My Mazak mazatrol M2 seams bee allergic for G21 and G17
Why and whot can I do.
The machine is metric as is now.
Sven
Thankyou.
Printable View
Sven
Thankyou.
Are you getting alarms? What is the machine doing when you command G21 or G17?
Machine stops and show alarm (illegal data)
So i take away G21 and start again.
Same thing and i take away G17.
After that it works.
Sven
What's the alarm number?
Illegal Data also usually means that you are using some codes that cannot be used with each other or on the same line. A conflict of code...
Can you post a portion of the program where you're having problems?
O0100
N1 G54 G90 G80 G21 G17 G00 Its little but problem
starts here.
Machine stops and show alarm (551 illegal data input)
Still same thing so i also take away G17.
After that it works for more then 8000 lines.
Machine is in Europe and all the time in metric mode.
Sven
related comments that may not solve the problem;
I am in the habit of putting G54 in a line all by itself at the first line of the program. In my 30 year history dealing with CNC's (not all accross the board - fanuc, mits, mazatrol, vickers, dyna mechatronics) sometimes problems can be caused by burying G54 with a string of other modals.
Secondly. NOT ALL CNC's can digest more than 3 G codes in one line. Some only act on the first three and ignore the subsequent ones. Mazatrol EIA can digest up to a string of 6, I think?
PROGRAM EXPERIMENT
N1G54
N2 G01
N3 G17
N4 G90
N5 G21
N6 G80
You can put in any G codes you want, in any order you want. The purpose of this is trouble shooting. Using the N word (aka sequence number) will help decode where your program error is taking place. (12, 34, 56) type of info will appear along with the alarm code (Always include the alarm number when asking questions) 12 is program number, 34 is sequence number, 56 is the line after the sequence number 34 is read. I have never quite understood whether the alarm is pointing to "the last good line" or "the line where the problem is", so I use this just to get in the vicinity of the problem.
Use the scientific method. run the experiment and change one thing at a time and record the results.
jim
Not sure if Jim's test is going to work... I suspect no alarms with that. Reason being is that all the codes are valid particularly if you have them all seperated on each line (for this case of the codes being used). But Jim's reasoning is not far off I think and right alongside of what I'm thinking. The problem is the combination of codes in the same line I believe.
In this case (on that ancient control), your plane select is likely the culprit being used on the same line with G54 (and possibly along with G0).
But as Jim suggested, test the difference. Try the same line but only remove G17 (for example)
Hello again Psycomill.
I notice today that it wasent any G40 in begining
but it is a G43 later in prog,coud it be sourse to the problems.
And about compensation some on net or on these site was say
it is nessesary set tools to zero,do that means in tool data and
tool comp.
Thank you one more time.
Sven.
I don't think that would be it. G40 cancels Cutter Compensation and G43 is to activate Tool Length.
This is going to depend on how your machine is set up on the parameters and how you program. If you're only talking about diameter compensation, you're pretty safe to set both sides (Data and Comp) to zero. If you program by centerline of tool, you'll know right away as well since the part size won't be right (1/2 the cutter diameter off).Quote:
tool comp.
If you're talking about Tool Length settings, ... You need the tool length active and correct for at least one side. Again, this will depend on parameters.
Sounds like you may need to run a couple tests with tool length and diameter compensation to see how your machine is set up..... be careful doing this....
How do i in tool data set tool lengd without diameter
I belive it will come up something like tol data not complite
And how to understand one side.
Thanks meny times more
Sven
Here is a program that works untill line 11 or 12.
O100 (POCKET IDAG..NC)
N1 (TUE. 06/15/2010 10:38AM)
N2 ( MAZATROL CAM M-2 - METRIC)
N3 ( T10 ENDMILL ROUGH , DIAMETER = 16. , LENGTH = 127.)
N4 ( T1 ENDMILL FINISH , DIAMETER = 12.7 , LENGTH = 127.)
N5 G90 G80 G17 G00
N6 G91 G28 Z0.
N7 G91 G28 X0. Y0.
N8 (JOB 1 POCKET)
N9 (FEATURE POCKET)
N10 M06 T10
N11 M03 S994
N12 G54 G90 X.73 Y.73
N13 G43 Z2.54 H10
N14 M08
N15 G01 Z-12.7 F101.0375
N16 X-.73 F197.0232
N17 Y-.73
N18 X.73
N19 Y.73
N20 X8.73
N21 Y8.73
N22 X-8.73
N23 Y-8.73
N24 X8.73
N25 Y.73
N26 X16.73
N27 Y16.73
N28 X-16.73
N29 Y-16.73
N30 X16.73
N31 Y.73
N32 X24.73
N33 Y24.73
N34 X-24.73
N35 Y-24.73
N36 X24.73
N37 Y.73
N38 X32.73
N39 Y32.73
N40 X-32.73
N41 Y-32.73
N42 X32.73
N43 Y.73
N44 Y32.73
N45 X40.73
N46 Y40.73
N47 X-40.73
N48 Y-40.73
N49 X40.73
N50 Y32.73
N51 G00 Z2.54
N52 M09
N53 M05
N54 G91 G30 Z0. H0
N55 (JOB 1 POCKET)
N56 (FEATURE POCKET)
N57 M06 T1
N58 M03 S1879
N59 G54 G90 X43.65 Y43.65
N60 G43 Z2.54 H1
N61 M08
N62 G01 Z-12.7 F190.937
N63 X-43.65
N64 Y-43.65
N65 X43.65
N66 Y43.65
N67 G00 Z2.54
N68 M09
N69 M05
N70 G91 G28 Z0.
N71 G91 G28 X0. Y0.
N72 M02
N73 M30
If i set not complet inputs in tool file in the mazak
I will get alarm inadequate data in the tool data
then i try to set the info for the same tool nr.
Do that means that i should set these data on Pc side
in progr cad/cam under tools.
Thanks to Psychomill for pointing
out four digits after point can give trouble.It did.
I changed to 3 digits after point and it works.
However I made a new prog,working good untill line
9994,there it stops giving alarm 551 saying as follow.
(Numerical falling out off the specified range has
been entered).
Now I dont know to do,becuse I just dont see any Wrong,
Maybee other eyes see better?
O100 (KROSS.NC made off 10"lenghd 2"Dia, alu stock 12"times 12")
N1 (WED. 06/23/2010 11:15AM)
N4 G90 G80 G17 G00
N5 G91 G28 Z0.
N6 G91 G28 X0. Y0.
N7 (JOB 1 SLICE CUT PLANAR)
N8 (FEATURE SLICE PLANAR)
N9 M06 T10
N10 M03 S994
N11 G54 G90 X-50.74 Y130.174
N12 G43 Z2.6 H10
N13 M08
N14 G01 Z0. F3031.12
N15 X50.74 F5910.69
N16 X53.407 Y128.975
N17 X51.331 Z-.062
N18 X-51.626 Z-.056
N19 X-53.407 Z0.
N20 X-53.826 Y127.775
N21 X-53.014 Z-.03
N22 X-52.202 Z-.121
N23 X-51.39 Z-.254
N24 X51.39
N25 X52.202 Z-.121
N26 X53.014 Z-.03
N27 X53.826 Z0.
N28 X53.882 Y126.575
N29 X52.984 Z-.036
N30 X52.085 Z-.146
N31 X51.187 Z-.331
N32 X50.289 Z-.596
N33 X-50.289
N34 X-51.187 Z-.331
N35 X-52.085 Z-.146
N36 X-52.984 Z-.036
N37 X-53.882 Z0.
N38 Y125.375
N39 X-52.984 Z-.036
N40 X-52.085 Z-.146
N41 X-51.187 Z-.331
N42 X-50.289 Z-.596
N43 X-49.025 Z-1.084
N44 X48.985
N45 X50.289 Z-.596
N46 X51.187 Z-.331
N47 X52.085 Z-.146
N48 X52.984 Z-.036
N49 X53.882 Z0.
N50 Y124.175
N51 X52.984 Z-.036
N52 X52.085 Z-.146
N53 X51.187 Z-.331
N54 X50.289 Z-.596
N55 X49.84 Z-.756
N56 X48.942 Z-1.151
N57 X47.888 Z-1.744
N58 X-47.876 Z-1.748
N59 X-48.942 Z-1.151
N60 X-49.84 Z-.756
N61 X-50.289 Z-.596
N62 X-51.187 Z-.331
N63 X-52.085 Z-.146
N64 X-52.984 Z-.036
N65 X-53.882 Z0.
N66 Y122.975
N67 X-52.984 Z-.036
N68 X-52.085 Z-.146
N69 X-51.187 Z-.331
N70 X-50.289 Z-.596
N71 X-49.84 Z-.757
N72 X-48.942 Z-1.151
N73 X-48.044 Z-1.646
N74 X-47.146 Z-2.258
N75 X-46.697 Z-2.62
N76 X-39.513 Z-2.634
N77 X46.697 Z-2.62
N78 X47.146 Z-2.258
N79 X48.044 Z-1.646
N80 X48.942 Z-1.151
N81 X49.84 Z-.756
N82 X50.289 Z-.596
N83 X51.187 Z-.331
N84 X52.085 Z-.146
N85 X52.984 Z-.036
N86 X53.882 Z0.
N87 Y121.775
N88 X52.984 Z-.036
N89 X52.085 Z-.146
N90 X51.187 Z-.331
N91 X50.289 Z-.596
N92 X49.84 Z-.757
N93 X48.942 Z-1.151
N94 X48.044 Z-1.646
N95 X47.146 Z-2.258
N96 X46.343 Z-2.927
N97 X45.5 Z-3.784
N98 X45.456 Z-3.805
N99 X-45.439
N100 X-45.499 Z-3.785
N101 X-46.248 Z-3.013
N102 X-47.146 Z-2.258
N103 X-48.044 Z-1.646
N104 X-48.942 Z-1.151
N105 X-49.84 Z-.757
N106 X-50.289 Z-.596
N107 X-51.187 Z-.331
N108 X-52.085 Z-.146
N109 X-52.984 Z-.036
N110 X-53.882 Z0.
N111 Y120.575
N112 X-52.984 Z-.036
N113 X-52.085 Z-.146
N114 X-51.187 Z-.331
N115 X-50.289 Z-.596
N116 X-49.84 Z-.757
N117 X-48.942 Z-1.151
N118 X-48.044 Z-1.646
N119 X-47.146 Z-2.258
N120 X-46.248 Z-3.013
N121 X-45.799 Z-3.463
N122 X-45.35 Z-3.958
N123 X-44.677 Z-4.839
N124 X-44.284 Z-5.453
N125 X44.237 Z-5.456
N126 X44.288 Z-5.446
N127 X44.647 Z-4.883
N128 X45.057 Z-4.325
N129 X45.467 Z-3.821
N130 X46.287 Z-2.977
N131 X47.146 Z-2.258
N132 X48.044 Z-1.646
N133 X48.942 Z-1.151
N134 X49.84 Z-.757
N135 X50.289 Z-.596
N136 X51.187 Z-.331
N137 X52.085 Z-.146
N138 X52.984 Z-.036
N139 X53.882 Z0.
N140 Y119.375
N141 X52.984 Z-.036
N142 X52.085 Z-.146
N143 X51.187 Z-.331
N144 X50.289 Z-.596
N145 X49.84 Z-.757
N146 X48.942 Z-1.151
N147 X48.044 Z-1.646
N148 X47.146 Z-2.258
N149 X46.248 Z-3.013
N150 X45.799 Z-3.463
N151 X45.35 Z-3.958
N152 X44.677 Z-4.839
N153 X44.228 Z-5.547
N154 X43.779 Z-6.401
N155 X43.554 Z-6.911
N156 X43.217 Z-7.839
N157 X43.077 Z-8.308
N158 X-43.077
N159 X-43.33 Z-7.496
N160 X-43.554 Z-6.911
N161 X-43.779 Z-6.401
N162 X-44.228 Z-5.547
N163 X-44.677 Z-4.839
N164 X-45.35 Z-3.958
N165 X-45.799 Z-3.463
N166 X-46.248 Z-3.013
N167 X-47.146 Z-2.258
N168 X-48.044 Z-1.646
N169 X-48.942 Z-1.151
N170 X-49.84 Z-.757
N171 X-50.289 Z-.596
N172 X-51.187 Z-.331
N173 X-52.085 Z-.146
N174 X-52.984 Z-.036
N175 X-53.882 Z0.
N176 Y118.175
N177 X-52.984 Z-.036
N178 X-52.085 Z-.146
N179 X-51.187 Z-.331
N180 X-50.289 Z-.596
N181 X-49.84 Z-.757
N182 X-48.942 Z-1.151
N183 X-48.044 Z-1.646
N184 X-47.146 Z-2.258
N185 X-46.248 Z-3.013
N186 X-45.799 Z-3.463
N187 X-45.35 Z-3.958
N188 X-44.677 Z-4.839
N189 X-44.228 Z-5.547
N190 X-43.779 Z-6.401
N191 X-43.554 Z-6.911
N192 X-43.33 Z-7.496
N193 X-43.003 Z-8.619
N194 X-42.798 Z-9.751
N195 X-42.491 Z-13.112
N196 X-42.082 Z-15.789
N197 X-41.346 Z-19.058
N198 X-40.491 Z-21.866
N199 X-39.757 Z-23.846
N200 X-39.033 Z-25.551
N201 X-38.554 Z-26.583
N202 X-38.074 Z-27.548
N203 X-37.595 Z-28.455
N204 X-36.635 Z-30.125
N205 X-35.676 Z-31.638
N206 X-34.839 Z-32.859
N207 X-34.002 Z-33.989
N208 X-33.166 Z-35.047
N209 X-32.329 Z-36.043
N210 X-31.408 Z-37.073
N211 X-30.487 Z-38.035
N212 X-29.566 Z-38.941
N213 X-28.645 Z-39.796
N214 X-27.77 Z-40.565
N215 X-26.895 Z-41.292
N216 X-26.02 Z-41.981
N217 X-25.145 Z-42.634
N218 X-24.233 Z-43.278
N219 X-23.321 Z-43.886
N220 X-22.41 Z-44.462
N221 X-21.498 Z-45.007
N222 X-19.729 Z-45.98
N223 X-17.961 Z-46.848
N224 X-16.151 Z-47.634
N225 X-14.342 Z-48.323
N226 X-12.559 Z-48.913
N227 X-10.776 Z-49.418
N228 X-8.958 Z-49.849
N229 X-7.169 Z-50.192
N230 X-5.362 Z-50.46
N231 X-3.592 Z-50.648
N232 X-1.797 Z-50.761
N233 X0. Z-50.8
N234 X1.797 Z-50.761
N235 X3.592 Z-50.648
N236 X5.362 Z-50.46
N237 X7.169 Z-50.192
N238 X8.958 Z-49.849
N239 X10.776 Z-49.418
N240 X12.559 Z-48.913
N241 X14.342 Z-48.323
N242 X16.151 Z-47.634
N243 X17.961 Z-46.848
N244 X18.845 Z-46.427
N245 X20.614 Z-45.507
N246 X22.41 Z-44.462
N247 X23.321 Z-43.886
N248 X24.233 Z-43.278
N249 X25.145 Z-42.634
N250 X26.02 Z-41.981
N251 X26.895 Z-41.292
N252 X27.77 Z-40.565
N253 X28.645 Z-39.796
N254 X29.566 Z-38.941
N255 X30.487 Z-38.035
N256 X31.408 Z-37.073
N257 X32.329 Z-36.043
N258 X33.166 Z-35.047
N259 X34.002 Z-33.989
N260 X34.839 Z-32.859
N261 X35.676 Z-31.638
N262 X36.156 Z-30.898
N263 X37.115 Z-29.312
N264 X38.074 Z-27.548
N265 X38.554 Z-26.583
N266 X39.033 Z-25.551
N267 X39.757 Z-23.846
N268 X40.491 Z-21.866
N269 X40.979 Z-20.339
N270 X41.57 Z-18.179
N271 X42.184 Z-15.23
N272 X42.44 Z-13.521
N273 X42.798 Z-9.751
N274 X42.952 Z-8.854
N275 X43.217 Z-7.839
N276 X43.554 Z-6.911
N277 X43.779 Z-6.401
N278 X44.228 Z-5.547
N279 X44.677 Z-4.839
N280 X45.35 Z-3.958
N281 X45.799 Z-3.463
N282 X46.248 Z-3.013
N283 X47.146 Z-2.258
N284 X48.044 Z-1.646
N285 X48.942 Z-1.151
N286 X49.84 Z-.757
N287 X50.289 Z-.596
N288 X51.187 Z-.331
N289 X52.085 Z-.146
N290 X52.984 Z-.036
N291 X53.882 Z0.
N292 Y116.975
N293 X52.984 Z-.036
N294 X52.085 Z-.146
N295 X51.187 Z-.331
N296 X50.289 Z-.596
N297 X49.84 Z-.757
N298 X48.942 Z-1.151
N299 X48.044 Z-1.646
N300 X47.146 Z-2.258
N301 X46.248 Z-3.013
N302 X45.799 Z-3.463
N303 X45.35 Z-3.958
N304 X44.677 Z-4.839
N305 X44.228 Z-5.547
N306 X43.779 Z-6.401
N307 X43.554 Z-6.91
N308 X43.217 Z-7.838
N309 X42.952 Z-8.854
N310 X42.798 Z-9.751
N311 X42.44 Z-13.521
N312 X42.184 Z-15.229
N313 X41.57 Z-18.179
N314 X40.979 Z-20.339
N315 X40.491 Z-21.866
N316 X39.758 Z-23.846
N317 X39.033 Z-25.551
N318 X38.554 Z-26.583
N319 X38.074 Z-27.548
N320 X37.115 Z-29.312
N321 X36.156 Z-30.898
N322 X35.676 Z-31.638
N323 X34.839 Z-32.859
N324 X34.002 Z-33.989
N325 X33.166 Z-35.047
N326 X32.329 Z-36.043
N327 X31.408 Z-37.073
N328 X30.487 Z-38.035
N329 X29.566 Z-38.941
N330 X28.645 Z-39.796
N331 X27.77 Z-40.565
N332 X26.895 Z-41.292
N333 X26.02 Z-41.981
N334 X25.145 Z-42.634
N335 X24.233 Z-43.278
N336 X23.321 Z-43.886
N337 X22.41 Z-44.462
N338 X20.614 Z-45.507
N339 X18.845 Z-46.427
N340 X17.961 Z-46.848
N341 X16.151 Z-47.634
N342 X14.342 Z-48.323
N343 X12.559 Z-48.913
N344 X10.776 Z-49.418
N345 X8.958 Z-49.849
N346 X7.169 Z-50.192
N347 X5.362 Z-50.46
N348 X3.592 Z-50.648
N349 X1.797 Z-50.761
N350 X0. Z-50.8
N351 X-1.797 Z-50.761
N352 X-3.592 Z-50.648
N353 X-5.362 Z-50.46
N354 X-7.169 Z-50.192
N355 X-8.958 Z-49.849
N356 X-10.776 Z-49.418
N357 X-12.559 Z-48.913
N358 X-14.342 Z-48.323
N359 X-16.151 Z-47.634
N360 X-17.961 Z-46.848
N361 X-19.729 Z-45.98
N362 X-21.498 Z-45.007
N363 X-22.41 Z-44.462
N364 X-23.321 Z-43.886
N365 X-24.233 Z-43.278
N366 X-25.145 Z-42.634
N367 X-26.02 Z-41.981
N368 X-26.895 Z-41.292
N369 X-27.77 Z-40.565
N370 X-28.645 Z-39.796
N371 X-29.566 Z-38.941
N372 X-30.487 Z-38.035
N373 X-31.408 Z-37.073
N374 X-32.329 Z-36.043
N375 X-33.166 Z-35.047
N376 X-34.002 Z-33.989
N377 X-34.839 Z-32.859
N378 X-35.676 Z-31.638
N379 X-36.635 Z-30.125
N380 X-37.595 Z-28.455
N381 X-38.074 Z-27.548
N382 X-38.554 Z-26.583
N383 X-39.033 Z-25.551
N384 X-39.758 Z-23.846
N385 X-40.491 Z-21.866
N386 X-41.346 Z-19.058
N387 X-42.082 Z-15.789
N388 X-42.491 Z-13.112
N389 X-42.798 Z-9.751
N390 X-43.003 Z-8.619
N391 X-43.33 Z-7.496
N392 X-43.554 Z-6.91
N393 X-43.779 Z-6.401
N394 X-44.228 Z-5.547
N395 X-44.677 Z-4.839
N396 X-45.35 Z-3.958
N397 X-45.799 Z-3.463
N398 X-46.248 Z-3.013
N399 X-47.146 Z-2.258
N400 X-48.044 Z-1.646
N401 X-48.942 Z-1.151
N402 X-49.84 Z-.757
N403 X-50.289 Z-.596
N404 X-51.187 Z-.331
N405 X-52.085 Z-.146
N406 X-52.984 Z-.036
N407 X-53.882 Z0.
N408 Y115.775
N409 X-52.984 Z-.036
N410 X-52.085 Z-.146
N411 X-51.187 Z-.331
N412 X-50.289 Z-.596
N413 X-49.84 Z-.757
N414 X-48.942 Z-1.151
N415 X-48.044 Z-1.646
N416 X-47.146 Z-2.258
N417 X-46.248 Z-3.013
N418 X-45.799 Z-3.463
N419 X-45.35 Z-3.958
N420 X-44.677 Z-4.839
N421 X-44.228 Z-5.547
N422 X-43.779 Z-6.401
N423 X-43.554 Z-6.91
N424 X-43.33 Z-7.496
N425 X-43.003 Z-8.619
N426 X-42.798 Z-9.751
N427 X-42.491 Z-13.112
N428 X-42.082 Z-15.789
N429 X-41.346 Z-19.058
N430 X-40.491 Z-21.866
N431 X-39.758 Z-23.846
N432 X-39.033 Z-25.551
N433 X-38.554 Z-26.583
N434 X-38.074 Z-27.548
N435 X-37.595 Z-28.455
N436 X-36.635 Z-30.125
N437 X-35.676 Z-31.638
N438 X-34.839 Z-32.859
N439 X-34.002 Z-33.989
N440 X-33.166 Z-35.047
N441 X-32.329 Z-36.043
N442 X-31.408 Z-37.073
N443 X-30.487 Z-38.035
N444 X-29.566 Z-38.941
N445 X-28.645 Z-39.796
N446 X-27.77 Z-40.565
N447 X-26.895 Z-41.292
N448 X-26.02 Z-41.981
N449 X-25.145 Z-42.634
N450 X-24.233 Z-43.278
N451 X-23.321 Z-43.886
N452 X-22.41 Z-44.462
N453 X-21.498 Z-45.007
N454 X-19.729 Z-45.98
N455 X-17.961 Z-46.848
N456 X-16.151 Z-47.634
N457 X-14.342 Z-48.323
N458 X-12.559 Z-48.913
N459 X-10.776 Z-49.418
N460 X-8.958 Z-49.849
N461 X-7.169 Z-50.192
N462 X-5.362 Z-50.46
N463 X-3.592 Z-50.648
N464 X-1.797 Z-50.761
N465 X0. Z-50.8
N466 X1.797 Z-50.761
N467 X3.592 Z-50.648
N468 X5.362 Z-50.46
N469 X7.169 Z-50.192
N470 X8.958 Z-49.849
N471 X10.776 Z-49.418
N472 X12.559 Z-48.913
N473 X14.342 Z-48.323
N474 X16.151 Z-47.634
N475 X17.961 Z-46.848
N476 X18.845 Z-46.427
N477 X20.614 Z-45.507
N478 X22.41 Z-44.462
N479 X23.321 Z-43.886
N480 X24.233 Z-43.278
N481 X25.145 Z-42.634
N482 X26.02 Z-41.981
N483 X26.895 Z-41.292
N484 X27.77 Z-40.565
N485 X28.645 Z-39.796
N486 X29.566 Z-38.941
N487 X30.487 Z-38.035
N488 X31.408 Z-37.073
N489 X32.329 Z-36.043
N490 X33.166 Z-35.047
N491 X34.002 Z-33.989
N492 X34.839 Z-32.859
N493 X35.676 Z-31.638
N494 X36.156 Z-30.898
N495 X37.115 Z-29.312
N496 X38.074 Z-27.548
N497 X38.554 Z-26.583
N498 X39.033 Z-25.551
N499 X39.758 Z-23.846
N500 X40.491 Z-21.866
N501 X40.979 Z-20.339
N502 X41.57 Z-18.179
N503 X42.184 Z-15.229
N504 X42.44 Z-13.521
N505 X42.798 Z-9.751
N506 X42.952 Z-8.854
N507 X43.217 Z-7.838
N508 X43.554 Z-6.91
N509 X43.779 Z-6.401
N510 X44.228 Z-5.547
N511 X44.677 Z-4.839
N512 X45.35 Z-3.958
N513 X45.799 Z-3.463
N514 X46.248 Z-3.013
N515 X47.146 Z-2.258
N516 X48.044 Z-1.646
N517 X48.942 Z-1.151
N518 X49.391 Z-.945
N519 X50.289 Z-.596
N520 X51.187 Z-.331
N521 X52.085 Z-.146
N522 X52.984 Z-.036
N523 X53.882 Z0.
N524 Y114.575
N525 X52.984 Z-.036
N526 X52.085 Z-.146
N527 X51.187 Z-.331
N528 X50.289 Z-.596
N529 X49.391 Z-.945
N530 X48.942 Z-1.151
N531 X48.044 Z-1.646
N532 X47.146 Z-2.258
N533 X46.248 Z-3.013
N534 X45.799 Z-3.463
N535 X45.35 Z-3.958
N536 X44.677 Z-4.839
N537 X44.228 Z-5.547
N538 X43.779 Z-6.402
N539 X43.554 Z-6.91
N540 X43.217 Z-7.838
N541 X42.952 Z-8.854
N542 X42.798 Z-9.751
N543 X42.44 Z-13.521
N544 X42.184 Z-15.229
N545 X41.57 Z-18.179
N546 X40.979 Z-20.339
N547 X40.491 Z-21.866
N548 X39.758 Z-23.846
N549 X39.033 Z-25.551
N550 X38.554 Z-26.583
N551 X38.074 Z-27.548
N552 X37.115 Z-29.312
N553 X36.156 Z-30.898
N554 X35.676 Z-31.638
N555 X34.839 Z-32.859
N556 X34.002 Z-33.989
N557 X33.166 Z-35.047
N558 X32.329 Z-36.043
N559 X31.408 Z-37.073
N560 X30.487 Z-38.035
N561 X29.566 Z-38.941
N562 X28.645 Z-39.796
N563 X27.77 Z-40.565
N564 X26.895 Z-41.292
N565 X26.02 Z-41.981
N566 X25.145 Z-42.634
N567 X24.233 Z-43.278
N568 X23.321 Z-43.886
N569 X22.41 Z-44.462
N570 X20.614 Z-45.507
N571 X18.845 Z-46.427
N572 X17.961 Z-46.848
N573 X16.151 Z-47.634
N574 X14.342 Z-48.323
N575 X12.559 Z-48.913
N576 X10.776 Z-49.418
N577 X8.958 Z-49.849
N578 X7.169 Z-50.192
N579 X5.362 Z-50.46
N580 X3.592 Z-50.648
N581 X1.797 Z-50.761
N582 X0. Z-50.8
N583 X-1.797 Z-50.761
N584 X-3.592 Z-50.648
N585 X-5.362 Z-50.46
N586 X-7.169 Z-50.192
N587 X-8.958 Z-49.849
N588 X-10.776 Z-49.418
N589 X-12.559 Z-48.913
N590 X-14.342 Z-48.323
N591 X-16.151 Z-47.634
N592 X-17.961 Z-46.848
N593 X-19.729 Z-45.98
N594 X-21.498 Z-45.007
N595 X-22.41 Z-44.462
N596 X-23.321 Z-43.886
N597 X-24.233 Z-43.278
N598 X-25.145 Z-42.634
N599 X-26.02 Z-41.981
N600 X-26.895 Z-41.292
N601 X-27.77 Z-40.565
N602 X-28.645 Z-39.796
N603 X-29.566 Z-38.941
N604 X-30.487 Z-38.035
N605 X-31.408 Z-37.073
N606 X-32.329 Z-36.043
N607 X-33.166 Z-35.047
N608 X-34.002 Z-33.989
N609 X-34.839 Z-32.859
N610 X-35.676 Z-31.638
N611 X-36.635 Z-30.125
N612 X-37.595 Z-28.455
N613 X-38.074 Z-27.548
N614 X-38.554 Z-26.583
N615 X-39.033 Z-25.551
N616 X-39.758 Z-23.846
N617 X-40.491 Z-21.866
N618 X-41.346 Z-19.058
N619 X-42.082 Z-15.789
N620 X-42.491 Z-13.112
N621 X-42.798 Z-9.751
N622 X-43.003 Z-8.619
N623 X-43.33 Z-7.496
N624 X-43.554 Z-6.91
N625 X-43.779 Z-6.402
N626 X-44.228 Z-5.547
N627 X-44.677 Z-4.839
N628 X-45.35 Z-3.958
N629 X-45.799 Z-3.463
N630 X-46.248 Z-3.013
N631 X-47.146 Z-2.258
N632 X-48.044 Z-1.646
N633 X-48.942 Z-1.151
N634 X-49.84 Z-.757
N635 X-50.289 Z-.596
N636 X-51.187 Z-.331
N637 X-52.085 Z-.146
N638 X-52.984 Z-.036
N639 X-53.882 Z0.
N640 Y113.375
N641 X-52.984 Z-.036
N642 X-52.085 Z-.146
N643 X-51.187 Z-.331
N644 X-50.289 Z-.595
N645 X-49.84 Z-.757
N646 X-48.942 Z-1.151
N647 X-48.044 Z-1.646
N648 X-47.146 Z-2.258
N649 X-46.248 Z-3.013
N650 X-45.799 Z-3.463
N651 X-45.35 Z-3.958
N652 X-44.677 Z-4.839
N653 X-44.228 Z-5.547
N654 X-43.779 Z-6.402
N655 X-43.554 Z-6.91
N656 X-43.33 Z-7.496
N657 X-43.003 Z-8.619
N658 X-42.798 Z-9.751
N659 X-42.491 Z-13.112
N660 X-42.082 Z-15.789
N661 X-41.346 Z-19.058
N662 X-40.491 Z-21.866
N663 X-39.758 Z-23.846
N664 X-39.033 Z-25.551
N665 X-38.554 Z-26.583
N666 X-38.074 Z-27.548
N667 X-37.595 Z-28.455
N668 X-36.635 Z-30.125
N669 X-35.676 Z-31.638
N670 X-34.839 Z-32.859
N671 X-34.002 Z-33.989
N672 X-33.166 Z-35.047
N673 X-32.329 Z-36.043
N674 X-31.408 Z-37.073
N675 X-30.487 Z-38.035
N676 X-29.566 Z-38.941
N677 X-28.645 Z-39.796
N678 X-27.77 Z-40.565
N679 X-26.895 Z-41.292
N680 X-26.02 Z-41.981
N681 X-25.145 Z-42.634
N682 X-24.233 Z-43.278
N683 X-23.321 Z-43.886
N684 X-22.41 Z-44.462
N685 X-21.498 Z-45.007
N686 X-19.729 Z-45.98
N687 X-17.961 Z-46.848
N688 X-16.151 Z-47.634
N689 X-14.342 Z-48.323
N690 X-12.559 Z-48.913
N691 X-10.776 Z-49.418
N692 X-8.958 Z-49.849
N693 X-7.169 Z-50.192
N694 X-5.362 Z-50.46
N695 X-3.592 Z-50.648
N696 X-1.797 Z-50.761
N697 X0. Z-50.8
N698 X1.797 Z-50.761
N699 X3.592 Z-50.648
N700 X5.362 Z-50.46
N701 X7.169 Z-50.192
N702 X8.958 Z-49.849
N703 X10.776 Z-49.418
N704 X12.559 Z-48.913
N705 X14.342 Z-48.323
N706 X16.151 Z-47.634
N707 X17.961 Z-46.848
N708 X18.845 Z-46.427
N709 X20.614 Z-45.507
N710 X22.41 Z-44.462
N711 X23.321 Z-43.886
N712 X24.233 Z-43.278
N713 X25.145 Z-42.634
N714 X26.02 Z-41.981
N715 X26.895 Z-41.292
N716 X27.77 Z-40.565
N717 X28.645 Z-39.796
N718 X29.566 Z-38.941
N719 X30.487 Z-38.035
N720 X31.408 Z-37.073
N721 X32.329 Z-36.043
N722 X33.166 Z-35.047
N723 X34.002 Z-33.989
N724 X34.839 Z-32.859
N725 X35.676 Z-31.638
N726 X36.156 Z-30.898
N727 X37.115 Z-29.312
N728 X38.074 Z-27.548
N729 X38.554 Z-26.583
N730 X39.033 Z-25.551
N731 X39.758 Z-23.846
N732 X40.491 Z-21.866
N733 X40.979 Z-20.339
N734 X41.57 Z-18.179
N735 X42.184 Z-15.229
N736 X42.44 Z-13.521
N737 X42.798 Z-9.751
N738 X42.952 Z-8.854
N739 X43.217 Z-7.838
N740 X43.554 Z-6.91
N741 X43.779 Z-6.402
N742 X44.228 Z-5.547
N743 X44.677 Z-4.839
N744 X45.35 Z-3.958
N745 X45.799 Z-3.463
N746 X46.248 Z-3.013
N747 X47.146 Z-2.258
N748 X48.044 Z-1.646
N749 X48.942 Z-1.151
N750 X49.391 Z-.945
N751 X50.289 Z-.595
N752 X51.187 Z-.331
N753 X52.085 Z-.146
N754 X52.984 Z-.036
N755 X53.882 Z0.
N756 Y112.175
N757 X52.984 Z-.036
N758 X52.085 Z-.146
N759 X51.187 Z-.331
N760 X50.289 Z-.595
N761 X49.391 Z-.945
N762 X48.942 Z-1.151
N763 X48.044 Z-1.646
N764 X47.146 Z-2.258
N765 X46.248 Z-3.013
N766 X45.799 Z-3.463
N767 X45.35 Z-3.958
N768 X44.677 Z-4.839
N769 X44.228 Z-5.547
N770 X43.779 Z-6.402
N771 X43.554 Z-6.91
N772 X43.217 Z-7.838
N773 X42.952 Z-8.854
N774 X42.798 Z-9.75
N775 X42.44 Z-13.521
N776 X42.184 Z-15.229
N777 X41.57 Z-18.178
N778 X40.979 Z-20.339
N779 X40.491 Z-21.866
N780 X39.758 Z-23.846
N781 X39.033 Z-25.551
N782 X38.554 Z-26.583
N783 X38.074 Z-27.548
N784 X37.115 Z-29.312
N785 X36.156 Z-30.898
N786 X35.676 Z-31.638
N787 X34.839 Z-32.859
N788 X34.002 Z-33.989
N789 X33.166 Z-35.047
N790 X32.329 Z-36.043
N791 X31.408 Z-37.073
N792 X30.487 Z-38.035
N793 X29.566 Z-38.941
N794 X28.645 Z-39.796
N795 X27.77 Z-40.565
N796 X26.895 Z-41.292
N797 X26.02 Z-41.981
N798 X25.145 Z-42.634
N799 X24.233 Z-43.278
N800 X23.321 Z-43.886
N801 X22.41 Z-44.462
N802 X20.614 Z-45.507
N803 X18.845 Z-46.427
N804 X17.961 Z-46.848
N805 X16.151 Z-47.634
N806 X14.342 Z-48.323
N807 X12.559 Z-48.913
N808 X10.776 Z-49.418
N809 X8.958 Z-49.849
N810 X7.169 Z-50.192
N811 X5.362 Z-50.46
N812 X3.592 Z-50.648
N813 X1.797 Z-50.761
N814 X0. Z-50.8
N815 X-1.797 Z-50.761
N816 X-3.592 Z-50.648
N817 X-5.362 Z-50.46
N818 X-7.169 Z-50.192
N819 X-8.958 Z-49.849
N820 X-10.776 Z-49.418
N821 X-12.559 Z-48.913
N822 X-14.342 Z-48.323
N823 X-16.151 Z-47.634
N824 X-17.961 Z-46.848
N825 X-19.729 Z-45.98
N826 X-21.498 Z-45.007
N827 X-22.41 Z-44.462
N828 X-23.321 Z-43.886
N829 X-24.233 Z-43.278
N830 X-25.145 Z-42.634
N831 X-26.02 Z-41.981
N832 X-26.895 Z-41.292
N833 X-27.77 Z-40.565
N834 X-28.645 Z-39.796
N835 X-29.566 Z-38.941
N836 X-30.487 Z-38.035
N837 X-31.408 Z-37.073
N838 X-32.329 Z-36.043
N839 X-33.166 Z-35.047
N840 X-34.002 Z-33.989
N841 X-34.839 Z-32.859
N842 X-35.676 Z-31.638
N843 X-36.635 Z-30.125
N844 X-37.595 Z-28.455
N845 X-38.074 Z-27.548
N846 X-38.554 Z-26.583
N847 X-39.033 Z-25.551
N848 X-39.758 Z-23.846
N849 X-40.491 Z-21.866
N850 X-41.346 Z-19.058
N851 X-42.082 Z-15.789
N852 X-42.491 Z-13.112
N853 X-42.798 Z-9.75
N854 X-43.003 Z-8.619
N855 X-43.33 Z-7.496
N856 X-43.554 Z-6.91
N857 X-43.779 Z-6.402
N858 X-44.228 Z-5.547
N859 X-44.677 Z-4.839
N860 X-45.35 Z-3.958
N861 X-45.799 Z-3.463
N862 X-46.248 Z-3.013
N863 X-47.146 Z-2.258
N864 X-48.044 Z-1.646
N865 X-48.942 Z-1.151
N866 X-49.84 Z-.757
N867 X-50.289 Z-.595
N868 X-51.187 Z-.331
N869 X-52.085 Z-.146
N870 X-52.984 Z-.036
N871 X-53.882 Z0.
N872 Y110.975
N873 X-52.984 Z-.036
N874 X-52.085 Z-.146
N875 X-51.187 Z-.331
N876 X-50.289 Z-.595
N877 X-49.84 Z-.757
N878 X-48.942 Z-1.151
N879 X-48.044 Z-1.646
N880 X-47.146 Z-2.258
N881 X-46.697 Z-2.619
N882 X-46.248 Z-3.013
N883 X-45.799 Z-3.463
N884 X-45.35 Z-3.958
N885 X-44.677 Z-4.839
N886 X-44.228 Z-5.547
N887 X-43.779 Z-6.402
N888 X-43.554 Z-6.91
N889 X-43.33 Z-7.496
N890 X-43.003 Z-8.619
N891 X-42.798 Z-9.75
N892 X-42.491 Z-13.112
N893 X-42.082 Z-15.789
N894 X-41.346 Z-19.058
N895 X-40.491 Z-21.866
N896 X-39.758 Z-23.846
N897 X-39.033 Z-25.551
N898 X-38.554 Z-26.583
N899 X-38.074 Z-27.548
N900 X-37.595 Z-28.455
N901 X-36.635 Z-30.125
N902 X-35.676 Z-31.638
N903 X-34.839 Z-32.859
N904 X-34.002 Z-33.989
N905 X-33.166 Z-35.047
N906 X-32.329 Z-36.043
N907 X-31.408 Z-37.073
N908 X-30.487 Z-38.035
N909 X-29.566 Z-38.941
N910 X-28.645 Z-39.796
N911 X-27.77 Z-40.565
N912 X-26.895 Z-41.292
N913 X-26.02 Z-41.981
N914 X-25.145 Z-42.634
N915 X-24.233 Z-43.278
N916 X-23.321 Z-43.886
N917 X-22.41 Z-44.462
N918 X-21.498 Z-45.007
N919 X-19.729 Z-45.98
N920 X-17.961 Z-46.848
N921 X-16.151 Z-47.634
N922 X-14.342 Z-48.323
N923 X-12.559 Z-48.913
N924 X-10.776 Z-49.418
N925 X-8.958 Z-49.849
N926 X-7.169 Z-50.192
N927 X-5.362 Z-50.46
N928 X-3.592 Z-50.648
N929 X-1.797 Z-50.761
N930 X0. Z-50.8
N931 X1.797 Z-50.761
N932 X3.592 Z-50.648
N933 X5.362 Z-50.46
N934 X7.169 Z-50.192
N935 X8.958 Z-49.849
N936 X10.776 Z-49.418
N937 X12.559 Z-48.913
N938 X14.342 Z-48.323
N939 X16.151 Z-47.634
N940 X17.961 Z-46.848
N941 X18.845 Z-46.427
N942 X20.614 Z-45.507
N943 X22.41 Z-44.462
N944 X23.321 Z-43.886
N945 X24.233 Z-43.278
N946 X25.145 Z-42.634
N947 X26.02 Z-41.981
N948 X26.895 Z-41.292
N949 X27.77 Z-40.565
N950 X28.645 Z-39.796
N951 X29.566 Z-38.941
N952 X30.487 Z-38.035
N953 X31.408 Z-37.073
N954 X32.329 Z-36.043
N955 X33.166 Z-35.047
N956 X34.002 Z-33.989
N957 X34.839 Z-32.859
N958 X35.676 Z-31.638
N959 X36.156 Z-30.898
N960 X37.115 Z-29.312
N961 X38.074 Z-27.548
N962 X38.554 Z-26.583
N963 X39.033 Z-25.551
N964 X39.758 Z-23.846
N965 X40.491 Z-21.866
N966 X40.979 Z-20.339
N967 X41.57 Z-18.178
N968 X42.184 Z-15.229
N969 X42.44 Z-13.521
N970 X42.798 Z-9.75
N971 X42.952 Z-8.854
N972 X43.217 Z-7.838
N973 X43.554 Z-6.91
N974 X43.779 Z-6.402
N975 X44.228 Z-5.547
N976 X44.677 Z-4.839
N977 X45.35 Z-3.958
N978 X45.799 Z-3.463
N979 X46.248 Z-3.013
N980 X47.146 Z-2.258
N981 X48.044 Z-1.646
N982 X48.942 Z-1.151
N983 X49.391 Z-.945
N984 X50.289 Z-.595
N985 X51.187 Z-.331
N986 X52.085 Z-.146
N987 X52.984 Z-.036
N988 X53.882 Z0.
N989 Y109.775
N990 X52.984 Z-.036
N991 X52.085 Z-.146
N992 X51.187 Z-.331
N993 X50.289 Z-.595
N994 X49.391 Z-.945
N995 X48.942 Z-1.151
N996 X48.044 Z-1.646
N997 X47.146 Z-2.258
N998 X46.697 Z-2.619
N999 X46.248 Z-3.013
N1000 X45.799 Z-3.463
N1001 X45.35 Z-3.958
N1002 X44.677 Z-4.839
N1003 X44.228 Z-5.547
N1004 X43.779 Z-6.402
N1005 X43.554 Z-6.91
N1006 X43.217 Z-7.838
N1007 X42.952 Z-8.854
N1008 X42.798 Z-9.75
N1009 X42.44 Z-13.521
N1010 X42.184 Z-15.229
N1011 X41.57 Z-18.178
N1012 X40.979 Z-20.339
N1013 X40.491 Z-21.866
N1014 X39.758 Z-23.846
N1015 X39.033 Z-25.551
N1016 X38.554 Z-26.583
N1017 X38.074 Z-27.548
N1018 X37.115 Z-29.312
N1019 X36.156 Z-30.898
N1020 X35.676 Z-31.638
N1021 X34.839 Z-32.859
N1022 X34.002 Z-33.989
N1023 X33.166 Z-35.047
N1024 X32.329 Z-36.043
N1025 X31.408 Z-37.073
N1026 X30.487 Z-38.035
N1027 X29.566 Z-38.941
N1028 X28.645 Z-39.796
N1029 X27.77 Z-40.565
N1030 X26.895 Z-41.292
N1031 X26.02 Z-41.981
N1032 X25.145 Z-42.634
N1033 X24.233 Z-43.278
N1034 X23.321 Z-43.886
N1035 X22.41 Z-44.462
N1036 X20.614 Z-45.507
N1037 X18.845 Z-46.427
N1038 X17.961 Z-46.848
N1039 X16.151 Z-47.634
N1040 X14.342 Z-48.323
N1041 X12.559 Z-48.913
N1042 X10.776 Z-49.418
N1043 X8.958 Z-49.849
N1044 X7.169 Z-50.192
N1045 X5.362 Z-50.46
N1046 X3.592 Z-50.648
N1047 X1.797 Z-50.761
N1048 X0. Z-50.8
N1049 X-1.797 Z-50.761
N1050 X-3.592 Z-50.648
N1051 X-5.362 Z-50.46
N1052 X-7.169 Z-50.192
N1053 X-8.958 Z-49.849
N1054 X-10.776 Z-49.418
N1055 X-12.559 Z-48.913
N1056 X-14.342 Z-48.323
N1057 X-16.151 Z-47.634
N1058 X-17.961 Z-46.848
N1059 X-19.729 Z-45.98
N1060 X-21.498 Z-45.007
N1061 X-22.41 Z-44.462
N1062 X-23.321 Z-43.886
N1063 X-24.233 Z-43.278
N1064 X-25.145 Z-42.634
N1065 X-26.02 Z-41.981
N1066 X-26.895 Z-41.292
N1067 X-27.77 Z-40.565
N1068 X-28.645 Z-39.796
N1069 X-29.566 Z-38.941
N1070 X-30.487 Z-38.035
N1071 X-31.408 Z-37.073
N1072 X-32.329 Z-36.043
N1073 X-33.166 Z-35.047
N1074 X-34.002 Z-33.989
N1075 X-34.839 Z-32.859
N1076 X-35.676 Z-31.638
N1077 X-36.635 Z-30.125
N1078 X-37.595 Z-28.455
N1079 X-38.074 Z-27.548
N1080 X-38.554 Z-26.583
N1081 X-39.033 Z-25.551
N1082 X-39.758 Z-23.846
N1083 X-40.491 Z-21.866
N1084 X-41.346 Z-19.058
N1085 X-42.082 Z-15.789
N1086 X-42.491 Z-13.112
N1087 X-42.798 Z-9.75
N1088 X-43.003 Z-8.619
N1089 X-43.33 Z-7.496
N1090 X-43.554 Z-6.91
N1091 X-43.779 Z-6.402
N1092 X-44.228 Z-5.547
N1093 X-44.677 Z-4.839
N1094 X-45.35 Z-3.958
N1095 X-45.799 Z-3.463
N1096 X-46.248 Z-3.013
N1097 X-46.697 Z-2.619
N1098 X-47.146 Z-2.258
N1099 X-48.044 Z-1.647
N1100 X-48.942 Z-1.152
N1101 X-49.84 Z-.757
N1102 X-50.289 Z-.595
N1103 X-51.187 Z-.331
N1104 X-52.085 Z-.146
N1105 X-52.984 Z-.036
N1106 X-53.882 Z0.
N1107 Y108.575
N1108 X-52.984 Z-.036
N1109 X-52.085 Z-.146
N1110 X-51.187 Z-.331
N1111 X-50.289 Z-.595
N1112 X-49.84 Z-.757
N1113 X-48.942 Z-1.152
N1114 X-48.044 Z-1.647
N1115 X-47.146 Z-2.258
N1116 X-46.697 Z-2.619
N1117 X-46.248 Z-3.013
N1118 X-45.799 Z-3.463
N1119 X-45.35 Z-3.958
N1120 X-44.677 Z-4.839
N1121 X-44.228 Z-5.547
N1122 X-43.779 Z-6.402
N1123 X-43.554 Z-6.91
N1124 X-43.33 Z-7.496
N1125 X-43.003 Z-8.619
N1126 X-42.798 Z-9.75
N1127 X-42.491 Z-13.112
N1128 X-42.082 Z-15.789
N1129 X-41.346 Z-19.058
N1130 X-40.491 Z-21.866
N1131 X-39.758 Z-23.846
N1132 X-39.033 Z-25.551
N1133 X-38.554 Z-26.583
N1134 X-38.074 Z-27.548
N1135 X-37.595 Z-28.455
N1136 X-36.635 Z-30.125
N1137 X-35.676 Z-31.638
N1138 X-34.839 Z-32.859
N1139 X-34.002 Z-33.989
N1140 X-33.166 Z-35.047
N1141 X-32.329 Z-36.043
N1142 X-31.408 Z-37.073
N1143 X-30.487 Z-38.035
N1144 X-29.566 Z-38.941
N1145 X-28.645 Z-39.796
N1146 X-27.77 Z-40.565
N1147 X-26.895 Z-41.292
N1148 X-26.02 Z-41.981
N1149 X-25.145 Z-42.634
N1150 X-24.233 Z-43.278
N1151 X-23.321 Z-43.886
N1152 X-22.41 Z-44.462
N1153 X-21.498 Z-45.007
N1154 X-19.729 Z-45.98
N1155 X-17.961 Z-46.848
N1156 X-16.151 Z-47.634
N1157 X-14.342 Z-48.323
N1158 X-12.559 Z-48.913
N1159 X-10.776 Z-49.418
N1160 X-8.958 Z-49.849
N1161 X-7.169 Z-50.192
N1162 X-5.362 Z-50.46
N1163 X-3.592 Z-50.648
N1164 X-1.797 Z-50.761
N1165 X0. Z-50.8
N1166 X1.797 Z-50.761
N1167 X3.592 Z-50.648
N1168 X5.362 Z-50.46
N1169 X7.169 Z-50.192
N1170 X8.958 Z-49.849
N1171 X10.776 Z-49.418
N1172 X12.559 Z-48.913
N1173 X14.342 Z-48.323
N1174 X16.151 Z-47.634
N1175 X17.961 Z-46.848
N1176 X18.845 Z-46.427
N1177 X20.614 Z-45.507
N1178 X22.41 Z-44.462
N1179 X23.321 Z-43.886
N1180 X24.233 Z-43.278
N1181 X25.145 Z-42.634
N1182 X26.02 Z-41.981
N1183 X26.895 Z-41.292
N1184 X27.77 Z-40.565
N1185 X28.645 Z-39.796
N1186 X29.566 Z-38.941
N1187 X30.487 Z-38.035
N1188 X31.408 Z-37.073
N1189 X32.329 Z-36.043
N1190 X33.166 Z-35.047
N1191 X34.002 Z-33.989
N1192 X34.839 Z-32.859
N1193 X35.676 Z-31.638
N1194 X36.156 Z-30.898
N1195 X37.115 Z-29.312
N1196 X38.074 Z-27.548
N1197 X38.554 Z-26.583
N1198 X39.033 Z-25.551
N1199 X39.758 Z-23.846
N1200 X40.491 Z-21.866
N1201 X40.979 Z-20.339
N1202 X41.57 Z-18.178
N1203 X42.184 Z-15.229
N1204 X42.44 Z-13.521
N1205 X42.798 Z-9.75
N1206 X42.952 Z-8.854
N1207 X43.217 Z-7.838
N1208 X43.554 Z-6.91
N1209 X43.779 Z-6.402
N1210 X44.228 Z-5.547
N1211 X44.677 Z-4.839
N1212 X45.35 Z-3.958
N1213 X45.799 Z-3.463
N1214 X46.248 Z-3.013
N1215 X46.697 Z-2.619
N1216 X47.146 Z-2.258
N1217 X48.044 Z-1.647
N1218 X48.942 Z-1.152
N1219 X49.391 Z-.945
N1220 X50.289 Z-.595
N1221 X51.187 Z-.331
N1222 X52.085 Z-.146
N1223 X52.984 Z-.036
N1224 X53.882 Z0.
N1225 Y107.375
N1226 X52.984 Z-.036
N1227 X52.085 Z-.146
N1228 X51.187 Z-.331
N1229 X50.289 Z-.595
N1230 X49.391 Z-.945
N1231 X48.942 Z-1.152
N1232 X48.044 Z-1.647
N1233 X47.146 Z-2.258
N1234 X46.697 Z-2.619
N1235 X46.248 Z-3.013
N1236 X45.799 Z-3.463
N1237 X45.35 Z-3.958
N1238 X44.677 Z-4.839
N1239 X44.228 Z-5.547
N1240 X43.779 Z-6.402
N1241 X43.554 Z-6.91
N1242 X43.217 Z-7.838
N1243 X42.952 Z-8.853
N1244 X42.773 Z-9.981
N1245 X42.44 Z-13.521
N1246 X42.184 Z-15.229
N1247 X41.571 Z-18.178
N1248 X40.979 Z-20.339
N1249 X40.491 Z-21.866
N1250 X39.758 Z-23.846
N1251 X39.033 Z-25.551
N1252 X38.554 Z-26.583
N1253 X38.074 Z-27.548
N1254 X37.115 Z-29.312
N1255 X36.156 Z-30.898
N1256 X35.676 Z-31.638
N1257 X34.839 Z-32.859
N1258 X34.002 Z-33.989
N1259 X33.166 Z-35.047
N1260 X32.329 Z-36.043
N1261 X31.408 Z-37.073
N1262 X30.487 Z-38.035
N1263 X29.566 Z-38.941
N1264 X28.645 Z-39.796
N1265 X27.77 Z-40.565
N1266 X26.895 Z-41.292
N1267 X26.02 Z-41.981
N1268 X25.145 Z-42.634
N1269 X24.233 Z-43.278
N1270 X23.321 Z-43.886
N1271 X22.41 Z-44.462
N1272 X20.614 Z-45.507
N1273 X18.845 Z-46.427
N1274 X17.961 Z-46.848
N1275 X16.151 Z-47.634
N1276 X14.342 Z-48.323
N1277 X12.559 Z-48.913
N1278 X10.776 Z-49.418
N1279 X8.958 Z-49.849
N1280 X7.169 Z-50.192
N1281 X5.362 Z-50.46
N1282 X3.592 Z-50.648
N1283 X1.797 Z-50.761
N1284 X0. Z-50.8
N1285 X-1.797 Z-50.761
N1286 X-3.592 Z-50.648
N1287 X-5.362 Z-50.46
N1288 X-7.169 Z-50.192
N1289 X-8.958 Z-49.849
N1290 X-10.776 Z-49.418
N1291 X-12.559 Z-48.913
N1292 X-14.342 Z-48.323
N1293 X-16.151 Z-47.634
N1294 X-17.961 Z-46.848
N1295 X-19.729 Z-45.98
N1296 X-21.498 Z-45.007
N1297 X-22.41 Z-44.462
N1298 X-23.321 Z-43.886
N1299 X-24.233 Z-43.278
N1300 X-25.145 Z-42.634
N1301 X-26.02 Z-41.981
N1302 X-26.895 Z-41.292
N1303 X-27.77 Z-40.565
N1304 X-28.645 Z-39.796
N1305 X-29.566 Z-38.941
N1306 X-30.487 Z-38.035
N1307 X-31.408 Z-37.073
N1308 X-32.329 Z-36.043
N1309 X-33.166 Z-35.047
N1310 X-34.002 Z-33.989
N1311 X-34.839 Z-32.859
N1312 X-35.676 Z-31.638
N1313 X-36.635 Z-30.125
N1314 X-37.595 Z-28.455
N1315 X-38.074 Z-27.548
N1316 X-38.554 Z-26.583
N1317 X-39.513 Z-24.44
N1318 X-40.246 Z-22.554
N1319 X-40.735 Z-21.126
N1320 X-41.346 Z-19.058
N1321 X-41.98 Z-16.329
N1322 X-42.491 Z-13.111
N1323 X-42.798 Z-9.75
N1324 X-43.003 Z-8.619
N1325 X-43.33 Z-7.496
N1326 X-43.554 Z-6.91
N1327 X-44.003 Z-5.954
N1328 X-44.452 Z-5.184
N1329 X-44.901 Z-4.526
N1330 X-45.35 Z-3.958
N1331 X-45.799 Z-3.462
N1332 X-46.248 Z-3.013
N1333 X-46.697 Z-2.619
N1334 X-47.146 Z-2.259
N1335 X-48.044 Z-1.647
N1336 X-48.942 Z-1.152
N1337 X-49.84 Z-.757
N1338 X-50.289 Z-.595
N1339 X-51.187 Z-.331
N1340 X-52.085 Z-.146
N1341 X-52.984 Z-.036
N1342 X-53.882 Z0.
N1343 Y106.175
N1344 X-52.984 Z-.036
N1345 X-52.085 Z-.146
N1346 X-51.187 Z-.331
N1347 X-50.289 Z-.595
N1348 X-49.84 Z-.757
N1349 X-48.942 Z-1.152
N1350 X-48.044 Z-1.647
N1351 X-47.146 Z-2.259
N1352 X-46.697 Z-2.619
N1353 X-46.248 Z-3.013
N1354 X-45.799 Z-3.462
N1355 X-45.35 Z-3.958
N1356 X-44.901 Z-4.526
N1357 X-44.452 Z-5.184
N1358 X-44.003 Z-5.954
N1359 X-43.554 Z-6.91
N1360 X-43.33 Z-7.496
N1361 X-43.003 Z-8.619
N1362 X-42.798 Z-9.75
N1363 X-42.491 Z-13.111
N1364 X-42.082 Z-15.789
N1365 X-41.346 Z-19.058
N1366 X-40.491 Z-21.866
N1367 X-39.758 Z-23.846
N1368 X-39.033 Z-25.551
N1369 X-38.554 Z-26.583
N1370 X-38.074 Z-27.548
N1371 X-37.595 Z-28.455
N1372 X-36.635 Z-30.125
N1373 X-35.676 Z-31.638
N1374 X-34.839 Z-32.859
N1375 X-34.002 Z-33.989
N1376 X-33.166 Z-35.047
N1377 X-32.329 Z-36.043
N1378 X-31.408 Z-37.073
N1379 X-30.487 Z-38.035
N1380 X-29.566 Z-38.941
N1381 X-28.645 Z-39.796
N1382 X-27.77 Z-40.565
N1383 X-26.895 Z-41.292
N1384 X-26.02 Z-41.981
N1385 X-25.145 Z-42.634
N1386 X-24.233 Z-43.278
N1387 X-23.321 Z-43.886
N1388 X-22.41 Z-44.462
N1389 X-21.498 Z-45.007
N1390 X-19.729 Z-45.98
N1391 X-17.961 Z-46.848
N1392 X-16.151 Z-47.634
N1393 X-14.342 Z-48.323
N1394 X-12.559 Z-48.913
N1395 X-10.776 Z-49.418
N1396 X-8.958 Z-49.849
N1397 X-7.169 Z-50.192
N1398 X-5.362 Z-50.46
N1399 X-3.592 Z-50.648
N1400 X-1.797 Z-50.761
N1401 X0. Z-50.8
N1402 X1.797 Z-50.761
N1403 X3.592 Z-50.648
N1404 X5.362 Z-50.46
N1405 X7.169 Z-50.192
N1406 X8.958 Z-49.849
N1407 X10.776 Z-49.418
N1408 X12.559 Z-48.913
N1409 X14.342 Z-48.323
N1410 X16.151 Z-47.634
N1411 X17.961 Z-46.848
N1412 X18.845 Z-46.427
N1413 X20.614 Z-45.507
N1414 X22.41 Z-44.462
N1415 X23.321 Z-43.886
N1416 X24.233 Z-43.278
N1417 X25.145 Z-42.634
N1418 X26.02 Z-41.981
N1419 X26.895 Z-41.292
N1420 X27.77 Z-40.565
N1421 X28.645 Z-39.796
N1422 X29.566 Z-38.941
N1423 X30.487 Z-38.035
N1424 X31.408 Z-37.073
N1425 X32.329 Z-36.043
N1426 X33.166 Z-35.047
N1427 X34.002 Z-33.989
N1428 X34.839 Z-32.859
N1429 X35.676 Z-31.638
N1430 X36.156 Z-30.898
N1431 X37.115 Z-29.312
N1432 X38.074 Z-27.548
N1433 X38.554 Z-26.583
N1434 X39.033 Z-25.551
N1435 X39.758 Z-23.846
N1436 X40.491 Z-21.866
N1437 X40.979 Z-20.339
N1438 X41.571 Z-18.178
N1439 X42.184 Z-15.229
N1440 X42.44 Z-13.521
N1441 X42.773 Z-9.981
N1442 X42.952 Z-8.853
N1443 X43.217 Z-7.838
N1444 X43.554 Z-6.91
N1445 X43.779 Z-6.402
N1446 X44.228 Z-5.547
N1447 X44.677 Z-4.839
N1448 X45.35 Z-3.958
N1449 X45.799 Z-3.462
N1450 X46.248 Z-3.013
N1451 X46.697 Z-2.619
N1452 X47.146 Z-2.258
N1453 X48.044 Z-1.647
N1454 X48.942 Z-1.152
N1455 X49.391 Z-.945
N1456 X50.289 Z-.595
N1457 X51.187 Z-.331
N1458 X52.085 Z-.146
N1459 X52.984 Z-.036
N1460 X53.882 Z0.
N1461 Y104.975
N1462 X52.984 Z-.036
N1463 X52.085 Z-.146
N1464 X51.187 Z-.331
N1465 X50.289 Z-.595
N1466 X49.391 Z-.945
N1467 X48.942 Z-1.152
N1468 X48.044 Z-1.647
N1469 X47.146 Z-2.259
N1470 X46.697 Z-2.619
N1471 X46.248 Z-3.013
N1472 X45.799 Z-3.462
N1473 X45.35 Z-3.958
N1474 X44.677 Z-4.839
N1475 X44.228 Z-5.547
N1476 X43.779 Z-6.402
N1477 X43.554 Z-6.909
N1478 X43.217 Z-7.838
N1479 X43.003 Z-8.619
N1480 X42.798 Z-9.75
N1481 X42.44 Z-13.521
N1482 X42.184 Z-15.229
N1483 X41.571 Z-18.178
N1484 X40.979 Z-20.339
N1485 X40.491 Z-21.866
N1486 X39.758 Z-23.846
N1487 X39.033 Z-25.551
N1488 X38.554 Z-26.583
N1489 X38.074 Z-27.548
N1490 X37.115 Z-29.312
N1491 X36.156 Z-30.898
N1492 X35.676 Z-31.638
N1493 X34.839 Z-32.859
N1494 X34.002 Z-33.989
N1495 X33.166 Z-35.047
N1496 X32.329 Z-36.043
N1497 X31.408 Z-37.073
N1498 X30.487 Z-38.035
N1499 X29.566 Z-38.941
N1500 X28.645 Z-39.796
N1501 X27.77 Z-40.565
N1502 X26.895 Z-41.292
N1503 X26.02 Z-41.981
N1504 X25.145 Z-42.634
N1505 X24.233 Z-43.278
N1506 X23.321 Z-43.886
N1507 X22.41 Z-44.462
N1508 X20.614 Z-45.507
N1509 X18.845 Z-46.427
N1510 X17.961 Z-46.848
N1511 X16.151 Z-47.634
N1512 X14.342 Z-48.323
N1513 X12.559 Z-48.913
N1514 X10.776 Z-49.418
N1515 X8.958 Z-49.849
N1516 X7.169 Z-50.192
N1517 X5.362 Z-50.46
N1518 X3.592 Z-50.648
N1519 X1.797 Z-50.761
N1520 X0. Z-50.8
N1521 X-1.797 Z-50.761
N1522 X-3.592 Z-50.648
N1523 X-5.362 Z-50.46
N1524 X-7.169 Z-50.192
N1525 X-8.958 Z-49.849
N1526 X-10.776 Z-49.418
N1527 X-12.559 Z-48.913
N1528 X-14.342 Z-48.323
N1529 X-16.151 Z-47.634
N1530 X-17.961 Z-46.848
N1531 X-19.729 Z-45.98
N1532 X-21.498 Z-45.007
N1533 X-22.41 Z-44.462
N1534 X-23.321 Z-43.886
N1535 X-24.233 Z-43.278
N1536 X-25.145 Z-42.634
N1537 X-26.02 Z-41.981
N1538 X-26.895 Z-41.292
N1539 X-27.77 Z-40.565
N1540 X-28.645 Z-39.796
N1541 X-29.566 Z-38.941
N1542 X-30.487 Z-38.035
N1543 X-31.408 Z-37.073
N1544 X-32.329 Z-36.043
N1545 X-33.166 Z-35.047
N1546 X-34.002 Z-33.989
N1547 X-34.839 Z-32.859
N1548 X-35.676 Z-31.638
N1549 X-36.635 Z-30.125
N1550 X-37.595 Z-28.455
N1551 X-38.074 Z-27.548
N1552 X-38.554 Z-26.583
N1553 X-39.033 Z-25.551
N1554 X-39.758 Z-23.846
N1555 X-40.491 Z-21.866
N1556 X-41.346 Z-19.058
N1557 X-41.98 Z-16.328
N1558 X-42.491 Z-13.111
N1559 X-42.798 Z-9.75
N1560 X-43.003 Z-8.619
N1561 X-43.33 Z-7.496
N1562 X-43.554 Z-6.909
N1563 X-44.003 Z-5.954
N1564 X-44.452 Z-5.184
N1565 X-44.901 Z-4.526
N1566 X-45.35 Z-3.958
N1567 X-45.799 Z-3.462
N1568 X-46.248 Z-3.013
N1569 X-46.697 Z-2.619
N1570 X-47.146 Z-2.259
N1571 X-48.044 Z-1.647
N1572 X-48.942 Z-1.152
N1573 X-49.391 Z-.945
N1574 X-50.289 Z-.595
N1575 X-51.187 Z-.331
N1576 X-52.085 Z-.146
N1577 X-52.984 Z-.036
N1578 X-53.882 Z0.
N1579 Y103.775
N1580 X-52.984 Z-.036
N1581 X-52.085 Z-.146
N1582 X-51.187 Z-.331
N1583 X-50.289 Z-.595
N1584 X-49.391 Z-.945
N1585 X-48.942 Z-1.152
N1586 X-48.044 Z-1.647
N1587 X-47.146 Z-2.259
N1588 X-46.697 Z-2.619
N1589 X-46.248 Z-3.013
N1590 X-45.799 Z-3.462
N1591 X-45.35 Z-3.957
N1592 X-44.901 Z-4.526
N1593 X-44.452 Z-5.184
N1594 X-44.003 Z-5.954
N1595 X-43.554 Z-6.909
N1596 X-43.33 Z-7.496
N1597 X-43.003 Z-8.619
N1598 X-42.798 Z-9.75
N1599 X-42.491 Z-13.111
N1600 X-41.98 Z-16.328
N1601 X-41.346 Z-19.058
N1602 X-40.491 Z-21.866
N1603 X-39.758 Z-23.846
N1604 X-39.033 Z-25.551
N1605 X-38.554 Z-26.583
N1606 X-38.074 Z-27.548
N1607 X-37.595 Z-28.455
N1608 X-36.635 Z-30.125
N1609 X-35.676 Z-31.638
N1610 X-34.839 Z-32.859
N1611 X-34.002 Z-33.989
N1612 X-33.166 Z-35.047
N1613 X-32.329 Z-36.043
N1614 X-31.408 Z-37.073
N1615 X-30.487 Z-38.035
N1616 X-29.566 Z-38.941
N1617 X-28.645 Z-39.796
N1618 X-27.77 Z-40.565
N1619 X-26.895 Z-41.292
N1620 X-26.02 Z-41.981
N1621 X-25.145 Z-42.634
N1622 X-24.233 Z-43.278
N1623 X-23.321 Z-43.886
N1624 X-22.41 Z-44.462
N1625 X-21.498 Z-45.007
N1626 X-19.729 Z-45.98
N1627 X-17.961 Z-46.848
N1628 X-16.151 Z-47.634
N1629 X-14.342 Z-48.323
N1630 X-12.559 Z-48.913
N1631 X-10.776 Z-49.418
N1632 X-8.958 Z-49.849
N1633 X-7.169 Z-50.192
N1634 X-5.362 Z-50.46
N1635 X-3.592 Z-50.648
N1636 X-1.797 Z-50.761
N1637 X0. Z-50.8
N1638 X1.797 Z-50.761
N1639 X3.592 Z-50.648
N1640 X5.362 Z-50.46
N1641 X7.169 Z-50.192
N1642 X8.958 Z-49.849
N1643 X10.776 Z-49.418
N1644 X12.559 Z-48.913
N1645 X14.342 Z-48.323
N1646 X16.151 Z-47.634
N1647 X17.961 Z-46.848
N1648 X18.845 Z-46.427
N1649 X20.614 Z-45.507
N1650 X22.41 Z-44.462
N1651 X23.321 Z-43.886
N1652 X24.233 Z-43.278
N1653 X25.145 Z-42.634
N1654 X26.02 Z-41.981
N1655 X26.895 Z-41.292
N1656 X27.77 Z-40.565
N1657 X28.645 Z-39.796
N1658 X29.566 Z-38.941
N1659 X30.487 Z-38.035
N1660 X31.408 Z-37.073
N1661 X32.329 Z-36.043
N1662 X33.166 Z-35.047
N1663 X34.002 Z-33.989
N1664 X34.839 Z-32.859
N1665 X35.676 Z-31.638
N1666 X36.156 Z-30.898
N1667 X37.115 Z-29.312
N1668 X38.074 Z-27.548
N1669 X38.554 Z-26.583
N1670 X39.033 Z-25.551
N1671 X39.758 Z-23.846
N1672 X40.491 Z-21.866
N1673 X40.979 Z-20.339
N1674 X41.571 Z-18.178
N1675 X42.184 Z-15.229
N1676 X42.44 Z-13.521
N1677 X42.798 Z-9.75
N1678 X43.003 Z-8.619
N1679 X43.217 Z-7.838
N1680 X43.554 Z-6.909
N1681 X43.779 Z-6.403
N1682 X44.228 Z-5.547
N1683 X44.677 Z-4.839
N1684 X45.35 Z-3.958
N1685 X45.799 Z-3.462
N1686 X46.248 Z-3.013
N1687 X46.697 Z-2.619
N1688 X47.146 Z-2.259
N1689 X48.044 Z-1.647
N1690 X48.942 Z-1.152
N1691 X49.391 Z-.945
N1692 X50.289 Z-.595
N1693 X51.187 Z-.331
N1694 X52.085 Z-.146
N1695 X52.984 Z-.036
N1696 X53.882 Z0.
N1697 Y102.575
N1698 X52.984 Z-.036
N1699 X52.085 Z-.146
N1700 X51.187 Z-.331
N1701 X50.289 Z-.595
N1702 X49.391 Z-.944
N1703 X48.942 Z-1.152
N1704 X48.044 Z-1.647
N1705 X47.146 Z-2.259
N1706 X46.697 Z-2.619
N1707 X46.248 Z-3.013
N1708 X45.799 Z-3.462
N1709 X45.35 Z-3.957
N1710 X44.677 Z-4.839
N1711 X44.228 Z-5.547
N1712 X43.779 Z-6.403
N1713 X43.554 Z-6.909
N1714 X43.217 Z-7.838
N1715 X43.003 Z-8.619
N1716 X42.798 Z-9.75
N1717 X42.44 Z-13.521
N1718 X42.184 Z-15.229
N1719 X41.571 Z-18.178
N1720 X40.979 Z-20.339
N1721 X40.491 Z-21.866
N1722 X39.758 Z-23.846
N1723 X39.033 Z-25.551
N1724 X38.554 Z-26.583
N1725 X38.074 Z-27.548
N1726 X37.115 Z-29.312
N1727 X36.156 Z-30.898
N1728 X35.676 Z-31.638
N1729 X34.839 Z-32.859
N1730 X34.002 Z-33.989
N1731 X33.166 Z-35.047
N1732 X32.329 Z-36.043
N1733 X31.408 Z-37.073
N1734 X30.487 Z-38.035
N1735 X29.566 Z-38.941
N1736 X28.645 Z-39.796
N1737 X27.77 Z-40.565
N1738 X26.895 Z-41.292
N1739 X26.02 Z-41.981
N1740 X25.145 Z-42.634
N1741 X24.233 Z-43.278
N1742 X23.321 Z-43.886
N1743 X22.41 Z-44.462
N1744 X20.614 Z-45.507
N1745 X18.845 Z-46.427
N1746 X17.961 Z-46.848
N1747 X16.151 Z-47.634
N1748 X14.342 Z-48.323
N1749 X12.559 Z-48.913
N1750 X10.776 Z-49.418
N1751 X8.958 Z-49.849
N1752 X7.169 Z-50.192
N1753 X5.362 Z-50.46
N1754 X3.592 Z-50.648
N1755 X1.797 Z-50.761
N1756 X0. Z-50.8
N1757 X-1.797 Z-50.761
N1758 X-3.592 Z-50.648
N1759 X-5.362 Z-50.46
N1760 X-7.169 Z-50.192
N1761 X-8.958 Z-49.849
N1762 X-10.776 Z-49.418
N1763 X-12.559 Z-48.913
N1764 X-14.342 Z-48.323
N1765 X-16.151 Z-47.634
N1766 X-17.961 Z-46.848
N1767 X-19.729 Z-45.98
N1768 X-21.498 Z-45.007
N1769 X-22.41 Z-44.462
N1770 X-23.321 Z-43.886
N1771 X-24.233 Z-43.278
N1772 X-25.145 Z-42.634
N1773 X-26.02 Z-41.981
N1774 X-26.895 Z-41.292
N1775 X-27.77 Z-40.565
N1776 X-28.645 Z-39.796
N1777 X-29.566 Z-38.941
N1778 X-30.487 Z-38.035
N1779 X-31.408 Z-37.073
N1780 X-32.329 Z-36.043
N1781 X-33.166 Z-35.047
N1782 X-34.002 Z-33.989
N1783 X-34.839 Z-32.859
N1784 X-35.676 Z-31.638
N1785 X-36.635 Z-30.125
N1786 X-37.595 Z-28.455
N1787 X-38.074 Z-27.548
N1788 X-38.554 Z-26.583
N1789 X-39.033 Z-25.551
N1790 X-39.758 Z-23.846
N1791 X-40.491 Z-21.866
N1792 X-41.346 Z-19.058
N1793 X-41.98 Z-16.328
N1794 X-42.491 Z-13.111
N1795 X-42.798 Z-9.75
N1796 X-43.003 Z-8.619
N1797 X-43.33 Z-7.496
N1798 X-43.554 Z-6.909
N1799 X-44.003 Z-5.954
N1800 X-44.452 Z-5.184
N1801 X-44.901 Z-4.526
N1802 X-45.35 Z-3.957
N1803 X-45.799 Z-3.462
N1804 X-46.248 Z-3.014
N1805 X-46.697 Z-2.619
N1806 X-47.146 Z-2.259
N1807 X-48.044 Z-1.647
N1808 X-48.942 Z-1.152
N1809 X-49.391 Z-.944
N1810 X-50.289 Z-.595
N1811 X-51.187 Z-.331
N1812 X-52.085 Z-.146
N1813 X-52.984 Z-.036
N1814 X-53.882 Z0.
