601,122 active members*
1,584 visitors online*
Results 1 to 18 of 18
    Mar 2007
    9
    Exclamation Printer port problems
    I've got my controller on and can hear that the motors on. But in mach3 when i attempt to jog it doesn't move. I've got the motor outputs set up right, all are going through port 1, steps per inch are set on all the axis' and set on active low as specified. when I go into the diagnostics window there is no printer port activity (no leds light up) when I attempt to jog. Also my enable1 led stays lit even though it is disabled. Any ideas? What settings for the pirinter port do i need to have on in the bios?Any suggestions are appreciated. thanks a lot.
    Dec 2005
    3319
    What kind of PC? Some laptops have 3.3 volt parallel ports and don't work well or at all with some BOB's that want 5 vdc signals.
    This whole laptop vs regular computer topic has been discussed AT GREAT LENGTH on the CNC ZOne.
    Mar 2007
    9
    I have a homebuilt desktop with a Asus motherboard.
    May 2006
    1469
    Control panel / system / hardware / device manager, look at the resources on the LPT
    Mach defaults to 275 where as it is often 375.
    This can be changed in BIOS but if you don't have to....
    As to the old chestnut about laptops 3.3v, most desktops are also.
    I have five desktops running here and all but one is 3.3v (that one is 10 years old)
    Mar 2007
    9
    is there a way to check and see what voltage it is? And i've tried messing with the port numbers in both the bios and in mach and i can't seem to get it to work. Thanks for the help.
    Mar 2003
    35494
    Are the DRO's in Mach changing when you attempt to jog?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2003
    35494
    Have you watched the Mach3 setup video at www.machsupport.com? It explains how to get the proper port address. Can you post a screenshot of your motor pin setup screen?
    Gerry
    Mar 2007
    9
    Ya i watched the whole mach video as well. And the DRO are changing too.
    Mar 2003
    35494
    You didn't install the driver, or it didn't take. On your diagnostics page, under pulse frequency, it says simulate. It should say something close to 25000 . Run drivertest.exe in the mach3 folder. If it doesn't work, uninstall, reboot, and reinstall.
    Gerry
    Mar 2007
    9
    I unistalled rebooted and installed. It never asked to install driver. And I went to the mach 3 folder and tried opening orignialdriver. And that didn't work. Any ideas on how to get driver to install. Running winxp 64-bit
    Mar 2003
    35494
    Yeah, don't use Xp 64 bit, it won't work. Must be standard 32bit XP, Vista or Win2K. The install should have a checkbox at the end that says "install driver".
    Gerry
    Mar 2007
    9
    thanks a lot for your help. Getting another computer set up for it.
    Apr 2024
    3
    Re: Printer port problems
    Printer port problems can be a frustrating issue for many users, particularly when dealing with specialized devices such as a thermal tattoo printer. These issues often stem from connectivity problems, driver conflicts, or hardware malfunctions. A thermal tattoo printer, which uses heat to transfer ink onto tattoo paper, relies on a stable and properly configured printer port to function correctly. If there are disruptions in the communication between the printer and the computer, it can result in errors or incomplete prints. Ensuring that the printer port settings are correctly configured and that drivers are up to date can help mitigate these problems and ensure smooth operation of the thermal tattoo printer.
    Aug 2024
    3
    Check out the back to school sale from Phomemo, who focus on the thermal printers and lead in the printing industry.
    Mar 2025
    HiLock specializes in precision stamping technology, manufacturing high-pressure connectors and valves. Their sterilization equipment is trusted in critical industrial applications.
    Mar 2025
    JazzPower delivers high-quality energy storage solutions, from commercial battery systems to home inverters. Their solar panel technology ensures sustainable energy for all applications!
  17. #17
    Mar 2025
    ARES Precision provides professional die casting and CNC machining services. Their precision molds and 3D printing capabilities make them a top-tier manufacturing partner.
  18. #18
    Mar 2025
    Looking for a trusted partner in mechanical sheet metal manufacturing? CTT Technology offers precision-engineered parts and 3D printing solutions to meet diverse industry needs
  1. USB to Printer port compatability
    By CbrViking in forum Mach Mill
    Last Post: 02-28-2007, 12:05 AM
  2. printer port tester
    By smarbaga in forum CNC Machine Related Electronics
    Last Post: 12-10-2005, 06:57 PM
  3. Communications output to Printer Port
    By kheri in forum Post Processors for MC
    Last Post: 03-26-2005, 07:40 AM
  4. printer port?
    By replicapro in forum Uncategorised CAM Discussion
    Last Post: 11-26-2004, 10:37 PM
  5. Have problems with G201 and printer port
    By Christian in forum Gecko Drives
    Last Post: 09-26-2004, 08:44 PM
