525,612 active members*
2,498 visitors online*
Results 1 to 6 of 6
    Sep 2006
    7
    plasma touch off for cnc4640 controller
    Hi have built a 8x4 router/plasma table, most things going well but would like to add touch off height setting, sounds like the controller won't do the gcode G28.1 G90
    has anyone got one going on plasma, every thing else is working well,
    thanks
    Oct 2010
    317
    Re: plasma touch off for cnc4640 controller
    Do you have any of the required hardware for the touchoff? You'll need something like an ohmic sensor or floating torch to do it.
    Sep 2006
    7
    yes got all sensors etc , its the gcode the cnc4640 doesn't know?
    runs standard gcode and i can cut parts and route parts fine, just wanted to add initial torch hight, at start of cut
    looking at using a XPTHC-4 torch hight controller , but doesn't really connect that well to the 4640
    Oct 2010
    317
    Have you tried using G31 for probing? It would probably be something like "G31 Z-10." which would send the Z in the negative direction for 10 units and it will stop whenever the probe input is activated. After that you'll need a "G92 Z0." if using something like an ohmic sensor or "G92 Z-.5" if you were using a floating torch that traveled .5 before activating the probe.
    Sep 2006
    7
    Attachment 410884got round the problem by purchasing a THC unit works great but modify the Z axis for plasma as I thought someone was going to purchase the machine,
    so building an other table slightly bigger, with plasma / router in mind again, just made modify a china spindle for ATC works great, Attachment 410880Attachment 410882
    Oct 2016
    John are you still around? getting ready to hook up our acorn / plasma and may have a few questions for you.
  1. seting up ADTECH CNC4640 ATC
    By glrjola in forum Auto Tool Changer
    Last Post: 12-28-2017, 11:22 PM
  2. Relay for Plasma Touch Off
    By ny_racer_xxx in forum General CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 08-13-2016, 06:48 PM
  3. ADTECH CNC4640
    By CJF in forum Fanuc
    Last Post: 05-15-2015, 03:04 PM
  4. ADT-CNC4640 4 Axis Milling CNC Controller
    By adtechcn in forum News Announcements
    Last Post: 01-07-2013, 09:30 AM
  5. CNC with touch cut plasma system
    By freedom2000 in forum General Waterjet
    Last Post: 09-01-2009, 02:16 PM
