532>0.</OEMDRO2_532>
    <OEMLED2_532>0</OEMLED2_532>
    <OEMDRO2_533>0.</OEMDRO2_533>
    <OEMLED2_533>0</OEMLED2_533>
    <OEMDRO2_534>0.</OEMDRO2_534>
    <OEMLED2_534>0</OEMLED2_534>
    <OEMDRO2_535>0.</OEMDRO2_535>
    <OEMLED2_535>0</OEMLED2_535>
    <OEMDRO2_536>0.</OEMDRO2_536>
    <OEMLED2_536>0</OEMLED2_536>
    <OEMDRO2_537>0.</OEMDRO2_537>
    <OEMLED2_537>0</OEMLED2_537>
    <OEMDRO2_538>0.</OEMDRO2_538>
    <OEMLED2_538>0</OEMLED2_538>
    <OEMDRO2_539>0.</OEMDRO2_539>
    <OEMLED2_539>0</OEMLED2_539>
    <OEMDRO2_540>0.</OEMDRO2_540>
    <OEMLED2_540>0</OEMLED2_540>
    <OEMDRO2_541>0.</OEMDRO2_541>
    <OEMLED2_541>0</OEMLED2_541>
    <OEMDRO2_542>0.</OEMDRO2_542>
    <OEMLED2_542>0</OEMLED2_542>
    <OEMDRO2_543>0.</OEMDRO2_543>
    <OEMLED2_543>0</OEMLED2_543>
    <OEMDRO2_544>0.</OEMDRO2_544>
    <OEMLED2_544>0</OEMLED2_544>
    <OEMDRO2_545>0.</OEMDRO2_545>
    <OEMLED2_545>0</OEMLED2_545>
    <OEMDRO2_546>0.</OEMDRO2_546>
    <OEMLED2_546>0</OEMLED2_546>
    <OEMDRO2_547>0.</OEMDRO2_547>
    <OEMLED2_547>0</OEMLED2_547>
    <OEMDRO2_548>0.</OEMDRO2_548>
    <OEMLED2_548>0</OEMLED2_548>
    <OEMDRO2_549>0.</OEMDRO2_549>
    <OEMLED2_549>0</OEMLED2_549>
    <OEMDRO2_550>0.</OEMDRO2_550>
    <OEMLED2_550>0</OEMLED2_550>
    <OEMDRO2_551>0.</OEMDRO2_551>
    <OEMLED2_551>0</OEMLED2_551>
    <OEMDRO2_552>0.</OEMDRO2_552>
    <OEMLED2_552>0</OEMLED2_552>
    <OEMDRO2_553>0.</OEMDRO2_553>
    <OEMLED2_553>0</OEMLED2_553>
    <OEMDRO2_554>0.</OEMDRO2_554>
    <OEMLED2_554>0</OEMLED2_554>
    <OEMDRO2_555>0.</OEMDRO2_555>
    <OEMLED2_555>0</OEMLED2_555>
    <OEMDRO2_556>0.</OEMDRO2_556>
    <OEMLED2_556>0</OEMLED2_556>
    <OEMDRO2_557>0.</OEMDRO2_557>
    <OEMLED2_557>0</OEMLED2_557>
    <OEMDRO2_558>0.</OEMDRO2_558>
    <OEMLED2_558>0</OEMLED2_558>
    <OEMDRO2_559>0.</OEMDRO2_559>
    <OEMLED2_559>0</OEMLED2_559>
    <OEMDRO2_560>0.</OEMDRO2_560>
    <OEMLED2_560>0</OEMLED2_560>
    <OEMDRO2_561>0.</OEMDRO2_561>
    <OEMLED2_561>0</OEMLED2_561>
    <OEMDRO2_562>0.</OEMDRO2_562>
    <OEMLED2_562>0</OEMLED2_562>
    <OEMDRO2_563>0.</OEMDRO2_563>
    <OEMLED2_563>0</OEMLED2_563>
    <OEMDRO2_564>0.</OEMDRO2_564>
    <OEMLED2_564>0</OEMLED2_564>
    <OEMDRO2_565>0.</OEMDRO2_565>
    <OEMLED2_565>0</OEMLED2_565>
    <OEMDRO2_566>0.</OEMDRO2_566>
    <OEMLED2_566>0</OEMLED2_566>
    <OEMDRO2_567>0.</OEMDRO2_567>
    <OEMLED2_567>0</OEMLED2_567>
    <OEMDRO2_568>0.</OEMDRO2_568>
    <OEMLED2_568>0</OEMLED2_568>
    <OEMDRO2_569>0.</OEMDRO2_569>
    <OEMLED2_569>0</OEMLED2_569>
    <OEMDRO2_570>0.</OEMDRO2_570>
    <OEMLED2_570>0</OEMLED2_570>
    <OEMDRO2_571>0.</OEMDRO2_571>
    <OEMLED2_571>0</OEMLED2_571>
    <OEMDRO2_572>0.</OEMDRO2_572>
    <OEMLED2_572>0</OEMLED2_572>
    <OEMDRO2_573>0.</OEMDRO2_573>
    <OEMLED2_573>0</OEMLED2_573>
    <OEMDRO2_574>0.</OEMDRO2_574>
    <OEMLED2_574>0</OEMLED2_574>
    <OEMDRO2_575>0.</OEMDRO2_575>
    <OEMLED2_575>0</OEMLED2_575>
    <OEMDRO2_576>0.</OEMDRO2_576>
    <OEMLED2_576>0</OEMLED2_576>
    <OEMDRO2_577>0.</OEMDRO2_577>
    <OEMLED2_577>0</OEMLED2_577>
    <OEMDRO2_578>0.</OEMDRO2_578>
    <OEMLED2_578>0</OEMLED2_578>
    <OEMDRO2_579>0.</OEMDRO2_579>
    <OEMLED2_579>0</OEMLED2_579>
    <OEMDRO2_580>0.</OEMDRO2_580>
    <OEMLED2_580>0</OEMLED2_580>
    <OEMDRO2_581>0.</OEMDRO2_581>
    <OEMLED2_581>0</OEMLED2_581>
    <OEMDRO2_582>0.</OEMDRO2_582>
    <OEMLED2_582>0</OEMLED2_582>
    <OEMDRO2_583>0.</OEMDRO2_583>
    <OEMLED2_583>0</OEMLED2_583>
    <OEMDRO2_584>0.</OEMDRO2_584>
    <OEMLED2_584>0</OEMLED2_584>
    <OEMDRO2_585>0.</OEMDRO2_585>
    <OEMLED2_585>0</OEMLED2_585>
    <OEMDRO2_586>0.</OEMDRO2_586>
    <OEMLED2_586>0</OEMLED2_586>
    <OEMDRO2_587>0.</OEMDRO2_587>
    <OEMLED2_587>0</OEMLED2_587>
    <OEMDRO2_588>0.</OEMDRO2_588>
    <OEMLED2_588>0</OEMLED2_588>
    <OEMDRO2_589>0.</OEMDRO2_589>
    <OEMLED2_589>0</OEMLED2_589>
    <OEMDRO2_590>0.</OEMDRO2_590>
    <OEMLED2_590>0</OEMLED2_590>
    <OEMDRO2_591>0.</OEMDRO2_591>
    <OEMLED2_591>0</OEMLED2_591>
    <OEMDRO2_592>0.</OEMDRO2_592>
    <OEMLED2_592>0</OEMLED2_592>
    <OEMDRO2_593>0.</OEMDRO2_593>
    <OEMLED2_593>0</OEMLED2_593>
    <OEMDRO2_594>0.</OEMDRO2_594>
    <OEMLED2_594>0</OEMLED2_594>
    <OEMDRO2_595>0.</OEMDRO2_595>
    <OEMLED2_595>0</OEMLED2_595>
    <OEMDRO2_596>0.</OEMDRO2_596>
    <OEMLED2_596>0</OEMLED2_596>
    <OEMDRO2_597>0.</OEMDRO2_597>
    <OEMLED2_597>0</OEMLED2_597>
    <OEMDRO2_598>0.</OEMDRO2_598>
    <OEMLED2_598>0</OEMLED2_598>
