Hello I need some help my encoder on the x axes makes a humming nose when it is being moved left or in the + position and when it is just sitting in idle, does not make any noise when being moved right or in the - position. any hepl?
Printable View
hi m8
first of all is easy for us if u give us some detail about u machine:
brand,model etc and how the noise apeear.---suddenly?
or u lost some parameters or u modified them?
more details more easy to help u
GOOD LUCK!
I have a victor vcenter 4 with a fanuc 10m controller, the x axes motor makes noise when you are moving it in the left position or in positive direction its does not make any noise going the other direction is there a parameter that I need to look at or is there a motor issue it has no drag on the ball screw . Please help
today I turned my machine on to try and find why the x servo is making noise and it keeps having a alarm message Sv00 X Tachogenerator Disconnect,
SV013 X Improper V_Ready Off On the servo drive board a lite is on and beside the light is has GLS. Any Ideas
Please somebody Help
Hello, my x servo is jerking when moving in counter clock wise I have changed servo motor and still does it changed cable still same problem, you can allso stop the servo with your hand, has anybody ever had this problem? I think it is the velocity drive any help???????
I can not switch because the drive is a dual axes drive
Could you switch motors?
I switched motors and cables
So? Fail persist in X axis?
yes only on x
Your servo drive is defective. You have to send it to a Fanuc repair center.
PM Sent.
Tell me more about your 10M configuration on the V-center IV.
There are a few so that would help me.
Greg
Hello Guys
We have a V-Center 4
S/N: NK-1217
After not using the ATC for the last two years we are now trying to get it going again. We are a bit stuck not having any of the Keep relay or counter data.
Can anyone assist me in providing the info that we need.
We are in a bit of trouble after trying to do a tool change our Z axis and spindle are now inhibited and are unable to run any cycle example: (M03s200; or G0X0)
We suspect a keep relay or tool data that needs to be changed.
And someone decided that we do not need our manuals anymore and tossed it we need some assistance
Thank You
Vleisman
South Africa
