1. Equipped with aluminum brackets for stability and automatic focusing with integrated red light for precise adjustments.
2. Enhanced air assist delivers a 3.2x efficiency boost with a 125 L/min flow rate and enlarged 8mm tubing for deeper cuts and cleaner edges.
3. The exhaust fan has an airflow rate of 540m3/hr, and its built-in air assist interface can be removed for optional external connection.
4. The front and back pass-through doors allow for working on large pieces. (When using front and back feeding, the laser class upgrades to 4, ensuring versatility and safety.)
5. Harnessing built-in pressure sensors, our system ensures safe laser engraving. If the pressure drops, an alarm will trigger, reducing risk in your workplace.
6. The upgraded honeycomb bed features stainless-steel edging for enhanced stability, complemented by an additional pin.
7. X-Axis: V-wheel design for smooth, high-speed movement; Y-Axis: High-precision belt for ultimate accuracy; Z-Axis: Ball screw for stable, quiet elevation
Bring your custom designs to life with a powerful and reliable laser engraver!
Learn more about the OMTech 100W CO2 Laser Engraving Machine here:
https://omtechlaser.au/products/100w...area-pronto-45
