Re: Fanuc oi tb parameter ?
Quote:
Originally Posted by
Ant29018
Still no luck. It says no feed rate specified when using G94 and illegal G code with G95. When I put it back to where all the other machine are and press dry run to get z to move then immediately release it will do the feed rate i want but after m69 to unclamp I have to press dry run again to get moving then release to get proper feed rate. I even photoed the active G codes on another Fanuc 0i machine while bar pulling and they match. Any other ideas ?
Thanks for your time.
Did you give it a feed rate after the G1 command ?
gabedrummin
Yes I did.
G0G40G98
x0.z0.
G1Z-1.F50.
Once it reaches the G1 Line it stop. Will start axis movement with DRY RUN and if I take it off it will finish its stroke in the specified feedrate.
Ant29018
What machine is it?
Hwacheon HI-Tech 200A Fanuc 0i-tb
Ant29018
There could be an M code that allows the machine to move whilst the spindle is not rotating like on a doosan
There could be a keep relay that could affect the same
I have done a little digging and found this, does it sound familiar?
http://www.cnczone.com/forums/fanuc/...eon-oi-tb.html
I changed bit 0 on parameter 3708 from 1 to 0 and it worked !!! The other guy chimed in and said that it will cause problems with thread cutting if bit 2 of parameter 3708 is also 1 but I will check parameters on other Hwacheon 0i tomorrow cause it threads fine while doing feed rates with spindle off. I will let you know.
Thanks again !!!
