New guy needing an assist. I have X & Y movement, but its very tiny.
New install on 6040Z machine.
I have the unit set in mach3 for inches. Created file in Aspire 10. Uploaded the file into Mach3 on Vista machine with windows 7 upgrade. All looked good so I hit run.
Code runs, I get movement but its very, very tiny movement.
Axis calibration gives me the following:
X & Y
steps- 400
Velocity 3000
Acceleration 425
Material size on file shows as X=10.0 Y=10.0 Z=0.99
Actual cut size is about 3/4 inch square......
I can manually run table entire width and length. Tried multiple files all run tiny. Machine is set to Inch. Aspire is set to Inch. Files show to be Inch.
Any Ideas or things to try to get the machine to cut correct dimensions would be much appreciated.
Thanks in advance
Novice
Specs:
6040Z
Dell Optiplex 760
Windows 7 Ultimate
Aspire 10.0
Mach 3 - Ver 3.043.066
G540 Rev 5
Post Processor: Mach3 2/3 arcs (Inch)
Motors-57BYGH433-06BS
Re: New guy needing an assist. I have X & Y movement, but its very tiny.
The step count seems pretty low. It looks like you were in mm when you ran the motor tuning dialog. Try increasing the steps per unit until the commanded position on an axis move matches the actual distance travel (or running the setup dialog again, making sure it knows the unit is an inch, not a mm.) You probably want a step count of about 10,160 (400 x 25.4).
