547,544 active members*
776 visitors online*
    Dec 2011
    15
    PMC programmer needed for 21i-t
    I have a lathe with a 21i-t.
    I need several things added/changed in the pmc program.
    I am more than happy to pay something reasonable for someone to make some changes.
    I can send you the program.
    Here’s what I need;
    Be able to pause program, jog axis, then restart program where it was paused at.
    F1 key to switch spindle between run and jog. (Spindle start button just jogs it now)
    F2 run spindle at 100 rpm
    F3 select external jog wheel
    Setup info/programming for external mpg with axis selector and step selection. This is for a hand held mpg.
    Aug 2019
    36
    Re: PMC programmer needed for 21i-t
    A note on the remote: Not sure the size of your facility but I suggest ensuring the remote MPG unit you purchase has an E-stop button as well as a 3 position enable button.
    A pain I know but required for those that try.
    Dec 2011
    15
    Quote Originally Posted by oetkbyentc View Post
    Thanks for info. I’m just a one man show.
  1. Mori Seiki SL200 Fanuc 21i-TA--------NC and PMC paramaters
    By zavateandu in forum Mori Seiki lathes
    Last Post: 05-04-2020, 11:15 AM
  2. Parameters and PMC Data needed for Mori SL25
    By cmp79 in forum Mori Seiki Software
    Last Post: 10-23-2018, 08:55 PM
  3. Fanuc 21i-T problem with PMC allocation
    By anethus in forum Fanuc
    Last Post: 04-02-2014, 09:31 AM
  4. Replies: 1
    Last Post: 07-19-2013, 11:44 PM
  5. FANUC 21i help needed
    By rickst in forum General CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-28-2007, 01:26 AM
