585,997 active members*
5,156 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > "power cabinet temp too high"
    Feb 2017
    3
    i am using hurco hawk 5m ultimax3 its show error "power cabinet temp too high enter machine diagnostic" i need help how resolve this problem.
    Oct 2004
    188
    Re: "power cabinet temp too high"
    check the power supply voltages. sounds like low voltage there should be test points on the rack -12, 5, 12, 24vdc. the 5 volt rail should be 5.10
    if they are all good, then try the oldie but goodie pull the cards clean the connections and put it back together.
    Feb 2017
    3
    Thanks for reply i already check all voltage of supply fans are running and card put different slot but result is same.
  1. Replies: 5
    Last Post: 01-12-2014, 07:07 PM
  2. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  3. "low end" HF Spindle or "high end" router for about $1000?
    By biomed_eng in forum DIY CNC Router Table Machines
    Last Post: 01-06-2012, 07:15 AM