    <OEMDRO2_599>0.</OEMDRO2_599>
    <OEMLED2_599>0</OEMLED2_599>
    <OEMDRO2_600>0.</OEMDRO2_600>
    <OEMLED2_600>0</OEMLED2_600>
    <OEMDRO2_601>0.</OEMDRO2_601>
    <OEMLED2_601>0</OEMLED2_601>
    <OEMDRO2_602>0.</OEMDRO2_602>
    <OEMLED2_602>0</OEMLED2_602>
    <OEMDRO2_603>0.</OEMDRO2_603>
    <OEMLED2_603>0</OEMLED2_603>
    <OEMDRO2_604>0.</OEMDRO2_604>
    <OEMLED2_604>0</OEMLED2_604>
    <OEMDRO2_605>0.</OEMDRO2_605>
    <OEMLED2_605>0</OEMLED2_605>
    <OEMDRO2_606>0.</OEMDRO2_606>
    <OEMLED2_606>0</OEMLED2_606>
    <OEMDRO2_607>0.</OEMDRO2_607>
    <OEMLED2_607>0</OEMLED2_607>
    <OEMDRO2_608>0.</OEMDRO2_608>
    <OEMLED2_608>0</OEMLED2_608>
    <OEMDRO2_609>0.</OEMDRO2_609>
    <OEMLED2_609>0</OEMLED2_609>
    <OEMDRO2_610>0.</OEMDRO2_610>
    <OEMLED2_610>0</OEMLED2_610>
    <OEMDRO2_611>0.</OEMDRO2_611>
    <OEMLED2_611>0</OEMLED2_611>
    <OEMDRO2_612>0.</OEMDRO2_612>
    <OEMLED2_612>0</OEMLED2_612>
    <OEMDRO2_613>0.</OEMDRO2_613>
    <OEMLED2_613>0</OEMLED2_613>
    <OEMDRO2_614>0.</OEMDRO2_614>
    <OEMLED2_614>0</OEMLED2_614>
    <OEMDRO2_615>0.</OEMDRO2_615>
    <OEMLED2_615>0</OEMLED2_615>
    <OEMDRO2_616>0.</OEMDRO2_616>
    <OEMLED2_616>0</OEMLED2_616>
    <OEMDRO2_617>0.</OEMDRO2_617>
    <OEMLED2_617>0</OEMLED2_617>
    <OEMDRO2_618>0.</OEMDRO2_618>
    <OEMLED2_618>0</OEMLED2_618>
    <OEMDRO2_619>0.</OEMDRO2_619>
    <OEMLED2_619>0</OEMLED2_619>
    <OEMDRO2_620>0.</OEMDRO2_620>
    <OEMLED2_620>0</OEMLED2_620>
    <OEMDRO2_621>0.</OEMDRO2_621>
    <OEMLED2_621>0</OEMLED2_621>
    <OEMDRO2_622>0.</OEMDRO2_622>
    <OEMLED2_622>0</OEMLED2_622>
    <OEMDRO2_623>0.</OEMDRO2_623>
    <OEMLED2_623>0</OEMLED2_623>
    <OEMDRO2_624>0.</OEMDRO2_624>
    <OEMLED2_624>0</OEMLED2_624>
    <OEMDRO2_625>0.</OEMDRO2_625>
    <OEMLED2_625>0</OEMLED2_625>
    <OEMDRO2_626>0.</OEMDRO2_626>
    <OEMLED2_626>0</OEMLED2_626>
    <OEMDRO2_627>0.</OEMDRO2_627>
    <OEMLED2_627>0</OEMLED2_627>
    <OEMDRO2_628>0.</OEMDRO2_628>
    <OEMLED2_628>0</OEMLED2_628>
    <OEMDRO2_629>0.</OEMDRO2_629>
    <OEMLED2_629>0</OEMLED2_629>
    <OEMDRO2_630>0.</OEMDRO2_630>
    <OEMLED2_630>0</OEMLED2_630>
    <OEMDRO2_631>0.</OEMDRO2_631>
    <OEMLED2_631>0</OEMLED2_631>
    <OEMDRO2_632>0.</OEMDRO2_632>
    <OEMLED2_632>0</OEMLED2_632>
    <OEMDRO2_633>0.</OEMDRO2_633>
    <OEMLED2_633>0</OEMLED2_633>
    <OEMDRO2_634>0.</OEMDRO2_634>
    <OEMLED2_634>0</OEMLED2_634>
    <OEMDRO2_635>0.</OEMDRO2_635>
    <OEMLED2_635>0</OEMLED2_635>
    <OEMDRO2_636>0.</OEMDRO2_636>
    <OEMLED2_636>0</OEMLED2_636>
    <OEMDRO2_637>0.</OEMDRO2_637>
    <OEMLED2_637>0</OEMLED2_637>
    <OEMDRO2_638>0.</OEMDRO2_638>
    <OEMLED2_638>0</OEMLED2_638>
    <OEMDRO2_639>0.</OEMDRO2_639>
    <OEMLED2_639>0</OEMLED2_639>
    <OEMDRO2_640>0.</OEMDRO2_640>
    <OEMLED2_640>0</OEMLED2_640>
    <OEMDRO2_641>0.</OEMDRO2_641>
    <OEMLED2_641>0</OEMLED2_641>
    <OEMDRO2_642>0.</OEMDRO2_642>
    <OEMLED2_642>0</OEMLED2_642>
    <OEMDRO2_643>0.</OEMDRO2_643>
    <OEMLED2_643>0</OEMLED2_643>
    <OEMDRO2_644>0.</OEMDRO2_644>
    <OEMLED2_644>0</OEMLED2_644>
    <OEMDRO2_645>0.</OEMDRO2_645>
    <OEMLED2_645>0</OEMLED2_645>
    <OEMDRO2_646>0.</OEMDRO2_646>
    <OEMLED2_646>0</OEMLED2_646>
    <OEMDRO2_647>0.</OEMDRO2_647>
    <OEMLED2_647>0</OEMLED2_647>
    <OEMDRO2_648>0.</OEMDRO2_648>
    <OEMLED2_648>0</OEMLED2_648>
    <OEMDRO2_649>0.</OEMDRO2_649>
    <OEMLED2_649>0</OEMLED2_649>
    <OEMDRO2_650>0.</OEMDRO2_650>
    <OEMLED2_650>0</OEMLED2_650>
    <OEMDRO2_651>0.</OEMDRO2_651>
    <OEMLED2_651>0</OEMLED2_651>
    <OEMDRO2_652>0.</OEMDRO2_652>
    <OEMLED2_652>0</OEMLED2_652>
    <OEMDRO2_653>0.</OEMDRO2_653>
    <OEMLED2_653>0</OEMLED2_653>
    <OEMDRO2_654>0.</OEMDRO2_654>
    <OEMLED2_654>0</OEMLED2_654>
    <OEMDRO2_655>0.</OEMDRO2_655>
    <OEMLED2_655>0</OEMLED2_655>
    <OEMDRO2_656>0.</OEMDRO2_656>
    <OEMLED2_656>0</OEMLED2_656>
    <OEMDRO2_657>0.</OEMDRO2_657>
    <OEMLED2_657>0</OEMLED2_657>
    <OEMDRO2_658>0.</OEMDRO2_658>
    <OEMLED2_658>0</OEMLED2_658>
    <OEMDRO2_659>0.</OEMDRO2_659>
    <OEMLED2_659>0</OEMLED2_659>
    <OEMDRO2_660>0.</OEMDRO2_660>
    <OEMLED2_660>0</OEMLED2_660>
    <OEMDRO2_661>0.</OEMDRO2_661>
    <OEMLED2_661>0</OEMLED2_661>
    <OEMDRO2_662>0.</OEMDRO2_662>
    <OEMLED2_662>0</OEMLED2_662>
    <OEMDRO2_663>0.</OEMDRO2_663>
    <OEMLED2_663>0</OEMLED2_663>
    <OEMDRO2_664>0.</OEMDRO2_664>
    <OEMLED2_664>0</OEMLED2_664>
    <OEMDRO2_665>0.</OEMDRO2_665>
    <OEMLED2_665>0</OEMLED2_665>
