547,312 active members*
3,126 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Optional Parameter OSP-P200L
Results 1 to 1 of 1
    Aug 2021
    Hello,
    I am looking for the system variable to read and write the "optional parameter" long word #33 on an OSP-P200L.
    Jun 2015
    3377
    Re: Optional Parameter OSP-P200L
    hy changing parameters from code is only possible on mills, for bits, by using voprb
    if you wish to adjust peckings, simply create a soubroutine / kindly
