547,087 active members*
2,203 visitors online*
IndustryArena Forum > CAD Software > Autodesk > Personal license 2020 changes to file export
Results 1 to 7 of 7
    May 2005
    1662
    Ransomware is a form of malware that encrypts a victim's files. The attacker then demands a ransom from the victim to restore access to the data upon payment.
    Okay I'll admit ransomware is a bit over the top. I signed up with Autodesk fully knowing, or at least suspecting, that this was coming.
    At the end of September non-paying Fusion users will only be able to export to mesh formats or save sketches as dxf..
    I will be exporting my existing files as STEP to use in other software while it's still 'convenient'.
    You may want to consider doing the same.
    Anyone who says "It only goes together one way" has no imagination.
    May 2005
    1662
    Re: Personal license 2020 changes to file export
    From member TurboStep in another thread
    Apparently it will stïll be possible to export in step format using some form of web interface until January 2021:
    You can still export your designs as STEP file formats via Fusion Team. This workflow will remain valid until Jan 19, 2021.
    May 2005
    1662
    That didn't take long
    https://github.com/Jnesselr/fusion-360-total-exporter
    No warrenty is implied, etc. etc. Go blame Autodesk for changing the free tier. If you want to blame me for anything, blame me and my sense of ethics for feeling like I need to write this program in the first place.
    May 2005
    1662
    Forget to clarify I haven't tested that add-on, I just found it amusing how quickly it happened.
    May 2005
    1662
    Step is back.
    1000's whining in unison was too much for Autodesk to ignore ?
    Nov 2012
    193
    Don't hold your breath.... AutoDesk is likely to pull the rug out from underneath you again. It is only a matter of time.
    Aug 2009
    1115
    ...I agree with ya Mr Metric....The Twilight Zone of machine codes. Skynet101
  1. Activity - 100% Win 1-Year ZW3D 2020 Premium License
    By Victoria_Li in forum ZW3D CAM
    Last Post: 03-18-2021, 09:03 PM
  2. Expoting a DXF file from 2020 Fusion to import and use in Biesseworks
    By Rooster82 in forum Uncategorised CAM Discussion
    Last Post: 11-12-2013, 05:52 PM
  3. File export
    By Polytyper in forum Autodesk
    Last Post: 10-10-2008, 12:20 AM
  4. Why does My dxf file export like this
    By sqatch in forum Dolphin CAD/CAM
    Last Post: 03-17-2008, 10:28 AM