    <OEMDRO2_666>0.</OEMDRO2_666>
    <OEMLED2_666>0</OEMLED2_666>
    <OEMDRO2_667>0.</OEMDRO2_667>
    <OEMLED2_667>0</OEMLED2_667>
    <OEMDRO2_668>0.</OEMDRO2_668>
    <OEMLED2_668>0</OEMLED2_668>
    <OEMDRO2_669>0.</OEMDRO2_669>
    <OEMLED2_669>0</OEMLED2_669>
    <OEMDRO2_670>0.</OEMDRO2_670>
    <OEMLED2_670>0</OEMLED2_670>
    <OEMDRO2_671>0.</OEMDRO2_671>
    <OEMLED2_671>0</OEMLED2_671>
    <OEMDRO2_672>0.</OEMDRO2_672>
    <OEMLED2_672>0</OEMLED2_672>
    <OEMDRO2_673>0.</OEMDRO2_673>
    <OEMLED2_673>0</OEMLED2_673>
    <OEMDRO2_674>0.</OEMDRO2_674>
    <OEMLED2_674>0</OEMLED2_674>
    <OEMDRO2_675>0.</OEMDRO2_675>
    <OEMLED2_675>0</OEMLED2_675>
    <OEMDRO2_676>0.</OEMDRO2_676>
    <OEMLED2_676>0</OEMLED2_676>
    <OEMDRO2_677>0.</OEMDRO2_677>
    <OEMLED2_677>0</OEMLED2_677>
    <OEMDRO2_678>0.</OEMDRO2_678>
    <OEMLED2_678>0</OEMLED2_678>
    <OEMDRO2_679>0.</OEMDRO2_679>
    <OEMLED2_679>0</OEMLED2_679>
    <OEMDRO2_680>0.</OEMDRO2_680>
    <OEMLED2_680>0</OEMLED2_680>
    <OEMDRO2_681>0.</OEMDRO2_681>
    <OEMLED2_681>0</OEMLED2_681>
    <OEMDRO2_682>0.</OEMDRO2_682>
    <OEMLED2_682>0</OEMLED2_682>
    <OEMDRO2_683>0.</OEMDRO2_683>
    <OEMLED2_683>0</OEMLED2_683>
    <OEMDRO2_684>0.</OEMDRO2_684>
    <OEMLED2_684>0</OEMLED2_684>
    <OEMDRO2_685>0.</OEMDRO2_685>
    <OEMLED2_685>0</OEMLED2_685>
    <OEMDRO2_686>0.</OEMDRO2_686>
    <OEMLED2_686>0</OEMLED2_686>
    <OEMDRO2_687>0.</OEMDRO2_687>
    <OEMLED2_687>0</OEMLED2_687>
    <OEMDRO2_688>0.</OEMDRO2_688>
    <OEMLED2_688>0</OEMLED2_688>
    <OEMDRO2_689>0.</OEMDRO2_689>
    <OEMLED2_689>0</OEMLED2_689>
    <OEMDRO2_690>0.</OEMDRO2_690>
    <OEMLED2_690>0</OEMLED2_690>
    <OEMDRO2_691>0.</OEMDRO2_691>
    <OEMLED2_691>0</OEMLED2_691>
    <OEMDRO2_692>0.</OEMDRO2_692>
    <OEMLED2_692>0</OEMLED2_692>
    <OEMDRO2_693>0.</OEMDRO2_693>
    <OEMLED2_693>0</OEMLED2_693>
    <OEMDRO2_694>0.</OEMDRO2_694>
    <OEMLED2_694>0</OEMLED2_694>
    <OEMDRO2_695>0.</OEMDRO2_695>
    <OEMLED2_695>0</OEMLED2_695>
    <OEMDRO2_696>0.</OEMDRO2_696>
    <OEMLED2_696>0</OEMLED2_696>
    <OEMDRO2_697>0.</OEMDRO2_697>
    <OEMLED2_697>0</OEMLED2_697>
    <OEMDRO2_698>0.</OEMDRO2_698>
    <OEMLED2_698>0</OEMLED2_698>
    <OEMDRO2_699>0.</OEMDRO2_699>
    <OEMLED2_699>0</OEMLED2_699>
    <OEMDRO2_700>0.</OEMDRO2_700>
    <OEMLED2_700>0</OEMLED2_700>
    <OEMDRO2_701>0.</OEMDRO2_701>
    <OEMLED2_701>0</OEMLED2_701>
    <OEMDRO2_702>0.</OEMDRO2_702>
    <OEMLED2_702>0</OEMLED2_702>
    <OEMDRO2_703>0.</OEMDRO2_703>
    <OEMLED2_703>0</OEMLED2_703>
    <OEMDRO2_704>0.</OEMDRO2_704>
    <OEMLED2_704>0</OEMLED2_704>
    <OEMDRO2_705>0.</OEMDRO2_705>
    <OEMLED2_705>0</OEMLED2_705>
    <OEMDRO2_706>0.</OEMDRO2_706>
    <OEMLED2_706>0</OEMLED2_706>
    <OEMDRO2_707>0.</OEMDRO2_707>
    <OEMLED2_707>0</OEMLED2_707>
    <OEMDRO2_708>0.</OEMDRO2_708>
    <OEMLED2_708>0</OEMLED2_708>
    <OEMDRO2_709>0.</OEMDRO2_709>
    <OEMLED2_709>0</OEMLED2_709>
    <OEMDRO2_710>0.</OEMDRO2_710>
    <OEMLED2_710>0</OEMLED2_710>
    <OEMDRO2_711>0.</OEMDRO2_711>
    <OEMLED2_711>0</OEMLED2_711>
    <OEMDRO2_712>0.</OEMDRO2_712>
    <OEMLED2_712>0</OEMLED2_712>
    <OEMDRO2_713>0.</OEMDRO2_713>
    <OEMLED2_713>0</OEMLED2_713>
    <OEMDRO2_714>0.</OEMDRO2_714>
    <OEMLED2_714>0</OEMLED2_714>
    <OEMDRO2_715>0.</OEMDRO2_715>
    <OEMLED2_715>0</OEMLED2_715>
    <OEMDRO2_716>0.</OEMDRO2_716>
    <OEMLED2_716>0</OEMLED2_716>
    <OEMDRO2_717>0.</OEMDRO2_717>
    <OEMLED2_717>0</OEMLED2_717>
    <OEMDRO2_718>0.</OEMDRO2_718>
    <OEMLED2_718>0</OEMLED2_718>
    <OEMDRO2_719>0.</OEMDRO2_719>
    <OEMLED2_719>0</OEMLED2_719>
    <OEMDRO2_720>0.</OEMDRO2_720>
    <OEMLED2_720>0</OEMLED2_720>
    <OEMDRO2_721>0.</OEMDRO2_721>
    <OEMLED2_721>0</OEMLED2_721>
    <OEMDRO2_722>0.</OEMDRO2_722>
    <OEMLED2_722>0</OEMLED2_722>
    <OEMDRO2_723>0.</OEMDRO2_723>
    <OEMLED2_723>0</OEMLED2_723>
    <OEMDRO2_724>0.</OEMDRO2_724>
    <OEMLED2_724>0</OEMLED2_724>
    <OEMDRO2_725>0.</OEMDRO2_725>
    <OEMLED2_725>0</OEMLED2_725>
    <OEMDRO2_726>0.</OEMDRO2_726>
    <OEMLED2_726>0</OEMLED2_726>
    <OEMDRO2_727>0.</OEMDRO2_727>
    <OEMLED2_727>0</OEMLED2_727>
    <OEMDRO2_728>0.</OEMDRO2_728>
    <OEMLED2_728>0</OEMLED2_728>
    <OEMDRO2_729>0.</OEMDRO2_729>
    <OEMLED2_729>0</OEMLED2_729>
    <OEMDRO2_730>0.</OEMDRO2_730>
    <OEMLED2_730>0</OEMLED2_730>
    <OEMDRO2_731>0.</OEMDRO2_731>
    <OEMLED2_731>0</OEMLED2_731>
    <OEMDRO2_732>0.</OEMDRO2_732>
    <OEMLED2_732>0</OEMLED2_732>
