593,588 active members*
5,051 visitors online*
IndustryArena Forum > CAM Software > Rhinocam > Parallel Finishing Issues, Open Curves and or Gaps...
    Hello Everyone. I'm having issues with parallel finishing.
    I keep getting an error "Open curves and/or gaps between curves found. All curves must be closed or end-point matched!"
    I don't understand it. From what I can tell my geometry is good but I'm still a bit new to Rhino and RhinoCam. I'm certain I'm overlooking something. Please see linked video.
    https://youtu.be/S8R_F4C_T2I
    Thanks!!!
    Re: Parallel Finishing Issues, Open Curves and or Gaps...
    Uploading the Rhino File if it helps anyone.
    Thanks!
    Attached Files Attached Files
    Nov 2011
    332
    Hi, friend. Select a curve point on the curve and choose Curves > Move Seam. The seam will move to the edit point closest to the selected point.
    E-mail: [email protected] Web: www.elephant-cnc.com
    --------------Jinan Blue Elephant CNC Machinery Co., Ltd-------------
  1. Bad finishing issues
    By cange in forum Turning
    Last Post: 11-11-2019, 03:26 AM
  2. 4axis rhinocam parallel finishing act weird
    By alextech in forum Rhinocam
    Last Post: 06-05-2017, 01:43 PM
  3. HELP! parallel finishing Problem HELP!
    By Macguitar in forum Rhinocam
    Last Post: 03-25-2017, 05:19 PM
  4. Parallel Finishing Problem
    By kyle_vk in forum Rhinocam
    Last Post: 04-13-2015, 10:41 AM
  5. Surface finishing issues
    By fadalmatt in forum Mastercam
    Last Post: 02-24-2015, 01:38 AM