N1815 Y101.375
N1816 X-52.984 Z-.036
N1817 X-52.085 Z-.146
N1818 X-51.187 Z-.331
N1819 X-50.289 Z-.595
N1820 X-49.391 Z-.944
N1821 X-48.942 Z-1.152
N1822 X-48.044 Z-1.647
N1823 X-47.146 Z-2.259
N1824 X-46.697 Z-2.619
N1825 X-46.248 Z-3.014
N1826 X-45.799 Z-3.462
N1827 X-45.35 Z-3.957
N1828 X-44.901 Z-4.526
N1829 X-44.452 Z-5.184
N1830 X-44.003 Z-5.954
N1831 X-43.554 Z-6.909
N1832 X-43.33 Z-7.496
N1833 X-43.003 Z-8.619
N1834 X-42.798 Z-9.75
N1835 X-42.491 Z-13.111
N1836 X-41.98 Z-16.328
N1837 X-41.346 Z-19.058
N1838 X-40.491 Z-21.866
N1839 X-39.758 Z-23.846
N1840 X-39.033 Z-25.551
N1841 X-38.554 Z-26.583
N1842 X-38.074 Z-27.548
N1843 X-37.595 Z-28.455
N1844 X-36.635 Z-30.125
N1845 X-35.676 Z-31.638
N1846 X-34.839 Z-32.859
N1847 X-34.002 Z-33.989
N1848 X-33.166 Z-35.047
N1849 X-32.329 Z-36.043
N1850 X-31.408 Z-37.073
N1851 X-30.487 Z-38.035
N1852 X-29.566 Z-38.941
N1853 X-28.645 Z-39.796
N1854 X-27.77 Z-40.565
N1855 X-26.895 Z-41.292
N1856 X-26.02 Z-41.981
N1857 X-25.145 Z-42.634
N1858 X-24.233 Z-43.278
N1859 X-23.321 Z-43.886
N1860 X-22.41 Z-44.462
N1861 X-21.498 Z-45.007
N1862 X-19.729 Z-45.98
N1863 X-17.961 Z-46.848
N1864 X-16.151 Z-47.634
N1865 X-14.342 Z-48.323
N1866 X-12.559 Z-48.913
N1867 X-10.776 Z-49.418
N1868 X-8.958 Z-49.849
N1869 X-7.169 Z-50.192
N1870 X-5.362 Z-50.46
N1871 X-3.592 Z-50.648
N1872 X-1.797 Z-50.761
N1873 X0. Z-50.8
N1874 X1.797 Z-50.761
N1875 X3.592 Z-50.648
N1876 X5.362 Z-50.46
N1877 X7.169 Z-50.192
N1878 X8.958 Z-49.849
N1879 X10.776 Z-49.418
N1880 X12.559 Z-48.913
N1881 X14.342 Z-48.323
N1882 X16.151 Z-47.634
N1883 X17.961 Z-46.848
N1884 X18.845 Z-46.427
N1885 X20.614 Z-45.507
N1886 X22.41 Z-44.462
N1887 X23.321 Z-43.886
N1888 X24.233 Z-43.278
N1889 X25.145 Z-42.634
N1890 X26.02 Z-41.981
N1891 X26.895 Z-41.292
N1892 X27.77 Z-40.565
N1893 X28.645 Z-39.796
N1894 X29.566 Z-38.941
N1895 X30.487 Z-38.035
N1896 X31.408 Z-37.073
N1897 X32.329 Z-36.043
N1898 X33.166 Z-35.047
N1899 X34.002 Z-33.989
N1900 X34.839 Z-32.859
N1901 X35.676 Z-31.638
N1902 X36.156 Z-30.898
N1903 X37.115 Z-29.312
N1904 X38.074 Z-27.548
N1905 X38.554 Z-26.583
N1906 X39.033 Z-25.551
N1907 X39.758 Z-23.846
N1908 X40.491 Z-21.866
N1909 X40.979 Z-20.339
N1910 X41.571 Z-18.178
N1911 X42.184 Z-15.229
N1912 X42.44 Z-13.521
N1913 X42.798 Z-9.75
N1914 X43.003 Z-8.619
N1915 X43.217 Z-7.837
N1916 X43.554 Z-6.909
N1917 X43.779 Z-6.403
N1918 X44.228 Z-5.547
N1919 X44.677 Z-4.839
N1920 X45.35 Z-3.957
N1921 X45.799 Z-3.462
N1922 X46.248 Z-3.013
N1923 X46.697 Z-2.619
N1924 X47.146 Z-2.259
N1925 X48.044 Z-1.647
N1926 X48.493 Z-1.387
N1927 X49.391 Z-.944
N1928 X50.289 Z-.595
N1929 X51.187 Z-.331
N1930 X52.085 Z-.146
N1931 X52.984 Z-.036
N1932 X53.882 Z0.
N1933 Y100.175
N1934 X52.984 Z-.036
N1935 X52.085 Z-.146
N1936 X51.187 Z-.33
N1937 X50.289 Z-.595
N1938 X49.391 Z-.944
N1939 X48.493 Z-1.387
N1940 X48.044 Z-1.647
N1941 X47.146 Z-2.259
N1942 X46.697 Z-2.619
N1943 X46.248 Z-3.014
N1944 X45.799 Z-3.462
N1945 X45.35 Z-3.957
N1946 X44.677 Z-4.839
N1947 X44.228 Z-5.547
N1948 X43.779 Z-6.403
N1949 X43.554 Z-6.909
N1950 X43.217 Z-7.837
N1951 X43.003 Z-8.619
N1952 X42.798 Z-9.749
N1953 X42.44 Z-13.521
N1954 X42.184 Z-15.229
N1955 X41.571 Z-18.178
N1956 X40.979 Z-20.339
N1957 X40.491 Z-21.866
N1958 X39.758 Z-23.846
N1959 X39.033 Z-25.551
N1960 X38.554 Z-26.583
N1961 X38.074 Z-27.548
N1962 X37.115 Z-29.312
N1963 X36.156 Z-30.898
N1964 X35.676 Z-31.638
N1965 X34.839 Z-32.859
N1966 X34.002 Z-33.989
N1967 X33.166 Z-35.047
N1968 X32.329 Z-36.043
N1969 X31.408 Z-37.073
N1970 X30.487 Z-38.035
N1971 X29.566 Z-38.941
N1972 X28.645 Z-39.796
N1973 X27.77 Z-40.565
N1974 X26.895 Z-41.292
N1975 X26.02 Z-41.981
N1976 X25.145 Z-42.634
N1977 X24.233 Z-43.278
N1978 X23.321 Z-43.886
N1979 X22.41 Z-44.462
N1980 X20.614 Z-45.507
N1981 X18.845 Z-46.427
N1982 X17.961 Z-46.848
N1983 X16.151 Z-47.634
N1984 X14.342 Z-48.323
N1985 X12.559 Z-48.913
N1986 X10.776 Z-49.418
N1987 X8.958 Z-49.849
N1988 X7.169 Z-50.192
N1989 X5.362 Z-50.46
N1990 X3.592 Z-50.648
N1991 X1.797 Z-50.761
N1992 X0. Z-50.8
N1993 X-1.797 Z-50.761
N1994 X-3.592 Z-50.648
N1995 X-5.362 Z-50.46
N1996 X-7.169 Z-50.192
N1997 X-8.958 Z-49.849
N1998 X-10.776 Z-49.418
N1999 X-12.559 Z-48.913
N2000 X-14.342 Z-48.323
N2001 X-16.151 Z-47.634
N2002 X-17.961 Z-46.848
N2003 X-19.729 Z-45.98
N2004 X-21.498 Z-45.007
N2005 X-22.41 Z-44.462
N2006 X-23.321 Z-43.886
N2007 X-24.233 Z-43.278
N2008 X-25.145 Z-42.634
N2009 X-26.02 Z-41.981
N2010 X-26.895 Z-41.292
N2011 X-27.77 Z-40.565
N2012 X-28.645 Z-39.796
N2013 X-29.566 Z-38.941
N2014 X-30.487 Z-38.035
N2015 X-31.408 Z-37.073
N2016 X-32.329 Z-36.043
N2017 X-33.166 Z-35.047
N2018 X-34.002 Z-33.989
N2019 X-34.839 Z-32.859
N2020 X-35.676 Z-31.638
N2021 X-36.635 Z-30.125
N2022 X-37.595 Z-28.455
N2023 X-38.074 Z-27.548
N2024 X-38.554 Z-26.583
N2025 X-39.033 Z-25.551
N2026 X-39.758 Z-23.846
N2027 X-40.491 Z-21.866
N2028 X-41.346 Z-19.058
N2029 X-41.98 Z-16.328
N2030 X-42.491 Z-13.111
N2031 X-42.798 Z-9.749
N2032 X-42.901 Z-9.113
N2033 X-43.105 Z-8.222
N2034 X-43.33 Z-7.496
N2035 X-43.554 Z-6.909
N2036 X-44.003 Z-5.954
N2037 X-44.452 Z-5.184
N2038 X-44.901 Z-4.526
N2039 X-45.35 Z-3.957
N2040 X-45.799 Z-3.462
N2041 X-46.248 Z-3.014
N2042 X-46.697 Z-2.619
N2043 X-47.146 Z-2.259
N2044 X-48.044 Z-1.647
N2045 X-48.942 Z-1.152
N2046 X-49.391 Z-.944
N2047 X-50.289 Z-.595
N2048 X-51.187 Z-.331
N2049 X-52.085 Z-.146
N2050 X-52.984 Z-.036
N2051 X-53.882 Z0.
N2052 Y98.975
N2053 X-52.984 Z-.036
N2054 X-52.085 Z-.146
N2055 X-51.187 Z-.33
N2056 X-50.289 Z-.595
N2057 X-49.391 Z-.944
N2058 X-48.942 Z-1.152
N2059 X-48.044 Z-1.647
N2060 X-47.146 Z-2.259
N2061 X-46.697 Z-2.619
N2062 X-46.248 Z-3.014
N2063 X-45.799 Z-3.462
N2064 X-45.35 Z-3.957
N2065 X-44.901 Z-4.526
N2066 X-44.452 Z-5.184
N2067 X-44.003 Z-5.954
N2068 X-43.554 Z-6.909
N2069 X-43.33 Z-7.496
N2070 X-43.105 Z-8.222
N2071 X-42.901 Z-9.112
N2072 X-42.798 Z-9.749
N2073 X-42.491 Z-13.111
N2074 X-41.98 Z-16.328
N2075 X-41.346 Z-19.058
N2076 X-40.491 Z-21.866
N2077 X-39.758 Z-23.846
N2078 X-39.033 Z-25.551
N2079 X-38.554 Z-26.583
N2080 X-38.074 Z-27.548
N2081 X-37.595 Z-28.455
N2082 X-36.635 Z-30.125
N2083 X-35.676 Z-31.638
N2084 X-34.839 Z-32.859
N2085 X-34.002 Z-33.989
N2086 X-33.166 Z-35.047
N2087 X-32.329 Z-36.043
N2088 X-31.408 Z-37.073
N2089 X-30.487 Z-38.035
N2090 X-29.566 Z-38.941
N2091 X-28.645 Z-39.796
N2092 X-27.77 Z-40.565
N2093 X-26.895 Z-41.292
N2094 X-26.02 Z-41.981
N2095 X-25.145 Z-42.634
N2096 X-24.233 Z-43.278
N2097 X-23.321 Z-43.886
N2098 X-22.41 Z-44.462
N2099 X-21.498 Z-45.007
N2100 X-19.729 Z-45.98
N2101 X-17.961 Z-46.848
N2102 X-16.151 Z-47.634
N2103 X-14.342 Z-48.323
N2104 X-12.559 Z-48.913
N2105 X-10.776 Z-49.418
N2106 X-8.958 Z-49.849
N2107 X-7.169 Z-50.192
N2108 X-5.362 Z-50.46
N2109 X-3.592 Z-50.648
N2110 X-1.797 Z-50.761
N2111 X0. Z-50.8
N2112 X1.797 Z-50.761
N2113 X3.592 Z-50.648
N2114 X5.362 Z-50.46
N2115 X7.169 Z-50.192
N2116 X8.958 Z-49.849
N2117 X10.776 Z-49.418
N2118 X12.559 Z-48.913
N2119 X14.342 Z-48.323
N2120 X16.151 Z-47.634
N2121 X17.961 Z-46.848
N2122 X18.845 Z-46.427
N2123 X20.614 Z-45.507
N2124 X22.41 Z-44.462
N2125 X23.321 Z-43.886
N2126 X24.233 Z-43.278
N2127 X25.145 Z-42.634
N2128 X26.02 Z-41.981
N2129 X26.895 Z-41.292
N2130 X27.77 Z-40.565
N2131 X28.645 Z-39.796
N2132 X29.566 Z-38.941
N2133 X30.487 Z-38.035
N2134 X31.408 Z-37.073
N2135 X32.329 Z-36.043
N2136 X33.166 Z-35.047
N2137 X34.002 Z-33.989
N2138 X34.839 Z-32.859
N2139 X35.676 Z-31.638
N2140 X36.156 Z-30.898
N2141 X37.115 Z-29.312
N2142 X38.074 Z-27.548
N2143 X38.554 Z-26.583
N2144 X39.033 Z-25.551
N2145 X39.758 Z-23.846
N2146 X40.491 Z-21.866
N2147 X40.979 Z-20.339
N2148 X41.571 Z-18.178
N2149 X42.184 Z-15.229
N2150 X42.44 Z-13.521
N2151 X42.798 Z-9.749
N2152 X43.003 Z-8.619
N2153 X43.217 Z-7.837
N2154 X43.554 Z-6.909
N2155 X43.779 Z-6.403
N2156 X44.228 Z-5.547
N2157 X44.677 Z-4.839
N2158 X45.35 Z-3.957
N2159 X45.799 Z-3.462
N2160 X46.248 Z-3.014
N2161 X46.697 Z-2.619
N2162 X47.146 Z-2.259
N2163 X48.044 Z-1.647
N2164 X48.493 Z-1.387
N2165 X49.391 Z-.944
N2166 X50.289 Z-.595
N2167 X51.187 Z-.33
N2168 X52.085 Z-.146
N2169 X52.984 Z-.036
N2170 X53.882 Z0.
N2171 Y97.775
N2172 X52.984 Z-.036
N2173 X52.085 Z-.146
N2174 X51.187 Z-.33
N2175 X50.289 Z-.595
N2176 X49.391 Z-.944
N2177 X48.493 Z-1.387
N2178 X48.044 Z-1.647
N2179 X47.146 Z-2.259
N2180 X46.697 Z-2.619
N2181 X46.248 Z-3.014
N2182 X45.799 Z-3.462
N2183 X45.35 Z-3.957
N2184 X44.677 Z-4.839
N2185 X44.228 Z-5.547
N2186 X43.779 Z-6.403
N2187 X43.554 Z-6.909
N2188 X43.217 Z-7.837
N2189 X43.003 Z-8.619
N2190 X42.798 Z-9.749
N2191 X42.44 Z-13.521
N2192 X42.184 Z-15.229
N2193 X41.571 Z-18.178
N2194 X40.979 Z-20.339
N2195 X40.491 Z-21.866
N2196 X39.758 Z-23.846
N2197 X39.033 Z-25.551
N2198 X38.554 Z-26.583
N2199 X38.074 Z-27.548
N2200 X37.115 Z-29.312
N2201 X36.156 Z-30.898
N2202 X35.676 Z-31.638
N2203 X34.839 Z-32.859
N2204 X34.002 Z-33.989
N2205 X33.166 Z-35.047
N2206 X32.329 Z-36.043
N2207 X31.408 Z-37.073
N2208 X30.487 Z-38.035
N2209 X29.566 Z-38.941
N2210 X28.645 Z-39.796
N2211 X27.77 Z-40.565
N2212 X26.895 Z-41.292
N2213 X26.02 Z-41.981
N2214 X25.145 Z-42.634
N2215 X24.233 Z-43.278
N2216 X23.321 Z-43.886
N2217 X22.41 Z-44.462
N2218 X20.614 Z-45.507
N2219 X18.845 Z-46.427
N2220 X17.961 Z-46.848
N2221 X16.151 Z-47.634
N2222 X14.342 Z-48.323
N2223 X12.559 Z-48.913
N2224 X10.776 Z-49.418
N2225 X8.958 Z-49.849
N2226 X7.169 Z-50.192
N2227 X5.362 Z-50.46
N2228 X3.592 Z-50.648
N2229 X1.797 Z-50.761
N2230 X0. Z-50.8
N2231 X-1.797 Z-50.761
N2232 X-3.592 Z-50.648
N2233 X-5.362 Z-50.46
N2234 X-7.169 Z-50.192
N2235 X-8.958 Z-49.849
N2236 X-10.776 Z-49.418
N2237 X-12.559 Z-48.913
N2238 X-14.342 Z-48.323
N2239 X-16.151 Z-47.634
N2240 X-17.961 Z-46.848
N2241 X-19.729 Z-45.98
N2242 X-21.498 Z-45.007
N2243 X-22.41 Z-44.462
N2244 X-23.321 Z-43.886
N2245 X-24.233 Z-43.278
N2246 X-25.145 Z-42.634
N2247 X-26.02 Z-41.981
N2248 X-26.895 Z-41.292
N2249 X-27.77 Z-40.565
N2250 X-28.645 Z-39.796
N2251 X-29.566 Z-38.941
N2252 X-30.487 Z-38.035
N2253 X-31.408 Z-37.073
N2254 X-32.329 Z-36.043
N2255 X-33.166 Z-35.047
N2256 X-34.002 Z-33.989
N2257 X-34.839 Z-32.859
N2258 X-35.676 Z-31.638
N2259 X-36.635 Z-30.125
N2260 X-37.595 Z-28.455
N2261 X-38.074 Z-27.548
N2262 X-38.554 Z-26.583
N2263 X-39.033 Z-25.551
N2264 X-39.758 Z-23.846
N2265 X-40.491 Z-21.866
N2266 X-41.346 Z-19.058
N2267 X-41.98 Z-16.328
N2268 X-42.491 Z-13.111
N2269 X-42.798 Z-9.749
N2270 X-42.901 Z-9.112
N2271 X-43.105 Z-8.222
N2272 X-43.33 Z-7.496
N2273 X-43.554 Z-6.909
N2274 X-44.003 Z-5.954
N2275 X-44.452 Z-5.184
N2276 X-44.901 Z-4.526
N2277 X-45.35 Z-3.957
N2278 X-45.799 Z-3.462
N2279 X-46.248 Z-3.014
N2280 X-46.697 Z-2.619
N2281 X-47.146 Z-2.259
N2282 X-48.044 Z-1.647
N2283 X-48.942 Z-1.152
N2284 X-49.391 Z-.944
N2285 X-50.289 Z-.595
N2286 X-51.187 Z-.33
N2287 X-52.085 Z-.146
N2288 X-52.984 Z-.036
N2289 X-53.882 Z0.
N2290 Y96.575
N2291 X-52.984 Z-.036
N2292 X-52.085 Z-.146
N2293 X-51.187 Z-.33
N2294 X-50.289 Z-.595
N2295 X-49.391 Z-.944
N2296 X-48.942 Z-1.152
N2297 X-48.044 Z-1.647
N2298 X-47.146 Z-2.259
N2299 X-46.697 Z-2.619
N2300 X-46.248 Z-3.014
N2301 X-45.799 Z-3.462
N2302 X-45.35 Z-3.957
N2303 X-44.901 Z-4.526
N2304 X-44.452 Z-5.184
N2305 X-44.003 Z-5.954
N2306 X-43.554 Z-6.909
N2307 X-43.33 Z-7.496
N2308 X-43.105 Z-8.222
N2309 X-42.901 Z-9.112
N2310 X-42.798 Z-9.749
N2311 X-42.491 Z-13.111
N2312 X-41.98 Z-16.328
N2313 X-41.346 Z-19.058
N2314 X-40.491 Z-21.866
N2315 X-39.758 Z-23.846
N2316 X-39.033 Z-25.551
N2317 X-38.554 Z-26.583
N2318 X-38.074 Z-27.548
N2319 X-37.595 Z-28.455
N2320 X-36.635 Z-30.125
N2321 X-35.676 Z-31.638
N2322 X-34.839 Z-32.859
N2323 X-34.002 Z-33.989
N2324 X-33.166 Z-35.047
N2325 X-32.329 Z-36.043
N2326 X-31.408 Z-37.073
N2327 X-30.487 Z-38.035
N2328 X-29.566 Z-38.941
N2329 X-28.645 Z-39.796
N2330 X-27.77 Z-40.565
N2331 X-26.895 Z-41.292
N2332 X-26.02 Z-41.981
N2333 X-25.145 Z-42.634
N2334 X-24.233 Z-43.278
N2335 X-23.321 Z-43.886
N2336 X-22.41 Z-44.462
N2337 X-21.498 Z-45.007
N2338 X-19.729 Z-45.98
N2339 X-17.961 Z-46.848
N2340 X-16.151 Z-47.634
N2341 X-14.342 Z-48.323
N2342 X-12.559 Z-48.913
N2343 X-10.776 Z-49.418
N2344 X-8.958 Z-49.849
N2345 X-7.169 Z-50.192
N2346 X-5.362 Z-50.46
N2347 X-3.592 Z-50.648
N2348 X-1.797 Z-50.761
N2349 X0. Z-50.8
N2350 X1.797 Z-50.761
N2351 X3.592 Z-50.648
N2352 X5.362 Z-50.46
N2353 X7.169 Z-50.192
N2354 X8.958 Z-49.849
N2355 X10.776 Z-49.418
N2356 X12.559 Z-48.913
N2357 X14.342 Z-48.323
N2358 X16.151 Z-47.634
N2359 X17.961 Z-46.848
N2360 X18.845 Z-46.427
N2361 X20.614 Z-45.507
N2362 X22.41 Z-44.462
N2363 X23.321 Z-43.886
N2364 X24.233 Z-43.278
N2365 X25.145 Z-42.634
N2366 X26.02 Z-41.981
N2367 X26.895 Z-41.292
N2368 X27.77 Z-40.565
N2369 X28.645 Z-39.796
N2370 X29.566 Z-38.941
N2371 X30.487 Z-38.035
N2372 X31.408 Z-37.073
N2373 X32.329 Z-36.043
N2374 X33.166 Z-35.047
N2375 X34.002 Z-33.989
N2376 X34.839 Z-32.859
N2377 X35.676 Z-31.638
N2378 X36.156 Z-30.898
N2379 X37.115 Z-29.312
N2380 X38.074 Z-27.548
N2381 X38.554 Z-26.583
N2382 X39.033 Z-25.551
N2383 X39.758 Z-23.846
N2384 X40.491 Z-21.866
N2385 X40.979 Z-20.339
N2386 X41.571 Z-18.178
N2387 X42.184 Z-15.229
N2388 X42.44 Z-13.521
N2389 X42.798 Z-9.749
N2390 X43.003 Z-8.619
N2391 X43.217 Z-7.837
N2392 X43.554 Z-6.909
N2393 X43.779 Z-6.403
N2394 X44.228 Z-5.547
N2395 X44.677 Z-4.839
N2396 X45.35 Z-3.957
N2397 X45.799 Z-3.462
N2398 X46.248 Z-3.014
N2399 X46.697 Z-2.619
N2400 X47.146 Z-2.259
N2401 X48.044 Z-1.647
N2402 X48.493 Z-1.387
N2403 X49.391 Z-.944
N2404 X50.289 Z-.595
N2405 X51.187 Z-.33
N2406 X52.085 Z-.146
N2407 X52.984 Z-.036
N2408 X53.882 Z0.
N2409 Y95.375
N2410 X52.984 Z-.036
N2411 X52.085 Z-.146
N2412 X51.187 Z-.33
N2413 X50.289 Z-.595
N2414 X49.391 Z-.944
N2415 X48.493 Z-1.387
N2416 X48.044 Z-1.647
N2417 X47.146 Z-2.259
N2418 X46.697 Z-2.619
N2419 X46.248 Z-3.014
N2420 X45.799 Z-3.462
N2421 X45.35 Z-3.957
N2422 X44.677 Z-4.839
N2423 X44.228 Z-5.547
N2424 X43.779 Z-6.403
N2425 X43.554 Z-6.909
N2426 X43.217 Z-7.837
N2427 X43.003 Z-8.619
N2428 X42.798 Z-9.749
N2429 X42.44 Z-13.521
N2430 X42.184 Z-15.229
N2431 X41.571 Z-18.178
N2432 X40.979 Z-20.339
N2433 X40.491 Z-21.866
N2434 X39.758 Z-23.846
N2435 X39.033 Z-25.551
N2436 X38.554 Z-26.583
N2437 X38.074 Z-27.548
N2438 X37.115 Z-29.312
N2439 X36.156 Z-30.898
N2440 X35.676 Z-31.638
N2441 X34.839 Z-32.859
N2442 X34.002 Z-33.989
N2443 X33.166 Z-35.047
N2444 X32.329 Z-36.043
N2445 X31.408 Z-37.073
N2446 X30.487 Z-38.035
N2447 X29.566 Z-38.941
N2448 X28.645 Z-39.796
N2449 X27.77 Z-40.565
N2450 X26.895 Z-41.292
N2451 X26.02 Z-41.981
N2452 X25.145 Z-42.634
N2453 X24.233 Z-43.278
N2454 X23.321 Z-43.886
N2455 X22.41 Z-44.462
N2456 X20.614 Z-45.507
N2457 X18.845 Z-46.427
N2458 X17.961 Z-46.848
N2459 X16.151 Z-47.634
N2460 X14.342 Z-48.323
N2461 X12.559 Z-48.913
N2462 X10.776 Z-49.418
N2463 X8.958 Z-49.849
N2464 X7.169 Z-50.192
N2465 X5.362 Z-50.46
N2466 X3.592 Z-50.648
N2467 X1.797 Z-50.761
N2468 X0. Z-50.8
N2469 X-1.797 Z-50.761
N2470 X-3.592 Z-50.648
N2471 X-5.362 Z-50.46
N2472 X-7.169 Z-50.192
N2473 X-8.958 Z-49.849
N2474 X-10.776 Z-49.418
N2475 X-12.559 Z-48.913
N2476 X-14.342 Z-48.323
N2477 X-16.151 Z-47.634
N2478 X-17.961 Z-46.848
N2479 X-19.729 Z-45.98
N2480 X-21.498 Z-45.007
N2481 X-22.41 Z-44.462
N2482 X-23.321 Z-43.886
N2483 X-24.233 Z-43.278
N2484 X-25.145 Z-42.634
N2485 X-26.02 Z-41.981
N2486 X-26.895 Z-41.292
N2487 X-27.77 Z-40.565
N2488 X-28.645 Z-39.796
N2489 X-29.566 Z-38.941
N2490 X-30.487 Z-38.035
N2491 X-31.408 Z-37.073
N2492 X-32.329 Z-36.043
N2493 X-33.166 Z-35.047
N2494 X-34.002 Z-33.989
N2495 X-34.839 Z-32.859
N2496 X-35.676 Z-31.638
N2497 X-36.635 Z-30.125
N2498 X-37.595 Z-28.455
N2499 X-38.074 Z-27.548
N2500 X-38.554 Z-26.583
N2501 X-39.033 Z-25.551
N2502 X-39.758 Z-23.846
N2503 X-40.491 Z-21.866
N2504 X-41.346 Z-19.058
N2505 X-41.98 Z-16.328
N2506 X-42.491 Z-13.111
N2507 X-42.798 Z-9.749
N2508 X-42.901 Z-9.112
N2509 X-43.105 Z-8.221
N2510 X-43.33 Z-7.496
N2511 X-43.554 Z-6.909
N2512 X-44.003 Z-5.954
N2513 X-44.452 Z-5.183
N2514 X-44.901 Z-4.526
N2515 X-45.35 Z-3.957
N2516 X-45.799 Z-3.462
N2517 X-46.248 Z-3.014
N2518 X-46.697 Z-2.619
N2519 X-47.146 Z-2.259
N2520 X-48.044 Z-1.647
N2521 X-48.942 Z-1.152
N2522 X-49.391 Z-.944
N2523 X-50.289 Z-.595
N2524 X-51.187 Z-.33
N2525 X-52.085 Z-.146
N2526 X-52.984 Z-.036
N2527 X-53.882 Z0.
N2528 Y94.175
N2529 X-52.984 Z-.036
N2530 X-52.085 Z-.146
N2531 X-51.187 Z-.33
N2532 X-50.289 Z-.595
N2533 X-49.391 Z-.944
N2534 X-48.942 Z-1.152
N2535 X-48.044 Z-1.647
N2536 X-47.146 Z-2.259
N2537 X-46.697 Z-2.619
N2538 X-46.248 Z-3.014
N2539 X-45.799 Z-3.462
N2540 X-45.35 Z-3.957
N2541 X-44.901 Z-4.526
N2542 X-44.452 Z-5.183
N2543 X-44.003 Z-5.954
N2544 X-43.554 Z-6.909
N2545 X-43.33 Z-7.496
N2546 X-43.105 Z-8.221
N2547 X-42.901 Z-9.111
N2548 X-42.798 Z-9.749
N2549 X-42.491 Z-13.111
N2550 X-41.98 Z-16.328
N2551 X-41.346 Z-19.058
N2552 X-40.491 Z-21.866
N2553 X-39.758 Z-23.846
N2554 X-39.033 Z-25.551
N2555 X-38.554 Z-26.583
N2556 X-38.074 Z-27.548
N2557 X-37.595 Z-28.455
N2558 X-36.635 Z-30.125
N2559 X-35.676 Z-31.638
N2560 X-34.839 Z-32.859
N2561 X-34.002 Z-33.989
N2562 X-33.166 Z-35.047
N2563 X-32.329 Z-36.043
N2564 X-31.408 Z-37.073
N2565 X-30.487 Z-38.035
N2566 X-29.566 Z-38.941
N2567 X-28.645 Z-39.796
N2568 X-27.77 Z-40.565
N2569 X-26.895 Z-41.292
N2570 X-26.02 Z-41.981
N2571 X-25.145 Z-42.634
N2572 X-24.233 Z-43.278
N2573 X-23.321 Z-43.886
N2574 X-22.41 Z-44.462
N2575 X-21.498 Z-45.007
N2576 X-19.729 Z-45.98
N2577 X-17.961 Z-46.848
N2578 X-16.151 Z-47.634
N2579 X-14.342 Z-48.323
N2580 X-12.559 Z-48.913
N2581 X-10.776 Z-49.418
N2582 X-8.958 Z-49.849
N2583 X-7.169 Z-50.192
N2584 X-5.362 Z-50.46
N2585 X-3.592 Z-50.648
N2586 X-1.797 Z-50.761
N2587 X0. Z-50.8
N2588 X1.797 Z-50.761
N2589 X3.592 Z-50.648
N2590 X5.362 Z-50.46
N2591 X7.169 Z-50.192
N2592 X8.958 Z-49.849
N2593 X10.776 Z-49.418
N2594 X12.559 Z-48.913
N2595 X14.342 Z-48.323
N2596 X16.151 Z-47.634
N2597 X17.961 Z-46.848
N2598 X18.845 Z-46.427
N2599 X20.614 Z-45.507
N2600 X22.41 Z-44.462
N2601 X23.321 Z-43.886
N2602 X24.233 Z-43.278
N2603 X25.145 Z-42.634
N2604 X26.02 Z-41.981
N2605 X26.895 Z-41.292
N2606 X27.77 Z-40.565
N2607 X28.645 Z-39.796
N2608 X29.566 Z-38.941
N2609 X30.487 Z-38.035
N2610 X31.408 Z-37.073
N2611 X32.329 Z-36.043
N2612 X33.166 Z-35.047
N2613 X34.002 Z-33.989
N2614 X34.839 Z-32.859
N2615 X35.676 Z-31.638
N2616 X36.156 Z-30.898
N2617 X37.115 Z-29.312
N2618 X38.074 Z-27.548
N2619 X38.554 Z-26.583
N2620 X39.033 Z-25.551
N2621 X39.758 Z-23.846
N2622 X40.491 Z-21.866
N2623 X40.979 Z-20.339
N2624 X41.571 Z-18.178
N2625 X42.184 Z-15.229
N2626 X42.44 Z-13.521
N2627 X42.798 Z-9.749
N2628 X43.003 Z-8.619
N2629 X43.217 Z-7.837
N2630 X43.554 Z-6.909
N2631 X43.779 Z-6.403
N2632 X44.228 Z-5.547
N2633 X44.677 Z-4.839
N2634 X45.35 Z-3.957
N2635 X45.799 Z-3.462
N2636 X46.248 Z-3.014
N2637 X46.697 Z-2.619
N2638 X47.146 Z-2.259
N2639 X48.044 Z-1.647
N2640 X48.493 Z-1.387
N2641 X49.391 Z-.944
N2642 X50.289 Z-.595
N2643 X51.187 Z-.33
N2644 X52.085 Z-.146
N2645 X52.984 Z-.036
N2646 X53.882 Z0.
N2647 Y92.975
N2648 X52.984 Z-.036
N2649 X52.085 Z-.146
N2650 X51.187 Z-.33
N2651 X50.289 Z-.595
N2652 X49.391 Z-.944
N2653 X48.493 Z-1.387
N2654 X48.044 Z-1.647
N2655 X47.146 Z-2.259
N2656 X46.697 Z-2.619
N2657 X46.248 Z-3.014
N2658 X45.799 Z-3.462
N2659 X45.35 Z-3.957
N2660 X44.677 Z-4.839
N2661 X44.228 Z-5.547
N2662 X43.779 Z-6.404
N2663 X43.554 Z-6.909
N2664 X43.217 Z-7.837
N2665 X43.003 Z-8.619
N2666 X42.798 Z-9.749
N2667 X42.44 Z-13.521
N2668 X42.184 Z-15.229
N2669 X41.571 Z-18.178
N2670 X40.979 Z-20.339
N2671 X40.491 Z-21.866
N2672 X39.758 Z-23.846
N2673 X39.033 Z-25.551
N2674 X38.554 Z-26.583
N2675 X38.074 Z-27.548
N2676 X37.115 Z-29.312
N2677 X36.156 Z-30.898
N2678 X35.676 Z-31.638
N2679 X34.839 Z-32.859
N2680 X34.002 Z-33.989
N2681 X33.166 Z-35.047
N2682 X32.329 Z-36.043
N2683 X31.408 Z-37.073
N2684 X30.487 Z-38.035
N2685 X29.566 Z-38.941
N2686 X28.645 Z-39.796
N2687 X27.77 Z-40.565
N2688 X26.895 Z-41.292
N2689 X26.02 Z-41.981
N2690 X25.145 Z-42.634
N2691 X24.233 Z-43.278
N2692 X23.321 Z-43.886
N2693 X22.41 Z-44.462
N2694 X20.614 Z-45.507
N2695 X18.845 Z-46.427
N2696 X17.961 Z-46.848
N2697 X16.151 Z-47.634
N2698 X14.342 Z-48.323
N2699 X12.559 Z-48.913
N2700 X10.776 Z-49.418
N2701 X8.958 Z-49.849
N2702 X7.169 Z-50.192
N2703 X5.362 Z-50.46
N2704 X3.592 Z-50.648
N2705 X1.797 Z-50.761
N2706 X0. Z-50.8
N2707 X-1.797 Z-50.761
N2708 X-3.592 Z-50.648
N2709 X-5.362 Z-50.46
N2710 X-7.169 Z-50.192
N2711 X-8.958 Z-49.849
N2712 X-10.776 Z-49.418
N2713 X-12.559 Z-48.913
N2714 X-14.342 Z-48.323
N2715 X-16.151 Z-47.634
N2716 X-17.961 Z-46.848
N2717 X-19.729 Z-45.98
N2718 X-21.498 Z-45.007
N2719 X-22.41 Z-44.462
N2720 X-23.321 Z-43.886
N2721 X-24.233 Z-43.278
N2722 X-25.145 Z-42.634
N2723 X-26.02 Z-41.981
N2724 X-26.895 Z-41.292
N2725 X-27.77 Z-40.565
N2726 X-28.645 Z-39.796
N2727 X-29.566 Z-38.941
N2728 X-30.487 Z-38.035
N2729 X-31.408 Z-37.073
N2730 X-32.329 Z-36.043
N2731 X-33.166 Z-35.047
N2732 X-34.002 Z-33.989
N2733 X-34.839 Z-32.859
N2734 X-35.676 Z-31.638
N2735 X-36.635 Z-30.125
N2736 X-37.595 Z-28.455
N2737 X-38.074 Z-27.548
N2738 X-38.554 Z-26.583
N2739 X-39.033 Z-25.551
N2740 X-39.758 Z-23.846
N2741 X-40.491 Z-21.866
N2742 X-41.346 Z-19.058
N2743 X-41.98 Z-16.328
N2744 X-42.491 Z-13.111
N2745 X-42.798 Z-9.749
N2746 X-42.901 Z-9.111
N2747 X-43.105 Z-8.221
N2748 X-43.33 Z-7.496
N2749 X-43.554 Z-6.909
N2750 X-44.003 Z-5.954
N2751 X-44.452 Z-5.183
N2752 X-44.901 Z-4.526
N2753 X-45.35 Z-3.957
N2754 X-45.799 Z-3.462
N2755 X-46.248 Z-3.014
N2756 X-46.697 Z-2.619
N2757 X-47.146 Z-2.259
N2758 X-48.044 Z-1.647
N2759 X-48.942 Z-1.152
N2760 X-49.391 Z-.944
N2761 X-50.289 Z-.595
N2762 X-51.187 Z-.33
N2763 X-52.085 Z-.146
N2764 X-52.984 Z-.036
N2765 X-53.882 Z0.
N2766 Y91.775
N2767 X-52.984 Z-.036
N2768 X-52.085 Z-.146
N2769 X-51.187 Z-.33
N2770 X-50.289 Z-.595
N2771 X-49.391 Z-.944
N2772 X-48.942 Z-1.152
N2773 X-48.044 Z-1.647
N2774 X-47.146 Z-2.259
N2775 X-46.697 Z-2.618
N2776 X-46.248 Z-3.014
N2777 X-45.799 Z-3.462
N2778 X-45.35 Z-3.957
N2779 X-44.901 Z-4.526
N2780 X-44.452 Z-5.183
N2781 X-44.003 Z-5.953
N2782 X-43.554 Z-6.908
N2783 X-43.33 Z-7.496
N2784 X-43.105 Z-8.221
N2785 X-42.901 Z-9.111
N2786 X-42.798 Z-9.749
N2787 X-42.491 Z-13.111
N2788 X-41.98 Z-16.328
N2789 X-41.346 Z-19.058
N2790 X-40.491 Z-21.866
N2791 X-39.758 Z-23.846
N2792 X-39.033 Z-25.551
N2793 X-38.554 Z-26.583
N2794 X-38.074 Z-27.548
N2795 X-37.595 Z-28.455
N2796 X-36.635 Z-30.125
N2797 X-35.676 Z-31.638
N2798 X-34.839 Z-32.859
N2799 X-34.002 Z-33.989
N2800 X-33.166 Z-35.047
N2801 X-32.329 Z-36.043
N2802 X-31.408 Z-37.073
N2803 X-30.487 Z-38.035
N2804 X-29.566 Z-38.941
N2805 X-28.645 Z-39.796
N2806 X-27.77 Z-40.565
N2807 X-26.895 Z-41.292
N2808 X-26.02 Z-41.981
N2809 X-25.145 Z-42.634
N2810 X-24.233 Z-43.278
N2811 X-23.321 Z-43.886
N2812 X-22.41 Z-44.462
N2813 X-21.498 Z-45.007
N2814 X-19.729 Z-45.98
N2815 X-17.961 Z-46.848
N2816 X-16.151 Z-47.634
N2817 X-14.342 Z-48.323
N2818 X-12.559 Z-48.913
N2819 X-10.776 Z-49.418
N2820 X-8.958 Z-49.849
N2821 X-7.169 Z-50.192
N2822 X-5.362 Z-50.46
N2823 X-3.592 Z-50.648
N2824 X-1.797 Z-50.761
N2825 X0. Z-50.8
N2826 X1.797 Z-50.761
N2827 X3.592 Z-50.648
N2828 X5.362 Z-50.46
N2829 X7.169 Z-50.192
N2830 X8.958 Z-49.849
N2831 X10.776 Z-49.418
N2832 X12.559 Z-48.913
N2833 X14.342 Z-48.323
N2834 X16.151 Z-47.634
N2835 X17.961 Z-46.848
N2836 X18.845 Z-46.427
N2837 X20.614 Z-45.507
N2838 X22.41 Z-44.462
N2839 X23.321 Z-43.886
N2840 X24.233 Z-43.278
N2841 X25.145 Z-42.634
N2842 X26.02 Z-41.981
N2843 X26.895 Z-41.292
N2844 X27.77 Z-40.565
N2845 X28.645 Z-39.796
N2846 X29.566 Z-38.941
N2847 X30.487 Z-38.035
N2848 X31.408 Z-37.073
N2849 X32.329 Z-36.043
N2850 X33.166 Z-35.047
N2851 X34.002 Z-33.989
N2852 X34.839 Z-32.859
N2853 X35.676 Z-31.638
N2854 X36.156 Z-30.898
N2855 X37.115 Z-29.312
N2856 X38.074 Z-27.548
N2857 X38.554 Z-26.583
N2858 X39.033 Z-25.551
N2859 X39.758 Z-23.846
N2860 X40.491 Z-21.866
N2861 X40.979 Z-20.339
N2862 X41.571 Z-18.178
N2863 X42.184 Z-15.229
N2864 X42.44 Z-13.521
N2865 X42.798 Z-9.749
N2866 X43.003 Z-8.619
N2867 X43.217 Z-7.837
N2868 X43.554 Z-6.908
N2869 X43.779 Z-6.404
N2870 X44.228 Z-5.547
N2871 X44.677 Z-4.839
N2872 X45.35 Z-3.957
N2873 X45.799 Z-3.462
N2874 X46.248 Z-3.014
N2875 X46.697 Z-2.619
N2876 X47.146 Z-2.259
N2877 X48.044 Z-1.647
N2878 X48.493 Z-1.387
N2879 X49.391 Z-.944
N2880 X50.289 Z-.594
N2881 X51.187 Z-.33
N2882 X52.085 Z-.146
N2883 X52.984 Z-.036
N2884 X53.882 Z0.
N2885 Y90.575
N2886 X52.984 Z-.036
N2887 X52.085 Z-.146
N2888 X51.187 Z-.33
N2889 X50.289 Z-.594
N2890 X49.391 Z-.944
N2891 X48.493 Z-1.387
N2892 X48.044 Z-1.647
N2893 X47.146 Z-2.259
N2894 X46.697 Z-2.618
N2895 X46.248 Z-3.014
N2896 X45.799 Z-3.462
N2897 X45.35 Z-3.957
N2898 X44.677 Z-4.839
N2899 X44.228 Z-5.547
N2900 X43.779 Z-6.404
N2901 X43.554 Z-6.908
N2902 X43.217 Z-7.837
N2903 X43.003 Z-8.619
N2904 X42.798 Z-9.749
N2905 X42.44 Z-13.521
N2906 X42.184 Z-15.229
N2907 X41.571 Z-18.178
N2908 X40.979 Z-20.339
N2909 X40.491 Z-21.866
N2910 X39.758 Z-23.846
N2911 X39.033 Z-25.551
N2912 X38.554 Z-26.583
N2913 X38.074 Z-27.548
N2914 X37.115 Z-29.312
N2915 X36.156 Z-30.898
N2916 X35.676 Z-31.638
N2917 X34.839 Z-32.859
N2918 X34.002 Z-33.989
N2919 X33.166 Z-35.047
N2920 X32.329 Z-36.043
N2921 X31.408 Z-37.073
N2922 X30.487 Z-38.035
N2923 X29.566 Z-38.941
N2924 X28.645 Z-39.796
N2925 X27.77 Z-40.565
N2926 X26.895 Z-41.292
N2927 X26.02 Z-41.981
N2928 X25.145 Z-42.634
N2929 X24.233 Z-43.278
N2930 X23.321 Z-43.886
N2931 X22.41 Z-44.462
N2932 X20.614 Z-45.507
N2933 X18.845 Z-46.427
N2934 X17.961 Z-46.848
N2935 X16.151 Z-47.634
N2936 X14.342 Z-48.323
N2937 X12.559 Z-48.913
N2938 X10.776 Z-49.418
N2939 X8.958 Z-49.849
N2940 X7.169 Z-50.192
N2941 X5.362 Z-50.46
N2942 X3.592 Z-50.648
N2943 X1.797 Z-50.761
N2944 X0. Z-50.8
N2945 X-1.797 Z-50.761
N2946 X-3.592 Z-50.648
N2947 X-5.362 Z-50.46
N2948 X-7.169 Z-50.192
N2949 X-8.958 Z-49.849
N2950 X-10.776 Z-49.418
N2951 X-12.559 Z-48.913
N2952 X-14.342 Z-48.323
N2953 X-16.151 Z-47.634
N2954 X-17.961 Z-46.848
N2955 X-19.729 Z-45.98
N2956 X-21.498 Z-45.007
N2957 X-22.41 Z-44.462
N2958 X-23.321 Z-43.886
N2959 X-24.233 Z-43.278
N2960 X-25.145 Z-42.634
N2961 X-26.02 Z-41.981
N2962 X-26.895 Z-41.292
N2963 X-27.77 Z-40.565
N2964 X-28.645 Z-39.796
N2965 X-29.566 Z-38.941
N2966 X-30.487 Z-38.035
N2967 X-31.408 Z-37.073
N2968 X-32.329 Z-36.043
N2969 X-33.166 Z-35.047
N2970 X-34.002 Z-33.989
N2971 X-34.839 Z-32.859
N2972 X-35.676 Z-31.638
N2973 X-36.635 Z-30.125
N2974 X-37.595 Z-28.455
N2975 X-38.074 Z-27.548
N2976 X-38.554 Z-26.583
N2977 X-39.033 Z-25.551
N2978 X-39.758 Z-23.846
N2979 X-40.491 Z-21.866
N2980 X-41.346 Z-19.058
N2981 X-41.98 Z-16.328
N2982 X-42.491 Z-13.111
N2983 X-42.798 Z-9.749
N2984 X-42.901 Z-9.111
N2985 X-43.105 Z-8.221
N2986 X-43.33 Z-7.496
N2987 X-43.554 Z-6.908
N2988 X-44.003 Z-5.953
N2989 X-44.452 Z-5.183
N2990 X-44.901 Z-4.526
N2991 X-45.35 Z-3.957
N2992 X-45.799 Z-3.462
N2993 X-46.248 Z-3.014
N2994 X-46.697 Z-2.618
N2995 X-47.146 Z-2.259
N2996 X-48.044 Z-1.647
N2997 X-48.942 Z-1.152
N2998 X-49.391 Z-.944
N2999 X-50.289 Z-.594
N3000 X-51.187 Z-.33
N3001 X-52.085 Z-.146
N3002 X-52.984 Z-.036
N3003 X-53.882 Z0.
N3004 Y89.375
N3005 X-52.984 Z-.036
N3006 X-52.085 Z-.146
N3007 X-51.187 Z-.33
N3008 X-50.289 Z-.594
N3009 X-49.391 Z-.944
N3010 X-48.942 Z-1.152
N3011 X-48.044 Z-1.647
N3012 X-47.595 Z-1.938
N3013 X-47.146 Z-2.259
N3014 X-46.697 Z-2.618
N3015 X-46.248 Z-3.014
N3016 X-45.799 Z-3.462
N3017 X-45.35 Z-3.957
N3018 X-44.901 Z-4.526
N3019 X-44.452 Z-5.183
N3020 X-44.003 Z-5.953
N3021 X-43.554 Z-6.908
N3022 X-43.33 Z-7.496
N3023 X-43.105 Z-8.221
N3024 X-42.901 Z-9.111
N3025 X-42.798 Z-9.749
N3026 X-42.491 Z-13.111
N3027 X-41.98 Z-16.328
N3028 X-41.346 Z-19.058
N3029 X-40.491 Z-21.866
N3030 X-39.758 Z-23.846
N3031 X-39.033 Z-25.551
N3032 X-38.554 Z-26.583
N3033 X-38.074 Z-27.548
N3034 X-37.595 Z-28.455
N3035 X-36.635 Z-30.125
N3036 X-35.676 Z-31.638
N3037 X-34.839 Z-32.859
N3038 X-34.002 Z-33.989
N3039 X-33.166 Z-35.047
N3040 X-32.329 Z-36.043
N3041 X-31.408 Z-37.073
N3042 X-30.487 Z-38.035
N3043 X-29.566 Z-38.941
N3044 X-28.645 Z-39.796
N3045 X-27.77 Z-40.565
N3046 X-26.895 Z-41.292
N3047 X-26.02 Z-41.981
N3048 X-25.145 Z-42.634
N3049 X-24.233 Z-43.278
N3050 X-23.321 Z-43.886
N3051 X-22.41 Z-44.462
N3052 X-21.498 Z-45.007
N3053 X-19.729 Z-45.98
N3054 X-17.961 Z-46.848
N3055 X-16.151 Z-47.634
N3056 X-14.342 Z-48.323
N3057 X-12.559 Z-48.913
N3058 X-10.776 Z-49.418
N3059 X-8.958 Z-49.849
N3060 X-7.169 Z-50.192
N3061 X-5.362 Z-50.46
N3062 X-3.592 Z-50.648
N3063 X-1.797 Z-50.761
N3064 X0. Z-50.8
N3065 X1.797 Z-50.761
N3066 X3.592 Z-50.648
N3067 X5.362 Z-50.46
N3068 X7.169 Z-50.192
N3069 X8.958 Z-49.849
N3070 X10.776 Z-49.418
N3071 X12.559 Z-48.913
N3072 X14.342 Z-48.323
N3073 X16.151 Z-47.634
N3074 X17.961 Z-46.848
N3075 X18.845 Z-46.427
N3076 X20.614 Z-45.507
N3077 X22.41 Z-44.462
N3078 X23.321 Z-43.886
N3079 X24.233 Z-43.278
N3080 X25.145 Z-42.634
N3081 X26.02 Z-41.981
N3082 X26.895 Z-41.292
N3083 X27.77 Z-40.565
N3084 X28.645 Z-39.796
N3085 X29.566 Z-38.941
N3086 X30.487 Z-38.035
N3087 X31.408 Z-37.073
N3088 X32.329 Z-36.043
N3089 X33.166 Z-35.047
N3090 X34.002 Z-33.989
N3091 X34.839 Z-32.859
N3092 X35.676 Z-31.638
N3093 X36.156 Z-30.898
N3094 X37.115 Z-29.312
N3095 X38.074 Z-27.548
N3096 X38.554 Z-26.583
N3097 X39.033 Z-25.551
N3098 X39.758 Z-23.846
N3099 X40.491 Z-21.866
N3100 X40.979 Z-20.339
N3101 X41.571 Z-18.178
N3102 X42.184 Z-15.229
N3103 X42.44 Z-13.521
N3104 X42.798 Z-9.749
N3105 X43.003 Z-8.619
N3106 X43.217 Z-7.837
N3107 X43.554 Z-6.908
N3108 X43.779 Z-6.404
N3109 X44.228 Z-5.547
N3110 X44.677 Z-4.839
N3111 X45.35 Z-3.957
N3112 X45.799 Z-3.462
N3113 X46.248 Z-3.014
N3114 X46.697 Z-2.618
N3115 X47.146 Z-2.259
N3116 X48.044 Z-1.647
N3117 X48.493 Z-1.387
N3118 X49.391 Z-.944
N3119 X50.289 Z-.594
N3120 X51.187 Z-.33
N3121 X52.085 Z-.146
N3122 X52.984 Z-.036
N3123 X53.882 Z0.
N3124 Y88.175
N3125 X52.984 Z-.036
N3126 X52.085 Z-.146
N3127 X51.187 Z-.33
N3128 X50.289 Z-.594
N3129 X49.391 Z-.944
N3130 X48.493 Z-1.387
N3131 X48.044 Z-1.647
N3132 X47.595 Z-1.938
N3133 X47.146 Z-2.259
N3134 X46.697 Z-2.618
N3135 X46.248 Z-3.014
N3136 X45.799 Z-3.462
N3137 X45.35 Z-3.957
N3138 X44.677 Z-4.839
N3139 X44.228 Z-5.547
N3140 X43.779 Z-6.404
N3141 X43.554 Z-6.908
N3142 X43.217 Z-7.837
N3143 X43.003 Z-8.619
N3144 X42.798 Z-9.749
N3145 X42.44 Z-13.52
N3146 X42.184 Z-15.229
N3147 X41.571 Z-18.178
N3148 X40.979 Z-20.339
N3149 X40.491 Z-21.866
N3150 X39.758 Z-23.846
N3151 X39.033 Z-25.551
N3152 X38.554 Z-26.583
N3153 X38.074 Z-27.548
N3154 X37.115 Z-29.312
N3155 X36.156 Z-30.898
N3156 X35.676 Z-31.638
N3157 X34.839 Z-32.859
N3158 X34.002 Z-33.989
N3159 X33.166 Z-35.047
N3160 X32.329 Z-36.043
N3161 X31.408 Z-37.073
N3162 X30.487 Z-38.035
N3163 X29.566 Z-38.941
N3164 X28.645 Z-39.796
N3165 X27.77 Z-40.565
N3166 X26.895 Z-41.292
N3167 X26.02 Z-41.981
N3168 X25.145 Z-42.634
N3169 X24.233 Z-43.278
N3170 X23.321 Z-43.886
N3171 X22.41 Z-44.462
N3172 X20.614 Z-45.507
N3173 X18.845 Z-46.427
N3174 X17.961 Z-46.848
N3175 X16.151 Z-47.634
N3176 X14.342 Z-48.323
N3177 X12.559 Z-48.913
N3178 X10.776 Z-49.418
N3179 X8.958 Z-49.849
N3180 X7.169 Z-50.192
N3181 X5.362 Z-50.46
N3182 X3.592 Z-50.648
N3183 X1.797 Z-50.761
N3184 X0. Z-50.8
N3185 X-1.797 Z-50.761
N3186 X-3.592 Z-50.648
N3187 X-5.362 Z-50.46
N3188 X-7.169 Z-50.192
N3189 X-8.958 Z-49.849
N3190 X-10.776 Z-49.418
N3191 X-12.559 Z-48.913
N3192 X-14.342 Z-48.323
N3193 X-16.151 Z-47.634
N3194 X-17.961 Z-46.848
N3195 X-19.729 Z-45.98
N3196 X-21.498 Z-45.007
N3197 X-22.41 Z-44.462
N3198 X-23.321 Z-43.886
N3199 X-24.233 Z-43.278
N3200 X-25.145 Z-42.634
N3201 X-26.02 Z-41.981
N3202 X-26.895 Z-41.292
N3203 X-27.77 Z-40.565
N3204 X-28.645 Z-39.796
N3205 X-29.566 Z-38.941
N3206 X-30.487 Z-38.035
N3207 X-31.408 Z-37.073
N3208 X-32.329 Z-36.043
N3209 X-33.166 Z-35.047
N3210 X-34.002 Z-33.989
N3211 X-34.839 Z-32.859
N3212 X-35.676 Z-31.638
N3213 X-36.635 Z-30.125
N3214 X-37.595 Z-28.455
N3215 X-38.074 Z-27.548
N3216 X-38.554 Z-26.583
N3217 X-39.033 Z-25.551
N3218 X-39.758 Z-23.846
N3219 X-40.491 Z-21.866
N3220 X-41.346 Z-19.058
N3221 X-41.98 Z-16.328
N3222 X-42.491 Z-13.111
N3223 X-42.798 Z-9.749
N3224 X-42.901 Z-9.11
N3225 X-43.105 Z-8.221
N3226 X-43.33 Z-7.496
N3227 X-43.554 Z-6.908
N3228 X-44.003 Z-5.953
N3229 X-44.452 Z-5.183
N3230 X-44.901 Z-4.526
N3231 X-45.35 Z-3.957
N3232 X-45.799 Z-3.462
N3233 X-46.248 Z-3.014
N3234 X-46.697 Z-2.618
N3235 X-47.146 Z-2.259
N3236 X-47.595 Z-1.938
N3237 X-48.493 Z-1.387
N3238 X-49.391 Z-.944
N3239 X-50.289 Z-.594
N3240 X-51.187 Z-.33
N3241 X-52.085 Z-.146
N3242 X-52.984 Z-.036
N3243 X-53.882 Z0.
N3244 Y86.975
N3245 X-52.984 Z-.036
N3246 X-52.085 Z-.146
N3247 X-51.187 Z-.33
N3248 X-50.289 Z-.594
N3249 X-49.391 Z-.944
N3250 X-48.493 Z-1.387
N3251 X-47.595 Z-1.938
N3252 X-47.146 Z-2.259
N3253 X-46.697 Z-2.618
N3254 X-46.248 Z-3.014
N3255 X-45.799 Z-3.462
N3256 X-45.35 Z-3.957
N3257 X-44.901 Z-4.527
N3258 X-44.452 Z-5.183
N3259 X-44.003 Z-5.953
N3260 X-43.554 Z-6.908
N3261 X-43.33 Z-7.496
N3262 X-43.105 Z-8.221
N3263 X-42.901 Z-9.11
N3264 X-42.798 Z-9.749
N3265 X-42.491 Z-13.111
N3266 X-41.98 Z-16.328
N3267 X-41.346 Z-19.058
N3268 X-40.491 Z-21.866
N3269 X-39.758 Z-23.846
N3270 X-39.033 Z-25.551
N3271 X-38.554 Z-26.583
N3272 X-38.074 Z-27.548
N3273 X-37.595 Z-28.455
N3274 X-36.635 Z-30.125
N3275 X-35.676 Z-31.638
N3276 X-34.839 Z-32.859
N3277 X-34.002 Z-33.989
N3278 X-33.166 Z-35.047
N3279 X-32.329 Z-36.043
N3280 X-31.408 Z-37.073
N3281 X-30.487 Z-38.035
N3282 X-29.566 Z-38.941
N3283 X-28.645 Z-39.796
N3284 X-27.77 Z-40.565
N3285 X-26.895 Z-41.292
N3286 X-26.02 Z-41.981
N3287 X-25.145 Z-42.634
N3288 X-24.233 Z-43.278
N3289 X-23.321 Z-43.886
N3290 X-22.41 Z-44.462
N3291 X-21.498 Z-45.007
N3292 X-19.729 Z-45.98
N3293 X-17.961 Z-46.848
N3294 X-16.151 Z-47.634
N3295 X-14.342 Z-48.323
N3296 X-12.559 Z-48.913
N3297 X-10.776 Z-49.418
N3298 X-8.958 Z-49.849
N3299 X-7.169 Z-50.192
N3300 X-5.362 Z-50.46
N3301 X-3.592 Z-50.648
N3302 X-1.797 Z-50.761
N3303 X0. Z-50.8
N3304 X1.797 Z-50.761
N3305 X3.592 Z-50.648
N3306 X5.362 Z-50.46
N3307 X7.169 Z-50.192
N3308 X8.958 Z-49.849
N3309 X10.776 Z-49.418
N3310 X12.559 Z-48.913
N3311 X14.342 Z-48.323
N3312 X16.151 Z-47.634
N3313 X17.961 Z-46.848
N3314 X18.845 Z-46.427
N3315 X20.614 Z-45.507
N3316 X22.41 Z-44.462
N3317 X23.321 Z-43.886
N3318 X24.233 Z-43.278
N3319 X25.145 Z-42.634
N3320 X26.02 Z-41.981
N3321 X26.895 Z-41.292
N3322 X27.77 Z-40.565
N3323 X28.645 Z-39.796
N3324 X29.566 Z-38.941
N3325 X30.487 Z-38.035
N3326 X31.408 Z-37.073
N3327 X32.329 Z-36.043
N3328 X33.166 Z-35.047
N3329 X34.002 Z-33.989
N3330 X34.839 Z-32.859
N3331 X35.676 Z-31.638
N3332 X36.156 Z-30.898
N3333 X37.115 Z-29.312
N3334 X38.074 Z-27.548
N3335 X38.554 Z-26.583
N3336 X39.033 Z-25.551
N3337 X39.758 Z-23.846
N3338 X40.491 Z-21.866
N3339 X40.979 Z-20.339
N3340 X41.571 Z-18.178
N3341 X42.184 Z-15.229
N3342 X42.44 Z-13.52
N3343 X42.798 Z-9.749
N3344 X43.003 Z-8.618
N3345 X43.217 Z-7.837
N3346 X43.554 Z-6.908
N3347 X43.779 Z-6.404
N3348 X44.228 Z-5.547
N3349 X44.677 Z-4.839
N3350 X45.35 Z-3.957
N3351 X45.799 Z-3.462
N3352 X46.248 Z-3.014
N3353 X46.697 Z-2.618
N3354 X47.146 Z-2.259
N3355 X47.595 Z-1.938
N3356 X48.493 Z-1.387
N3357 X49.391 Z-.944
N3358 X50.289 Z-.594
N3359 X51.187 Z-.33
N3360 X52.085 Z-.145
N3361 X52.984 Z-.036
N3362 X53.882 Z0.
N3363 Y85.775
N3364 X52.984 Z-.036
N3365 X52.085 Z-.145
N3366 X51.187 Z-.33
N3367 X50.289 Z-.594
N3368 X49.391 Z-.944
N3369 X48.493 Z-1.387
N3370 X47.595 Z-1.938
N3371 X47.146 Z-2.259
N3372 X46.697 Z-2.618
N3373 X46.248 Z-3.014
N3374 X45.799 Z-3.462
N3375 X45.35 Z-3.957
N3376 X44.677 Z-4.839
N3377 X44.228 Z-5.547
N3378 X43.779 Z-6.404
N3379 X43.554 Z-6.908
N3380 X43.217 Z-7.837
N3381 X43.003 Z-8.618
N3382 X42.798 Z-9.749
N3383 X42.44 Z-13.52
N3384 X42.184 Z-15.229
N3385 X41.571 Z-18.178
N3386 X40.979 Z-20.339
N3387 X40.491 Z-21.866
N3388 X39.758 Z-23.846
N3389 X39.033 Z-25.551
N3390 X38.554 Z-26.583
N3391 X38.074 Z-27.548
N3392 X37.115 Z-29.312
N3393 X36.156 Z-30.898
N3394 X35.676 Z-31.638
N3395 X34.839 Z-32.859
N3396 X34.002 Z-33.989
N3397 X33.166 Z-35.047
N3398 X32.329 Z-36.043
N3399 X31.408 Z-37.073
N3400 X30.487 Z-38.035
N3401 X29.566 Z-38.941
N3402 X28.645 Z-39.796
N3403 X27.77 Z-40.565
N3404 X26.895 Z-41.292
N3405 X26.02 Z-41.981
N3406 X25.145 Z-42.634
N3407 X24.233 Z-43.278
N3408 X23.321 Z-43.886
N3409 X22.41 Z-44.462
N3410 X20.614 Z-45.507
N3411 X18.845 Z-46.427
N3412 X17.961 Z-46.848
N3413 X16.151 Z-47.634
N3414 X14.342 Z-48.323
N3415 X12.559 Z-48.913
N3416 X10.776 Z-49.418
N3417 X8.958 Z-49.849
N3418 X7.169 Z-50.192
N3419 X5.362 Z-50.46
N3420 X3.592 Z-50.648
N3421 X1.797 Z-50.761
N3422 X0. Z-50.8
N3423 X-1.797 Z-50.761
N3424 X-3.592 Z-50.648
N3425 X-5.362 Z-50.46
N3426 X-7.169 Z-50.192
N3427 X-8.958 Z-49.849
N3428 X-10.776 Z-49.418
N3429 X-12.559 Z-48.913
N3430 X-14.342 Z-48.323
N3431 X-16.151 Z-47.634
N3432 X-17.961 Z-46.848
N3433 X-19.729 Z-45.98
N3434 X-21.498 Z-45.007
N3435 X-22.41 Z-44.462
N3436 X-23.321 Z-43.886
N3437 X-24.233 Z-43.278
N3438 X-25.145 Z-42.634
N3439 X-26.02 Z-41.981
N3440 X-26.895 Z-41.292
N3441 X-27.77 Z-40.565
N3442 X-28.645 Z-39.796
N3443 X-29.566 Z-38.941
N3444 X-30.487 Z-38.035
N3445 X-31.408 Z-37.073
N3446 X-32.329 Z-36.043
N3447 X-33.166 Z-35.047
N3448 X-34.002 Z-33.989
N3449 X-34.839 Z-32.859
N3450 X-35.676 Z-31.638
N3451 X-36.635 Z-30.125
N3452 X-37.595 Z-28.455
N3453 X-38.074 Z-27.548
N3454 X-38.554 Z-26.583
N3455 X-39.033 Z-25.551
N3456 X-39.758 Z-23.846
N3457 X-40.491 Z-21.866
N3458 X-41.346 Z-19.058
N3459 X-41.98 Z-16.328
N3460 X-42.491 Z-13.111
N3461 X-42.798 Z-9.749
N3462 X-42.901 Z-9.11
N3463 X-43.105 Z-8.221
N3464 X-43.33 Z-7.496
N3465 X-43.554 Z-6.908
N3466 X-44.003 Z-5.953
N3467 X-44.452 Z-5.183
N3468 X-44.901 Z-4.527
N3469 X-45.35 Z-3.957
N3470 X-45.799 Z-3.462
N3471 X-46.248 Z-3.014
N3472 X-46.697 Z-2.618
N3473 X-47.146 Z-2.259
N3474 X-47.595 Z-1.938
N3475 X-48.493 Z-1.387
N3476 X-49.391 Z-.944
N3477 X-50.289 Z-.594
N3478 X-51.187 Z-.33
N3479 X-52.085 Z-.145
N3480 X-52.984 Z-.036
N3481 X-53.882 Z0.
N3482 Y84.575
N3483 X-52.984 Z-.036
N3484 X-52.085 Z-.145
N3485 X-51.187 Z-.33
N3486 X-50.289 Z-.594
N3487 X-49.391 Z-.943
N3488 X-48.493 Z-1.387
N3489 X-47.595 Z-1.938
N3490 X-47.146 Z-2.259
N3491 X-46.697 Z-2.618
N3492 X-46.248 Z-3.014
N3493 X-45.799 Z-3.462
N3494 X-45.35 Z-3.957
N3495 X-44.901 Z-4.527
N3496 X-44.452 Z-5.183
N3497 X-44.003 Z-5.953
N3498 X-43.554 Z-6.908
N3499 X-43.33 Z-7.496
N3500 X-43.105 Z-8.221
N3501 X-42.901 Z-9.11
N3502 X-42.798 Z-9.749
N3503 X-42.491 Z-13.111
N3504 X-41.98 Z-16.328
N3505 X-41.346 Z-19.058
N3506 X-40.491 Z-21.866
N3507 X-39.758 Z-23.846
N3508 X-39.033 Z-25.551
N3509 X-38.554 Z-26.583
N3510 X-38.074 Z-27.548
N3511 X-37.595 Z-28.455
N3512 X-36.635 Z-30.125
N3513 X-35.676 Z-31.638
N3514 X-34.839 Z-32.859
N3515 X-34.002 Z-33.989
N3516 X-33.166 Z-35.047
N3517 X-32.329 Z-36.043
N3518 X-31.408 Z-37.073
N3519 X-30.487 Z-38.035
N3520 X-29.566 Z-38.941
N3521 X-28.645 Z-39.796
N3522 X-27.77 Z-40.565
N3523 X-26.895 Z-41.292
N3524 X-26.02 Z-41.981
N3525 X-25.145 Z-42.634
N3526 X-24.233 Z-43.278
N3527 X-23.321 Z-43.886
N3528 X-22.41 Z-44.462
N3529 X-21.498 Z-45.007
N3530 X-19.729 Z-45.98
N3531 X-17.961 Z-46.848
N3532 X-16.151 Z-47.634
N3533 X-14.342 Z-48.323
N3534 X-12.559 Z-48.913
N3535 X-10.776 Z-49.418
N3536 X-8.958 Z-49.849
N3537 X-7.169 Z-50.192
N3538 X-5.362 Z-50.46
N3539 X-3.592 Z-50.648
N3540 X-1.797 Z-50.761
N3541 X0. Z-50.8
N3542 X1.797 Z-50.761
N3543 X3.592 Z-50.648
N3544 X5.362 Z-50.46
N3545 X7.169 Z-50.192
N3546 X8.958 Z-49.849
N3547 X10.776 Z-49.418
N3548 X12.559 Z-48.913
N3549 X14.342 Z-48.323
N3550 X16.151 Z-47.634
N3551 X17.961 Z-46.848
N3552 X18.845 Z-46.427
N3553 X20.614 Z-45.507
N3554 X22.41 Z-44.462
N3555 X23.321 Z-43.886
N3556 X24.233 Z-43.278
N3557 X25.145 Z-42.634
N3558 X26.02 Z-41.981
N3559 X26.895 Z-41.292
N3560 X27.77 Z-40.565
N3561 X28.645 Z-39.796
N3562 X29.566 Z-38.941
N3563 X30.487 Z-38.035
N3564 X31.408 Z-37.073
N3565 X32.329 Z-36.043
N3566 X33.166 Z-35.047
N3567 X34.002 Z-33.989
N3568 X34.839 Z-32.859
N3569 X35.676 Z-31.638
N3570 X36.156 Z-30.898
N3571 X37.115 Z-29.312
N3572 X38.074 Z-27.548
N3573 X38.554 Z-26.583
N3574 X39.033 Z-25.551
N3575 X39.758 Z-23.846
N3576 X40.491 Z-21.866
N3577 X40.979 Z-20.339
N3578 X41.571 Z-18.178
N3579 X42.184 Z-15.229
N3580 X42.44 Z-13.52
N3581 X42.798 Z-9.749
N3582 X43.003 Z-8.618
N3583 X43.217 Z-7.837
N3584 X43.554 Z-6.908
N3585 X43.779 Z-6.404
N3586 X44.228 Z-5.547
N3587 X44.677 Z-4.839
N3588 X45.35 Z-3.957
N3589 X45.799 Z-3.462
N3590 X46.248 Z-3.014
N3591 X46.697 Z-2.618
N3592 X47.146 Z-2.259
N3593 X47.595 Z-1.938
N3594 X48.493 Z-1.387
N3595 X49.391 Z-.943
N3596 X50.289 Z-.594
N3597 X51.187 Z-.33
N3598 X52.085 Z-.145
N3599 X52.984 Z-.036
N3600 X53.882 Z0.
N3601 Y83.375
N3602 X52.984 Z-.036
N3603 X52.085 Z-.145
N3604 X51.187 Z-.33
N3605 X50.289 Z-.594
N3606 X49.391 Z-.943
N3607 X48.493 Z-1.386
N3608 X47.595 Z-1.938
N3609 X47.146 Z-2.259
N3610 X46.697 Z-2.618
N3611 X46.248 Z-3.014
N3612 X45.799 Z-3.462
N3613 X45.35 Z-3.957
N3614 X44.677 Z-4.839
N3615 X44.228 Z-5.547
N3616 X43.779 Z-6.405
N3617 X43.554 Z-6.908
N3618 X43.217 Z-7.837
N3619 X43.003 Z-8.618
N3620 X42.798 Z-9.749
N3621 X42.44 Z-13.52
N3622 X42.184 Z-15.229
N3623 X41.571 Z-18.178
N3624 X40.979 Z-20.339
N3625 X40.491 Z-21.866
N3626 X39.758 Z-23.846
N3627 X39.033 Z-25.551
N3628 X38.554 Z-26.583
N3629 X38.074 Z-27.548
N3630 X37.115 Z-29.312
N3631 X36.156 Z-30.898
N3632 X35.676 Z-31.638
N3633 X34.839 Z-32.859
N3634 X34.002 Z-33.989
N3635 X33.166 Z-35.047
N3636 X32.329 Z-36.043
N3637 X31.408 Z-37.073
N3638 X30.487 Z-38.035
N3639 X29.566 Z-38.941
N3640 X28.645 Z-39.796
N3641 X27.77 Z-40.565
N3642 X26.895 Z-41.292
N3643 X26.02 Z-41.981
N3644 X25.145 Z-42.634
N3645 X24.233 Z-43.278
N3646 X23.321 Z-43.886
N3647 X22.41 Z-44.462
N3648 X20.614 Z-45.507
N3649 X18.845 Z-46.427
N3650 X17.961 Z-46.848
N3651 X16.151 Z-47.634
N3652 X14.342 Z-48.323
N3653 X12.559 Z-48.913
N3654 X10.776 Z-49.418
N3655 X8.958 Z-49.849
N3656 X7.169 Z-50.192
N3657 X5.362 Z-50.46
N3658 X3.592 Z-50.648
N3659 X1.797 Z-50.761
N3660 X0. Z-50.8
N3661 X-1.797 Z-50.761
N3662 X-3.592 Z-50.648
N3663 X-5.362 Z-50.46
N3664 X-7.169 Z-50.192
N3665 X-8.958 Z-49.849
N3666 X-10.776 Z-49.418
N3667 X-12.559 Z-48.913
N3668 X-14.342 Z-48.323
N3669 X-16.151 Z-47.634
N3670 X-17.961 Z-46.848
N3671 X-19.729 Z-45.98
N3672 X-21.498 Z-45.007
N3673 X-22.41 Z-44.462
N3674 X-23.321 Z-43.886
N3675 X-24.233 Z-43.278
N3676 X-25.145 Z-42.634
N3677 X-26.02 Z-41.981
N3678 X-26.895 Z-41.292
N3679 X-27.77 Z-40.565
N3680 X-28.645 Z-39.796
N3681 X-29.566 Z-38.941
N3682 X-30.487 Z-38.035
N3683 X-31.408 Z-37.073
N3684 X-32.329 Z-36.043
N3685 X-33.166 Z-35.047
N3686 X-34.002 Z-33.989
N3687 X-34.839 Z-32.859
N3688 X-35.676 Z-31.638
N3689 X-36.635 Z-30.125
N3690 X-37.595 Z-28.455
N3691 X-38.074 Z-27.548
N3692 X-38.554 Z-26.583
N3693 X-39.033 Z-25.551
N3694 X-39.758 Z-23.846
N3695 X-40.491 Z-21.866
N3696 X-41.346 Z-19.058
N3697 X-41.98 Z-16.328
N3698 X-42.491 Z-13.111
N3699 X-42.798 Z-9.749
N3700 X-42.901 Z-9.109
N3701 X-43.105 Z-8.221
N3702 X-43.33 Z-7.496
N3703 X-43.554 Z-6.908
N3704 X-44.003 Z-5.953
N3705 X-44.452 Z-5.183
N3706 X-44.901 Z-4.527
N3707 X-45.35 Z-3.957
N3708 X-45.799 Z-3.462
N3709 X-46.248 Z-3.014
N3710 X-46.697 Z-2.618
N3711 X-47.146 Z-2.259
N3712 X-47.595 Z-1.937
N3713 X-48.493 Z-1.386
N3714 X-49.391 Z-.943
N3715 X-50.289 Z-.594
N3716 X-51.187 Z-.33
N3717 X-52.085 Z-.145
N3718 X-52.984 Z-.036
N3719 X-53.882 Z0.
