Problem when tying drain wires together
Hello everyone,
I’m a long time lurker and have learned a great deal from this forum. I wish it has been available 22 years ago when I built my router. I’m hoping someone can explain why the following happened:
I had replaced my stepper cables with new shielded cables that had a drain wire. The old cables were not shielded and had no drain. I tied the drains on the new cables together and grounded them to the controller chassis.
After I powered up the motors I was hearing lots of clicks and squealing from the motors. Worse, my X axis would occasionally stutter and lose steps. I suspect noise was getting into the system but could not find any logical source.
When I disconnected the drain lug from the chassis I still had the problem, however; when I untied the drains from the common lug the problem went away.
While I can run this without the drains grounded I do wonder what caused the problem. The cables are all well separated. They are 22 gauge and attached to old chopper drivers that are set for 2 Amps/phase. The cables are about 12’ long.
Mark
