Re: PARTNER 3, C4 spindle starts, table won't move until motor stops!tops
Ok, I got it working. I had a 3AM AH HA! moment. Setup Parameter 90 was calling for an Up-To-Speed check. I have no idea why that shook me from my sleep, but there we are.
My Param . 90 was set to 100420. Changing to 100400 and it runs like it should. Or at least it runs the table with its called for.
Parameter 90
Byte 0 00000#
1 = check 0 speed
2 = output creep speed
4 = check low range
Byte 1 0000#0
1 = check high range
2 = check spindle up-to-speed
4 = specify bipolar spindle D/A (-5 to +5 volt range)
As far as coolant, I literally built in a webcam into the control cabinet so I can watch relays/etc. while at the front of the machine. The relays on the main relay board (PC-REL-1B) for coolant, CR8 for Flood and CR7 for Spray, are coming on both with the front panel selector switch and when calling for it in MDI/programs. This was not working before with the broken EN. wire in the front panel. So this is progress. Both pumps have been pulled during the testing so I will have to do further testing.
I still wonder if they are locked out somewhere else waiting for the up-to-speed signal. Something with the MC1/MC2 contactors in the "Aux Box" section.
Cheers!
Evan.
"You're making WHAT?"
