600,786 active members*
2,957 visitors online*
IndustryArena Forum > Manufacturing Processes > Other Manufacturing Processes > Pneumatic Actuated Ball Valve Manufacturers in USA
    Mar 2025
    Post Pneumatic Actuated Ball Valve Manufacturers in USA
    Valves Only is leading Pneumatic Actuated Ball Valve Manufacturers in USA. We offer high quality and reliable valve solution. Depending on the intended operation, the pneumatic actuator either rotates the ball to permit fluid flow or positions it to restrict the flow when it is engaged.
    Key parts
    Ball – Rotating component inside valve that control fluid flow.
    Actuator – Device that use compressed air to move Valve.
    Valve Body – Outer shell that hold all internal part.
    Seat – Sealing material ensure no leakage when valve is closed.
    Stem – Connect actuator to ball allowing rotation.
    Seal and Packing – Prevent external leak and ensure airtight operation.
    End Connection – Connect valve to piping system available in different configuration like flanged, threaded, or welded.
    Working mechanism
    When compressed air is introduced into actuator, it generate force needed to turn the ball inside valve. This movement either open or close passage for fluid flow.
    There are two types of actuators :
    Spring Return Actuator – The valve returns to its default position when air pressure is removed.
    Double Acting Actuator – Air pressure control both opening and closing function.
    Benefit of Pneumatic Actuated Ball Valve
    Automation and Efficiency – Allow remote operation with minimal manual effort.
    Durability and Strength – Withstand high pressure and extreme condition.
    Leak Proof Design – Tight sealing prevent leak ensuring safe operation.
    Quick Response Time – Enable fast opening and closing for smooth operation.
    Corrosion Resistance – Made from material like stainless steel and brass for long term use.
    Cost Effective – Require minimal maintenance reducing overall operational cost.
    Industries:
    ●Oil and Gas
    ●Chemical Processing
    ●Water Treatment
    ●Petrochemical
    ●Power Generation
    ●Pulp and Paper
    ●Mining
    ●Automotive
    ●Aerospace
    ●Marine
    ●Textiles
    ●Renewable Energy (e.g., Wind and Solar)
    ●General Manufacturing
    ●Wastewater Treatment
    Temperature:
    ●Standard -4°F to 200°F (-20°C to 93°C)
    ●Low -40°F to 176°F (-40°C to 80°C)
    ●High 0°F to 300°F (-18°C to 149°C)
    Configuration of Pneumatic Actuator:
    ●4-20 Mamp
    ●Pneumatic single acting actuators
    ●Pneumatic double acting actuators
    ●Pneumatic rotary actuators
    ●Pneumatic Scotch and Yoke actuators
    ●Pressure: 228 bar
    Product Description:
    ●Pneumatic Ball Valve Manufacturer in USA has the valve with this specifications
    ●Available materials: WCB, WC6, WCC, LCB, LCC, Cast iron, Ductile Iron, SS316, SS304
    ●Size: 2″ to 80″
    ●Class: 150 to 300
    ●Nominal Pressure: PN6 to PN40
    ●Operation: Pneumatic Actuated
    ●Ends: Flanged, Threaded, Socket and Butt Weld
    Conclusion
    Pneumatic actuated ball valves offer automation, reliability and efficiency. Selecting right Pneumatic Actuated Ball Valve Manufacturers in USA ensure you get durable and high performing valve solution. Valves Only is trusted provider, delivering top quality pneumatic actuated ball valve tailored to industrial need. Investing in these valve guarantee smooth operations, reduced downtime and long term reliability.
    Visit us: https://valvesonly.com/product-categ...ed-ball-valve/
    Feb 2023
    Re: Pneumatic Actuated Ball Valve Manufacturers in USA
    Thanks for the detailed overview! Pneumatic actuated ball valves are indeed a solid choice for automated systems. I’ve sourced components for a similar setup recently and found this Valve and Fittings Online Store really useful — they have a broad selection of valves, actuators, and fittings that match a variety of industrial specs.