    <OEMDRO2_733>0.</OEMDRO2_733>
    <OEMLED2_733>0</OEMLED2_733>
    <OEMDRO2_734>0.</OEMDRO2_734>
    <OEMLED2_734>0</OEMLED2_734>
    <OEMDRO2_735>0.</OEMDRO2_735>
    <OEMLED2_735>0</OEMLED2_735>
    <OEMDRO2_736>0.</OEMDRO2_736>
    <OEMLED2_736>0</OEMLED2_736>
    <OEMDRO2_737>0.</OEMDRO2_737>
    <OEMLED2_737>0</OEMLED2_737>
    <OEMDRO2_738>0.</OEMDRO2_738>
    <OEMLED2_738>0</OEMLED2_738>
    <OEMDRO2_739>0.</OEMDRO2_739>
    <OEMLED2_739>0</OEMLED2_739>
    <OEMDRO2_740>0.</OEMDRO2_740>
    <OEMLED2_740>0</OEMLED2_740>
    <OEMDRO2_741>0.</OEMDRO2_741>
    <OEMLED2_741>0</OEMLED2_741>
    <OEMDRO2_742>0.</OEMDRO2_742>
    <OEMLED2_742>0</OEMLED2_742>
    <OEMDRO2_743>0.</OEMDRO2_743>
    <OEMLED2_743>0</OEMLED2_743>
    <OEMDRO2_744>0.</OEMDRO2_744>
    <OEMLED2_744>0</OEMLED2_744>
    <OEMDRO2_745>0.</OEMDRO2_745>
    <OEMLED2_745>0</OEMLED2_745>
    <OEMDRO2_746>0.</OEMDRO2_746>
    <OEMLED2_746>0</OEMLED2_746>
    <OEMDRO2_747>0.</OEMDRO2_747>
    <OEMLED2_747>0</OEMLED2_747>
    <OEMDRO2_748>0.</OEMDRO2_748>
    <OEMLED2_748>0</OEMLED2_748>
    <OEMDRO2_749>0.</OEMDRO2_749>
    <OEMLED2_749>0</OEMLED2_749>
    <OEMDRO2_750>0.</OEMDRO2_750>
    <OEMLED2_750>0</OEMLED2_750>
    <OEMDRO2_751>0.</OEMDRO2_751>
    <OEMLED2_751>0</OEMLED2_751>
    <OEMDRO2_752>0.</OEMDRO2_752>
    <OEMLED2_752>0</OEMLED2_752>
    <OEMDRO2_753>0.</OEMDRO2_753>
    <OEMLED2_753>0</OEMLED2_753>
    <OEMDRO2_754>0.</OEMDRO2_754>
    <OEMLED2_754>0</OEMLED2_754>
    <OEMDRO2_755>0.</OEMDRO2_755>
    <OEMLED2_755>0</OEMLED2_755>
    <OEMDRO2_756>0.</OEMDRO2_756>
    <OEMLED2_756>0</OEMLED2_756>
    <OEMDRO2_757>0.</OEMDRO2_757>
    <OEMLED2_757>0</OEMLED2_757>
    <OEMDRO2_758>0.</OEMDRO2_758>
    <OEMLED2_758>0</OEMLED2_758>
    <OEMDRO2_759>0.</OEMDRO2_759>
    <OEMLED2_759>0</OEMLED2_759>
    <OEMDRO2_760>0.</OEMDRO2_760>
    <OEMLED2_760>0</OEMLED2_760>
    <OEMDRO2_761>0.</OEMDRO2_761>
    <OEMLED2_761>0</OEMLED2_761>
    <OEMDRO2_762>0.</OEMDRO2_762>
    <OEMLED2_762>0</OEMLED2_762>
    <OEMDRO2_763>0.</OEMDRO2_763>
    <OEMLED2_763>0</OEMLED2_763>
    <OEMDRO2_764>0.</OEMDRO2_764>
    <OEMLED2_764>0</OEMLED2_764>
    <OEMDRO2_765>0.</OEMDRO2_765>
    <OEMLED2_765>0</OEMLED2_765>
    <OEMDRO2_766>0.</OEMDRO2_766>
    <OEMLED2_766>0</OEMLED2_766>
    <OEMDRO2_767>0.</OEMDRO2_767>
    <OEMLED2_767>0</OEMLED2_767>
    <OEMDRO2_768>0.</OEMDRO2_768>
    <OEMLED2_768>0</OEMLED2_768>
    <OEMDRO2_769>0.</OEMDRO2_769>
    <OEMLED2_769>0</OEMLED2_769>
    <OEMDRO2_770>0.</OEMDRO2_770>
    <OEMLED2_770>0</OEMLED2_770>
    <OEMDRO2_771>0.</OEMDRO2_771>
    <OEMLED2_771>0</OEMLED2_771>
    <OEMDRO2_772>0.</OEMDRO2_772>
    <OEMLED2_772>0</OEMLED2_772>
    <OEMDRO2_773>0.</OEMDRO2_773>
    <OEMLED2_773>0</OEMLED2_773>
    <OEMDRO2_774>0.</OEMDRO2_774>
    <OEMLED2_774>0</OEMLED2_774>
    <OEMDRO2_775>0.</OEMDRO2_775>
    <OEMLED2_775>0</OEMLED2_775>
    <OEMDRO2_776>0.</OEMDRO2_776>
    <OEMLED2_776>0</OEMLED2_776>
    <OEMDRO2_777>0.</OEMDRO2_777>
    <OEMLED2_777>0</OEMLED2_777>
    <OEMDRO2_778>0.</OEMDRO2_778>
    <OEMLED2_778>0</OEMLED2_778>
    <OEMDRO2_779>0.</OEMDRO2_779>
    <OEMLED2_779>0</OEMLED2_779>
    <OEMDRO2_780>0.</OEMDRO2_780>
    <OEMLED2_780>0</OEMLED2_780>
    <OEMDRO2_781>0.</OEMDRO2_781>
    <OEMLED2_781>0</OEMLED2_781>
    <OEMDRO2_782>0.</OEMDRO2_782>
    <OEMLED2_782>0</OEMLED2_782>
    <OEMDRO2_783>0.</OEMDRO2_783>
    <OEMLED2_783>0</OEMLED2_783>
    <OEMDRO2_784>0.</OEMDRO2_784>
    <OEMLED2_784>0</OEMLED2_784>
    <OEMDRO2_785>0.</OEMDRO2_785>
    <OEMLED2_785>0</OEMLED2_785>
    <OEMDRO2_786>0.</OEMDRO2_786>
    <OEMLED2_786>0</OEMLED2_786>
    <OEMDRO2_787>0.</OEMDRO2_787>
    <OEMLED2_787>0</OEMLED2_787>
    <OEMDRO2_788>0.</OEMDRO2_788>
    <OEMLED2_788>0</OEMLED2_788>
    <OEMDRO2_789>0.</OEMDRO2_789>
    <OEMLED2_789>0</OEMLED2_789>
    <OEMDRO2_790>0.</OEMDRO2_790>
    <OEMLED2_790>0</OEMLED2_790>
    <OEMDRO2_791>0.</OEMDRO2_791>
    <OEMLED2_791>0</OEMLED2_791>
    <OEMDRO2_792>0.</OEMDRO2_792>
    <OEMLED2_792>0</OEMLED2_792>
    <OEMDRO2_793>0.</OEMDRO2_793>
    <OEMLED2_793>0</OEMLED2_793>
    <OEMDRO2_794>0.</OEMDRO2_794>
    <OEMLED2_794>0</OEMLED2_794>
    <OEMDRO2_795>0.</OEMDRO2_795>
    <OEMLED2_795>0</OEMLED2_795>
    <OEMDRO2_796>0.</OEMDRO2_796>
    <OEMLED2_796>0</OEMLED2_796>
    <OEMDRO2_797>0.</OEMDRO2_797>
    <OEMLED2_797>0</OEMLED2_797>
    <OEMDRO2_798>0.</OEMDRO2_798>
    <OEMLED2_798>0</OEMLED2_798>
    <OEMDRO2_799>0.</OEMDRO2_799>
