547,633 active members*
3,590 visitors online*
IndustryArena Forum > CAM Software > Surfcam > Planar mill depth cuts
    Aug 2012
    69
    How do you get the planar toolpath to use depth cuts? I want to step down .1"
    TIA
    FMJ
    May 2014
    11
    Re: Planar mill depth cuts
    Quote Originally Posted by FMJ View Post
    TIA
    FMJ
    You don't unless you have Multi-Cut (an optional module that's included with 4 axis & higher). It has the option of doing multiple depths in a single operation. With the normal 3 axis planar there's not an option for multiple depths - a workaround would be to copy the operation and adjust the stock to leave. For example, your first planar cut would leave 0.2, the second would leave 0.1 and the third would leave 0.0, etc
  1. Replies: 7
    Last Post: 05-23-2017, 09:13 AM
  2. Advanced Planar Vs Parallel Cuts
    By aldepoalo in forum BobCad-Cam
    Last Post: 02-23-2016, 03:33 PM
  3. Diffrent cuts depth
    By takamin in forum PhotoVCarve and VCarve Pro
    Last Post: 05-09-2015, 11:22 PM
  4. Depth of Cuts
    By Mattyvdv in forum General MetalWork Discussion
    Last Post: 08-01-2014, 03:00 PM
  5. Typical Depth of Cuts for steel
    By Palinvan in forum Taig Mills / Lathes
    Last Post: 08-04-2012, 01:11 AM
