544,101 active members*
2,048 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > PathPilot installed on Pulsar + Mesa 5i25 - Everything works EXCEPT servo spindle!
    Question PathPilot installed on Pulsar + Mesa 5i25 - Everything works EXCEPT servo spindle!
    Hey guys,
    Huge fan, and long time lurker. I have read through nearly all @BrianBoneDoc and @PCW_MESA posts before attempting this, and that is why I have been able to get this far problem free. Much appreciated guys.
    However, in PathPilot The Rev and Fwd buttons do nothing for the spindle, nor the RPMS.
    The EP1C Servo Controller in the back of the Novakon says ERR 13, which their documentation in the manual is hardly helpful as it lists 6 different vague issues it could be.
    Has anyone still around put PP on their Pulsar and been successful, or use a EP1C servo with a MESA card?
    Thanks!
    Aug 2016
    56
    Re: PathPilot installed on Pulsar + Mesa 5i25 - Everything works EXCEPT servo spindle
    Not sure this is super helpful or not, but I used Brian's guide when I converted my torus pro over to path pilot. My spindle directions were reversed, and to this day I can not manually command the rpm setting directly in the gui. I was able to work around this by simply entering Sxxxx for the RPM in the MDI screen, and from there I could then trigger fwd and reverse. I don't recall what I did to reverse the directions, I am sure it was in the hal somewhere. Best of luck.
  1. Replies: 5
    Last Post: 04-29-2017, 10:09 PM
  2. Any one running LinuxCNC with the Mesa 5i25 on their Patriot
    By bill.anderson in forum Shopmaster/Shoptask
    Last Post: 03-24-2016, 12:07 AM
  3. MESA 5i25-7i76 Spindle Issue
    By johnjsb in forum LinuxCNC (formerly EMC2)
    Last Post: 07-18-2012, 11:14 PM
  4. Mesa 5i25
    By Holzwurm56 in forum LinuxCNC (formerly EMC2)
    Last Post: 06-26-2012, 02:01 PM
  5. Mesa 5I25+7i76 5V I/O
    By dicker in forum LinuxCNC (formerly EMC2)
    Last Post: 06-08-2012, 10:19 PM