    <OEMLED2_799>0</OEMLED2_799>
    <OEMDRO2_800>0.</OEMDRO2_800>
    <OEMLED2_800>0</OEMLED2_800>
    <OEMDRO2_801>0.</OEMDRO2_801>
    <OEMLED2_801>0</OEMLED2_801>
    <OEMDRO2_802>0.</OEMDRO2_802>
    <OEMLED2_802>0</OEMLED2_802>
    <OEMDRO2_803>0.</OEMDRO2_803>
    <OEMLED2_803>0</OEMLED2_803>
    <OEMDRO2_804>0.</OEMDRO2_804>
    <OEMLED2_804>0</OEMLED2_804>
    <OEMDRO2_805>0.</OEMDRO2_805>
    <OEMLED2_805>0</OEMLED2_805>
    <OEMDRO2_806>0.</OEMDRO2_806>
    <OEMLED2_806>0</OEMLED2_806>
    <OEMDRO2_807>0.</OEMDRO2_807>
    <OEMLED2_807>0</OEMLED2_807>
    <OEMDRO2_808>0.</OEMDRO2_808>
    <OEMLED2_808>0</OEMLED2_808>
    <OEMDRO2_809>0.</OEMDRO2_809>
    <OEMLED2_809>0</OEMLED2_809>
    <OEMDRO2_810>0.</OEMDRO2_810>
    <OEMLED2_810>0</OEMLED2_810>
    <OEMDRO2_811>0.</OEMDRO2_811>
    <OEMLED2_811>0</OEMLED2_811>
    <OEMDRO2_812>0.</OEMDRO2_812>
    <OEMLED2_812>0</OEMLED2_812>
    <OEMDRO2_813>0.</OEMDRO2_813>
    <OEMLED2_813>0</OEMLED2_813>
    <OEMDRO2_814>0.</OEMDRO2_814>
    <OEMLED2_814>0</OEMLED2_814>
    <OEMDRO2_815>0.</OEMDRO2_815>
    <OEMLED2_815>0</OEMLED2_815>
    <OEMDRO2_816>0.</OEMDRO2_816>
    <OEMLED2_816>0</OEMLED2_816>
    <OEMDRO2_817>0.</OEMDRO2_817>
    <OEMLED2_817>0</OEMLED2_817>
    <OEMDRO2_818>0.</OEMDRO2_818>
    <OEMLED2_818>0</OEMLED2_818>
    <OEMDRO2_819>0.</OEMDRO2_819>
    <OEMLED2_819>0</OEMLED2_819>
    <OEMDRO2_820>0.</OEMDRO2_820>
    <OEMLED2_820>0</OEMLED2_820>
    <OEMDRO2_821>0.</OEMDRO2_821>
    <OEMLED2_821>0</OEMLED2_821>
    <OEMDRO2_822>0.</OEMDRO2_822>
    <OEMLED2_822>0</OEMLED2_822>
    <OEMDRO2_823>0.</OEMDRO2_823>
    <OEMLED2_823>0</OEMLED2_823>
    <OEMDRO2_824>0.</OEMDRO2_824>
    <OEMLED2_824>0</OEMLED2_824>
    <OEMDRO2_825>0.</OEMDRO2_825>
    <OEMLED2_825>0</OEMLED2_825>
    <OEMDRO2_826>0.</OEMDRO2_826>
    <OEMLED2_826>0</OEMLED2_826>
    <OEMDRO2_827>0.</OEMDRO2_827>
    <OEMLED2_827>0</OEMLED2_827>
    <OEMDRO2_828>0.</OEMDRO2_828>
    <OEMLED2_828>0</OEMLED2_828>
    <OEMDRO2_829>0.</OEMDRO2_829>
    <OEMLED2_829>0</OEMLED2_829>
    <OEMDRO2_830>0.</OEMDRO2_830>
    <OEMLED2_830>0</OEMLED2_830>
    <OEMDRO2_831>0.</OEMDRO2_831>
    <OEMLED2_831>0</OEMLED2_831>
    <OEMDRO2_832>0.</OEMDRO2_832>
    <OEMLED2_832>0</OEMLED2_832>
    <OEMDRO2_833>0.</OEMDRO2_833>
    <OEMLED2_833>0</OEMLED2_833>
    <OEMDRO2_834>0.</OEMDRO2_834>
    <OEMLED2_834>0</OEMLED2_834>
    <OEMDRO2_835>0.</OEMDRO2_835>
    <OEMLED2_835>0</OEMLED2_835>
    <OEMDRO2_836>0.</OEMDRO2_836>
    <OEMLED2_836>0</OEMLED2_836>
    <OEMDRO2_837>0.</OEMDRO2_837>
    <OEMLED2_837>0</OEMLED2_837>
    <OEMDRO2_838>0.</OEMDRO2_838>
    <OEMLED2_838>0</OEMLED2_838>
    <OEMDRO2_839>0.</OEMDRO2_839>
    <OEMLED2_839>0</OEMLED2_839>
    <OEMDRO2_840>0.</OEMDRO2_840>
    <OEMLED2_840>0</OEMLED2_840>
    <OEMDRO2_841>0.</OEMDRO2_841>
    <OEMLED2_841>0</OEMLED2_841>
    <OEMDRO2_842>0.</OEMDRO2_842>
    <OEMLED2_842>0</OEMLED2_842>
    <OEMDRO2_843>0.</OEMDRO2_843>
    <OEMLED2_843>0</OEMLED2_843>
    <OEMDRO2_844>0.</OEMDRO2_844>
    <OEMLED2_844>0</OEMLED2_844>
    <OEMDRO2_845>0.</OEMDRO2_845>
    <OEMLED2_845>0</OEMLED2_845>
    <OEMDRO2_846>0.</OEMDRO2_846>
    <OEMLED2_846>0</OEMLED2_846>
    <OEMDRO2_847>0.</OEMDRO2_847>
    <OEMLED2_847>0</OEMLED2_847>
    <OEMDRO2_848>0.</OEMDRO2_848>
    <OEMLED2_848>0</OEMLED2_848>
    <OEMDRO2_849>0.</OEMDRO2_849>
    <OEMLED2_849>0</OEMLED2_849>
    <OEMDRO2_850>0.</OEMDRO2_850>
    <OEMLED2_850>0</OEMLED2_850>
    <OEMDRO2_851>0.</OEMDRO2_851>
    <OEMLED2_851>0</OEMLED2_851>
    <OEMDRO2_852>0.</OEMDRO2_852>
    <OEMLED2_852>0</OEMLED2_852>
    <OEMDRO2_853>0.</OEMDRO2_853>
    <OEMLED2_853>0</OEMLED2_853>
    <OEMDRO2_854>0.</OEMDRO2_854>
    <OEMLED2_854>0</OEMLED2_854>
    <OEMDRO2_855>0.</OEMDRO2_855>
    <OEMLED2_855>0</OEMLED2_855>
    <OEMDRO2_856>0.</OEMDRO2_856>
    <OEMLED2_856>0</OEMLED2_856>
    <OEMDRO2_857>0.</OEMDRO2_857>
    <OEMLED2_857>0</OEMLED2_857>
    <OEMDRO2_858>0.</OEMDRO2_858>
    <OEMLED2_858>0</OEMLED2_858>
    <OEMDRO2_859>0.</OEMDRO2_859>
    <OEMLED2_859>0</OEMLED2_859>
    <OEMDRO2_860>0.</OEMDRO2_860>
    <OEMLED2_860>0</OEMLED2_860>
    <OEMDRO2_861>0.</OEMDRO2_861>
    <OEMLED2_861>0</OEMLED2_861>
    <OEMDRO2_862>0.</OEMDRO2_862>
    <OEMLED2_862>0</OEMLED2_862>
    <OEMDRO2_863>0.</OEMDRO2_863>
    <OEMLED2_863>0</OEMLED2_863>
    <OEMDRO2_864>0.</OEMDRO2_864>
    <OEMLED2_864>0</OEMLED2_864>
    <OEMDRO2_865>0.</OEMDRO2_865>
    <OEMLED2_865>0</OEMLED2_865>
    <OEMDRO2_866>0.</OEMDRO2_866>
