601,649 active members*
2,201 visitors online*
    May 2025
    PlanetCNC interface
    Just broke a bit by accidentally pressing the "go to zero" button with my mouse instead of go to x,y.
    Yes, I know- my fault. But to avoid it from happening again, can I remove or disable the "go to zero" button?
    Nov 2015
    261
    Re: PlanetCNC interface
    It happened to me once, too.
    I've also modified some scripts. For example, with G28/G30, I preceded G53 Z0, so that Z moves to 0 before XY is moved.
    Okay, as far as I know, individual standard buttons can't be hidden.
    Only all of them. I did that, and then created all the buttons I needed myself. It's a bit of work, but it's worth it.
  1. Replies: 0
    Last Post: 03-30-2023, 11:43 AM
  2. Replies: 0
    Last Post: 03-27-2023, 11:47 AM
  3. PlanetCNC Licence
    By Davidmo82 in forum PlanetCNC
    Last Post: 09-20-2021, 04:31 PM
  4. Planetcnc controller
    By go47f in forum PlanetCNC
    Last Post: 10-06-2017, 05:14 PM
  5. Interface board Rodgers board/ Romaxx Encoder Interface.
    By Ark1 in forum Wood Lathes / Mills
    Last Post: 03-23-2013, 10:57 PM
