528,152 active members*
3,380 visitors online*
IndustryArena Forum > GENERAL MANUFACTURING PROCESSES > DRILLING > Peck drilling on Okuma lb3000 osp200
Results 1 to 1 of 1
    Aug 2020
    Have been able to peck drill but can't get drill to retract to face of part.I used G74 z-2.5d.25k.25r.of.oo8
    Can anyone help with this.
    Check the parm
    Set at 500
    Jun 2015
    3195
    Re: Peck drilling on Okuma lb3000 osp200
    hy if better control is needed, i like to write the code :
    Code:
        G00 X0 Z2.5
        G01    Z-50      F0.10 G95
               Z-50+0.15
               Z-55
               Z-55+0.15
        G00    Z50                  ( or, if you wish, feed out slower, at smaller clearance G01 Z2.5 F2000 G94 )
        G04    F....                ( maybe dwell a bit ? )
               Z-55+1               ( back in )
        G01    Z-60      F0.085 G95 ( use slower feed for the last 5mm )
               Z-60+0.15
        G00    Z2.5
    for deep holes, or when drill flute's are relatively too short, you may use the load diagram, in order to fine-tune your code
    if you wish, i may share drilling codes for osp
    by the way, there is a nice okuma forum here : https://www.cnczone.com/forums/okuma/
    kindly
