585,748 active members*
3,677 visitors online*
IndustryArena Forum > WoodWorking Machines > Uncategorised WoodWorking Machines > Ooznest Workbee Z-axis wobble in carriage?
Results 1 to 4 of 4
    Mar 2017
    10
    Question Ooznest Workbee Z-axis wobble in carriage?
    I'm getting about 5 degrees of wobble perpendicular to the X axis in the carriage, is this normal? Everything is tight as far as I can tell, but also according to the instructions you assemble the carriage without the ability of the stop switch to engage by hitting the frame at max extrusion... I'll upload a video as soon as it finishes processing on my computer.
    Nov 2014
    724
    Re: Ooznest Workbee Z-axis wobble in carriage?
    Have you contacted Workbee about this?
    David
    David
    Romans 3:23
    Etsy shop opened 12/1/17 - CurlyWoodShop
    Mar 2017
    10
    I haven't yet no, I wanted to see if this is a normal thing for the CNC machine or not.
    Dec 2003
    1218
    Quote Originally Posted by Jayson_2016 View Post
    It shouldn't be normal.Is a fastening loose or are you expecting the machine to work beyond it's capabilities?
  1. Looking for Mounting Brackets for Dewalt 618 on an Ooznest CNC Workbee.
    By Jayson_2016 in forum RFQ (Request for Quote)
    Last Post: 05-07-2020, 09:12 PM
  2. Issue with A-axis on Chinese Workbee Stb5100
    By Workbee1x1 in forum Machines running Mach Software
    Last Post: 05-22-2019, 04:46 AM
  3. Acme lead screw Y-axis wobble - what to do?
    By spandadk in forum DIY CNC Router Table Machines
    Last Post: 08-24-2018, 12:54 PM
  4. Z Axis Wobble in Acme Thread - Help Please
    By dameronw in forum Linear and Rotary Motion
    Last Post: 10-01-2015, 05:55 AM
  5. wobble when i move the y axis...how to diagnose/fix
    By airbrush in forum DIY CNC Router Table Machines
    Last Post: 04-07-2015, 04:41 PM
