601,649 active members*
2,211 visitors online*
    Dec 2008
    51
    PC keyboard issue
    Hello,
    I've a strange trouble when I want use the PC physical keyboard to input value in axis position dro, only on Linux release 2025-04-12.
    The insert bar flashes, but nothing happens when I type any digit on PC keyboard. Only in this window I can use only the virtual keyboard. On the other windows like MDI, Edit, etc. the PC keyboard works as expected.
    I've tried with the same release on Windows 10 and the PC keyboard works at all, including Dro input value.
    Could be a bug or setting isue?
    Mar 2017
    1390
    Re: PC keyboard issue
    This is OS issue.
    You can disable Wayland and switch to X11. Usually it helps.
    Dec 2008
    51
    I switched from Wayland to X1. Now the physical keyboard input works also on the Dro. Thanks.
    But with X1, sometimes, I get a freeze with the file>open command
  1. Replies: 2
    Last Post: 08-21-2020, 11:59 PM
  2. Seems Z and A axis are not running...Motor issue or Step/Dir issue?
    By Cattle in forum Mach Software (ArtSoft software)
    Last Post: 04-12-2016, 08:51 PM
  3. Replies: 1
    Last Post: 01-08-2016, 06:58 AM
  4. Replies: 2
    Last Post: 11-20-2013, 03:24 AM
  5. Hurco SSM Keyboard issue
    By jman6716 in forum HURCO
    Last Post: 03-19-2013, 08:29 PM
