I'm going through and cleaning up the machine. Also wanting to remove and replace the X & Y axis belts and pulleys. The old belts I cut off. The X axis motor is mounted on slots with four Allen head screws. Easy enough. The y-axis though, does not seem to want to be adjusted in the same manner. How do I adjust the y-axis motor to install the new belt?
Also, the pulleys seem to be mounted the same way. But I don't see how they come off, any help here?
