548,600 active members*
2,119 visitors online*
Thread: Output Panel
    Nov 2015
    253
    Output Panel
    Every time a limit, input or estop etc. is activated. Is that printed with a counter in the output window.
    Unfortunately, this is not really good for troubleshooting. It would make sense if it would say which input / limit pin etc. was activated.
    Re: Output Panel
    Yes indeed. Finding which input trigger an estop can be quiet painfull and in most cases results in disconnecting everything to find the offending input. Would be great to habe a output that tells which action triggered the error
    Something like:
    Estop triggered by axis error pin
    Or
    Estop triggered by input 1
    Or
    Estop triggered by mpg Button
  1. POST PROBLEM
    By jeff1124 in forum Dynapath
    Last Post: 11-21-2014, 05:51 PM
  2. Post Problem/Post needed
    By Dan88 in forum EdgeCam
    Last Post: 03-25-2013, 01:22 PM
  3. Post problem
    By Etced in forum Rhinocam
    Last Post: 01-17-2011, 08:06 PM
  4. post problem
    By CNC_FAN in forum Screen Layouts, Post Processors & Misc
    Last Post: 08-04-2010, 01:35 PM
  5. post problem
    By foamovercast in forum General MetalWork Discussion
    Last Post: 10-18-2005, 04:27 AM
