I asked some advice recently from ArtCam forum but didn't got any help yet, so I'll try next from here...
I bought recently a Isel CPM 4030 mill and now seeking post processor that works with RemoteLT controlling software. I have contacted my AC reseller and tried to work out the issues, but seems hard to find solution that fixes the problems. Program runs the code but arcs are small lines that makes the process very slow.
Here is code that should run 50mm circle, but stops two times at the beginning and half way of the circle... This is done with edited post processor and here those half circles goes smoothly. I also tested several posts from ArtCam and for example Mach2, Proma and Charly G code posts worked but arcs were handled as small lines.
IMF_PBL_V1.0 - PICTURES BY PC
;Type: Alcami Soloutions
;Machine: Isel from Unimatic soloutions
SPINDLE OFF
COOLANT OFF
GETTOOL 1
SPINDLE CW RPM15000
SPINDLE ON
FASTABS X0 Y0
FASTABS Z20000
COOLANT ON
FASTABS X-25000 Y0 Z20000
VEL 9000
MOVEABS Z0
VEL 10800
stops here
CWABS I25000 J0 X0 Y25003 VEL 10800
CWABS I0 J-25002 X25000 Y0
and here
CWABS I-25000 J-0 X0 Y-25003
CWABS I-0 J25002 X-25000 Y0
VEL 149985
FASTABS Z20000
FASTABS X0
FASTABS
FASTABS X0
SPINDLE OFF
COOLANT OFF
PROGEND
I'm looking at the posibility to change the stepper motor controllers to Gecko G540 so I could use Mach3 control software instead of RemoteLT, but meanwhile the post for IMC4 controllers is needed.
Thank you for any help!
Cheers,
-niko-