N3720 Y82.175
N3721 X-52.984 Z-.036
N3722 X-52.085 Z-.145
N3723 X-51.187 Z-.33
N3724 X-50.289 Z-.594
N3725 X-49.391 Z-.943
N3726 X-48.493 Z-1.386
N3727 X-47.595 Z-1.937
N3728 X-47.146 Z-2.259
N3729 X-46.697 Z-2.618
N3730 X-46.248 Z-3.014
N3731 X-45.799 Z-3.462
N3732 X-45.35 Z-3.957
N3733 X-44.901 Z-4.527
N3734 X-44.452 Z-5.183
N3735 X-44.003 Z-5.953
N3736 X-43.554 Z-6.908
N3737 X-43.33 Z-7.496
N3738 X-43.105 Z-8.221
N3739 X-42.901 Z-9.109
N3740 X-42.798 Z-9.748
N3741 X-42.491 Z-13.111
N3742 X-41.98 Z-16.328
N3743 X-41.346 Z-19.058
N3744 X-40.491 Z-21.866
N3745 X-39.758 Z-23.846
N3746 X-39.033 Z-25.551
N3747 X-38.554 Z-26.583
N3748 X-38.074 Z-27.548
N3749 X-37.595 Z-28.455
N3750 X-36.635 Z-30.125
N3751 X-35.676 Z-31.638
N3752 X-34.839 Z-32.859
N3753 X-34.002 Z-33.989
N3754 X-33.166 Z-35.047
N3755 X-32.329 Z-36.043
N3756 X-31.408 Z-37.073
N3757 X-30.487 Z-38.035
N3758 X-29.566 Z-38.941
N3759 X-28.645 Z-39.796
N3760 X-27.77 Z-40.565
N3761 X-26.895 Z-41.292
N3762 X-26.02 Z-41.981
N3763 X-25.145 Z-42.634
N3764 X-24.233 Z-43.278
N3765 X-23.321 Z-43.886
N3766 X-22.41 Z-44.462
N3767 X-21.498 Z-45.007
N3768 X-19.729 Z-45.98
N3769 X-17.961 Z-46.848
N3770 X-16.151 Z-47.634
N3771 X-14.342 Z-48.323
N3772 X-12.559 Z-48.913
N3773 X-10.776 Z-49.418
N3774 X-8.958 Z-49.849
N3775 X-7.169 Z-50.192
N3776 X-5.362 Z-50.46
N3777 X-3.592 Z-50.648
N3778 X-1.797 Z-50.761
N3779 X0. Z-50.8
N3780 X1.797 Z-50.761
N3781 X3.592 Z-50.648
N3782 X5.362 Z-50.46
N3783 X7.169 Z-50.192
N3784 X8.958 Z-49.849
N3785 X10.776 Z-49.418
N3786 X12.559 Z-48.913
N3787 X14.342 Z-48.323
N3788 X16.151 Z-47.634
N3789 X17.961 Z-46.848
N3790 X18.845 Z-46.427
N3791 X20.614 Z-45.507
N3792 X22.41 Z-44.462
N3793 X23.321 Z-43.886
N3794 X24.233 Z-43.278
N3795 X25.145 Z-42.634
N3796 X26.02 Z-41.981
N3797 X26.895 Z-41.292
N3798 X27.77 Z-40.565
N3799 X28.645 Z-39.796
N3800 X29.566 Z-38.941
N3801 X30.487 Z-38.035
N3802 X31.408 Z-37.073
N3803 X32.329 Z-36.043
N3804 X33.166 Z-35.047
N3805 X34.002 Z-33.989
N3806 X34.839 Z-32.859
N3807 X35.676 Z-31.638
N3808 X36.156 Z-30.898
N3809 X37.115 Z-29.312
N3810 X38.074 Z-27.548
N3811 X38.554 Z-26.583
N3812 X39.033 Z-25.551
N3813 X39.758 Z-23.846
N3814 X40.491 Z-21.866
N3815 X40.979 Z-20.339
N3816 X41.571 Z-18.178
N3817 X42.184 Z-15.229
N3818 X42.44 Z-13.52
N3819 X42.798 Z-9.748
N3820 X43.003 Z-8.618
N3821 X43.217 Z-7.837
N3822 X43.554 Z-6.908
N3823 X43.779 Z-6.405
N3824 X44.228 Z-5.547
N3825 X44.677 Z-4.839
N3826 X45.35 Z-3.957
N3827 X45.799 Z-3.462
N3828 X46.248 Z-3.014
N3829 X46.697 Z-2.618
N3830 X47.146 Z-2.259
N3831 X47.595 Z-1.937
N3832 X48.493 Z-1.386
N3833 X49.391 Z-.943
N3834 X50.289 Z-.594
N3835 X51.187 Z-.33
N3836 X52.085 Z-.145
N3837 X52.984 Z-.036
N3838 X53.882 Z0.
N3839 Y80.975
N3840 X52.984 Z-.036
N3841 X52.085 Z-.145
N3842 X51.187 Z-.33
N3843 X50.289 Z-.594
N3844 X49.391 Z-.943
N3845 X48.493 Z-1.386
N3846 X47.595 Z-1.937
N3847 X47.146 Z-2.259
N3848 X46.697 Z-2.618
N3849 X46.248 Z-3.014
N3850 X45.799 Z-3.462
N3851 X45.35 Z-3.957
N3852 X44.677 Z-4.839
N3853 X44.228 Z-5.548
N3854 X43.779 Z-6.405
N3855 X43.554 Z-6.908
N3856 X43.217 Z-7.837
N3857 X43.003 Z-8.618
N3858 X42.798 Z-9.748
N3859 X42.44 Z-13.52
N3860 X42.184 Z-15.229
N3861 X41.571 Z-18.178
N3862 X40.979 Z-20.339
N3863 X40.491 Z-21.866
N3864 X39.758 Z-23.846
N3865 X39.033 Z-25.551
N3866 X38.554 Z-26.583
N3867 X38.074 Z-27.548
N3868 X37.115 Z-29.312
N3869 X36.156 Z-30.898
N3870 X35.676 Z-31.638
N3871 X34.839 Z-32.859
N3872 X34.002 Z-33.989
N3873 X33.166 Z-35.047
N3874 X32.329 Z-36.043
N3875 X31.408 Z-37.073
N3876 X30.487 Z-38.035
N3877 X29.566 Z-38.941
N3878 X28.645 Z-39.796
N3879 X27.77 Z-40.565
N3880 X26.895 Z-41.292
N3881 X26.02 Z-41.981
N3882 X25.145 Z-42.634
N3883 X24.233 Z-43.278
N3884 X23.321 Z-43.886
N3885 X22.41 Z-44.462
N3886 X20.614 Z-45.507
N3887 X18.845 Z-46.427
N3888 X17.961 Z-46.848
N3889 X16.151 Z-47.634
N3890 X14.342 Z-48.323
N3891 X12.559 Z-48.913
N3892 X10.776 Z-49.418
N3893 X8.958 Z-49.849
N3894 X7.169 Z-50.192
N3895 X5.362 Z-50.46
N3896 X3.592 Z-50.648
N3897 X1.797 Z-50.761
N3898 X0. Z-50.8
N3899 X-1.797 Z-50.761
N3900 X-3.592 Z-50.648
N3901 X-5.362 Z-50.46
N3902 X-7.169 Z-50.192
N3903 X-8.958 Z-49.849
N3904 X-10.776 Z-49.418
N3905 X-12.559 Z-48.913
N3906 X-14.342 Z-48.323
N3907 X-16.151 Z-47.634
N3908 X-17.961 Z-46.848
N3909 X-19.729 Z-45.98
N3910 X-21.498 Z-45.007
N3911 X-22.41 Z-44.462
N3912 X-23.321 Z-43.886
N3913 X-24.233 Z-43.278
N3914 X-25.145 Z-42.634
N3915 X-26.02 Z-41.981
N3916 X-26.895 Z-41.292
N3917 X-27.77 Z-40.565
N3918 X-28.645 Z-39.796
N3919 X-29.566 Z-38.941
N3920 X-30.487 Z-38.035
N3921 X-31.408 Z-37.073
N3922 X-32.329 Z-36.043
N3923 X-33.166 Z-35.047
N3924 X-34.002 Z-33.989
N3925 X-34.839 Z-32.859
N3926 X-35.676 Z-31.638
N3927 X-36.635 Z-30.125
N3928 X-37.595 Z-28.455
N3929 X-38.074 Z-27.548
N3930 X-38.554 Z-26.583
N3931 X-39.033 Z-25.551
N3932 X-39.758 Z-23.846
N3933 X-40.491 Z-21.866
N3934 X-41.346 Z-19.058
N3935 X-41.98 Z-16.328
N3936 X-42.491 Z-13.111
N3937 X-42.798 Z-9.748
N3938 X-42.901 Z-9.109
N3939 X-43.105 Z-8.22
N3940 X-43.33 Z-7.496
N3941 X-43.554 Z-6.908
N3942 X-44.003 Z-5.953
N3943 X-44.452 Z-5.183
N3944 X-44.901 Z-4.527
N3945 X-45.35 Z-3.957
N3946 X-45.799 Z-3.462
N3947 X-46.248 Z-3.014
N3948 X-46.697 Z-2.618
N3949 X-47.146 Z-2.259
N3950 X-47.595 Z-1.937
N3951 X-48.493 Z-1.386
N3952 X-49.391 Z-.943
N3953 X-50.289 Z-.594
N3954 X-51.187 Z-.33
N3955 X-52.085 Z-.145
N3956 X-52.984 Z-.036
N3957 X-53.882 Z0.
N3958 Y79.775
N3959 X-52.984 Z-.036
N3960 X-52.085 Z-.145
N3961 X-51.187 Z-.33
N3962 X-50.289 Z-.594
N3963 X-49.391 Z-.943
N3964 X-48.493 Z-1.386
N3965 X-47.595 Z-1.937
N3966 X-47.146 Z-2.259
N3967 X-46.697 Z-2.618
N3968 X-46.248 Z-3.014
N3969 X-45.799 Z-3.462
N3970 X-45.35 Z-3.957
N3971 X-44.901 Z-4.527
N3972 X-44.452 Z-5.183
N3973 X-44.003 Z-5.953
N3974 X-43.554 Z-6.908
N3975 X-43.33 Z-7.496
N3976 X-43.105 Z-8.22
N3977 X-42.901 Z-9.109
N3978 X-42.798 Z-9.748
N3979 X-42.491 Z-13.111
N3980 X-41.98 Z-16.328
N3981 X-41.346 Z-19.058
N3982 X-40.491 Z-21.866
N3983 X-39.758 Z-23.846
N3984 X-39.033 Z-25.551
N3985 X-38.554 Z-26.583
N3986 X-38.074 Z-27.548
N3987 X-37.595 Z-28.455
N3988 X-36.635 Z-30.125
N3989 X-35.676 Z-31.638
N3990 X-34.839 Z-32.859
N3991 X-34.002 Z-33.989
N3992 X-33.166 Z-35.047
N3993 X-32.329 Z-36.043
N3994 X-31.408 Z-37.073
N3995 X-30.487 Z-38.035
N3996 X-29.566 Z-38.941
N3997 X-28.645 Z-39.796
N3998 X-27.77 Z-40.565
N3999 X-26.895 Z-41.292
N4000 X-26.02 Z-41.981
N4001 X-25.145 Z-42.634
N4002 X-24.233 Z-43.278
N4003 X-23.321 Z-43.886
N4004 X-22.41 Z-44.462
N4005 X-21.498 Z-45.007
N4006 X-19.729 Z-45.98
N4007 X-17.961 Z-46.848
N4008 X-16.151 Z-47.634
N4009 X-14.342 Z-48.323
N4010 X-12.559 Z-48.913
N4011 X-10.776 Z-49.418
N4012 X-8.958 Z-49.849
N4013 X-7.169 Z-50.192
N4014 X-5.362 Z-50.46
N4015 X-3.592 Z-50.648
N4016 X-1.797 Z-50.761
N4017 X0. Z-50.8
N4018 X1.797 Z-50.761
N4019 X3.592 Z-50.648
N4020 X5.362 Z-50.46
N4021 X7.169 Z-50.192
N4022 X8.958 Z-49.849
N4023 X10.776 Z-49.418
N4024 X12.559 Z-48.913
N4025 X14.342 Z-48.323
N4026 X16.151 Z-47.634
N4027 X17.961 Z-46.848
N4028 X18.845 Z-46.427
N4029 X20.614 Z-45.507
N4030 X22.41 Z-44.462
N4031 X23.321 Z-43.886
N4032 X24.233 Z-43.278
N4033 X25.145 Z-42.634
N4034 X26.02 Z-41.981
N4035 X26.895 Z-41.292
N4036 X27.77 Z-40.565
N4037 X28.645 Z-39.796
N4038 X29.566 Z-38.941
N4039 X30.487 Z-38.035
N4040 X31.408 Z-37.073
N4041 X32.329 Z-36.043
N4042 X33.166 Z-35.047
N4043 X34.002 Z-33.989
N4044 X34.839 Z-32.859
N4045 X35.676 Z-31.638
N4046 X36.156 Z-30.898
N4047 X37.115 Z-29.312
N4048 X38.074 Z-27.548
N4049 X38.554 Z-26.583
N4050 X39.033 Z-25.551
N4051 X39.758 Z-23.846
N4052 X40.491 Z-21.866
N4053 X40.979 Z-20.339
N4054 X41.571 Z-18.178
N4055 X42.184 Z-15.229
N4056 X42.44 Z-13.52
N4057 X42.798 Z-9.748
N4058 X43.003 Z-8.618
N4059 X43.217 Z-7.837
N4060 X43.554 Z-6.908
N4061 X43.779 Z-6.405
N4062 X44.228 Z-5.548
N4063 X44.677 Z-4.839
N4064 X45.35 Z-3.957
N4065 X45.799 Z-3.462
N4066 X46.248 Z-3.014
N4067 X46.697 Z-2.618
N4068 X47.146 Z-2.259
N4069 X47.595 Z-1.937
N4070 X48.493 Z-1.386
N4071 X49.391 Z-.943
N4072 X50.289 Z-.594
N4073 X51.187 Z-.33
N4074 X52.085 Z-.145
N4075 X52.984 Z-.036
N4076 X53.882 Z0.
N4077 Y78.575
N4078 X52.984 Z-.036
N4079 X52.085 Z-.145
N4080 X51.187 Z-.33
N4081 X50.289 Z-.594
N4082 X49.391 Z-.943
N4083 X48.493 Z-1.386
N4084 X47.595 Z-1.937
N4085 X47.146 Z-2.259
N4086 X46.697 Z-2.618
N4087 X46.248 Z-3.014
N4088 X45.799 Z-3.462
N4089 X45.35 Z-3.957
N4090 X44.677 Z-4.839
N4091 X44.228 Z-5.548
N4092 X43.779 Z-6.405
N4093 X43.554 Z-6.908
N4094 X43.217 Z-7.837
N4095 X43.003 Z-8.618
N4096 X42.798 Z-9.748
N4097 X42.44 Z-13.52
N4098 X42.184 Z-15.229
N4099 X41.571 Z-18.178
N4100 X40.979 Z-20.339
N4101 X40.491 Z-21.866
N4102 X39.758 Z-23.846
N4103 X39.033 Z-25.551
N4104 X38.554 Z-26.583
N4105 X38.074 Z-27.548
N4106 X37.115 Z-29.312
N4107 X36.156 Z-30.898
N4108 X35.676 Z-31.638
N4109 X34.839 Z-32.859
N4110 X34.002 Z-33.989
N4111 X33.166 Z-35.047
N4112 X32.329 Z-36.043
N4113 X31.408 Z-37.073
N4114 X30.487 Z-38.035
N4115 X29.566 Z-38.941
N4116 X28.645 Z-39.796
N4117 X27.77 Z-40.565
N4118 X26.895 Z-41.292
N4119 X26.02 Z-41.981
N4120 X25.145 Z-42.634
N4121 X24.233 Z-43.278
N4122 X23.321 Z-43.886
N4123 X22.41 Z-44.462
N4124 X20.614 Z-45.507
N4125 X18.845 Z-46.427
N4126 X17.961 Z-46.848
N4127 X16.151 Z-47.634
N4128 X14.342 Z-48.323
N4129 X12.559 Z-48.913
N4130 X10.776 Z-49.418
N4131 X8.958 Z-49.849
N4132 X7.169 Z-50.192
N4133 X5.362 Z-50.46
N4134 X3.592 Z-50.648
N4135 X1.797 Z-50.761
N4136 X0. Z-50.8
N4137 X-1.797 Z-50.761
N4138 X-3.592 Z-50.648
N4139 X-5.362 Z-50.46
N4140 X-7.169 Z-50.192
N4141 X-8.958 Z-49.849
N4142 X-10.776 Z-49.418
N4143 X-12.559 Z-48.913
N4144 X-14.342 Z-48.323
N4145 X-16.151 Z-47.634
N4146 X-17.961 Z-46.848
N4147 X-19.729 Z-45.98
N4148 X-21.498 Z-45.007
N4149 X-22.41 Z-44.462
N4150 X-23.321 Z-43.886
N4151 X-24.233 Z-43.278
N4152 X-25.145 Z-42.634
N4153 X-26.02 Z-41.981
N4154 X-26.895 Z-41.292
N4155 X-27.77 Z-40.565
N4156 X-28.645 Z-39.796
N4157 X-29.566 Z-38.941
N4158 X-30.487 Z-38.035
N4159 X-31.408 Z-37.073
N4160 X-32.329 Z-36.043
N4161 X-33.166 Z-35.047
N4162 X-34.002 Z-33.989
N4163 X-34.839 Z-32.859
N4164 X-35.676 Z-31.638
N4165 X-36.635 Z-30.125
N4166 X-37.595 Z-28.455
N4167 X-38.074 Z-27.548
N4168 X-38.554 Z-26.583
N4169 X-39.033 Z-25.551
N4170 X-39.758 Z-23.846
N4171 X-40.491 Z-21.866
N4172 X-41.346 Z-19.058
N4173 X-41.98 Z-16.328
N4174 X-42.491 Z-13.111
N4175 X-42.798 Z-9.748
N4176 X-42.901 Z-9.108
N4177 X-43.105 Z-8.22
N4178 X-43.33 Z-7.496
N4179 X-43.554 Z-6.908
N4180 X-44.003 Z-5.953
N4181 X-44.452 Z-5.183
N4182 X-44.901 Z-4.527
N4183 X-45.35 Z-3.957
N4184 X-45.799 Z-3.462
N4185 X-46.248 Z-3.014
N4186 X-46.697 Z-2.618
N4187 X-47.146 Z-2.259
N4188 X-47.595 Z-1.937
N4189 X-48.493 Z-1.386
N4190 X-49.391 Z-.943
N4191 X-50.289 Z-.594
N4192 X-51.187 Z-.33
N4193 X-52.085 Z-.145
N4194 X-52.984 Z-.036
N4195 X-53.882 Z0.
N4196 Y77.375
N4197 X-52.984 Z-.036
N4198 X-52.085 Z-.145
N4199 X-51.187 Z-.33
N4200 X-50.289 Z-.594
N4201 X-49.391 Z-.943
N4202 X-48.493 Z-1.386
N4203 X-47.595 Z-1.937
N4204 X-47.146 Z-2.259
N4205 X-46.697 Z-2.618
N4206 X-46.248 Z-3.014
N4207 X-45.799 Z-3.462
N4208 X-45.35 Z-3.957
N4209 X-44.901 Z-4.527
N4210 X-44.452 Z-5.183
N4211 X-44.003 Z-5.953
N4212 X-43.554 Z-6.907
N4213 X-43.33 Z-7.496
N4214 X-43.105 Z-8.22
N4215 X-42.901 Z-9.108
N4216 X-42.798 Z-9.748
N4217 X-42.491 Z-13.111
N4218 X-41.98 Z-16.328
N4219 X-41.346 Z-19.058
N4220 X-40.491 Z-21.866
N4221 X-39.758 Z-23.846
N4222 X-39.033 Z-25.551
N4223 X-38.554 Z-26.583
N4224 X-38.074 Z-27.548
N4225 X-37.595 Z-28.455
N4226 X-36.635 Z-30.125
N4227 X-35.676 Z-31.638
N4228 X-34.839 Z-32.859
N4229 X-34.002 Z-33.989
N4230 X-33.166 Z-35.047
N4231 X-32.329 Z-36.043
N4232 X-31.408 Z-37.073
N4233 X-30.487 Z-38.035
N4234 X-29.566 Z-38.941
N4235 X-28.645 Z-39.796
N4236 X-27.77 Z-40.565
N4237 X-26.895 Z-41.292
N4238 X-26.02 Z-41.981
N4239 X-25.145 Z-42.634
N4240 X-24.233 Z-43.278
N4241 X-23.321 Z-43.886
N4242 X-22.41 Z-44.462
N4243 X-21.498 Z-45.007
N4244 X-19.729 Z-45.98
N4245 X-17.961 Z-46.848
N4246 X-16.151 Z-47.634
N4247 X-14.342 Z-48.323
N4248 X-12.559 Z-48.913
N4249 X-10.776 Z-49.418
N4250 X-8.958 Z-49.849
N4251 X-7.169 Z-50.192
N4252 X-5.362 Z-50.46
N4253 X-3.592 Z-50.648
N4254 X-1.797 Z-50.761
N4255 X0. Z-50.8
N4256 X1.797 Z-50.761
N4257 X3.592 Z-50.648
N4258 X5.362 Z-50.46
N4259 X7.169 Z-50.192
N4260 X8.958 Z-49.849
N4261 X10.776 Z-49.418
N4262 X12.559 Z-48.913
N4263 X14.342 Z-48.323
N4264 X16.151 Z-47.634
N4265 X17.961 Z-46.848
N4266 X18.845 Z-46.427
N4267 X20.614 Z-45.507
N4268 X22.41 Z-44.462
N4269 X23.321 Z-43.886
N4270 X24.233 Z-43.278
N4271 X25.145 Z-42.634
N4272 X26.02 Z-41.981
N4273 X26.895 Z-41.292
N4274 X27.77 Z-40.565
N4275 X28.645 Z-39.796
N4276 X29.566 Z-38.941
N4277 X30.487 Z-38.035
N4278 X31.408 Z-37.073
N4279 X32.329 Z-36.043
N4280 X33.166 Z-35.047
N4281 X34.002 Z-33.989
N4282 X34.839 Z-32.859
N4283 X35.676 Z-31.638
N4284 X36.156 Z-30.898
N4285 X37.115 Z-29.312
N4286 X38.074 Z-27.548
N4287 X38.554 Z-26.583
N4288 X39.033 Z-25.551
N4289 X39.758 Z-23.846
N4290 X40.491 Z-21.866
N4291 X40.979 Z-20.339
N4292 X41.571 Z-18.178
N4293 X42.184 Z-15.229
N4294 X42.44 Z-13.52
N4295 X42.798 Z-9.748
N4296 X43.003 Z-8.618
N4297 X43.217 Z-7.837
N4298 X43.554 Z-6.907
N4299 X43.779 Z-6.405
N4300 X44.228 Z-5.548
N4301 X44.677 Z-4.839
N4302 X45.35 Z-3.957
N4303 X45.799 Z-3.462
N4304 X46.248 Z-3.014
N4305 X46.697 Z-2.618
N4306 X47.146 Z-2.259
N4307 X47.595 Z-1.937
N4308 X48.493 Z-1.386
N4309 X49.391 Z-.943
N4310 X50.289 Z-.594
N4311 X51.187 Z-.33
N4312 X52.085 Z-.145
N4313 X52.984 Z-.036
N4314 X53.882 Z0.
N4315 Y76.175
N4316 X52.984 Z-.036
N4317 X52.085 Z-.145
N4318 X51.187 Z-.33
N4319 X50.289 Z-.594
N4320 X49.391 Z-.943
N4321 X48.493 Z-1.386
N4322 X47.595 Z-1.937
N4323 X47.146 Z-2.259
N4324 X46.697 Z-2.618
N4325 X46.248 Z-3.014
N4326 X45.799 Z-3.462
N4327 X45.35 Z-3.957
N4328 X44.677 Z-4.839
N4329 X44.228 Z-5.548
N4330 X43.779 Z-6.405
N4331 X43.554 Z-6.907
N4332 X43.217 Z-7.837
N4333 X43.003 Z-8.618
N4334 X42.798 Z-9.748
N4335 X42.44 Z-13.52
N4336 X42.184 Z-15.229
N4337 X41.571 Z-18.178
N4338 X40.979 Z-20.339
N4339 X40.491 Z-21.866
N4340 X39.758 Z-23.846
N4341 X39.033 Z-25.551
N4342 X38.554 Z-26.583
N4343 X38.074 Z-27.548
N4344 X37.115 Z-29.312
N4345 X36.156 Z-30.898
N4346 X35.676 Z-31.638
N4347 X34.839 Z-32.859
N4348 X34.002 Z-33.989
N4349 X33.166 Z-35.047
N4350 X32.329 Z-36.043
N4351 X31.408 Z-37.073
N4352 X30.487 Z-38.035
N4353 X29.566 Z-38.941
N4354 X28.645 Z-39.796
N4355 X27.77 Z-40.565
N4356 X26.895 Z-41.292
N4357 X26.02 Z-41.981
N4358 X25.145 Z-42.634
N4359 X24.233 Z-43.278
N4360 X23.321 Z-43.886
N4361 X22.41 Z-44.462
N4362 X20.614 Z-45.507
N4363 X18.845 Z-46.427
N4364 X17.961 Z-46.848
N4365 X16.151 Z-47.634
N4366 X14.342 Z-48.323
N4367 X12.559 Z-48.913
N4368 X10.776 Z-49.418
N4369 X8.958 Z-49.849
N4370 X7.169 Z-50.192
N4371 X5.362 Z-50.46
N4372 X3.592 Z-50.648
N4373 X1.797 Z-50.761
N4374 X0. Z-50.8
N4375 X-1.797 Z-50.761
N4376 X-3.592 Z-50.648
N4377 X-5.362 Z-50.46
N4378 X-7.169 Z-50.192
N4379 X-8.958 Z-49.849
N4380 X-10.776 Z-49.418
N4381 X-12.559 Z-48.913
N4382 X-14.342 Z-48.323
N4383 X-16.151 Z-47.634
N4384 X-17.961 Z-46.848
N4385 X-19.729 Z-45.98
N4386 X-21.498 Z-45.007
N4387 X-22.41 Z-44.462
N4388 X-23.321 Z-43.886
N4389 X-24.233 Z-43.278
N4390 X-25.145 Z-42.634
N4391 X-26.02 Z-41.981
N4392 X-26.895 Z-41.292
N4393 X-27.77 Z-40.565
N4394 X-28.645 Z-39.796
N4395 X-29.566 Z-38.941
N4396 X-30.487 Z-38.035
N4397 X-31.408 Z-37.073
N4398 X-32.329 Z-36.043
N4399 X-33.166 Z-35.047
N4400 X-34.002 Z-33.989
N4401 X-34.839 Z-32.859
N4402 X-35.676 Z-31.638
N4403 X-36.635 Z-30.125
N4404 X-37.595 Z-28.455
N4405 X-38.074 Z-27.548
N4406 X-38.554 Z-26.583
N4407 X-39.033 Z-25.551
N4408 X-39.758 Z-23.846
N4409 X-40.491 Z-21.866
N4410 X-41.346 Z-19.058
N4411 X-41.98 Z-16.328
N4412 X-42.491 Z-13.111
N4413 X-42.798 Z-9.748
N4414 X-42.901 Z-9.108
N4415 X-43.105 Z-8.22
N4416 X-43.33 Z-7.496
N4417 X-43.554 Z-6.907
N4418 X-44.003 Z-5.953
N4419 X-44.452 Z-5.183
N4420 X-44.901 Z-4.527
N4421 X-45.35 Z-3.957
N4422 X-45.799 Z-3.462
N4423 X-46.248 Z-3.014
N4424 X-46.697 Z-2.618
N4425 X-47.146 Z-2.259
N4426 X-47.595 Z-1.937
N4427 X-48.493 Z-1.386
N4428 X-49.391 Z-.943
N4429 X-50.289 Z-.594
N4430 X-51.187 Z-.33
N4431 X-52.085 Z-.145
N4432 X-52.984 Z-.036
N4433 X-53.882 Z0.
N4434 Y74.975
N4435 X-52.984 Z-.036
N4436 X-52.085 Z-.145
N4437 X-51.187 Z-.33
N4438 X-50.289 Z-.594
N4439 X-49.391 Z-.943
N4440 X-48.493 Z-1.386
N4441 X-47.595 Z-1.937
N4442 X-47.146 Z-2.259
N4443 X-46.697 Z-2.618
N4444 X-46.248 Z-3.014
N4445 X-45.799 Z-3.462
N4446 X-45.35 Z-3.957
N4447 X-44.901 Z-4.527
N4448 X-44.452 Z-5.183
N4449 X-44.003 Z-5.953
N4450 X-43.554 Z-6.907
N4451 X-43.33 Z-7.496
N4452 X-43.105 Z-8.22
N4453 X-42.901 Z-9.108
N4454 X-42.798 Z-9.748
N4455 X-42.491 Z-13.111
N4456 X-41.98 Z-16.328
N4457 X-41.346 Z-19.058
N4458 X-40.491 Z-21.866
N4459 X-39.758 Z-23.846
N4460 X-39.033 Z-25.551
N4461 X-38.554 Z-26.583
N4462 X-38.074 Z-27.548
N4463 X-37.595 Z-28.455
N4464 X-36.635 Z-30.125
N4465 X-35.676 Z-31.638
N4466 X-34.839 Z-32.859
N4467 X-34.002 Z-33.989
N4468 X-33.166 Z-35.047
N4469 X-32.329 Z-36.043
N4470 X-31.408 Z-37.073
N4471 X-30.487 Z-38.035
N4472 X-29.566 Z-38.941
N4473 X-28.645 Z-39.796
N4474 X-27.77 Z-40.565
N4475 X-26.895 Z-41.292
N4476 X-26.02 Z-41.981
N4477 X-25.145 Z-42.634
N4478 X-24.233 Z-43.278
N4479 X-23.321 Z-43.886
N4480 X-22.41 Z-44.462
N4481 X-21.498 Z-45.007
N4482 X-19.729 Z-45.98
N4483 X-17.961 Z-46.848
N4484 X-16.151 Z-47.634
N4485 X-14.342 Z-48.323
N4486 X-12.559 Z-48.913
N4487 X-10.776 Z-49.418
N4488 X-8.958 Z-49.849
N4489 X-7.169 Z-50.192
N4490 X-5.362 Z-50.46
N4491 X-3.592 Z-50.648
N4492 X-1.797 Z-50.761
N4493 X0. Z-50.8
N4494 X1.797 Z-50.761
N4495 X3.592 Z-50.648
N4496 X5.362 Z-50.46
N4497 X7.169 Z-50.192
N4498 X8.958 Z-49.849
N4499 X10.776 Z-49.418
N4500 X12.559 Z-48.913
N4501 X14.342 Z-48.323
N4502 X16.151 Z-47.634
N4503 X17.961 Z-46.848
N4504 X18.845 Z-46.427
N4505 X20.614 Z-45.507
N4506 X22.41 Z-44.462
N4507 X23.321 Z-43.886
N4508 X24.233 Z-43.278
N4509 X25.145 Z-42.634
N4510 X26.02 Z-41.981
N4511 X26.895 Z-41.292
N4512 X27.77 Z-40.565
N4513 X28.645 Z-39.796
N4514 X29.566 Z-38.941
N4515 X30.487 Z-38.035
N4516 X31.408 Z-37.073
N4517 X32.329 Z-36.043
N4518 X33.166 Z-35.047
N4519 X34.002 Z-33.989
N4520 X34.839 Z-32.859
N4521 X35.676 Z-31.638
N4522 X36.156 Z-30.898
N4523 X37.115 Z-29.312
N4524 X38.074 Z-27.548
N4525 X38.554 Z-26.583
N4526 X39.033 Z-25.551
N4527 X39.758 Z-23.846
N4528 X40.491 Z-21.866
N4529 X40.979 Z-20.339
N4530 X41.571 Z-18.178
N4531 X42.184 Z-15.229
N4532 X42.44 Z-13.52
N4533 X42.798 Z-9.748
N4534 X43.003 Z-8.618
N4535 X43.217 Z-7.836
N4536 X43.554 Z-6.907
N4537 X43.779 Z-6.405
N4538 X44.228 Z-5.548
N4539 X44.677 Z-4.839
N4540 X45.35 Z-3.957
N4541 X45.799 Z-3.462
N4542 X46.248 Z-3.014
N4543 X46.697 Z-2.618
N4544 X47.146 Z-2.259
N4545 X47.595 Z-1.937
N4546 X48.493 Z-1.386
N4547 X49.391 Z-.943
N4548 X50.289 Z-.594
N4549 X51.187 Z-.33
N4550 X52.085 Z-.145
N4551 X52.984 Z-.036
N4552 X53.882 Z0.
N4553 Y73.775
N4554 X52.984 Z-.036
N4555 X52.085 Z-.145
N4556 X51.187 Z-.33
N4557 X50.289 Z-.594
N4558 X49.391 Z-.943
N4559 X48.493 Z-1.386
N4560 X47.595 Z-1.937
N4561 X47.146 Z-2.259
N4562 X46.697 Z-2.618
N4563 X46.248 Z-3.014
N4564 X45.799 Z-3.462
N4565 X45.35 Z-3.957
N4566 X44.677 Z-4.839
N4567 X44.228 Z-5.548
N4568 X43.779 Z-6.405
N4569 X43.554 Z-6.907
N4570 X43.217 Z-7.836
N4571 X43.003 Z-8.618
N4572 X42.798 Z-9.748
N4573 X42.44 Z-13.52
N4574 X42.184 Z-15.229
N4575 X41.571 Z-18.178
N4576 X40.979 Z-20.339
N4577 X40.491 Z-21.866
N4578 X39.758 Z-23.846
N4579 X39.033 Z-25.551
N4580 X38.554 Z-26.583
N4581 X38.074 Z-27.548
N4582 X37.115 Z-29.312
N4583 X36.156 Z-30.898
N4584 X35.676 Z-31.638
N4585 X34.839 Z-32.859
N4586 X34.002 Z-33.989
N4587 X33.166 Z-35.047
N4588 X32.329 Z-36.043
N4589 X31.408 Z-37.073
N4590 X30.487 Z-38.035
N4591 X29.566 Z-38.941
N4592 X28.645 Z-39.796
N4593 X27.77 Z-40.565
N4594 X26.895 Z-41.292
N4595 X26.02 Z-41.981
N4596 X25.145 Z-42.634
N4597 X24.233 Z-43.278
N4598 X23.321 Z-43.886
N4599 X22.41 Z-44.462
N4600 X20.614 Z-45.507
N4601 X18.845 Z-46.427
N4602 X17.961 Z-46.848
N4603 X16.151 Z-47.634
N4604 X14.342 Z-48.323
N4605 X12.559 Z-48.913
N4606 X10.776 Z-49.418
N4607 X8.958 Z-49.849
N4608 X7.169 Z-50.192
N4609 X5.362 Z-50.46
N4610 X3.592 Z-50.648
N4611 X1.797 Z-50.761
N4612 X0. Z-50.8
N4613 X-1.797 Z-50.761
N4614 X-3.592 Z-50.648
N4615 X-5.362 Z-50.46
N4616 X-7.169 Z-50.192
N4617 X-8.958 Z-49.849
N4618 X-10.776 Z-49.418
N4619 X-12.559 Z-48.913
N4620 X-14.342 Z-48.323
N4621 X-16.151 Z-47.634
N4622 X-17.961 Z-46.848
N4623 X-19.729 Z-45.98
N4624 X-21.498 Z-45.007
N4625 X-22.41 Z-44.462
N4626 X-23.321 Z-43.886
N4627 X-24.233 Z-43.278
N4628 X-25.145 Z-42.634
N4629 X-26.02 Z-41.981
N4630 X-26.895 Z-41.292
N4631 X-27.77 Z-40.565
N4632 X-28.645 Z-39.796
N4633 X-29.566 Z-38.941
N4634 X-30.487 Z-38.035
N4635 X-31.408 Z-37.073
N4636 X-32.329 Z-36.043
N4637 X-33.166 Z-35.047
N4638 X-34.002 Z-33.989
N4639 X-34.839 Z-32.859
N4640 X-35.676 Z-31.638
N4641 X-36.635 Z-30.125
N4642 X-37.595 Z-28.455
N4643 X-38.074 Z-27.548
N4644 X-38.554 Z-26.583
N4645 X-39.033 Z-25.551
N4646 X-39.758 Z-23.846
N4647 X-40.491 Z-21.866
N4648 X-41.346 Z-19.058
N4649 X-41.98 Z-16.328
N4650 X-42.491 Z-13.111
N4651 X-42.798 Z-9.748
N4652 X-42.901 Z-9.108
N4653 X-43.105 Z-8.22
N4654 X-43.33 Z-7.496
N4655 X-43.554 Z-6.907
N4656 X-44.003 Z-5.953
N4657 X-44.452 Z-5.183
N4658 X-44.901 Z-4.527
N4659 X-45.35 Z-3.957
N4660 X-45.799 Z-3.462
N4661 X-46.248 Z-3.014
N4662 X-46.697 Z-2.618
N4663 X-47.146 Z-2.259
N4664 X-47.595 Z-1.937
N4665 X-48.493 Z-1.386
N4666 X-49.391 Z-.943
N4667 X-50.289 Z-.594
N4668 X-51.187 Z-.33
N4669 X-52.085 Z-.145
N4670 X-52.984 Z-.036
N4671 X-53.882 Z0.
N4672 Y72.575
N4673 X-52.984 Z-.036
N4674 X-52.085 Z-.145
N4675 X-51.187 Z-.33
N4676 X-50.289 Z-.594
N4677 X-49.391 Z-.943
N4678 X-48.493 Z-1.386
N4679 X-47.595 Z-1.937
N4680 X-47.146 Z-2.259
N4681 X-46.697 Z-2.618
N4682 X-46.248 Z-3.014
N4683 X-45.799 Z-3.462
N4684 X-45.35 Z-3.957
N4685 X-44.901 Z-4.527
N4686 X-44.452 Z-5.183
N4687 X-44.003 Z-5.953
N4688 X-43.554 Z-6.907
N4689 X-43.33 Z-7.496
N4690 X-43.105 Z-8.22
N4691 X-42.901 Z-9.107
N4692 X-42.798 Z-9.748
N4693 X-42.491 Z-13.111
N4694 X-41.98 Z-16.328
N4695 X-41.346 Z-19.058
N4696 X-40.491 Z-21.866
N4697 X-39.758 Z-23.846
N4698 X-39.033 Z-25.551
N4699 X-38.554 Z-26.583
N4700 X-38.074 Z-27.548
N4701 X-37.595 Z-28.455
N4702 X-36.635 Z-30.125
N4703 X-35.676 Z-31.638
N4704 X-34.839 Z-32.859
N4705 X-34.002 Z-33.989
N4706 X-33.166 Z-35.047
N4707 X-32.329 Z-36.043
N4708 X-31.408 Z-37.073
N4709 X-30.487 Z-38.035
N4710 X-29.566 Z-38.941
N4711 X-28.645 Z-39.796
N4712 X-27.77 Z-40.565
N4713 X-26.895 Z-41.292
N4714 X-26.02 Z-41.981
N4715 X-25.145 Z-42.634
N4716 X-24.233 Z-43.278
N4717 X-23.321 Z-43.886
N4718 X-22.41 Z-44.462
N4719 X-21.498 Z-45.007
N4720 X-19.729 Z-45.98
N4721 X-17.961 Z-46.848
N4722 X-16.151 Z-47.634
N4723 X-14.342 Z-48.323
N4724 X-12.559 Z-48.913
N4725 X-10.776 Z-49.418
N4726 X-8.958 Z-49.849
N4727 X-7.169 Z-50.192
N4728 X-5.362 Z-50.46
N4729 X-3.592 Z-50.648
N4730 X-1.797 Z-50.761
N4731 X0. Z-50.8
N4732 X1.797 Z-50.761
N4733 X3.592 Z-50.648
N4734 X5.362 Z-50.46
N4735 X7.169 Z-50.192
N4736 X8.958 Z-49.849
N4737 X10.776 Z-49.418
N4738 X12.559 Z-48.913
N4739 X14.342 Z-48.323
N4740 X16.151 Z-47.634
N4741 X17.961 Z-46.848
N4742 X18.845 Z-46.427
N4743 X20.614 Z-45.507
N4744 X22.41 Z-44.462
N4745 X23.321 Z-43.886
N4746 X24.233 Z-43.278
N4747 X25.145 Z-42.634
N4748 X26.02 Z-41.981
N4749 X26.895 Z-41.292
N4750 X27.77 Z-40.565
N4751 X28.645 Z-39.796
N4752 X29.566 Z-38.941
N4753 X30.487 Z-38.035
N4754 X31.408 Z-37.073
N4755 X32.329 Z-36.043
N4756 X33.166 Z-35.047
N4757 X34.002 Z-33.989
N4758 X34.839 Z-32.859
N4759 X35.676 Z-31.638
N4760 X36.156 Z-30.898
N4761 X37.115 Z-29.312
N4762 X38.074 Z-27.548
N4763 X38.554 Z-26.583
N4764 X39.033 Z-25.551
N4765 X39.758 Z-23.846
N4766 X40.491 Z-21.866
N4767 X40.979 Z-20.339
N4768 X41.571 Z-18.178
N4769 X42.184 Z-15.229
N4770 X42.44 Z-13.52
N4771 X42.798 Z-9.748
N4772 X43.003 Z-8.618
N4773 X43.217 Z-7.836
N4774 X43.554 Z-6.907
N4775 X43.779 Z-6.406
N4776 X44.228 Z-5.548
N4777 X44.677 Z-4.839
N4778 X45.35 Z-3.957
N4779 X45.799 Z-3.462
N4780 X46.248 Z-3.014
N4781 X46.697 Z-2.618
N4782 X47.146 Z-2.259
N4783 X47.595 Z-1.937
N4784 X48.493 Z-1.386
N4785 X49.391 Z-.943
N4786 X50.289 Z-.594
N4787 X51.187 Z-.33
N4788 X52.085 Z-.145
N4789 X52.984 Z-.036
N4790 X53.882 Z0.
N4791 Y71.375
N4792 X52.984 Z-.036
N4793 X52.085 Z-.145
N4794 X51.187 Z-.33
N4795 X50.289 Z-.594
N4796 X49.391 Z-.943
N4797 X48.493 Z-1.386
N4798 X47.595 Z-1.937
N4799 X47.146 Z-2.259
N4800 X46.697 Z-2.618
N4801 X46.248 Z-3.014
N4802 X45.799 Z-3.462
N4803 X45.35 Z-3.957
N4804 X44.677 Z-4.839
N4805 X44.228 Z-5.548
N4806 X43.779 Z-6.406
N4807 X43.554 Z-6.907
N4808 X43.217 Z-7.836
N4809 X43.003 Z-8.618
N4810 X42.798 Z-9.748
N4811 X42.44 Z-13.52
N4812 X42.184 Z-15.229
N4813 X41.571 Z-18.178
N4814 X40.979 Z-20.339
N4815 X40.491 Z-21.866
N4816 X39.758 Z-23.846
N4817 X39.033 Z-25.551
N4818 X38.554 Z-26.583
N4819 X38.074 Z-27.548
N4820 X37.115 Z-29.312
N4821 X36.156 Z-30.898
N4822 X35.676 Z-31.638
N4823 X34.839 Z-32.859
N4824 X34.002 Z-33.989
N4825 X33.166 Z-35.047
N4826 X32.329 Z-36.043
N4827 X31.408 Z-37.073
N4828 X30.487 Z-38.035
N4829 X29.566 Z-38.941
N4830 X28.645 Z-39.796
N4831 X27.77 Z-40.565
N4832 X26.895 Z-41.292
N4833 X26.02 Z-41.981
N4834 X25.145 Z-42.634
N4835 X24.233 Z-43.278
N4836 X23.321 Z-43.886
N4837 X22.41 Z-44.462
N4838 X20.614 Z-45.507
N4839 X18.845 Z-46.427
N4840 X17.961 Z-46.848
N4841 X16.151 Z-47.634
N4842 X14.342 Z-48.323
N4843 X12.559 Z-48.913
N4844 X10.776 Z-49.418
N4845 X8.958 Z-49.849
N4846 X7.169 Z-50.192
N4847 X5.362 Z-50.46
N4848 X3.592 Z-50.648
N4849 X1.797 Z-50.761
N4850 X0. Z-50.8
N4851 X-1.797 Z-50.761
N4852 X-3.592 Z-50.648
N4853 X-5.362 Z-50.46
N4854 X-7.169 Z-50.192
N4855 X-8.958 Z-49.849
N4856 X-10.776 Z-49.418
N4857 X-12.559 Z-48.913
N4858 X-14.342 Z-48.323
N4859 X-16.151 Z-47.634
N4860 X-17.961 Z-46.848
N4861 X-19.729 Z-45.98
N4862 X-21.498 Z-45.007
N4863 X-22.41 Z-44.462
N4864 X-23.321 Z-43.886
N4865 X-24.233 Z-43.278
N4866 X-25.145 Z-42.634
N4867 X-26.02 Z-41.981
N4868 X-26.895 Z-41.292
N4869 X-27.77 Z-40.565
N4870 X-28.645 Z-39.796
N4871 X-29.566 Z-38.941
N4872 X-30.487 Z-38.035
N4873 X-31.408 Z-37.073
N4874 X-32.329 Z-36.043
N4875 X-33.166 Z-35.047
N4876 X-34.002 Z-33.989
N4877 X-34.839 Z-32.859
N4878 X-35.676 Z-31.638
N4879 X-36.635 Z-30.125
N4880 X-37.595 Z-28.455
N4881 X-38.074 Z-27.548
N4882 X-38.554 Z-26.583
N4883 X-39.033 Z-25.551
N4884 X-39.758 Z-23.846
N4885 X-40.491 Z-21.866
N4886 X-41.346 Z-19.058
N4887 X-41.98 Z-16.328
N4888 X-42.491 Z-13.111
N4889 X-42.798 Z-9.748
N4890 X-42.901 Z-9.107
N4891 X-43.105 Z-8.22
N4892 X-43.33 Z-7.496
N4893 X-43.554 Z-6.907
N4894 X-44.003 Z-5.952
N4895 X-44.452 Z-5.183
N4896 X-44.901 Z-4.527
N4897 X-45.35 Z-3.957
N4898 X-45.799 Z-3.462
N4899 X-46.248 Z-3.014
N4900 X-46.697 Z-2.618
N4901 X-47.146 Z-2.26
N4902 X-47.595 Z-1.937
N4903 X-48.493 Z-1.386
N4904 X-49.391 Z-.943
N4905 X-50.289 Z-.594
N4906 X-51.187 Z-.33
N4907 X-52.085 Z-.145
N4908 X-52.984 Z-.036
N4909 X-53.882 Z0.
N4910 Y70.175
N4911 X-52.984 Z-.036
N4912 X-52.085 Z-.145
N4913 X-51.187 Z-.33
N4914 X-50.289 Z-.594
N4915 X-49.391 Z-.943
N4916 X-48.493 Z-1.386
N4917 X-47.595 Z-1.937
N4918 X-47.146 Z-2.26
N4919 X-46.697 Z-2.618
N4920 X-46.248 Z-3.014
N4921 X-45.799 Z-3.462
N4922 X-45.35 Z-3.957
N4923 X-44.901 Z-4.527
N4924 X-44.452 Z-5.183
N4925 X-44.003 Z-5.952
N4926 X-43.554 Z-6.907
N4927 X-43.33 Z-7.496
N4928 X-43.105 Z-8.22
N4929 X-42.901 Z-9.107
N4930 X-42.798 Z-9.748
N4931 X-42.491 Z-13.111
N4932 X-41.98 Z-16.328
N4933 X-41.346 Z-19.058
N4934 X-40.491 Z-21.866
N4935 X-39.758 Z-23.846
N4936 X-39.033 Z-25.551
N4937 X-38.554 Z-26.583
N4938 X-38.074 Z-27.548
N4939 X-37.595 Z-28.455
N4940 X-36.635 Z-30.125
N4941 X-35.676 Z-31.638
N4942 X-34.839 Z-32.859
N4943 X-34.002 Z-33.989
N4944 X-33.166 Z-35.047
N4945 X-32.329 Z-36.043
N4946 X-31.408 Z-37.073
N4947 X-30.487 Z-38.035
N4948 X-29.566 Z-38.941
N4949 X-28.645 Z-39.796
N4950 X-27.77 Z-40.565
N4951 X-26.895 Z-41.292
N4952 X-26.02 Z-41.981
N4953 X-25.145 Z-42.634
N4954 X-24.233 Z-43.278
N4955 X-23.321 Z-43.886
N4956 X-22.41 Z-44.462
N4957 X-21.498 Z-45.007
N4958 X-19.729 Z-45.98
N4959 X-17.961 Z-46.848
N4960 X-16.151 Z-47.634
N4961 X-14.342 Z-48.323
N4962 X-12.559 Z-48.913
N4963 X-10.776 Z-49.418
N4964 X-8.958 Z-49.849
N4965 X-7.169 Z-50.192
N4966 X-5.362 Z-50.46
N4967 X-3.592 Z-50.648
N4968 X-1.797 Z-50.761
N4969 X0. Z-50.8
N4970 X1.797 Z-50.761
N4971 X3.592 Z-50.648
N4972 X5.362 Z-50.46
N4973 X7.169 Z-50.192
N4974 X8.958 Z-49.849
N4975 X10.776 Z-49.418
N4976 X12.559 Z-48.913
N4977 X14.342 Z-48.323
N4978 X16.151 Z-47.634
N4979 X17.961 Z-46.848
N4980 X18.845 Z-46.427
N4981 X20.614 Z-45.507
N4982 X22.41 Z-44.462
N4983 X23.321 Z-43.886
N4984 X24.233 Z-43.278
N4985 X25.145 Z-42.634
N4986 X26.02 Z-41.981
N4987 X26.895 Z-41.292
N4988 X27.77 Z-40.565
N4989 X28.645 Z-39.796
N4990 X29.566 Z-38.941
N4991 X30.487 Z-38.035
N4992 X31.408 Z-37.073
N4993 X32.329 Z-36.043
N4994 X33.166 Z-35.047
N4995 X34.002 Z-33.989
N4996 X34.839 Z-32.859
N4997 X35.676 Z-31.638
N4998 X36.156 Z-30.898
N4999 X37.115 Z-29.312
N5000 X38.074 Z-27.548
N5001 X38.554 Z-26.583
N5002 X39.033 Z-25.551
N5003 X39.758 Z-23.846
N5004 X40.491 Z-21.866
N5005 X40.979 Z-20.339
N5006 X41.571 Z-18.178
N5007 X42.184 Z-15.229
N5008 X42.44 Z-13.52
N5009 X42.798 Z-9.748
N5010 X43.003 Z-8.618
N5011 X43.217 Z-7.836
N5012 X43.554 Z-6.907
N5013 X43.779 Z-6.406
N5014 X44.228 Z-5.548
N5015 X44.677 Z-4.839
N5016 X45.35 Z-3.957
N5017 X45.799 Z-3.462
N5018 X46.248 Z-3.014
N5019 X46.697 Z-2.618
N5020 X47.146 Z-2.259
N5021 X47.595 Z-1.937
N5022 X48.493 Z-1.386
N5023 X49.391 Z-.943
N5024 X50.289 Z-.594
N5025 X51.187 Z-.33
N5026 X52.085 Z-.145
N5027 X52.984 Z-.036
N5028 X53.882 Z0.
N5029 Y68.975
N5030 X52.984 Z-.036
N5031 X52.085 Z-.145
N5032 X51.187 Z-.33
N5033 X50.289 Z-.594
N5034 X49.391 Z-.943
N5035 X48.493 Z-1.386
N5036 X47.595 Z-1.937
N5037 X47.146 Z-2.259
N5038 X46.697 Z-2.618
N5039 X46.248 Z-3.014
N5040 X45.799 Z-3.462
N5041 X45.35 Z-3.957
N5042 X44.677 Z-4.839
N5043 X44.228 Z-5.548
N5044 X43.779 Z-6.406
N5045 X43.554 Z-6.907
N5046 X43.217 Z-7.836
N5047 X43.003 Z-8.618
N5048 X42.798 Z-9.748
N5049 X42.44 Z-13.52
N5050 X42.184 Z-15.229
N5051 X41.571 Z-18.178
N5052 X40.979 Z-20.339
N5053 X40.491 Z-21.866
N5054 X39.758 Z-23.846
N5055 X39.033 Z-25.551
N5056 X38.554 Z-26.583
N5057 X38.074 Z-27.548
N5058 X37.115 Z-29.312
N5059 X36.156 Z-30.898
N5060 X35.676 Z-31.638
N5061 X34.839 Z-32.859
N5062 X34.002 Z-33.989
N5063 X33.166 Z-35.047
N5064 X32.329 Z-36.043
N5065 X31.408 Z-37.073
N5066 X30.487 Z-38.035
N5067 X29.566 Z-38.941
N5068 X28.645 Z-39.796
N5069 X27.77 Z-40.565
N5070 X26.895 Z-41.292
N5071 X26.02 Z-41.981
N5072 X25.145 Z-42.634
N5073 X24.233 Z-43.278
N5074 X23.321 Z-43.886
N5075 X22.41 Z-44.462
N5076 X20.614 Z-45.507
N5077 X18.845 Z-46.427
N5078 X17.961 Z-46.848
N5079 X16.151 Z-47.634
N5080 X14.342 Z-48.323
N5081 X12.559 Z-48.913
N5082 X10.776 Z-49.418
N5083 X8.958 Z-49.849
N5084 X7.169 Z-50.192
N5085 X5.362 Z-50.46
N5086 X3.592 Z-50.648
N5087 X1.797 Z-50.761
N5088 X0. Z-50.8
N5089 X-1.797 Z-50.761
N5090 X-3.592 Z-50.648
N5091 X-5.362 Z-50.46
N5092 X-7.169 Z-50.192
N5093 X-8.958 Z-49.849
N5094 X-10.776 Z-49.418
N5095 X-12.559 Z-48.913
N5096 X-14.342 Z-48.323
N5097 X-16.151 Z-47.634
N5098 X-17.961 Z-46.848
N5099 X-19.729 Z-45.98
N5100 X-21.498 Z-45.007
N5101 X-22.41 Z-44.462
N5102 X-23.321 Z-43.886
N5103 X-24.233 Z-43.278
N5104 X-25.145 Z-42.634
N5105 X-26.02 Z-41.981
N5106 X-26.895 Z-41.292
N5107 X-27.77 Z-40.565
N5108 X-28.645 Z-39.796
N5109 X-29.566 Z-38.941
N5110 X-30.487 Z-38.035
N5111 X-31.408 Z-37.073
N5112 X-32.329 Z-36.043
N5113 X-33.166 Z-35.047
N5114 X-34.002 Z-33.989
N5115 X-34.839 Z-32.859
N5116 X-35.676 Z-31.638
N5117 X-36.635 Z-30.125
N5118 X-37.595 Z-28.455
N5119 X-38.074 Z-27.548
N5120 X-38.554 Z-26.583
N5121 X-39.033 Z-25.551
N5122 X-39.758 Z-23.846
N5123 X-40.491 Z-21.866
N5124 X-41.346 Z-19.058
N5125 X-41.98 Z-16.328
N5126 X-42.491 Z-13.111
N5127 X-42.798 Z-9.748
N5128 X-42.901 Z-9.107
N5129 X-43.105 Z-8.22
N5130 X-43.33 Z-7.496
N5131 X-43.554 Z-6.907
N5132 X-44.003 Z-5.952
N5133 X-44.452 Z-5.183
N5134 X-44.901 Z-4.527
N5135 X-45.35 Z-3.957
N5136 X-45.799 Z-3.462
N5137 X-46.248 Z-3.014
N5138 X-46.697 Z-2.617
N5139 X-47.146 Z-2.26
N5140 X-47.595 Z-1.937
N5141 X-48.493 Z-1.386
N5142 X-49.391 Z-.943
N5143 X-50.289 Z-.594
N5144 X-51.187 Z-.33
N5145 X-52.085 Z-.145
N5146 X-52.984 Z-.036
N5147 X-53.882 Z0.
N5148 Y67.775
N5149 X-52.984 Z-.036
N5150 X-52.085 Z-.145
N5151 X-51.187 Z-.33
N5152 X-50.289 Z-.594
N5153 X-49.391 Z-.943
N5154 X-48.493 Z-1.386
N5155 X-47.595 Z-1.937
N5156 X-47.146 Z-2.26
N5157 X-46.697 Z-2.617
N5158 X-46.248 Z-3.014
N5159 X-45.799 Z-3.462
N5160 X-45.35 Z-3.957
N5161 X-44.901 Z-4.527
N5162 X-44.452 Z-5.183
N5163 X-44.003 Z-5.952
N5164 X-43.554 Z-6.907
N5165 X-43.33 Z-7.496
N5166 X-43.105 Z-8.22
N5167 X-42.901 Z-9.106
N5168 X-42.798 Z-9.748
N5169 X-42.491 Z-13.111
N5170 X-41.98 Z-16.328
N5171 X-41.346 Z-19.058
N5172 X-40.491 Z-21.866
N5173 X-39.758 Z-23.846
N5174 X-39.033 Z-25.551
N5175 X-38.554 Z-26.583
N5176 X-38.074 Z-27.548
N5177 X-37.595 Z-28.455
N5178 X-36.635 Z-30.125
N5179 X-35.676 Z-31.638
N5180 X-34.839 Z-32.859
N5181 X-34.002 Z-33.989
N5182 X-33.166 Z-35.047
N5183 X-32.329 Z-36.043
N5184 X-31.408 Z-37.073
N5185 X-30.487 Z-38.035
N5186 X-29.566 Z-38.941
N5187 X-28.645 Z-39.796
N5188 X-27.77 Z-40.565
N5189 X-26.895 Z-41.292
N5190 X-26.02 Z-41.981
N5191 X-25.145 Z-42.634
N5192 X-24.233 Z-43.278
N5193 X-23.321 Z-43.886
N5194 X-22.41 Z-44.462
N5195 X-21.498 Z-45.007
N5196 X-19.729 Z-45.98
N5197 X-17.961 Z-46.848
N5198 X-16.151 Z-47.634
N5199 X-14.342 Z-48.323
N5200 X-12.559 Z-48.913
N5201 X-10.776 Z-49.418
N5202 X-8.958 Z-49.849
N5203 X-7.169 Z-50.192
N5204 X-5.362 Z-50.46
N5205 X-3.592 Z-50.648
N5206 X-1.797 Z-50.761
N5207 X0. Z-50.8
N5208 X1.797 Z-50.761
N5209 X3.592 Z-50.648
N5210 X5.362 Z-50.46
N5211 X7.169 Z-50.192
N5212 X8.958 Z-49.849
N5213 X10.776 Z-49.418
N5214 X12.559 Z-48.913
N5215 X14.342 Z-48.323
N5216 X16.151 Z-47.634
N5217 X17.961 Z-46.848
N5218 X18.845 Z-46.427
N5219 X20.614 Z-45.507
N5220 X22.41 Z-44.462
N5221 X23.321 Z-43.886
N5222 X24.233 Z-43.278
N5223 X25.145 Z-42.634
N5224 X26.02 Z-41.981
N5225 X26.895 Z-41.292
N5226 X27.77 Z-40.565
N5227 X28.645 Z-39.796
N5228 X29.566 Z-38.941
N5229 X30.487 Z-38.035
N5230 X31.408 Z-37.073
N5231 X32.329 Z-36.043
N5232 X33.166 Z-35.047
N5233 X34.002 Z-33.989
N5234 X34.839 Z-32.859
N5235 X35.676 Z-31.638
N5236 X36.156 Z-30.898
N5237 X37.115 Z-29.312
N5238 X38.074 Z-27.548
N5239 X38.554 Z-26.583
N5240 X39.033 Z-25.551
N5241 X39.758 Z-23.846
N5242 X40.491 Z-21.866
N5243 X40.979 Z-20.339
N5244 X41.571 Z-18.178
N5245 X42.184 Z-15.229
N5246 X42.44 Z-13.52
N5247 X42.798 Z-9.748
N5248 X43.003 Z-8.618
N5249 X43.217 Z-7.836
N5250 X43.554 Z-6.907
N5251 X43.779 Z-6.406
N5252 X44.228 Z-5.548
N5253 X44.677 Z-4.839
N5254 X45.35 Z-3.957
N5255 X45.799 Z-3.462
N5256 X46.248 Z-3.014
N5257 X46.697 Z-2.617
N5258 X47.146 Z-2.26
N5259 X47.595 Z-1.937
N5260 X48.493 Z-1.386
N5261 X49.391 Z-.943
N5262 X50.289 Z-.594
N5263 X51.187 Z-.33
N5264 X52.085 Z-.145
N5265 X52.984 Z-.036
N5266 X53.882 Z0.
N5267 Y66.575
N5268 X52.984 Z-.036
N5269 X52.085 Z-.145
N5270 X51.187 Z-.33
N5271 X50.289 Z-.594
N5272 X49.391 Z-.943
N5273 X48.493 Z-1.386
N5274 X47.595 Z-1.937
N5275 X47.146 Z-2.26
N5276 X46.697 Z-2.617
N5277 X46.248 Z-3.014
N5278 X45.799 Z-3.462
N5279 X45.35 Z-3.957
N5280 X44.677 Z-4.839
N5281 X44.228 Z-5.548
N5282 X43.779 Z-6.406
N5283 X43.554 Z-6.907
N5284 X43.217 Z-7.836
N5285 X43.003 Z-8.618
N5286 X42.798 Z-9.748
N5287 X42.44 Z-13.52
N5288 X42.184 Z-15.229
N5289 X41.571 Z-18.178
N5290 X40.979 Z-20.339
N5291 X40.491 Z-21.866
N5292 X39.758 Z-23.846
N5293 X39.033 Z-25.551
N5294 X38.554 Z-26.583
N5295 X38.074 Z-27.548
N5296 X37.115 Z-29.312
N5297 X36.156 Z-30.898
N5298 X35.676 Z-31.638
N5299 X34.839 Z-32.859
N5300 X34.002 Z-33.989
N5301 X33.166 Z-35.047
N5302 X32.329 Z-36.043
N5303 X31.408 Z-37.073
N5304 X30.487 Z-38.035
N5305 X29.566 Z-38.941
N5306 X28.645 Z-39.796
N5307 X27.77 Z-40.565
N5308 X26.895 Z-41.292
N5309 X26.02 Z-41.981
N5310 X25.145 Z-42.634
N5311 X24.233 Z-43.278
N5312 X23.321 Z-43.886
N5313 X22.41 Z-44.462
N5314 X20.614 Z-45.507
N5315 X18.845 Z-46.427
N5316 X17.961 Z-46.848
N5317 X16.151 Z-47.634
N5318 X14.342 Z-48.323
N5319 X12.559 Z-48.913
N5320 X10.776 Z-49.418
N5321 X8.958 Z-49.849
N5322 X7.169 Z-50.192
N5323 X5.362 Z-50.46
N5324 X3.592 Z-50.648
N5325 X1.797 Z-50.761
N5326 X0. Z-50.8
N5327 X-1.797 Z-50.761
N5328 X-3.592 Z-50.648
N5329 X-5.362 Z-50.46
N5330 X-7.169 Z-50.192
N5331 X-8.958 Z-49.849
N5332 X-10.776 Z-49.418
N5333 X-12.559 Z-48.913
N5334 X-14.342 Z-48.323
N5335 X-16.151 Z-47.634
N5336 X-17.961 Z-46.848
N5337 X-19.729 Z-45.98
N5338 X-21.498 Z-45.007
N5339 X-22.41 Z-44.462
N5340 X-23.321 Z-43.886
N5341 X-24.233 Z-43.278
N5342 X-25.145 Z-42.634
N5343 X-26.02 Z-41.981
N5344 X-26.895 Z-41.292
N5345 X-27.77 Z-40.565
N5346 X-28.645 Z-39.796
N5347 X-29.566 Z-38.941
N5348 X-30.487 Z-38.035
N5349 X-31.408 Z-37.073
N5350 X-32.329 Z-36.043
N5351 X-33.166 Z-35.047
N5352 X-34.002 Z-33.989
N5353 X-34.839 Z-32.859
N5354 X-35.676 Z-31.638
N5355 X-36.635 Z-30.125
N5356 X-37.595 Z-28.455
N5357 X-38.074 Z-27.548
N5358 X-38.554 Z-26.583
N5359 X-39.033 Z-25.551
N5360 X-39.758 Z-23.846
N5361 X-40.491 Z-21.866
N5362 X-41.346 Z-19.058
N5363 X-41.98 Z-16.328
N5364 X-42.491 Z-13.111
N5365 X-42.798 Z-9.748
N5366 X-42.901 Z-9.106
N5367 X-43.105 Z-8.22
N5368 X-43.33 Z-7.496
N5369 X-43.554 Z-6.907
N5370 X-44.003 Z-5.952
N5371 X-44.452 Z-5.183
N5372 X-44.901 Z-4.527
N5373 X-45.35 Z-3.957
N5374 X-45.799 Z-3.462
N5375 X-46.248 Z-3.014
N5376 X-46.697 Z-2.617
N5377 X-47.146 Z-2.26
N5378 X-47.595 Z-1.937
N5379 X-48.493 Z-1.386
N5380 X-49.391 Z-.943
N5381 X-50.289 Z-.594
N5382 X-51.187 Z-.33
N5383 X-52.085 Z-.145
N5384 X-52.984 Z-.036
N5385 X-53.882 Z0.
N5386 Y65.375
N5387 X-52.984 Z-.036
N5388 X-52.085 Z-.145
N5389 X-51.187 Z-.33
N5390 X-50.289 Z-.593
N5391 X-49.391 Z-.942
N5392 X-48.493 Z-1.385
N5393 X-47.595 Z-1.937
N5394 X-47.146 Z-2.26
N5395 X-46.697 Z-2.617
N5396 X-46.248 Z-3.014
N5397 X-45.799 Z-3.462
N5398 X-45.35 Z-3.957
N5399 X-44.901 Z-4.527
N5400 X-44.452 Z-5.184
N5401 X-44.003 Z-5.952
N5402 X-43.554 Z-6.907
N5403 X-43.33 Z-7.496
N5404 X-43.105 Z-8.22
N5405 X-42.901 Z-9.106
N5406 X-42.798 Z-9.748
N5407 X-42.491 Z-13.111
N5408 X-41.98 Z-16.328
N5409 X-41.346 Z-19.058
N5410 X-40.491 Z-21.866
N5411 X-39.758 Z-23.846
N5412 X-39.033 Z-25.551
N5413 X-38.554 Z-26.583
N5414 X-38.074 Z-27.548
N5415 X-37.595 Z-28.455
N5416 X-36.635 Z-30.125
N5417 X-35.676 Z-31.638
N5418 X-34.839 Z-32.859
N5419 X-34.002 Z-33.989
N5420 X-33.166 Z-35.047
N5421 X-32.329 Z-36.043
N5422 X-31.408 Z-37.073
N5423 X-30.487 Z-38.035
N5424 X-29.566 Z-38.941
N5425 X-28.645 Z-39.796
N5426 X-27.77 Z-40.565
N5427 X-26.895 Z-41.292
N5428 X-26.02 Z-41.981
N5429 X-25.145 Z-42.634
N5430 X-24.233 Z-43.278
N5431 X-23.321 Z-43.886
N5432 X-22.41 Z-44.462
N5433 X-21.498 Z-45.007
N5434 X-19.729 Z-45.98
N5435 X-17.961 Z-46.848
N5436 X-16.151 Z-47.634
N5437 X-14.342 Z-48.323
N5438 X-12.559 Z-48.913
N5439 X-10.776 Z-49.418
N5440 X-8.958 Z-49.849
N5441 X-7.169 Z-50.192
N5442 X-5.362 Z-50.46
N5443 X-3.592 Z-50.648
N5444 X-1.797 Z-50.761
N5445 X0. Z-50.8
N5446 X1.797 Z-50.761
N5447 X3.592 Z-50.648
N5448 X5.362 Z-50.46
N5449 X7.169 Z-50.192
N5450 X8.958 Z-49.849
N5451 X10.776 Z-49.418
N5452 X12.559 Z-48.913
N5453 X14.342 Z-48.323
N5454 X16.151 Z-47.634
N5455 X17.961 Z-46.848
N5456 X18.845 Z-46.427
N5457 X20.614 Z-45.507
N5458 X22.41 Z-44.462
N5459 X23.321 Z-43.886
N5460 X24.233 Z-43.278
N5461 X25.145 Z-42.634
N5462 X26.02 Z-41.981
N5463 X26.895 Z-41.292
N5464 X27.77 Z-40.565
N5465 X28.645 Z-39.796
N5466 X29.566 Z-38.941
N5467 X30.487 Z-38.035
N5468 X31.408 Z-37.073
N5469 X32.329 Z-36.043
N5470 X33.166 Z-35.047
N5471 X34.002 Z-33.989
N5472 X34.839 Z-32.859
N5473 X35.676 Z-31.638
N5474 X36.156 Z-30.898
N5475 X37.115 Z-29.312
N5476 X38.074 Z-27.548
N5477 X38.554 Z-26.583
N5478 X39.033 Z-25.551
N5479 X39.758 Z-23.846
N5480 X40.491 Z-21.866
N5481 X40.979 Z-20.339
N5482 X41.571 Z-18.178
N5483 X42.184 Z-15.229
N5484 X42.44 Z-13.521
N5485 X42.798 Z-9.748
N5486 X43.003 Z-8.618
N5487 X43.217 Z-7.836
N5488 X43.554 Z-6.907
N5489 X43.779 Z-6.406
N5490 X44.228 Z-5.548
N5491 X44.677 Z-4.839
N5492 X45.35 Z-3.957
N5493 X45.799 Z-3.462
N5494 X46.248 Z-3.014
N5495 X46.697 Z-2.617
N5496 X47.146 Z-2.26
N5497 X47.595 Z-1.937
N5498 X48.493 Z-1.386
N5499 X49.391 Z-.942
N5500 X50.289 Z-.593
N5501 X51.187 Z-.33
N5502 X52.085 Z-.145
N5503 X52.984 Z-.036
N5504 X53.882 Z0.
N5505 Y64.175
N5506 X52.984 Z-.036
N5507 X52.085 Z-.145
N5508 X51.187 Z-.33
N5509 X50.289 Z-.593
N5510 X49.391 Z-.942
N5511 X48.493 Z-1.385
N5512 X47.595 Z-1.937
N5513 X47.146 Z-2.26
N5514 X46.697 Z-2.617
N5515 X46.248 Z-3.014
N5516 X45.799 Z-3.462
N5517 X45.35 Z-3.957
N5518 X44.677 Z-4.839
N5519 X44.228 Z-5.548
N5520 X43.779 Z-6.406
N5521 X43.554 Z-6.907
N5522 X43.217 Z-7.836
N5523 X43.003 Z-8.618
N5524 X42.798 Z-9.748
N5525 X42.44 Z-13.521
N5526 X42.184 Z-15.229
N5527 X41.571 Z-18.178
N5528 X40.979 Z-20.339
N5529 X40.491 Z-21.866
N5530 X39.758 Z-23.846
N5531 X39.033 Z-25.551
N5532 X38.554 Z-26.583
N5533 X38.074 Z-27.548
N5534 X37.115 Z-29.312
N5535 X36.156 Z-30.898
N5536 X35.676 Z-31.638
N5537 X34.839 Z-32.859
N5538 X34.002 Z-33.989
N5539 X33.166 Z-35.047
N5540 X32.329 Z-36.043
N5541 X31.408 Z-37.073
N5542 X30.487 Z-38.035
N5543 X29.566 Z-38.941
N5544 X28.645 Z-39.796
N5545 X27.77 Z-40.565
N5546 X26.895 Z-41.292
N5547 X26.02 Z-41.981
N5548 X25.145 Z-42.634
N5549 X24.233 Z-43.278
N5550 X23.321 Z-43.886
N5551 X22.41 Z-44.462
N5552 X20.614 Z-45.507
N5553 X18.845 Z-46.427
N5554 X17.961 Z-46.848
N5555 X16.151 Z-47.634
N5556 X14.342 Z-48.323
N5557 X12.559 Z-48.913
N5558 X10.776 Z-49.418
N5559 X8.958 Z-49.849
N5560 X7.169 Z-50.192
N5561 X5.362 Z-50.46
N5562 X3.592 Z-50.648
N5563 X1.797 Z-50.761
N5564 X0. Z-50.8
N5565 X-1.797 Z-50.761
N5566 X-3.592 Z-50.648
N5567 X-5.362 Z-50.46
N5568 X-7.169 Z-50.192
N5569 X-8.958 Z-49.849
N5570 X-10.776 Z-49.418
N5571 X-12.559 Z-48.913
N5572 X-14.342 Z-48.323
N5573 X-16.151 Z-47.634
N5574 X-17.961 Z-46.848
N5575 X-19.729 Z-45.98
N5576 X-21.498 Z-45.007
N5577 X-22.41 Z-44.462
N5578 X-23.321 Z-43.886
N5579 X-24.233 Z-43.278
N5580 X-25.145 Z-42.634
N5581 X-26.02 Z-41.981
N5582 X-26.895 Z-41.292
N5583 X-27.77 Z-40.565
N5584 X-28.645 Z-39.796
N5585 X-29.566 Z-38.941
N5586 X-30.487 Z-38.035
N5587 X-31.408 Z-37.073
N5588 X-32.329 Z-36.043
N5589 X-33.166 Z-35.047
N5590 X-34.002 Z-33.989
N5591 X-34.839 Z-32.859
N5592 X-35.676 Z-31.638
N5593 X-36.635 Z-30.125
N5594 X-37.595 Z-28.455
N5595 X-38.074 Z-27.548
N5596 X-38.554 Z-26.583
N5597 X-39.513 Z-24.44
N5598 X-40.246 Z-22.553
N5599 X-40.735 Z-21.126
N5600 X-41.346 Z-19.058
N5601 X-41.98 Z-16.328
N5602 X-42.491 Z-13.111
N5603 X-42.798 Z-9.748
N5604 X-42.901 Z-9.106
N5605 X-43.105 Z-8.22
N5606 X-43.33 Z-7.496
N5607 X-43.554 Z-6.907
N5608 X-44.003 Z-5.952
N5609 X-44.452 Z-5.184
N5610 X-44.901 Z-4.527
N5611 X-45.35 Z-3.957
N5612 X-45.799 Z-3.462
N5613 X-46.248 Z-3.014
N5614 X-46.697 Z-2.617
N5615 X-47.146 Z-2.26
N5616 X-47.595 Z-1.937
N5617 X-48.493 Z-1.385
N5618 X-49.391 Z-.942
N5619 X-50.289 Z-.593
N5620 X-51.187 Z-.33
N5621 X-52.085 Z-.145
N5622 X-52.984 Z-.036
N5623 X-53.882 Z0.