    <OEMLED2_866>0</OEMLED2_866>
    <OEMDRO2_867>0.</OEMDRO2_867>
    <OEMLED2_867>0</OEMLED2_867>
    <OEMDRO2_868>0.</OEMDRO2_868>
    <OEMLED2_868>0</OEMLED2_868>
    <OEMDRO2_869>0.</OEMDRO2_869>
    <OEMLED2_869>0</OEMLED2_869>
    <OEMDRO2_870>0.</OEMDRO2_870>
    <OEMLED2_870>0</OEMLED2_870>
    <OEMDRO2_871>0.</OEMDRO2_871>
    <OEMLED2_871>0</OEMLED2_871>
    <OEMDRO2_872>0.</OEMDRO2_872>
    <OEMLED2_872>0</OEMLED2_872>
    <OEMDRO2_873>0.</OEMDRO2_873>
    <OEMLED2_873>0</OEMLED2_873>
    <OEMDRO2_874>0.</OEMDRO2_874>
    <OEMLED2_874>0</OEMLED2_874>
    <OEMDRO2_875>0.</OEMDRO2_875>
    <OEMLED2_875>0</OEMLED2_875>
    <OEMDRO2_876>0.</OEMDRO2_876>
    <OEMLED2_876>0</OEMLED2_876>
    <OEMDRO2_877>0.</OEMDRO2_877>
    <OEMLED2_877>0</OEMLED2_877>
    <OEMDRO2_878>0.</OEMDRO2_878>
    <OEMLED2_878>0</OEMLED2_878>
    <OEMDRO2_879>0.</OEMDRO2_879>
    <OEMLED2_879>0</OEMLED2_879>
    <OEMDRO2_880>0.</OEMDRO2_880>
    <OEMLED2_880>0</OEMLED2_880>
    <OEMDRO2_881>0.</OEMDRO2_881>
    <OEMLED2_881>0</OEMLED2_881>
    <OEMDRO2_882>0.</OEMDRO2_882>
    <OEMLED2_882>0</OEMLED2_882>
    <OEMDRO2_883>0.</OEMDRO2_883>
    <OEMLED2_883>0</OEMLED2_883>
    <OEMDRO2_884>0.</OEMDRO2_884>
    <OEMLED2_884>0</OEMLED2_884>
    <OEMDRO2_885>0.</OEMDRO2_885>
    <OEMLED2_885>0</OEMLED2_885>
    <OEMDRO2_886>0.</OEMDRO2_886>
    <OEMLED2_886>0</OEMLED2_886>
    <OEMDRO2_887>0.</OEMDRO2_887>
    <OEMLED2_887>0</OEMLED2_887>
    <OEMDRO2_888>0.</OEMDRO2_888>
    <OEMLED2_888>0</OEMLED2_888>
    <OEMDRO2_889>0.</OEMDRO2_889>
    <OEMLED2_889>0</OEMLED2_889>
    <OEMDRO2_890>0.</OEMDRO2_890>
    <OEMLED2_890>0</OEMLED2_890>
    <OEMDRO2_891>0.</OEMDRO2_891>
    <OEMLED2_891>0</OEMLED2_891>
    <OEMDRO2_892>0.</OEMDRO2_892>
    <OEMLED2_892>0</OEMLED2_892>
    <OEMDRO2_893>0.</OEMDRO2_893>
    <OEMLED2_893>0</OEMLED2_893>
    <OEMDRO2_894>0.</OEMDRO2_894>
    <OEMLED2_894>0</OEMLED2_894>
    <OEMDRO2_895>0.</OEMDRO2_895>
    <OEMLED2_895>0</OEMLED2_895>
    <OEMDRO2_896>0.</OEMDRO2_896>
    <OEMLED2_896>0</OEMLED2_896>
    <OEMDRO2_897>0.</OEMDRO2_897>
    <OEMLED2_897>0</OEMLED2_897>
    <OEMDRO2_898>0.</OEMDRO2_898>
    <OEMLED2_898>0</OEMLED2_898>
    <OEMDRO2_899>0.</OEMDRO2_899>
    <OEMLED2_899>0</OEMLED2_899>
    <OEMDRO2_900>0.</OEMDRO2_900>
    <OEMLED2_900>0</OEMLED2_900>
    <OEMDRO2_901>0.</OEMDRO2_901>
    <OEMLED2_901>0</OEMLED2_901>
    <OEMDRO2_902>0.</OEMDRO2_902>
    <OEMLED2_902>0</OEMLED2_902>
    <OEMDRO2_903>0.</OEMDRO2_903>
    <OEMLED2_903>0</OEMLED2_903>
    <OEMDRO2_904>0.</OEMDRO2_904>
    <OEMLED2_904>0</OEMLED2_904>
    <OEMDRO2_905>0.</OEMDRO2_905>
    <OEMLED2_905>0</OEMLED2_905>
    <OEMDRO2_906>0.</OEMDRO2_906>
    <OEMLED2_906>0</OEMLED2_906>
    <OEMDRO2_907>0.</OEMDRO2_907>
    <OEMLED2_907>0</OEMLED2_907>
    <OEMDRO2_908>0.</OEMDRO2_908>
    <OEMLED2_908>0</OEMLED2_908>
    <OEMDRO2_909>0.</OEMDRO2_909>
    <OEMLED2_909>0</OEMLED2_909>
    <OEMDRO2_910>0.</OEMDRO2_910>
    <OEMLED2_910>0</OEMLED2_910>
    <OEMDRO2_911>0.</OEMDRO2_911>
    <OEMLED2_911>0</OEMLED2_911>
    <OEMDRO2_912>0.</OEMDRO2_912>
    <OEMLED2_912>0</OEMLED2_912>
    <OEMDRO2_913>0.</OEMDRO2_913>
    <OEMLED2_913>0</OEMLED2_913>
    <OEMDRO2_914>0.</OEMDRO2_914>
    <OEMLED2_914>0</OEMLED2_914>
    <OEMDRO2_915>0.</OEMDRO2_915>
    <OEMLED2_915>0</OEMLED2_915>
    <OEMDRO2_916>0.</OEMDRO2_916>
    <OEMLED2_916>0</OEMLED2_916>
    <OEMDRO2_917>0.</OEMDRO2_917>
    <OEMLED2_917>0</OEMLED2_917>
    <OEMDRO2_918>0.</OEMDRO2_918>
    <OEMLED2_918>0</OEMLED2_918>
    <OEMDRO2_919>0.</OEMDRO2_919>
    <OEMLED2_919>0</OEMLED2_919>
    <OEMDRO2_920>0.</OEMDRO2_920>
    <OEMLED2_920>0</OEMLED2_920>
    <OEMDRO2_921>0.</OEMDRO2_921>
    <OEMLED2_921>0</OEMLED2_921>
    <OEMDRO2_922>0.</OEMDRO2_922>
    <OEMLED2_922>0</OEMLED2_922>
    <OEMDRO2_923>0.</OEMDRO2_923>
    <OEMLED2_923>0</OEMLED2_923>
    <OEMDRO2_924>0.</OEMDRO2_924>
    <OEMLED2_924>0</OEMLED2_924>
    <OEMDRO2_925>0.</OEMDRO2_925>
    <OEMLED2_925>0</OEMLED2_925>
    <OEMDRO2_926>0.</OEMDRO2_926>
    <OEMLED2_926>0</OEMLED2_926>
    <OEMDRO2_927>0.</OEMDRO2_927>
    <OEMLED2_927>0</OEMLED2_927>
    <OEMDRO2_928>0.</OEMDRO2_928>
    <OEMLED2_928>0</OEMLED2_928>
    <OEMDRO2_929>0.</OEMDRO2_929>
    <OEMLED2_929>0</OEMLED2_929>
    <OEMDRO2_930>0.</OEMDRO2_930>
    <OEMLED2_930>0</OEMLED2_930>
    <OEMDRO2_931>0.</OEMDRO2_931>
    <OEMLED2_931>0</OEMLED2_931>
    <OEMDRO2_932>0.</OEMDRO2_932>
    <OEMLED2_932>0</OEMLED2_932>
    <OEMDRO2_933>0.</OEMDRO2_933>
