I am trying to make a small vacuum plenum for my CNC that is it is about 18" by 30". I made one out of 3/4" Polypropylene and it has a horrible warp in it. What type of plastic would remain flat when grooves are machined in one side and not the other. I have very little experience machining plastic, outside of cast acrylic and even then it is almost exclusively 6mm. Also, I need to mention that it needs to be completely air tight. I am using a small vacuum pump that pulls down to almost 28" but has very low cfm. I am limping along with PP plenum that I have, but it is not ideal and am ready to upgrade.
