585,977 active members*
3,904 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Only movement in one direction on all 3 axes
Results 1 to 1 of 1
    Aug 2020
    5
    Need Help!
    Just installed new driver to Y axis . Now I have movement in all three axes where I did not before .However when first jogged machine moves in y axis but only one direction(was not moving previous new driver) X was moving two directions Z didn't try. I did a few checks on connections all seemed to be good connection, and now I have only movement in one direction in all three axes. Anyone out there that can make anymore sense of that then me? It has mach3 and my control box is a 3040z Chinese box. I will attach a photo of original driver to the newly installed one.
    Attached Thumbnails Attached Thumbnails FB_IMG_1606001475375.jpg   FB_IMG_1606001486572.jpg
  1. G28 moves Axes in wrong direction.
    By bemor187 in forum Mach Plasma / Laser
    Last Post: 10-11-2018, 01:08 AM
  2. g540 fault, no movement on z axis, other axes work fine
    By gingerbeardman in forum Gecko Drives
    Last Post: 05-21-2016, 01:22 PM
  3. Axes move wrong direction when homing. EZ TRAK DX II
    By Vernier Caliper in forum Bridgeport / Hardinge Mills
    Last Post: 01-15-2016, 03:29 AM
  4. Unwanted axes movement.
    By corrie in forum Controller & Computer Solutions
    Last Post: 03-16-2009, 02:57 AM
  5. Axes run rough in one direction
    By tmead in forum Machines running Mach Software
    Last Post: 09-21-2008, 08:29 PM