    <OEMLED2_933>0</OEMLED2_933>
    <OEMDRO2_934>0.</OEMDRO2_934>
    <OEMLED2_934>0</OEMLED2_934>
    <OEMDRO2_935>0.</OEMDRO2_935>
    <OEMLED2_935>0</OEMLED2_935>
    <OEMDRO2_936>0.</OEMDRO2_936>
    <OEMLED2_936>0</OEMLED2_936>
    <OEMDRO2_937>0.</OEMDRO2_937>
    <OEMLED2_937>0</OEMLED2_937>
    <OEMDRO2_938>0.</OEMDRO2_938>
    <OEMLED2_938>0</OEMLED2_938>
    <OEMDRO2_939>0.</OEMDRO2_939>
    <OEMLED2_939>0</OEMLED2_939>
    <OEMDRO2_940>0.</OEMDRO2_940>
    <OEMLED2_940>0</OEMLED2_940>
    <OEMDRO2_941>0.</OEMDRO2_941>
    <OEMLED2_941>0</OEMLED2_941>
    <OEMDRO2_942>0.</OEMDRO2_942>
    <OEMLED2_942>0</OEMLED2_942>
    <OEMDRO2_943>0.</OEMDRO2_943>
    <OEMLED2_943>0</OEMLED2_943>
    <OEMDRO2_944>0.</OEMDRO2_944>
    <OEMLED2_944>0</OEMLED2_944>
    <OEMDRO2_945>0.</OEMDRO2_945>
    <OEMLED2_945>0</OEMLED2_945>
    <OEMDRO2_946>0.</OEMDRO2_946>
    <OEMLED2_946>0</OEMLED2_946>
    <OEMDRO2_947>0.</OEMDRO2_947>
    <OEMLED2_947>0</OEMLED2_947>
    <OEMDRO2_948>0.</OEMDRO2_948>
    <OEMLED2_948>0</OEMLED2_948>
    <OEMDRO2_949>0.</OEMDRO2_949>
    <OEMLED2_949>0</OEMLED2_949>
    <OEMDRO2_950>0.</OEMDRO2_950>
    <OEMLED2_950>0</OEMLED2_950>
    <OEMDRO2_951>0.</OEMDRO2_951>
    <OEMLED2_951>0</OEMLED2_951>
    <OEMDRO2_952>0.</OEMDRO2_952>
    <OEMLED2_952>0</OEMLED2_952>
    <OEMDRO2_953>0.</OEMDRO2_953>
    <OEMLED2_953>0</OEMLED2_953>
    <OEMDRO2_954>0.</OEMDRO2_954>
    <OEMLED2_954>0</OEMLED2_954>
    <OEMDRO2_955>0.</OEMDRO2_955>
    <OEMLED2_955>0</OEMLED2_955>
    <OEMDRO2_956>0.</OEMDRO2_956>
    <OEMLED2_956>0</OEMLED2_956>
    <OEMDRO2_957>0.</OEMDRO2_957>
    <OEMLED2_957>0</OEMLED2_957>
    <OEMDRO2_958>0.</OEMDRO2_958>
    <OEMLED2_958>0</OEMLED2_958>
    <OEMDRO2_959>0.</OEMDRO2_959>
    <OEMLED2_959>0</OEMLED2_959>
    <OEMDRO2_960>0.</OEMDRO2_960>
    <OEMLED2_960>0</OEMLED2_960>
    <OEMDRO2_961>0.</OEMDRO2_961>
    <OEMLED2_961>0</OEMLED2_961>
    <OEMDRO2_962>0.</OEMDRO2_962>
    <OEMLED2_962>0</OEMLED2_962>
    <OEMDRO2_963>0.</OEMDRO2_963>
    <OEMLED2_963>0</OEMLED2_963>
    <OEMDRO2_964>0.</OEMDRO2_964>
    <OEMLED2_964>0</OEMLED2_964>
    <OEMDRO2_965>0.</OEMDRO2_965>
    <OEMLED2_965>0</OEMLED2_965>
    <OEMDRO2_966>0.</OEMDRO2_966>
    <OEMLED2_966>0</OEMLED2_966>
    <OEMDRO2_967>0.</OEMDRO2_967>
    <OEMLED2_967>0</OEMLED2_967>
    <OEMDRO2_968>0.</OEMDRO2_968>
    <OEMLED2_968>0</OEMLED2_968>
    <OEMDRO2_969>0.</OEMDRO2_969>
    <OEMLED2_969>0</OEMLED2_969>
    <OEMDRO2_970>0.</OEMDRO2_970>
    <OEMLED2_970>0</OEMLED2_970>
    <OEMDRO2_971>0.</OEMDRO2_971>
    <OEMLED2_971>0</OEMLED2_971>
    <OEMDRO2_972>0.</OEMDRO2_972>
    <OEMLED2_972>0</OEMLED2_972>
    <OEMDRO2_973>0.</OEMDRO2_973>
    <OEMLED2_973>0</OEMLED2_973>
    <OEMDRO2_974>0.</OEMDRO2_974>
    <OEMLED2_974>0</OEMLED2_974>
    <OEMDRO2_975>0.</OEMDRO2_975>
    <OEMLED2_975>0</OEMLED2_975>
    <OEMDRO2_976>0.</OEMDRO2_976>
    <OEMLED2_976>0</OEMLED2_976>
    <OEMDRO2_977>0.</OEMDRO2_977>
    <OEMLED2_977>0</OEMLED2_977>
    <OEMDRO2_978>0.</OEMDRO2_978>
    <OEMLED2_978>0</OEMLED2_978>
    <OEMDRO2_979>0.</OEMDRO2_979>
    <OEMLED2_979>0</OEMLED2_979>
    <OEMDRO2_980>0.</OEMDRO2_980>
    <OEMLED2_980>0</OEMLED2_980>
    <OEMDRO2_981>0.</OEMDRO2_981>
    <OEMLED2_981>0</OEMLED2_981>
    <OEMDRO2_982>0.</OEMDRO2_982>
    <OEMLED2_982>0</OEMLED2_982>
    <OEMDRO2_983>0.</OEMDRO2_983>
    <OEMLED2_983>0</OEMLED2_983>
    <OEMDRO2_984>0.</OEMDRO2_984>
    <OEMLED2_984>0</OEMLED2_984>
    <OEMDRO2_985>0.</OEMDRO2_985>
    <OEMLED2_985>0</OEMLED2_985>
    <OEMDRO2_986>0.</OEMDRO2_986>
    <OEMLED2_986>0</OEMLED2_986>
    <OEMDRO2_987>0.</OEMDRO2_987>
    <OEMLED2_987>0</OEMLED2_987>
    <OEMDRO2_988>0.</OEMDRO2_988>
    <OEMLED2_988>0</OEMLED2_988>
    <OEMDRO2_989>0.</OEMDRO2_989>
    <OEMLED2_989>0</OEMLED2_989>
    <OEMDRO2_990>0.</OEMDRO2_990>
    <OEMLED2_990>0</OEMLED2_990>
    <OEMDRO2_991>0.</OEMDRO2_991>
    <OEMLED2_991>0</OEMLED2_991>
    <OEMDRO2_992>0.</OEMDRO2_992>
    <OEMLED2_992>0</OEMLED2_992>
    <OEMDRO2_993>0.</OEMDRO2_993>
    <OEMLED2_993>0</OEMLED2_993>
    <OEMDRO2_994>0.</OEMDRO2_994>
    <OEMLED2_994>0</OEMLED2_994>
    <OEMDRO2_995>0.</OEMDRO2_995>
    <OEMLED2_995>0</OEMLED2_995>
    <OEMDRO2_996>0.</OEMDRO2_996>
    <OEMLED2_996>0</OEMLED2_996>
    <OEMDRO2_997>0.</OEMDRO2_997>
    <OEMLED2_997>0</OEMLED2_997>
    <OEMDRO2_998>0.</OEMDRO2_998>
    <OEMLED2_998>0</OEMLED2_998>
    <OEMDRO2_999>0.</OEMDRO2_999>
    <OEMLED2_999>0</OEMLED2_999>
    </Preferences>
