585,749 active members*
3,702 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > Prima Power Platino 6kW OR LVD Phoenix FL 6kW, which is better???
    Oct 2016
    6
    Smile Prima Power Platino 6kW OR LVD Phoenix FL 6kW, which is better???
    Hello guys, I'm in a process of buying a new Fiber Laser, but I'm in a doubt whether I should buy the LVD Phoenix FL 6kW OR Prima Power Platino 6kW, so can somebody help me with some experience notes, issues or advice for both machines, so I can decide a bit easier??
    Any help is better then none..
    Re: Prima Power Platino 6kW OR LVD Phoenix FL 6kW, which is better???
    Offcours sir you can go for Prima As it is one of first laser machinmanufactureer and they have complete solution for all sheet meta works.
  1. Anyone using a Prima Platino?
    By Blackened in forum Commercial Laser
    Last Post: 09-06-2017, 01:54 AM
  2. 2000 Prima Platino 1530 Axis calibration
    By Leadfoot2911 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-02-2016, 01:50 AM
  3. prima power platino machine issue
    By coolkarthi in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-06-2013, 10:32 AM
  4. Ona Prima S900
    By fruivo in forum Waterjet General Topics
    Last Post: 07-05-2007, 02:19 PM
