504,064 active members
3,083 visitors online
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > please, how to check alignment for small tool ...
Page 1 of 2 12
Results 1 to 12 of 21
    Jun 2015
    2792
    hello i have a small id turning knife ( image 00 ), that is mounted like in image 01
    each time i change that tool, i have to take out the sleeve from the machine, because there is not enough room inside the cabinet, so the keys won't fit ...
    when i put it back, is a gamble, and there is a big chance to have the tool misaligned, in X and/or Y
    i also can't check it's alignment, and, as a result, a new tool may break after machining 1 or 2 parts, especialy because the tool is small, so is very sensitive if not aligned properly
    problem is that there is too much overhang, and i can't achieve repetability when changing that tool, and also i can't check it's alignment ... pls, how to deal with this situation? i mean, is there a 'normal' approach ? kindly
    Feb 2011
    248
    Re: please, how to check alignment for small tool ...
    there are a couple of things that i can think of
    if the overhang is too much us a G50Wxxxx shift in the program to move the tool closer to the drill arm as long as the material is large enough to handle the overhang this might help with tool removal and replacement with out removing the tool holder
    check your set screws holding the tool some time they have a ball on the end of the screws change them to a flat nose screw or one that has been ground with a flat this will help keep the tool rotated more correct
    the piccco cut and the correct holder should put the tool on center as long as the screws are good so you shouldn't have to worry to much about being on center
    Jun 2015
    2792
    hi, i am afraid that this does not happen ... there is a play between the " id holder of the machine" and "sleeve that holds the tool" + other plays
    this play is not extraordinary big, but it still allows to put&remove the sleeve by hand, without too much effort, and so, the screws will tend to tilt a bit this sleeve, so missaligining will increase on tools with long overhang ... things simply sum up
    i just saw that there are even smaller piccos ( attached )
    hmm, maybe there is a method for aligning such tiny stuff / kindly
    Flies Fast
    Dec 2008
    2794
    Iscar have a holder designed to hold & orientate that boring bar for easier replacement...
    suggest you look at replicating their system
    ie. pointed grub screw in groove to orientate & flat grub screws to clamp
    Jun 2015
    2792
    hello superman, please, do you have a link to it ? or is it here : ISCAR Cutting Tools - Metal Working Tools - PICCO R/L 050, 053, 055 : 6402330 - ?
    kindly
    ps : why i can't edit my " member " label, and how come you still have the " flies fast " ? aaa, not fair
    Flies Fast
    Dec 2008
    2794
    Quote Originally Posted by deadlykitten View Post
    kindly
    yes
    you are not looking hard enough... happy hunting... LOL
    Apr 2017
    7
    Swap the Picco tool with the drill in the bottom station and install the Picco tool and holder inverted (upside down). Boom, access to set screws. You will have to swap X+ for X- in your program, G2/G3 swap, as well as your comp direction and quadrant.
    Jun 2015
    2792
    hei superman, i am not sure, but i believe that some users with older accounts have some 'edit' possibilites, that are no longer available
    if i go :
    ... my profile (up) \ about me (tab) \ edit your about me (right label), then nothing happens
    ... setting (up) \ edit profile ( left bottom ), then attached interface appears, and i'm stuck
    is it enough hunting ?:drowning:
    hi thunder, yup, this will allow acces to the screws, but i am still not sure if i will be on center ...
    of course, is better to avoid removing the sleeve from the lathe, and putting it back after, but even so, without removing the sleeve, the alignment has to be checked ; tools have broked inside the 1st or 2nd part ... and they are so tiny ... kindly
    Apr 2017
    7
    Install tool in holder, put holder in tool station, face off stock with turn tool, call up tool, touch tool off to face of stock, tighten holder set screws, jog Z1 forward .001", jog X1 X+ until tool is off of stock, cut off about .100-.200 of bar stock and catch that little coin, check the scored line on a tool scope to see how far over/under center you are, make adjustment to tool station core value to put the tool on center.
    Jun 2015
    2792
    hmm, sounds interesting, thank you very much
    i wonder, is it a good idea to scracth the surface with such a little tool ? i don't know
    most of the times, i am used to align without cutting, thus to be sure that when the tool will be mounted, it will be where it should be ... i am thinking about a method that does not involve the tool / kindly
    Apr 2017
    7
    I do it all the time with tools that size. If you are worried the tool will chip, then use brass stock as it is more forgiving. I am very much in favor of putting your TOOL on center, not just your tool holder or tool station.
    Jun 2015
    2792
    hy thunder thank you for your ideas so far; they are great
    i have been thinking about this, like using a softer material, but this may require downtime with the feeder and with the lathe; so, maybe i should craft a sharp-point thing, like the one attached ( image 01 ), with dimensions pretty similar with the tool, and i could use it to scracth the material, so to find the center... after that i would remove it, and put the tool instead, and i would adjust the offset :
    ... for a drill, only Z
    ... for a mini id boring tool, i could measure the dimension WF from image 02, and compensate the X offset ( or Y, depending on orientation )
    so true; tool station, tool holder and tool shank, each one is h7 or H7; also there is the play between them, excentricity caused by overhang, and the fact that their position is not the same, depending on how the screws are tightened ... all these little things sum up
    what else should i tell you ? hmm, i don't know thank you again
Page 1 of 2 12
  1. how to check axis alignment on NL4300
    By mattk1987pick in forum Mori Seiki lathes
    Last Post: 08-22-2016, 06:51 PM
  2. Replies: 1
    Last Post: 03-04-2014, 01:08 AM
  3. VF2 Tool Alignment - HELP!
    By Dennis Fletcher in forum Haas Mills
    Last Post: 03-15-2010, 07:10 AM
  4. Quick check of 5 axis alignment
    By Sissie in forum Want To Buy...Need help!
    Last Post: 10-13-2009, 01:54 PM
  5. tool carousel alignment
    By rubino2112 in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 12-27-2006, 07:26 PM