N5624 Y62.975
N5625 X-52.984 Z-.036
N5626 X-52.085 Z-.145
N5627 X-51.187 Z-.33
N5628 X-50.289 Z-.593
N5629 X-49.391 Z-.942
N5630 X-48.493 Z-1.385
N5631 X-47.595 Z-1.937
N5632 X-47.146 Z-2.26
N5633 X-46.697 Z-2.617
N5634 X-46.248 Z-3.014
N5635 X-45.799 Z-3.462
N5636 X-45.35 Z-3.957
N5637 X-44.901 Z-4.527
N5638 X-44.452 Z-5.184
N5639 X-44.003 Z-5.952
N5640 X-43.554 Z-6.907
N5641 X-43.33 Z-7.496
N5642 X-43.105 Z-8.22
N5643 X-42.901 Z-9.106
N5644 X-42.798 Z-9.748
N5645 X-42.491 Z-13.111
N5646 X-41.98 Z-16.328
N5647 X-41.346 Z-19.058
N5648 X-40.735 Z-21.126
N5649 X-40.246 Z-22.553
N5650 X-39.513 Z-24.44
N5651 X-38.554 Z-26.583
N5652 X-38.074 Z-27.548
N5653 X-37.595 Z-28.455
N5654 X-36.635 Z-30.125
N5655 X-35.676 Z-31.638
N5656 X-34.839 Z-32.859
N5657 X-34.002 Z-33.989
N5658 X-33.166 Z-35.047
N5659 X-32.329 Z-36.043
N5660 X-31.408 Z-37.073
N5661 X-30.487 Z-38.035
N5662 X-29.566 Z-38.941
N5663 X-28.645 Z-39.796
N5664 X-27.77 Z-40.565
N5665 X-26.895 Z-41.292
N5666 X-26.02 Z-41.981
N5667 X-25.145 Z-42.634
N5668 X-24.233 Z-43.278
N5669 X-23.321 Z-43.886
N5670 X-22.41 Z-44.462
N5671 X-21.498 Z-45.007
N5672 X-19.729 Z-45.98
N5673 X-17.961 Z-46.848
N5674 X-16.151 Z-47.634
N5675 X-14.342 Z-48.323
N5676 X-12.559 Z-48.913
N5677 X-10.776 Z-49.418
N5678 X-8.958 Z-49.849
N5679 X-7.169 Z-50.192
N5680 X-5.362 Z-50.46
N5681 X-3.592 Z-50.648
N5682 X-1.797 Z-50.761
N5683 X0. Z-50.8
N5684 X1.797 Z-50.761
N5685 X3.592 Z-50.648
N5686 X5.362 Z-50.46
N5687 X7.169 Z-50.192
N5688 X8.958 Z-49.849
N5689 X10.776 Z-49.418
N5690 X12.559 Z-48.913
N5691 X14.342 Z-48.323
N5692 X16.151 Z-47.634
N5693 X17.961 Z-46.848
N5694 X18.845 Z-46.427
N5695 X20.614 Z-45.507
N5696 X22.41 Z-44.462
N5697 X23.321 Z-43.886
N5698 X24.233 Z-43.278
N5699 X25.145 Z-42.634
N5700 X26.02 Z-41.981
N5701 X26.895 Z-41.292
N5702 X27.77 Z-40.565
N5703 X28.645 Z-39.796
N5704 X29.566 Z-38.941
N5705 X30.487 Z-38.035
N5706 X31.408 Z-37.073
N5707 X32.329 Z-36.043
N5708 X33.166 Z-35.047
N5709 X34.002 Z-33.989
N5710 X34.839 Z-32.859
N5711 X35.676 Z-31.638
N5712 X36.156 Z-30.898
N5713 X37.115 Z-29.312
N5714 X38.074 Z-27.548
N5715 X38.554 Z-26.583
N5716 X39.033 Z-25.551
N5717 X39.758 Z-23.846
N5718 X40.491 Z-21.866
N5719 X40.979 Z-20.339
N5720 X41.571 Z-18.178
N5721 X42.184 Z-15.229
N5722 X42.44 Z-13.521
N5723 X42.798 Z-9.748
N5724 X43.003 Z-8.618
N5725 X43.217 Z-7.836
N5726 X43.554 Z-6.907
N5727 X43.779 Z-6.407
N5728 X44.228 Z-5.548
N5729 X44.677 Z-4.839
N5730 X45.35 Z-3.957
N5731 X45.799 Z-3.462
N5732 X46.248 Z-3.014
N5733 X46.697 Z-2.617
N5734 X47.146 Z-2.26
N5735 X47.595 Z-1.937
N5736 X48.493 Z-1.385
N5737 X49.391 Z-.942
N5738 X50.289 Z-.593
N5739 X51.187 Z-.33
N5740 X52.085 Z-.145
N5741 X52.984 Z-.036
N5742 X53.882 Z0.
N5743 Y61.775
N5744 X52.984 Z-.036
N5745 X52.085 Z-.145
N5746 X51.187 Z-.33
N5747 X50.289 Z-.593
N5748 X49.391 Z-.942
N5749 X48.493 Z-1.385
N5750 X47.595 Z-1.937
N5751 X47.146 Z-2.26
N5752 X46.697 Z-2.617
N5753 X46.248 Z-3.014
N5754 X45.799 Z-3.462
N5755 X45.35 Z-3.957
N5756 X44.677 Z-4.839
N5757 X44.228 Z-5.548
N5758 X43.779 Z-6.407
N5759 X43.554 Z-6.906
N5760 X43.217 Z-7.836
N5761 X43.003 Z-8.618
N5762 X42.798 Z-9.748
N5763 X42.44 Z-13.521
N5764 X42.184 Z-15.229
N5765 X41.571 Z-18.178
N5766 X40.979 Z-20.339
N5767 X40.491 Z-21.866
N5768 X39.758 Z-23.846
N5769 X39.033 Z-25.551
N5770 X38.554 Z-26.583
N5771 X38.074 Z-27.548
N5772 X37.115 Z-29.312
N5773 X36.156 Z-30.898
N5774 X35.676 Z-31.638
N5775 X34.839 Z-32.859
N5776 X34.002 Z-33.989
N5777 X33.166 Z-35.047
N5778 X32.329 Z-36.043
N5779 X31.408 Z-37.073
N5780 X30.487 Z-38.035
N5781 X29.566 Z-38.941
N5782 X28.645 Z-39.796
N5783 X27.77 Z-40.565
N5784 X26.895 Z-41.292
N5785 X26.02 Z-41.981
N5786 X25.145 Z-42.634
N5787 X24.233 Z-43.278
N5788 X23.321 Z-43.886
N5789 X22.41 Z-44.462
N5790 X20.614 Z-45.507
N5791 X18.845 Z-46.427
N5792 X17.961 Z-46.848
N5793 X16.151 Z-47.634
N5794 X14.342 Z-48.323
N5795 X12.559 Z-48.913
N5796 X10.776 Z-49.418
N5797 X8.958 Z-49.849
N5798 X7.169 Z-50.192
N5799 X5.362 Z-50.46
N5800 X3.592 Z-50.648
N5801 X1.797 Z-50.761
N5802 X0. Z-50.8
N5803 X-1.797 Z-50.761
N5804 X-3.592 Z-50.648
N5805 X-5.362 Z-50.46
N5806 X-7.169 Z-50.192
N5807 X-8.958 Z-49.849
N5808 X-10.776 Z-49.418
N5809 X-12.559 Z-48.913
N5810 X-14.342 Z-48.323
N5811 X-16.151 Z-47.634
N5812 X-17.961 Z-46.848
N5813 X-19.729 Z-45.98
N5814 X-21.498 Z-45.007
N5815 X-22.41 Z-44.462
N5816 X-23.321 Z-43.886
N5817 X-24.233 Z-43.278
N5818 X-25.145 Z-42.634
N5819 X-26.02 Z-41.981
N5820 X-26.895 Z-41.292
N5821 X-27.77 Z-40.565
N5822 X-28.645 Z-39.796
N5823 X-29.566 Z-38.941
N5824 X-30.487 Z-38.035
N5825 X-31.408 Z-37.073
N5826 X-32.329 Z-36.043
N5827 X-33.166 Z-35.047
N5828 X-34.002 Z-33.989
N5829 X-34.839 Z-32.859
N5830 X-35.676 Z-31.638
N5831 X-36.635 Z-30.125
N5832 X-37.595 Z-28.455
N5833 X-38.074 Z-27.548
N5834 X-38.554 Z-26.583
N5835 X-39.513 Z-24.44
N5836 X-40.246 Z-22.553
N5837 X-40.735 Z-21.126
N5838 X-41.346 Z-19.058
N5839 X-41.98 Z-16.328
N5840 X-42.491 Z-13.111
N5841 X-42.798 Z-9.748
N5842 X-42.901 Z-9.105
N5843 X-43.105 Z-8.22
N5844 X-43.33 Z-7.496
N5845 X-43.554 Z-6.906
N5846 X-44.003 Z-5.952
N5847 X-44.452 Z-5.184
N5848 X-44.901 Z-4.527
N5849 X-45.35 Z-3.957
N5850 X-45.799 Z-3.462
N5851 X-46.248 Z-3.014
N5852 X-46.697 Z-2.617
N5853 X-47.146 Z-2.26
N5854 X-47.595 Z-1.936
N5855 X-48.493 Z-1.385
N5856 X-49.391 Z-.942
N5857 X-50.289 Z-.593
N5858 X-51.187 Z-.33
N5859 X-52.085 Z-.145
N5860 X-52.984 Z-.036
N5861 X-53.882 Z0.
N5862 Y60.575
N5863 X-52.984 Z-.036
N5864 X-52.085 Z-.145
N5865 X-51.187 Z-.33
N5866 X-50.289 Z-.593
N5867 X-49.391 Z-.942
N5868 X-48.493 Z-1.385
N5869 X-47.595 Z-1.936
N5870 X-47.146 Z-2.26
N5871 X-46.697 Z-2.617
N5872 X-46.248 Z-3.014
N5873 X-45.799 Z-3.462
N5874 X-45.35 Z-3.957
N5875 X-44.901 Z-4.527
N5876 X-44.452 Z-5.184
N5877 X-44.003 Z-5.952
N5878 X-43.554 Z-6.906
N5879 X-43.33 Z-7.496
N5880 X-43.105 Z-8.22
N5881 X-42.901 Z-9.105
N5882 X-42.798 Z-9.748
N5883 X-42.491 Z-13.111
N5884 X-41.98 Z-16.328
N5885 X-41.346 Z-19.058
N5886 X-40.735 Z-21.126
N5887 X-40.246 Z-22.553
N5888 X-39.513 Z-24.44
N5889 X-38.554 Z-26.583
N5890 X-38.074 Z-27.548
N5891 X-37.595 Z-28.455
N5892 X-36.635 Z-30.125
N5893 X-35.676 Z-31.638
N5894 X-34.839 Z-32.859
N5895 X-34.002 Z-33.989
N5896 X-33.166 Z-35.047
N5897 X-32.329 Z-36.043
N5898 X-31.408 Z-37.073
N5899 X-30.487 Z-38.035
N5900 X-29.566 Z-38.941
N5901 X-28.645 Z-39.796
N5902 X-27.77 Z-40.565
N5903 X-26.895 Z-41.292
N5904 X-26.02 Z-41.981
N5905 X-25.145 Z-42.634
N5906 X-24.233 Z-43.278
N5907 X-23.321 Z-43.886
N5908 X-22.41 Z-44.462
N5909 X-21.498 Z-45.007
N5910 X-19.729 Z-45.98
N5911 X-17.961 Z-46.848
N5912 X-16.151 Z-47.634
N5913 X-14.342 Z-48.323
N5914 X-12.559 Z-48.913
N5915 X-10.776 Z-49.418
N5916 X-8.958 Z-49.849
N5917 X-7.169 Z-50.192
N5918 X-5.362 Z-50.46
N5919 X-3.592 Z-50.648
N5920 X-1.797 Z-50.761
N5921 X0. Z-50.8
N5922 X1.797 Z-50.761
N5923 X3.592 Z-50.648
N5924 X5.362 Z-50.46
N5925 X7.169 Z-50.192
N5926 X8.958 Z-49.849
N5927 X10.776 Z-49.418
N5928 X12.559 Z-48.913
N5929 X14.342 Z-48.323
N5930 X16.151 Z-47.634
N5931 X17.961 Z-46.848
N5932 X18.845 Z-46.427
N5933 X20.614 Z-45.507
N5934 X22.41 Z-44.462
N5935 X23.321 Z-43.886
N5936 X24.233 Z-43.278
N5937 X25.145 Z-42.634
N5938 X26.02 Z-41.981
N5939 X26.895 Z-41.292
N5940 X27.77 Z-40.565
N5941 X28.645 Z-39.796
N5942 X29.566 Z-38.941
N5943 X30.487 Z-38.035
N5944 X31.408 Z-37.073
N5945 X32.329 Z-36.043
N5946 X33.166 Z-35.047
N5947 X34.002 Z-33.989
N5948 X34.839 Z-32.859
N5949 X35.676 Z-31.638
N5950 X36.156 Z-30.898
N5951 X37.115 Z-29.312
N5952 X38.074 Z-27.548
N5953 X38.554 Z-26.583
N5954 X39.033 Z-25.551
N5955 X39.758 Z-23.846
N5956 X40.491 Z-21.866
N5957 X40.979 Z-20.339
N5958 X41.571 Z-18.178
N5959 X42.184 Z-15.229
N5960 X42.44 Z-13.521
N5961 X42.798 Z-9.748
N5962 X43.003 Z-8.618
N5963 X43.217 Z-7.836
N5964 X43.554 Z-6.906
N5965 X43.779 Z-6.407
N5966 X44.228 Z-5.548
N5967 X44.677 Z-4.839
N5968 X45.35 Z-3.957
N5969 X45.799 Z-3.462
N5970 X46.248 Z-3.014
N5971 X46.697 Z-2.617
N5972 X47.146 Z-2.26
N5973 X47.595 Z-1.936
N5974 X48.493 Z-1.385
N5975 X49.391 Z-.942
N5976 X50.289 Z-.593
N5977 X51.187 Z-.33
N5978 X52.085 Z-.145
N5979 X52.984 Z-.036
N5980 X53.882 Z0.
N5981 Y59.375
N5982 X52.984 Z-.036
N5983 X52.085 Z-.145
N5984 X51.187 Z-.33
N5985 X50.289 Z-.593
N5986 X49.391 Z-.942
N5987 X48.493 Z-1.385
N5988 X47.595 Z-1.936
N5989 X47.146 Z-2.26
N5990 X46.697 Z-2.617
N5991 X46.248 Z-3.014
N5992 X45.799 Z-3.462
N5993 X45.35 Z-3.957
N5994 X44.677 Z-4.839
N5995 X44.228 Z-5.548
N5996 X43.779 Z-6.407
N5997 X43.554 Z-6.906
N5998 X43.217 Z-7.836
N5999 X43.003 Z-8.618
N6000 X42.798 Z-9.748
N6001 X42.44 Z-13.521
N6002 X42.184 Z-15.229
N6003 X41.571 Z-18.178
N6004 X40.979 Z-20.339
N6005 X40.491 Z-21.866
N6006 X39.758 Z-23.846
N6007 X39.033 Z-25.551
N6008 X38.554 Z-26.583
N6009 X38.074 Z-27.548
N6010 X37.115 Z-29.312
N6011 X36.156 Z-30.898
N6012 X35.676 Z-31.638
N6013 X34.839 Z-32.859
N6014 X34.002 Z-33.989
N6015 X33.166 Z-35.047
N6016 X32.329 Z-36.043
N6017 X31.408 Z-37.073
N6018 X30.487 Z-38.035
N6019 X29.566 Z-38.941
N6020 X28.645 Z-39.796
N6021 X27.77 Z-40.565
N6022 X26.895 Z-41.292
N6023 X26.02 Z-41.981
N6024 X25.145 Z-42.634
N6025 X24.233 Z-43.278
N6026 X23.321 Z-43.886
N6027 X22.41 Z-44.462
N6028 X20.614 Z-45.507
N6029 X18.845 Z-46.427
N6030 X17.961 Z-46.848
N6031 X16.151 Z-47.634
N6032 X14.342 Z-48.323
N6033 X12.559 Z-48.913
N6034 X10.776 Z-49.418
N6035 X8.958 Z-49.849
N6036 X7.169 Z-50.192
N6037 X5.362 Z-50.46
N6038 X3.592 Z-50.648
N6039 X1.797 Z-50.761
N6040 X0. Z-50.8
N6041 X-1.797 Z-50.761
N6042 X-3.592 Z-50.648
N6043 X-5.362 Z-50.46
N6044 X-7.169 Z-50.192
N6045 X-8.958 Z-49.849
N6046 X-10.776 Z-49.418
N6047 X-12.559 Z-48.913
N6048 X-14.342 Z-48.323
N6049 X-16.151 Z-47.634
N6050 X-17.961 Z-46.848
N6051 X-19.729 Z-45.98
N6052 X-21.498 Z-45.007
N6053 X-22.41 Z-44.462
N6054 X-23.321 Z-43.886
N6055 X-24.233 Z-43.278
N6056 X-25.145 Z-42.634
N6057 X-26.02 Z-41.981
N6058 X-26.895 Z-41.292
N6059 X-27.77 Z-40.565
N6060 X-28.645 Z-39.796
N6061 X-29.566 Z-38.941
N6062 X-30.487 Z-38.035
N6063 X-31.408 Z-37.073
N6064 X-32.329 Z-36.043
N6065 X-33.166 Z-35.047
N6066 X-34.002 Z-33.989
N6067 X-34.839 Z-32.859
N6068 X-35.676 Z-31.638
N6069 X-36.635 Z-30.125
N6070 X-37.595 Z-28.455
N6071 X-38.074 Z-27.548
N6072 X-38.554 Z-26.583
N6073 X-39.513 Z-24.44
N6074 X-40.246 Z-22.553
N6075 X-40.735 Z-21.126
N6076 X-41.346 Z-19.058
N6077 X-41.98 Z-16.328
N6078 X-42.491 Z-13.111
N6079 X-42.798 Z-9.748
N6080 X-42.901 Z-9.105
N6081 X-43.105 Z-8.22
N6082 X-43.33 Z-7.496
N6083 X-43.554 Z-6.906
N6084 X-44.003 Z-5.952
N6085 X-44.452 Z-5.184
N6086 X-44.901 Z-4.527
N6087 X-45.35 Z-3.957
N6088 X-45.799 Z-3.462
N6089 X-46.248 Z-3.014
N6090 X-46.697 Z-2.617
N6091 X-47.146 Z-2.26
N6092 X-47.595 Z-1.936
N6093 X-48.493 Z-1.385
N6094 X-49.391 Z-.942
N6095 X-50.289 Z-.593
N6096 X-51.187 Z-.33
N6097 X-52.085 Z-.145
N6098 X-52.984 Z-.036
N6099 X-53.882 Z0.
N6100 Y58.175
N6101 X-52.984 Z-.036
N6102 X-52.085 Z-.145
N6103 X-51.187 Z-.33
N6104 X-50.289 Z-.593
N6105 X-49.391 Z-.942
N6106 X-48.493 Z-1.385
N6107 X-47.595 Z-1.936
N6108 X-47.146 Z-2.26
N6109 X-46.697 Z-2.617
N6110 X-46.248 Z-3.014
N6111 X-45.799 Z-3.462
N6112 X-45.35 Z-3.957
N6113 X-44.901 Z-4.527
N6114 X-44.452 Z-5.184
N6115 X-44.003 Z-5.952
N6116 X-43.554 Z-6.906
N6117 X-43.33 Z-7.496
N6118 X-43.105 Z-8.22
N6119 X-42.901 Z-9.105
N6120 X-42.798 Z-9.748
N6121 X-42.491 Z-13.111
N6122 X-41.98 Z-16.328
N6123 X-41.346 Z-19.058
N6124 X-40.735 Z-21.126
N6125 X-40.246 Z-22.554
N6126 X-39.513 Z-24.44
N6127 X-38.554 Z-26.583
N6128 X-38.074 Z-27.548
N6129 X-37.595 Z-28.455
N6130 X-36.635 Z-30.125
N6131 X-35.676 Z-31.638
N6132 X-34.839 Z-32.859
N6133 X-34.002 Z-33.989
N6134 X-33.166 Z-35.047
N6135 X-32.329 Z-36.043
N6136 X-31.408 Z-37.073
N6137 X-30.487 Z-38.035
N6138 X-29.566 Z-38.941
N6139 X-28.645 Z-39.796
N6140 X-27.77 Z-40.565
N6141 X-26.895 Z-41.292
N6142 X-26.02 Z-41.981
N6143 X-25.145 Z-42.634
N6144 X-24.233 Z-43.278
N6145 X-23.321 Z-43.886
N6146 X-22.41 Z-44.462
N6147 X-21.498 Z-45.007
N6148 X-19.729 Z-45.98
N6149 X-17.961 Z-46.848
N6150 X-16.151 Z-47.634
N6151 X-14.342 Z-48.323
N6152 X-12.559 Z-48.913
N6153 X-10.776 Z-49.418
N6154 X-8.958 Z-49.849
N6155 X-7.169 Z-50.192
N6156 X-5.362 Z-50.46
N6157 X-3.592 Z-50.648
N6158 X-1.797 Z-50.761
N6159 X0. Z-50.8
N6160 X1.797 Z-50.761
N6161 X3.592 Z-50.648
N6162 X5.362 Z-50.46
N6163 X7.169 Z-50.192
N6164 X8.958 Z-49.849
N6165 X10.776 Z-49.418
N6166 X12.559 Z-48.913
N6167 X14.342 Z-48.323
N6168 X16.151 Z-47.634
N6169 X17.961 Z-46.848
N6170 X18.845 Z-46.427
N6171 X20.614 Z-45.507
N6172 X22.41 Z-44.462
N6173 X23.321 Z-43.886
N6174 X24.233 Z-43.278
N6175 X25.145 Z-42.634
N6176 X26.02 Z-41.981
N6177 X26.895 Z-41.292
N6178 X27.77 Z-40.565
N6179 X28.645 Z-39.796
N6180 X29.566 Z-38.941
N6181 X30.487 Z-38.035
N6182 X31.408 Z-37.073
N6183 X32.329 Z-36.043
N6184 X33.166 Z-35.047
N6185 X34.002 Z-33.989
N6186 X34.839 Z-32.859
N6187 X35.676 Z-31.638
N6188 X36.156 Z-30.898
N6189 X37.115 Z-29.312
N6190 X38.074 Z-27.548
N6191 X38.554 Z-26.583
N6192 X39.033 Z-25.551
N6193 X39.758 Z-23.846
N6194 X40.491 Z-21.866
N6195 X40.979 Z-20.339
N6196 X41.571 Z-18.178
N6197 X42.184 Z-15.229
N6198 X42.44 Z-13.521
N6199 X42.798 Z-9.748
N6200 X43.003 Z-8.618
N6201 X43.217 Z-7.836
N6202 X43.554 Z-6.906
N6203 X43.779 Z-6.407
N6204 X44.228 Z-5.548
N6205 X44.677 Z-4.839
N6206 X45.35 Z-3.957
N6207 X45.799 Z-3.462
N6208 X46.248 Z-3.014
N6209 X46.697 Z-2.617
N6210 X47.146 Z-2.26
N6211 X47.595 Z-1.936
N6212 X48.493 Z-1.385
N6213 X49.391 Z-.942
N6214 X50.289 Z-.593
N6215 X51.187 Z-.33
N6216 X52.085 Z-.145
N6217 X52.984 Z-.036
N6218 X53.882 Z0.
N6219 Y56.975
N6220 X52.984 Z-.036
N6221 X52.085 Z-.145
N6222 X51.187 Z-.33
N6223 X50.289 Z-.593
N6224 X49.391 Z-.942
N6225 X48.493 Z-1.385
N6226 X47.595 Z-1.936
N6227 X47.146 Z-2.26
N6228 X46.697 Z-2.617
N6229 X46.248 Z-3.014
N6230 X45.799 Z-3.462
N6231 X45.35 Z-3.957
N6232 X44.677 Z-4.838
N6233 X44.228 Z-5.548
N6234 X43.779 Z-6.407
N6235 X43.554 Z-6.906
N6236 X43.217 Z-7.836
N6237 X43.003 Z-8.618
N6238 X42.798 Z-9.748
N6239 X42.44 Z-13.521
N6240 X42.184 Z-15.229
N6241 X41.571 Z-18.178
N6242 X40.979 Z-20.339
N6243 X40.491 Z-21.866
N6244 X39.758 Z-23.846
N6245 X39.033 Z-25.551
N6246 X38.554 Z-26.583
N6247 X38.074 Z-27.548
N6248 X37.115 Z-29.312
N6249 X36.156 Z-30.898
N6250 X35.676 Z-31.638
N6251 X34.839 Z-32.859
N6252 X34.002 Z-33.989
N6253 X33.166 Z-35.047
N6254 X32.329 Z-36.043
N6255 X31.408 Z-37.073
N6256 X30.487 Z-38.035
N6257 X29.566 Z-38.941
N6258 X28.645 Z-39.796
N6259 X27.77 Z-40.565
N6260 X26.895 Z-41.292
N6261 X26.02 Z-41.981
N6262 X25.145 Z-42.634
N6263 X24.233 Z-43.278
N6264 X23.321 Z-43.886
N6265 X22.41 Z-44.462
N6266 X20.614 Z-45.507
N6267 X18.845 Z-46.427
N6268 X17.961 Z-46.848
N6269 X16.151 Z-47.634
N6270 X14.342 Z-48.323
N6271 X12.559 Z-48.913
N6272 X10.776 Z-49.418
N6273 X8.958 Z-49.849
N6274 X7.169 Z-50.192
N6275 X5.362 Z-50.46
N6276 X3.592 Z-50.648
N6277 X1.797 Z-50.761
N6278 X0. Z-50.8
N6279 X-1.797 Z-50.761
N6280 X-3.592 Z-50.648
N6281 X-5.362 Z-50.46
N6282 X-7.169 Z-50.192
N6283 X-8.958 Z-49.849
N6284 X-10.776 Z-49.418
N6285 X-12.559 Z-48.913
N6286 X-14.342 Z-48.323
N6287 X-16.151 Z-47.634
N6288 X-17.961 Z-46.848
N6289 X-19.729 Z-45.98
N6290 X-21.498 Z-45.007
N6291 X-22.41 Z-44.462
N6292 X-23.321 Z-43.886
N6293 X-24.233 Z-43.278
N6294 X-25.145 Z-42.634
N6295 X-26.02 Z-41.981
N6296 X-26.895 Z-41.292
N6297 X-27.77 Z-40.565
N6298 X-28.645 Z-39.796
N6299 X-29.566 Z-38.941
N6300 X-30.487 Z-38.035
N6301 X-31.408 Z-37.073
N6302 X-32.329 Z-36.043
N6303 X-33.166 Z-35.047
N6304 X-34.002 Z-33.989
N6305 X-34.839 Z-32.859
N6306 X-35.676 Z-31.638
N6307 X-36.635 Z-30.125
N6308 X-37.595 Z-28.455
N6309 X-38.074 Z-27.548
N6310 X-38.554 Z-26.583
N6311 X-39.513 Z-24.44
N6312 X-40.246 Z-22.554
N6313 X-40.735 Z-21.126
N6314 X-41.346 Z-19.058
N6315 X-41.98 Z-16.328
N6316 X-42.491 Z-13.111
N6317 X-42.798 Z-9.748
N6318 X-42.901 Z-9.104
N6319 X-43.105 Z-8.22
N6320 X-43.33 Z-7.496
N6321 X-43.554 Z-6.906
N6322 X-44.003 Z-5.952
N6323 X-44.452 Z-5.184
N6324 X-44.901 Z-4.527
N6325 X-45.35 Z-3.957
N6326 X-45.799 Z-3.462
N6327 X-46.248 Z-3.014
N6328 X-46.697 Z-2.617
N6329 X-47.146 Z-2.26
N6330 X-47.595 Z-1.936
N6331 X-48.493 Z-1.385
N6332 X-49.391 Z-.942
N6333 X-50.289 Z-.593
N6334 X-51.187 Z-.33
N6335 X-52.085 Z-.145
N6336 X-52.984 Z-.036
N6337 X-53.882 Z0.
N6338 Y55.775
N6339 X-52.984 Z-.036
N6340 X-52.085 Z-.145
N6341 X-51.187 Z-.33
N6342 X-50.289 Z-.593
N6343 X-49.391 Z-.942
N6344 X-48.493 Z-1.385
N6345 X-47.595 Z-1.936
N6346 X-47.146 Z-2.26
N6347 X-46.697 Z-2.617
N6348 X-46.248 Z-3.014
N6349 X-45.799 Z-3.462
N6350 X-45.35 Z-3.957
N6351 X-44.901 Z-4.527
N6352 X-44.452 Z-5.184
N6353 X-44.003 Z-5.952
N6354 X-43.554 Z-6.906
N6355 X-43.33 Z-7.496
N6356 X-43.105 Z-8.22
N6357 X-42.901 Z-9.104
N6358 X-42.798 Z-9.748
N6359 X-42.491 Z-13.111
N6360 X-41.98 Z-16.328
N6361 X-41.346 Z-19.058
N6362 X-40.491 Z-21.866
N6363 X-39.758 Z-23.846
N6364 X-39.033 Z-25.551
N6365 X-38.554 Z-26.583
N6366 X-38.074 Z-27.548
N6367 X-37.595 Z-28.455
N6368 X-36.635 Z-30.125
N6369 X-35.676 Z-31.638
N6370 X-34.839 Z-32.859
N6371 X-34.002 Z-33.989
N6372 X-33.166 Z-35.047
N6373 X-32.329 Z-36.043
N6374 X-31.408 Z-37.073
N6375 X-30.487 Z-38.035
N6376 X-29.566 Z-38.941
N6377 X-28.645 Z-39.796
N6378 X-27.77 Z-40.565
N6379 X-26.895 Z-41.292
N6380 X-26.02 Z-41.981
N6381 X-25.145 Z-42.634
N6382 X-24.233 Z-43.278
N6383 X-23.321 Z-43.886
N6384 X-22.41 Z-44.462
N6385 X-21.498 Z-45.007
N6386 X-19.729 Z-45.98
N6387 X-17.961 Z-46.848
N6388 X-16.151 Z-47.634
N6389 X-14.342 Z-48.323
N6390 X-12.559 Z-48.913
N6391 X-10.776 Z-49.418
N6392 X-8.958 Z-49.849
N6393 X-7.169 Z-50.192
N6394 X-5.362 Z-50.46
N6395 X-3.592 Z-50.648
N6396 X-1.797 Z-50.761
N6397 X0. Z-50.8
N6398 X1.797 Z-50.761
N6399 X3.592 Z-50.648
N6400 X5.362 Z-50.46
N6401 X7.169 Z-50.192
N6402 X8.958 Z-49.849
N6403 X10.776 Z-49.418
N6404 X12.559 Z-48.913
N6405 X14.342 Z-48.323
N6406 X16.151 Z-47.634
N6407 X17.961 Z-46.848
N6408 X18.845 Z-46.427
N6409 X20.614 Z-45.507
N6410 X22.41 Z-44.462
N6411 X23.321 Z-43.886
N6412 X24.233 Z-43.278
N6413 X25.145 Z-42.634
N6414 X26.02 Z-41.981
N6415 X26.895 Z-41.292
N6416 X27.77 Z-40.565
N6417 X28.645 Z-39.796
N6418 X29.566 Z-38.941
N6419 X30.487 Z-38.035
N6420 X31.408 Z-37.073
N6421 X32.329 Z-36.043
N6422 X33.166 Z-35.047
N6423 X34.002 Z-33.989
N6424 X34.839 Z-32.859
N6425 X35.676 Z-31.638
N6426 X36.156 Z-30.898
N6427 X37.115 Z-29.312
N6428 X38.074 Z-27.548
N6429 X38.554 Z-26.583
N6430 X39.033 Z-25.551
N6431 X39.758 Z-23.846
N6432 X40.491 Z-21.866
N6433 X40.979 Z-20.339
N6434 X41.571 Z-18.178
N6435 X42.184 Z-15.229
N6436 X42.44 Z-13.521
N6437 X42.798 Z-9.748
N6438 X43.003 Z-8.618
N6439 X43.217 Z-7.836
N6440 X43.554 Z-6.906
N6441 X43.779 Z-6.407
N6442 X44.228 Z-5.548
N6443 X44.677 Z-4.838
N6444 X45.35 Z-3.957
N6445 X45.799 Z-3.462
N6446 X46.248 Z-3.014
N6447 X46.697 Z-2.617
N6448 X47.146 Z-2.26
N6449 X47.595 Z-1.936
N6450 X48.493 Z-1.385
N6451 X49.391 Z-.942
N6452 X50.289 Z-.593
N6453 X51.187 Z-.33
N6454 X52.085 Z-.145
N6455 X52.984 Z-.036
N6456 X53.882 Z0.
N6457 Y54.575
N6458 X52.984 Z-.036
N6459 X52.085 Z-.145
N6460 X51.187 Z-.33
N6461 X50.289 Z-.593
N6462 X49.391 Z-.942
N6463 X48.493 Z-1.385
N6464 X47.595 Z-1.936
N6465 X47.146 Z-2.26
N6466 X46.697 Z-2.617
N6467 X46.248 Z-3.014
N6468 X45.799 Z-3.462
N6469 X45.35 Z-3.957
N6470 X44.677 Z-4.838
N6471 X44.228 Z-5.548
N6472 X43.779 Z-6.407
N6473 X43.554 Z-6.906
N6474 X43.217 Z-7.836
N6475 X43.003 Z-8.618
N6476 X42.798 Z-9.748
N6477 X42.44 Z-13.521
N6478 X42.184 Z-15.229
N6479 X41.571 Z-18.178
N6480 X40.979 Z-20.339
N6481 X40.491 Z-21.866
N6482 X39.758 Z-23.846
N6483 X39.033 Z-25.551
N6484 X38.554 Z-26.583
N6485 X38.074 Z-27.548
N6486 X37.115 Z-29.312
N6487 X36.156 Z-30.898
N6488 X35.676 Z-31.638
N6489 X34.839 Z-32.859
N6490 X34.002 Z-33.989
N6491 X33.166 Z-35.047
N6492 X32.329 Z-36.043
N6493 X31.408 Z-37.073
N6494 X30.487 Z-38.035
N6495 X29.566 Z-38.941
N6496 X28.645 Z-39.796
N6497 X27.77 Z-40.565
N6498 X26.895 Z-41.292
N6499 X26.02 Z-41.981
N6500 X25.145 Z-42.634
N6501 X24.233 Z-43.278
N6502 X23.321 Z-43.886
N6503 X22.41 Z-44.462
N6504 X20.614 Z-45.507
N6505 X18.845 Z-46.427
N6506 X17.961 Z-46.848
N6507 X16.151 Z-47.634
N6508 X14.342 Z-48.323
N6509 X12.559 Z-48.913
N6510 X10.776 Z-49.418
N6511 X8.958 Z-49.849
N6512 X7.169 Z-50.192
N6513 X5.362 Z-50.46
N6514 X3.592 Z-50.648
N6515 X1.797 Z-50.761
N6516 X0. Z-50.8
N6517 X-1.797 Z-50.761
N6518 X-3.592 Z-50.648
N6519 X-5.362 Z-50.46
N6520 X-7.169 Z-50.192
N6521 X-8.958 Z-49.849
N6522 X-10.776 Z-49.418
N6523 X-12.559 Z-48.913
N6524 X-14.342 Z-48.323
N6525 X-16.151 Z-47.634
N6526 X-17.961 Z-46.848
N6527 X-19.729 Z-45.98
N6528 X-21.498 Z-45.007
N6529 X-22.41 Z-44.462
N6530 X-23.321 Z-43.886
N6531 X-24.233 Z-43.278
N6532 X-25.145 Z-42.634
N6533 X-26.02 Z-41.981
N6534 X-26.895 Z-41.292
N6535 X-27.77 Z-40.565
N6536 X-28.645 Z-39.796
N6537 X-29.566 Z-38.941
N6538 X-30.487 Z-38.035
N6539 X-31.408 Z-37.073
N6540 X-32.329 Z-36.043
N6541 X-33.166 Z-35.047
N6542 X-34.002 Z-33.989
N6543 X-34.839 Z-32.859
N6544 X-35.676 Z-31.638
N6545 X-36.635 Z-30.125
N6546 X-37.595 Z-28.455
N6547 X-38.074 Z-27.548
N6548 X-38.554 Z-26.583
N6549 X-39.033 Z-25.551
N6550 X-39.758 Z-23.846
N6551 X-40.491 Z-21.866
N6552 X-41.346 Z-19.058
N6553 X-41.98 Z-16.328
N6554 X-42.491 Z-13.111
N6555 X-42.798 Z-9.748
N6556 X-42.901 Z-9.104
N6557 X-43.105 Z-8.22
N6558 X-43.33 Z-7.496
N6559 X-43.554 Z-6.906
N6560 X-44.003 Z-5.952
N6561 X-44.452 Z-5.184
N6562 X-44.901 Z-4.527
N6563 X-45.35 Z-3.957
N6564 X-45.799 Z-3.462
N6565 X-46.248 Z-3.014
N6566 X-46.697 Z-2.617
N6567 X-47.146 Z-2.26
N6568 X-47.595 Z-1.936
N6569 X-48.493 Z-1.385
N6570 X-49.391 Z-.942
N6571 X-50.289 Z-.593
N6572 X-51.187 Z-.33
N6573 X-52.085 Z-.145
N6574 X-52.984 Z-.036
N6575 X-53.882 Z0.
N6576 X-129.021 Y53.375
N6577 X-53.126 Z-.03
N6578 X-52.178 Z-.131
N6579 X-51.229 Z-.319
N6580 X-50.28 Z-.596
N6581 X-49.332 Z-.968
N6582 X-48.383 Z-1.447
N6583 X-47.909 Z-1.732
N6584 X-47.434 Z-2.05
N6585 X-46.96 Z-2.402
N6586 X-46.486 Z-2.802
N6587 X-46.011 Z-3.242
N6588 X-45.3 Z-4.018
N6589 X-44.588 Z-4.97
N6590 X-44.114 Z-5.746
N6591 X-43.64 Z-6.706
N6592 X-43.284 Z-7.633
N6593 X-43.047 Z-8.441
N6594 X-42.809 Z-9.668
N6595 X-42.454 Z-13.422
N6596 X-42.216 Z-15.03
N6597 X-41.861 Z-16.905
N6598 X-41.386 Z-18.901
N6599 X-40.793 Z-20.949
N6600 X-40.082 Z-23.003
N6601 X-39.37 Z-24.785
N6602 X-38.896 Z-25.853
N6603 X-38.422 Z-26.851
N6604 X-37.947 Z-27.788
N6605 X-37.448 Z-28.718
N6606 X-36.448 Z-30.432
N6607 X-35.448 Z-31.982
N6608 X-34.449 Z-33.393
N6609 X-33.5 Z-34.636
N6610 X-32.153 Z-36.247
N6611 X-31.256 Z-37.234
N6612 X-30.358 Z-38.165
N6613 X-29.394 Z-39.106
N6614 X-28.43 Z-39.992
N6615 X-27.466 Z-40.821
N6616 X-26.502 Z-41.603
N6617 X-25.569 Z-42.318
N6618 X-24.635 Z-42.994
N6619 X-23.702 Z-43.634
N6620 X-22.768 Z-44.238
N6621 X-21.808 Z-44.824
N6622 X-20.847 Z-45.377
N6623 X-19.886 Z-45.897
N6624 X-18.926 Z-46.387
N6625 X-17.052 Z-47.255
N6626 X-15.179 Z-48.016
N6627 X-13.242 Z-48.699
N6628 X-11.361 Z-49.263
N6629 X-9.443 Z-49.744
N6630 X-7.589 Z-50.12
N6631 X-5.682 Z-50.42
N6632 X-3.788 Z-50.631
N6633 X-1.883 Z-50.758
N6634 X0. Z-50.8
N6635 X1.883 Z-50.758
N6636 X3.788 Z-50.631
N6637 X5.682 Z-50.42
N6638 X7.589 Z-50.12
N6639 X9.443 Z-49.744
N6640 X11.361 Z-49.263
N6641 X13.242 Z-48.699
N6642 X15.179 Z-48.016
N6643 X17.052 Z-47.255
N6644 X18.926 Z-46.387
N6645 X19.886 Z-45.897
N6646 X20.847 Z-45.377
N6647 X21.808 Z-44.824
N6648 X22.768 Z-44.238
N6649 X23.702 Z-43.634
N6650 X24.635 Z-42.994
N6651 X25.569 Z-42.318
N6652 X26.502 Z-41.603
N6653 X27.466 Z-40.821
N6654 X28.43 Z-39.992
N6655 X29.394 Z-39.106
N6656 X30.358 Z-38.165
N6657 X31.256 Z-37.234
N6658 X32.153 Z-36.247
N6659 X33.5 Z-34.636
N6660 X34.949 Z-32.702
N6661 X35.948 Z-31.226
N6662 X36.948 Z-29.597
N6663 X37.947 Z-27.788
N6664 X38.422 Z-26.851
N6665 X38.896 Z-25.853
N6666 X39.37 Z-24.785
N6667 X40.082 Z-23.003
N6668 X40.793 Z-20.949
N6669 X41.386 Z-18.901
N6670 X41.979 Z-16.331
N6671 X42.335 Z-14.287
N6672 X42.572 Z-12.403
N6673 X42.78 Z-9.898
N6674 X42.987 Z-8.686
N6675 X43.284 Z-7.633
N6676 X43.64 Z-6.706
N6677 X44.114 Z-5.746
N6678 X44.588 Z-4.97
N6679 X44.825 Z-4.629
N6680 X45.3 Z-4.018
N6681 X46.011 Z-3.242
N6682 X46.486 Z-2.802
N6683 X46.96 Z-2.402
N6684 X47.434 Z-2.05
N6685 X47.909 Z-1.731
N6686 X48.383 Z-1.447
N6687 X49.332 Z-.968
N6688 X50.28 Z-.596
N6689 X51.229 Z-.319
N6690 X52.178 Z-.131
N6691 X53.126 Z-.03
N6692 X60.716 Z-.014
N6693 X129.021 Z0.
N6694 X129.944 Y52.175
N6695 X128.869 Z-.048
N6696 X127.794 Z-.125
N6697 X53.834 Z-.131
N6698 X52.906 Z-.145
N6699 X51.978 Z-.231
N6700 X51.05 Z-.407
N6701 X50.121 Z-.675
N6702 X49.657 Z-.843
N6703 X48.729 Z-1.262
N6704 X47.801 Z-1.799
N6705 X46.873 Z-2.471
N6706 X46.409 Z-2.87
N6707 X45.945 Z-3.31
N6708 X45.48 Z-3.807
N6709 X44.784 Z-4.685
N6710 X44.552 Z-5.026
N6711 X44.088 Z-5.792
N6712 X43.624 Z-6.741
N6713 X43.276 Z-7.656
N6714 X42.986 Z-8.692
N6715 X42.783 Z-9.87
N6716 X42.58 Z-12.324
N6717 X42.348 Z-14.196
N6718 X42. Z-16.231
N6719 X41.768 Z-17.332
N6720 X41.304 Z-19.21
N6721 X40.84 Z-20.798
N6722 X40.082 Z-23.004
N6723 X39.323 Z-24.892
N6724 X38.565 Z-26.559
N6725 X37.807 Z-28.053
N6726 X36.796 Z-29.853
N6727 X35.951 Z-31.222
N6728 X35.105 Z-32.477
N6729 X34.26 Z-33.65
N6730 X33.414 Z-34.742
N6731 X32.462 Z-35.888
N6732 X31.51 Z-36.962
N6733 X30.558 Z-37.963
N6734 X29.606 Z-38.903
N6735 X28.702 Z-39.745
N6736 X27.798 Z-40.541
N6737 X26.893 Z-41.293
N6738 X25.989 Z-42.005
N6739 X25.046 Z-42.705
N6740 X24.102 Z-43.365
N6741 X23.159 Z-43.989
N6742 X22.216 Z-44.579
N6743 X21.303 Z-45.118
N6744 X19.476 Z-46.108
N6745 X17.627 Z-46.998
N6746 X15.755 Z-47.791
N6747 X14.819 Z-48.15
N6748 X12.978 Z-48.782
N6749 X11.138 Z-49.323
N6750 X9.256 Z-49.786
N6751 X7.406 Z-50.153
N6752 X5.54 Z-50.439
N6753 X3.713 Z-50.638
N6754 X1.858 Z-50.759
N6755 X0. Z-50.8
N6756 X-1.858 Z-50.759
N6757 X-3.713 Z-50.638
N6758 X-5.54 Z-50.439
N6759 X-7.406 Z-50.153
N6760 X-9.256 Z-49.786
N6761 X-11.138 Z-49.323
N6762 X-12.978 Z-48.782
N6763 X-14.819 Z-48.15
N6764 X-16.691 Z-47.408
N6765 X-18.563 Z-46.561
N6766 X-20.39 Z-45.627
N6767 X-21.303 Z-45.118
N6768 X-22.216 Z-44.579
N6769 X-23.159 Z-43.989
N6770 X-24.102 Z-43.365
N6771 X-25.046 Z-42.705
N6772 X-25.989 Z-42.005
N6773 X-26.893 Z-41.293
N6774 X-27.798 Z-40.541
N6775 X-28.702 Z-39.745
N6776 X-29.606 Z-38.903
N6777 X-30.558 Z-37.963
N6778 X-31.51 Z-36.962
N6779 X-32.462 Z-35.888
N6780 X-33.414 Z-34.742
N6781 X-34.26 Z-33.65
N6782 X-35.105 Z-32.477
N6783 X-35.951 Z-31.222
N6784 X-36.796 Z-29.853
N6785 X-38.06 Z-27.576
N6786 X-38.818 Z-26.02
N6787 X-39.323 Z-24.892
N6788 X-40.082 Z-23.004
N6789 X-40.587 Z-21.574
N6790 X-41.072 Z-20.036
N6791 X-41.536 Z-18.315
N6792 X-41.768 Z-17.332
N6793 X-42.232 Z-14.933
N6794 X-42.464 Z-13.347
N6795 X-42.812 Z-9.65
N6796 X-43.044 Z-8.451
N6797 X-43.392 Z-7.322
N6798 X-43.624 Z-6.741
N6799 X-44.088 Z-5.792
N6800 X-44.552 Z-5.025
N6801 X-45.016 Z-4.378
N6802 X-45.48 Z-3.807
N6803 X-45.945 Z-3.31
N6804 X-46.409 Z-2.87
N6805 X-46.873 Z-2.471
N6806 X-47.801 Z-1.799
N6807 X-48.729 Z-1.262
N6808 X-49.657 Z-.843
N6809 X-50.121 Z-.675
N6810 X-51.05 Z-.407
N6811 X-51.978 Z-.231
N6812 X-52.906 Z-.145
N6813 X-127.804 Z-.125
N6814 X-128.874 Z-.048
N6815 X-129.944 Z0.
N6816 X-130.166 Y50.975
N6817 X-129.236 Z-.039
N6818 X-128.307 Z-.156
N6819 X-127.132 Z-.384
N6820 X-52.996 Z-.386
N6821 X-52.066 Z-.435
N6822 X-51.137 Z-.575
N6823 X-50.672 Z-.678
N6824 X-49.742 Z-.957
N6825 X-48.812 Z-1.34
N6826 X-48.347 Z-1.573
N6827 X-47.418 Z-2.133
N6828 X-46.953 Z-2.471
N6829 X-46.488 Z-2.842
N6830 X-46.023 Z-3.27
N6831 X-45.558 Z-3.743
N6832 X-45.093 Z-4.293
N6833 X-44.628 Z-4.92
N6834 X-44.164 Z-5.66
N6835 X-43.931 Z-6.096
N6836 X-43.582 Z-6.838
N6837 X-43.234 Z-7.786
N6838 X-43.001 Z-8.625
N6839 X-42.827 Z-9.548
N6840 X-42.478 Z-13.225
N6841 X-42.188 Z-15.21
N6842 X-41.839 Z-17.01
N6843 X-41.374 Z-18.949
N6844 X-40.909 Z-20.569
N6845 X-40.148 Z-22.829
N6846 X-39.386 Z-24.748
N6847 X-38.879 Z-25.89
N6848 X-38.371 Z-26.953
N6849 X-37.863 Z-27.947
N6850 X-36.848 Z-29.765
N6851 X-36.004 Z-31.14
N6852 X-34.738 Z-33.
N6853 X-33.471 Z-34.672
N6854 X-32.516 Z-35.825
N6855 X-31.56 Z-36.907
N6856 X-30.604 Z-37.917
N6857 X-29.648 Z-38.862
N6858 X-28.745 Z-39.706
N6859 X-27.841 Z-40.503
N6860 X-26.937 Z-41.257
N6861 X-26.033 Z-41.97
N6862 X-25.09 Z-42.673
N6863 X-24.147 Z-43.336
N6864 X-23.203 Z-43.961
N6865 X-22.26 Z-44.552
N6866 X-21.344 Z-45.095
N6867 X-20.428 Z-45.607
N6868 X-18.595 Z-46.546
N6869 X-16.719 Z-47.396
N6870 X-14.844 Z-48.14
N6871 X-13. Z-48.775
N6872 X-11.157 Z-49.318
N6873 X-9.272 Z-49.782
N6874 X-7.421 Z-50.151
N6875 X-5.554 Z-50.438
N6876 X-3.719 Z-50.637
N6877 X-1.862 Z-50.759
N6878 X0. Z-50.8
N6879 X1.862 Z-50.759
N6880 X3.719 Z-50.637
N6881 X5.554 Z-50.438
N6882 X7.421 Z-50.151
N6883 X9.272 Z-49.782
N6884 X11.157 Z-49.318
N6885 X13. Z-48.775
N6886 X14.844 Z-48.14
N6887 X15.782 Z-47.781
N6888 X17.657 Z-46.985
N6889 X19.511 Z-46.09
N6890 X21.344 Z-45.095
N6891 X22.26 Z-44.552
N6892 X23.203 Z-43.961
N6893 X24.147 Z-43.336
N6894 X25.09 Z-42.673
N6895 X26.033 Z-41.97
N6896 X26.937 Z-41.257
N6897 X27.841 Z-40.503
N6898 X28.745 Z-39.706
N6899 X29.648 Z-38.862
N6900 X30.604 Z-37.917
N6901 X31.56 Z-36.907
N6902 X32.516 Z-35.825
N6903 X33.471 Z-34.672
N6904 X34.738 Z-33.
N6905 X36.004 Z-31.14
N6906 X36.848 Z-29.765
N6907 X37.863 Z-27.947
N6908 X38.371 Z-26.953
N6909 X38.879 Z-25.89
N6910 X39.386 Z-24.748
N6911 X40.148 Z-22.829
N6912 X40.656 Z-21.367
N6913 X41.374 Z-18.949
N6914 X41.839 Z-17.01
N6915 X42.188 Z-15.21
N6916 X42.478 Z-13.225
N6917 X42.798 Z-9.751
N6918 X43.001 Z-8.625
N6919 X43.234 Z-7.786
N6920 X43.582 Z-6.838
N6921 X44.164 Z-5.66
N6922 X44.628 Z-4.92
N6923 X44.861 Z-4.59
N6924 X45.558 Z-3.743
N6925 X46.023 Z-3.27
N6926 X46.488 Z-2.842
N6927 X46.953 Z-2.471
N6928 X47.418 Z-2.133
N6929 X48.347 Z-1.573
N6930 X48.812 Z-1.34
N6931 X49.742 Z-.957
N6932 X50.207 Z-.808
N6933 X51.137 Z-.574
N6934 X52.066 Z-.435
N6935 X52.996 Z-.386
N6936 X127.132 Z-.384
N6937 X128.307 Z-.156
N6938 X129.236 Z-.039
N6939 X130.166 Z0.
N6940 X130.175 Y49.775
N6941 X129.245 Z-.039
N6942 X128.315 Z-.156
N6943 X127.386 Z-.354
N6944 X126.107 Z-.767
N6945 X125.991 Z-.782
N6946 X55.789 Z-.785
N6947 X52.07 Z-.804
N6948 X51.14 Z-.916
N6949 X50.675 Z-1.008
N6950 X49.745 Z-1.263
N6951 X48.816 Z-1.625
N6952 X48.351 Z-1.847
N6953 X47.421 Z-2.389
N6954 X46.956 Z-2.718
N6955 X46.491 Z-3.082
N6956 X46.026 Z-3.498
N6957 X45.561 Z-3.967
N6958 X45.096 Z-4.507
N6959 X44.631 Z-5.127
N6960 X44.167 Z-5.875
N6961 X43.934 Z-6.295
N6962 X43.585 Z-7.045
N6963 X43.237 Z-8.014
N6964 X42.946 Z-9.187
N6965 X42.801 Z-10.257
N6966 X42.481 Z-13.389
N6967 X42.191 Z-15.222
N6968 X41.842 Z-16.996
N6969 X41.377 Z-18.938
N6970 X40.658 Z-21.359
N6971 X40.151 Z-22.822
N6972 X39.389 Z-24.742
N6973 X38.881 Z-25.885
N6974 X38.373 Z-26.948
N6975 X37.866 Z-27.943
N6976 X36.85 Z-29.762
N6977 X36.006 Z-31.137
N6978 X34.74 Z-32.997
N6979 X33.474 Z-34.669
N6980 X32.518 Z-35.823
N6981 X31.562 Z-36.905
N6982 X30.606 Z-37.915
N6983 X29.65 Z-38.861
N6984 X28.746 Z-39.704
N6985 X27.843 Z-40.502
N6986 X26.939 Z-41.256
N6987 X26.035 Z-41.969
N6988 X25.092 Z-42.672
N6989 X24.148 Z-43.334
N6990 X23.205 Z-43.96
N6991 X22.262 Z-44.551
N6992 X21.345 Z-45.094
N6993 X19.513 Z-46.09
N6994 X17.658 Z-46.984
N6995 X15.783 Z-47.781
N6996 X14.845 Z-48.14
N6997 X13.001 Z-48.775
N6998 X11.158 Z-49.318
N6999 X9.273 Z-49.782
N7000 X7.422 Z-50.151
N7001 X5.554 Z-50.437
N7002 X3.719 Z-50.637
N7003 X1.862 Z-50.759
N7004 X0. Z-50.8
N7005 X-1.862 Z-50.759
N7006 X-3.719 Z-50.637
N7007 X-5.554 Z-50.437
N7008 X-7.422 Z-50.151
N7009 X-9.273 Z-49.782
N7010 X-11.158 Z-49.318
N7011 X-13.001 Z-48.775
N7012 X-14.845 Z-48.14
N7013 X-16.721 Z-47.395
N7014 X-18.596 Z-46.545
N7015 X-20.429 Z-45.606
N7016 X-21.345 Z-45.094
N7017 X-22.262 Z-44.551
N7018 X-23.205 Z-43.96
N7019 X-24.148 Z-43.334
N7020 X-25.092 Z-42.672
N7021 X-26.035 Z-41.969
N7022 X-26.939 Z-41.256
N7023 X-27.843 Z-40.502
N7024 X-28.746 Z-39.704
N7025 X-29.65 Z-38.861
N7026 X-30.606 Z-37.915
N7027 X-31.562 Z-36.905
N7028 X-32.518 Z-35.823
N7029 X-33.474 Z-34.669
N7030 X-34.74 Z-32.997
N7031 X-36.006 Z-31.137
N7032 X-36.85 Z-29.762
N7033 X-37.866 Z-27.943
N7034 X-38.373 Z-26.948
N7035 X-38.881 Z-25.885
N7036 X-39.389 Z-24.742
N7037 X-40.151 Z-22.822
N7038 X-41.028 Z-20.178
N7039 X-41.377 Z-18.938
N7040 X-41.842 Z-16.996
N7041 X-42.191 Z-15.222
N7042 X-42.656 Z-11.943
N7043 X-42.888 Z-9.531
N7044 X-43.004 Z-8.901
N7045 X-43.237 Z-8.014
N7046 X-43.585 Z-7.045
N7047 X-43.934 Z-6.295
N7048 X-44.399 Z-5.48
N7049 X-44.631 Z-5.127
N7050 X-45.096 Z-4.507
N7051 X-45.561 Z-3.968
N7052 X-46.026 Z-3.498
N7053 X-46.491 Z-3.082
N7054 X-46.956 Z-2.718
N7055 X-47.421 Z-2.389
N7056 X-48.351 Z-1.847
N7057 X-49.281 Z-1.432
N7058 X-49.745 Z-1.263
N7059 X-50.675 Z-1.007
N7060 X-51.14 Z-.916
N7061 X-52.07 Z-.804
N7062 X-55.789 Z-.785
N7063 X-125.991 Z-.782
N7064 X-126.107 Z-.767
N7065 X-126.456 Z-.638
N7066 X-127.386 Z-.354
N7067 X-128.315 Z-.156
N7068 X-129.245 Z-.039
N7069 X-130.175 Z0.
N7070 Y48.575
N7071 X-129.245 Z-.039
N7072 X-128.315 Z-.156
N7073 X-127.386 Z-.354
N7074 X-126.456 Z-.638
N7075 X-125.554 Z-1.002
N7076 X-124.878 Z-1.339
N7077 X-52.07 Z-1.346
N7078 X-51.14 Z-1.429
N7079 X-50.675 Z-1.509
N7080 X-49.745 Z-1.744
N7081 X-49.281 Z-1.905
N7082 X-48.351 Z-2.309
N7083 X-47.421 Z-2.847
N7084 X-46.956 Z-3.173
N7085 X-46.491 Z-3.546
N7086 X-46.026 Z-3.962
N7087 X-45.561 Z-4.451
N7088 X-45.096 Z-4.999
N7089 X-44.864 Z-5.316
N7090 X-44.399 Z-6.025
N7091 X-43.934 Z-6.909
N7092 X-43.702 Z-7.451
N7093 X-43.469 Z-8.107
N7094 X-43.237 Z-8.972
N7095 X-43.12 Z-9.586
N7096 X-42.83 Z-12.275
N7097 X-42.539 Z-14.125
N7098 X-42.191 Z-15.834
N7099 X-41.61 Z-18.161
N7100 X-40.912 Z-20.56
N7101 X-40.151 Z-22.822
N7102 X-39.389 Z-24.742
N7103 X-38.881 Z-25.885
N7104 X-38.373 Z-26.948
N7105 X-37.866 Z-27.943
N7106 X-36.85 Z-29.762
N7107 X-36.006 Z-31.137
N7108 X-34.74 Z-32.997
N7109 X-33.474 Z-34.669
N7110 X-32.518 Z-35.823
N7111 X-31.562 Z-36.905
N7112 X-30.606 Z-37.915
N7113 X-29.65 Z-38.861
N7114 X-28.746 Z-39.704
N7115 X-27.843 Z-40.502
N7116 X-26.939 Z-41.256
N7117 X-26.035 Z-41.969
N7118 X-25.092 Z-42.672
N7119 X-24.148 Z-43.334
N7120 X-23.205 Z-43.96
N7121 X-22.262 Z-44.551
N7122 X-21.345 Z-45.094
N7123 X-20.429 Z-45.606
N7124 X-18.596 Z-46.545
N7125 X-16.721 Z-47.395
N7126 X-14.845 Z-48.14
N7127 X-13.001 Z-48.775
N7128 X-11.158 Z-49.318
N7129 X-9.273 Z-49.782
N7130 X-7.422 Z-50.151
N7131 X-5.554 Z-50.437
N7132 X-3.719 Z-50.637
N7133 X-1.862 Z-50.759
N7134 X0. Z-50.8
N7135 X1.862 Z-50.759
N7136 X3.719 Z-50.637
N7137 X5.554 Z-50.437
N7138 X7.422 Z-50.151
N7139 X9.273 Z-49.782
N7140 X11.158 Z-49.318
N7141 X13.001 Z-48.775
N7142 X14.845 Z-48.14
N7143 X15.783 Z-47.781
N7144 X17.658 Z-46.984
N7145 X19.513 Z-46.09
N7146 X21.345 Z-45.094
N7147 X22.262 Z-44.551
N7148 X23.205 Z-43.96
N7149 X24.148 Z-43.334
N7150 X25.092 Z-42.672
N7151 X26.035 Z-41.969
N7152 X26.939 Z-41.256
N7153 X27.843 Z-40.502
N7154 X28.746 Z-39.704
N7155 X29.65 Z-38.861
N7156 X30.606 Z-37.915
N7157 X31.562 Z-36.905
N7158 X32.518 Z-35.823
N7159 X33.474 Z-34.669
N7160 X34.74 Z-32.997
N7161 X36.006 Z-31.137
N7162 X36.85 Z-29.762
N7163 X37.866 Z-27.943
N7164 X38.373 Z-26.948
N7165 X38.881 Z-25.885
N7166 X39.389 Z-24.742
N7167 X40.151 Z-22.822
N7168 X40.658 Z-21.359
N7169 X41.145 Z-19.795
N7170 X41.842 Z-17.278
N7171 X42.307 Z-15.294
N7172 X42.714 Z-13.092
N7173 X43.12 Z-9.586
N7174 X43.353 Z-8.507
N7175 X43.585 Z-7.765
N7176 X43.934 Z-6.909
N7177 X44.399 Z-6.025
N7178 X44.631 Z-5.66
N7179 X45.096 Z-4.999
N7180 X45.561 Z-4.451
N7181 X46.026 Z-3.962
N7182 X46.491 Z-3.546
N7183 X46.956 Z-3.173
N7184 X47.421 Z-2.847
N7185 X48.351 Z-2.309
N7186 X49.281 Z-1.906
N7187 X49.745 Z-1.744
N7188 X50.675 Z-1.509
N7189 X51.14 Z-1.429
N7190 X52.07 Z-1.347
N7191 X124.878 Z-1.339
N7192 X125.554 Z-1.002
N7193 X126.456 Z-.638
N7194 X127.386 Z-.354
N7195 X128.315 Z-.156
N7196 X129.245 Z-.039
N7197 X130.175 Z0.
N7198 Y47.375
N7199 X129.245 Z-.039
N7200 X128.315 Z-.156
N7201 X127.386 Z-.354
N7202 X126.456 Z-.638
N7203 X125.526 Z-1.015
N7204 X125.061 Z-1.24
N7205 X124.596 Z-1.495
N7206 X123.676 Z-2.087
N7207 X51.605 Z-2.104
N7208 X51.14 Z-2.141
N7209 X50.21 Z-2.307
N7210 X49.745 Z-2.428
N7211 X49.281 Z-2.585
N7212 X48.816 Z-2.771
N7213 X48.351 Z-2.986
N7214 X47.886 Z-3.245
N7215 X47.421 Z-3.537
N7216 X46.956 Z-3.872
N7217 X46.491 Z-4.267
N7218 X46.026 Z-4.706
N7219 X45.561 Z-5.234
N7220 X45.096 Z-5.838
N7221 X44.631 Z-6.579
N7222 X44.283 Z-7.265
N7223 X43.934 Z-8.143
N7224 X43.702 Z-8.941
N7225 X43.498 Z-10.08
N7226 X43.237 Z-12.274
N7227 X42.888 Z-14.169
N7228 X42.539 Z-15.654
N7229 X41.842 Z-18.072
N7230 X41.377 Z-19.484
N7231 X40.397 Z-22.179
N7232 X39.368 Z-24.791
N7233 X38.853 Z-25.946
N7234 X38.08 Z-27.536
N7235 X37.308 Z-28.967
N7236 X36.793 Z-29.858
N7237 X35.963 Z-31.203
N7238 X35.133 Z-32.437
N7239 X34.304 Z-33.591
N7240 X33.474 Z-34.669
N7241 X32.518 Z-35.823
N7242 X31.562 Z-36.905
N7243 X30.606 Z-37.915
N7244 X29.65 Z-38.861
N7245 X28.746 Z-39.704
N7246 X27.843 Z-40.502
N7247 X26.939 Z-41.256
N7248 X26.035 Z-41.969
N7249 X25.092 Z-42.672
N7250 X24.148 Z-43.334
N7251 X23.205 Z-43.96
N7252 X22.262 Z-44.551
N7253 X21.345 Z-45.094
N7254 X19.513 Z-46.09
N7255 X17.658 Z-46.984
N7256 X15.783 Z-47.781
N7257 X14.845 Z-48.14
N7258 X13.001 Z-48.775
N7259 X11.158 Z-49.318
N7260 X9.273 Z-49.782
N7261 X7.422 Z-50.151
N7262 X5.554 Z-50.437
N7263 X3.719 Z-50.637
N7264 X1.862 Z-50.759
N7265 X0. Z-50.8
N7266 X-1.862 Z-50.759
N7267 X-3.719 Z-50.637
N7268 X-5.554 Z-50.437
N7269 X-7.422 Z-50.151
N7270 X-9.273 Z-49.782
N7271 X-11.158 Z-49.318
N7272 X-13.001 Z-48.775
N7273 X-14.845 Z-48.14
N7274 X-16.721 Z-47.395
N7275 X-18.596 Z-46.545
N7276 X-20.429 Z-45.606
N7277 X-21.345 Z-45.094
N7278 X-22.262 Z-44.551
N7279 X-23.205 Z-43.96
N7280 X-24.148 Z-43.334
N7281 X-25.092 Z-42.672
N7282 X-26.035 Z-41.969
N7283 X-26.939 Z-41.256
N7284 X-27.843 Z-40.502
N7285 X-28.746 Z-39.704
N7286 X-29.65 Z-38.861
N7287 X-30.606 Z-37.915
N7288 X-31.562 Z-36.905
N7289 X-32.518 Z-35.823
N7290 X-33.474 Z-34.669
N7291 X-34.304 Z-33.591
N7292 X-35.133 Z-32.437
N7293 X-35.963 Z-31.203
N7294 X-36.793 Z-29.858
N7295 X-37.308 Z-28.967
N7296 X-38.08 Z-27.536
N7297 X-38.853 Z-25.946
N7298 X-39.368 Z-24.791
N7299 X-39.882 Z-23.523
N7300 X-40.912 Z-20.799
N7301 X-41.61 Z-18.796
N7302 X-42.307 Z-16.517
N7303 X-42.772 Z-14.697
N7304 X-43.12 Z-12.989
N7305 X-43.411 Z-10.916
N7306 X-43.585 Z-9.487
N7307 X-43.818 Z-8.513
N7308 X-44.167 Z-7.532
N7309 X-44.399 Z-7.024
N7310 X-44.631 Z-6.579
N7311 X-45.096 Z-5.838
N7312 X-45.794 Z-4.957
N7313 X-46.026 Z-4.706
N7314 X-46.491 Z-4.267
N7315 X-46.956 Z-3.872
N7316 X-47.421 Z-3.537
N7317 X-47.886 Z-3.245
N7318 X-48.351 Z-2.986
N7319 X-48.816 Z-2.771
N7320 X-49.281 Z-2.585
N7321 X-49.745 Z-2.428
N7322 X-50.675 Z-2.211
N7323 X-51.14 Z-2.141
N7324 X-51.605 Z-2.104
N7325 X-123.676 Z-2.087
N7326 X-124.07 Z-1.816
N7327 X-124.596 Z-1.495
N7328 X-125.061 Z-1.24
N7329 X-125.526 Z-1.015
N7330 X-126.456 Z-.638
N7331 X-127.386 Z-.354
N7332 X-128.315 Z-.156
N7333 X-129.245 Z-.039
N7334 X-130.175 Z0.
N7335 Y46.175
N7336 X-129.245 Z-.039
N7337 X-128.315 Z-.156
N7338 X-127.386 Z-.354
N7339 X-126.456 Z-.638
N7340 X-125.526 Z-1.015
N7341 X-125.061 Z-1.24
N7342 X-124.131 Z-1.776
N7343 X-123.666 Z-2.094
N7344 X-123.201 Z-2.444
N7345 X-122.454 Z-3.082
N7346 X-52.07 Z-3.083
N7347 X-51.14 Z-3.107
N7348 X-50.21 Z-3.247
N7349 X-49.745 Z-3.366
N7350 X-48.816 Z-3.711
N7351 X-48.351 Z-3.936
N7352 X-47.886 Z-4.213
N7353 X-47.421 Z-4.524
N7354 X-46.956 Z-4.893
N7355 X-46.491 Z-5.336
N7356 X-46.026 Z-5.838
N7357 X-45.561 Z-6.454
N7358 X-45.096 Z-7.223
N7359 X-44.864 Z-7.698
N7360 X-44.545 Z-8.511
N7361 X-44.286 Z-9.476
N7362 X-44.07 Z-11.052
N7363 X-43.768 Z-12.877
N7364 X-43.595 Z-13.667
N7365 X-43.336 Z-14.71
N7366 X-42.543 Z-17.262
N7367 X-41.679 Z-19.562
N7368 X-40.912 Z-21.397
N7369 X-38.71 Z-26.25
N7370 X-38.16 Z-27.377
N7371 X-37.609 Z-28.427
N7372 X-37.059 Z-29.41
N7373 X-36.508 Z-30.335
N7374 X-35.37 Z-32.097
N7375 X-34.232 Z-33.687
N7376 X-33.474 Z-34.669
N7377 X-32.518 Z-35.823
N7378 X-31.562 Z-36.905
N7379 X-30.606 Z-37.915
N7380 X-29.65 Z-38.861
N7381 X-28.746 Z-39.704
N7382 X-27.843 Z-40.502
N7383 X-26.939 Z-41.256
N7384 X-26.035 Z-41.969
N7385 X-25.092 Z-42.672
N7386 X-24.148 Z-43.334
N7387 X-23.205 Z-43.96
N7388 X-22.262 Z-44.551
N7389 X-21.345 Z-45.094
N7390 X-20.429 Z-45.606
N7391 X-18.596 Z-46.545
N7392 X-16.721 Z-47.395
N7393 X-14.845 Z-48.14
N7394 X-13.001 Z-48.775
N7395 X-11.158 Z-49.318
N7396 X-9.273 Z-49.782
N7397 X-7.422 Z-50.151
N7398 X-5.554 Z-50.437
N7399 X-3.719 Z-50.637
N7400 X-1.862 Z-50.759
N7401 X0. Z-50.8
N7402 X1.862 Z-50.759
N7403 X3.719 Z-50.637
N7404 X5.554 Z-50.437
N7405 X7.422 Z-50.151
N7406 X9.273 Z-49.782
N7407 X11.158 Z-49.318
N7408 X13.001 Z-48.775
N7409 X14.845 Z-48.14
N7410 X15.783 Z-47.781
N7411 X17.658 Z-46.984
N7412 X19.513 Z-46.09
N7413 X21.345 Z-45.094
N7414 X22.262 Z-44.551
N7415 X23.205 Z-43.96
N7416 X24.148 Z-43.334
N7417 X25.092 Z-42.672
N7418 X26.035 Z-41.969
N7419 X26.939 Z-41.256
N7420 X27.843 Z-40.502
N7421 X28.746 Z-39.704
N7422 X29.65 Z-38.861
N7423 X30.606 Z-37.915
N7424 X31.562 Z-36.905
N7425 X32.518 Z-35.823
N7426 X33.474 Z-34.669
N7427 X34.232 Z-33.687
N7428 X35.37 Z-32.097
N7429 X36.508 Z-30.335
N7430 X37.059 Z-29.41
N7431 X37.609 Z-28.427
N7432 X38.16 Z-27.377
N7433 X38.71 Z-26.25
N7434 X40.362 Z-22.641
N7435 X41.401 Z-20.241
N7436 X41.993 Z-18.76
N7437 X42.778 Z-16.575
N7438 X43.249 Z-15.015
N7439 X43.768 Z-12.877
N7440 X43.94 Z-11.932
N7441 X44.243 Z-9.707
N7442 X44.459 Z-8.784
N7443 X44.748 Z-7.964
N7444 X45.096 Z-7.223
N7445 X45.561 Z-6.454
N7446 X46.026 Z-5.838
N7447 X46.259 Z-5.574
N7448 X46.956 Z-4.893
N7449 X47.421 Z-4.524
N7450 X47.886 Z-4.213
N7451 X48.351 Z-3.936
N7452 X48.816 Z-3.71
N7453 X49.745 Z-3.366
N7454 X50.21 Z-3.247
N7455 X51.14 Z-3.107
N7456 X52.07 Z-3.083
N7457 X122.454 Z-3.082
N7458 X123.201 Z-2.444
N7459 X123.666 Z-2.094
N7460 X124.131 Z-1.776
N7461 X125.061 Z-1.24
N7462 X125.526 Z-1.015
N7463 X126.456 Z-.638
N7464 X127.386 Z-.354
N7465 X128.315 Z-.156
N7466 X129.245 Z-.039
N7467 X130.175 Z0.
N7468 Y44.975
N7469 X129.245 Z-.039
N7470 X128.315 Z-.156
N7471 X127.386 Z-.354
N7472 X126.456 Z-.638
N7473 X125.526 Z-1.015
N7474 X125.061 Z-1.24
N7475 X124.131 Z-1.776
N7476 X123.666 Z-2.094
N7477 X123.201 Z-2.444
N7478 X122.736 Z-2.837
N7479 X122.272 Z-3.278
N7480 X121.807 Z-3.769
N7481 X121.284 Z-4.409
N7482 X121.255 Z-4.429
N7483 X51.14 Z-4.433
N7484 X50.675 Z-4.468
N7485 X50.21 Z-4.548
N7486 X49.745 Z-4.673
N7487 X49.281 Z-4.83
N7488 X48.816 Z-5.033
N7489 X48.351 Z-5.294
N7490 X47.886 Z-5.606
N7491 X47.421 Z-5.975
N7492 X46.956 Z-6.432
N7493 X46.491 Z-6.995
N7494 X46.259 Z-7.329
N7495 X45.91 Z-7.928
N7496 X45.561 Z-8.721
N7497 X45.329 Z-9.483
N7498 X45.213 Z-10.07
N7499 X44.864 Z-12.183
N7500 X44.631 Z-13.173
N7501 X44.24 Z-14.549
N7502 X43.628 Z-16.31
N7503 X42.965 Z-17.939
N7504 X42.452 Z-19.093
N7505 X41.425 Z-21.219
N7506 X39.677 Z-24.552
N7507 X37.207 Z-29.148
N7508 X36.589 Z-30.202
N7509 X35.972 Z-31.19
N7510 X35.347 Z-32.13
N7511 X34.723 Z-33.02
N7512 X33.474 Z-34.669
N7513 X32.518 Z-35.823
N7514 X31.562 Z-36.905
N7515 X30.606 Z-37.915
N7516 X29.65 Z-38.861
N7517 X28.746 Z-39.704
N7518 X27.843 Z-40.502
N7519 X26.939 Z-41.256
N7520 X26.035 Z-41.969
N7521 X25.092 Z-42.672
N7522 X24.148 Z-43.334
N7523 X23.205 Z-43.96
N7524 X22.262 Z-44.551
N7525 X21.345 Z-45.094
N7526 X19.513 Z-46.09
N7527 X17.658 Z-46.984
N7528 X15.783 Z-47.781
N7529 X14.845 Z-48.14
N7530 X13.001 Z-48.775
N7531 X11.158 Z-49.318
N7532 X9.273 Z-49.782
N7533 X7.422 Z-50.151
N7534 X5.554 Z-50.437
N7535 X3.719 Z-50.637
N7536 X1.862 Z-50.759
N7537 X0. Z-50.8
N7538 X-1.862 Z-50.759
N7539 X-3.719 Z-50.637
N7540 X-5.554 Z-50.437
N7541 X-7.422 Z-50.151
N7542 X-9.273 Z-49.782
N7543 X-11.158 Z-49.318
N7544 X-13.001 Z-48.775
N7545 X-14.845 Z-48.14
N7546 X-16.721 Z-47.395
N7547 X-18.596 Z-46.545
N7548 X-20.429 Z-45.606
N7549 X-21.345 Z-45.094
N7550 X-22.262 Z-44.551
N7551 X-23.205 Z-43.96
N7552 X-24.148 Z-43.334
N7553 X-25.092 Z-42.672
N7554 X-26.035 Z-41.969
N7555 X-26.939 Z-41.256
N7556 X-27.843 Z-40.502
N7557 X-28.746 Z-39.704
N7558 X-29.65 Z-38.861
N7559 X-30.606 Z-37.915
N7560 X-31.562 Z-36.905
N7561 X-32.518 Z-35.823
N7562 X-33.474 Z-34.669
N7563 X-34.723 Z-33.02
N7564 X-35.347 Z-32.13
N7565 X-35.972 Z-31.19
N7566 X-36.589 Z-30.202
N7567 X-37.207 Z-29.148
N7568 X-40.912 Z-22.222
N7569 X-41.939 Z-20.181
N7570 X-42.452 Z-19.093
N7571 X-43.186 Z-17.426
N7572 X-43.849 Z-15.713
N7573 X-44.24 Z-14.549
N7574 X-44.748 Z-12.7
N7575 X-45.096 Z-10.878
N7576 X-45.271 Z-9.748
N7577 X-45.445 Z-9.072
N7578 X-45.677 Z-8.429
N7579 X-46.026 Z-7.714
N7580 X-46.259 Z-7.329
N7581 X-46.724 Z-6.698
N7582 X-46.956 Z-6.432
N7583 X-47.421 Z-5.975
N7584 X-47.886 Z-5.606
N7585 X-48.351 Z-5.294
N7586 X-48.816 Z-5.033
N7587 X-49.281 Z-4.83
N7588 X-49.745 Z-4.673
N7589 X-50.21 Z-4.548
N7590 X-50.675 Z-4.468
N7591 X-51.14 Z-4.434
N7592 X-121.255 Z-4.429
N7593 X-121.284 Z-4.409
N7594 X-121.807 Z-3.769
N7595 X-122.272 Z-3.278
N7596 X-122.736 Z-2.837
N7597 X-123.201 Z-2.444
N7598 X-123.666 Z-2.094
N7599 X-124.131 Z-1.776
N7600 X-125.061 Z-1.24
N7601 X-125.526 Z-1.015
N7602 X-126.456 Z-.638
N7603 X-127.386 Z-.354
N7604 X-128.315 Z-.156
N7605 X-129.245 Z-.039
N7606 X-130.175 Z0.
