5 Attachment(s)
My second big 5 axis
Hello.A long time I was not here. I got an interesting job to do. This 5 axis. Another company did not build the machine, I received several parts to build it.
I have a planed beam and several supports. I drew a new project and started to build the machine.
The assumptions:
working area x3m, y8m, z2m, head BC, c 350, B +- 120,
Drive with servomotors Delta B2, head with harmonic gear's, xyz planetary gear's. Axis X and Z ballscrew. Y tothed rack's.
A few photos
Attachment 396950
Attachment 396952
Attachment 396954
Attachment 396956
Attachment 396958
Re: My second big 5 axis
Good to see you back Bartuss.
I like the cnc cut plate weldment
1 Attachment(s)
today I welded one side, tomorrow the other, and then all angles will be set
Attachment 397036
4 Attachment(s)
All angles are, diagonals also after welding side's. I started to paint it
Attachment 397132
Attachment 397134
Attachment 397136
Attachment 397140
1 Attachment(s)
Today I drew the Z axis. The drawing went to the laser.
Attachment 397402
3 Attachment(s)
I welding the Z axis. I bought a harmonic gear for axis C to head.
Attachment 397502
Attachment 397504
Attachment 397506
2 Attachment(s)
I have a guides Hiwin 30. Actually I turning shaft's for drive Y axis.
Attachment 398276
Attachment 398278
This is amazing! Whats the cost range of a build like this and capabilities?
Whats this: "head BC, c 350, B +- 120,"
I'm trying to build a 5-axis laser + cnc capable of working with 1/8" aluminum (cutting and welding) wiht work area of x1m x y1m 0.5mz + 360x' + 360 y'
Looking forward to your build and learning a lot. Apologies if they are newbie questions, kindly point me to the relevant sticky or forum area.
Wow! Excellent!
Sent from my iPhone using Tapatalk Pro
Head BC have an angle axes for spindle position, C axis 350 deg around Z axis, B axis +- 120deg around Y axis.
My previous 5 axis machine :
https://www.youtube.com/watch?v=pg2Fd9wUpmQ
Cost about 60 th dollars
What do you make with the machines?
2 Attachment(s)
X axis steel plate is mounting after milling.
Attachment 398756
Attachment 398758
1 Attachment(s)
Tomorrow I'll be milling the Z axis
Attachment 399004
4 Attachment(s)
4 Attachment(s)
2 Attachment(s)
The Z axis with counterbalance and harmonic gear with bearing in out
Attachment 399614
Attachment 399616
Excellent work, thank you for posting. We can learn a lot from you!
3 Attachment(s)
Thank's for watching haha
I have a long ballscrew. 4m 2520. Previous company wanted to drive the ballscrew. At this length there would be large vibrations. So I decided to do a driven ballnut and ballscrew to stretch the string.
Attachment 399752
Attachment 399754
Attachment 399756
Great work here! Thank you sharing. What kind of CNC board you are using to control 5 delta B2 motors / 5 axis ?
