Has anyone else noticed malfunctions with PP V2.1.6?
I had a problem on bootup, it didnt load all the files or something, keyboard didnt work, neither did the jog controller, this has happened once.
In the Boss probing routine, it starts out OK then makes a sudden move in Y- instead of Y+ , then it moves in a rapid move across the top of the part and does not trip the probe. Restarting the boss routine it works as it should the second time. This has happened twice, the first time it is used after bootup this occurs, using the same routine the second time it works as it should.
I am wondering if anyone other than me has had problems similar to these with their PP v2.1.6 install? This could be something I have not done correctly as well, any input welcome.
V2.1.5 worked fine.
