Help please: Fanuc spindle alarm AL-33
I just received a Hardinge T42 which was working when inspected, but on arrival it's giving me an alarm code: AL-33 on the LED display on the spindle servo drive. Controller is 18t and as far as I can tell it's hooked up properly to power. Hydraulics work so the phase is fine.
I looked up the error code and it's described as "SHORTAGE POWER CHARGE" which sounds like some sort of voltage isn't high enough somewhere.
Has anyone else got experience with this glitch?
Re: Help please: Fanuc spindle alarm AL-33
Good afternoon, I have the same problem. Is it possible to indicate which relays you replaced?
Good afternoon, I have the same problem in Nakamura TW30. Is it possible to indicate which relays you replaced?
Problem in your spindle drive , sent it for repair
