2 Attachment(s)
Kflop to Ditron DC10 Encoders
Hi I.m try to hookup a set of Ditron DC10 linear encoder to a kflop board. I have the encoders wired up to match a pinout off of the Ditron website but I.m not getting any Voltage change when i test with a multimeter(the tester is an analog type with a needle) i have a 10k resistor on channel a and 2.2 on channel B with 5v going in. Has anyone used these encoders or know the proper wiring Attachment 221522Attachment 221524
do i need to link the encoder to the axis with c code if so what is the wording in c i.am using I/O 0 1 pins 7 and 8 on the jp7 i also should note these are running threw my c10 board pins 10 and 11 witch are wired to pins 7 and 8 on jp7 on kflop. any help would be great