N7607 Y43.775
N7608 X-129.245 Z-.039
N7609 X-128.315 Z-.156
N7610 X-127.386 Z-.354
N7611 X-126.456 Z-.638
N7612 X-125.526 Z-1.015
N7613 X-125.061 Z-1.24
N7614 X-124.131 Z-1.776
N7615 X-123.666 Z-2.094
N7616 X-123.201 Z-2.444
N7617 X-122.736 Z-2.837
N7618 X-122.272 Z-3.278
N7619 X-121.807 Z-3.769
N7620 X-121.342 Z-4.335
N7621 X-120.877 Z-4.981
N7622 X-120.412 Z-5.739
N7623 X-120.063 Z-6.409
N7624 X-50.675 Z-6.427
N7625 X-50.21 Z-6.495
N7626 X-49.745 Z-6.629
N7627 X-49.281 Z-6.827
N7628 X-48.816 Z-7.099
N7629 X-48.351 Z-7.455
N7630 X-47.886 Z-7.93
N7631 X-47.653 Z-8.227
N7632 X-47.305 Z-8.785
N7633 X-47.072 Z-9.293
N7634 X-46.898 Z-9.814
N7635 X-46.607 Z-11.232
N7636 X-46.142 Z-12.948
N7637 X-45.794 Z-13.948
N7638 X-45.096 Z-15.651
N7639 X-44.631 Z-16.645
N7640 X-43.702 Z-18.456
N7641 X-42.772 Z-20.121
N7642 X-41.842 Z-21.681
N7643 X-38.123 Z-27.654
N7644 X-36.263 Z-30.727
N7645 X-35.798 Z-31.453
N7646 X-34.868 Z-32.817
N7647 X-33.474 Z-34.669
N7648 X-32.518 Z-35.823
N7649 X-31.562 Z-36.905
N7650 X-30.606 Z-37.915
N7651 X-29.65 Z-38.861
N7652 X-28.746 Z-39.704
N7653 X-27.843 Z-40.502
N7654 X-26.939 Z-41.256
N7655 X-26.035 Z-41.969
N7656 X-25.092 Z-42.672
N7657 X-24.148 Z-43.334
N7658 X-23.205 Z-43.96
N7659 X-22.262 Z-44.551
N7660 X-21.345 Z-45.094
N7661 X-20.429 Z-45.606
N7662 X-18.596 Z-46.545
N7663 X-16.721 Z-47.395
N7664 X-14.845 Z-48.14
N7665 X-13.001 Z-48.775
N7666 X-11.158 Z-49.318
N7667 X-9.273 Z-49.782
N7668 X-7.422 Z-50.151
N7669 X-5.554 Z-50.437
N7670 X-3.719 Z-50.637
N7671 X-1.862 Z-50.759
N7672 X0. Z-50.8
N7673 X1.862 Z-50.759
N7674 X3.719 Z-50.637
N7675 X5.554 Z-50.437
N7676 X7.422 Z-50.151
N7677 X9.273 Z-49.782
N7678 X11.158 Z-49.318
N7679 X13.001 Z-48.775
N7680 X14.845 Z-48.14
N7681 X15.783 Z-47.781
N7682 X17.658 Z-46.984
N7683 X19.513 Z-46.09
N7684 X21.345 Z-45.094
N7685 X22.262 Z-44.551
N7686 X23.205 Z-43.96
N7687 X24.148 Z-43.334
N7688 X25.092 Z-42.672
N7689 X26.035 Z-41.969
N7690 X26.939 Z-41.256
N7691 X27.843 Z-40.502
N7692 X28.746 Z-39.704
N7693 X29.65 Z-38.861
N7694 X30.606 Z-37.915
N7695 X31.562 Z-36.905
N7696 X32.518 Z-35.823
N7697 X33.474 Z-34.669
N7698 X34.403 Z-33.455
N7699 X35.333 Z-32.15
N7700 X36.263 Z-30.727
N7701 X38.123 Z-27.654
N7702 X40.912 Z-23.197
N7703 X42.772 Z-20.121
N7704 X43.702 Z-18.456
N7705 X44.631 Z-16.645
N7706 X45.096 Z-15.651
N7707 X45.561 Z-14.548
N7708 X46.026 Z-13.284
N7709 X46.375 Z-12.162
N7710 X46.607 Z-11.232
N7711 X46.898 Z-9.814
N7712 X47.072 Z-9.293
N7713 X47.305 Z-8.785
N7714 X47.653 Z-8.227
N7715 X47.886 Z-7.93
N7716 X48.351 Z-7.455
N7717 X48.816 Z-7.1
N7718 X49.281 Z-6.827
N7719 X49.745 Z-6.629
N7720 X50.21 Z-6.495
N7721 X50.675 Z-6.427
N7722 X120.063 Z-6.409
N7723 X120.644 Z-5.343
N7724 X121.109 Z-4.641
N7725 X121.807 Z-3.769
N7726 X122.272 Z-3.278
N7727 X122.736 Z-2.837
N7728 X123.201 Z-2.444
N7729 X123.666 Z-2.094
N7730 X124.131 Z-1.776
N7731 X125.061 Z-1.24
N7732 X125.526 Z-1.015
N7733 X126.456 Z-.638
N7734 X127.386 Z-.354
N7735 X128.315 Z-.156
N7736 X129.245 Z-.039
N7737 X130.175 Z0.
N7738 Y42.575
N7739 X129.245 Z-.039
N7740 X128.315 Z-.156
N7741 X127.386 Z-.354
N7742 X126.456 Z-.638
N7743 X125.526 Z-1.015
N7744 X125.061 Z-1.24
N7745 X124.131 Z-1.776
N7746 X123.666 Z-2.094
N7747 X123.201 Z-2.444
N7748 X122.736 Z-2.837
N7749 X122.272 Z-3.278
N7750 X121.807 Z-3.769
N7751 X121.109 Z-4.641
N7752 X120.644 Z-5.343
N7753 X120.179 Z-6.185
N7754 X119.947 Z-6.674
N7755 X119.598 Z-7.568
N7756 X119.308 Z-8.571
N7757 X119.104 Z-9.653
N7758 X119.01 Z-10.724
N7759 X119.003 Z-12.378
N7760 X50.443 Z-12.382
N7761 X50.21 Z-12.43
N7762 X49.978 Z-12.531
N7763 X49.745 Z-12.68
N7764 X49.513 Z-12.876
N7765 X48.816 Z-13.619
N7766 X48.351 Z-14.205
N7767 X47.421 Z-15.444
N7768 X44.631 Z-19.296
N7769 X39.053 Z-26.787
N7770 X37.193 Z-29.38
N7771 X35.178 Z-32.373
N7772 X33.99 Z-34.005
N7773 X33.474 Z-34.669
N7774 X32.518 Z-35.823
N7775 X31.562 Z-36.905
N7776 X30.606 Z-37.915
N7777 X29.65 Z-38.861
N7778 X28.746 Z-39.704
N7779 X27.843 Z-40.502
N7780 X26.939 Z-41.256
N7781 X26.035 Z-41.969
N7782 X25.092 Z-42.672
N7783 X24.148 Z-43.334
N7784 X23.205 Z-43.96
N7785 X22.262 Z-44.551
N7786 X21.345 Z-45.094
N7787 X19.513 Z-46.09
N7788 X17.658 Z-46.984
N7789 X15.783 Z-47.781
N7790 X14.845 Z-48.14
N7791 X13.001 Z-48.775
N7792 X11.158 Z-49.318
N7793 X9.273 Z-49.782
N7794 X7.422 Z-50.151
N7795 X5.554 Z-50.437
N7796 X3.719 Z-50.637
N7797 X1.862 Z-50.759
N7798 X0. Z-50.8
N7799 X-1.862 Z-50.759
N7800 X-3.719 Z-50.637
N7801 X-5.554 Z-50.437
N7802 X-7.422 Z-50.151
N7803 X-9.273 Z-49.782
N7804 X-11.158 Z-49.318
N7805 X-13.001 Z-48.775
N7806 X-14.845 Z-48.14
N7807 X-16.721 Z-47.395
N7808 X-18.596 Z-46.545
N7809 X-20.429 Z-45.606
N7810 X-21.345 Z-45.094
N7811 X-22.262 Z-44.551
N7812 X-23.205 Z-43.96
N7813 X-24.148 Z-43.334
N7814 X-25.092 Z-42.672
N7815 X-26.035 Z-41.969
N7816 X-26.939 Z-41.256
N7817 X-27.843 Z-40.502
N7818 X-28.746 Z-39.704
N7819 X-29.65 Z-38.861
N7820 X-30.606 Z-37.915
N7821 X-31.562 Z-36.905
N7822 X-32.518 Z-35.823
N7823 X-33.474 Z-34.669
N7824 X-34.506 Z-33.315
N7825 X-35.178 Z-32.373
N7826 X-37.193 Z-29.38
N7827 X-39.053 Z-26.787
N7828 X-44.631 Z-19.296
N7829 X-47.421 Z-15.444
N7830 X-48.351 Z-14.205
N7831 X-48.816 Z-13.619
N7832 X-49.513 Z-12.876
N7833 X-49.745 Z-12.68
N7834 X-49.978 Z-12.531
N7835 X-50.21 Z-12.43
N7836 X-50.443 Z-12.382
N7837 X-119.003 Z-12.378
N7838 X-119.046 Z-10.182
N7839 X-119.133 Z-9.454
N7840 X-119.366 Z-8.342
N7841 X-119.598 Z-7.568
N7842 X-119.947 Z-6.674
N7843 X-120.412 Z-5.739
N7844 X-120.877 Z-4.981
N7845 X-121.342 Z-4.335
N7846 X-121.807 Z-3.769
N7847 X-122.272 Z-3.278
N7848 X-122.736 Z-2.837
N7849 X-123.201 Z-2.444
N7850 X-123.666 Z-2.094
N7851 X-124.131 Z-1.776
N7852 X-125.061 Z-1.24
N7853 X-125.526 Z-1.015
N7854 X-126.456 Z-.638
N7855 X-127.386 Z-.354
N7856 X-128.315 Z-.156
N7857 X-129.245 Z-.039
N7858 X-130.175 Z0.
N7859 Y41.375
N7860 X-129.245 Z-.039
N7861 X-128.315 Z-.156
N7862 X-127.386 Z-.354
N7863 X-126.456 Z-.638
N7864 X-125.526 Z-1.015
N7865 X-125.061 Z-1.24
N7866 X-124.131 Z-1.776
N7867 X-123.666 Z-2.094
N7868 X-123.201 Z-2.444
N7869 X-122.736 Z-2.837
N7870 X-122.272 Z-3.278
N7871 X-121.807 Z-3.769
N7872 X-121.342 Z-4.335
N7873 X-120.877 Z-4.981
N7874 X-120.412 Z-5.739
N7875 X-119.947 Z-6.674
N7876 X-119.598 Z-7.568
N7877 X-119.366 Z-8.342
N7878 X-119.133 Z-9.454
N7879 X-119.017 Z-10.557
N7880 X-119.003 Z-18.946
N7881 X-49.281
N7882 X-48.816 Z-18.969
N7883 X-48.351 Z-19.061
N7884 X-47.886 Z-19.229
N7885 X-47.421 Z-19.464
N7886 X-46.956 Z-19.745
N7887 X-46.491 Z-20.062
N7888 X-45.561 Z-20.798
N7889 X-44.631 Z-21.626
N7890 X-43.702 Z-22.518
N7891 X-42.772 Z-23.457
N7892 X-40.912 Z-25.441
N7893 X-39.053 Z-27.541
N7894 X-37.193 Z-29.764
N7895 X-36.263 Z-30.94
N7896 X-35.333 Z-32.172
N7897 X-34.403 Z-33.455
N7898 X-33.474 Z-34.669
N7899 X-32.518 Z-35.823
N7900 X-31.562 Z-36.905
N7901 X-30.606 Z-37.915
N7902 X-29.65 Z-38.861
N7903 X-28.746 Z-39.704
N7904 X-27.843 Z-40.502
N7905 X-26.939 Z-41.256
N7906 X-26.035 Z-41.969
N7907 X-25.092 Z-42.672
N7908 X-24.148 Z-43.334
N7909 X-23.205 Z-43.96
N7910 X-22.262 Z-44.551
N7911 X-21.345 Z-45.094
N7912 X-20.429 Z-45.606
N7913 X-18.596 Z-46.545
N7914 X-16.721 Z-47.395
N7915 X-14.845 Z-48.14
N7916 X-13.001 Z-48.775
N7917 X-11.158 Z-49.318
N7918 X-9.273 Z-49.782
N7919 X-7.422 Z-50.151
N7920 X-5.554 Z-50.437
N7921 X-3.719 Z-50.637
N7922 X-1.862 Z-50.759
N7923 X0. Z-50.8
N7924 X1.862 Z-50.759
N7925 X3.719 Z-50.637
N7926 X5.554 Z-50.437
N7927 X7.422 Z-50.151
N7928 X9.273 Z-49.782
N7929 X11.158 Z-49.318
N7930 X13.001 Z-48.775
N7931 X14.845 Z-48.14
N7932 X15.783 Z-47.781
N7933 X17.658 Z-46.984
N7934 X19.513 Z-46.09
N7935 X21.345 Z-45.094
N7936 X22.262 Z-44.551
N7937 X23.205 Z-43.96
N7938 X24.148 Z-43.334
N7939 X25.092 Z-42.672
N7940 X26.035 Z-41.969
N7941 X26.939 Z-41.256
N7942 X27.843 Z-40.502
N7943 X28.746 Z-39.704
N7944 X29.65 Z-38.861
N7945 X30.606 Z-37.915
N7946 X31.562 Z-36.905
N7947 X32.518 Z-35.823
N7948 X33.474 Z-34.669
N7949 X34.403 Z-33.455
N7950 X35.333 Z-32.172
N7951 X36.263 Z-30.94
N7952 X37.193 Z-29.764
N7953 X39.053 Z-27.541
N7954 X40.912 Z-25.441
N7955 X42.772 Z-23.457
N7956 X43.702 Z-22.518
N7957 X44.631 Z-21.626
N7958 X45.561 Z-20.798
N7959 X46.491 Z-20.062
N7960 X46.956 Z-19.745
N7961 X47.421 Z-19.464
N7962 X47.886 Z-19.229
N7963 X48.351 Z-19.061
N7964 X48.816 Z-18.969
N7965 X49.281 Z-18.946
N7966 X119.003
N7967 X119.01 Z-10.724
N7968 X119.104 Z-9.653
N7969 X119.308 Z-8.571
N7970 X119.598 Z-7.568
N7971 X119.947 Z-6.674
N7972 X120.179 Z-6.185
N7973 X120.644 Z-5.343
N7974 X121.109 Z-4.641
N7975 X121.807 Z-3.769
N7976 X122.272 Z-3.278
N7977 X122.736 Z-2.837
N7978 X123.201 Z-2.444
N7979 X123.666 Z-2.094
N7980 X124.131 Z-1.776
N7981 X125.061 Z-1.24
N7982 X125.526 Z-1.015
N7983 X126.456 Z-.638
N7984 X127.386 Z-.354
N7985 X128.315 Z-.156
N7986 X129.245 Z-.039
N7987 X130.175 Z0.
N7988 Y40.175
N7989 X129.245 Z-.039
N7990 X128.315 Z-.156
N7991 X127.386 Z-.354
N7992 X126.456 Z-.638
N7993 X125.526 Z-1.015
N7994 X125.061 Z-1.24
N7995 X124.131 Z-1.776
N7996 X123.666 Z-2.094
N7997 X123.201 Z-2.444
N7998 X122.736 Z-2.837
N7999 X122.272 Z-3.278
N8000 X121.807 Z-3.769
N8001 X121.109 Z-4.641
N8002 X120.644 Z-5.343
N8003 X120.179 Z-6.185
N8004 X119.947 Z-6.674
N8005 X119.598 Z-7.568
N8006 X119.308 Z-8.571
N8007 X119.104 Z-9.653
N8008 X119.01 Z-10.724
N8009 X119.003 Z-22.753
N8010 X48.351
N8011 X47.421 Z-22.767
N8012 X46.956 Z-22.829
N8013 X46.491 Z-22.946
N8014 X46.026 Z-23.111
N8015 X45.096 Z-23.553
N8016 X44.631 Z-23.82
N8017 X43.702 Z-24.425
N8018 X42.772 Z-25.111
N8019 X41.842 Z-25.861
N8020 X40.912 Z-26.663
N8021 X39.982 Z-27.51
N8022 X39.053 Z-28.398
N8023 X38.123 Z-29.326
N8024 X37.193 Z-30.294
N8025 X36.263 Z-31.306
N8026 X35.333 Z-32.368
N8027 X34.403 Z-33.489
N8028 X33.474 Z-34.669
N8029 X32.518 Z-35.823
N8030 X31.562 Z-36.905
N8031 X30.606 Z-37.915
N8032 X29.65 Z-38.861
N8033 X28.746 Z-39.704
N8034 X27.843 Z-40.502
N8035 X26.939 Z-41.256
N8036 X26.035 Z-41.969
N8037 X25.092 Z-42.672
N8038 X24.148 Z-43.334
N8039 X23.205 Z-43.96
N8040 X22.262 Z-44.551
N8041 X21.345 Z-45.094
N8042 X19.513 Z-46.09
N8043 X17.658 Z-46.984
N8044 X15.783 Z-47.781
N8045 X14.845 Z-48.14
N8046 X13.001 Z-48.775
N8047 X11.158 Z-49.318
N8048 X9.273 Z-49.782
N8049 X7.422 Z-50.151
N8050 X5.554 Z-50.437
N8051 X3.719 Z-50.637
N8052 X1.862 Z-50.759
N8053 X0. Z-50.8
N8054 X-1.862 Z-50.759
N8055 X-3.719 Z-50.637
N8056 X-5.554 Z-50.437
N8057 X-7.422 Z-50.151
N8058 X-9.273 Z-49.782
N8059 X-11.158 Z-49.318
N8060 X-13.001 Z-48.775
N8061 X-14.845 Z-48.14
N8062 X-16.721 Z-47.395
N8063 X-18.596 Z-46.545
N8064 X-20.429 Z-45.606
N8065 X-21.345 Z-45.094
N8066 X-22.262 Z-44.551
N8067 X-23.205 Z-43.96
N8068 X-24.148 Z-43.334
N8069 X-25.092 Z-42.672
N8070 X-26.035 Z-41.969
N8071 X-26.939 Z-41.256
N8072 X-27.843 Z-40.502
N8073 X-28.746 Z-39.704
N8074 X-29.65 Z-38.861
N8075 X-30.606 Z-37.915
N8076 X-31.562 Z-36.905
N8077 X-32.518 Z-35.823
N8078 X-33.474 Z-34.669
N8079 X-34.403 Z-33.489
N8080 X-35.333 Z-32.368
N8081 X-36.263 Z-31.306
N8082 X-37.193 Z-30.294
N8083 X-38.123 Z-29.326
N8084 X-39.053 Z-28.398
N8085 X-39.982 Z-27.51
N8086 X-40.912 Z-26.663
N8087 X-41.842 Z-25.861
N8088 X-42.772 Z-25.111
N8089 X-43.702 Z-24.425
N8090 X-44.631 Z-23.82
N8091 X-45.096 Z-23.553
N8092 X-46.026 Z-23.111
N8093 X-46.491 Z-22.946
N8094 X-46.956 Z-22.829
N8095 X-47.421 Z-22.767
N8096 X-119.003 Z-22.753
N8097 X-119.017 Z-10.557
N8098 X-119.133 Z-9.454
N8099 X-119.366 Z-8.342
N8100 X-119.598 Z-7.568
N8101 X-119.947 Z-6.674
N8102 X-120.412 Z-5.739
N8103 X-120.877 Z-4.981
N8104 X-121.342 Z-4.335
N8105 X-121.807 Z-3.769
N8106 X-122.272 Z-3.278
N8107 X-122.736 Z-2.837
N8108 X-123.201 Z-2.444
N8109 X-123.666 Z-2.094
N8110 X-124.131 Z-1.776
N8111 X-125.061 Z-1.24
N8112 X-125.526 Z-1.015
N8113 X-126.456 Z-.638
N8114 X-127.386 Z-.354
N8115 X-128.315 Z-.156
N8116 X-129.245 Z-.039
N8117 X-130.175 Z0.
N8118 Y38.975
N8119 X-129.245 Z-.039
N8120 X-128.315 Z-.156
N8121 X-127.386 Z-.354
N8122 X-126.456 Z-.638
N8123 X-125.526 Z-1.015
N8124 X-125.061 Z-1.24
N8125 X-124.131 Z-1.776
N8126 X-123.666 Z-2.094
N8127 X-123.201 Z-2.444
N8128 X-122.736 Z-2.837
N8129 X-122.272 Z-3.278
N8130 X-121.807 Z-3.769
N8131 X-121.342 Z-4.335
N8132 X-120.877 Z-4.981
N8133 X-120.412 Z-5.739
N8134 X-119.947 Z-6.674
N8135 X-119.598 Z-7.568
N8136 X-119.366 Z-8.342
N8137 X-119.133 Z-9.454
N8138 X-119.017 Z-10.557
N8139 X-119.003 Z-25.684
N8140 X-46.026 Z-25.689
N8141 X-45.561 Z-25.736
N8142 X-45.096 Z-25.828
N8143 X-44.631 Z-25.961
N8144 X-43.702 Z-26.318
N8145 X-43.237 Z-26.537
N8146 X-41.842 Z-27.326
N8147 X-40.912 Z-27.939
N8148 X-39.982 Z-28.613
N8149 X-39.053 Z-29.341
N8150 X-38.123 Z-30.117
N8151 X-37.193 Z-30.934
N8152 X-36.263 Z-31.797
N8153 X-35.333 Z-32.71
N8154 X-34.403 Z-33.676
N8155 X-33.474 Z-34.702
N8156 X-32.5 Z-35.843
N8157 X-31.527 Z-36.944
N8158 X-30.553 Z-37.968
N8159 X-29.58 Z-38.928
N8160 X-28.693 Z-39.752
N8161 X-27.807 Z-40.532
N8162 X-26.921 Z-41.27
N8163 X-26.035 Z-41.969
N8164 X-25.092 Z-42.672
N8165 X-24.148 Z-43.334
N8166 X-23.205 Z-43.96
N8167 X-22.262 Z-44.551
N8168 X-21.345 Z-45.094
N8169 X-20.429 Z-45.606
N8170 X-18.596 Z-46.545
N8171 X-16.721 Z-47.395
N8172 X-14.845 Z-48.14
N8173 X-13.001 Z-48.775
N8174 X-11.158 Z-49.318
N8175 X-9.273 Z-49.782
N8176 X-7.422 Z-50.151
N8177 X-5.554 Z-50.437
N8178 X-3.719 Z-50.637
N8179 X-1.862 Z-50.759
N8180 X0. Z-50.8
N8181 X1.862 Z-50.759
N8182 X3.719 Z-50.637
N8183 X5.554 Z-50.437
N8184 X7.422 Z-50.151
N8185 X9.273 Z-49.782
N8186 X11.158 Z-49.318
N8187 X13.001 Z-48.775
N8188 X14.845 Z-48.14
N8189 X15.783 Z-47.781
N8190 X17.658 Z-46.984
N8191 X19.513 Z-46.09
N8192 X21.345 Z-45.094
N8193 X22.262 Z-44.551
N8194 X23.205 Z-43.96
N8195 X24.148 Z-43.334
N8196 X25.092 Z-42.672
N8197 X26.035 Z-41.969
N8198 X26.921 Z-41.27
N8199 X27.807 Z-40.532
N8200 X28.693 Z-39.752
N8201 X29.58 Z-38.928
N8202 X30.553 Z-37.968
N8203 X31.527 Z-36.944
N8204 X32.5 Z-35.843
N8205 X33.474 Z-34.702
N8206 X34.403 Z-33.676
N8207 X35.333 Z-32.71
N8208 X36.263 Z-31.797
N8209 X37.193 Z-30.934
N8210 X38.123 Z-30.117
N8211 X39.053 Z-29.341
N8212 X39.982 Z-28.613
N8213 X40.912 Z-27.939
N8214 X41.842 Z-27.326
N8215 X42.307 Z-27.043
N8216 X43.237 Z-26.537
N8217 X43.702 Z-26.318
N8218 X44.631 Z-25.961
N8219 X45.096 Z-25.828
N8220 X45.561 Z-25.736
N8221 X46.026 Z-25.689
N8222 X119.003 Z-25.684
N8223 X119.01 Z-10.724
N8224 X119.104 Z-9.653
N8225 X119.308 Z-8.571
N8226 X119.598 Z-7.568
N8227 X119.947 Z-6.674
N8228 X120.179 Z-6.185
N8229 X120.644 Z-5.343
N8230 X121.109 Z-4.641
N8231 X121.807 Z-3.769
N8232 X122.272 Z-3.278
N8233 X122.736 Z-2.837
N8234 X123.201 Z-2.444
N8235 X123.666 Z-2.094
N8236 X124.131 Z-1.776
N8237 X125.061 Z-1.24
N8238 X125.526 Z-1.015
N8239 X126.456 Z-.638
N8240 X127.386 Z-.354
N8241 X128.315 Z-.156
N8242 X129.245 Z-.039
N8243 X130.175 Z0.
N8244 Y37.775
N8245 X129.245 Z-.039
N8246 X128.315 Z-.156
N8247 X127.386 Z-.354
N8248 X126.456 Z-.638
N8249 X125.526 Z-1.015
N8250 X125.061 Z-1.24
N8251 X124.131 Z-1.776
N8252 X123.666 Z-2.094
N8253 X123.201 Z-2.444
N8254 X122.736 Z-2.837
N8255 X122.272 Z-3.278
N8256 X121.807 Z-3.769
N8257 X121.109 Z-4.641
N8258 X120.644 Z-5.343
N8259 X120.179 Z-6.185
N8260 X119.947 Z-6.674
N8261 X119.598 Z-7.568
N8262 X119.308 Z-8.571
N8263 X119.104 Z-9.653
N8264 X119.01 Z-10.724
N8265 X119.003 Z-28.114
N8266 X44.631 Z-28.119
N8267 X44.167 Z-28.162
N8268 X43.702 Z-28.239
N8269 X43.237 Z-28.346
N8270 X42.772 Z-28.484
N8271 X41.842 Z-28.84
N8272 X40.912 Z-29.28
N8273 X39.982 Z-29.788
N8274 X39.053 Z-30.364
N8275 X38.123 Z-30.997
N8276 X37.193 Z-31.674
N8277 X36.263 Z-32.402
N8278 X35.333 Z-33.182
N8279 X34.403 Z-34.012
N8280 X32.903 Z-35.463
N8281 X31.193 Z-37.301
N8282 X30.053 Z-38.472
N8283 X28.912 Z-39.553
N8284 X27.474 Z-40.815
N8285 X26.035 Z-41.969
N8286 X25.092 Z-42.672
N8287 X24.148 Z-43.334
N8288 X23.205 Z-43.96
N8289 X22.262 Z-44.551
N8290 X21.345 Z-45.094
N8291 X19.513 Z-46.09
N8292 X17.658 Z-46.984
N8293 X15.783 Z-47.781
N8294 X14.845 Z-48.14
N8295 X13.001 Z-48.775
N8296 X11.158 Z-49.318
N8297 X9.273 Z-49.782
N8298 X7.422 Z-50.151
N8299 X5.554 Z-50.437
N8300 X3.719 Z-50.637
N8301 X1.862 Z-50.759
N8302 X0. Z-50.8
N8303 X-1.862 Z-50.759
N8304 X-3.719 Z-50.637
N8305 X-5.554 Z-50.437
N8306 X-7.422 Z-50.151
N8307 X-9.273 Z-49.782
N8308 X-11.158 Z-49.318
N8309 X-13.001 Z-48.775
N8310 X-14.845 Z-48.14
N8311 X-16.721 Z-47.395
N8312 X-18.596 Z-46.545
N8313 X-20.429 Z-45.606
N8314 X-21.345 Z-45.094
N8315 X-22.262 Z-44.551
N8316 X-23.205 Z-43.96
N8317 X-24.148 Z-43.334
N8318 X-25.092 Z-42.672
N8319 X-26.754 Z-41.405
N8320 X-28.193 Z-40.198
N8321 X-28.912 Z-39.553
N8322 X-30.053 Z-38.472
N8323 X-31.193 Z-37.301
N8324 X-32.903 Z-35.463
N8325 X-34.403 Z-34.012
N8326 X-35.333 Z-33.182
N8327 X-36.263 Z-32.402
N8328 X-37.193 Z-31.674
N8329 X-38.123 Z-30.997
N8330 X-39.053 Z-30.364
N8331 X-39.982 Z-29.788
N8332 X-40.912 Z-29.28
N8333 X-41.842 Z-28.84
N8334 X-42.772 Z-28.484
N8335 X-43.237 Z-28.346
N8336 X-43.702 Z-28.239
N8337 X-44.167 Z-28.162
N8338 X-44.631 Z-28.119
N8339 X-119.003 Z-28.114
N8340 X-119.017 Z-10.557
N8341 X-119.133 Z-9.454
N8342 X-119.366 Z-8.342
N8343 X-119.598 Z-7.568
N8344 X-119.947 Z-6.674
N8345 X-120.412 Z-5.739
N8346 X-120.877 Z-4.981
N8347 X-121.342 Z-4.335
N8348 X-121.807 Z-3.769
N8349 X-122.272 Z-3.278
N8350 X-122.736 Z-2.837
N8351 X-123.201 Z-2.444
N8352 X-123.666 Z-2.094
N8353 X-124.131 Z-1.776
N8354 X-125.061 Z-1.24
N8355 X-125.526 Z-1.015
N8356 X-126.456 Z-.638
N8357 X-127.386 Z-.354
N8358 X-128.315 Z-.156
N8359 X-129.245 Z-.039
N8360 X-130.175 Z0.
N8361 Y36.575
N8362 X-129.245 Z-.039
N8363 X-128.315 Z-.156
N8364 X-127.386 Z-.354
N8365 X-126.456 Z-.638
N8366 X-125.526 Z-1.015
N8367 X-125.061 Z-1.24
N8368 X-124.131 Z-1.776
N8369 X-123.666 Z-2.094
N8370 X-123.201 Z-2.444
N8371 X-122.736 Z-2.837
N8372 X-122.272 Z-3.278
N8373 X-121.807 Z-3.769
N8374 X-121.342 Z-4.335
N8375 X-120.877 Z-4.981
N8376 X-120.412 Z-5.739
N8377 X-119.947 Z-6.674
N8378 X-119.598 Z-7.568
N8379 X-119.366 Z-8.342
N8380 X-119.133 Z-9.454
N8381 X-119.017 Z-10.557
N8382 X-119.003 Z-30.226
N8383 X-43.702
N8384 X-42.772 Z-30.259
N8385 X-42.307 Z-30.322
N8386 X-41.842 Z-30.417
N8387 X-40.912 Z-30.685
N8388 X-39.982 Z-31.037
N8389 X-39.053 Z-31.463
N8390 X-38.123 Z-31.958
N8391 X-37.193 Z-32.503
N8392 X-36.263 Z-33.105
N8393 X-35.333 Z-33.761
N8394 X-34.403 Z-34.465
N8395 X-33.474 Z-35.218
N8396 X-32.544 Z-36.027
N8397 X-31.614 Z-36.898
N8398 X-29.754 Z-38.761
N8399 X-28.824 Z-39.633
N8400 X-27.895 Z-40.457
N8401 X-26.965 Z-41.234
N8402 X-26.035 Z-41.969
N8403 X-25.092 Z-42.672
N8404 X-24.148 Z-43.334
N8405 X-23.205 Z-43.96
N8406 X-22.262 Z-44.551
N8407 X-21.345 Z-45.094
N8408 X-20.429 Z-45.606
N8409 X-18.596 Z-46.545
N8410 X-16.721 Z-47.395
N8411 X-14.845 Z-48.14
N8412 X-13.001 Z-48.775
N8413 X-11.158 Z-49.318
N8414 X-9.273 Z-49.782
N8415 X-7.422 Z-50.151
N8416 X-5.554 Z-50.437
N8417 X-3.719 Z-50.637
N8418 X-1.862 Z-50.759
N8419 X0. Z-50.8
N8420 X1.862 Z-50.759
N8421 X3.719 Z-50.637
N8422 X5.554 Z-50.437
N8423 X7.422 Z-50.151
N8424 X9.273 Z-49.782
N8425 X11.158 Z-49.318
N8426 X13.001 Z-48.775
N8427 X14.845 Z-48.14
N8428 X15.783 Z-47.781
N8429 X17.658 Z-46.984
N8430 X19.513 Z-46.09
N8431 X21.345 Z-45.094
N8432 X22.262 Z-44.551
N8433 X23.205 Z-43.96
N8434 X24.148 Z-43.334
N8435 X25.092 Z-42.672
N8436 X26.035 Z-41.969
N8437 X26.965 Z-41.234
N8438 X27.895 Z-40.457
N8439 X28.824 Z-39.633
N8440 X29.754 Z-38.761
N8441 X31.614 Z-36.898
N8442 X32.544 Z-36.027
N8443 X33.474 Z-35.218
N8444 X34.403 Z-34.465
N8445 X35.333 Z-33.761
N8446 X36.263 Z-33.105
N8447 X37.193 Z-32.503
N8448 X38.123 Z-31.958
N8449 X39.053 Z-31.463
N8450 X39.982 Z-31.037
N8451 X40.912 Z-30.685
N8452 X41.842 Z-30.417
N8453 X42.307 Z-30.322
N8454 X42.772 Z-30.259
N8455 X43.702 Z-30.226
N8456 X119.003
N8457 X119.01 Z-10.724
N8458 X119.104 Z-9.653
N8459 X119.308 Z-8.571
N8460 X119.598 Z-7.568
N8461 X119.947 Z-6.674
N8462 X120.179 Z-6.185
N8463 X120.644 Z-5.343
N8464 X121.109 Z-4.641
N8465 X121.807 Z-3.769
N8466 X122.272 Z-3.278
N8467 X122.736 Z-2.837
N8468 X123.201 Z-2.444
N8469 X123.666 Z-2.094
N8470 X124.131 Z-1.776
N8471 X125.061 Z-1.24
N8472 X125.526 Z-1.015
N8473 X126.456 Z-.638
N8474 X127.386 Z-.354
N8475 X128.315 Z-.156
N8476 X129.245 Z-.039
N8477 X130.175 Z0.
N8478 Y35.375
N8479 X129.245 Z-.039
N8480 X128.315 Z-.156
N8481 X127.386 Z-.354
N8482 X126.456 Z-.638
N8483 X125.526 Z-1.015
N8484 X125.061 Z-1.24
N8485 X124.131 Z-1.776
N8486 X123.666 Z-2.094
N8487 X123.201 Z-2.444
N8488 X122.736 Z-2.837
N8489 X122.272 Z-3.278
N8490 X121.807 Z-3.769
N8491 X121.109 Z-4.641
N8492 X120.644 Z-5.343
N8493 X120.179 Z-6.185
N8494 X119.947 Z-6.674
N8495 X119.598 Z-7.568
N8496 X119.308 Z-8.571
N8497 X119.104 Z-9.653
N8498 X119.01 Z-10.724
N8499 X119.003 Z-32.09
N8500 X41.842 Z-32.091
N8501 X41.377 Z-32.115
N8502 X40.912 Z-32.171
N8503 X40.447 Z-32.256
N8504 X39.982 Z-32.367
N8505 X39.053 Z-32.641
N8506 X38.123 Z-32.999
N8507 X37.193 Z-33.416
N8508 X36.263 Z-33.896
N8509 X35.333 Z-34.434
N8510 X34.403 Z-35.016
N8511 X33.474 Z-35.654
N8512 X32.544 Z-36.347
N8513 X31.614 Z-37.089
N8514 X30.684 Z-37.891
N8515 X28.817 Z-39.64
N8516 X27.88 Z-40.469
N8517 X26.957 Z-41.24
N8518 X26.035 Z-41.969
N8519 X25.092 Z-42.672
N8520 X24.148 Z-43.334
N8521 X23.205 Z-43.96
N8522 X22.262 Z-44.551
N8523 X21.345 Z-45.094
N8524 X19.513 Z-46.09
N8525 X17.658 Z-46.984
N8526 X15.783 Z-47.781
N8527 X14.845 Z-48.14
N8528 X13.001 Z-48.775
N8529 X11.158 Z-49.318
N8530 X9.273 Z-49.782
N8531 X7.422 Z-50.151
N8532 X5.554 Z-50.437
N8533 X3.719 Z-50.637
N8534 X1.862 Z-50.759
N8535 X0. Z-50.8
N8536 X-1.862 Z-50.759
N8537 X-3.719 Z-50.637
N8538 X-5.554 Z-50.437
N8539 X-7.422 Z-50.151
N8540 X-9.273 Z-49.782
N8541 X-11.158 Z-49.318
N8542 X-13.001 Z-48.775
N8543 X-14.845 Z-48.14
N8544 X-16.721 Z-47.395
N8545 X-18.596 Z-46.545
N8546 X-20.429 Z-45.606
N8547 X-21.345 Z-45.094
N8548 X-22.262 Z-44.551
N8549 X-23.205 Z-43.96
N8550 X-24.148 Z-43.334
N8551 X-25.092 Z-42.672
N8552 X-26.035 Z-41.969
N8553 X-26.957 Z-41.24
N8554 X-27.88 Z-40.469
N8555 X-28.817 Z-39.64
N8556 X-30.684 Z-37.891
N8557 X-31.614 Z-37.089
N8558 X-32.544 Z-36.347
N8559 X-33.474 Z-35.654
N8560 X-34.403 Z-35.016
N8561 X-35.333 Z-34.434
N8562 X-36.263 Z-33.896
N8563 X-37.193 Z-33.416
N8564 X-38.123 Z-32.999
N8565 X-39.053 Z-32.641
N8566 X-39.982 Z-32.367
N8567 X-40.447 Z-32.256
N8568 X-40.912 Z-32.171
N8569 X-41.377 Z-32.115
N8570 X-41.842 Z-32.091
N8571 X-119.003 Z-32.09
N8572 X-119.017 Z-10.557
N8573 X-119.133 Z-9.454
N8574 X-119.366 Z-8.342
N8575 X-119.598 Z-7.568
N8576 X-119.947 Z-6.674
N8577 X-120.412 Z-5.739
N8578 X-120.877 Z-4.981
N8579 X-121.342 Z-4.335
N8580 X-121.807 Z-3.769
N8581 X-122.272 Z-3.278
N8582 X-122.736 Z-2.837
N8583 X-123.201 Z-2.444
N8584 X-123.666 Z-2.094
N8585 X-124.131 Z-1.776
N8586 X-125.061 Z-1.24
N8587 X-125.526 Z-1.015
N8588 X-126.456 Z-.638
N8589 X-127.386 Z-.354
N8590 X-128.315 Z-.156
N8591 X-129.245 Z-.039
N8592 X-130.175 Z0.
N8593 Y34.175
N8594 X-129.245 Z-.039
N8595 X-128.315 Z-.156
N8596 X-127.386 Z-.354
N8597 X-126.456 Z-.638
N8598 X-125.526 Z-1.015
N8599 X-125.061 Z-1.24
N8600 X-124.131 Z-1.776
N8601 X-123.666 Z-2.094
N8602 X-123.201 Z-2.444
N8603 X-122.736 Z-2.837
N8604 X-122.272 Z-3.278
N8605 X-121.807 Z-3.769
N8606 X-121.342 Z-4.335
N8607 X-120.877 Z-4.981
N8608 X-120.412 Z-5.739
N8609 X-119.947 Z-6.674
N8610 X-119.598 Z-7.568
N8611 X-119.366 Z-8.342
N8612 X-119.133 Z-9.454
N8613 X-119.017 Z-10.557
N8614 X-119.003 Z-33.765
N8615 X-40.912
N8616 X-39.982 Z-33.785
N8617 X-39.517 Z-33.833
N8618 X-39.053 Z-33.908
N8619 X-38.123 Z-34.124
N8620 X-37.193 Z-34.413
N8621 X-36.263 Z-34.771
N8622 X-35.333 Z-35.19
N8623 X-34.403 Z-35.662
N8624 X-33.474 Z-36.191
N8625 X-32.544 Z-36.768
N8626 X-31.614 Z-37.398
N8627 X-30.684 Z-38.085
N8628 X-29.754 Z-38.827
N8629 X-28.433 Z-39.989
N8630 X-27.112 Z-41.113
N8631 X-26.035 Z-41.969
N8632 X-25.092 Z-42.672
N8633 X-24.148 Z-43.334
N8634 X-23.205 Z-43.96
N8635 X-22.262 Z-44.551
N8636 X-21.345 Z-45.094
N8637 X-20.429 Z-45.606
N8638 X-18.596 Z-46.545
N8639 X-16.721 Z-47.395
N8640 X-14.845 Z-48.14
N8641 X-13.001 Z-48.775
N8642 X-11.158 Z-49.318
N8643 X-9.273 Z-49.782
N8644 X-7.422 Z-50.151
N8645 X-5.554 Z-50.437
N8646 X-3.719 Z-50.637
N8647 X-1.862 Z-50.759
N8648 X0. Z-50.8
N8649 X1.862 Z-50.759
N8650 X3.719 Z-50.637
N8651 X5.554 Z-50.437
N8652 X7.422 Z-50.151
N8653 X9.273 Z-49.782
N8654 X11.158 Z-49.318
N8655 X13.001 Z-48.775
N8656 X14.845 Z-48.14
N8657 X15.783 Z-47.781
N8658 X17.658 Z-46.984
N8659 X19.513 Z-46.09
N8660 X21.345 Z-45.094
N8661 X22.262 Z-44.551
N8662 X23.205 Z-43.96
N8663 X24.148 Z-43.334
N8664 X25.092 Z-42.672
N8665 X26.035 Z-41.969
N8666 X27.112 Z-41.113
N8667 X28.433 Z-39.989
N8668 X29.754 Z-38.827
N8669 X30.684 Z-38.085
N8670 X31.614 Z-37.398
N8671 X32.544 Z-36.768
N8672 X33.474 Z-36.191
N8673 X34.403 Z-35.662
N8674 X35.333 Z-35.19
N8675 X36.263 Z-34.771
N8676 X37.193 Z-34.413
N8677 X38.123 Z-34.124
N8678 X39.053 Z-33.908
N8679 X39.517 Z-33.833
N8680 X39.982 Z-33.785
N8681 X40.912 Z-33.765
N8682 X119.003
N8683 X119.01 Z-10.724
N8684 X119.104 Z-9.653
N8685 X119.308 Z-8.571
N8686 X119.598 Z-7.568
N8687 X119.947 Z-6.674
N8688 X120.179 Z-6.185
N8689 X120.644 Z-5.343
N8690 X121.109 Z-4.641
N8691 X121.807 Z-3.769
N8692 X122.272 Z-3.278
N8693 X122.736 Z-2.837
N8694 X123.201 Z-2.444
N8695 X123.666 Z-2.094
N8696 X124.131 Z-1.776
N8697 X125.061 Z-1.24
N8698 X125.526 Z-1.015
N8699 X126.456 Z-.638
N8700 X127.386 Z-.354
N8701 X128.315 Z-.156
N8702 X129.245 Z-.039
N8703 X130.175 Z0.
N8704 Y32.975
N8705 X129.245 Z-.039
N8706 X128.315 Z-.156
N8707 X127.386 Z-.354
N8708 X126.456 Z-.638
N8709 X125.526 Z-1.015
N8710 X125.061 Z-1.24
N8711 X124.131 Z-1.776
N8712 X123.666 Z-2.094
N8713 X123.201 Z-2.444
N8714 X122.736 Z-2.837
N8715 X122.272 Z-3.278
N8716 X121.807 Z-3.769
N8717 X121.109 Z-4.641
N8718 X120.644 Z-5.343
N8719 X120.179 Z-6.185
N8720 X119.947 Z-6.674
N8721 X119.598 Z-7.568
N8722 X119.308 Z-8.571
N8723 X119.104 Z-9.653
N8724 X119.01 Z-10.724
N8725 X119.003 Z-35.281
N8726 X39.053 Z-35.283
N8727 X38.123 Z-35.344
N8728 X37.193 Z-35.499
N8729 X36.263 Z-35.732
N8730 X35.333 Z-36.033
N8731 X34.403 Z-36.395
N8732 X33.474 Z-36.816
N8733 X32.544 Z-37.286
N8734 X31.614 Z-37.814
N8735 X30.684 Z-38.389
N8736 X29.754 Z-39.019
N8737 X28.824 Z-39.71
N8738 X26.965 Z-41.234
N8739 X26.035 Z-41.969
N8740 X25.092 Z-42.672
N8741 X24.148 Z-43.334
N8742 X23.205 Z-43.96
N8743 X22.262 Z-44.551
N8744 X21.345 Z-45.094
N8745 X19.513 Z-46.09
N8746 X17.658 Z-46.984
N8747 X15.783 Z-47.781
N8748 X14.845 Z-48.14
N8749 X13.001 Z-48.775
N8750 X11.158 Z-49.318
N8751 X9.273 Z-49.782
N8752 X7.422 Z-50.151
N8753 X5.554 Z-50.437
N8754 X3.719 Z-50.637
N8755 X1.862 Z-50.759
N8756 X0. Z-50.8
N8757 X-1.862 Z-50.759
N8758 X-3.719 Z-50.637
N8759 X-5.554 Z-50.437
N8760 X-7.422 Z-50.151
N8761 X-9.273 Z-49.782
N8762 X-11.158 Z-49.318
N8763 X-13.001 Z-48.775
N8764 X-14.845 Z-48.14
N8765 X-16.721 Z-47.395
N8766 X-18.596 Z-46.545
N8767 X-20.429 Z-45.606
N8768 X-21.345 Z-45.094
N8769 X-22.262 Z-44.551
N8770 X-23.205 Z-43.96
N8771 X-24.148 Z-43.334
N8772 X-25.092 Z-42.672
N8773 X-26.035 Z-41.969
N8774 X-26.965 Z-41.234
N8775 X-28.824 Z-39.71
N8776 X-29.754 Z-39.019
N8777 X-30.684 Z-38.389
N8778 X-31.614 Z-37.814
N8779 X-32.544 Z-37.286
N8780 X-33.474 Z-36.816
N8781 X-34.403 Z-36.395
N8782 X-35.333 Z-36.033
N8783 X-36.263 Z-35.732
N8784 X-37.193 Z-35.499
N8785 X-38.123 Z-35.344
N8786 X-39.053 Z-35.283
N8787 X-119.003 Z-35.281
N8788 X-119.017 Z-10.557
N8789 X-119.133 Z-9.454
N8790 X-119.366 Z-8.342
N8791 X-119.598 Z-7.568
N8792 X-119.947 Z-6.674
N8793 X-120.412 Z-5.739
N8794 X-120.877 Z-4.981
N8795 X-121.342 Z-4.335
N8796 X-121.807 Z-3.769
N8797 X-122.272 Z-3.278
N8798 X-122.736 Z-2.837
N8799 X-123.201 Z-2.444
N8800 X-123.666 Z-2.094
N8801 X-124.131 Z-1.776
N8802 X-125.061 Z-1.24
N8803 X-125.526 Z-1.015
N8804 X-126.456 Z-.638
N8805 X-127.386 Z-.354
N8806 X-128.315 Z-.156
N8807 X-129.245 Z-.039
N8808 X-130.175 Z0.
N8809 Y31.775
N8810 X-129.245 Z-.039
N8811 X-128.315 Z-.156
N8812 X-127.386 Z-.354
N8813 X-126.456 Z-.638
N8814 X-125.526 Z-1.015
N8815 X-125.061 Z-1.24
N8816 X-124.131 Z-1.776
N8817 X-123.666 Z-2.094
N8818 X-123.201 Z-2.444
N8819 X-122.736 Z-2.837
N8820 X-122.272 Z-3.278
N8821 X-121.807 Z-3.769
N8822 X-121.342 Z-4.335
N8823 X-120.877 Z-4.981
N8824 X-120.412 Z-5.739
N8825 X-119.947 Z-6.674
N8826 X-119.598 Z-7.568
N8827 X-119.366 Z-8.342
N8828 X-119.133 Z-9.454
N8829 X-119.017 Z-10.557
N8830 X-119.003 Z-36.668
N8831 X-37.193 Z-36.686
N8832 X-36.263 Z-36.786
N8833 X-35.333 Z-36.965
N8834 X-34.403 Z-37.216
N8835 X-33.474 Z-37.526
N8836 X-32.544 Z-37.895
N8837 X-31.614 Z-38.319
N8838 X-30.684 Z-38.792
N8839 X-29.754 Z-39.324
N8840 X-28.824 Z-39.9
N8841 X-27.895 Z-40.538
N8842 X-26.035 Z-41.969
N8843 X-25.092 Z-42.672
N8844 X-24.148 Z-43.334
N8845 X-23.205 Z-43.96
N8846 X-22.262 Z-44.551
N8847 X-21.345 Z-45.094
N8848 X-20.429 Z-45.606
N8849 X-18.596 Z-46.545
N8850 X-16.721 Z-47.395
N8851 X-14.845 Z-48.14
N8852 X-13.001 Z-48.775
N8853 X-11.158 Z-49.318
N8854 X-9.273 Z-49.782
N8855 X-7.422 Z-50.151
N8856 X-5.554 Z-50.437
N8857 X-3.719 Z-50.637
N8858 X-1.862 Z-50.759
N8859 X0. Z-50.8
N8860 X1.862 Z-50.759
N8861 X3.719 Z-50.637
N8862 X5.554 Z-50.437
N8863 X7.422 Z-50.151
N8864 X9.273 Z-49.782
N8865 X11.158 Z-49.318
N8866 X13.001 Z-48.775
N8867 X14.845 Z-48.14
N8868 X15.783 Z-47.781
N8869 X17.658 Z-46.984
N8870 X19.513 Z-46.09
N8871 X21.345 Z-45.094
N8872 X22.262 Z-44.551
N8873 X23.205 Z-43.96
N8874 X24.148 Z-43.334
N8875 X25.092 Z-42.672
N8876 X27.895 Z-40.538
N8877 X28.824 Z-39.9
N8878 X29.754 Z-39.324
N8879 X30.684 Z-38.792
N8880 X31.614 Z-38.319
N8881 X32.544 Z-37.895
N8882 X33.474 Z-37.526
N8883 X34.403 Z-37.216
N8884 X35.333 Z-36.965
N8885 X36.263 Z-36.786
N8886 X37.193 Z-36.686
N8887 X39.053 Z-36.668
N8888 X119.003
N8889 X119.01 Z-10.724
N8890 X119.104 Z-9.653
N8891 X119.308 Z-8.571
N8892 X119.598 Z-7.568
N8893 X119.947 Z-6.674
N8894 X120.179 Z-6.185
N8895 X120.644 Z-5.343
N8896 X121.109 Z-4.641
N8897 X121.807 Z-3.769
N8898 X122.272 Z-3.278
N8899 X122.736 Z-2.837
N8900 X123.201 Z-2.444
N8901 X123.666 Z-2.094
N8902 X124.131 Z-1.776
N8903 X125.061 Z-1.24
N8904 X125.526 Z-1.015
N8905 X126.456 Z-.638
N8906 X127.386 Z-.354
N8907 X128.315 Z-.156
N8908 X129.245 Z-.039
N8909 X130.175 Z0.
N8910 Y30.575
N8911 X129.245 Z-.039
N8912 X128.315 Z-.156
N8913 X127.386 Z-.354
N8914 X126.456 Z-.638
N8915 X125.526 Z-1.015
N8916 X125.061 Z-1.24
N8917 X124.131 Z-1.776
N8918 X123.666 Z-2.094
N8919 X123.201 Z-2.444
N8920 X122.736 Z-2.837
N8921 X122.272 Z-3.278
N8922 X121.807 Z-3.769
N8923 X121.109 Z-4.641
N8924 X120.644 Z-5.343
N8925 X120.179 Z-6.185
N8926 X119.947 Z-6.674
N8927 X119.598 Z-7.568
N8928 X119.308 Z-8.571
N8929 X119.104 Z-9.653
N8930 X119.01 Z-10.724
N8931 X119.003 Z-37.946
N8932 X36.263
N8933 X35.333 Z-37.993
N8934 X34.403 Z-38.127
N8935 X33.474 Z-38.325
N8936 X32.544 Z-38.593
N8937 X31.614 Z-38.911
N8938 X30.684 Z-39.29
N8939 X29.754 Z-39.718
N8940 X28.824 Z-40.199
N8941 X27.895 Z-40.734
N8942 X26.965 Z-41.322
N8943 X26.035 Z-41.974
N8944 X25.087 Z-42.675
N8945 X24.139 Z-43.341
N8946 X23.19 Z-43.97
N8947 X22.242 Z-44.563
N8948 X21.331 Z-45.102
N8949 X19.508 Z-46.092
N8950 X17.658 Z-46.984
N8951 X15.783 Z-47.781
N8952 X13.923 Z-48.469
N8953 X13.001 Z-48.775
N8954 X11.158 Z-49.318
N8955 X9.273 Z-49.782
N8956 X7.422 Z-50.151
N8957 X5.554 Z-50.437
N8958 X3.719 Z-50.637
N8959 X1.862 Z-50.759
N8960 X0. Z-50.8
N8961 X-1.862 Z-50.759
N8962 X-3.719 Z-50.637
N8963 X-5.554 Z-50.437
N8964 X-7.422 Z-50.151
N8965 X-9.273 Z-49.782
N8966 X-11.158 Z-49.318
N8967 X-13.001 Z-48.775
N8968 X-14.845 Z-48.14
N8969 X-16.721 Z-47.395
N8970 X-18.596 Z-46.545
N8971 X-20.419 Z-45.611
N8972 X-21.331 Z-45.102
N8973 X-22.242 Z-44.563
N8974 X-23.19 Z-43.97
N8975 X-24.139 Z-43.341
N8976 X-25.087 Z-42.675
N8977 X-26.035 Z-41.974
N8978 X-26.965 Z-41.322
N8979 X-27.895 Z-40.734
N8980 X-28.824 Z-40.199
N8981 X-29.754 Z-39.718
N8982 X-30.684 Z-39.29
N8983 X-31.614 Z-38.911
N8984 X-32.544 Z-38.593
N8985 X-33.474 Z-38.325
N8986 X-34.403 Z-38.127
N8987 X-35.333 Z-37.993
N8988 X-36.263 Z-37.946
N8989 X-119.003
N8990 X-119.017 Z-10.557
N8991 X-119.133 Z-9.454
N8992 X-119.366 Z-8.342
N8993 X-119.598 Z-7.568
N8994 X-119.947 Z-6.674
N8995 X-120.412 Z-5.739
N8996 X-120.877 Z-4.981
N8997 X-121.342 Z-4.335
N8998 X-121.807 Z-3.769
N8999 X-122.272 Z-3.278
N9000 X-122.736 Z-2.837
N9001 X-123.201 Z-2.444
N9002 X-123.666 Z-2.094
N9003 X-124.131 Z-1.776
N9004 X-125.061 Z-1.24
N9005 X-125.526 Z-1.015
N9006 X-126.456 Z-.638
N9007 X-127.386 Z-.354
N9008 X-128.315 Z-.156
N9009 X-129.245 Z-.039
N9010 X-130.175 Z0.
N9011 Y29.375
N9012 X-129.245 Z-.039
N9013 X-128.315 Z-.156
N9014 X-127.386 Z-.354
N9015 X-126.456 Z-.638
N9016 X-125.526 Z-1.015
N9017 X-125.061 Z-1.24
N9018 X-124.131 Z-1.776
N9019 X-123.666 Z-2.094
N9020 X-123.201 Z-2.444
N9021 X-122.736 Z-2.837
N9022 X-122.272 Z-3.278
N9023 X-121.807 Z-3.769
N9024 X-121.342 Z-4.335
N9025 X-120.877 Z-4.981
N9026 X-120.412 Z-5.739
N9027 X-119.947 Z-6.674
N9028 X-119.598 Z-7.568
N9029 X-119.366 Z-8.342
N9030 X-119.133 Z-9.454
N9031 X-119.017 Z-10.557
N9032 X-119.003 Z-39.124
N9033 X-34.403 Z-39.138
N9034 X-33.474 Z-39.217
N9035 X-32.544 Z-39.375
N9036 X-31.614 Z-39.593
N9037 X-30.684 Z-39.873
N9038 X-29.754 Z-40.204
N9039 X-28.824 Z-40.593
N9040 X-27.895 Z-41.028
N9041 X-26.965 Z-41.522
N9042 X-26.035 Z-42.064
N9043 X-24.965 Z-42.763
N9044 X-23.896 Z-43.504
N9045 X-22.826 Z-44.201
N9046 X-21.756 Z-44.855
N9047 X-20.176 Z-45.742
N9048 X-18.596 Z-46.545
N9049 X-16.721 Z-47.395
N9050 X-14.845 Z-48.14
N9051 X-13.001 Z-48.775
N9052 X-11.158 Z-49.318
N9053 X-9.273 Z-49.782
N9054 X-7.422 Z-50.151
N9055 X-5.554 Z-50.437
N9056 X-3.719 Z-50.637
N9057 X-1.862 Z-50.759
N9058 X0. Z-50.8
N9059 X1.862 Z-50.759
N9060 X3.719 Z-50.637
N9061 X5.554 Z-50.437
N9062 X7.422 Z-50.151
N9063 X9.273 Z-49.782
N9064 X11.158 Z-49.318
N9065 X13.001 Z-48.775
N9066 X14.845 Z-48.14
N9067 X16.721 Z-47.395
N9068 X18.596 Z-46.545
N9069 X20.176 Z-45.742
N9070 X21.756 Z-44.855
N9071 X22.826 Z-44.201
N9072 X23.896 Z-43.504
N9073 X24.965 Z-42.763
N9074 X26.035 Z-42.064
N9075 X26.965 Z-41.522
N9076 X27.895 Z-41.028
N9077 X28.824 Z-40.593
N9078 X29.754 Z-40.204
N9079 X30.684 Z-39.873
N9080 X31.614 Z-39.593
N9081 X32.544 Z-39.375
N9082 X33.474 Z-39.217
N9083 X34.403 Z-39.138
N9084 X35.333 Z-39.124
N9085 X119.003
N9086 X119.01 Z-10.724
N9087 X119.104 Z-9.653
N9088 X119.308 Z-8.571
N9089 X119.598 Z-7.568
N9090 X119.947 Z-6.674
N9091 X120.179 Z-6.185
N9092 X120.644 Z-5.343
N9093 X121.109 Z-4.641
N9094 X121.807 Z-3.769
N9095 X122.272 Z-3.278
N9096 X122.736 Z-2.837
N9097 X123.201 Z-2.444
N9098 X123.666 Z-2.094
N9099 X124.131 Z-1.776
N9100 X125.061 Z-1.24
N9101 X125.526 Z-1.015
N9102 X126.456 Z-.638
N9103 X127.386 Z-.354
N9104 X128.315 Z-.156
N9105 X129.245 Z-.039
N9106 X130.175 Z0.
N9107 Y28.175
N9108 X129.245 Z-.039
N9109 X128.315 Z-.156
N9110 X127.386 Z-.354
N9111 X126.456 Z-.638
N9112 X125.526 Z-1.015
N9113 X125.061 Z-1.24
N9114 X124.131 Z-1.776
N9115 X123.666 Z-2.094
N9116 X123.201 Z-2.444
N9117 X122.736 Z-2.837
N9118 X122.272 Z-3.278
N9119 X121.807 Z-3.769
N9120 X121.109 Z-4.641
N9121 X120.644 Z-5.343
N9122 X120.179 Z-6.185
N9123 X119.947 Z-6.674
N9124 X119.598 Z-7.568
N9125 X119.308 Z-8.571
N9126 X119.104 Z-9.653
N9127 X119.01 Z-10.724
N9128 X119.003 Z-40.214
N9129 X33.474
N9130 X32.544 Z-40.252
N9131 X31.614 Z-40.365
N9132 X30.684 Z-40.541
N9133 X29.754 Z-40.781
N9134 X28.824 Z-41.07
N9135 X27.895 Z-41.418
N9136 X26.965 Z-41.813
N9137 X26.035 Z-42.263
N9138 X25.105 Z-42.766
N9139 X24.175 Z-43.325
N9140 X22.316 Z-44.519
N9141 X21.386 Z-45.071
N9142 X20.456 Z-45.592
N9143 X19.526 Z-46.083
N9144 X17.658 Z-46.984
N9145 X15.783 Z-47.781
N9146 X14.845 Z-48.14
N9147 X13.001 Z-48.775
N9148 X11.158 Z-49.318
N9149 X9.273 Z-49.782
N9150 X7.422 Z-50.151
N9151 X5.554 Z-50.437
N9152 X3.719 Z-50.637
N9153 X1.862 Z-50.759
N9154 X0. Z-50.8
N9155 X-1.862 Z-50.759
N9156 X-3.719 Z-50.637
N9157 X-5.554 Z-50.437
N9158 X-7.422 Z-50.151
N9159 X-9.273 Z-49.782
N9160 X-11.158 Z-49.318
N9161 X-13.001 Z-48.775
N9162 X-14.845 Z-48.14
N9163 X-16.721 Z-47.395
N9164 X-18.596 Z-46.545
N9165 X-19.526 Z-46.083
N9166 X-20.456 Z-45.592
N9167 X-21.386 Z-45.071
N9168 X-22.316 Z-44.519
N9169 X-24.175 Z-43.325
N9170 X-25.105 Z-42.766
N9171 X-26.035 Z-42.263
N9172 X-26.965 Z-41.813
N9173 X-27.895 Z-41.418
N9174 X-28.824 Z-41.07
N9175 X-29.754 Z-40.781
N9176 X-30.684 Z-40.541
N9177 X-31.614 Z-40.365
N9178 X-32.544 Z-40.252
N9179 X-33.474 Z-40.214
N9180 X-119.003
N9181 X-119.017 Z-10.557
N9182 X-119.133 Z-9.454
N9183 X-119.366 Z-8.342
N9184 X-119.598 Z-7.568
N9185 X-119.947 Z-6.674
N9186 X-120.412 Z-5.739
N9187 X-120.877 Z-4.981
N9188 X-121.342 Z-4.335
N9189 X-121.807 Z-3.769
N9190 X-122.272 Z-3.278
N9191 X-122.736 Z-2.837
N9192 X-123.201 Z-2.444
N9193 X-123.666 Z-2.094
N9194 X-124.131 Z-1.776
N9195 X-125.061 Z-1.24
N9196 X-125.526 Z-1.015
N9197 X-126.456 Z-.638
N9198 X-127.386 Z-.354
N9199 X-128.315 Z-.156
N9200 X-129.245 Z-.039
N9201 X-130.175 Z0.
N9202 Y26.975
N9203 X-129.245 Z-.039
N9204 X-128.315 Z-.156
N9205 X-127.386 Z-.354
N9206 X-126.456 Z-.638
N9207 X-125.526 Z-1.015
N9208 X-125.061 Z-1.24
N9209 X-124.131 Z-1.776
N9210 X-123.666 Z-2.094
N9211 X-123.201 Z-2.444
N9212 X-122.736 Z-2.837
N9213 X-122.272 Z-3.278
N9214 X-121.807 Z-3.769
N9215 X-121.342 Z-4.335
N9216 X-120.877 Z-4.981
N9217 X-120.412 Z-5.739
N9218 X-119.947 Z-6.674
N9219 X-119.598 Z-7.568
N9220 X-119.366 Z-8.342
N9221 X-119.133 Z-9.454
N9222 X-119.017 Z-10.557
N9223 X-119.003 Z-41.226
N9224 X-31.614 Z-41.236
N9225 X-30.684 Z-41.302
N9226 X-29.754 Z-41.441
N9227 X-28.824 Z-41.637
N9228 X-27.895 Z-41.892
N9229 X-26.965 Z-42.198
N9230 X-26.035 Z-42.557
N9231 X-25.105 Z-42.966
N9232 X-24.175 Z-43.431
N9233 X-23.246 Z-43.948
N9234 X-21.359 Z-45.086
N9235 X-20.45 Z-45.595
N9236 X-18.596 Z-46.545
N9237 X-16.721 Z-47.395
N9238 X-14.845 Z-48.14
N9239 X-13.001 Z-48.775
N9240 X-11.158 Z-49.318
N9241 X-9.273 Z-49.782
N9242 X-7.422 Z-50.151
N9243 X-5.554 Z-50.437
N9244 X-3.719 Z-50.637
N9245 X-1.862 Z-50.759
N9246 X0. Z-50.8
N9247 X1.862 Z-50.759
N9248 X3.719 Z-50.637
N9249 X5.554 Z-50.437
N9250 X7.422 Z-50.151
N9251 X9.273 Z-49.782
N9252 X11.158 Z-49.318
N9253 X13.001 Z-48.775
N9254 X14.845 Z-48.14
N9255 X16.721 Z-47.395
N9256 X18.596 Z-46.545
N9257 X20.45 Z-45.595
N9258 X21.359 Z-45.086
N9259 X23.246 Z-43.948
N9260 X24.175 Z-43.431
N9261 X25.105 Z-42.966
N9262 X26.035 Z-42.557
N9263 X26.965 Z-42.198
N9264 X27.895 Z-41.892
N9265 X28.824 Z-41.637
N9266 X29.754 Z-41.441
N9267 X30.684 Z-41.302
N9268 X31.614 Z-41.236
N9269 X119.003 Z-41.226
N9270 X119.01 Z-10.724
N9271 X119.104 Z-9.653
N9272 X119.308 Z-8.571
N9273 X119.598 Z-7.568
N9274 X119.947 Z-6.674
N9275 X120.179 Z-6.185
N9276 X120.644 Z-5.343
N9277 X121.109 Z-4.641
N9278 X121.807 Z-3.769
N9279 X122.272 Z-3.278
N9280 X122.736 Z-2.837
N9281 X123.201 Z-2.444
N9282 X123.666 Z-2.094
N9283 X124.131 Z-1.776
N9284 X125.061 Z-1.24
N9285 X125.526 Z-1.015
N9286 X126.456 Z-.638
N9287 X127.386 Z-.354
N9288 X128.315 Z-.156
N9289 X129.245 Z-.039
N9290 X130.175 Z0.
N9291 Y25.775
N9292 X129.245 Z-.039
N9293 X128.315 Z-.156
N9294 X127.386 Z-.354
N9295 X126.456 Z-.638
N9296 X125.526 Z-1.015
N9297 X125.061 Z-1.24
N9298 X124.131 Z-1.776
N9299 X123.666 Z-2.094
N9300 X123.201 Z-2.444
N9301 X122.736 Z-2.837
N9302 X122.272 Z-3.278
N9303 X121.807 Z-3.769
N9304 X121.109 Z-4.641
N9305 X120.644 Z-5.343
N9306 X120.179 Z-6.185
N9307 X119.947 Z-6.674
N9308 X119.598 Z-7.568
N9309 X119.308 Z-8.571
N9310 X119.104 Z-9.653
N9311 X119.01 Z-10.724
N9312 X119.003 Z-42.165
N9313 X30.684
N9314 X29.754 Z-42.194
N9315 X28.824 Z-42.295
N9316 X27.895 Z-42.451
N9317 X26.965 Z-42.671
N9318 X26.035 Z-42.937
N9319 X25.105 Z-43.262
N9320 X24.175 Z-43.631
N9321 X23.246 Z-44.061
N9322 X22.316 Z-44.537
N9323 X20.258 Z-45.698
N9324 X18.596 Z-46.545
N9325 X16.721 Z-47.395
N9326 X14.845 Z-48.14
N9327 X13.001 Z-48.775
N9328 X11.158 Z-49.318
N9329 X9.273 Z-49.782
N9330 X7.422 Z-50.151
N9331 X5.554 Z-50.437
N9332 X3.719 Z-50.637
N9333 X1.862 Z-50.759
N9334 X0. Z-50.8
N9335 X-1.862 Z-50.759
N9336 X-3.719 Z-50.637
N9337 X-5.554 Z-50.437
N9338 X-7.422 Z-50.151
N9339 X-9.273 Z-49.782
N9340 X-11.158 Z-49.318
N9341 X-13.001 Z-48.775
N9342 X-14.845 Z-48.14
N9343 X-16.721 Z-47.395
N9344 X-18.596 Z-46.545
N9345 X-20.258 Z-45.698
N9346 X-22.316 Z-44.537
N9347 X-23.246 Z-44.061
N9348 X-24.175 Z-43.631
N9349 X-25.105 Z-43.262
N9350 X-26.035 Z-42.937
N9351 X-26.965 Z-42.671
N9352 X-27.895 Z-42.451
N9353 X-28.824 Z-42.295
N9354 X-29.754 Z-42.194
N9355 X-30.684 Z-42.165
N9356 X-119.003
N9357 X-119.017 Z-10.557
N9358 X-119.133 Z-9.454
N9359 X-119.366 Z-8.342
N9360 X-119.598 Z-7.568
N9361 X-119.947 Z-6.674
N9362 X-120.412 Z-5.739
N9363 X-120.877 Z-4.981
N9364 X-121.342 Z-4.335
N9365 X-121.807 Z-3.769
N9366 X-122.272 Z-3.278
N9367 X-122.736 Z-2.837
N9368 X-123.201 Z-2.444
N9369 X-123.666 Z-2.094
N9370 X-124.131 Z-1.776
N9371 X-125.061 Z-1.24
N9372 X-125.526 Z-1.015
N9373 X-126.456 Z-.638
N9374 X-127.386 Z-.354
N9375 X-128.315 Z-.156
N9376 X-129.245 Z-.039
N9377 X-130.175 Z0.
N9378 Y24.575
N9379 X-129.245 Z-.039
N9380 X-128.315 Z-.156
N9381 X-127.386 Z-.354
N9382 X-126.456 Z-.638
N9383 X-125.526 Z-1.015
N9384 X-125.061 Z-1.24
N9385 X-124.131 Z-1.776
N9386 X-123.666 Z-2.094
N9387 X-123.201 Z-2.444
N9388 X-122.736 Z-2.837
N9389 X-122.272 Z-3.278
N9390 X-121.807 Z-3.769
N9391 X-121.342 Z-4.335
N9392 X-120.877 Z-4.981
N9393 X-120.412 Z-5.739
N9394 X-119.947 Z-6.674
N9395 X-119.598 Z-7.568
N9396 X-119.366 Z-8.342
N9397 X-119.133 Z-9.454
N9398 X-119.017 Z-10.557
N9399 X-119.003 Z-43.037
N9400 X-28.824 Z-43.043
N9401 X-27.895 Z-43.103
N9402 X-26.965 Z-43.225
N9403 X-26.035 Z-43.407
N9404 X-25.105 Z-43.639
N9405 X-24.175 Z-43.927
N9406 X-23.246 Z-44.262
N9407 X-22.316 Z-44.654
N9408 X-21.386 Z-45.094
N9409 X-19.526 Z-46.083
N9410 X-18.596 Z-46.545
N9411 X-16.721 Z-47.395
N9412 X-14.845 Z-48.14
N9413 X-13.001 Z-48.775
N9414 X-11.158 Z-49.318
N9415 X-9.273 Z-49.782
N9416 X-7.422 Z-50.151
N9417 X-5.554 Z-50.437
N9418 X-3.719 Z-50.637
N9419 X-1.862 Z-50.759
N9420 X0. Z-50.8
N9421 X1.862 Z-50.759
N9422 X3.719 Z-50.637
N9423 X5.554 Z-50.437
N9424 X7.422 Z-50.151
N9425 X9.273 Z-49.782
N9426 X11.158 Z-49.318
N9427 X13.001 Z-48.775
N9428 X14.845 Z-48.14
N9429 X15.783 Z-47.781
N9430 X17.658 Z-46.984
N9431 X19.526 Z-46.083
N9432 X21.386 Z-45.094
N9433 X22.316 Z-44.654
N9434 X23.246 Z-44.262
N9435 X24.175 Z-43.927
N9436 X25.105 Z-43.639
N9437 X26.035 Z-43.407
N9438 X26.965 Z-43.225
N9439 X27.895 Z-43.103
N9440 X28.824 Z-43.043
N9441 X119.003 Z-43.037
N9442 X119.01 Z-10.724
N9443 X119.104 Z-9.653
N9444 X119.308 Z-8.571
N9445 X119.598 Z-7.568
N9446 X119.947 Z-6.674
N9447 X120.179 Z-6.185
N9448 X120.644 Z-5.343
N9449 X121.109 Z-4.641
N9450 X121.807 Z-3.769
N9451 X122.272 Z-3.278
N9452 X122.736 Z-2.837
N9453 X123.201 Z-2.444
N9454 X123.666 Z-2.094
N9455 X124.131 Z-1.776
N9456 X125.061 Z-1.24
N9457 X125.526 Z-1.015
N9458 X126.456 Z-.638
N9459 X127.386 Z-.354
N9460 X128.315 Z-.156
N9461 X129.245 Z-.039
N9462 X130.175 Z0.
