532,233 active members*
4,062 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > Precision Parts Machining And Assembly Service For BMW customized production line
Results 1 to 1 of 1
    Banned
    Oct 2020
    17
    Precision Parts Machining and assembly
    Used in the customized production line of BMW parts
    Turntable working mode, 5 manipulators work together, and 5 points work at the same time. One operator puts work, greatly improves work efficiency.
    The turntable has high precision and is positioned within 0.01mm tolerance with the medium-sized one. The fit clearance of the medium-sized running to any point of the turntable is within 0.01mm.
    This kind of design scheme can guarantee the long-term efficiency while also guaranteeing the accuracy of assembly in use. In terms of space occupied, it is completely controlled within 2.5m and 1m, which greatly saves working space.
    Attached Thumbnails Attached Thumbnails IMG_20200916_130702.jpg   IMG_20200916_131102.jpg   IMG_20200916_130644.jpg
