fanuc o_m parameter )
For what machine??
Could be for any MTB?
Al.
Albert E.
this is only o_m controler>>>>>>
yes. but for WHICH machine?
what is the make and model of the machine that these parameters came from?
VMV 500B
MODEL SEP 90
CNC UNIT MODLE IS FANUC OMF
MACHINE NAME IS KRYLE>>>>>>>
Hello,
machine is kryle 500b, GE Fanuc OMF
problem with ATC, only thing that machine does is move to home and orient spindle, alarm says failed to index is one, other alarm is failed to move foward/retract.
macro seems to be done right, parameter 240 bit 0 is set to 6, programs are O9001 and O9003, if someone can reply with a list of thing to put in a post I can give better decription. Is there a tool home and how is it done?
Can you send me o_m parameters