N9463 Y23.375
N9464 X129.245 Z-.039
N9465 X128.315 Z-.156
N9466 X127.386 Z-.354
N9467 X126.456 Z-.638
N9468 X125.526 Z-1.015
N9469 X125.061 Z-1.24
N9470 X124.131 Z-1.776
N9471 X123.666 Z-2.094
N9472 X123.201 Z-2.444
N9473 X122.736 Z-2.837
N9474 X122.272 Z-3.278
N9475 X121.807 Z-3.769
N9476 X121.109 Z-4.641
N9477 X120.644 Z-5.343
N9478 X120.179 Z-6.185
N9479 X119.947 Z-6.674
N9480 X119.598 Z-7.568
N9481 X119.308 Z-8.571
N9482 X119.104 Z-9.653
N9483 X119.01 Z-10.724
N9484 X119.003 Z-43.852
N9485 X27.895
N9486 X26.965 Z-43.873
N9487 X26.035 Z-43.961
N9488 X25.105 Z-44.106
N9489 X24.175 Z-44.305
N9490 X23.246 Z-44.557
N9491 X22.316 Z-44.859
N9492 X21.386 Z-45.215
N9493 X20.456 Z-45.621
N9494 X18.596 Z-46.545
N9495 X16.721 Z-47.395
N9496 X14.845 Z-48.14
N9497 X13.001 Z-48.775
N9498 X11.158 Z-49.318
N9499 X9.273 Z-49.782
N9500 X7.422 Z-50.151
N9501 X5.554 Z-50.437
N9502 X3.719 Z-50.637
N9503 X1.862 Z-50.759
N9504 X0. Z-50.8
N9505 X-1.862 Z-50.759
N9506 X-3.719 Z-50.637
N9507 X-5.554 Z-50.437
N9508 X-7.422 Z-50.151
N9509 X-9.273 Z-49.782
N9510 X-11.158 Z-49.318
N9511 X-13.001 Z-48.775
N9512 X-14.845 Z-48.14
N9513 X-16.721 Z-47.395
N9514 X-18.596 Z-46.545
N9515 X-20.456 Z-45.621
N9516 X-21.386 Z-45.215
N9517 X-22.316 Z-44.859
N9518 X-23.246 Z-44.557
N9519 X-24.175 Z-44.305
N9520 X-25.105 Z-44.106
N9521 X-26.035 Z-43.961
N9522 X-26.965 Z-43.873
N9523 X-27.895 Z-43.852
N9524 X-119.003
N9525 X-119.017 Z-10.557
N9526 X-119.133 Z-9.454
N9527 X-119.366 Z-8.342
N9528 X-119.598 Z-7.568
N9529 X-119.947 Z-6.674
N9530 X-120.412 Z-5.739
N9531 X-120.877 Z-4.981
N9532 X-121.342 Z-4.335
N9533 X-121.807 Z-3.769
N9534 X-122.272 Z-3.278
N9535 X-122.736 Z-2.837
N9536 X-123.201 Z-2.444
N9537 X-123.666 Z-2.094
N9538 X-124.131 Z-1.776
N9539 X-125.061 Z-1.24
N9540 X-125.526 Z-1.015
N9541 X-126.456 Z-.638
N9542 X-127.386 Z-.354
N9543 X-128.315 Z-.156
N9544 X-129.245 Z-.039
N9545 X-130.175 Z0.
N9546 Y22.175
N9547 X-129.245 Z-.039
N9548 X-128.315 Z-.156
N9549 X-127.386 Z-.354
N9550 X-126.456 Z-.638
N9551 X-125.526 Z-1.015
N9552 X-125.061 Z-1.24
N9553 X-124.131 Z-1.776
N9554 X-123.666 Z-2.094
N9555 X-123.201 Z-2.444
N9556 X-122.736 Z-2.837
N9557 X-122.272 Z-3.278
N9558 X-121.807 Z-3.769
N9559 X-121.342 Z-4.335
N9560 X-120.877 Z-4.981
N9561 X-120.412 Z-5.739
N9562 X-119.947 Z-6.674
N9563 X-119.598 Z-7.568
N9564 X-119.366 Z-8.342
N9565 X-119.133 Z-9.454
N9566 X-119.017 Z-10.557
N9567 X-119.003 Z-44.603
N9568 X-26.035 Z-44.606
N9569 X-25.105 Z-44.661
N9570 X-24.175 Z-44.769
N9571 X-23.246 Z-44.937
N9572 X-22.316 Z-45.155
N9573 X-21.386 Z-45.424
N9574 X-20.456 Z-45.745
N9575 X-19.526 Z-46.118
N9576 X-16.721 Z-47.395
N9577 X-14.845 Z-48.14
N9578 X-13.001 Z-48.775
N9579 X-11.158 Z-49.318
N9580 X-9.273 Z-49.782
N9581 X-7.422 Z-50.151
N9582 X-5.554 Z-50.437
N9583 X-3.719 Z-50.637
N9584 X-1.862 Z-50.759
N9585 X0. Z-50.8
N9586 X1.862 Z-50.759
N9587 X3.719 Z-50.637
N9588 X5.554 Z-50.437
N9589 X7.422 Z-50.151
N9590 X9.273 Z-49.782
N9591 X11.158 Z-49.318
N9592 X13.001 Z-48.775
N9593 X14.845 Z-48.14
N9594 X15.783 Z-47.781
N9595 X17.658 Z-46.984
N9596 X19.526 Z-46.118
N9597 X20.456 Z-45.745
N9598 X21.386 Z-45.424
N9599 X22.316 Z-45.155
N9600 X23.246 Z-44.937
N9601 X24.175 Z-44.769
N9602 X25.105 Z-44.661
N9603 X26.035 Z-44.606
N9604 X119.003 Z-44.603
N9605 X119.01 Z-10.724
N9606 X119.104 Z-9.653
N9607 X119.308 Z-8.571
N9608 X119.598 Z-7.568
N9609 X119.947 Z-6.674
N9610 X120.179 Z-6.185
N9611 X120.644 Z-5.343
N9612 X121.109 Z-4.641
N9613 X121.807 Z-3.769
N9614 X122.272 Z-3.278
N9615 X122.736 Z-2.837
N9616 X123.201 Z-2.444
N9617 X123.666 Z-2.094
N9618 X124.131 Z-1.776
N9619 X125.061 Z-1.24
N9620 X125.526 Z-1.015
N9621 X126.456 Z-.638
N9622 X127.386 Z-.354
N9623 X128.315 Z-.156
N9624 X129.245 Z-.039
N9625 X130.175 Z0.
N9626 Y20.975
N9627 X129.245 Z-.039
N9628 X128.315 Z-.156
N9629 X127.386 Z-.354
N9630 X126.456 Z-.638
N9631 X125.526 Z-1.015
N9632 X125.061 Z-1.24
N9633 X124.131 Z-1.776
N9634 X123.666 Z-2.094
N9635 X123.201 Z-2.444
N9636 X122.736 Z-2.837
N9637 X122.272 Z-3.278
N9638 X121.807 Z-3.769
N9639 X121.109 Z-4.641
N9640 X120.644 Z-5.343
N9641 X120.179 Z-6.185
N9642 X119.947 Z-6.674
N9643 X119.598 Z-7.568
N9644 X119.308 Z-8.571
N9645 X119.104 Z-9.653
N9646 X119.01 Z-10.724
N9647 X119.003 Z-45.304
N9648 X26.035
N9649 X24.175 Z-45.326
N9650 X23.246 Z-45.401
N9651 X22.316 Z-45.536
N9652 X21.386 Z-45.721
N9653 X20.456 Z-45.959
N9654 X19.526 Z-46.247
N9655 X18.596 Z-46.587
N9656 X16.58 Z-47.454
N9657 X15.572 Z-47.863
N9658 X14.564 Z-48.242
N9659 X12.861 Z-48.819
N9660 X11.158 Z-49.318
N9661 X9.273 Z-49.782
N9662 X7.422 Z-50.151
N9663 X5.554 Z-50.437
N9664 X3.719 Z-50.637
N9665 X1.862 Z-50.759
N9666 X0. Z-50.8
N9667 X-1.862 Z-50.759
N9668 X-3.719 Z-50.637
N9669 X-5.554 Z-50.437
N9670 X-7.422 Z-50.151
N9671 X-9.273 Z-49.782
N9672 X-11.158 Z-49.318
N9673 X-12.861 Z-48.819
N9674 X-14.564 Z-48.242
N9675 X-15.572 Z-47.863
N9676 X-16.58 Z-47.454
N9677 X-18.596 Z-46.587
N9678 X-19.526 Z-46.247
N9679 X-20.456 Z-45.959
N9680 X-21.386 Z-45.721
N9681 X-22.316 Z-45.536
N9682 X-23.246 Z-45.401
N9683 X-24.175 Z-45.326
N9684 X-26.035 Z-45.304
N9685 X-119.003
N9686 X-119.017 Z-10.557
N9687 X-119.133 Z-9.454
N9688 X-119.366 Z-8.342
N9689 X-119.598 Z-7.568
N9690 X-119.947 Z-6.674
N9691 X-120.412 Z-5.739
N9692 X-120.877 Z-4.981
N9693 X-121.342 Z-4.335
N9694 X-121.807 Z-3.769
N9695 X-122.272 Z-3.278
N9696 X-122.736 Z-2.837
N9697 X-123.201 Z-2.444
N9698 X-123.666 Z-2.094
N9699 X-124.131 Z-1.776
N9700 X-125.061 Z-1.24
N9701 X-125.526 Z-1.015
N9702 X-126.456 Z-.638
N9703 X-127.386 Z-.354
N9704 X-128.315 Z-.156
N9705 X-129.245 Z-.039
N9706 X-130.175 Z0.
N9707 Y19.775
N9708 X-129.245 Z-.039
N9709 X-128.315 Z-.156
N9710 X-127.386 Z-.354
N9711 X-126.456 Z-.638
N9712 X-125.526 Z-1.015
N9713 X-125.061 Z-1.24
N9714 X-124.131 Z-1.776
N9715 X-123.666 Z-2.094
N9716 X-123.201 Z-2.444
N9717 X-122.736 Z-2.837
N9718 X-122.272 Z-3.278
N9719 X-121.807 Z-3.769
N9720 X-121.342 Z-4.335
N9721 X-120.877 Z-4.981
N9722 X-120.412 Z-5.739
N9723 X-119.947 Z-6.674
N9724 X-119.598 Z-7.568
N9725 X-119.366 Z-8.342
N9726 X-119.133 Z-9.454
N9727 X-119.017 Z-10.557
N9728 X-119.003 Z-45.957
N9729 X-23.246 Z-45.958
N9730 X-22.316 Z-46.
N9731 X-21.386 Z-46.105
N9732 X-20.456 Z-46.257
N9733 X-19.526 Z-46.465
N9734 X-18.596 Z-46.72
N9735 X-17.667 Z-47.029
N9736 X-14.877 Z-48.128
N9737 X-12.992 Z-48.778
N9738 X-11.158 Z-49.318
N9739 X-9.273 Z-49.782
N9740 X-7.422 Z-50.151
N9741 X-5.554 Z-50.437
N9742 X-3.719 Z-50.637
N9743 X-1.862 Z-50.759
N9744 X0. Z-50.8
N9745 X1.862 Z-50.759
N9746 X3.719 Z-50.637
N9747 X5.554 Z-50.437
N9748 X7.422 Z-50.151
N9749 X9.273 Z-49.782
N9750 X11.158 Z-49.318
N9751 X12.992 Z-48.778
N9752 X14.877 Z-48.128
N9753 X17.667 Z-47.029
N9754 X18.596 Z-46.72
N9755 X19.526 Z-46.465
N9756 X20.456 Z-46.257
N9757 X21.386 Z-46.105
N9758 X22.316 Z-46.
N9759 X23.246 Z-45.958
N9760 X119.003 Z-45.957
N9761 X119.01 Z-10.724
N9762 X119.104 Z-9.653
N9763 X119.308 Z-8.571
N9764 X119.598 Z-7.568
N9765 X119.947 Z-6.674
N9766 X120.179 Z-6.185
N9767 X120.644 Z-5.343
N9768 X121.109 Z-4.641
N9769 X121.807 Z-3.769
N9770 X122.272 Z-3.278
N9771 X122.736 Z-2.837
N9772 X123.201 Z-2.444
N9773 X123.666 Z-2.094
N9774 X124.131 Z-1.776
N9775 X125.061 Z-1.24
N9776 X125.526 Z-1.015
N9777 X126.456 Z-.638
N9778 X127.386 Z-.354
N9779 X128.315 Z-.156
N9780 X129.245 Z-.039
N9781 X130.175 Z0.
N9782 Y18.575
N9783 X129.245 Z-.039
N9784 X128.315 Z-.156
N9785 X127.386 Z-.354
N9786 X126.456 Z-.638
N9787 X125.526 Z-1.015
N9788 X125.061 Z-1.24
N9789 X124.131 Z-1.776
N9790 X123.666 Z-2.094
N9791 X123.201 Z-2.444
N9792 X122.736 Z-2.837
N9793 X122.272 Z-3.278
N9794 X121.807 Z-3.769
N9795 X121.109 Z-4.641
N9796 X120.644 Z-5.343
N9797 X120.179 Z-6.185
N9798 X119.947 Z-6.674
N9799 X119.598 Z-7.568
N9800 X119.308 Z-8.571
N9801 X119.104 Z-9.653
N9802 X119.01 Z-10.724
N9803 X119.003 Z-46.556
N9804 X22.316
N9805 X21.386 Z-46.57
N9806 X20.456 Z-46.643
N9807 X19.526 Z-46.764
N9808 X18.596 Z-46.942
N9809 X17.667 Z-47.166
N9810 X16.737 Z-47.444
N9811 X15.807 Z-47.772
N9812 X14.877 Z-48.128
N9813 X13.011 Z-48.772
N9814 X11.158 Z-49.318
N9815 X9.273 Z-49.782
N9816 X7.422 Z-50.151
N9817 X5.554 Z-50.437
N9818 X3.719 Z-50.637
N9819 X1.862 Z-50.759
N9820 X0. Z-50.8
N9821 X-1.862 Z-50.759
N9822 X-3.719 Z-50.637
N9823 X-5.554 Z-50.437
N9824 X-7.422 Z-50.151
N9825 X-9.273 Z-49.782
N9826 X-11.158 Z-49.318
N9827 X-13.011 Z-48.772
N9828 X-14.877 Z-48.128
N9829 X-15.807 Z-47.772
N9830 X-16.737 Z-47.444
N9831 X-17.667 Z-47.166
N9832 X-18.596 Z-46.942
N9833 X-19.526 Z-46.764
N9834 X-20.456 Z-46.643
N9835 X-21.386 Z-46.57
N9836 X-119.003 Z-46.556
N9837 X-119.017 Z-10.557
N9838 X-119.133 Z-9.454
N9839 X-119.366 Z-8.342
N9840 X-119.598 Z-7.568
N9841 X-119.947 Z-6.674
N9842 X-120.412 Z-5.739
N9843 X-120.877 Z-4.981
N9844 X-121.342 Z-4.335
N9845 X-121.807 Z-3.769
N9846 X-122.272 Z-3.278
N9847 X-122.736 Z-2.837
N9848 X-123.201 Z-2.444
N9849 X-123.666 Z-2.094
N9850 X-124.131 Z-1.776
N9851 X-125.061 Z-1.24
N9852 X-125.526 Z-1.015
N9853 X-126.456 Z-.638
N9854 X-127.386 Z-.354
N9855 X-128.315 Z-.156
N9856 X-129.245 Z-.039
N9857 X-130.175 Z0.
N9858 Y17.375
N9859 X-129.245 Z-.039
N9860 X-128.315 Z-.156
N9861 X-127.386 Z-.354
N9862 X-126.456 Z-.638
N9863 X-125.526 Z-1.015
N9864 X-125.061 Z-1.24
N9865 X-124.131 Z-1.776
N9866 X-123.666 Z-2.094
N9867 X-123.201 Z-2.444
N9868 X-122.736 Z-2.837
N9869 X-122.272 Z-3.278
N9870 X-121.807 Z-3.769
N9871 X-121.342 Z-4.335
N9872 X-120.877 Z-4.981
N9873 X-120.412 Z-5.739
N9874 X-119.947 Z-6.674
N9875 X-119.598 Z-7.568
N9876 X-119.366 Z-8.342
N9877 X-119.133 Z-9.454
N9878 X-119.017 Z-10.557
N9879 X-119.003 Z-47.111
N9880 X-20.456 Z-47.112
N9881 X-19.526 Z-47.153
N9882 X-18.596 Z-47.244
N9883 X-17.667 Z-47.393
N9884 X-16.737 Z-47.586
N9885 X-15.807 Z-47.834
N9886 X-14.877 Z-48.13
N9887 X-13.006 Z-48.773
N9888 X-11.158 Z-49.318
N9889 X-9.273 Z-49.782
N9890 X-7.422 Z-50.151
N9891 X-5.554 Z-50.437
N9892 X-3.719 Z-50.637
N9893 X-1.862 Z-50.759
N9894 X0. Z-50.8
N9895 X1.862 Z-50.759
N9896 X3.719 Z-50.637
N9897 X5.554 Z-50.437
N9898 X7.422 Z-50.151
N9899 X9.273 Z-49.782
N9900 X11.158 Z-49.318
N9901 X13.006 Z-48.773
N9902 X14.877 Z-48.13
N9903 X15.807 Z-47.834
N9904 X16.737 Z-47.586
N9905 X17.667 Z-47.393
N9906 X18.596 Z-47.244
N9907 X19.526 Z-47.153
N9908 X20.456 Z-47.112
N9909 X119.003 Z-47.111
N9910 X119.01 Z-10.724
N9911 X119.104 Z-9.653
N9912 X119.308 Z-8.571
N9913 X119.598 Z-7.568
N9914 X119.947 Z-6.674
N9915 X120.179 Z-6.185
N9916 X120.644 Z-5.343
N9917 X121.109 Z-4.641
N9918 X121.807 Z-3.769
N9919 X122.272 Z-3.278
N9920 X122.736 Z-2.837
N9921 X123.201 Z-2.444
N9922 X123.666 Z-2.094
N9923 X124.131 Z-1.776
N9924 X125.061 Z-1.24
N9925 X125.526 Z-1.015
N9926 X126.456 Z-.638
N9927 X127.386 Z-.354
N9928 X128.315 Z-.156
N9929 X129.245 Z-.039
N9930 X130.175 Z0.
N9931 Y16.175
N9932 X129.245 Z-.039
N9933 X128.315 Z-.156
N9934 X127.386 Z-.354
N9935 X126.456 Z-.638
N9936 X125.526 Z-1.015
N9937 X125.061 Z-1.24
N9938 X124.131 Z-1.776
N9939 X123.666 Z-2.094
N9940 X123.201 Z-2.444
N9941 X122.736 Z-2.837
N9942 X122.272 Z-3.278
N9943 X121.807 Z-3.769
N9944 X121.109 Z-4.641
N9945 X120.644 Z-5.343
N9946 X120.179 Z-6.185
N9947 X119.947 Z-6.674
N9948 X119.598 Z-7.568
N9949 X119.308 Z-8.571
N9950 X119.104 Z-9.653
N9951 X119.01 Z-10.724
N9952 X119.003 Z-47.624
N9953 X18.596 Z-47.636
N9954 X17.667 Z-47.698
N9955 X16.737 Z-47.817
N9956 X15.807 Z-47.98
N9957 X14.877 Z-48.199
N9958 X13.947 Z-48.465
N9959 X13.017 Z-48.77
N9960 X11.158 Z-49.318
N9961 X9.273 Z-49.782
N9962 X7.422 Z-50.151
N9963 X5.554 Z-50.437
N9964 X3.719 Z-50.637
N9965 X1.862 Z-50.759
N9966 X0. Z-50.8
N9967 X-1.862 Z-50.759
N9968 X-3.719 Z-50.637
N9969 X-5.554 Z-50.437
N9970 X-7.422 Z-50.151
N9971 X-9.273 Z-49.782
N9972 X-11.158 Z-49.318
N9973 X-14.877 Z-48.199
N9974 X-15.807 Z-47.98
N9975 X-16.737 Z-47.817
N9976 X-17.667 Z-47.698
N9977 X-18.596 Z-47.636
N9978 X-119.003 Z-47.624
N9979 X-119.017 Z-10.557
N9980 X-119.133 Z-9.454
N9981 X-119.366 Z-8.342
N9982 X-119.598 Z-7.568
N9983 X-119.947 Z-6.674
N9984 X-120.412 Z-5.739
N9985 X-120.877 Z-4.981
N9986 X-121.342 Z-4.335
N9987 X-121.807 Z-3.769
N9988 X-122.272 Z-3.278
N9989 X-122.736 Z-2.837
N9990 X-123.201 Z-2.444
N9991 X-123.666 Z-2.094
N9992 X-124.131 Z-1.776
N9993 X-125.061 Z-1.24
N9994 X-125.526 Z-1.015
N9995 X-126.456 Z-.638
N9996 X-127.386 Z-.354
N9997 X-128.315 Z-.156
N9998 X-129.245 Z-.039
N9999 X-130.175 Z0.
N10000 Y14.975
N10001 X-129.245 Z-.039
N10002 X-128.315 Z-.156
N10003 X-127.386 Z-.354
N10004 X-126.456 Z-.638
N10005 X-125.526 Z-1.015
N10006 X-125.061 Z-1.24
N10007 X-124.131 Z-1.776
N10008 X-123.666 Z-2.094
N10009 X-123.201 Z-2.444
N10010 X-122.736 Z-2.837
N10011 X-122.272 Z-3.278
N10012 X-121.807 Z-3.769
N10013 X-121.342 Z-4.335
N10014 X-120.877 Z-4.981
N10015 X-120.412 Z-5.739
N10016 X-119.947 Z-6.674
N10017 X-119.598 Z-7.568
N10018 X-119.366 Z-8.342
N10019 X-119.133 Z-9.454
N10020 X-119.017 Z-10.557
N10021 X-119.003 Z-48.093
N10022 X-17.667 Z-48.093
N10023 X-16.737 Z-48.125
N10024 X-15.807 Z-48.215
N10025 X-14.877 Z-48.35
N10026 X-13.947 Z-48.54
N10027 X-13.017 Z-48.776
N10028 X-11.158 Z-49.318
N10029 X-9.273 Z-49.782
N10030 X-7.422 Z-50.151
N10031 X-5.554 Z-50.437
N10032 X-3.719 Z-50.637
N10033 X-1.862 Z-50.759
N10034 X0. Z-50.8
N10035 X1.862 Z-50.759
N10036 X3.719 Z-50.637
N10037 X5.554 Z-50.437
N10038 X7.422 Z-50.151
N10039 X9.273 Z-49.782
N10040 X11.158 Z-49.318
N10041 X13.017 Z-48.776
N10042 X13.947 Z-48.54
N10043 X14.877 Z-48.35
N10044 X15.807 Z-48.215
N10045 X16.737 Z-48.125
N10046 X17.667 Z-48.093
N10047 X119.003 Z-48.093
N10048 X119.01 Z-10.724
N10049 X119.104 Z-9.653
N10050 X119.308 Z-8.571
N10051 X119.598 Z-7.568
N10052 X119.947 Z-6.674
N10053 X120.179 Z-6.185
N10054 X120.644 Z-5.343
N10055 X121.109 Z-4.641
N10056 X121.807 Z-3.769
N10057 X122.272 Z-3.278
N10058 X122.736 Z-2.837
N10059 X123.201 Z-2.444
N10060 X123.666 Z-2.094
N10061 X124.131 Z-1.776
N10062 X125.061 Z-1.24
N10063 X125.526 Z-1.015
N10064 X126.456 Z-.638
N10065 X127.386 Z-.354
N10066 X128.315 Z-.156
N10067 X129.245 Z-.039
N10068 X130.175 Z0.
N10069 Y13.775
N10070 X129.245 Z-.039
N10071 X128.315 Z-.156
N10072 X127.386 Z-.354
N10073 X126.456 Z-.638
N10074 X125.526 Z-1.015
N10075 X125.061 Z-1.24
N10076 X124.131 Z-1.776
N10077 X123.666 Z-2.094
N10078 X123.201 Z-2.444
N10079 X122.736 Z-2.837
N10080 X122.272 Z-3.278
N10081 X121.807 Z-3.769
N10082 X121.109 Z-4.641
N10083 X120.644 Z-5.343
N10084 X120.179 Z-6.185
N10085 X119.947 Z-6.674
N10086 X119.598 Z-7.568
N10087 X119.308 Z-8.571
N10088 X119.104 Z-9.653
N10089 X119.01 Z-10.724
N10090 X119.003 Z-48.519
N10091 X15.807 Z-48.529
N10092 X14.877 Z-48.589
N10093 X13.947 Z-48.695
N10094 X13.017 Z-48.857
N10095 X12.088 Z-49.064
N10096 X11.158 Z-49.318
N10097 X9.273 Z-49.782
N10098 X7.422 Z-50.151
N10099 X5.554 Z-50.437
N10100 X3.719 Z-50.637
N10101 X1.862 Z-50.759
N10102 X0. Z-50.8
N10103 X-1.862 Z-50.759
N10104 X-3.719 Z-50.637
N10105 X-5.554 Z-50.437
N10106 X-7.422 Z-50.151
N10107 X-9.273 Z-49.782
N10108 X-11.158 Z-49.318
N10109 X-12.088 Z-49.064
N10110 X-13.017 Z-48.857
N10111 X-13.947 Z-48.695
N10112 X-14.877 Z-48.589
N10113 X-15.807 Z-48.529
N10114 X-119.003 Z-48.519
N10115 X-119.017 Z-10.557
N10116 X-119.133 Z-9.454
N10117 X-119.366 Z-8.342
N10118 X-119.598 Z-7.568
N10119 X-119.947 Z-6.674
N10120 X-120.412 Z-5.739
N10121 X-120.877 Z-4.981
N10122 X-121.342 Z-4.335
N10123 X-121.807 Z-3.769
N10124 X-122.272 Z-3.278
N10125 X-122.736 Z-2.837
N10126 X-123.201 Z-2.444
N10127 X-123.666 Z-2.094
N10128 X-124.131 Z-1.776
N10129 X-125.061 Z-1.24
N10130 X-125.526 Z-1.015
N10131 X-126.456 Z-.638
N10132 X-127.386 Z-.354
N10133 X-128.315 Z-.156
N10134 X-129.245 Z-.039
N10135 X-130.175 Z0.
N10136 Y12.575
N10137 X-129.245 Z-.039
N10138 X-128.315 Z-.156
N10139 X-127.386 Z-.354
N10140 X-126.456 Z-.638
N10141 X-125.526 Z-1.015
N10142 X-125.061 Z-1.24
N10143 X-124.131 Z-1.776
N10144 X-123.666 Z-2.094
N10145 X-123.201 Z-2.444
N10146 X-122.736 Z-2.837
N10147 X-122.272 Z-3.278
N10148 X-121.807 Z-3.769
N10149 X-121.342 Z-4.335
N10150 X-120.877 Z-4.981
N10151 X-120.412 Z-5.739
N10152 X-119.947 Z-6.674
N10153 X-119.598 Z-7.568
N10154 X-119.366 Z-8.342
N10155 X-119.133 Z-9.454
N10156 X-119.017 Z-10.557
N10157 X-119.003 Z-48.908
N10158 X-14.877 Z-48.908
N10159 X-13.947 Z-48.939
N10160 X-13.017 Z-49.018
N10161 X-12.088 Z-49.152
N10162 X-11.158 Z-49.33
N10163 X-9.031 Z-49.833
N10164 X-7.334 Z-50.165
N10165 X-5.496 Z-50.444
N10166 X-3.719 Z-50.637
N10167 X-1.862 Z-50.759
N10168 X0. Z-50.8
N10169 X1.862 Z-50.759
N10170 X3.719 Z-50.637
N10171 X5.496 Z-50.444
N10172 X7.334 Z-50.165
N10173 X9.031 Z-49.833
N10174 X11.158 Z-49.33
N10175 X12.088 Z-49.152
N10176 X13.017 Z-49.018
N10177 X13.947 Z-48.939
N10178 X14.877 Z-48.908
N10179 X119.003 Z-48.908
N10180 X119.01 Z-10.724
N10181 X119.104 Z-9.653
N10182 X119.308 Z-8.571
N10183 X119.598 Z-7.568
N10184 X119.947 Z-6.674
N10185 X120.179 Z-6.185
N10186 X120.644 Z-5.343
N10187 X121.109 Z-4.641
N10188 X121.807 Z-3.769
N10189 X122.272 Z-3.278
N10190 X122.736 Z-2.837
N10191 X123.201 Z-2.444
N10192 X123.666 Z-2.094
N10193 X124.131 Z-1.776
N10194 X125.061 Z-1.24
N10195 X125.526 Z-1.015
N10196 X126.456 Z-.638
N10197 X127.386 Z-.354
N10198 X128.315 Z-.156
N10199 X129.245 Z-.039
N10200 X130.175 Z0.
N10201 Y11.375
N10202 X129.245 Z-.039
N10203 X128.315 Z-.156
N10204 X127.386 Z-.354
N10205 X126.456 Z-.638
N10206 X125.526 Z-1.015
N10207 X125.061 Z-1.24
N10208 X124.131 Z-1.776
N10209 X123.666 Z-2.094
N10210 X123.201 Z-2.444
N10211 X122.736 Z-2.837
N10212 X122.272 Z-3.278
N10213 X121.807 Z-3.769
N10214 X121.109 Z-4.641
N10215 X120.644 Z-5.343
N10216 X120.179 Z-6.185
N10217 X119.947 Z-6.674
N10218 X119.598 Z-7.568
N10219 X119.308 Z-8.571
N10220 X119.104 Z-9.653
N10221 X119.01 Z-10.724
N10222 X119.003 Z-49.259
N10223 X13.017 Z-49.266
N10224 X12.088 Z-49.317
N10225 X11.158 Z-49.424
N10226 X9.906 Z-49.639
N10227 X8.654 Z-49.913
N10228 X7.354 Z-50.162
N10229 X6.149 Z-50.353
N10230 X5.062 Z-50.496
N10231 X3.719 Z-50.637
N10232 X1.862 Z-50.759
N10233 X0. Z-50.8
N10234 X-1.862 Z-50.759
N10235 X-3.719 Z-50.637
N10236 X-5.062 Z-50.496
N10237 X-6.149 Z-50.353
N10238 X-7.354 Z-50.162
N10239 X-8.654 Z-49.913
N10240 X-9.906 Z-49.639
N10241 X-11.158 Z-49.424
N10242 X-12.088 Z-49.317
N10243 X-13.017 Z-49.266
N10244 X-119.003 Z-49.259
N10245 X-119.017 Z-10.557
N10246 X-119.133 Z-9.454
N10247 X-119.366 Z-8.342
N10248 X-119.598 Z-7.568
N10249 X-119.947 Z-6.674
N10250 X-120.412 Z-5.739
N10251 X-120.877 Z-4.981
N10252 X-121.342 Z-4.335
N10253 X-121.807 Z-3.769
N10254 X-122.272 Z-3.278
N10255 X-122.736 Z-2.837
N10256 X-123.201 Z-2.444
N10257 X-123.666 Z-2.094
N10258 X-124.131 Z-1.776
N10259 X-125.061 Z-1.24
N10260 X-125.526 Z-1.015
N10261 X-126.456 Z-.638
N10262 X-127.386 Z-.354
N10263 X-128.315 Z-.156
N10264 X-129.245 Z-.039
N10265 X-130.175 Z0.
N10266 Y10.175
N10267 X-129.245 Z-.039
N10268 X-128.315 Z-.156
N10269 X-127.386 Z-.354
N10270 X-126.456 Z-.638
N10271 X-125.526 Z-1.015
N10272 X-125.061 Z-1.24
N10273 X-124.131 Z-1.776
N10274 X-123.666 Z-2.094
N10275 X-123.201 Z-2.444
N10276 X-122.736 Z-2.837
N10277 X-122.272 Z-3.278
N10278 X-121.807 Z-3.769
N10279 X-121.342 Z-4.335
N10280 X-120.877 Z-4.981
N10281 X-120.412 Z-5.739
N10282 X-119.947 Z-6.674
N10283 X-119.598 Z-7.568
N10284 X-119.366 Z-8.342
N10285 X-119.133 Z-9.454
N10286 X-119.017 Z-10.557
N10287 X-119.003 Z-49.571
N10288 X-11.158 Z-49.595
N10289 X-10.228 Z-49.673
N10290 X-9.298 Z-49.796
N10291 X-7.439 Z-50.148
N10292 X-5.58 Z-50.434
N10293 X-3.719 Z-50.637
N10294 X-1.862 Z-50.759
N10295 X0. Z-50.8
N10296 X1.862 Z-50.759
N10297 X3.719 Z-50.637
N10298 X5.58 Z-50.434
N10299 X7.439 Z-50.148
N10300 X9.298 Z-49.796
N10301 X10.228 Z-49.673
N10302 X11.158 Z-49.595
N10303 X13.017 Z-49.571
N10304 X119.003
N10305 X119.01 Z-10.724
N10306 X119.104 Z-9.653
N10307 X119.308 Z-8.571
N10308 X119.598 Z-7.568
N10309 X119.947 Z-6.674
N10310 X120.179 Z-6.185
N10311 X120.644 Z-5.343
N10312 X121.109 Z-4.641
N10313 X121.807 Z-3.769
N10314 X122.272 Z-3.278
N10315 X122.736 Z-2.837
N10316 X123.201 Z-2.444
N10317 X123.666 Z-2.094
N10318 X124.131 Z-1.776
N10319 X125.061 Z-1.24
N10320 X125.526 Z-1.015
N10321 X126.456 Z-.638
N10322 X127.386 Z-.354
N10323 X128.315 Z-.156
N10324 X129.245 Z-.039
N10325 X130.175 Z0.
N10326 Y8.975
N10327 X129.245 Z-.039
N10328 X128.315 Z-.156
N10329 X127.386 Z-.354
N10330 X126.456 Z-.638
N10331 X125.526 Z-1.015
N10332 X125.061 Z-1.24
N10333 X124.131 Z-1.776
N10334 X123.666 Z-2.094
N10335 X123.201 Z-2.444
N10336 X122.736 Z-2.837
N10337 X122.272 Z-3.278
N10338 X121.807 Z-3.769
N10339 X121.109 Z-4.641
N10340 X120.644 Z-5.343
N10341 X120.179 Z-6.185
N10342 X119.947 Z-6.674
N10343 X119.598 Z-7.568
N10344 X119.308 Z-8.571
N10345 X119.104 Z-9.653
N10346 X119.01 Z-10.724
N10347 X119.003 Z-49.845
N10348 X10.228 Z-49.851
N10349 X9.298 Z-49.901
N10350 X8.368 Z-49.998
N10351 X5.589 Z-50.433
N10352 X3.719 Z-50.637
N10353 X1.862 Z-50.759
N10354 X0. Z-50.8
N10355 X-1.862 Z-50.759
N10356 X-3.719 Z-50.637
N10357 X-5.589 Z-50.433
N10358 X-8.368 Z-49.998
N10359 X-9.298 Z-49.901
N10360 X-10.228 Z-49.851
N10361 X-119.003 Z-49.845
N10362 X-119.017 Z-10.557
N10363 X-119.133 Z-9.454
N10364 X-119.366 Z-8.342
N10365 X-119.598 Z-7.568
N10366 X-119.947 Z-6.674
N10367 X-120.412 Z-5.739
N10368 X-120.877 Z-4.981
N10369 X-121.342 Z-4.335
N10370 X-121.807 Z-3.769
N10371 X-122.272 Z-3.278
N10372 X-122.736 Z-2.837
N10373 X-123.201 Z-2.444
N10374 X-123.666 Z-2.094
N10375 X-124.131 Z-1.776
N10376 X-125.061 Z-1.24
N10377 X-125.526 Z-1.015
N10378 X-126.456 Z-.638
N10379 X-127.386 Z-.354
N10380 X-128.315 Z-.156
N10381 X-129.245 Z-.039
N10382 X-130.175 Z0.
N10383 Y7.775
N10384 X-129.245 Z-.039
N10385 X-128.315 Z-.156
N10386 X-127.386 Z-.354
N10387 X-126.456 Z-.638
N10388 X-125.526 Z-1.015
N10389 X-125.061 Z-1.24
N10390 X-124.131 Z-1.776
N10391 X-123.666 Z-2.094
N10392 X-123.201 Z-2.444
N10393 X-122.736 Z-2.837
N10394 X-122.272 Z-3.278
N10395 X-121.807 Z-3.769
N10396 X-121.342 Z-4.335
N10397 X-120.877 Z-4.981
N10398 X-120.412 Z-5.739
N10399 X-119.947 Z-6.674
N10400 X-119.598 Z-7.568
N10401 X-119.366 Z-8.342
N10402 X-119.133 Z-9.454
N10403 X-119.017 Z-10.557
N10404 X-119.003 Z-50.085
N10405 X-9.298
N10406 X-8.368 Z-50.108
N10407 X-7.439 Z-50.178
N10408 X-4.749 Z-50.534
N10409 X-3.719 Z-50.637
N10410 X-1.862 Z-50.759
N10411 X0. Z-50.8
N10412 X1.862 Z-50.759
N10413 X3.719 Z-50.637
N10414 X4.749 Z-50.534
N10415 X7.439 Z-50.178
N10416 X8.368 Z-50.108
N10417 X9.298 Z-50.085
N10418 X119.003
N10419 X119.01 Z-10.724
N10420 X119.104 Z-9.653
N10421 X119.308 Z-8.571
N10422 X119.598 Z-7.568
N10423 X119.947 Z-6.674
N10424 X120.179 Z-6.185
N10425 X120.644 Z-5.343
N10426 X121.109 Z-4.641
N10427 X121.807 Z-3.769
N10428 X122.272 Z-3.278
N10429 X122.736 Z-2.837
N10430 X123.201 Z-2.444
N10431 X123.666 Z-2.094
N10432 X124.131 Z-1.776
N10433 X125.061 Z-1.24
N10434 X125.526 Z-1.015
N10435 X126.456 Z-.638
N10436 X127.386 Z-.354
N10437 X128.315 Z-.156
N10438 X129.245 Z-.039
N10439 X130.175 Z0.
N10440 Y6.575
N10441 X129.245 Z-.039
N10442 X128.315 Z-.156
N10443 X127.386 Z-.354
N10444 X126.456 Z-.638
N10445 X125.526 Z-1.015
N10446 X125.061 Z-1.24
N10447 X124.131 Z-1.776
N10448 X123.666 Z-2.094
N10449 X123.201 Z-2.444
N10450 X122.736 Z-2.837
N10451 X122.272 Z-3.278
N10452 X121.807 Z-3.769
N10453 X121.109 Z-4.641
N10454 X120.644 Z-5.343
N10455 X120.179 Z-6.185
N10456 X119.947 Z-6.674
N10457 X119.598 Z-7.568
N10458 X119.308 Z-8.571
N10459 X119.104 Z-9.653
N10460 X119.01 Z-10.724
N10461 X119.003 Z-50.291
N10462 X7.439 Z-50.294
N10463 X6.509 Z-50.337
N10464 X3.719 Z-50.637
N10465 X1.862 Z-50.759
N10466 X0. Z-50.8
N10467 X-1.862 Z-50.759
N10468 X-3.719 Z-50.637
N10469 X-6.509 Z-50.337
N10470 X-7.439 Z-50.294
N10471 X-119.003 Z-50.291
N10472 X-119.017 Z-10.557
N10473 X-119.133 Z-9.454
N10474 X-119.366 Z-8.342
N10475 X-119.598 Z-7.568
N10476 X-119.947 Z-6.674
N10477 X-120.412 Z-5.739
N10478 X-120.877 Z-4.981
N10479 X-121.342 Z-4.335
N10480 X-121.807 Z-3.769
N10481 X-122.272 Z-3.278
N10482 X-122.736 Z-2.837
N10483 X-123.201 Z-2.444
N10484 X-123.666 Z-2.094
N10485 X-124.131 Z-1.776
N10486 X-125.061 Z-1.24
N10487 X-125.526 Z-1.015
N10488 X-126.456 Z-.638
N10489 X-127.386 Z-.354
N10490 X-128.315 Z-.156
N10491 X-129.245 Z-.039
N10492 X-130.175 Z0.
N10493 Y5.375
N10494 X-129.245 Z-.039
N10495 X-128.315 Z-.156
N10496 X-127.386 Z-.354
N10497 X-126.456 Z-.638
N10498 X-125.526 Z-1.015
N10499 X-125.061 Z-1.24
N10500 X-124.131 Z-1.776
N10501 X-123.666 Z-2.094
N10502 X-123.201 Z-2.444
N10503 X-122.736 Z-2.837
N10504 X-122.272 Z-3.278
N10505 X-121.807 Z-3.769
N10506 X-121.342 Z-4.335
N10507 X-120.877 Z-4.981
N10508 X-120.412 Z-5.739
N10509 X-119.947 Z-6.674
N10510 X-119.598 Z-7.568
N10511 X-119.366 Z-8.342
N10512 X-119.133 Z-9.454
N10513 X-119.017 Z-10.557
N10514 X-119.003 Z-50.459
N10515 X-5.579 Z-50.477
N10516 X-3.719 Z-50.637
N10517 X-1.862 Z-50.759
N10518 X0. Z-50.8
N10519 X1.862 Z-50.759
N10520 X3.719 Z-50.637
N10521 X5.579 Z-50.477
N10522 X7.439 Z-50.459
N10523 X119.003
N10524 X119.01 Z-10.724
N10525 X119.104 Z-9.653
N10526 X119.308 Z-8.571
N10527 X119.598 Z-7.568
N10528 X119.947 Z-6.674
N10529 X120.179 Z-6.185
N10530 X120.644 Z-5.343
N10531 X121.109 Z-4.641
N10532 X121.807 Z-3.769
N10533 X122.272 Z-3.278
N10534 X122.736 Z-2.837
N10535 X123.201 Z-2.444
N10536 X123.666 Z-2.094
N10537 X124.131 Z-1.776
N10538 X125.061 Z-1.24
N10539 X125.526 Z-1.015
N10540 X126.456 Z-.638
N10541 X127.386 Z-.354
N10542 X128.315 Z-.156
N10543 X129.245 Z-.039
N10544 X130.175 Z0.
N10545 Y4.175
N10546 X129.245 Z-.039
N10547 X128.315 Z-.156
N10548 X127.386 Z-.354
N10549 X126.456 Z-.638
N10550 X125.526 Z-1.015
N10551 X125.061 Z-1.24
N10552 X124.131 Z-1.776
N10553 X123.666 Z-2.094
N10554 X123.201 Z-2.444
N10555 X122.736 Z-2.837
N10556 X122.272 Z-3.278
N10557 X121.807 Z-3.769
N10558 X121.109 Z-4.641
N10559 X120.644 Z-5.343
N10560 X120.179 Z-6.185
N10561 X119.947 Z-6.674
N10562 X119.598 Z-7.568
N10563 X119.308 Z-8.571
N10564 X119.104 Z-9.653
N10565 X119.01 Z-10.724
N10566 X119.003 Z-50.593
N10567 X4.649 Z-50.596
N10568 X1.839 Z-50.76
N10569 X0. Z-50.8
N10570 X-1.839 Z-50.76
N10571 X-4.649 Z-50.596
N10572 X-119.003 Z-50.593
N10573 X-119.017 Z-10.557
N10574 X-119.133 Z-9.454
N10575 X-119.366 Z-8.342
N10576 X-119.598 Z-7.568
N10577 X-119.947 Z-6.674
N10578 X-120.412 Z-5.739
N10579 X-120.877 Z-4.981
N10580 X-121.342 Z-4.335
N10581 X-121.807 Z-3.769
N10582 X-122.272 Z-3.278
N10583 X-122.736 Z-2.837
N10584 X-123.201 Z-2.444
N10585 X-123.666 Z-2.094
N10586 X-124.131 Z-1.776
N10587 X-125.061 Z-1.24
N10588 X-125.526 Z-1.015
N10589 X-126.456 Z-.638
N10590 X-127.386 Z-.354
N10591 X-128.315 Z-.156
N10592 X-129.245 Z-.039
N10593 X-130.175 Z0.
N10594 Y2.975
N10595 X-129.245 Z-.039
N10596 X-128.315 Z-.156
N10597 X-127.386 Z-.354
N10598 X-126.456 Z-.638
N10599 X-125.526 Z-1.015
N10600 X-125.061 Z-1.24
N10601 X-124.131 Z-1.776
N10602 X-123.666 Z-2.094
N10603 X-123.201 Z-2.444
N10604 X-122.736 Z-2.837
N10605 X-122.272 Z-3.278
N10606 X-121.807 Z-3.769
N10607 X-121.342 Z-4.335
N10608 X-120.877 Z-4.981
N10609 X-120.412 Z-5.739
N10610 X-119.947 Z-6.674
N10611 X-119.598 Z-7.568
N10612 X-119.366 Z-8.342
N10613 X-119.133 Z-9.454
N10614 X-119.017 Z-10.557
N10615 X-119.003 Z-50.694
N10616 X-3.719
N10617 X0. Z-50.8
N10618 X3.719 Z-50.694
N10619 X119.003
N10620 X119.01 Z-10.724
N10621 X119.104 Z-9.653
N10622 X119.308 Z-8.571
N10623 X119.598 Z-7.568
N10624 X119.947 Z-6.674
N10625 X120.179 Z-6.185
N10626 X120.644 Z-5.343
N10627 X121.109 Z-4.641
N10628 X121.807 Z-3.769
N10629 X122.272 Z-3.278
N10630 X122.736 Z-2.837
N10631 X123.201 Z-2.444
N10632 X123.666 Z-2.094
N10633 X124.131 Z-1.776
N10634 X125.061 Z-1.24
N10635 X125.526 Z-1.015
N10636 X126.456 Z-.638
N10637 X127.386 Z-.354
N10638 X128.315 Z-.156
N10639 X129.245 Z-.039
N10640 X130.175 Z0.
N10641 Y1.775
N10642 X129.245 Z-.039
N10643 X128.315 Z-.156
N10644 X127.386 Z-.354
N10645 X126.456 Z-.638
N10646 X125.526 Z-1.015
N10647 X125.061 Z-1.24
N10648 X124.131 Z-1.776
N10649 X123.666 Z-2.094
N10650 X123.201 Z-2.444
N10651 X122.736 Z-2.837
N10652 X122.272 Z-3.278
N10653 X121.807 Z-3.769
N10654 X121.109 Z-4.641
N10655 X120.644 Z-5.343
N10656 X120.179 Z-6.185
N10657 X119.947 Z-6.674
N10658 X119.598 Z-7.568
N10659 X119.308 Z-8.571
N10660 X119.104 Z-9.653
N10661 X119.01 Z-10.724
N10662 X119.003 Z-50.762
N10663 X1.86 Z-50.763
N10664 X0. Z-50.8
N10665 X-1.86 Z-50.763
N10666 X-119.003 Z-50.762
N10667 X-119.017 Z-10.557
N10668 X-119.133 Z-9.454
N10669 X-119.366 Z-8.342
N10670 X-119.598 Z-7.568
N10671 X-119.947 Z-6.674
N10672 X-120.412 Z-5.739
N10673 X-120.877 Z-4.981
N10674 X-121.342 Z-4.335
N10675 X-121.807 Z-3.769
N10676 X-122.272 Z-3.278
N10677 X-122.736 Z-2.837
N10678 X-123.201 Z-2.444
N10679 X-123.666 Z-2.094
N10680 X-124.131 Z-1.776
N10681 X-125.061 Z-1.24
N10682 X-125.526 Z-1.015
N10683 X-126.456 Z-.638
N10684 X-127.386 Z-.354
N10685 X-128.315 Z-.156
N10686 X-129.245 Z-.039
N10687 X-130.175 Z0.
N10688 Y.575
N10689 X-129.245 Z-.039
N10690 X-128.315 Z-.156
N10691 X-127.386 Z-.354
N10692 X-126.456 Z-.638
N10693 X-125.526 Z-1.015
N10694 X-125.061 Z-1.24
N10695 X-124.131 Z-1.776
N10696 X-123.666 Z-2.094
N10697 X-123.201 Z-2.444
N10698 X-122.736 Z-2.837
N10699 X-122.272 Z-3.278
N10700 X-121.807 Z-3.769
N10701 X-121.342 Z-4.335
N10702 X-120.877 Z-4.981
N10703 X-120.412 Z-5.739
N10704 X-119.947 Z-6.674
N10705 X-119.598 Z-7.568
N10706 X-119.366 Z-8.342
N10707 X-119.133 Z-9.454
N10708 X-119.017 Z-10.557
N10709 X-119.003 Z-50.793
N10710 X119.003
N10711 X119.01 Z-10.724
N10712 X119.104 Z-9.653
N10713 X119.308 Z-8.571
N10714 X119.598 Z-7.568
N10715 X119.947 Z-6.674
N10716 X120.179 Z-6.185
N10717 X120.644 Z-5.343
N10718 X121.109 Z-4.641
N10719 X121.807 Z-3.769
N10720 X122.272 Z-3.278
N10721 X122.736 Z-2.837
N10722 X123.201 Z-2.444
N10723 X123.666 Z-2.094
N10724 X124.131 Z-1.776
N10725 X125.061 Z-1.24
N10726 X125.526 Z-1.015
N10727 X126.456 Z-.638
N10728 X127.386 Z-.354
N10729 X128.315 Z-.156
N10730 X129.245 Z-.039
N10731 X130.175 Z0.
N10732 Y-.625
N10733 X129.245 Z-.039
N10734 X128.315 Z-.156
N10735 X127.386 Z-.354
N10736 X126.456 Z-.638
N10737 X125.526 Z-1.015
N10738 X125.061 Z-1.24
N10739 X124.131 Z-1.776
N10740 X123.666 Z-2.094
N10741 X123.201 Z-2.444
N10742 X122.736 Z-2.837
N10743 X122.272 Z-3.278
N10744 X121.807 Z-3.769
N10745 X121.109 Z-4.641
N10746 X120.644 Z-5.343
N10747 X120.179 Z-6.185
N10748 X119.947 Z-6.674
N10749 X119.598 Z-7.568
N10750 X119.308 Z-8.571
N10751 X119.104 Z-9.653
N10752 X119.01 Z-10.724
N10753 X119.003 Z-50.793
N10754 X-119.003
N10755 X-119.017 Z-10.557
N10756 X-119.133 Z-9.454
N10757 X-119.366 Z-8.342
N10758 X-119.598 Z-7.568
N10759 X-119.947 Z-6.674
N10760 X-120.412 Z-5.739
N10761 X-120.877 Z-4.981
N10762 X-121.342 Z-4.335
N10763 X-121.807 Z-3.769
N10764 X-122.272 Z-3.278
N10765 X-122.736 Z-2.837
N10766 X-123.201 Z-2.444
N10767 X-123.666 Z-2.094
N10768 X-124.131 Z-1.776
N10769 X-125.061 Z-1.24
N10770 X-125.526 Z-1.015
N10771 X-126.456 Z-.638
N10772 X-127.386 Z-.354
N10773 X-128.315 Z-.156
N10774 X-129.245 Z-.039
N10775 X-130.175 Z0.
N10776 Y-1.825
N10777 X-129.245 Z-.039
N10778 X-128.315 Z-.156
N10779 X-127.386 Z-.354
N10780 X-126.456 Z-.638
N10781 X-125.526 Z-1.015
N10782 X-125.061 Z-1.24
N10783 X-124.131 Z-1.776
N10784 X-123.666 Z-2.094
N10785 X-123.201 Z-2.444
N10786 X-122.736 Z-2.837
N10787 X-122.272 Z-3.278
N10788 X-121.807 Z-3.769
N10789 X-121.342 Z-4.335
N10790 X-120.877 Z-4.981
N10791 X-120.412 Z-5.739
N10792 X-119.947 Z-6.674
N10793 X-119.598 Z-7.568
N10794 X-119.366 Z-8.342
N10795 X-119.133 Z-9.454
N10796 X-119.017 Z-10.557
N10797 X-119.003 Z-50.761
N10798 X-1.86 Z-50.762
N10799 X0. Z-50.8
N10800 X1.86 Z-50.762
N10801 X119.003 Z-50.761
N10802 X119.01 Z-10.724
N10803 X119.104 Z-9.653
N10804 X119.308 Z-8.571
N10805 X119.598 Z-7.568
N10806 X119.947 Z-6.674
N10807 X120.179 Z-6.185
N10808 X120.644 Z-5.343
N10809 X121.109 Z-4.641
N10810 X121.807 Z-3.769
N10811 X122.272 Z-3.278
N10812 X122.736 Z-2.837
N10813 X123.201 Z-2.444
N10814 X123.666 Z-2.094
N10815 X124.131 Z-1.776
N10816 X125.061 Z-1.24
N10817 X125.526 Z-1.015
N10818 X126.456 Z-.638
N10819 X127.386 Z-.354
N10820 X128.315 Z-.156
N10821 X129.245 Z-.039
N10822 X130.175 Z0.
N10823 Y-3.025
N10824 X129.245 Z-.039
N10825 X128.315 Z-.156
N10826 X127.386 Z-.354
N10827 X126.456 Z-.638
N10828 X125.526 Z-1.015
N10829 X125.061 Z-1.24
N10830 X124.131 Z-1.776
N10831 X123.666 Z-2.094
N10832 X123.201 Z-2.444
N10833 X122.736 Z-2.837
N10834 X122.272 Z-3.278
N10835 X121.807 Z-3.769
N10836 X121.109 Z-4.641
N10837 X120.644 Z-5.343
N10838 X120.179 Z-6.185
N10839 X119.947 Z-6.674
N10840 X119.598 Z-7.568
N10841 X119.308 Z-8.571
N10842 X119.104 Z-9.653
N10843 X119.01 Z-10.724
N10844 X119.003 Z-50.69
N10845 X3.719
N10846 X2.789 Z-50.71
N10847 X1.86 Z-50.759
N10848 X0. Z-50.8
N10849 X-1.86 Z-50.759
N10850 X-2.789 Z-50.71
N10851 X-3.719 Z-50.69
N10852 X-119.003
N10853 X-119.017 Z-10.557
N10854 X-119.133 Z-9.454
N10855 X-119.366 Z-8.342
N10856 X-119.598 Z-7.568
N10857 X-119.947 Z-6.674
N10858 X-120.412 Z-5.739
N10859 X-120.877 Z-4.981
N10860 X-121.342 Z-4.335
N10861 X-121.807 Z-3.769
N10862 X-122.272 Z-3.278
N10863 X-122.736 Z-2.837
N10864 X-123.201 Z-2.444
N10865 X-123.666 Z-2.094
N10866 X-124.131 Z-1.776
N10867 X-125.061 Z-1.24
N10868 X-125.526 Z-1.015
N10869 X-126.456 Z-.638
N10870 X-127.386 Z-.354
N10871 X-128.315 Z-.156
N10872 X-129.245 Z-.039
N10873 X-130.175 Z0.
N10874 Y-4.225
N10875 X-129.245 Z-.039
N10876 X-128.315 Z-.156
N10877 X-127.386 Z-.354
N10878 X-126.456 Z-.638
N10879 X-125.526 Z-1.015
N10880 X-125.061 Z-1.24
N10881 X-124.131 Z-1.776
N10882 X-123.666 Z-2.094
N10883 X-123.201 Z-2.444
N10884 X-122.736 Z-2.837
N10885 X-122.272 Z-3.278
N10886 X-121.807 Z-3.769
N10887 X-121.342 Z-4.335
N10888 X-120.877 Z-4.981
N10889 X-120.412 Z-5.739
N10890 X-119.947 Z-6.674
N10891 X-119.598 Z-7.568
N10892 X-119.366 Z-8.342
N10893 X-119.133 Z-9.454
N10894 X-119.017 Z-10.557
N10895 X-119.003 Z-50.588
N10896 X-4.649 Z-50.592
N10897 X-1.845 Z-50.76
N10898 X0. Z-50.8
N10899 X1.845 Z-50.76
N10900 X4.649 Z-50.592
N10901 X119.003 Z-50.588
N10902 X119.01 Z-10.724
N10903 X119.104 Z-9.653
N10904 X119.308 Z-8.571
N10905 X119.598 Z-7.568
N10906 X119.947 Z-6.674
N10907 X120.179 Z-6.185
N10908 X120.644 Z-5.343
N10909 X121.109 Z-4.641
N10910 X121.807 Z-3.769
N10911 X122.272 Z-3.278
N10912 X122.736 Z-2.837
N10913 X123.201 Z-2.444
N10914 X123.666 Z-2.094
N10915 X124.131 Z-1.776
N10916 X125.061 Z-1.24
N10917 X125.526 Z-1.015
N10918 X126.456 Z-.638
N10919 X127.386 Z-.354
N10920 X128.315 Z-.156
N10921 X129.245 Z-.039
N10922 X130.175 Z0.
N10923 Y-5.425
N10924 X129.245 Z-.039
N10925 X128.315 Z-.156
N10926 X127.386 Z-.354
N10927 X126.456 Z-.638
N10928 X125.526 Z-1.015
N10929 X125.061 Z-1.24
N10930 X124.131 Z-1.776
N10931 X123.666 Z-2.094
N10932 X123.201 Z-2.444
N10933 X122.736 Z-2.837
N10934 X122.272 Z-3.278
N10935 X121.807 Z-3.769
N10936 X121.109 Z-4.641
N10937 X120.644 Z-5.343
N10938 X120.179 Z-6.185
N10939 X119.947 Z-6.674
N10940 X119.598 Z-7.568
N10941 X119.308 Z-8.571
N10942 X119.104 Z-9.653
N10943 X119.01 Z-10.724
N10944 X119.003 Z-50.453
N10945 X7.439
N10946 X5.579 Z-50.473
N10947 X3.719 Z-50.637
N10948 X1.862 Z-50.759
N10949 X0. Z-50.8
N10950 X-1.862 Z-50.759
N10951 X-3.719 Z-50.637
N10952 X-5.579 Z-50.473
N10953 X-7.439 Z-50.453
N10954 X-119.003
N10955 X-119.017 Z-10.557
N10956 X-119.133 Z-9.454
N10957 X-119.366 Z-8.342
N10958 X-119.598 Z-7.568
N10959 X-119.947 Z-6.674
N10960 X-120.412 Z-5.739
N10961 X-120.877 Z-4.981
N10962 X-121.342 Z-4.335
N10963 X-121.807 Z-3.769
N10964 X-122.272 Z-3.278
N10965 X-122.736 Z-2.837
N10966 X-123.201 Z-2.444
N10967 X-123.666 Z-2.094
N10968 X-124.131 Z-1.776
N10969 X-125.061 Z-1.24
N10970 X-125.526 Z-1.015
N10971 X-126.456 Z-.638
N10972 X-127.386 Z-.354
N10973 X-128.315 Z-.156
N10974 X-129.245 Z-.039
N10975 X-130.175 Z0.
N10976 Y-6.625
N10977 X-129.245 Z-.039
N10978 X-128.315 Z-.156
N10979 X-127.386 Z-.354
N10980 X-126.456 Z-.638
N10981 X-125.526 Z-1.015
N10982 X-125.061 Z-1.24
N10983 X-124.131 Z-1.776
N10984 X-123.666 Z-2.094
N10985 X-123.201 Z-2.444
N10986 X-122.736 Z-2.837
N10987 X-122.272 Z-3.278
N10988 X-121.807 Z-3.769
N10989 X-121.342 Z-4.335
N10990 X-120.877 Z-4.981
N10991 X-120.412 Z-5.739
N10992 X-119.947 Z-6.674
N10993 X-119.598 Z-7.568
N10994 X-119.366 Z-8.342
N10995 X-119.133 Z-9.454
N10996 X-119.017 Z-10.557
N10997 X-119.003 Z-50.282
N10998 X-7.439 Z-50.288
N10999 X-6.509 Z-50.334
N11000 X-3.719 Z-50.637
N11001 X-1.862 Z-50.759
N11002 X0. Z-50.8
N11003 X1.862 Z-50.759
N11004 X3.719 Z-50.637
N11005 X6.509 Z-50.334
N11006 X7.439 Z-50.288
N11007 X119.003 Z-50.282
N11008 X119.01 Z-10.724
N11009 X119.104 Z-9.653
N11010 X119.308 Z-8.571
N11011 X119.598 Z-7.568
N11012 X119.947 Z-6.674
N11013 X120.179 Z-6.185
N11014 X120.644 Z-5.343
N11015 X121.109 Z-4.641
N11016 X121.807 Z-3.769
N11017 X122.272 Z-3.278
N11018 X122.736 Z-2.837
N11019 X123.201 Z-2.444
N11020 X123.666 Z-2.094
N11021 X124.131 Z-1.776
N11022 X125.061 Z-1.24
N11023 X125.526 Z-1.015
N11024 X126.456 Z-.638
N11025 X127.386 Z-.354
N11026 X128.315 Z-.156
N11027 X129.245 Z-.039
N11028 X130.175 Z0.
N11029 Y-7.825
N11030 X129.245 Z-.039
N11031 X128.315 Z-.156
N11032 X127.386 Z-.354
N11033 X126.456 Z-.638
N11034 X125.526 Z-1.015
N11035 X125.061 Z-1.24
N11036 X124.131 Z-1.776
N11037 X123.666 Z-2.094
N11038 X123.201 Z-2.444
N11039 X122.736 Z-2.837
N11040 X122.272 Z-3.278
N11041 X121.807 Z-3.769
N11042 X121.109 Z-4.641
N11043 X120.644 Z-5.343
N11044 X120.179 Z-6.185
N11045 X119.947 Z-6.674
N11046 X119.598 Z-7.568
N11047 X119.308 Z-8.571
N11048 X119.104 Z-9.653
N11049 X119.01 Z-10.724
N11050 X119.003 Z-50.075
N11051 X9.298
N11052 X8.368 Z-50.102
N11053 X7.439 Z-50.175
N11054 X4.898 Z-50.516
N11055 X3.719 Z-50.637
N11056 X1.862 Z-50.759
N11057 X0. Z-50.8
N11058 X-1.862 Z-50.759
N11059 X-3.719 Z-50.637
N11060 X-4.898 Z-50.516
N11061 X-7.439 Z-50.175
N11062 X-8.368 Z-50.102
N11063 X-9.298 Z-50.075
N11064 X-119.003
N11065 X-119.017 Z-10.557
N11066 X-119.133 Z-9.454
N11067 X-119.366 Z-8.342
N11068 X-119.598 Z-7.568
N11069 X-119.947 Z-6.674
N11070 X-120.412 Z-5.739
N11071 X-120.877 Z-4.981
N11072 X-121.342 Z-4.335
N11073 X-121.807 Z-3.769
N11074 X-122.272 Z-3.278
N11075 X-122.736 Z-2.837
N11076 X-123.201 Z-2.444
N11077 X-123.666 Z-2.094
N11078 X-124.131 Z-1.776
N11079 X-125.061 Z-1.24
N11080 X-125.526 Z-1.015
N11081 X-126.456 Z-.638
N11082 X-127.386 Z-.354
N11083 X-128.315 Z-.156
N11084 X-129.245 Z-.039
N11085 X-130.175 Z0.
N11086 Y-9.025
N11087 X-129.245 Z-.039
N11088 X-128.315 Z-.156
N11089 X-127.386 Z-.354
N11090 X-126.456 Z-.638
N11091 X-125.526 Z-1.015
N11092 X-125.061 Z-1.24
N11093 X-124.131 Z-1.776
N11094 X-123.666 Z-2.094
N11095 X-123.201 Z-2.444
N11096 X-122.736 Z-2.837
N11097 X-122.272 Z-3.278
N11098 X-121.807 Z-3.769
N11099 X-121.342 Z-4.335
N11100 X-120.877 Z-4.981
N11101 X-120.412 Z-5.739
N11102 X-119.947 Z-6.674
N11103 X-119.598 Z-7.568
N11104 X-119.366 Z-8.342
N11105 X-119.133 Z-9.454
N11106 X-119.017 Z-10.557
N11107 X-119.003 Z-49.834
N11108 X-10.228 Z-49.841
N11109 X-9.298 Z-49.896
N11110 X-8.368 Z-49.995
N11111 X-5.589 Z-50.433
N11112 X-3.719 Z-50.637
N11113 X-1.862 Z-50.759
N11114 X0. Z-50.8
N11115 X1.862 Z-50.759
N11116 X3.719 Z-50.637
N11117 X5.589 Z-50.433
N11118 X8.368 Z-49.995
N11119 X9.298 Z-49.896
N11120 X10.228 Z-49.841
N11121 X119.003 Z-49.834
N11122 X119.01 Z-10.724
N11123 X119.104 Z-9.653
N11124 X119.308 Z-8.571
N11125 X119.598 Z-7.568
N11126 X119.947 Z-6.674
N11127 X120.179 Z-6.185
N11128 X120.644 Z-5.343
N11129 X121.109 Z-4.641
N11130 X121.807 Z-3.769
N11131 X122.272 Z-3.278
N11132 X122.736 Z-2.837
N11133 X123.201 Z-2.444
N11134 X123.666 Z-2.094
N11135 X124.131 Z-1.776
N11136 X125.061 Z-1.24
N11137 X125.526 Z-1.015
N11138 X126.456 Z-.638
N11139 X127.386 Z-.354
N11140 X128.315 Z-.156
N11141 X129.245 Z-.039
N11142 X130.175 Z0.
N11143 Y-10.225
N11144 X129.245 Z-.039
N11145 X128.315 Z-.156
N11146 X127.386 Z-.354
N11147 X126.456 Z-.638
N11148 X125.526 Z-1.015
N11149 X125.061 Z-1.24
N11150 X124.131 Z-1.776
N11151 X123.666 Z-2.094
N11152 X123.201 Z-2.444
N11153 X122.736 Z-2.837
N11154 X122.272 Z-3.278
N11155 X121.807 Z-3.769
N11156 X121.109 Z-4.641
N11157 X120.644 Z-5.343
N11158 X120.179 Z-6.185
N11159 X119.947 Z-6.674
N11160 X119.598 Z-7.568
N11161 X119.308 Z-8.571
N11162 X119.104 Z-9.653
N11163 X119.01 Z-10.724
N11164 X119.003 Z-49.559
N11165 X12.088
N11166 X11.158 Z-49.586
N11167 X10.228 Z-49.668
N11168 X9.298 Z-49.794
N11169 X7.439 Z-50.148
N11170 X5.579 Z-50.434
N11171 X3.719 Z-50.637
N11172 X1.862 Z-50.759
N11173 X0. Z-50.8
N11174 X-1.862 Z-50.759
N11175 X-3.719 Z-50.637
N11176 X-5.579 Z-50.434
N11177 X-7.439 Z-50.148
N11178 X-9.298 Z-49.794
N11179 X-10.228 Z-49.668
N11180 X-11.158 Z-49.586
N11181 X-12.088 Z-49.559
N11182 X-119.003
N11183 X-119.017 Z-10.557
N11184 X-119.133 Z-9.454
N11185 X-119.366 Z-8.342
N11186 X-119.598 Z-7.568
N11187 X-119.947 Z-6.674
N11188 X-120.412 Z-5.739
N11189 X-120.877 Z-4.981
N11190 X-121.342 Z-4.335
N11191 X-121.807 Z-3.769
N11192 X-122.272 Z-3.278
N11193 X-122.736 Z-2.837
N11194 X-123.201 Z-2.444
N11195 X-123.666 Z-2.094
N11196 X-124.131 Z-1.776
N11197 X-125.061 Z-1.24
N11198 X-125.526 Z-1.015
N11199 X-126.456 Z-.638
N11200 X-127.386 Z-.354
N11201 X-128.315 Z-.156
N11202 X-129.245 Z-.039
N11203 X-130.175 Z0.
N11204 Y-11.425
N11205 X-129.245 Z-.039
N11206 X-128.315 Z-.156
N11207 X-127.386 Z-.354
N11208 X-126.456 Z-.638
N11209 X-125.526 Z-1.015
N11210 X-125.061 Z-1.24
N11211 X-124.131 Z-1.776
N11212 X-123.666 Z-2.094
N11213 X-123.201 Z-2.444
N11214 X-122.736 Z-2.837
N11215 X-122.272 Z-3.278
N11216 X-121.807 Z-3.769
N11217 X-121.342 Z-4.335
N11218 X-120.877 Z-4.981
N11219 X-120.412 Z-5.739
N11220 X-119.947 Z-6.674
N11221 X-119.598 Z-7.568
N11222 X-119.366 Z-8.342
N11223 X-119.133 Z-9.454
N11224 X-119.017 Z-10.557
N11225 X-119.003 Z-49.245
N11226 X-13.017 Z-49.254
N11227 X-12.088 Z-49.309
N11228 X-11.158 Z-49.418
N11229 X-9.933 Z-49.632
N11230 X-8.708 Z-49.902
N11231 X-7.478 Z-50.141
N11232 X-6.259 Z-50.337
N11233 X-5.082 Z-50.494
N11234 X-3.719 Z-50.637
N11235 X-1.862 Z-50.759
N11236 X0. Z-50.8
N11237 X1.862 Z-50.759
N11238 X3.719 Z-50.637
N11239 X5.082 Z-50.494
N11240 X6.259 Z-50.337
N11241 X7.478 Z-50.141
N11242 X8.708 Z-49.902
N11243 X9.933 Z-49.632
N11244 X11.158 Z-49.418
N11245 X12.088 Z-49.309
N11246 X13.017 Z-49.254
N11247 X119.003 Z-49.245
N11248 X119.01 Z-10.724
N11249 X119.104 Z-9.653
N11250 X119.308 Z-8.571
N11251 X119.598 Z-7.568
N11252 X119.947 Z-6.674
N11253 X120.179 Z-6.185
N11254 X120.644 Z-5.343
N11255 X121.109 Z-4.641
N11256 X121.807 Z-3.769
N11257 X122.272 Z-3.278
N11258 X122.736 Z-2.837
N11259 X123.201 Z-2.444
N11260 X123.666 Z-2.094
N11261 X124.131 Z-1.776
N11262 X125.061 Z-1.24
N11263 X125.526 Z-1.015
N11264 X126.456 Z-.638
N11265 X127.386 Z-.354
N11266 X128.315 Z-.156
N11267 X129.245 Z-.039
N11268 X130.175 Z0.
N11269 Y-12.625
N11270 X129.245 Z-.039
N11271 X128.315 Z-.156
N11272 X127.386 Z-.354
N11273 X126.456 Z-.638
N11274 X125.526 Z-1.015
N11275 X125.061 Z-1.24
N11276 X124.131 Z-1.776
N11277 X123.666 Z-2.094
N11278 X123.201 Z-2.444
N11279 X122.736 Z-2.837
N11280 X122.272 Z-3.278
N11281 X121.807 Z-3.769
N11282 X121.109 Z-4.641
N11283 X120.644 Z-5.343
N11284 X120.179 Z-6.185
N11285 X119.947 Z-6.674
N11286 X119.598 Z-7.568
N11287 X119.308 Z-8.571
N11288 X119.104 Z-9.653
N11289 X119.01 Z-10.724
N11290 X119.003 Z-48.892
N11291 X14.877 Z-48.893
N11292 X13.947 Z-48.927
N11293 X13.017 Z-49.009
N11294 X12.088 Z-49.146
N11295 X11.158 Z-49.328
N11296 X9.074 Z-49.824
N11297 X7.348 Z-50.163
N11298 X5.506 Z-50.443
N11299 X3.719 Z-50.637
N11300 X1.862 Z-50.759
N11301 X0. Z-50.8
N11302 X-1.862 Z-50.759
N11303 X-3.719 Z-50.637
N11304 X-5.506 Z-50.443
N11305 X-7.348 Z-50.163
N11306 X-9.074 Z-49.824
N11307 X-11.158 Z-49.328
N11308 X-12.088 Z-49.146
N11309 X-13.017 Z-49.009
N11310 X-13.947 Z-48.927
N11311 X-14.877 Z-48.893
N11312 X-119.003 Z-48.892
N11313 X-119.017 Z-10.557
N11314 X-119.133 Z-9.454
N11315 X-119.366 Z-8.342
N11316 X-119.598 Z-7.568
N11317 X-119.947 Z-6.674
N11318 X-120.412 Z-5.739
N11319 X-120.877 Z-4.981
N11320 X-121.342 Z-4.335
N11321 X-121.807 Z-3.769
N11322 X-122.272 Z-3.278
N11323 X-122.736 Z-2.837
N11324 X-123.201 Z-2.444
N11325 X-123.666 Z-2.094
N11326 X-124.131 Z-1.776
N11327 X-125.061 Z-1.24
N11328 X-125.526 Z-1.015
N11329 X-126.456 Z-.638
N11330 X-127.386 Z-.354
N11331 X-128.315 Z-.156
N11332 X-129.245 Z-.039
N11333 X-130.175 Z0.
N11334 Y-13.825
N11335 X-129.245 Z-.039
N11336 X-128.315 Z-.156
N11337 X-127.386 Z-.354
N11338 X-126.456 Z-.638
N11339 X-125.526 Z-1.015
N11340 X-125.061 Z-1.24
N11341 X-124.131 Z-1.776
N11342 X-123.666 Z-2.094
N11343 X-123.201 Z-2.444
N11344 X-122.736 Z-2.837
N11345 X-122.272 Z-3.278
N11346 X-121.807 Z-3.769
N11347 X-121.342 Z-4.335
N11348 X-120.877 Z-4.981
N11349 X-120.412 Z-5.739
N11350 X-119.947 Z-6.674
N11351 X-119.598 Z-7.568
N11352 X-119.366 Z-8.342
N11353 X-119.133 Z-9.454
N11354 X-119.017 Z-10.557
N11355 X-119.003 Z-48.502
N11356 X-15.807 Z-48.514
N11357 X-14.877 Z-48.577
N11358 X-13.947 Z-48.687
N11359 X-13.017 Z-48.852
N11360 X-12.088 Z-49.063
N11361 X-11.158 Z-49.318
N11362 X-9.273 Z-49.782
N11363 X-7.422 Z-50.151
N11364 X-5.554 Z-50.437
N11365 X-3.719 Z-50.637
N11366 X-1.862 Z-50.759
N11367 X0. Z-50.8
N11368 X1.862 Z-50.759
N11369 X3.719 Z-50.637
N11370 X5.554 Z-50.437
N11371 X7.422 Z-50.151
N11372 X9.273 Z-49.782
N11373 X11.158 Z-49.318
N11374 X12.088 Z-49.063
N11375 X13.017 Z-48.852
N11376 X13.947 Z-48.687
N11377 X14.877 Z-48.577
N11378 X15.807 Z-48.514
N11379 X119.003 Z-48.502
N11380 X119.01 Z-10.724
N11381 X119.104 Z-9.653
N11382 X119.308 Z-8.571
N11383 X119.598 Z-7.568
N11384 X119.947 Z-6.674
N11385 X120.179 Z-6.185
N11386 X120.644 Z-5.343
N11387 X121.109 Z-4.641
N11388 X121.807 Z-3.769
N11389 X122.272 Z-3.278
N11390 X122.736 Z-2.837
N11391 X123.201 Z-2.444
N11392 X123.666 Z-2.094
N11393 X124.131 Z-1.776
N11394 X125.061 Z-1.24
N11395 X125.526 Z-1.015
N11396 X126.456 Z-.638
N11397 X127.386 Z-.354
N11398 X128.315 Z-.156
N11399 X129.245 Z-.039
N11400 X130.175 Z0.
