G Code for Roland Modela MDX 15
Hi
I am trying to use my Modela to cut isolation routes on PCBs. I have been using Eagle with the GCode outputter but my machine as with most Roland machines it seems only listens to Rolands RML-1 language.
Does anybody know a way either of converting the codes or even just using the MDX-15 with GCode straight away.
I've heard of a program called Dropout but all the links posted on here are bad and I can't find it anywhere on Rolands website.
Any help would be reatly appreciated
Laurence
Short of gutting the whole machine
You might consider getting a CAM software package that can write .ROL files. DeskProto is one; it also can run the files on your (unmodified) MDX15. They've just announced a new hobbyist special; $350 for the 4.2 version, with a free (except for shipping) upgrade to the full 6.0 version when it's released. This is not for companies or commercial users, though. Let me know if you're interested.
Andrew Werby
ComputerSculpture.com — Home Page for Discount Hardware & Software
Quote:
Originally Posted by
lawmate
Cool, it looks pretty good. Does it involve completely changing the motor drivers? I mainly use the machine for PCBs and occasionally for making stamps, so I'm not sure how much I'd use a 4th axis, but being able to use commercially available CAM software would definately be something I'd consider.
Thanks a lot, and let us know when you're selling them
Re: G Code for Roland Modela MDX 15
I have a MDX-15/20 and have read lots online that people say its possible to make the miller work with g-code / mach3 but can not find any further information any help advice or links would be really helpful as would love to bring this little machine back to life.
Download a copy of Deskproto (DeskProto: 3D CNC machining for non-machinists ); it will write the code from your STL mesh and run it for you (Create/Extra/Send NC code to machine). You don't need Mach3 if you've got the Roland control software installed and working. The demo will expire after a month, but if you're a hobbyist you can purchase it for less than $300, which is not bad compared to a dead machine.
awerby
Ran the trial version last night worked a treat just need to work out how tool changes work then will be up and running with lots more to learn I am sure.
Those machines don't have an automatic toolchanger, so just write a separate NC file for each tool you want to use, and run it after you've changed them and re-zeroed the Z axis.
