594,891 active members*
5,559 visitors online*
    Oct 2022
    39
    Parameter 1008
    Hi
    In one of my machine tools, I have used the parameter 1008-bit 1 to rotate the table in one direction due to the table error and failure to correct the mechanical problem of the table. But sometimes, in some cases, the table turns again in two directions. And I have to reset the parameters and turn the machine off and on. What is the problem?
    Jan 2013
    474
    Quote Originally Posted by Electrify View Post
    Hi
    CNC axis generally move shortest path, so not a surprise. Possibly it's picking up an incremental move in a program G90 G91. Also, axis motors with absolute encoders are limited to the number of turns they can make in one direction due to "count" buffer, by setting the parameter bit off then on, maybe you are resetting this to zero.
    Nov 2024
    Re: Parameter 1008
    Mechanical play or backlash in the table drive Sprunki mechanism can cause position errors, leading the system to attempt corrections in both directions.