N11401 Y-15.025
N11402 X129.245 Z-.039
N11403 X128.315 Z-.156
N11404 X127.386 Z-.354
N11405 X126.456 Z-.638
N11406 X125.526 Z-1.015
N11407 X125.061 Z-1.24
N11408 X124.131 Z-1.776
N11409 X123.666 Z-2.094
N11410 X123.201 Z-2.444
N11411 X122.736 Z-2.837
N11412 X122.272 Z-3.278
N11413 X121.807 Z-3.769
N11414 X121.109 Z-4.641
N11415 X120.644 Z-5.343
N11416 X120.179 Z-6.185
N11417 X119.947 Z-6.674
N11418 X119.598 Z-7.568
N11419 X119.308 Z-8.571
N11420 X119.104 Z-9.653
N11421 X119.01 Z-10.724
N11422 X119.003 Z-48.074
N11423 X17.667 Z-48.075
N11424 X16.737 Z-48.111
N11425 X15.807 Z-48.204
N11426 X14.877 Z-48.342
N11427 X13.947 Z-48.535
N11428 X13.017 Z-48.775
N11429 X11.158 Z-49.318
N11430 X9.273 Z-49.782
N11431 X7.422 Z-50.151
N11432 X5.554 Z-50.437
N11433 X3.719 Z-50.637
N11434 X1.862 Z-50.759
N11435 X0. Z-50.8
N11436 X-1.862 Z-50.759
N11437 X-3.719 Z-50.637
N11438 X-5.554 Z-50.437
N11439 X-7.422 Z-50.151
N11440 X-9.273 Z-49.782
N11441 X-11.158 Z-49.318
N11442 X-13.017 Z-48.775
N11443 X-13.947 Z-48.535
N11444 X-14.877 Z-48.342
N11445 X-15.807 Z-48.204
N11446 X-16.737 Z-48.111
N11447 X-17.667 Z-48.075
N11448 X-119.003 Z-48.074
N11449 X-119.017 Z-10.557
N11450 X-119.133 Z-9.454
N11451 X-119.366 Z-8.342
N11452 X-119.598 Z-7.568
N11453 X-119.947 Z-6.674
N11454 X-120.412 Z-5.739
N11455 X-120.877 Z-4.981
N11456 X-121.342 Z-4.335
N11457 X-121.807 Z-3.769
N11458 X-122.272 Z-3.278
N11459 X-122.736 Z-2.837
N11460 X-123.201 Z-2.444
N11461 X-123.666 Z-2.094
N11462 X-124.131 Z-1.776
N11463 X-125.061 Z-1.24
N11464 X-125.526 Z-1.015
N11465 X-126.456 Z-.638
N11466 X-127.386 Z-.354
N11467 X-128.315 Z-.156
N11468 X-129.245 Z-.039
N11469 X-130.175 Z0.
N11470 Y-16.225
N11471 X-129.245 Z-.039
N11472 X-128.315 Z-.156
N11473 X-127.386 Z-.354
N11474 X-126.456 Z-.638
N11475 X-125.526 Z-1.015
N11476 X-125.061 Z-1.24
N11477 X-124.131 Z-1.776
N11478 X-123.666 Z-2.094
N11479 X-123.201 Z-2.444
N11480 X-122.736 Z-2.837
N11481 X-122.272 Z-3.278
N11482 X-121.807 Z-3.769
N11483 X-121.342 Z-4.335
N11484 X-120.877 Z-4.981
N11485 X-120.412 Z-5.739
N11486 X-119.947 Z-6.674
N11487 X-119.598 Z-7.568
N11488 X-119.366 Z-8.342
N11489 X-119.133 Z-9.454
N11490 X-119.017 Z-10.557
N11491 X-119.003 Z-47.603
N11492 X-18.596 Z-47.618
N11493 X-17.667 Z-47.683
N11494 X-16.737 Z-47.806
N11495 X-15.807 Z-47.972
N11496 X-14.877 Z-48.194
N11497 X-13.947 Z-48.464
N11498 X-13.017 Z-48.77
N11499 X-11.158 Z-49.318
N11500 X-9.273 Z-49.782
N11501 X-7.422 Z-50.151
N11502 X-5.554 Z-50.437
N11503 X-3.719 Z-50.637
N11504 X-1.862 Z-50.759
N11505 X0. Z-50.8
N11506 X1.862 Z-50.759
N11507 X3.719 Z-50.637
N11508 X5.554 Z-50.437
N11509 X7.422 Z-50.151
N11510 X9.273 Z-49.782
N11511 X11.158 Z-49.318
N11512 X13.017 Z-48.77
N11513 X13.947 Z-48.464
N11514 X14.877 Z-48.194
N11515 X15.807 Z-47.972
N11516 X16.737 Z-47.806
N11517 X17.667 Z-47.683
N11518 X18.596 Z-47.618
N11519 X26.035 Z-47.603
N11520 X119.003
N11521 X119.01 Z-10.724
N11522 X119.104 Z-9.653
N11523 X119.308 Z-8.571
N11524 X119.598 Z-7.568
N11525 X119.947 Z-6.674
N11526 X120.179 Z-6.185
N11527 X120.644 Z-5.343
N11528 X121.109 Z-4.641
N11529 X121.807 Z-3.769
N11530 X122.272 Z-3.278
N11531 X122.736 Z-2.837
N11532 X123.201 Z-2.444
N11533 X123.666 Z-2.094
N11534 X124.131 Z-1.776
N11535 X125.061 Z-1.24
N11536 X125.526 Z-1.015
N11537 X126.456 Z-.638
N11538 X127.386 Z-.354
N11539 X128.315 Z-.156
N11540 X129.245 Z-.039
N11541 X130.175 Z0.
N11542 Y-17.425
N11543 X129.245 Z-.039
N11544 X128.315 Z-.156
N11545 X127.386 Z-.354
N11546 X126.456 Z-.638
N11547 X125.526 Z-1.015
N11548 X125.061 Z-1.24
N11549 X124.131 Z-1.776
N11550 X123.666 Z-2.094
N11551 X123.201 Z-2.444
N11552 X122.736 Z-2.837
N11553 X122.272 Z-3.278
N11554 X121.807 Z-3.769
N11555 X121.109 Z-4.641
N11556 X120.644 Z-5.343
N11557 X120.179 Z-6.185
N11558 X119.947 Z-6.674
N11559 X119.598 Z-7.568
N11560 X119.308 Z-8.571
N11561 X119.104 Z-9.653
N11562 X119.01 Z-10.724
N11563 X119.003 Z-47.088
N11564 X20.456 Z-47.09
N11565 X19.526 Z-47.135
N11566 X18.596 Z-47.23
N11567 X17.667 Z-47.381
N11568 X16.737 Z-47.578
N11569 X15.807 Z-47.83
N11570 X14.877 Z-48.129
N11571 X13.016 Z-48.771
N11572 X11.158 Z-49.318
N11573 X9.273 Z-49.782
N11574 X7.422 Z-50.151
N11575 X5.554 Z-50.437
N11576 X3.719 Z-50.637
N11577 X1.862 Z-50.759
N11578 X0. Z-50.8
N11579 X-1.862 Z-50.759
N11580 X-3.719 Z-50.637
N11581 X-5.554 Z-50.437
N11582 X-7.422 Z-50.151
N11583 X-9.273 Z-49.782
N11584 X-11.158 Z-49.318
N11585 X-13.016 Z-48.771
N11586 X-14.877 Z-48.129
N11587 X-15.807 Z-47.83
N11588 X-16.737 Z-47.578
N11589 X-17.667 Z-47.381
N11590 X-18.596 Z-47.23
N11591 X-19.526 Z-47.135
N11592 X-20.456 Z-47.09
N11593 X-119.003 Z-47.088
N11594 X-119.017 Z-10.557
N11595 X-119.133 Z-9.454
N11596 X-119.366 Z-8.342
N11597 X-119.598 Z-7.568
N11598 X-119.947 Z-6.674
N11599 X-120.412 Z-5.739
N11600 X-120.877 Z-4.981
N11601 X-121.342 Z-4.335
N11602 X-121.807 Z-3.769
N11603 X-122.272 Z-3.278
N11604 X-122.736 Z-2.837
N11605 X-123.201 Z-2.444
N11606 X-123.666 Z-2.094
N11607 X-124.131 Z-1.776
N11608 X-125.061 Z-1.24
N11609 X-125.526 Z-1.015
N11610 X-126.456 Z-.638
N11611 X-127.386 Z-.354
N11612 X-128.315 Z-.156
N11613 X-129.245 Z-.039
N11614 X-130.175 Z0.
N11615 Y-18.625
N11616 X-129.245 Z-.039
N11617 X-128.315 Z-.156
N11618 X-127.386 Z-.354
N11619 X-126.456 Z-.638
N11620 X-125.526 Z-1.015
N11621 X-125.061 Z-1.24
N11622 X-124.131 Z-1.776
N11623 X-123.666 Z-2.094
N11624 X-123.201 Z-2.444
N11625 X-122.736 Z-2.837
N11626 X-122.272 Z-3.278
N11627 X-121.807 Z-3.769
N11628 X-121.342 Z-4.335
N11629 X-120.877 Z-4.981
N11630 X-120.412 Z-5.739
N11631 X-119.947 Z-6.674
N11632 X-119.598 Z-7.568
N11633 X-119.366 Z-8.342
N11634 X-119.133 Z-9.454
N11635 X-119.017 Z-10.557
N11636 X-119.003 Z-46.532
N11637 X-22.316
N11638 X-21.386 Z-46.549
N11639 X-20.456 Z-46.626
N11640 X-19.526 Z-46.75
N11641 X-18.596 Z-46.931
N11642 X-17.667 Z-47.158
N11643 X-16.737 Z-47.44
N11644 X-14.877 Z-48.128
N11645 X-13.01 Z-48.772
N11646 X-11.158 Z-49.318
N11647 X-9.273 Z-49.782
N11648 X-7.422 Z-50.151
N11649 X-5.554 Z-50.437
N11650 X-3.719 Z-50.637
N11651 X-1.862 Z-50.759
N11652 X0. Z-50.8
N11653 X1.862 Z-50.759
N11654 X3.719 Z-50.637
N11655 X5.554 Z-50.437
N11656 X7.422 Z-50.151
N11657 X9.273 Z-49.782
N11658 X11.158 Z-49.318
N11659 X13.01 Z-48.772
N11660 X14.877 Z-48.128
N11661 X16.737 Z-47.44
N11662 X17.667 Z-47.158
N11663 X18.596 Z-46.931
N11664 X19.526 Z-46.75
N11665 X20.456 Z-46.626
N11666 X21.386 Z-46.549
N11667 X22.316 Z-46.532
N11668 X119.003
N11669 X119.01 Z-10.724
N11670 X119.104 Z-9.653
N11671 X119.308 Z-8.571
N11672 X119.598 Z-7.568
N11673 X119.947 Z-6.674
N11674 X120.179 Z-6.185
N11675 X120.644 Z-5.343
N11676 X121.109 Z-4.641
N11677 X121.807 Z-3.769
N11678 X122.272 Z-3.278
N11679 X122.736 Z-2.837
N11680 X123.201 Z-2.444
N11681 X123.666 Z-2.094
N11682 X124.131 Z-1.776
N11683 X125.061 Z-1.24
N11684 X125.526 Z-1.015
N11685 X126.456 Z-.638
N11686 X127.386 Z-.354
N11687 X128.315 Z-.156
N11688 X129.245 Z-.039
N11689 X130.175 Z0.
N11690 Y-19.825
N11691 X129.245 Z-.039
N11692 X128.315 Z-.156
N11693 X127.386 Z-.354
N11694 X126.456 Z-.638
N11695 X125.526 Z-1.015
N11696 X125.061 Z-1.24
N11697 X124.131 Z-1.776
N11698 X123.666 Z-2.094
N11699 X123.201 Z-2.444
N11700 X122.736 Z-2.837
N11701 X122.272 Z-3.278
N11702 X121.807 Z-3.769
N11703 X121.109 Z-4.641
N11704 X120.644 Z-5.343
N11705 X120.179 Z-6.185
N11706 X119.947 Z-6.674
N11707 X119.598 Z-7.568
N11708 X119.308 Z-8.571
N11709 X119.104 Z-9.653
N11710 X119.01 Z-10.724
N11711 X119.003 Z-45.93
N11712 X23.246 Z-45.933
N11713 X22.316 Z-45.979
N11714 X21.386 Z-46.087
N11715 X20.456 Z-46.243
N11716 X19.526 Z-46.454
N11717 X18.596 Z-46.713
N11718 X17.667 Z-47.025
N11719 X14.877 Z-48.128
N11720 X12.991 Z-48.778
N11721 X11.158 Z-49.318
N11722 X9.273 Z-49.782
N11723 X7.422 Z-50.151
N11724 X5.554 Z-50.437
N11725 X3.719 Z-50.637
N11726 X1.862 Z-50.759
N11727 X0. Z-50.8
N11728 X-1.862 Z-50.759
N11729 X-3.719 Z-50.637
N11730 X-5.554 Z-50.437
N11731 X-7.422 Z-50.151
N11732 X-9.273 Z-49.782
N11733 X-11.158 Z-49.318
N11734 X-12.991 Z-48.778
N11735 X-14.877 Z-48.128
N11736 X-17.667 Z-47.025
N11737 X-18.596 Z-46.713
N11738 X-19.526 Z-46.454
N11739 X-20.456 Z-46.243
N11740 X-21.386 Z-46.087
N11741 X-22.316 Z-45.979
N11742 X-23.246 Z-45.933
N11743 X-119.003 Z-45.93
N11744 X-119.017 Z-10.557
N11745 X-119.133 Z-9.454
N11746 X-119.366 Z-8.342
N11747 X-119.598 Z-7.568
N11748 X-119.947 Z-6.674
N11749 X-120.412 Z-5.739
N11750 X-120.877 Z-4.981
N11751 X-121.342 Z-4.335
N11752 X-121.807 Z-3.769
N11753 X-122.272 Z-3.278
N11754 X-122.736 Z-2.837
N11755 X-123.201 Z-2.444
N11756 X-123.666 Z-2.094
N11757 X-124.131 Z-1.776
N11758 X-125.061 Z-1.24
N11759 X-125.526 Z-1.015
N11760 X-126.456 Z-.638
N11761 X-127.386 Z-.354
N11762 X-128.315 Z-.156
N11763 X-129.245 Z-.039
N11764 X-130.175 Z0.
N11765 Y-21.025
N11766 X-129.245 Z-.039
N11767 X-128.315 Z-.156
N11768 X-127.386 Z-.354
N11769 X-126.456 Z-.638
N11770 X-125.526 Z-1.015
N11771 X-125.061 Z-1.24
N11772 X-124.131 Z-1.776
N11773 X-123.666 Z-2.094
N11774 X-123.201 Z-2.444
N11775 X-122.736 Z-2.837
N11776 X-122.272 Z-3.278
N11777 X-121.807 Z-3.769
N11778 X-121.342 Z-4.335
N11779 X-120.877 Z-4.981
N11780 X-120.412 Z-5.739
N11781 X-119.947 Z-6.674
N11782 X-119.598 Z-7.568
N11783 X-119.366 Z-8.342
N11784 X-119.133 Z-9.454
N11785 X-119.017 Z-10.557
N11786 X-119.003 Z-45.276
N11787 X-25.105
N11788 X-24.175 Z-45.302
N11789 X-23.246 Z-45.379
N11790 X-22.316 Z-45.519
N11791 X-21.386 Z-45.707
N11792 X-20.456 Z-45.948
N11793 X-19.526 Z-46.24
N11794 X-18.596 Z-46.583
N11795 X-16.595 Z-47.448
N11796 X-15.594 Z-47.854
N11797 X-14.593 Z-48.231
N11798 X-12.876 Z-48.814
N11799 X-11.158 Z-49.318
N11800 X-9.273 Z-49.782
N11801 X-7.422 Z-50.151
N11802 X-5.554 Z-50.437
N11803 X-3.719 Z-50.637
N11804 X-1.862 Z-50.759
N11805 X0. Z-50.8
N11806 X1.862 Z-50.759
N11807 X3.719 Z-50.637
N11808 X5.554 Z-50.437
N11809 X7.422 Z-50.151
N11810 X9.273 Z-49.782
N11811 X11.158 Z-49.318
N11812 X12.876 Z-48.814
N11813 X14.593 Z-48.231
N11814 X15.594 Z-47.854
N11815 X16.595 Z-47.448
N11816 X18.596 Z-46.583
N11817 X19.526 Z-46.24
N11818 X20.456 Z-45.948
N11819 X21.386 Z-45.707
N11820 X22.316 Z-45.519
N11821 X23.246 Z-45.379
N11822 X24.175 Z-45.302
N11823 X25.105 Z-45.276
N11824 X119.003
N11825 X119.01 Z-10.724
N11826 X119.104 Z-9.653
N11827 X119.308 Z-8.571
N11828 X119.598 Z-7.568
N11829 X119.947 Z-6.674
N11830 X120.179 Z-6.185
N11831 X120.644 Z-5.343
N11832 X121.109 Z-4.641
N11833 X121.807 Z-3.769
N11834 X122.272 Z-3.278
N11835 X122.736 Z-2.837
N11836 X123.201 Z-2.444
N11837 X123.666 Z-2.094
N11838 X124.131 Z-1.776
N11839 X125.061 Z-1.24
N11840 X125.526 Z-1.015
N11841 X126.456 Z-.638
N11842 X127.386 Z-.354
N11843 X128.315 Z-.156
N11844 X129.245 Z-.039
N11845 X130.175 Z0.
N11846 Y-22.225
N11847 X129.245 Z-.039
N11848 X128.315 Z-.156
N11849 X127.386 Z-.354
N11850 X126.456 Z-.638
N11851 X125.526 Z-1.015
N11852 X125.061 Z-1.24
N11853 X124.131 Z-1.776
N11854 X123.666 Z-2.094
N11855 X123.201 Z-2.444
N11856 X122.736 Z-2.837
N11857 X122.272 Z-3.278
N11858 X121.807 Z-3.769
N11859 X121.109 Z-4.641
N11860 X120.644 Z-5.343
N11861 X120.179 Z-6.185
N11862 X119.947 Z-6.674
N11863 X119.598 Z-7.568
N11864 X119.308 Z-8.571
N11865 X119.104 Z-9.653
N11866 X119.01 Z-10.724
N11867 X119.003 Z-44.573
N11868 X26.035 Z-44.577
N11869 X25.105 Z-44.636
N11870 X24.175 Z-44.748
N11871 X23.246 Z-44.919
N11872 X22.316 Z-45.141
N11873 X21.386 Z-45.414
N11874 X20.456 Z-45.738
N11875 X19.526 Z-46.114
N11876 X17.658 Z-46.984
N11877 X15.783 Z-47.781
N11878 X14.845 Z-48.14
N11879 X13.001 Z-48.775
N11880 X11.158 Z-49.318
N11881 X9.273 Z-49.782
N11882 X7.422 Z-50.151
N11883 X5.554 Z-50.437
N11884 X3.719 Z-50.637
N11885 X1.862 Z-50.759
N11886 X0. Z-50.8
N11887 X-1.862 Z-50.759
N11888 X-3.719 Z-50.637
N11889 X-5.554 Z-50.437
N11890 X-7.422 Z-50.151
N11891 X-9.273 Z-49.782
N11892 X-11.158 Z-49.318
N11893 X-13.001 Z-48.775
N11894 X-14.845 Z-48.14
N11895 X-16.721 Z-47.395
N11896 X-19.526 Z-46.114
N11897 X-20.456 Z-45.738
N11898 X-21.386 Z-45.414
N11899 X-22.316 Z-45.141
N11900 X-23.246 Z-44.919
N11901 X-24.175 Z-44.748
N11902 X-25.105 Z-44.636
N11903 X-26.035 Z-44.577
N11904 X-119.003 Z-44.573
N11905 X-119.017 Z-10.557
N11906 X-119.133 Z-9.454
N11907 X-119.366 Z-8.342
N11908 X-119.598 Z-7.568
N11909 X-119.947 Z-6.674
N11910 X-120.412 Z-5.739
N11911 X-120.877 Z-4.981
N11912 X-121.342 Z-4.335
N11913 X-121.807 Z-3.769
N11914 X-122.272 Z-3.278
N11915 X-122.736 Z-2.837
N11916 X-123.201 Z-2.444
N11917 X-123.666 Z-2.094
N11918 X-124.131 Z-1.776
N11919 X-125.061 Z-1.24
N11920 X-125.526 Z-1.015
N11921 X-126.456 Z-.638
N11922 X-127.386 Z-.354
N11923 X-128.315 Z-.156
N11924 X-129.245 Z-.039
N11925 X-130.175 Z0.
N11926 Y-23.425
N11927 X-129.245 Z-.039
N11928 X-128.315 Z-.156
N11929 X-127.386 Z-.354
N11930 X-126.456 Z-.638
N11931 X-125.526 Z-1.015
N11932 X-125.061 Z-1.24
N11933 X-124.131 Z-1.776
N11934 X-123.666 Z-2.094
N11935 X-123.201 Z-2.444
N11936 X-122.736 Z-2.837
N11937 X-122.272 Z-3.278
N11938 X-121.807 Z-3.769
N11939 X-121.342 Z-4.335
N11940 X-120.877 Z-4.981
N11941 X-120.412 Z-5.739
N11942 X-119.947 Z-6.674
N11943 X-119.598 Z-7.568
N11944 X-119.366 Z-8.342
N11945 X-119.133 Z-9.454
N11946 X-119.017 Z-10.557
N11947 X-119.003 Z-43.819
N11948 X-27.895
N11949 X-26.965 Z-43.844
N11950 X-26.035 Z-43.936
N11951 X-25.105 Z-44.085
N11952 X-24.175 Z-44.287
N11953 X-23.246 Z-44.544
N11954 X-22.316 Z-44.849
N11955 X-21.386 Z-45.208
N11956 X-20.456 Z-45.617
N11957 X-18.596 Z-46.545
N11958 X-16.721 Z-47.395
N11959 X-14.845 Z-48.14
N11960 X-13.001 Z-48.775
N11961 X-11.158 Z-49.318
N11962 X-9.273 Z-49.782
N11963 X-7.422 Z-50.151
N11964 X-5.554 Z-50.437
N11965 X-3.719 Z-50.637
N11966 X-1.862 Z-50.759
N11967 X0. Z-50.8
N11968 X1.862 Z-50.759
N11969 X3.719 Z-50.637
N11970 X5.554 Z-50.437
N11971 X7.422 Z-50.151
N11972 X9.273 Z-49.782
N11973 X11.158 Z-49.318
N11974 X13.001 Z-48.775
N11975 X14.845 Z-48.14
N11976 X16.721 Z-47.395
N11977 X18.596 Z-46.545
N11978 X20.456 Z-45.617
N11979 X21.386 Z-45.208
N11980 X22.316 Z-44.849
N11981 X23.246 Z-44.544
N11982 X24.175 Z-44.287
N11983 X25.105 Z-44.085
N11984 X26.035 Z-43.936
N11985 X26.965 Z-43.844
N11986 X27.895 Z-43.819
N11987 X119.003
N11988 X119.01 Z-10.724
N11989 X119.104 Z-9.653
N11990 X119.308 Z-8.571
N11991 X119.598 Z-7.568
N11992 X119.947 Z-6.674
N11993 X120.179 Z-6.185
N11994 X120.644 Z-5.343
N11995 X121.109 Z-4.641
N11996 X121.807 Z-3.769
N11997 X122.272 Z-3.278
N11998 X122.736 Z-2.837
N11999 X123.201 Z-2.444
N12000 X123.666 Z-2.094
N12001 X124.131 Z-1.776
N12002 X125.061 Z-1.24
N12003 X125.526 Z-1.015
N12004 X126.456 Z-.638
N12005 X127.386 Z-.354
N12006 X128.315 Z-.156
N12007 X129.245 Z-.039
N12008 X130.175 Z0.
N12009 Y-24.625
N12010 X129.245 Z-.039
N12011 X128.315 Z-.156
N12012 X127.386 Z-.354
N12013 X126.456 Z-.638
N12014 X125.526 Z-1.015
N12015 X125.061 Z-1.24
N12016 X124.131 Z-1.776
N12017 X123.666 Z-2.094
N12018 X123.201 Z-2.444
N12019 X122.736 Z-2.837
N12020 X122.272 Z-3.278
N12021 X121.807 Z-3.769
N12022 X121.109 Z-4.641
N12023 X120.644 Z-5.343
N12024 X120.179 Z-6.185
N12025 X119.947 Z-6.674
N12026 X119.598 Z-7.568
N12027 X119.308 Z-8.571
N12028 X119.104 Z-9.653
N12029 X119.01 Z-10.724
N12030 X119.003 Z-43.002
N12031 X28.824 Z-43.01
N12032 X27.895 Z-43.075
N12033 X26.965 Z-43.2
N12034 X26.035 Z-43.386
N12035 X25.105 Z-43.621
N12036 X24.175 Z-43.914
N12037 X23.246 Z-44.252
N12038 X22.316 Z-44.647
N12039 X18.596 Z-46.545
N12040 X16.721 Z-47.395
N12041 X14.845 Z-48.14
N12042 X13.001 Z-48.775
N12043 X11.158 Z-49.318
N12044 X9.273 Z-49.782
N12045 X7.422 Z-50.151
N12046 X5.554 Z-50.437
N12047 X3.719 Z-50.637
N12048 X1.862 Z-50.759
N12049 X0. Z-50.8
N12050 X-1.862 Z-50.759
N12051 X-3.719 Z-50.637
N12052 X-5.554 Z-50.437
N12053 X-7.422 Z-50.151
N12054 X-9.273 Z-49.782
N12055 X-11.158 Z-49.318
N12056 X-13.001 Z-48.775
N12057 X-14.845 Z-48.14
N12058 X-16.721 Z-47.395
N12059 X-18.596 Z-46.545
N12060 X-22.316 Z-44.647
N12061 X-23.246 Z-44.252
N12062 X-24.175 Z-43.914
N12063 X-25.105 Z-43.621
N12064 X-26.035 Z-43.386
N12065 X-26.965 Z-43.2
N12066 X-27.895 Z-43.075
N12067 X-28.824 Z-43.01
N12068 X-119.003 Z-43.002
N12069 X-119.017 Z-10.557
N12070 X-119.133 Z-9.454
N12071 X-119.366 Z-8.342
N12072 X-119.598 Z-7.568
N12073 X-119.947 Z-6.674
N12074 X-120.412 Z-5.739
N12075 X-120.877 Z-4.981
N12076 X-121.342 Z-4.335
N12077 X-121.807 Z-3.769
N12078 X-122.272 Z-3.278
N12079 X-122.736 Z-2.837
N12080 X-123.201 Z-2.444
N12081 X-123.666 Z-2.094
N12082 X-124.131 Z-1.776
N12083 X-125.061 Z-1.24
N12084 X-125.526 Z-1.015
N12085 X-126.456 Z-.638
N12086 X-127.386 Z-.354
N12087 X-128.315 Z-.156
N12088 X-129.245 Z-.039
N12089 X-130.175 Z0.
N12090 Y-25.825
N12091 X-129.245 Z-.039
N12092 X-128.315 Z-.156
N12093 X-127.386 Z-.354
N12094 X-126.456 Z-.638
N12095 X-125.526 Z-1.015
N12096 X-125.061 Z-1.24
N12097 X-124.131 Z-1.776
N12098 X-123.666 Z-2.094
N12099 X-123.201 Z-2.444
N12100 X-122.736 Z-2.837
N12101 X-122.272 Z-3.278
N12102 X-121.807 Z-3.769
N12103 X-121.342 Z-4.335
N12104 X-120.877 Z-4.981
N12105 X-120.412 Z-5.739
N12106 X-119.947 Z-6.674
N12107 X-119.598 Z-7.568
N12108 X-119.366 Z-8.342
N12109 X-119.133 Z-9.454
N12110 X-119.017 Z-10.557
N12111 X-119.003 Z-42.128
N12112 X-30.684
N12113 X-29.754 Z-42.16
N12114 X-28.824 Z-42.267
N12115 X-27.895 Z-42.426
N12116 X-26.965 Z-42.649
N12117 X-26.035 Z-42.919
N12118 X-25.105 Z-43.248
N12119 X-24.175 Z-43.621
N12120 X-23.246 Z-44.054
N12121 X-22.316 Z-44.534
N12122 X-20.297 Z-45.677
N12123 X-18.596 Z-46.545
N12124 X-16.721 Z-47.395
N12125 X-14.845 Z-48.14
N12126 X-13.001 Z-48.775
N12127 X-11.158 Z-49.318
N12128 X-9.273 Z-49.782
N12129 X-7.422 Z-50.151
N12130 X-5.554 Z-50.437
N12131 X-3.719 Z-50.637
N12132 X-1.862 Z-50.759
N12133 X0. Z-50.8
N12134 X1.862 Z-50.759
N12135 X3.719 Z-50.637
N12136 X5.554 Z-50.437
N12137 X7.422 Z-50.151
N12138 X9.273 Z-49.782
N12139 X11.158 Z-49.318
N12140 X13.001 Z-48.775
N12141 X14.845 Z-48.14
N12142 X16.721 Z-47.395
N12143 X18.596 Z-46.545
N12144 X20.297 Z-45.677
N12145 X22.316 Z-44.534
N12146 X23.246 Z-44.054
N12147 X24.175 Z-43.621
N12148 X25.105 Z-43.248
N12149 X26.035 Z-42.919
N12150 X26.965 Z-42.649
N12151 X27.895 Z-42.426
N12152 X28.824 Z-42.267
N12153 X29.754 Z-42.16
N12154 X30.684 Z-42.128
N12155 X119.003
N12156 X119.01 Z-10.724
N12157 X119.104 Z-9.653
N12158 X119.308 Z-8.571
N12159 X119.598 Z-7.568
N12160 X119.947 Z-6.674
N12161 X120.179 Z-6.185
N12162 X120.644 Z-5.343
N12163 X121.109 Z-4.641
N12164 X121.807 Z-3.769
N12165 X122.272 Z-3.278
N12166 X122.736 Z-2.837
N12167 X123.201 Z-2.444
N12168 X123.666 Z-2.094
N12169 X124.131 Z-1.776
N12170 X125.061 Z-1.24
N12171 X125.526 Z-1.015
N12172 X126.456 Z-.638
N12173 X127.386 Z-.354
N12174 X128.315 Z-.156
N12175 X129.245 Z-.039
N12176 X130.175 Z0.
N12177 Y-27.025
N12178 X129.245 Z-.039
N12179 X128.315 Z-.156
N12180 X127.386 Z-.354
N12181 X126.456 Z-.638
N12182 X125.526 Z-1.015
N12183 X125.061 Z-1.24
N12184 X124.131 Z-1.776
N12185 X123.666 Z-2.094
N12186 X123.201 Z-2.444
N12187 X122.736 Z-2.837
N12188 X122.272 Z-3.278
N12189 X121.807 Z-3.769
N12190 X121.109 Z-4.641
N12191 X120.644 Z-5.343
N12192 X120.179 Z-6.185
N12193 X119.947 Z-6.674
N12194 X119.598 Z-7.568
N12195 X119.308 Z-8.571
N12196 X119.104 Z-9.653
N12197 X119.01 Z-10.724
N12198 X119.003 Z-41.185
N12199 X31.614 Z-41.197
N12200 X30.684 Z-41.269
N12201 X29.754 Z-41.412
N12202 X28.824 Z-41.612
N12203 X27.895 Z-41.87
N12204 X26.965 Z-42.18
N12205 X26.035 Z-42.543
N12206 X25.105 Z-42.956
N12207 X24.175 Z-43.425
N12208 X23.246 Z-43.945
N12209 X21.356 Z-45.088
N12210 X20.449 Z-45.596
N12211 X18.596 Z-46.545
N12212 X16.721 Z-47.395
N12213 X14.845 Z-48.14
N12214 X13.001 Z-48.775
N12215 X11.158 Z-49.318
N12216 X9.273 Z-49.782
N12217 X7.422 Z-50.151
N12218 X5.554 Z-50.437
N12219 X3.719 Z-50.637
N12220 X1.862 Z-50.759
N12221 X0. Z-50.8
N12222 X-1.862 Z-50.759
N12223 X-3.719 Z-50.637
N12224 X-5.554 Z-50.437
N12225 X-7.422 Z-50.151
N12226 X-9.273 Z-49.782
N12227 X-11.158 Z-49.318
N12228 X-13.001 Z-48.775
N12229 X-14.845 Z-48.14
N12230 X-16.721 Z-47.395
N12231 X-18.596 Z-46.545
N12232 X-20.449 Z-45.596
N12233 X-21.356 Z-45.088
N12234 X-23.246 Z-43.945
N12235 X-24.175 Z-43.425
N12236 X-25.105 Z-42.956
N12237 X-26.035 Z-42.543
N12238 X-26.965 Z-42.18
N12239 X-27.895 Z-41.87
N12240 X-28.824 Z-41.612
N12241 X-29.754 Z-41.412
N12242 X-30.684 Z-41.269
N12243 X-31.614 Z-41.197
N12244 X-119.003 Z-41.185
N12245 X-119.017 Z-10.557
N12246 X-119.133 Z-9.454
N12247 X-119.366 Z-8.342
N12248 X-119.598 Z-7.568
N12249 X-119.947 Z-6.674
N12250 X-120.412 Z-5.739
N12251 X-120.877 Z-4.981
N12252 X-121.342 Z-4.335
N12253 X-121.807 Z-3.769
N12254 X-122.272 Z-3.278
N12255 X-122.736 Z-2.837
N12256 X-123.201 Z-2.444
N12257 X-123.666 Z-2.094
N12258 X-124.131 Z-1.776
N12259 X-125.061 Z-1.24
N12260 X-125.526 Z-1.015
N12261 X-126.456 Z-.638
N12262 X-127.386 Z-.354
N12263 X-128.315 Z-.156
N12264 X-129.245 Z-.039
N12265 X-130.175 Z0.
N12266 Y-28.225
N12267 X-129.245 Z-.039
N12268 X-128.315 Z-.156
N12269 X-127.386 Z-.354
N12270 X-126.456 Z-.638
N12271 X-125.526 Z-1.015
N12272 X-125.061 Z-1.24
N12273 X-124.131 Z-1.776
N12274 X-123.666 Z-2.094
N12275 X-123.201 Z-2.444
N12276 X-122.736 Z-2.837
N12277 X-122.272 Z-3.278
N12278 X-121.807 Z-3.769
N12279 X-121.342 Z-4.335
N12280 X-120.877 Z-4.981
N12281 X-120.412 Z-5.739
N12282 X-119.947 Z-6.674
N12283 X-119.598 Z-7.568
N12284 X-119.366 Z-8.342
N12285 X-119.133 Z-9.454
N12286 X-119.017 Z-10.557
N12287 X-119.003 Z-40.17
N12288 X-33.474
N12289 X-32.544 Z-40.213
N12290 X-31.614 Z-40.332
N12291 X-30.684 Z-40.511
N12292 X-29.754 Z-40.755
N12293 X-28.824 Z-41.049
N12294 X-27.895 Z-41.4
N12295 X-26.965 Z-41.799
N12296 X-26.035 Z-42.254
N12297 X-25.105 Z-42.76
N12298 X-24.175 Z-43.323
N12299 X-22.316 Z-44.519
N12300 X-21.386 Z-45.071
N12301 X-20.456 Z-45.592
N12302 X-19.526 Z-46.083
N12303 X-18.596 Z-46.545
N12304 X-16.721 Z-47.395
N12305 X-14.845 Z-48.14
N12306 X-13.001 Z-48.775
N12307 X-11.158 Z-49.318
N12308 X-9.273 Z-49.782
N12309 X-7.422 Z-50.151
N12310 X-5.554 Z-50.437
N12311 X-3.719 Z-50.637
N12312 X-1.862 Z-50.759
N12313 X0. Z-50.8
N12314 X1.862 Z-50.759
N12315 X3.719 Z-50.637
N12316 X5.554 Z-50.437
N12317 X7.422 Z-50.151
N12318 X9.273 Z-49.782
N12319 X11.158 Z-49.318
N12320 X13.001 Z-48.775
N12321 X14.845 Z-48.14
N12322 X15.783 Z-47.781
N12323 X17.658 Z-46.984
N12324 X19.526 Z-46.083
N12325 X20.456 Z-45.592
N12326 X21.386 Z-45.071
N12327 X22.316 Z-44.519
N12328 X24.175 Z-43.323
N12329 X25.105 Z-42.76
N12330 X26.035 Z-42.254
N12331 X26.965 Z-41.799
N12332 X27.895 Z-41.4
N12333 X28.824 Z-41.049
N12334 X29.754 Z-40.755
N12335 X30.684 Z-40.511
N12336 X31.614 Z-40.332
N12337 X32.544 Z-40.213
N12338 X33.474 Z-40.17
N12339 X119.003
N12340 X119.01 Z-10.724
N12341 X119.104 Z-9.653
N12342 X119.308 Z-8.571
N12343 X119.598 Z-7.568
N12344 X119.947 Z-6.674
N12345 X120.179 Z-6.185
N12346 X120.644 Z-5.343
N12347 X121.109 Z-4.641
N12348 X121.807 Z-3.769
N12349 X122.272 Z-3.278
N12350 X122.736 Z-2.837
N12351 X123.201 Z-2.444
N12352 X123.666 Z-2.094
N12353 X124.131 Z-1.776
N12354 X125.061 Z-1.24
N12355 X125.526 Z-1.015
N12356 X126.456 Z-.638
N12357 X127.386 Z-.354
N12358 X128.315 Z-.156
N12359 X129.245 Z-.039
N12360 X130.175 Z0.
N12361 Y-29.425
N12362 X129.245 Z-.039
N12363 X128.315 Z-.156
N12364 X127.386 Z-.354
N12365 X126.456 Z-.638
N12366 X125.526 Z-1.015
N12367 X125.061 Z-1.24
N12368 X124.131 Z-1.776
N12369 X123.666 Z-2.094
N12370 X123.201 Z-2.444
N12371 X122.736 Z-2.837
N12372 X122.272 Z-3.278
N12373 X121.807 Z-3.769
N12374 X121.109 Z-4.641
N12375 X120.644 Z-5.343
N12376 X120.179 Z-6.185
N12377 X119.947 Z-6.674
N12378 X119.598 Z-7.568
N12379 X119.308 Z-8.571
N12380 X119.104 Z-9.653
N12381 X119.01 Z-10.724
N12382 X119.003 Z-39.076
N12383 X35.333
N12384 X34.403 Z-39.093
N12385 X33.474 Z-39.178
N12386 X32.544 Z-39.34
N12387 X31.614 Z-39.563
N12388 X30.684 Z-39.847
N12389 X29.754 Z-40.182
N12390 X28.824 Z-40.575
N12391 X27.895 Z-41.014
N12392 X26.965 Z-41.512
N12393 X26.035 Z-42.057
N12394 X24.976 Z-42.755
N12395 X23.917 Z-43.489
N12396 X22.858 Z-44.18
N12397 X21.799 Z-44.829
N12398 X20.198 Z-45.73
N12399 X18.596 Z-46.545
N12400 X16.721 Z-47.395
N12401 X14.845 Z-48.14
N12402 X13.001 Z-48.775
N12403 X11.158 Z-49.318
N12404 X9.273 Z-49.782
N12405 X7.422 Z-50.151
N12406 X5.554 Z-50.437
N12407 X3.719 Z-50.637
N12408 X1.862 Z-50.759
N12409 X0. Z-50.8
N12410 X-1.862 Z-50.759
N12411 X-3.719 Z-50.637
N12412 X-5.554 Z-50.437
N12413 X-7.422 Z-50.151
N12414 X-9.273 Z-49.782
N12415 X-11.158 Z-49.318
N12416 X-13.001 Z-48.775
N12417 X-14.845 Z-48.14
N12418 X-16.721 Z-47.395
N12419 X-18.596 Z-46.545
N12420 X-20.198 Z-45.73
N12421 X-21.799 Z-44.829
N12422 X-22.858 Z-44.18
N12423 X-23.917 Z-43.489
N12424 X-24.976 Z-42.755
N12425 X-26.035 Z-42.057
N12426 X-26.965 Z-41.512
N12427 X-27.895 Z-41.014
N12428 X-28.824 Z-40.575
N12429 X-29.754 Z-40.182
N12430 X-30.684 Z-39.847
N12431 X-31.614 Z-39.563
N12432 X-32.544 Z-39.34
N12433 X-33.474 Z-39.178
N12434 X-34.403 Z-39.093
N12435 X-119.003 Z-39.076
N12436 X-119.017 Z-10.557
N12437 X-119.133 Z-9.454
N12438 X-119.366 Z-8.342
N12439 X-119.598 Z-7.568
N12440 X-119.947 Z-6.674
N12441 X-120.412 Z-5.739
N12442 X-120.877 Z-4.981
N12443 X-121.342 Z-4.335
N12444 X-121.807 Z-3.769
N12445 X-122.272 Z-3.278
N12446 X-122.736 Z-2.837
N12447 X-123.201 Z-2.444
N12448 X-123.666 Z-2.094
N12449 X-124.131 Z-1.776
N12450 X-125.061 Z-1.24
N12451 X-125.526 Z-1.015
N12452 X-126.456 Z-.638
N12453 X-127.386 Z-.354
N12454 X-128.315 Z-.156
N12455 X-129.245 Z-.039
N12456 X-130.175 Z0.
N12457 Y-30.625
N12458 X-129.245 Z-.039
N12459 X-128.315 Z-.156
N12460 X-127.386 Z-.354
N12461 X-126.456 Z-.638
N12462 X-125.526 Z-1.015
N12463 X-125.061 Z-1.24
N12464 X-124.131 Z-1.776
N12465 X-123.666 Z-2.094
N12466 X-123.201 Z-2.444
N12467 X-122.736 Z-2.837
N12468 X-122.272 Z-3.278
N12469 X-121.807 Z-3.769
N12470 X-121.342 Z-4.335
N12471 X-120.877 Z-4.981
N12472 X-120.412 Z-5.739
N12473 X-119.947 Z-6.674
N12474 X-119.598 Z-7.568
N12475 X-119.366 Z-8.342
N12476 X-119.133 Z-9.454
N12477 X-119.017 Z-10.557
N12478 X-119.003 Z-37.896
N12479 X-36.965
N12480 X-35.634 Z-37.921
N12481 X-35.094 Z-37.977
N12482 X-34.554 Z-38.061
N12483 X-33.474 Z-38.289
N12484 X-32.544 Z-38.562
N12485 X-31.614 Z-38.885
N12486 X-30.684 Z-39.268
N12487 X-29.754 Z-39.699
N12488 X-28.824 Z-40.185
N12489 X-27.895 Z-40.724
N12490 X-26.965 Z-41.316
N12491 X-26.035 Z-41.973
N12492 X-25.088 Z-42.675
N12493 X-24.141 Z-43.34
N12494 X-23.193 Z-43.968
N12495 X-22.246 Z-44.561
N12496 X-21.334 Z-45.1
N12497 X-20.421 Z-45.61
N12498 X-18.596 Z-46.545
N12499 X-16.721 Z-47.395
N12500 X-14.845 Z-48.14
N12501 X-13.001 Z-48.775
N12502 X-11.158 Z-49.318
N12503 X-9.273 Z-49.782
N12504 X-7.422 Z-50.151
N12505 X-5.554 Z-50.437
N12506 X-3.719 Z-50.637
N12507 X-1.862 Z-50.759
N12508 X0. Z-50.8
N12509 X1.862 Z-50.759
N12510 X3.719 Z-50.637
N12511 X5.554 Z-50.437
N12512 X7.422 Z-50.151
N12513 X9.273 Z-49.782
N12514 X11.158 Z-49.318
N12515 X13.001 Z-48.775
N12516 X14.845 Z-48.14
N12517 X15.783 Z-47.781
N12518 X17.658 Z-46.984
N12519 X19.509 Z-46.092
N12520 X21.334 Z-45.1
N12521 X22.246 Z-44.561
N12522 X23.193 Z-43.968
N12523 X24.141 Z-43.34
N12524 X25.088 Z-42.675
N12525 X26.035 Z-41.973
N12526 X26.965 Z-41.316
N12527 X27.895 Z-40.724
N12528 X28.824 Z-40.185
N12529 X29.754 Z-39.699
N12530 X30.684 Z-39.268
N12531 X31.614 Z-38.885
N12532 X32.544 Z-38.562
N12533 X33.474 Z-38.289
N12534 X34.403 Z-38.088
N12535 X35.333 Z-37.948
N12536 X36.263 Z-37.896
N12537 X119.003 Z-37.896
N12538 X119.01 Z-10.724
N12539 X119.104 Z-9.653
N12540 X119.308 Z-8.571
N12541 X119.598 Z-7.568
N12542 X119.947 Z-6.674
N12543 X120.179 Z-6.185
N12544 X120.644 Z-5.343
N12545 X121.109 Z-4.641
N12546 X121.807 Z-3.769
N12547 X122.272 Z-3.278
N12548 X122.736 Z-2.837
N12549 X123.201 Z-2.444
N12550 X123.666 Z-2.094
N12551 X124.131 Z-1.776
N12552 X125.061 Z-1.24
N12553 X125.526 Z-1.015
N12554 X126.456 Z-.638
N12555 X127.386 Z-.354
N12556 X128.315 Z-.156
N12557 X129.245 Z-.039
N12558 X130.175 Z0.
N12559 Y-31.825
N12560 X129.245 Z-.039
N12561 X128.315 Z-.156
N12562 X127.386 Z-.354
N12563 X126.456 Z-.638
N12564 X125.526 Z-1.015
N12565 X125.061 Z-1.24
N12566 X124.131 Z-1.776
N12567 X123.666 Z-2.094
N12568 X123.201 Z-2.444
N12569 X122.736 Z-2.837
N12570 X122.272 Z-3.278
N12571 X121.807 Z-3.769
N12572 X121.109 Z-4.641
N12573 X120.644 Z-5.343
N12574 X120.179 Z-6.185
N12575 X119.947 Z-6.674
N12576 X119.598 Z-7.568
N12577 X119.308 Z-8.571
N12578 X119.104 Z-9.653
N12579 X119.01 Z-10.724
N12580 X119.003 Z-36.612
N12581 X39.053
N12582 X37.193 Z-36.633
N12583 X36.263 Z-36.74
N12584 X35.333 Z-36.924
N12585 X34.403 Z-37.18
N12586 X33.474 Z-37.494
N12587 X32.544 Z-37.868
N12588 X31.614 Z-38.296
N12589 X30.684 Z-38.774
N12590 X29.754 Z-39.309
N12591 X28.824 Z-39.89
N12592 X27.895 Z-40.532
N12593 X26.035 Z-41.969
N12594 X25.092 Z-42.672
N12595 X24.148 Z-43.334
N12596 X23.205 Z-43.96
N12597 X22.262 Z-44.551
N12598 X21.345 Z-45.094
N12599 X19.513 Z-46.09
N12600 X17.658 Z-46.984
N12601 X15.783 Z-47.781
N12602 X14.845 Z-48.14
N12603 X13.001 Z-48.775
N12604 X11.158 Z-49.318
N12605 X9.273 Z-49.782
N12606 X7.422 Z-50.151
N12607 X5.554 Z-50.437
N12608 X3.719 Z-50.637
N12609 X1.862 Z-50.759
N12610 X0. Z-50.8
N12611 X-1.862 Z-50.759
N12612 X-3.719 Z-50.637
N12613 X-5.554 Z-50.437
N12614 X-7.422 Z-50.151
N12615 X-9.273 Z-49.782
N12616 X-11.158 Z-49.318
N12617 X-13.001 Z-48.775
N12618 X-14.845 Z-48.14
N12619 X-16.721 Z-47.395
N12620 X-18.596 Z-46.545
N12621 X-20.429 Z-45.606
N12622 X-21.345 Z-45.094
N12623 X-22.262 Z-44.551
N12624 X-23.205 Z-43.96
N12625 X-24.148 Z-43.334
N12626 X-25.092 Z-42.672
N12627 X-26.035 Z-41.969
N12628 X-27.895 Z-40.532
N12629 X-28.824 Z-39.89
N12630 X-29.754 Z-39.309
N12631 X-30.684 Z-38.774
N12632 X-31.614 Z-38.296
N12633 X-32.544 Z-37.868
N12634 X-33.474 Z-37.494
N12635 X-34.403 Z-37.18
N12636 X-35.333 Z-36.924
N12637 X-36.263 Z-36.74
N12638 X-37.193 Z-36.633
N12639 X-40.912 Z-36.612
N12640 X-119.003
N12641 X-119.017 Z-10.557
N12642 X-119.133 Z-9.454
N12643 X-119.366 Z-8.342
N12644 X-119.598 Z-7.568
N12645 X-119.947 Z-6.674
N12646 X-120.412 Z-5.739
N12647 X-120.877 Z-4.981
N12648 X-121.342 Z-4.335
N12649 X-121.807 Z-3.769
N12650 X-122.272 Z-3.278
N12651 X-122.736 Z-2.837
N12652 X-123.201 Z-2.444
N12653 X-123.666 Z-2.094
N12654 X-124.131 Z-1.776
N12655 X-125.061 Z-1.24
N12656 X-125.526 Z-1.015
N12657 X-126.456 Z-.638
N12658 X-127.386 Z-.354
N12659 X-128.315 Z-.156
N12660 X-129.245 Z-.039
N12661 X-130.175 Z0.
N12662 Y-33.025
N12663 X-129.245 Z-.039
N12664 X-128.315 Z-.156
N12665 X-127.386 Z-.354
N12666 X-126.456 Z-.638
N12667 X-125.526 Z-1.015
N12668 X-125.061 Z-1.24
N12669 X-124.131 Z-1.776
N12670 X-123.666 Z-2.094
N12671 X-123.201 Z-2.444
N12672 X-122.736 Z-2.837
N12673 X-122.272 Z-3.278
N12674 X-121.807 Z-3.769
N12675 X-121.342 Z-4.335
N12676 X-120.877 Z-4.981
N12677 X-120.412 Z-5.739
N12678 X-119.947 Z-6.674
N12679 X-119.598 Z-7.568
N12680 X-119.366 Z-8.342
N12681 X-119.133 Z-9.454
N12682 X-119.017 Z-10.557
N12683 X-119.003 Z-35.22
N12684 X-39.053 Z-35.222
N12685 X-38.123 Z-35.291
N12686 X-37.193 Z-35.451
N12687 X-36.263 Z-35.691
N12688 X-35.333 Z-35.996
N12689 X-34.403 Z-36.363
N12690 X-33.474 Z-36.788
N12691 X-32.544 Z-37.263
N12692 X-31.614 Z-37.795
N12693 X-30.684 Z-38.374
N12694 X-29.754 Z-39.008
N12695 X-28.824 Z-39.705
N12696 X-26.965 Z-41.234
N12697 X-26.035 Z-41.969
N12698 X-25.092 Z-42.672
N12699 X-24.148 Z-43.334
N12700 X-23.205 Z-43.96
N12701 X-22.262 Z-44.551
N12702 X-21.345 Z-45.094
N12703 X-20.429 Z-45.606
N12704 X-18.596 Z-46.545
N12705 X-16.721 Z-47.395
N12706 X-14.845 Z-48.14
N12707 X-13.001 Z-48.775
N12708 X-11.158 Z-49.318
N12709 X-9.273 Z-49.782
N12710 X-7.422 Z-50.151
N12711 X-5.554 Z-50.437
N12712 X-3.719 Z-50.637
N12713 X-1.862 Z-50.759
N12714 X0. Z-50.8
N12715 X1.862 Z-50.759
N12716 X3.719 Z-50.637
N12717 X5.554 Z-50.437
N12718 X7.422 Z-50.151
N12719 X9.273 Z-49.782
N12720 X11.158 Z-49.318
N12721 X13.001 Z-48.775
N12722 X14.845 Z-48.14
N12723 X15.783 Z-47.781
N12724 X17.658 Z-46.984
N12725 X19.513 Z-46.09
N12726 X21.345 Z-45.094
N12727 X22.262 Z-44.551
N12728 X23.205 Z-43.96
N12729 X24.148 Z-43.334
N12730 X25.092 Z-42.672
N12731 X26.035 Z-41.969
N12732 X26.965 Z-41.234
N12733 X28.824 Z-39.705
N12734 X29.754 Z-39.008
N12735 X30.684 Z-38.374
N12736 X31.614 Z-37.795
N12737 X32.544 Z-37.263
N12738 X33.474 Z-36.788
N12739 X34.403 Z-36.363
N12740 X35.333 Z-35.996
N12741 X36.263 Z-35.691
N12742 X37.193 Z-35.451
N12743 X38.123 Z-35.291
N12744 X39.053 Z-35.222
N12745 X119.003 Z-35.22
N12746 X119.01 Z-10.724
N12747 X119.104 Z-9.653
N12748 X119.308 Z-8.571
N12749 X119.598 Z-7.568
N12750 X119.947 Z-6.674
N12751 X120.179 Z-6.185
N12752 X120.644 Z-5.343
N12753 X121.109 Z-4.641
N12754 X121.807 Z-3.769
N12755 X122.272 Z-3.278
N12756 X122.736 Z-2.837
N12757 X123.201 Z-2.444
N12758 X123.666 Z-2.094
N12759 X124.131 Z-1.776
N12760 X125.061 Z-1.24
N12761 X125.526 Z-1.015
N12762 X126.456 Z-.638
N12763 X127.386 Z-.354
N12764 X128.315 Z-.156
N12765 X129.245 Z-.039
N12766 X130.175 Z0.
N12767 Y-34.225
N12768 X129.245 Z-.039
N12769 X128.315 Z-.156
N12770 X127.386 Z-.354
N12771 X126.456 Z-.638
N12772 X125.526 Z-1.015
N12773 X125.061 Z-1.24
N12774 X124.131 Z-1.776
N12775 X123.666 Z-2.094
N12776 X123.201 Z-2.444
N12777 X122.736 Z-2.837
N12778 X122.272 Z-3.278
N12779 X121.807 Z-3.769
N12780 X121.109 Z-4.641
N12781 X120.644 Z-5.343
N12782 X120.179 Z-6.185
N12783 X119.947 Z-6.674
N12784 X119.598 Z-7.568
N12785 X119.308 Z-8.571
N12786 X119.104 Z-9.653
N12787 X119.01 Z-10.724
N12788 X119.003 Z-33.697
N12789 X40.912
N12790 X39.982 Z-33.724
N12791 X39.517 Z-33.775
N12792 X39.053 Z-33.853
N12793 X38.123 Z-34.076
N12794 X37.193 Z-34.369
N12795 X36.263 Z-34.733
N12796 X35.333 Z-35.157
N12797 X34.403 Z-35.633
N12798 X33.474 Z-36.168
N12799 X32.544 Z-36.748
N12800 X31.614 Z-37.383
N12801 X30.684 Z-38.076
N12802 X29.754 Z-38.822
N12803 X28.495 Z-39.933
N12804 X27.236 Z-41.01
N12805 X26.035 Z-41.969
N12806 X25.092 Z-42.672
N12807 X24.148 Z-43.334
N12808 X23.205 Z-43.96
N12809 X22.262 Z-44.551
N12810 X21.345 Z-45.094
N12811 X19.513 Z-46.09
N12812 X17.658 Z-46.984
N12813 X15.783 Z-47.781
N12814 X14.845 Z-48.14
N12815 X13.001 Z-48.775
N12816 X11.158 Z-49.318
N12817 X9.273 Z-49.782
N12818 X7.422 Z-50.151
N12819 X5.554 Z-50.437
N12820 X3.719 Z-50.637
N12821 X1.862 Z-50.759
N12822 X0. Z-50.8
N12823 X-1.862 Z-50.759
N12824 X-3.719 Z-50.637
N12825 X-5.554 Z-50.437
N12826 X-7.422 Z-50.151
N12827 X-9.273 Z-49.782
N12828 X-11.158 Z-49.318
N12829 X-13.001 Z-48.775
N12830 X-14.845 Z-48.14
N12831 X-16.721 Z-47.395
N12832 X-18.596 Z-46.545
N12833 X-20.429 Z-45.606
N12834 X-21.345 Z-45.094
N12835 X-22.262 Z-44.551
N12836 X-23.205 Z-43.96
N12837 X-24.148 Z-43.334
N12838 X-25.092 Z-42.672
N12839 X-26.035 Z-41.969
N12840 X-27.236 Z-41.01
N12841 X-28.495 Z-39.933
N12842 X-29.754 Z-38.822
N12843 X-30.684 Z-38.076
N12844 X-31.614 Z-37.383
N12845 X-32.544 Z-36.748
N12846 X-33.474 Z-36.168
N12847 X-34.403 Z-35.633
N12848 X-35.333 Z-35.157
N12849 X-36.263 Z-34.733
N12850 X-37.193 Z-34.369
N12851 X-38.123 Z-34.076
N12852 X-39.053 Z-33.853
N12853 X-39.517 Z-33.775
N12854 X-39.982 Z-33.724
N12855 X-40.912 Z-33.697
N12856 X-119.003
N12857 X-119.017 Z-10.557
N12858 X-119.133 Z-9.454
N12859 X-119.366 Z-8.342
N12860 X-119.598 Z-7.568
N12861 X-119.947 Z-6.674
N12862 X-120.412 Z-5.739
N12863 X-120.877 Z-4.981
N12864 X-121.342 Z-4.335
N12865 X-121.807 Z-3.769
N12866 X-122.272 Z-3.278
N12867 X-122.736 Z-2.837
N12868 X-123.201 Z-2.444
N12869 X-123.666 Z-2.094
N12870 X-124.131 Z-1.776
N12871 X-125.061 Z-1.24
N12872 X-125.526 Z-1.015
N12873 X-126.456 Z-.638
N12874 X-127.386 Z-.354
N12875 X-128.315 Z-.156
N12876 X-129.245 Z-.039
N12877 X-130.175 Z0.
N12878 Y-35.425
N12879 X-129.245 Z-.039
N12880 X-128.315 Z-.156
N12881 X-127.386 Z-.354
N12882 X-126.456 Z-.638
N12883 X-125.526 Z-1.015
N12884 X-125.061 Z-1.24
N12885 X-124.131 Z-1.776
N12886 X-123.666 Z-2.094
N12887 X-123.201 Z-2.444
N12888 X-122.736 Z-2.837
N12889 X-122.272 Z-3.278
N12890 X-121.807 Z-3.769
N12891 X-121.342 Z-4.335
N12892 X-120.877 Z-4.981
N12893 X-120.412 Z-5.739
N12894 X-119.947 Z-6.674
N12895 X-119.598 Z-7.568
N12896 X-119.366 Z-8.342
N12897 X-119.133 Z-9.454
N12898 X-119.017 Z-10.557
N12899 X-119.003 Z-32.017
N12900 X-41.842 Z-32.02
N12901 X-41.377 Z-32.048
N12902 X-40.912 Z-32.107
N12903 X-40.447 Z-32.195
N12904 X-39.982 Z-32.309
N12905 X-39.053 Z-32.59
N12906 X-38.123 Z-32.955
N12907 X-37.193 Z-33.376
N12908 X-36.263 Z-33.861
N12909 X-35.333 Z-34.404
N12910 X-34.403 Z-34.991
N12911 X-33.474 Z-35.634
N12912 X-32.544 Z-36.332
N12913 X-31.614 Z-37.078
N12914 X-30.684 Z-37.885
N12915 X-28.816 Z-39.641
N12916 X-27.877 Z-40.472
N12917 X-26.956 Z-41.241
N12918 X-26.035 Z-41.969
N12919 X-25.092 Z-42.672
N12920 X-24.148 Z-43.334
N12921 X-23.205 Z-43.96
N12922 X-22.262 Z-44.551
N12923 X-21.345 Z-45.094
N12924 X-20.429 Z-45.606
N12925 X-18.596 Z-46.545
N12926 X-16.721 Z-47.395
N12927 X-14.845 Z-48.14
N12928 X-13.001 Z-48.775
N12929 X-11.158 Z-49.318
N12930 X-9.273 Z-49.782
N12931 X-7.422 Z-50.151
N12932 X-5.554 Z-50.437
N12933 X-3.719 Z-50.637
N12934 X-1.862 Z-50.759
N12935 X0. Z-50.8
N12936 X1.862 Z-50.759
N12937 X3.719 Z-50.637
N12938 X5.554 Z-50.437
N12939 X7.422 Z-50.151
N12940 X9.273 Z-49.782
N12941 X11.158 Z-49.318
N12942 X13.001 Z-48.775
N12943 X14.845 Z-48.14
N12944 X15.783 Z-47.781
N12945 X17.658 Z-46.984
N12946 X19.513 Z-46.09
N12947 X21.345 Z-45.094
N12948 X22.262 Z-44.551
N12949 X23.205 Z-43.96
N12950 X24.148 Z-43.334
N12951 X25.092 Z-42.672
N12952 X26.035 Z-41.969
N12953 X26.956 Z-41.241
N12954 X27.877 Z-40.472
N12955 X28.816 Z-39.641
N12956 X30.684 Z-37.885
N12957 X31.614 Z-37.078
N12958 X32.544 Z-36.332
N12959 X33.474 Z-35.634
N12960 X34.403 Z-34.991
N12961 X35.333 Z-34.404
N12962 X36.263 Z-33.861
N12963 X37.193 Z-33.376
N12964 X38.123 Z-32.955
N12965 X39.053 Z-32.59
N12966 X39.982 Z-32.309
N12967 X40.447 Z-32.195
N12968 X40.912 Z-32.107
N12969 X41.395 Z-32.046
N12970 X41.878 Z-32.02
N12971 X119.003 Z-32.017
N12972 X119.01 Z-10.724
N12973 X119.104 Z-9.653
N12974 X119.308 Z-8.571
N12975 X119.598 Z-7.568
N12976 X119.947 Z-6.674
N12977 X120.179 Z-6.185
N12978 X120.644 Z-5.343
N12979 X121.109 Z-4.641
N12980 X121.807 Z-3.769
N12981 X122.272 Z-3.278
N12982 X122.736 Z-2.837
N12983 X123.201 Z-2.444
N12984 X123.666 Z-2.094
N12985 X124.131 Z-1.776
N12986 X125.061 Z-1.24
N12987 X125.526 Z-1.015
N12988 X126.456 Z-.638
N12989 X127.386 Z-.354
N12990 X128.315 Z-.156
N12991 X129.245 Z-.039
N12992 X130.175 Z0.
N12993 Y-36.625
N12994 X129.245 Z-.039
N12995 X128.315 Z-.156
N12996 X127.386 Z-.354
N12997 X126.456 Z-.638
N12998 X125.526 Z-1.015
N12999 X125.061 Z-1.24
N13000 X124.131 Z-1.776
N13001 X123.666 Z-2.094
N13002 X123.201 Z-2.444
N13003 X122.736 Z-2.837
N13004 X122.272 Z-3.278
N13005 X121.807 Z-3.769
N13006 X121.109 Z-4.641
N13007 X120.644 Z-5.343
N13008 X120.179 Z-6.185
N13009 X119.947 Z-6.674
N13010 X119.598 Z-7.568
N13011 X119.308 Z-8.571
N13012 X119.104 Z-9.653
N13013 X119.01 Z-10.724
N13014 X119.003 Z-30.142
N13015 X43.237 Z-30.149
N13016 X42.772 Z-30.184
N13017 X42.307 Z-30.251
N13018 X41.842 Z-30.349
N13019 X40.912 Z-30.626
N13020 X39.982 Z-30.983
N13021 X39.053 Z-31.415
N13022 X38.123 Z-31.917
N13023 X37.193 Z-32.467
N13024 X36.263 Z-33.074
N13025 X35.333 Z-33.735
N13026 X34.403 Z-34.444
N13027 X33.474 Z-35.202
N13028 X32.544 Z-36.016
N13029 X31.614 Z-36.893
N13030 X29.754 Z-38.761
N13031 X28.824 Z-39.633
N13032 X27.895 Z-40.457
N13033 X26.965 Z-41.234
N13034 X26.035 Z-41.969
N13035 X25.092 Z-42.672
N13036 X24.148 Z-43.334
N13037 X23.205 Z-43.96
N13038 X22.262 Z-44.551
N13039 X21.345 Z-45.094
N13040 X19.513 Z-46.09
N13041 X17.658 Z-46.984
N13042 X15.783 Z-47.781
N13043 X14.845 Z-48.14
N13044 X13.001 Z-48.775
N13045 X11.158 Z-49.318
N13046 X9.273 Z-49.782
N13047 X7.422 Z-50.151
N13048 X5.554 Z-50.437
N13049 X3.719 Z-50.637
N13050 X1.862 Z-50.759
N13051 X0. Z-50.8
N13052 X-1.862 Z-50.759
N13053 X-3.719 Z-50.637
N13054 X-5.554 Z-50.437
N13055 X-7.422 Z-50.151
N13056 X-9.273 Z-49.782
N13057 X-11.158 Z-49.318
N13058 X-13.001 Z-48.775
N13059 X-14.845 Z-48.14
N13060 X-16.721 Z-47.395
N13061 X-18.596 Z-46.545
N13062 X-20.429 Z-45.606
N13063 X-21.345 Z-45.094
N13064 X-22.262 Z-44.551
N13065 X-23.205 Z-43.96
N13066 X-24.148 Z-43.334
N13067 X-25.092 Z-42.672
N13068 X-26.035 Z-41.969
N13069 X-26.965 Z-41.234
N13070 X-27.895 Z-40.457
N13071 X-28.824 Z-39.633
N13072 X-29.754 Z-38.761
N13073 X-31.614 Z-36.893
N13074 X-32.544 Z-36.016
N13075 X-33.474 Z-35.202
N13076 X-34.403 Z-34.444
N13077 X-35.333 Z-33.735
N13078 X-36.263 Z-33.074
N13079 X-37.193 Z-32.467
N13080 X-38.123 Z-31.917
N13081 X-39.053 Z-31.415
N13082 X-39.982 Z-30.983
N13083 X-40.912 Z-30.626
N13084 X-41.427 Z-30.462
N13085 X-41.943 Z-30.326
N13086 X-42.458 Z-30.226
N13087 X-42.973 Z-30.166
N13088 X-48.351 Z-30.142
N13089 X-119.003
N13090 X-119.017 Z-10.557
N13091 X-119.133 Z-9.454
N13092 X-119.366 Z-8.342
N13093 X-119.598 Z-7.568
N13094 X-119.947 Z-6.674
N13095 X-120.412 Z-5.739
N13096 X-120.877 Z-4.981
N13097 X-121.342 Z-4.335
N13098 X-121.807 Z-3.769
N13099 X-122.272 Z-3.278
N13100 X-122.736 Z-2.837
N13101 X-123.201 Z-2.444
N13102 X-123.666 Z-2.094
N13103 X-124.131 Z-1.776
N13104 X-125.061 Z-1.24
N13105 X-125.526 Z-1.015
N13106 X-126.456 Z-.638
N13107 X-127.386 Z-.354
N13108 X-128.315 Z-.156
N13109 X-129.245 Z-.039
N13110 X-130.175 Z0.
N13111 Y-37.825
N13112 X-129.245 Z-.039
N13113 X-128.315 Z-.156
N13114 X-127.386 Z-.354
N13115 X-126.456 Z-.638
N13116 X-125.526 Z-1.015
N13117 X-125.061 Z-1.24
N13118 X-124.131 Z-1.776
N13119 X-123.666 Z-2.094
N13120 X-123.201 Z-2.444
N13121 X-122.736 Z-2.837
N13122 X-122.272 Z-3.278
N13123 X-121.807 Z-3.769
N13124 X-121.342 Z-4.335
N13125 X-120.877 Z-4.981
N13126 X-120.412 Z-5.739
N13127 X-119.947 Z-6.674
N13128 X-119.598 Z-7.568
N13129 X-119.366 Z-8.342
N13130 X-119.133 Z-9.454
N13131 X-119.017 Z-10.557
N13132 X-119.003 Z-28.02
N13133 X-44.631 Z-28.027
N13134 X-44.167 Z-28.075
N13135 X-43.237 Z-28.27
N13136 X-42.772 Z-28.412
N13137 X-41.842 Z-28.777
N13138 X-40.912 Z-29.222
N13139 X-39.982 Z-29.738
N13140 X-39.053 Z-30.32
N13141 X-38.123 Z-30.958
N13142 X-37.193 Z-31.641
N13143 X-36.263 Z-32.375
N13144 X-35.333 Z-33.16
N13145 X-34.403 Z-33.996
N13146 X-32.91 Z-35.449
N13147 X-31.221 Z-37.271
N13148 X-30.095 Z-38.429
N13149 X-28.969 Z-39.502
N13150 X-28.235 Z-40.161
N13151 X-26.768 Z-41.394
N13152 X-25.092 Z-42.672
N13153 X-24.148 Z-43.334
N13154 X-23.205 Z-43.96
N13155 X-22.262 Z-44.551
N13156 X-21.345 Z-45.094
N13157 X-20.429 Z-45.606
N13158 X-18.596 Z-46.545
N13159 X-16.721 Z-47.395
N13160 X-14.845 Z-48.14
N13161 X-13.001 Z-48.775
N13162 X-11.158 Z-49.318
N13163 X-9.273 Z-49.782
N13164 X-7.422 Z-50.151
N13165 X-5.554 Z-50.437
N13166 X-3.719 Z-50.637
N13167 X-1.862 Z-50.759
N13168 X0. Z-50.8
N13169 X1.862 Z-50.759
N13170 X3.719 Z-50.637
N13171 X5.554 Z-50.437
N13172 X7.422 Z-50.151
N13173 X9.273 Z-49.782
N13174 X11.158 Z-49.318
N13175 X13.001 Z-48.775
N13176 X14.845 Z-48.14
N13177 X15.783 Z-47.781
N13178 X17.658 Z-46.984
N13179 X19.513 Z-46.09
N13180 X21.345 Z-45.094
N13181 X22.262 Z-44.551
N13182 X23.205 Z-43.96
N13183 X24.148 Z-43.334
N13184 X25.092 Z-42.672
N13185 X26.035 Z-41.969
N13186 X27.502 Z-40.792
N13187 X28.969 Z-39.502
N13188 X30.095 Z-38.429
N13189 X30.658 Z-37.863
N13190 X32.91 Z-35.449
N13191 X34.403 Z-33.996
N13192 X35.333 Z-33.16
N13193 X36.263 Z-32.375
N13194 X37.193 Z-31.641
N13195 X38.123 Z-30.958
N13196 X39.053 Z-30.32
N13197 X39.982 Z-29.738
N13198 X40.912 Z-29.222
N13199 X41.842 Z-28.777
N13200 X42.772 Z-28.412
N13201 X43.237 Z-28.27
N13202 X44.167 Z-28.075
N13203 X44.631 Z-28.027
N13204 X119.003 Z-28.02
N13205 X119.01 Z-10.724
N13206 X119.104 Z-9.653
N13207 X119.308 Z-8.571
N13208 X119.598 Z-7.568
N13209 X119.947 Z-6.674
N13210 X120.179 Z-6.185
N13211 X120.644 Z-5.343
N13212 X121.109 Z-4.641
N13213 X121.807 Z-3.769
N13214 X122.272 Z-3.278
N13215 X122.736 Z-2.837
N13216 X123.201 Z-2.444
N13217 X123.666 Z-2.094
N13218 X124.131 Z-1.776
N13219 X125.061 Z-1.24
N13220 X125.526 Z-1.015
N13221 X126.456 Z-.638
N13222 X127.386 Z-.354
N13223 X128.315 Z-.156
N13224 X129.245 Z-.039
N13225 X130.175 Z0.
N13226 Y-39.025
N13227 X129.245 Z-.039
N13228 X128.315 Z-.156
N13229 X127.386 Z-.354
N13230 X126.456 Z-.638
N13231 X125.526 Z-1.015
N13232 X125.061 Z-1.24
N13233 X124.131 Z-1.776
N13234 X123.666 Z-2.094
N13235 X123.201 Z-2.444
N13236 X122.736 Z-2.837
N13237 X122.272 Z-3.278
N13238 X121.807 Z-3.769
N13239 X121.109 Z-4.641
N13240 X120.644 Z-5.343
N13241 X120.179 Z-6.185
N13242 X119.947 Z-6.674
N13243 X119.598 Z-7.568
N13244 X119.308 Z-8.571
N13245 X119.104 Z-9.653
N13246 X119.01 Z-10.724
N13247 X119.003 Z-25.57
N13248 X46.491
N13249 X46.026 Z-25.584
N13250 X45.561 Z-25.637
N13251 X45.096 Z-25.733
N13252 X44.631 Z-25.871
N13253 X43.702 Z-26.239
N13254 X43.237 Z-26.462
N13255 X42.772 Z-26.714
N13256 X41.842 Z-27.263
N13257 X40.912 Z-27.885
N13258 X39.982 Z-28.567
N13259 X39.053 Z-29.301
N13260 X38.123 Z-30.082
N13261 X37.193 Z-30.904
N13262 X36.263 Z-31.774
N13263 X35.333 Z-32.693
N13264 X34.403 Z-33.665
N13265 X33.474 Z-34.698
N13266 X32.503 Z-35.84
N13267 X31.532 Z-36.939
N13268 X30.561 Z-37.961
N13269 X29.59 Z-38.919
N13270 X28.701 Z-39.746
N13271 X27.812 Z-40.528
N13272 X26.924 Z-41.268
N13273 X26.035 Z-41.969
N13274 X25.092 Z-42.672
N13275 X24.148 Z-43.334
N13276 X23.205 Z-43.96
N13277 X22.262 Z-44.551
N13278 X21.345 Z-45.094
N13279 X19.513 Z-46.09
N13280 X17.658 Z-46.984
N13281 X15.783 Z-47.781
N13282 X14.845 Z-48.14
N13283 X13.001 Z-48.775
N13284 X11.158 Z-49.318
N13285 X9.273 Z-49.782
N13286 X7.422 Z-50.151
N13287 X5.554 Z-50.437
N13288 X3.719 Z-50.637
N13289 X1.862 Z-50.759
N13290 X0. Z-50.8
N13291 X-1.862 Z-50.759
N13292 X-3.719 Z-50.637
N13293 X-5.554 Z-50.437
N13294 X-7.422 Z-50.151
N13295 X-9.273 Z-49.782
N13296 X-11.158 Z-49.318
N13297 X-13.001 Z-48.775
N13298 X-14.845 Z-48.14
N13299 X-16.721 Z-47.395
N13300 X-18.596 Z-46.545
N13301 X-20.429 Z-45.606
N13302 X-21.345 Z-45.094
N13303 X-22.262 Z-44.551
N13304 X-23.205 Z-43.96
N13305 X-24.148 Z-43.334
N13306 X-25.092 Z-42.672
N13307 X-26.035 Z-41.969
N13308 X-26.924 Z-41.268
N13309 X-27.812 Z-40.528
N13310 X-28.701 Z-39.746
N13311 X-29.59 Z-38.919
N13312 X-30.561 Z-37.961
N13313 X-31.532 Z-36.939
N13314 X-32.503 Z-35.84
N13315 X-33.474 Z-34.698
N13316 X-34.403 Z-33.665
N13317 X-35.333 Z-32.693
N13318 X-36.263 Z-31.774
N13319 X-37.193 Z-30.904
N13320 X-38.123 Z-30.082
N13321 X-39.053 Z-29.301
N13322 X-39.982 Z-28.567
N13323 X-40.912 Z-27.885
N13324 X-41.842 Z-27.263
N13325 X-42.772 Z-26.714
N13326 X-43.237 Z-26.462
N13327 X-43.702 Z-26.239
N13328 X-44.631 Z-25.871
N13329 X-45.096 Z-25.733
N13330 X-45.561 Z-25.637
N13331 X-46.026 Z-25.584
N13332 X-119.003 Z-25.57
N13333 X-119.017 Z-10.557
N13334 X-119.133 Z-9.454
N13335 X-119.366 Z-8.342
N13336 X-119.598 Z-7.568
N13337 X-119.947 Z-6.674
N13338 X-120.412 Z-5.739
N13339 X-120.877 Z-4.981
N13340 X-121.342 Z-4.335
N13341 X-121.807 Z-3.769
N13342 X-122.272 Z-3.278
N13343 X-122.736 Z-2.837
N13344 X-123.201 Z-2.444
N13345 X-123.666 Z-2.094
N13346 X-124.131 Z-1.776
N13347 X-125.061 Z-1.24
N13348 X-125.526 Z-1.015
N13349 X-126.456 Z-.638
N13350 X-127.386 Z-.354
N13351 X-128.315 Z-.156
N13352 X-129.245 Z-.039
N13353 X-130.175 Z0.
