Help needed from the Taig Pros...shopping list
Hey guys, while I'm a long time lurker of this great forum, I've only joined today. I've found there is a ton of reading and know what I'm asking could be a loaded request, but it beats doing the wrong thing 10 times before getting it right.
After owning multiple machine shops and owning multiple product lines, I now source all of my work out, but have found I desperately need to be able to prototype my own parts in house (at least the parts that have high potential for changes prior to production). A majority of my parts are milled components but a few will require a lathe (which I plan to go ahead and order a Taig micro lathe).
So here's the request. I'm needing help putting together a solid 4th axis capable (or 4th axis included) Taig setup that can handle fine detail, and can do it as quickly as possible...within reason of course. Time is of the essence and I am looking to get the necessary parts/kits on order now.
I know there are a lot of preferences involved as to the ideal Taig CNC setup, but I need to get the right parts the first time to get the most performance for my $$ and get me to cutting prototypes...that's why I am coming to the most informed users of the Taig mills with my request. I utilize Alibre for all of my design and have the CAM package for it along with an older version of MasterCAM. What I am looking for is guidance on everything I need to be cutting parts. I have a large air compressor here and will be building an enclosure with air and mist for it right away as well.
You can browse around my site and see the types of parts/materials I'll mostly be working on/with. www.billet-works.com
I know I'm asking a lot and hope I don't get blasted too hard here.
Thanks a ton for taking the time,
Don Eidson
Owner
Billet Works Designs
Partner
Billet Works Tactical
If you want a turn-key system
Get the whole thing from Taig (or a Taig dealer). Their top-of-the-line DSLS 3000 system comes all ready to run, with a proprietary control box, Mach3, a relay receptacle box, encoder-equipped stepper motors, cables, collets, vise, etc. The rotary 4th axis kit for that model includes the Sherline rotary table mounted for vertical use, an encoder-equipped stepper motor, and an adjustable tailstock that mounts on the bed of the mill.
One advantage of getting it all from the same manufacturer is that you will get technical support that doesn't pass the buck to whomever supplied whatever odd components you've cobbled together in hopes of assembling a working system - Taig has a stern note on their site disclaiming any responsibility for supporting people's home-made motion control solutions:
http://www.taigtools.com/specialnote.html
They are good, however, at supporting their own proprietary systems.
Andrew Werby
www.computersculpture.com
