I like your new OptoIsolated Input and Limit Module. That's realy a big improvement. To bad, that I already use an alternative solution , but with the next Project, I definitively will use that modules.
The ExtInOut Module is also a great improvement. Especially the 24V Versions are perfect for industrial environment.
I only miss an OptoIsolated Output Module, which should support the PWM and frequency Output. And work as NPN or PNP. I think that Relais may not the best solution for my environment because of the high switching count on Output 1-8
Do you have any plans for such an module in near future?
I currently use the 4-port Module DST-1R4P-N which is OK. But a Planet CNC Solution would be great.