    <Mach3Mill>
    <WPVB>500</WPVB>
    <WPVT>100</WPVT>
    <WPVL>50</WPVL>
    <WPVR>400</WPVR>
    </Mach3Mill>
    <Control>
    <Default>1</Default>
    <Device>Printer</Device>
    </Control>
    <VideoPlugIn>
    <DROcolor>1178909</DROcolor>
    <TOOLcolor>255</TOOLcolor>
    <CROSScolor>16777215</CROSScolor>
    <ShowTool>0</ShowTool>
    <ShowMousePos>0</ShowMousePos>
    <ShowAxisPos>0</ShowAxisPos>
    <FlipAxis>0</FlipAxis>
    <ToolDia>0.5</ToolDia>
    <ScaleFactor>2.e-003</ScaleFactor>
    </VideoPlugIn>
    <GCodeVar>
    <GVar500>0.</GVar500>
    <GVar501>0.</GVar501>
    <GVar502>0.</GVar502>
    <GVar503>0.</GVar503>
    <GVar504>0.</GVar504>
    <GVar505>0.</GVar505>
    <GVar506>0.</GVar506>
    <GVar507>0.</GVar507>
    <GVar508>0.</GVar508>
    <GVar509>0.</GVar509>
    <GVar510>0.</GVar510>
    <GVar511>0.</GVar511>
    <GVar512>0.</GVar512>
    <GVar513>0.</GVar513>
    <GVar514>0.</GVar514>
    <GVar515>0.</GVar515>
    <GVar516>0.</GVar516>
    <GVar517>0.</GVar517>
    <GVar518>0.</GVar518>
    <GVar519>0.</GVar519>
    <GVar520>0.</GVar520>
    <GVar521>0.</GVar521>
    <GVar522>0.</GVar522>
    <GVar523>0.</GVar523>
    <GVar524>0.</GVar524>
    <GVar525>0.</GVar525>
    <GVar526>0.</GVar526>
    <GVar527>0.</GVar527>
    <GVar528>0.</GVar528>
    <GVar529>0.</GVar529>
    <GVar530>0.</GVar530>
    <GVar531>0.</GVar531>
    <GVar532>0.</GVar532>
    <GVar533>0.</GVar533>
    <GVar534>0.</GVar534>
    <GVar535>0.</GVar535>
    <GVar536>0.</GVar536>
    <GVar537>0.</GVar537>
    <GVar538>0.</GVar538>
    <GVar539>0.</GVar539>
    <GVar540>0.</GVar540>
    <GVar541>0.</GVar541>
    <GVar542>0.</GVar542>
    <GVar543>0.</GVar543>
    <GVar544>0.</GVar544>
    <GVar545>0.</GVar545>
    <GVar546>0.</GVar546>
    <GVar547>0.</GVar547>
    <GVar548>0.</GVar548>
    <GVar549>0.</GVar549>
    <GVar550>0.</GVar550>
    <GVar551>0.</GVar551>
    <GVar552>0.</GVar552>
    <GVar553>0.</GVar553>
    <GVar554>0.</GVar554>
    <GVar555>0.</GVar555>
    <GVar556>0.</GVar556>
    <GVar557>0.</GVar557>
    <GVar558>0.</GVar558>
    <GVar559>0.</GVar559>
    <GVar560>0.</GVar560>
    <GVar561>0.</GVar561>
    <GVar562>0.</GVar562>
    <GVar563>0.</GVar563>
    <GVar564>0.</GVar564>
    <GVar565>0.</GVar565>
    <GVar566>0.</GVar566>
    <GVar567>0.</GVar567>
    <GVar568>0.</GVar568>
    <GVar569>0.</GVar569>
    <GVar570>0.</GVar570>
    <GVar571>0.</GVar571>
    <GVar572>0.</GVar572>
    <GVar573>0.</GVar573>
    <GVar574>0.</GVar574>
    <GVar575>0.</GVar575>
    <GVar576>0.</GVar576>
    <GVar577>0.</GVar577>
    <GVar578>0.</GVar578>
    <GVar579>0.</GVar579>
    <GVar580>0.</GVar580>
    <GVar581>0.</GVar581>
    <GVar582>0.</GVar582>
    <GVar583>0.</GVar583>
    <GVar584>0.</GVar584>
    <GVar585>0.</GVar585>
    <GVar586>0.</GVar586>
    <GVar587>0.</GVar587>
    <GVar588>0.</GVar588>
    <GVar589>0.</GVar589>
    <GVar590>0.</GVar590>
    <GVar591>0.</GVar591>
    <GVar592>0.</GVar592>
    <GVar593>0.</GVar593>
    <GVar594>0.</GVar594>
    <GVar595>0.</GVar595>
    <GVar596>0.</GVar596>
    <GVar597>0.</GVar597>
    <GVar598>0.</GVar598>
    <GVar599>0.</GVar599>
    <GVar600>0.</GVar600>
    </GCodeVar>
    </profile>
    Junior Member
    Jun 2010
    3838
    Re: old machine new computer...
    You won't win too many friends by including the entire XML in your posting. 99.9% of it is irrelevant. Attach it as a file instead.
    Anyhow, FIRST use Device Manager to see whether Windows can see the PCI card and the LPT port. It sounds to me as though it can't.
    Actually, an LPT port is not a good choice these days anyhow. Switch to an Ethernet Smooth Stepper and life will be much easier.
    Cheers
    Roger
    Sep 2019
    4
    I’ll fix that tomorrow my phone keeps erring when I try to edit or delete.
  1. Need computer to machine help
    By Larry Myers in forum Sharp CNC
    Last Post: 09-11-2019, 09:04 AM
  2. Computer Won't Communicate With Machine
    By 300sniper in forum Tormach Personal CNC Mill
    Last Post: 12-12-2017, 09:55 PM
  3. Will a new computer run a CNC machine
    By MajorTendonitis in forum Controller & Computer Solutions
    Last Post: 04-09-2017, 03:50 AM
  4. can you use more than one usb-ss on the same machine with one computer
    By skyguynca in forum SmoothStepper USB Motion Control
    Last Post: 12-14-2014, 02:34 AM
  5. Computer to machine help needed
    By Larry Myers in forum Controller & Computer Solutions
    Last Post: 08-21-2008, 05:37 PM