N13354 Y-40.225
N13355 X-129.245 Z-.039
N13356 X-128.315 Z-.156
N13357 X-127.386 Z-.354
N13358 X-126.456 Z-.638
N13359 X-125.526 Z-1.015
N13360 X-125.061 Z-1.24
N13361 X-124.131 Z-1.776
N13362 X-123.666 Z-2.094
N13363 X-123.201 Z-2.444
N13364 X-122.736 Z-2.837
N13365 X-122.272 Z-3.278
N13366 X-121.807 Z-3.769
N13367 X-121.342 Z-4.335
N13368 X-120.877 Z-4.981
N13369 X-120.412 Z-5.739
N13370 X-119.947 Z-6.674
N13371 X-119.598 Z-7.568
N13372 X-119.366 Z-8.342
N13373 X-119.133 Z-9.454
N13374 X-119.017 Z-10.557
N13375 X-119.003 Z-22.613
N13376 X-48.351
N13377 X-47.421 Z-22.632
N13378 X-46.956 Z-22.709
N13379 X-46.491 Z-22.831
N13380 X-46.026 Z-23.002
N13381 X-45.096 Z-23.458
N13382 X-44.631 Z-23.729
N13383 X-43.702 Z-24.346
N13384 X-42.772 Z-25.043
N13385 X-41.842 Z-25.802
N13386 X-40.912 Z-26.612
N13387 X-39.982 Z-27.466
N13388 X-39.053 Z-28.361
N13389 X-38.123 Z-29.295
N13390 X-37.193 Z-30.269
N13391 X-36.263 Z-31.287
N13392 X-35.333 Z-32.356
N13393 X-34.403 Z-33.484
N13394 X-33.474 Z-34.669
N13395 X-32.518 Z-35.823
N13396 X-31.562 Z-36.905
N13397 X-30.606 Z-37.915
N13398 X-29.65 Z-38.861
N13399 X-28.746 Z-39.704
N13400 X-27.843 Z-40.502
N13401 X-26.939 Z-41.256
N13402 X-26.035 Z-41.969
N13403 X-25.092 Z-42.672
N13404 X-24.148 Z-43.334
N13405 X-23.205 Z-43.96
N13406 X-22.262 Z-44.551
N13407 X-21.345 Z-45.094
N13408 X-20.429 Z-45.606
N13409 X-18.596 Z-46.545
N13410 X-16.721 Z-47.395
N13411 X-14.845 Z-48.14
N13412 X-13.001 Z-48.775
N13413 X-11.158 Z-49.318
N13414 X-9.273 Z-49.782
N13415 X-7.422 Z-50.151
N13416 X-5.554 Z-50.437
N13417 X-3.719 Z-50.637
N13418 X-1.862 Z-50.759
N13419 X0. Z-50.8
N13420 X1.862 Z-50.759
N13421 X3.719 Z-50.637
N13422 X5.554 Z-50.437
N13423 X7.422 Z-50.151
N13424 X9.273 Z-49.782
N13425 X11.158 Z-49.318
N13426 X13.001 Z-48.775
N13427 X14.845 Z-48.14
N13428 X15.783 Z-47.781
N13429 X17.658 Z-46.984
N13430 X19.513 Z-46.09
N13431 X21.345 Z-45.094
N13432 X22.262 Z-44.551
N13433 X23.205 Z-43.96
N13434 X24.148 Z-43.334
N13435 X25.092 Z-42.672
N13436 X26.035 Z-41.969
N13437 X26.939 Z-41.256
N13438 X27.843 Z-40.502
N13439 X28.746 Z-39.704
N13440 X29.65 Z-38.861
N13441 X30.606 Z-37.915
N13442 X31.562 Z-36.905
N13443 X32.518 Z-35.823
N13444 X33.474 Z-34.669
N13445 X34.403 Z-33.484
N13446 X35.333 Z-32.356
N13447 X36.263 Z-31.287
N13448 X37.193 Z-30.269
N13449 X38.123 Z-29.295
N13450 X39.053 Z-28.361
N13451 X39.982 Z-27.466
N13452 X40.912 Z-26.612
N13453 X41.842 Z-25.802
N13454 X42.772 Z-25.043
N13455 X43.702 Z-24.346
N13456 X44.631 Z-23.729
N13457 X45.096 Z-23.458
N13458 X46.026 Z-23.002
N13459 X46.491 Z-22.831
N13460 X46.956 Z-22.709
N13461 X47.421 Z-22.632
N13462 X48.351 Z-22.613
N13463 X119.003
N13464 X119.01 Z-10.724
N13465 X119.104 Z-9.653
N13466 X119.308 Z-8.571
N13467 X119.598 Z-7.568
N13468 X119.947 Z-6.674
N13469 X120.179 Z-6.185
N13470 X120.644 Z-5.343
N13471 X121.109 Z-4.641
N13472 X121.807 Z-3.769
N13473 X122.272 Z-3.278
N13474 X122.736 Z-2.837
N13475 X123.201 Z-2.444
N13476 X123.666 Z-2.094
N13477 X124.131 Z-1.776
N13478 X125.061 Z-1.24
N13479 X125.526 Z-1.015
N13480 X126.456 Z-.638
N13481 X127.386 Z-.354
N13482 X128.315 Z-.156
N13483 X129.245 Z-.039
N13484 X130.175 Z0.
N13485 Y-41.425
N13486 X129.245 Z-.039
N13487 X128.315 Z-.156
N13488 X127.386 Z-.354
N13489 X126.456 Z-.638
N13490 X125.526 Z-1.015
N13491 X125.061 Z-1.24
N13492 X124.131 Z-1.776
N13493 X123.666 Z-2.094
N13494 X123.201 Z-2.444
N13495 X122.736 Z-2.837
N13496 X122.272 Z-3.278
N13497 X121.807 Z-3.769
N13498 X121.109 Z-4.641
N13499 X120.644 Z-5.343
N13500 X120.179 Z-6.185
N13501 X119.947 Z-6.674
N13502 X119.598 Z-7.568
N13503 X119.308 Z-8.571
N13504 X119.104 Z-9.653
N13505 X119.01 Z-10.724
N13506 X119.003 Z-18.75
N13507 X49.282
N13508 X48.816 Z-18.78
N13509 X48.351 Z-18.897
N13510 X47.886 Z-19.072
N13511 X47.421 Z-19.314
N13512 X46.491 Z-19.935
N13513 X45.561 Z-20.689
N13514 X44.631 Z-21.532
N13515 X43.702 Z-22.437
N13516 X41.842 Z-24.374
N13517 X39.982 Z-26.434
N13518 X38.123 Z-28.608
N13519 X37.193 Z-29.746
N13520 X36.263 Z-30.928
N13521 X35.333 Z-32.168
N13522 X34.403 Z-33.455
N13523 X33.474 Z-34.669
N13524 X32.518 Z-35.823
N13525 X31.562 Z-36.905
N13526 X30.606 Z-37.915
N13527 X29.65 Z-38.861
N13528 X28.746 Z-39.704
N13529 X27.843 Z-40.502
N13530 X26.939 Z-41.256
N13531 X26.035 Z-41.969
N13532 X25.092 Z-42.672
N13533 X24.148 Z-43.334
N13534 X23.205 Z-43.96
N13535 X22.262 Z-44.551
N13536 X21.345 Z-45.094
N13537 X19.513 Z-46.09
N13538 X17.658 Z-46.984
N13539 X15.783 Z-47.781
N13540 X14.845 Z-48.14
N13541 X13.001 Z-48.775
N13542 X11.158 Z-49.318
N13543 X9.273 Z-49.782
N13544 X7.422 Z-50.151
N13545 X5.554 Z-50.437
N13546 X3.719 Z-50.637
N13547 X1.862 Z-50.759
N13548 X0. Z-50.8
N13549 X-1.862 Z-50.759
N13550 X-3.719 Z-50.637
N13551 X-5.554 Z-50.437
N13552 X-7.422 Z-50.151
N13553 X-9.273 Z-49.782
N13554 X-11.158 Z-49.318
N13555 X-13.001 Z-48.775
N13556 X-14.845 Z-48.14
N13557 X-16.721 Z-47.395
N13558 X-18.596 Z-46.545
N13559 X-20.429 Z-45.606
N13560 X-21.345 Z-45.094
N13561 X-22.262 Z-44.551
N13562 X-23.205 Z-43.96
N13563 X-24.148 Z-43.334
N13564 X-25.092 Z-42.672
N13565 X-26.035 Z-41.969
N13566 X-26.939 Z-41.256
N13567 X-27.843 Z-40.502
N13568 X-28.746 Z-39.704
N13569 X-29.65 Z-38.861
N13570 X-30.606 Z-37.915
N13571 X-31.562 Z-36.905
N13572 X-32.996 Z-35.256
N13573 X-33.474 Z-34.669
N13574 X-34.403 Z-33.455
N13575 X-35.333 Z-32.168
N13576 X-36.263 Z-30.928
N13577 X-37.193 Z-29.746
N13578 X-39.053 Z-27.507
N13579 X-40.912 Z-25.39
N13580 X-42.772 Z-23.388
N13581 X-43.702 Z-22.437
N13582 X-44.631 Z-21.532
N13583 X-45.561 Z-20.689
N13584 X-46.491 Z-19.935
N13585 X-47.421 Z-19.314
N13586 X-47.886 Z-19.072
N13587 X-48.351 Z-18.897
N13588 X-48.816 Z-18.78
N13589 X-49.282 Z-18.75
N13590 X-119.003
N13591 X-119.017 Z-10.557
N13592 X-119.133 Z-9.454
N13593 X-119.366 Z-8.342
N13594 X-119.598 Z-7.568
N13595 X-119.947 Z-6.674
N13596 X-120.412 Z-5.739
N13597 X-120.877 Z-4.981
N13598 X-121.342 Z-4.335
N13599 X-121.807 Z-3.769
N13600 X-122.272 Z-3.278
N13601 X-122.736 Z-2.837
N13602 X-123.201 Z-2.444
N13603 X-123.666 Z-2.094
N13604 X-124.131 Z-1.776
N13605 X-125.061 Z-1.24
N13606 X-125.526 Z-1.015
N13607 X-126.456 Z-.638
N13608 X-127.386 Z-.354
N13609 X-128.315 Z-.156
N13610 X-129.245 Z-.039
N13611 X-130.175 Z0.
N13612 Y-42.625
N13613 X-129.245 Z-.039
N13614 X-128.315 Z-.156
N13615 X-127.386 Z-.354
N13616 X-126.456 Z-.638
N13617 X-125.526 Z-1.015
N13618 X-125.061 Z-1.24
N13619 X-124.131 Z-1.776
N13620 X-123.666 Z-2.094
N13621 X-123.201 Z-2.444
N13622 X-122.736 Z-2.837
N13623 X-122.272 Z-3.278
N13624 X-121.807 Z-3.769
N13625 X-121.342 Z-4.335
N13626 X-120.877 Z-4.981
N13627 X-120.412 Z-5.739
N13628 X-119.947 Z-6.674
N13629 X-119.598 Z-7.568
N13630 X-119.366 Z-8.342
N13631 X-119.133 Z-9.454
N13632 X-119.046 Z-10.182
N13633 X-119.003 Z-11.833
N13634 X-50.443 Z-11.848
N13635 X-50.21 Z-11.927
N13636 X-49.978 Z-12.071
N13637 X-49.513 Z-12.486
N13638 X-49.281 Z-12.733
N13639 X-48.583 Z-13.613
N13640 X-46.411 Z-16.693
N13641 X-44.471 Z-19.412
N13642 X-39.053 Z-26.76
N13643 X-37.193 Z-29.367
N13644 X-35.223 Z-32.308
N13645 X-34.566 Z-33.233
N13646 X-33.474 Z-34.669
N13647 X-32.518 Z-35.823
N13648 X-31.562 Z-36.905
N13649 X-30.606 Z-37.915
N13650 X-29.65 Z-38.861
N13651 X-28.746 Z-39.704
N13652 X-27.843 Z-40.502
N13653 X-26.939 Z-41.256
N13654 X-26.035 Z-41.969
N13655 X-25.092 Z-42.672
N13656 X-24.148 Z-43.334
N13657 X-23.205 Z-43.96
N13658 X-22.262 Z-44.551
N13659 X-21.345 Z-45.094
N13660 X-20.429 Z-45.606
N13661 X-18.596 Z-46.545
N13662 X-16.721 Z-47.395
N13663 X-14.845 Z-48.14
N13664 X-13.001 Z-48.775
N13665 X-11.158 Z-49.318
N13666 X-9.273 Z-49.782
N13667 X-7.422 Z-50.151
N13668 X-5.554 Z-50.437
N13669 X-3.719 Z-50.637
N13670 X-1.862 Z-50.759
N13671 X0. Z-50.8
N13672 X1.862 Z-50.759
N13673 X3.719 Z-50.637
N13674 X5.554 Z-50.437
N13675 X7.422 Z-50.151
N13676 X9.273 Z-49.782
N13677 X11.158 Z-49.318
N13678 X13.001 Z-48.775
N13679 X14.845 Z-48.14
N13680 X15.783 Z-47.781
N13681 X17.658 Z-46.984
N13682 X19.513 Z-46.09
N13683 X21.345 Z-45.094
N13684 X22.262 Z-44.551
N13685 X23.205 Z-43.96
N13686 X24.148 Z-43.334
N13687 X25.092 Z-42.672
N13688 X26.035 Z-41.969
N13689 X26.939 Z-41.256
N13690 X27.843 Z-40.502
N13691 X28.746 Z-39.704
N13692 X29.65 Z-38.861
N13693 X30.606 Z-37.915
N13694 X31.562 Z-36.905
N13695 X32.518 Z-35.823
N13696 X33.474 Z-34.669
N13697 X34.02 Z-33.966
N13698 X35.223 Z-32.308
N13699 X36.536 Z-30.332
N13700 X38.123 Z-28.045
N13701 X44.471 Z-19.412
N13702 X46.411 Z-16.693
N13703 X47.381 Z-15.298
N13704 X48.645 Z-13.53
N13705 X49.234 Z-12.788
N13706 X49.528 Z-12.471
N13707 X49.822 Z-12.201
N13708 X50.117 Z-11.978
N13709 X50.264 Z-11.903
N13710 X50.411 Z-11.855
N13711 X50.705 Z-11.833
N13712 X119.003
N13713 X119.01 Z-10.724
N13714 X119.104 Z-9.653
N13715 X119.308 Z-8.571
N13716 X119.598 Z-7.568
N13717 X119.947 Z-6.674
N13718 X120.179 Z-6.185
N13719 X120.644 Z-5.343
N13720 X121.109 Z-4.641
N13721 X121.807 Z-3.769
N13722 X122.272 Z-3.278
N13723 X122.736 Z-2.837
N13724 X123.201 Z-2.444
N13725 X123.666 Z-2.094
N13726 X124.131 Z-1.776
N13727 X125.061 Z-1.24
N13728 X125.526 Z-1.015
N13729 X126.456 Z-.638
N13730 X127.386 Z-.354
N13731 X128.315 Z-.156
N13732 X129.245 Z-.039
N13733 X130.175 Z0.
N13734 Y-43.825
N13735 X129.245 Z-.039
N13736 X128.315 Z-.156
N13737 X127.386 Z-.354
N13738 X126.456 Z-.638
N13739 X125.526 Z-1.015
N13740 X125.061 Z-1.24
N13741 X124.131 Z-1.776
N13742 X123.666 Z-2.094
N13743 X123.201 Z-2.444
N13744 X122.736 Z-2.837
N13745 X122.272 Z-3.278
N13746 X121.807 Z-3.769
N13747 X121.109 Z-4.641
N13748 X120.644 Z-5.343
N13749 X120.121 Z-6.299
N13750 X120.063 Z-6.306
N13751 X51.14 Z-6.312
N13752 X50.675 Z-6.326
N13753 X50.21 Z-6.393
N13754 X49.745 Z-6.523
N13755 X49.281 Z-6.72
N13756 X48.816 Z-6.984
N13757 X48.351 Z-7.333
N13758 X47.886 Z-7.795
N13759 X47.653 Z-8.075
N13760 X47.421 Z-8.416
N13761 X47.188 Z-8.818
N13762 X46.898 Z-9.511
N13763 X46.724 Z-10.175
N13764 X46.491 Z-11.364
N13765 X46.259 Z-12.284
N13766 X46.026 Z-13.064
N13767 X45.445 Z-14.675
N13768 X45.096 Z-15.505
N13769 X44.631 Z-16.528
N13770 X43.702 Z-18.367
N13771 X42.772 Z-20.047
N13772 X40.912 Z-23.154
N13773 X38.123 Z-27.641
N13774 X36.263 Z-30.727
N13775 X35.333 Z-32.15
N13776 X34.403 Z-33.455
N13777 X33.474 Z-34.669
N13778 X32.518 Z-35.823
N13779 X31.562 Z-36.905
N13780 X30.606 Z-37.915
N13781 X29.65 Z-38.861
N13782 X28.746 Z-39.704
N13783 X27.843 Z-40.502
N13784 X26.939 Z-41.256
N13785 X26.035 Z-41.969
N13786 X25.092 Z-42.672
N13787 X24.148 Z-43.334
N13788 X23.205 Z-43.96
N13789 X22.262 Z-44.551
N13790 X21.345 Z-45.094
N13791 X19.513 Z-46.09
N13792 X17.658 Z-46.984
N13793 X15.783 Z-47.781
N13794 X14.845 Z-48.14
N13795 X13.001 Z-48.775
N13796 X11.158 Z-49.318
N13797 X9.273 Z-49.782
N13798 X7.422 Z-50.151
N13799 X5.554 Z-50.437
N13800 X3.719 Z-50.637
N13801 X1.862 Z-50.759
N13802 X0. Z-50.8
N13803 X-1.862 Z-50.759
N13804 X-3.719 Z-50.637
N13805 X-5.554 Z-50.437
N13806 X-7.422 Z-50.151
N13807 X-9.273 Z-49.782
N13808 X-11.158 Z-49.318
N13809 X-13.001 Z-48.775
N13810 X-14.845 Z-48.14
N13811 X-16.721 Z-47.395
N13812 X-18.596 Z-46.545
N13813 X-20.429 Z-45.606
N13814 X-21.345 Z-45.094
N13815 X-22.262 Z-44.551
N13816 X-23.205 Z-43.96
N13817 X-24.148 Z-43.334
N13818 X-25.092 Z-42.672
N13819 X-26.035 Z-41.969
N13820 X-26.939 Z-41.256
N13821 X-27.843 Z-40.502
N13822 X-28.746 Z-39.704
N13823 X-29.65 Z-38.861
N13824 X-30.606 Z-37.915
N13825 X-31.562 Z-36.905
N13826 X-32.518 Z-35.823
N13827 X-33.474 Z-34.669
N13828 X-34.868 Z-32.817
N13829 X-35.798 Z-31.453
N13830 X-36.263 Z-30.727
N13831 X-38.123 Z-27.641
N13832 X-40.912 Z-23.154
N13833 X-42.772 Z-20.047
N13834 X-43.702 Z-18.367
N13835 X-44.631 Z-16.528
N13836 X-45.445 Z-14.675
N13837 X-45.794 Z-13.751
N13838 X-46.317 Z-12.087
N13839 X-46.527 Z-11.218
N13840 X-46.84 Z-9.698
N13841 X-46.956 Z-9.35
N13842 X-47.188 Z-8.818
N13843 X-47.421 Z-8.416
N13844 X-47.653 Z-8.075
N13845 X-48.118 Z-7.547
N13846 X-48.351 Z-7.333
N13847 X-48.816 Z-6.984
N13848 X-49.281 Z-6.72
N13849 X-49.745 Z-6.523
N13850 X-50.21 Z-6.393
N13851 X-50.675 Z-6.327
N13852 X-120.121 Z-6.299
N13853 X-120.412 Z-5.739
N13854 X-120.877 Z-4.981
N13855 X-121.342 Z-4.335
N13856 X-121.807 Z-3.769
N13857 X-122.272 Z-3.278
N13858 X-122.736 Z-2.837
N13859 X-123.201 Z-2.444
N13860 X-123.666 Z-2.094
N13861 X-124.131 Z-1.776
N13862 X-125.061 Z-1.24
N13863 X-125.526 Z-1.015
N13864 X-126.456 Z-.638
N13865 X-127.386 Z-.354
N13866 X-128.315 Z-.156
N13867 X-129.245 Z-.039
N13868 X-130.175 Z0.
N13869 Y-45.025
N13870 X-129.245 Z-.039
N13871 X-128.315 Z-.156
N13872 X-127.386 Z-.354
N13873 X-126.456 Z-.638
N13874 X-125.526 Z-1.015
N13875 X-125.061 Z-1.24
N13876 X-124.131 Z-1.776
N13877 X-123.666 Z-2.094
N13878 X-123.201 Z-2.444
N13879 X-122.736 Z-2.837
N13880 X-122.215 Z-3.337
N13881 X-121.694 Z-3.899
N13882 X-121.303 Z-4.365
N13883 X-51.14 Z-4.37
N13884 X-50.675 Z-4.405
N13885 X-50.21 Z-4.483
N13886 X-49.745 Z-4.608
N13887 X-49.281 Z-4.767
N13888 X-48.816 Z-4.967
N13889 X-48.351 Z-5.224
N13890 X-47.886 Z-5.537
N13891 X-47.421 Z-5.901
N13892 X-46.956 Z-6.353
N13893 X-46.724 Z-6.613
N13894 X-46.259 Z-7.231
N13895 X-46.026 Z-7.61
N13896 X-45.794 Z-8.043
N13897 X-45.561 Z-8.575
N13898 X-45.445 Z-8.898
N13899 X-45.271 Z-9.505
N13900 X-44.864 Z-11.947
N13901 X-44.439 Z-13.731
N13902 X-43.861 Z-15.569
N13903 X-43.42 Z-16.749
N13904 X-42.72 Z-18.432
N13905 X-41.945 Z-20.111
N13906 X-40.912 Z-22.186
N13907 X-37.532 Z-28.567
N13908 X-36.611 Z-30.166
N13909 X-35.996 Z-31.153
N13910 X-35.366 Z-32.104
N13911 X-34.735 Z-33.003
N13912 X-33.474 Z-34.669
N13913 X-32.518 Z-35.823
N13914 X-31.562 Z-36.905
N13915 X-30.606 Z-37.915
N13916 X-29.65 Z-38.861
N13917 X-28.746 Z-39.704
N13918 X-27.843 Z-40.502
N13919 X-26.939 Z-41.256
N13920 X-26.035 Z-41.969
N13921 X-25.092 Z-42.672
N13922 X-24.148 Z-43.334
N13923 X-23.205 Z-43.96
N13924 X-22.262 Z-44.551
N13925 X-21.345 Z-45.094
N13926 X-20.429 Z-45.606
N13927 X-18.596 Z-46.545
N13928 X-16.721 Z-47.395
N13929 X-14.845 Z-48.14
N13930 X-13.001 Z-48.775
N13931 X-11.158 Z-49.318
N13932 X-9.273 Z-49.782
N13933 X-7.422 Z-50.151
N13934 X-5.554 Z-50.437
N13935 X-3.719 Z-50.637
N13936 X-1.862 Z-50.759
N13937 X0. Z-50.8
N13938 X1.862 Z-50.759
N13939 X3.719 Z-50.637
N13940 X5.554 Z-50.437
N13941 X7.422 Z-50.151
N13942 X9.273 Z-49.782
N13943 X11.158 Z-49.318
N13944 X13.001 Z-48.775
N13945 X14.845 Z-48.14
N13946 X15.783 Z-47.781
N13947 X17.658 Z-46.984
N13948 X19.513 Z-46.09
N13949 X21.345 Z-45.094
N13950 X22.262 Z-44.551
N13951 X23.205 Z-43.96
N13952 X24.148 Z-43.334
N13953 X25.092 Z-42.672
N13954 X26.035 Z-41.969
N13955 X26.939 Z-41.256
N13956 X27.843 Z-40.502
N13957 X28.746 Z-39.704
N13958 X29.65 Z-38.861
N13959 X30.606 Z-37.915
N13960 X31.562 Z-36.905
N13961 X32.518 Z-35.823
N13962 X33.474 Z-34.669
N13963 X34.735 Z-33.003
N13964 X35.366 Z-32.104
N13965 X35.996 Z-31.153
N13966 X36.611 Z-30.166
N13967 X37.225 Z-29.115
N13968 X39.683 Z-24.52
N13969 X41.429 Z-21.167
N13970 X42.462 Z-19.004
N13971 X43.199 Z-17.306
N13972 X43.861 Z-15.569
N13973 X44.15 Z-14.705
N13974 X44.631 Z-12.996
N13975 X44.98 Z-11.308
N13976 X45.154 Z-10.11
N13977 X45.329 Z-9.282
N13978 X45.561 Z-8.575
N13979 X45.794 Z-8.043
N13980 X46.026 Z-7.61
N13981 X46.259 Z-7.231
N13982 X46.491 Z-6.907
N13983 X46.956 Z-6.353
N13984 X47.421 Z-5.901
N13985 X47.886 Z-5.537
N13986 X48.351 Z-5.225
N13987 X48.816 Z-4.967
N13988 X49.281 Z-4.767
N13989 X49.745 Z-4.608
N13990 X50.21 Z-4.483
N13991 X50.675 Z-4.405
N13992 X51.14 Z-4.37
N13993 X121.303 Z-4.365
N13994 X121.694 Z-3.899
N13995 X122.215 Z-3.337
N13996 X122.736 Z-2.837
N13997 X123.201 Z-2.444
N13998 X123.666 Z-2.094
N13999 X124.131 Z-1.776
N14000 X125.061 Z-1.24
N14001 X125.526 Z-1.015
N14002 X126.456 Z-.638
N14003 X127.386 Z-.354
N14004 X128.315 Z-.156
N14005 X129.245 Z-.039
N14006 X130.175 Z0.
N14007 Y-46.225
N14008 X129.245 Z-.039
N14009 X128.315 Z-.156
N14010 X127.386 Z-.354
N14011 X126.456 Z-.638
N14012 X125.526 Z-1.015
N14013 X125.061 Z-1.24
N14014 X124.131 Z-1.776
N14015 X123.666 Z-2.094
N14016 X123.201 Z-2.444
N14017 X122.504 Z-3.035
N14018 X52.07 Z-3.036
N14019 X51.14 Z-3.06
N14020 X50.21 Z-3.202
N14021 X49.745 Z-3.32
N14022 X49.281 Z-3.479
N14023 X48.816 Z-3.666
N14024 X48.351 Z-3.89
N14025 X47.886 Z-4.165
N14026 X47.421 Z-4.477
N14027 X46.956 Z-4.842
N14028 X46.491 Z-5.282
N14029 X46.026 Z-5.78
N14030 X45.561 Z-6.391
N14031 X45.096 Z-7.148
N14032 X44.748 Z-7.873
N14033 X44.456 Z-8.671
N14034 X44.238 Z-9.542
N14035 X43.844 Z-12.297
N14036 X43.319 Z-14.661
N14037 X42.767 Z-16.529
N14038 X41.985 Z-18.729
N14039 X41.355 Z-20.315
N14040 X40.364 Z-22.615
N14041 X38.72 Z-26.229
N14042 X38.172 Z-27.352
N14043 X37.624 Z-28.4
N14044 X37.076 Z-29.382
N14045 X36.146 Z-30.914
N14046 X35.382 Z-32.08
N14047 X34.237 Z-33.681
N14048 X32.996 Z-35.256
N14049 X31.562 Z-36.905
N14050 X30.606 Z-37.915
N14051 X29.65 Z-38.861
N14052 X28.746 Z-39.704
N14053 X27.843 Z-40.502
N14054 X26.939 Z-41.256
N14055 X26.035 Z-41.969
N14056 X25.092 Z-42.672
N14057 X24.148 Z-43.334
N14058 X23.205 Z-43.96
N14059 X22.262 Z-44.551
N14060 X21.345 Z-45.094
N14061 X19.513 Z-46.09
N14062 X17.658 Z-46.984
N14063 X15.783 Z-47.781
N14064 X14.845 Z-48.14
N14065 X13.001 Z-48.775
N14066 X11.158 Z-49.318
N14067 X9.273 Z-49.782
N14068 X7.422 Z-50.151
N14069 X5.554 Z-50.437
N14070 X3.719 Z-50.637
N14071 X1.862 Z-50.759
N14072 X0. Z-50.8
N14073 X-1.862 Z-50.759
N14074 X-3.719 Z-50.637
N14075 X-5.554 Z-50.437
N14076 X-7.422 Z-50.151
N14077 X-9.273 Z-49.782
N14078 X-11.158 Z-49.318
N14079 X-13.001 Z-48.775
N14080 X-14.845 Z-48.14
N14081 X-16.721 Z-47.395
N14082 X-18.596 Z-46.545
N14083 X-20.429 Z-45.606
N14084 X-21.345 Z-45.094
N14085 X-22.262 Z-44.551
N14086 X-23.205 Z-43.96
N14087 X-24.148 Z-43.334
N14088 X-25.092 Z-42.672
N14089 X-26.035 Z-41.969
N14090 X-26.939 Z-41.256
N14091 X-27.843 Z-40.502
N14092 X-28.746 Z-39.704
N14093 X-29.65 Z-38.861
N14094 X-30.606 Z-37.915
N14095 X-31.562 Z-36.905
N14096 X-32.518 Z-35.823
N14097 X-33.474 Z-34.669
N14098 X-34.237 Z-33.681
N14099 X-35.382 Z-32.08
N14100 X-36.528 Z-30.304
N14101 X-37.076 Z-29.382
N14102 X-37.624 Z-28.4
N14103 X-38.446 Z-26.803
N14104 X-40.364 Z-22.615
N14105 X-41.355 Z-20.315
N14106 X-41.985 Z-18.729
N14107 X-42.767 Z-16.529
N14108 X-43.494 Z-13.968
N14109 X-43.888 Z-12.062
N14110 X-44.019 Z-11.2
N14111 X-44.238 Z-9.542
N14112 X-44.456 Z-8.671
N14113 X-44.748 Z-7.873
N14114 X-45.096 Z-7.148
N14115 X-45.561 Z-6.391
N14116 X-46.026 Z-5.78
N14117 X-46.491 Z-5.282
N14118 X-46.956 Z-4.842
N14119 X-47.421 Z-4.477
N14120 X-47.886 Z-4.165
N14121 X-48.351 Z-3.89
N14122 X-48.816 Z-3.666
N14123 X-49.281 Z-3.479
N14124 X-49.745 Z-3.32
N14125 X-50.21 Z-3.202
N14126 X-51.14 Z-3.06
N14127 X-52.07 Z-3.036
N14128 X-122.504 Z-3.035
N14129 X-123.201 Z-2.444
N14130 X-123.666 Z-2.094
N14131 X-124.131 Z-1.776
N14132 X-125.061 Z-1.24
N14133 X-125.526 Z-1.015
N14134 X-126.456 Z-.638
N14135 X-127.386 Z-.354
N14136 X-128.315 Z-.156
N14137 X-129.245 Z-.039
N14138 X-130.175 Z0.
N14139 Y-47.425
N14140 X-129.245 Z-.039
N14141 X-128.315 Z-.156
N14142 X-127.386 Z-.354
N14143 X-126.456 Z-.638
N14144 X-125.526 Z-1.015
N14145 X-125.061 Z-1.24
N14146 X-124.098 Z-1.798
N14147 X-123.724 Z-2.053
N14148 X-52.07 Z-2.057
N14149 X-51.14 Z-2.107
N14150 X-50.675 Z-2.177
N14151 X-49.745 Z-2.395
N14152 X-49.281 Z-2.551
N14153 X-48.351 Z-2.953
N14154 X-47.886 Z-3.211
N14155 X-47.421 Z-3.504
N14156 X-46.956 Z-3.837
N14157 X-46.491 Z-4.231
N14158 X-46.026 Z-4.669
N14159 X-45.794 Z-4.918
N14160 X-45.096 Z-5.795
N14161 X-44.631 Z-6.53
N14162 X-44.399 Z-6.97
N14163 X-44.167 Z-7.47
N14164 X-43.934 Z-8.07
N14165 X-43.702 Z-8.844
N14166 X-43.527 Z-9.693
N14167 X-43.353 Z-11.263
N14168 X-43.12 Z-12.861
N14169 X-42.772 Z-14.612
N14170 X-42.307 Z-16.46
N14171 X-41.61 Z-18.764
N14172 X-40.912 Z-20.782
N14173 X-39.884 Z-23.52
N14174 X-39.369 Z-24.787
N14175 X-38.855 Z-25.94
N14176 X-38.341 Z-27.013
N14177 X-37.57 Z-28.501
N14178 X-36.798 Z-29.85
N14179 X-35.967 Z-31.197
N14180 X-34.72 Z-33.023
N14181 X-33.474 Z-34.669
N14182 X-32.518 Z-35.823
N14183 X-31.562 Z-36.905
N14184 X-30.606 Z-37.915
N14185 X-29.65 Z-38.861
N14186 X-28.746 Z-39.704
N14187 X-27.843 Z-40.502
N14188 X-26.939 Z-41.256
N14189 X-26.035 Z-41.969
N14190 X-25.092 Z-42.672
N14191 X-24.148 Z-43.334
N14192 X-23.205 Z-43.96
N14193 X-22.262 Z-44.551
N14194 X-21.345 Z-45.094
N14195 X-20.429 Z-45.606
N14196 X-18.596 Z-46.545
N14197 X-16.721 Z-47.395
N14198 X-14.845 Z-48.14
N14199 X-13.001 Z-48.775
N14200 X-11.158 Z-49.318
N14201 X-9.273 Z-49.782
N14202 X-7.422 Z-50.151
N14203 X-5.554 Z-50.437
N14204 X-3.719 Z-50.637
N14205 X-1.862 Z-50.759
N14206 X0. Z-50.8
N14207 X1.862 Z-50.759
N14208 X3.719 Z-50.637
N14209 X5.554 Z-50.437
N14210 X7.422 Z-50.151
N14211 X9.273 Z-49.782
N14212 X11.158 Z-49.318
N14213 X13.001 Z-48.775
N14214 X14.845 Z-48.14
N14215 X15.783 Z-47.781
N14216 X17.658 Z-46.984
N14217 X19.513 Z-46.09
N14218 X21.345 Z-45.094
N14219 X22.262 Z-44.551
N14220 X23.205 Z-43.96
N14221 X24.148 Z-43.334
N14222 X25.092 Z-42.672
N14223 X26.035 Z-41.969
N14224 X26.939 Z-41.256
N14225 X27.843 Z-40.502
N14226 X28.746 Z-39.704
N14227 X29.65 Z-38.861
N14228 X30.606 Z-37.915
N14229 X31.562 Z-36.905
N14230 X32.518 Z-35.823
N14231 X33.474 Z-34.669
N14232 X34.72 Z-33.023
N14233 X35.967 Z-31.197
N14234 X36.798 Z-29.85
N14235 X37.313 Z-28.959
N14236 X38.084 Z-27.529
N14237 X38.855 Z-25.94
N14238 X39.627 Z-24.164
N14239 X40.912 Z-20.782
N14240 X41.377 Z-19.455
N14241 X41.842 Z-18.033
N14242 X42.539 Z-15.584
N14243 X42.888 Z-14.082
N14244 X43.237 Z-12.143
N14245 X43.527 Z-9.693
N14246 X43.702 Z-8.844
N14247 X43.934 Z-8.07
N14248 X44.167 Z-7.47
N14249 X44.399 Z-6.97
N14250 X44.631 Z-6.53
N14251 X45.096 Z-5.795
N14252 X45.561 Z-5.193
N14253 X46.026 Z-4.669
N14254 X46.491 Z-4.231
N14255 X46.956 Z-3.837
N14256 X47.421 Z-3.503
N14257 X47.886 Z-3.211
N14258 X48.351 Z-2.953
N14259 X49.281 Z-2.551
N14260 X49.745 Z-2.395
N14261 X50.675 Z-2.177
N14262 X51.14 Z-2.107
N14263 X52.07 Z-2.057
N14264 X123.724 Z-2.053
N14265 X124.098 Z-1.798
N14266 X125.061 Z-1.24
N14267 X125.526 Z-1.015
N14268 X126.456 Z-.638
N14269 X127.386 Z-.354
N14270 X128.315 Z-.156
N14271 X129.245 Z-.039
N14272 X130.175 Z0.
N14273 Y-48.625
N14274 X129.245 Z-.039
N14275 X128.315 Z-.156
N14276 X127.386 Z-.354
N14277 X126.456 Z-.638
N14278 X125.589 Z-.987
N14279 X124.938 Z-1.306
N14280 X52.07 Z-1.32
N14281 X51.14 Z-1.404
N14282 X50.675 Z-1.484
N14283 X49.745 Z-1.721
N14284 X49.281 Z-1.881
N14285 X48.351 Z-2.286
N14286 X47.421 Z-2.824
N14287 X46.956 Z-3.149
N14288 X46.491 Z-3.523
N14289 X46.026 Z-3.937
N14290 X45.561 Z-4.426
N14291 X45.096 Z-4.972
N14292 X44.399 Z-5.995
N14293 X43.934 Z-6.873
N14294 X43.585 Z-7.721
N14295 X43.353 Z-8.452
N14296 X43.12 Z-9.501
N14297 X42.714 Z-13.008
N14298 X42.307 Z-15.252
N14299 X41.842 Z-17.255
N14300 X41.145 Z-19.79
N14301 X40.658 Z-21.359
N14302 X40.151 Z-22.822
N14303 X39.389 Z-24.742
N14304 X38.881 Z-25.885
N14305 X38.373 Z-26.948
N14306 X37.866 Z-27.943
N14307 X36.85 Z-29.762
N14308 X36.006 Z-31.137
N14309 X34.74 Z-32.997
N14310 X33.474 Z-34.669
N14311 X32.518 Z-35.823
N14312 X31.562 Z-36.905
N14313 X30.606 Z-37.915
N14314 X29.65 Z-38.861
N14315 X28.746 Z-39.704
N14316 X27.843 Z-40.502
N14317 X26.939 Z-41.256
N14318 X26.035 Z-41.969
N14319 X25.092 Z-42.672
N14320 X24.148 Z-43.334
N14321 X23.205 Z-43.96
N14322 X22.262 Z-44.551
N14323 X21.345 Z-45.094
N14324 X19.513 Z-46.09
N14325 X17.658 Z-46.984
N14326 X15.783 Z-47.781
N14327 X14.845 Z-48.14
N14328 X13.001 Z-48.775
N14329 X11.158 Z-49.318
N14330 X9.273 Z-49.782
N14331 X7.422 Z-50.151
N14332 X5.554 Z-50.437
N14333 X3.719 Z-50.637
N14334 X1.862 Z-50.759
N14335 X0. Z-50.8
N14336 X-1.862 Z-50.759
N14337 X-3.719 Z-50.637
N14338 X-5.554 Z-50.437
N14339 X-7.422 Z-50.151
N14340 X-9.273 Z-49.782
N14341 X-11.158 Z-49.318
N14342 X-13.001 Z-48.775
N14343 X-14.845 Z-48.14
N14344 X-16.721 Z-47.395
N14345 X-18.596 Z-46.545
N14346 X-20.429 Z-45.606
N14347 X-21.345 Z-45.094
N14348 X-22.262 Z-44.551
N14349 X-23.205 Z-43.96
N14350 X-24.148 Z-43.334
N14351 X-25.092 Z-42.672
N14352 X-26.035 Z-41.969
N14353 X-26.939 Z-41.256
N14354 X-27.843 Z-40.502
N14355 X-28.746 Z-39.704
N14356 X-29.65 Z-38.861
N14357 X-30.606 Z-37.915
N14358 X-31.562 Z-36.905
N14359 X-32.996 Z-35.256
N14360 X-33.474 Z-34.669
N14361 X-34.74 Z-32.997
N14362 X-36.006 Z-31.137
N14363 X-36.85 Z-29.762
N14364 X-37.866 Z-27.943
N14365 X-38.373 Z-26.948
N14366 X-38.881 Z-25.885
N14367 X-39.389 Z-24.742
N14368 X-40.151 Z-22.822
N14369 X-40.912 Z-20.56
N14370 X-41.61 Z-18.145
N14371 X-42.191 Z-15.794
N14372 X-42.539 Z-14.07
N14373 X-42.83 Z-12.182
N14374 X-43.12 Z-9.501
N14375 X-43.237 Z-8.908
N14376 X-43.469 Z-8.06
N14377 X-43.702 Z-7.412
N14378 X-43.934 Z-6.873
N14379 X-44.399 Z-5.995
N14380 X-44.864 Z-5.287
N14381 X-45.096 Z-4.972
N14382 X-45.561 Z-4.426
N14383 X-46.026 Z-3.937
N14384 X-46.491 Z-3.523
N14385 X-46.956 Z-3.149
N14386 X-47.421 Z-2.824
N14387 X-48.351 Z-2.286
N14388 X-49.281 Z-1.881
N14389 X-49.745 Z-1.721
N14390 X-50.675 Z-1.484
N14391 X-51.14 Z-1.404
N14392 X-52.07 Z-1.32
N14393 X-124.721 Z-1.316
N14394 X-126.456 Z-.638
N14395 X-127.386 Z-.354
N14396 X-128.315 Z-.156
N14397 X-129.245 Z-.039
N14398 X-130.175 Z0.
N14399 Y-49.825
N14400 X-129.245 Z-.039
N14401 X-128.315 Z-.156
N14402 X-127.386 Z-.354
N14403 X-126.107 Z-.762
N14404 X-55.789 Z-.765
N14405 X-52.07 Z-.786
N14406 X-51.14 Z-.899
N14407 X-50.675 Z-.99
N14408 X-49.745 Z-1.247
N14409 X-49.281 Z-1.415
N14410 X-48.351 Z-1.831
N14411 X-47.421 Z-2.374
N14412 X-46.956 Z-2.703
N14413 X-46.491 Z-3.068
N14414 X-46.026 Z-3.483
N14415 X-45.561 Z-3.954
N14416 X-45.096 Z-4.491
N14417 X-44.631 Z-5.113
N14418 X-44.399 Z-5.464
N14419 X-43.934 Z-6.279
N14420 X-43.585 Z-7.028
N14421 X-43.237 Z-7.991
N14422 X-43.004 Z-8.873
N14423 X-42.888 Z-9.495
N14424 X-42.656 Z-11.894
N14425 X-42.191 Z-15.213
N14426 X-41.842 Z-16.996
N14427 X-41.377 Z-18.938
N14428 X-40.912 Z-20.56
N14429 X-40.151 Z-22.822
N14430 X-39.389 Z-24.742
N14431 X-38.881 Z-25.885
N14432 X-38.373 Z-26.948
N14433 X-37.866 Z-27.943
N14434 X-36.85 Z-29.762
N14435 X-36.006 Z-31.137
N14436 X-34.74 Z-32.997
N14437 X-33.474 Z-34.669
N14438 X-32.518 Z-35.823
N14439 X-31.562 Z-36.905
N14440 X-30.606 Z-37.915
N14441 X-29.65 Z-38.861
N14442 X-28.746 Z-39.704
N14443 X-27.843 Z-40.502
N14444 X-26.939 Z-41.256
N14445 X-26.035 Z-41.969
N14446 X-25.092 Z-42.672
N14447 X-24.148 Z-43.334
N14448 X-23.205 Z-43.96
N14449 X-22.262 Z-44.551
N14450 X-21.345 Z-45.094
N14451 X-20.429 Z-45.606
N14452 X-18.596 Z-46.545
N14453 X-16.721 Z-47.395
N14454 X-14.845 Z-48.14
N14455 X-13.001 Z-48.775
N14456 X-11.158 Z-49.318
N14457 X-9.273 Z-49.782
N14458 X-7.422 Z-50.151
N14459 X-5.554 Z-50.437
N14460 X-3.719 Z-50.637
N14461 X-1.862 Z-50.759
N14462 X0. Z-50.8
N14463 X1.862 Z-50.759
N14464 X3.719 Z-50.637
N14465 X5.554 Z-50.437
N14466 X7.422 Z-50.151
N14467 X9.273 Z-49.782
N14468 X11.158 Z-49.318
N14469 X13.001 Z-48.775
N14470 X14.845 Z-48.14
N14471 X15.783 Z-47.781
N14472 X17.658 Z-46.984
N14473 X19.513 Z-46.09
N14474 X21.345 Z-45.094
N14475 X22.262 Z-44.551
N14476 X23.205 Z-43.96
N14477 X24.148 Z-43.334
N14478 X25.092 Z-42.672
N14479 X26.035 Z-41.969
N14480 X26.939 Z-41.256
N14481 X27.843 Z-40.502
N14482 X28.746 Z-39.704
N14483 X29.65 Z-38.861
N14484 X30.606 Z-37.915
N14485 X31.562 Z-36.905
N14486 X32.518 Z-35.823
N14487 X33.474 Z-34.669
N14488 X34.74 Z-32.997
N14489 X36.006 Z-31.137
N14490 X36.85 Z-29.762
N14491 X37.866 Z-27.943
N14492 X38.373 Z-26.948
N14493 X38.881 Z-25.885
N14494 X39.389 Z-24.742
N14495 X40.151 Z-22.822
N14496 X40.658 Z-21.359
N14497 X41.377 Z-18.938
N14498 X41.842 Z-16.996
N14499 X42.307 Z-14.517
N14500 X42.597 Z-12.443
N14501 X42.801 Z-10.197
N14502 X42.946 Z-9.154
N14503 X43.237 Z-7.991
N14504 X43.585 Z-7.028
N14505 X43.934 Z-6.279
N14506 X44.167 Z-5.86
N14507 X44.631 Z-5.113
N14508 X45.096 Z-4.492
N14509 X45.561 Z-3.954
N14510 X46.026 Z-3.483
N14511 X46.491 Z-3.068
N14512 X46.956 Z-2.703
N14513 X47.421 Z-2.374
N14514 X48.351 Z-1.831
N14515 X48.816 Z-1.611
N14516 X49.745 Z-1.247
N14517 X50.675 Z-.99
N14518 X51.14 Z-.899
N14519 X52.07 Z-.786
N14520 X55.789 Z-.765
N14521 X126.107 Z-.762
N14522 X127.386 Z-.354
N14523 X128.315 Z-.156
N14524 X129.245 Z-.039
N14525 X130.175 Z0.
N14526 X130.165 Y-51.025
N14527 X129.058 Z-.055
N14528 X128.505 Z-.126
N14529 X127.952 Z-.223
N14530 X127.289 Z-.37
N14531 X52.996 Z-.373
N14532 X52.066 Z-.423
N14533 X51.136 Z-.564
N14534 X50.671 Z-.668
N14535 X49.741 Z-.948
N14536 X48.812 Z-1.332
N14537 X48.347 Z-1.565
N14538 X47.417 Z-2.126
N14539 X46.952 Z-2.465
N14540 X46.487 Z-2.837
N14541 X46.022 Z-3.265
N14542 X45.558 Z-3.739
N14543 X44.86 Z-4.588
N14544 X44.628 Z-4.918
N14545 X44.163 Z-5.66
N14546 X43.582 Z-6.839
N14547 X43.233 Z-7.788
N14548 X43.001 Z-8.627
N14549 X42.797 Z-9.755
N14550 X42.478 Z-13.23
N14551 X42.187 Z-15.213
N14552 X41.839 Z-17.013
N14553 X41.374 Z-18.951
N14554 X40.655 Z-21.368
N14555 X40.147 Z-22.831
N14556 X39.386 Z-24.749
N14557 X38.878 Z-25.891
N14558 X38.371 Z-26.954
N14559 X37.863 Z-27.948
N14560 X36.848 Z-29.766
N14561 X36.004 Z-31.141
N14562 X34.737 Z-33.
N14563 X33.471 Z-34.672
N14564 X32.515 Z-35.826
N14565 X31.56 Z-36.908
N14566 X30.604 Z-37.917
N14567 X29.648 Z-38.863
N14568 X28.744 Z-39.706
N14569 X27.841 Z-40.503
N14570 X26.937 Z-41.257
N14571 X26.033 Z-41.971
N14572 X25.09 Z-42.674
N14573 X24.146 Z-43.336
N14574 X23.203 Z-43.961
N14575 X22.26 Z-44.552
N14576 X21.343 Z-45.095
N14577 X19.511 Z-46.09
N14578 X17.657 Z-46.985
N14579 X15.781 Z-47.781
N14580 X13.922 Z-48.47
N14581 X13. Z-48.775
N14582 X11.157 Z-49.318
N14583 X9.272 Z-49.782
N14584 X7.421 Z-50.151
N14585 X5.553 Z-50.438
N14586 X3.719 Z-50.637
N14587 X1.861 Z-50.759
N14588 X0. Z-50.8
N14589 X-1.861 Z-50.759
N14590 X-3.719 Z-50.637
N14591 X-5.553 Z-50.438
N14592 X-7.421 Z-50.151
N14593 X-9.272 Z-49.782
N14594 X-11.157 Z-49.318
N14595 X-13. Z-48.775
N14596 X-14.844 Z-48.14
N14597 X-16.719 Z-47.396
N14598 X-18.595 Z-46.546
N14599 X-20.427 Z-45.607
N14600 X-21.343 Z-45.095
N14601 X-22.26 Z-44.552
N14602 X-23.203 Z-43.961
N14603 X-24.146 Z-43.336
N14604 X-25.09 Z-42.674
N14605 X-26.033 Z-41.971
N14606 X-26.937 Z-41.257
N14607 X-27.841 Z-40.503
N14608 X-28.744 Z-39.706
N14609 X-29.648 Z-38.863
N14610 X-30.604 Z-37.917
N14611 X-31.56 Z-36.908
N14612 X-32.515 Z-35.826
N14613 X-33.471 Z-34.672
N14614 X-34.737 Z-33.
N14615 X-36.004 Z-31.141
N14616 X-36.848 Z-29.766
N14617 X-37.863 Z-27.948
N14618 X-38.371 Z-26.954
N14619 X-38.878 Z-25.891
N14620 X-39.64 Z-24.132
N14621 X-40.147 Z-22.831
N14622 X-40.909 Z-20.571
N14623 X-41.374 Z-18.951
N14624 X-41.839 Z-17.013
N14625 X-42.187 Z-15.213
N14626 X-42.478 Z-13.23
N14627 X-42.826 Z-9.551
N14628 X-43.001 Z-8.627
N14629 X-43.233 Z-7.788
N14630 X-43.582 Z-6.839
N14631 X-43.931 Z-6.096
N14632 X-44.163 Z-5.66
N14633 X-44.628 Z-4.918
N14634 X-45.093 Z-4.29
N14635 X-45.558 Z-3.739
N14636 X-46.022 Z-3.265
N14637 X-46.487 Z-2.837
N14638 X-46.952 Z-2.465
N14639 X-47.417 Z-2.126
N14640 X-48.347 Z-1.565
N14641 X-48.812 Z-1.332
N14642 X-49.741 Z-.948
N14643 X-50.671 Z-.668
N14644 X-51.136 Z-.564
N14645 X-52.066 Z-.423
N14646 X-52.996 Z-.372
N14647 X-127.289 Z-.37
N14648 X-127.952 Z-.223
N14649 X-128.505 Z-.126
N14650 X-129.058 Z-.055
N14651 X-130.165 Z0.
N14652 X-129.925 Y-52.225
N14653 X-127.777 Z-.118
N14654 X-52.898 Z-.138
N14655 X-51.97 Z-.226
N14656 X-51.042 Z-.404
N14657 X-50.114 Z-.675
N14658 X-49.65 Z-.844
N14659 X-48.722 Z-1.265
N14660 X-47.794 Z-1.804
N14661 X-46.866 Z-2.477
N14662 X-46.402 Z-2.876
N14663 X-45.938 Z-3.317
N14664 X-45.474 Z-3.814
N14665 X-45.01 Z-4.386
N14666 X-44.546 Z-5.036
N14667 X-44.082 Z-5.805
N14668 X-43.618 Z-6.756
N14669 X-43.386 Z-7.339
N14670 X-43.038 Z-8.477
N14671 X-42.806 Z-9.695
N14672 X-42.574 Z-12.391
N14673 X-42.342 Z-14.242
N14674 X-41.994 Z-16.262
N14675 X-41.646 Z-17.863
N14676 X-41.065 Z-20.057
N14677 X-40.581 Z-21.593
N14678 X-40.076 Z-23.02
N14679 X-39.318 Z-24.904
N14680 X-38.813 Z-26.031
N14681 X-38.055 Z-27.585
N14682 X-36.792 Z-29.861
N14683 X-35.946 Z-31.229
N14684 X-35.1 Z-32.484
N14685 X-34.255 Z-33.657
N14686 X-33.409 Z-34.748
N14687 X-32.458 Z-35.893
N14688 X-31.506 Z-36.967
N14689 X-30.554 Z-37.967
N14690 X-29.603 Z-38.906
N14691 X-28.698 Z-39.748
N14692 X-27.794 Z-40.544
N14693 X-26.889 Z-41.296
N14694 X-25.985 Z-42.008
N14695 X-25.042 Z-42.707
N14696 X-24.098 Z-43.368
N14697 X-23.155 Z-43.992
N14698 X-22.212 Z-44.581
N14699 X-21.299 Z-45.12
N14700 X-20.386 Z-45.629
N14701 X-18.561 Z-46.562
N14702 X-16.689 Z-47.409
N14703 X-14.816 Z-48.15
N14704 X-12.976 Z-48.783
N14705 X-11.136 Z-49.324
N14706 X-9.254 Z-49.786
N14707 X-7.405 Z-50.153
N14708 X-5.538 Z-50.439
N14709 X-3.712 Z-50.638
N14710 X-1.858 Z-50.759
N14711 X0. Z-50.8
N14712 X1.858 Z-50.759
N14713 X3.712 Z-50.638
N14714 X5.538 Z-50.439
N14715 X7.405 Z-50.153
N14716 X9.254 Z-49.786
N14717 X11.136 Z-49.324
N14718 X12.976 Z-48.783
N14719 X14.816 Z-48.15
N14720 X15.752 Z-47.792
N14721 X17.625 Z-46.999
N14722 X19.473 Z-46.11
N14723 X21.299 Z-45.12
N14724 X22.212 Z-44.581
N14725 X23.155 Z-43.992
N14726 X24.098 Z-43.368
N14727 X25.042 Z-42.707
N14728 X25.985 Z-42.008
N14729 X26.889 Z-41.296
N14730 X27.794 Z-40.544
N14731 X28.698 Z-39.748
N14732 X29.603 Z-38.906
N14733 X30.554 Z-37.967
N14734 X31.506 Z-36.967
N14735 X32.458 Z-35.893
N14736 X33.409 Z-34.748
N14737 X34.255 Z-33.657
N14738 X35.523 Z-31.868
N14739 X36.369 Z-30.558
N14740 X37.297 Z-28.987
N14741 X38.055 Z-27.585
N14742 X39.065 Z-25.479
N14743 X39.823 Z-23.678
N14744 X40.581 Z-21.593
N14745 X41.065 Z-20.057
N14746 X41.53 Z-18.339
N14747 X41.994 Z-16.262
N14748 X42.342 Z-14.242
N14749 X42.574 Z-12.391
N14750 X42.777 Z-9.927
N14751 X42.98 Z-8.721
N14752 X43.27 Z-7.676
N14753 X43.618 Z-6.756
N14754 X44.082 Z-5.805
N14755 X44.314 Z-5.407
N14756 X44.778 Z-4.695
N14757 X45.474 Z-3.814
N14758 X45.938 Z-3.317
N14759 X46.402 Z-2.876
N14760 X46.866 Z-2.477
N14761 X47.794 Z-1.804
N14762 X48.722 Z-1.265
N14763 X49.65 Z-.844
N14764 X50.114 Z-.675
N14765 X51.042 Z-.404
N14766 X51.97 Z-.226
N14767 X52.898 Z-.138
N14768 X53.826 Z-.124
N14769 X127.784 Z-.118
N14770 X129.925 Z0.
N14771 X128.948 Y-53.425
N14772 X60.682 Z-.012
N14773 X53.096 Z-.03
N14774 X52.148 Z-.135
N14775 X51.2 Z-.327
N14776 X50.252 Z-.606
N14777 X49.304 Z-.981
N14778 X48.356 Z-1.463
N14779 X47.882 Z-1.748
N14780 X47.407 Z-2.069
N14781 X46.933 Z-2.423
N14782 X46.459 Z-2.825
N14783 X45.985 Z-3.268
N14784 X45.511 Z-3.772
N14785 X44.8 Z-4.664
N14786 X44.326 Z-5.387
N14787 X44.089 Z-5.791
N14788 X43.615 Z-6.762
N14789 X43.259 Z-7.708
N14790 X42.963 Z-8.798
N14791 X42.785 Z-9.852
N14792 X42.565 Z-12.466
N14793 X42.328 Z-14.331
N14794 X41.956 Z-16.446
N14795 X41.363 Z-18.993
N14796 X40.77 Z-21.019
N14797 X40.059 Z-23.062
N14798 X39.348 Z-24.835
N14799 X38.874 Z-25.9
N14800 X38.4 Z-26.895
N14801 X37.926 Z-27.829
N14802 X36.927 Z-29.632
N14803 X35.928 Z-31.256
N14804 X34.93 Z-32.729
N14805 X33.482 Z-34.658
N14806 X32.136 Z-36.267
N14807 X31.238 Z-37.253
N14808 X30.341 Z-38.182
N14809 X29.378 Z-39.121
N14810 X28.415 Z-40.005
N14811 X27.453 Z-40.832
N14812 X26.49 Z-41.613
N14813 X25.556 Z-42.328
N14814 X24.623 Z-43.003
N14815 X23.689 Z-43.642
N14816 X22.756 Z-44.246
N14817 X21.795 Z-44.832
N14818 X20.835 Z-45.384
N14819 X19.875 Z-45.903
N14820 X18.915 Z-46.392
N14821 X17.043 Z-47.259
N14822 X15.17 Z-48.02
N14823 X13.234 Z-48.702
N14824 X11.354 Z-49.265
N14825 X9.438 Z-49.745
N14826 X7.585 Z-50.121
N14827 X5.678 Z-50.42
N14828 X3.786 Z-50.631
N14829 X1.882 Z-50.758
N14830 X0. Z-50.8
N14831 X-1.882 Z-50.758
N14832 X-3.786 Z-50.631
N14833 X-5.678 Z-50.42
N14834 X-7.585 Z-50.121
N14835 X-9.438 Z-49.745
N14836 X-11.354 Z-49.265
N14837 X-13.234 Z-48.702
N14838 X-15.17 Z-48.02
N14839 X-17.043 Z-47.259
N14840 X-18.915 Z-46.392
N14841 X-19.875 Z-45.903
N14842 X-20.835 Z-45.384
N14843 X-21.795 Z-44.832
N14844 X-22.756 Z-44.246
N14845 X-23.689 Z-43.642
N14846 X-24.623 Z-43.003
N14847 X-25.556 Z-42.328
N14848 X-26.49 Z-41.613
N14849 X-27.453 Z-40.832
N14850 X-28.415 Z-40.005
N14851 X-29.378 Z-39.121
N14852 X-30.341 Z-38.182
N14853 X-31.238 Z-37.253
N14854 X-32.136 Z-36.267
N14855 X-33.482 Z-34.658
N14856 X-34.43 Z-33.418
N14857 X-35.429 Z-32.011
N14858 X-36.428 Z-30.464
N14859 X-37.427 Z-28.756
N14860 X-37.926 Z-27.829
N14861 X-38.4 Z-26.895
N14862 X-38.874 Z-25.9
N14863 X-39.348 Z-24.835
N14864 X-40.059 Z-23.062
N14865 X-40.77 Z-21.019
N14866 X-41.363 Z-18.993
N14867 X-41.837 Z-17.02
N14868 X-42.193 Z-15.179
N14869 X-42.463 Z-13.351
N14870 X-42.667 Z-11.358
N14871 X-42.785 Z-9.852
N14872 X-43.022 Z-8.538
N14873 X-43.259 Z-7.708
N14874 X-43.615 Z-6.762
N14875 X-44.089 Z-5.791
N14876 X-44.563 Z-5.009
N14877 X-45.037 Z-4.351
N14878 X-45.511 Z-3.772
N14879 X-45.985 Z-3.268
N14880 X-46.459 Z-2.825
N14881 X-46.933 Z-2.423
N14882 X-47.407 Z-2.069
N14883 X-47.882 Z-1.748
N14884 X-48.356 Z-1.463
N14885 X-49.304 Z-.981
N14886 X-50.252 Z-.606
N14887 X-51.2 Z-.327
N14888 X-52.148 Z-.135
N14889 X-53.096 Z-.03
N14890 X-128.948 Z0.
N14891 X-53.882 Y-54.625
N14892 X-52.984 Z-.036
N14893 X-52.085 Z-.145
N14894 X-51.187 Z-.33
N14895 X-50.289 Z-.593
N14896 X-49.391 Z-.942
N14897 X-48.493 Z-1.385
N14898 X-47.595 Z-1.936
N14899 X-47.146 Z-2.26
N14900 X-46.697 Z-2.617
N14901 X-46.248 Z-3.014
N14902 X-45.799 Z-3.462
N14903 X-45.35 Z-3.957
N14904 X-44.901 Z-4.527
N14905 X-44.452 Z-5.184
N14906 X-44.003 Z-5.952
N14907 X-43.554 Z-6.906
N14908 X-43.33 Z-7.496
N14909 X-43.105 Z-8.22
N14910 X-42.901 Z-9.104
N14911 X-42.798 Z-9.748
N14912 X-42.491 Z-13.111
N14913 X-41.98 Z-16.328
N14914 X-41.346 Z-19.058
N14915 X-40.491 Z-21.866
N14916 X-39.758 Z-23.846
N14917 X-39.033 Z-25.551
N14918 X-38.554 Z-26.583
N14919 X-38.074 Z-27.548
N14920 X-37.595 Z-28.455
N14921 X-36.635 Z-30.125
N14922 X-35.676 Z-31.638
N14923 X-34.839 Z-32.859
N14924 X-34.002 Z-33.989
N14925 X-33.166 Z-35.047
N14926 X-32.329 Z-36.043
N14927 X-31.408 Z-37.073
N14928 X-30.487 Z-38.035
N14929 X-29.566 Z-38.941
N14930 X-28.645 Z-39.796
N14931 X-27.77 Z-40.565
N14932 X-26.895 Z-41.292
N14933 X-26.02 Z-41.981
N14934 X-25.145 Z-42.634
N14935 X-24.233 Z-43.278
N14936 X-23.321 Z-43.886
N14937 X-22.41 Z-44.462
N14938 X-21.498 Z-45.007
N14939 X-19.729 Z-45.98
N14940 X-17.961 Z-46.848
N14941 X-16.151 Z-47.634
N14942 X-14.342 Z-48.323
N14943 X-12.559 Z-48.913
N14944 X-10.776 Z-49.418
N14945 X-8.958 Z-49.849
N14946 X-7.169 Z-50.192
N14947 X-5.362 Z-50.46
N14948 X-3.592 Z-50.648
N14949 X-1.797 Z-50.761
N14950 X0. Z-50.8
N14951 X1.797 Z-50.761
N14952 X3.592 Z-50.648
N14953 X5.362 Z-50.46
N14954 X7.169 Z-50.192
N14955 X8.958 Z-49.849
N14956 X10.776 Z-49.418
N14957 X12.559 Z-48.913
N14958 X14.342 Z-48.323
N14959 X16.151 Z-47.634
N14960 X17.961 Z-46.848
N14961 X18.845 Z-46.427
N14962 X20.614 Z-45.507
N14963 X22.41 Z-44.462
N14964 X23.321 Z-43.886
N14965 X24.233 Z-43.278
N14966 X25.145 Z-42.634
N14967 X26.02 Z-41.981
N14968 X26.895 Z-41.292
N14969 X27.77 Z-40.565
N14970 X28.645 Z-39.796
N14971 X29.566 Z-38.941
N14972 X30.487 Z-38.035
N14973 X31.408 Z-37.073
N14974 X32.329 Z-36.043
N14975 X33.166 Z-35.047
N14976 X34.002 Z-33.989
N14977 X34.839 Z-32.859
N14978 X35.676 Z-31.638
N14979 X36.156 Z-30.898
N14980 X37.115 Z-29.312
N14981 X38.074 Z-27.548
N14982 X38.554 Z-26.583
N14983 X39.033 Z-25.551
N14984 X39.758 Z-23.846
N14985 X40.491 Z-21.866
N14986 X40.979 Z-20.339
N14987 X41.571 Z-18.178
N14988 X42.184 Z-15.229
N14989 X42.44 Z-13.521
N14990 X42.798 Z-9.748
N14991 X43.003 Z-8.618
N14992 X43.217 Z-7.836
N14993 X43.554 Z-6.906
N14994 X43.779 Z-6.407
N14995 X44.228 Z-5.548
N14996 X44.677 Z-4.838
N14997 X45.35 Z-3.957
N14998 X45.799 Z-3.462
N14999 X46.248 Z-3.014
N15000 X46.697 Z-2.617
N15001 X47.146 Z-2.26
N15002 X47.595 Z-1.936
N15003 X48.493 Z-1.385
N15004 X49.391 Z-.942
N15005 X50.289 Z-.593
N15006 X51.187 Z-.33
N15007 X52.085 Z-.145
N15008 X52.984 Z-.036
N15009 X53.882 Z0.
N15010 Y-55.825
N15011 X52.984 Z-.036
N15012 X52.085 Z-.145
N15013 X51.187 Z-.33
N15014 X50.289 Z-.593
N15015 X49.391 Z-.942
N15016 X48.493 Z-1.385
N15017 X47.595 Z-1.936
N15018 X47.146 Z-2.26
N15019 X46.697 Z-2.617
N15020 X46.248 Z-3.014
N15021 X45.799 Z-3.462
N15022 X45.35 Z-3.957
N15023 X44.677 Z-4.838
N15024 X44.228 Z-5.548
N15025 X43.779 Z-6.407
N15026 X43.554 Z-6.906
N15027 X43.217 Z-7.836
N15028 X43.003 Z-8.618
N15029 X42.798 Z-9.748
N15030 X42.44 Z-13.521
N15031 X42.184 Z-15.229
N15032 X41.571 Z-18.178
N15033 X40.979 Z-20.339
N15034 X40.491 Z-21.866
N15035 X39.758 Z-23.846
N15036 X39.033 Z-25.551
N15037 X38.554 Z-26.583
N15038 X38.074 Z-27.548
N15039 X37.115 Z-29.312
N15040 X36.156 Z-30.898
N15041 X35.676 Z-31.638
N15042 X34.839 Z-32.859
N15043 X34.002 Z-33.989
N15044 X33.166 Z-35.047
N15045 X32.329 Z-36.043
N15046 X31.408 Z-37.073
N15047 X30.487 Z-38.035
N15048 X29.566 Z-38.941
N15049 X28.645 Z-39.796
N15050 X27.77 Z-40.565
N15051 X26.895 Z-41.292
N15052 X26.02 Z-41.981
N15053 X25.145 Z-42.634
N15054 X24.233 Z-43.278
N15055 X23.321 Z-43.886
N15056 X22.41 Z-44.462
N15057 X20.614 Z-45.507
N15058 X18.845 Z-46.427
N15059 X17.961 Z-46.848
N15060 X16.151 Z-47.634
N15061 X14.342 Z-48.323
N15062 X12.559 Z-48.913
N15063 X10.776 Z-49.418
N15064 X8.958 Z-49.849
N15065 X7.169 Z-50.192
N15066 X5.362 Z-50.46
N15067 X3.592 Z-50.648
N15068 X1.797 Z-50.761
N15069 X0. Z-50.8
N15070 X-1.797 Z-50.761
N15071 X-3.592 Z-50.648
N15072 X-5.362 Z-50.46
N15073 X-7.169 Z-50.192
N15074 X-8.958 Z-49.849
N15075 X-10.776 Z-49.418
N15076 X-12.559 Z-48.913
N15077 X-14.342 Z-48.323
N15078 X-16.151 Z-47.634
N15079 X-17.961 Z-46.848
N15080 X-19.729 Z-45.98
N15081 X-21.498 Z-45.007
N15082 X-22.41 Z-44.462
N15083 X-23.321 Z-43.886
N15084 X-24.233 Z-43.278
N15085 X-25.145 Z-42.634
N15086 X-26.02 Z-41.981
N15087 X-26.895 Z-41.292
N15088 X-27.77 Z-40.565
N15089 X-28.645 Z-39.796
N15090 X-29.566 Z-38.941
N15091 X-30.487 Z-38.035
N15092 X-31.408 Z-37.073
N15093 X-32.329 Z-36.043
N15094 X-33.166 Z-35.047
N15095 X-34.002 Z-33.989
N15096 X-34.839 Z-32.859
N15097 X-35.676 Z-31.638
N15098 X-36.635 Z-30.125
N15099 X-37.595 Z-28.455
N15100 X-38.074 Z-27.548
N15101 X-38.554 Z-26.583
N15102 X-39.033 Z-25.551
N15103 X-39.758 Z-23.846
N15104 X-40.491 Z-21.866
N15105 X-41.346 Z-19.058
N15106 X-41.98 Z-16.328
N15107 X-42.491 Z-13.111
N15108 X-42.798 Z-9.748
N15109 X-42.901 Z-9.104
N15110 X-43.105 Z-8.22
N15111 X-43.33 Z-7.496
N15112 X-43.554 Z-6.906
N15113 X-44.003 Z-5.952
N15114 X-44.452 Z-5.184
N15115 X-44.901 Z-4.527
N15116 X-45.35 Z-3.957
N15117 X-45.799 Z-3.462
N15118 X-46.248 Z-3.014
N15119 X-46.697 Z-2.617
N15120 X-47.146 Z-2.26
N15121 X-47.595 Z-1.936
N15122 X-48.493 Z-1.385
N15123 X-49.391 Z-.942
N15124 X-50.289 Z-.593
N15125 X-51.187 Z-.33
N15126 X-52.085 Z-.145
N15127 X-52.984 Z-.036
N15128 X-53.882 Z0.
N15129 Y-57.025
N15130 X-52.984 Z-.036
N15131 X-52.085 Z-.145
N15132 X-51.187 Z-.33
N15133 X-50.289 Z-.593
N15134 X-49.391 Z-.942
N15135 X-48.493 Z-1.385
N15136 X-47.595 Z-1.936
N15137 X-47.146 Z-2.26
N15138 X-46.697 Z-2.617
N15139 X-46.248 Z-3.014
N15140 X-45.799 Z-3.462
N15141 X-45.35 Z-3.957
N15142 X-44.901 Z-4.527
N15143 X-44.452 Z-5.184
N15144 X-44.003 Z-5.952
N15145 X-43.554 Z-6.906
N15146 X-43.33 Z-7.496
N15147 X-43.105 Z-8.22
N15148 X-42.901 Z-9.104
N15149 X-42.798 Z-9.748
N15150 X-42.491 Z-13.111
N15151 X-41.98 Z-16.328
N15152 X-41.346 Z-19.058
N15153 X-40.491 Z-21.866
N15154 X-39.758 Z-23.846
N15155 X-39.033 Z-25.551
N15156 X-38.554 Z-26.583
N15157 X-38.074 Z-27.548
N15158 X-37.595 Z-28.455
N15159 X-36.635 Z-30.125
N15160 X-35.676 Z-31.638
N15161 X-34.839 Z-32.859
N15162 X-34.002 Z-33.989
N15163 X-33.166 Z-35.047
N15164 X-32.329 Z-36.043
N15165 X-31.408 Z-37.073
N15166 X-30.487 Z-38.035
N15167 X-29.566 Z-38.941
N15168 X-28.645 Z-39.796
N15169 X-27.77 Z-40.565
N15170 X-26.895 Z-41.292
N15171 X-26.02 Z-41.981
N15172 X-25.145 Z-42.634
N15173 X-24.233 Z-43.278
N15174 X-23.321 Z-43.886
N15175 X-22.41 Z-44.462
N15176 X-21.498 Z-45.007
N15177 X-19.729 Z-45.98
N15178 X-17.961 Z-46.848
N15179 X-16.151 Z-47.634
N15180 X-14.342 Z-48.323
N15181 X-12.559 Z-48.913
N15182 X-10.776 Z-49.418
N15183 X-8.958 Z-49.849
N15184 X-7.169 Z-50.192
N15185 X-5.362 Z-50.46
N15186 X-3.592 Z-50.648
N15187 X-1.797 Z-50.761
N15188 X0. Z-50.8
N15189 X1.797 Z-50.761
N15190 X3.592 Z-50.648
N15191 X5.362 Z-50.46
N15192 X7.169 Z-50.192
N15193 X8.958 Z-49.849
N15194 X10.776 Z-49.418
N15195 X12.559 Z-48.913
N15196 X14.342 Z-48.323
N15197 X16.151 Z-47.634
N15198 X17.961 Z-46.848
N15199 X18.845 Z-46.427
N15200 X20.614 Z-45.507
N15201 X22.41 Z-44.462
N15202 X23.321 Z-43.886
N15203 X24.233 Z-43.278
N15204 X25.145 Z-42.634
N15205 X26.02 Z-41.981
N15206 X26.895 Z-41.292
N15207 X27.77 Z-40.565
N15208 X28.645 Z-39.796
N15209 X29.566 Z-38.941
N15210 X30.487 Z-38.035
N15211 X31.408 Z-37.073
N15212 X32.329 Z-36.043
N15213 X33.166 Z-35.047
N15214 X34.002 Z-33.989
N15215 X34.839 Z-32.859
N15216 X35.676 Z-31.638
N15217 X36.156 Z-30.898
N15218 X37.115 Z-29.312
N15219 X38.074 Z-27.548
N15220 X38.554 Z-26.583
N15221 X39.033 Z-25.551
N15222 X39.758 Z-23.846
N15223 X40.491 Z-21.866
N15224 X40.979 Z-20.339
N15225 X41.571 Z-18.178
N15226 X42.184 Z-15.229
N15227 X42.44 Z-13.521
N15228 X42.798 Z-9.748
N15229 X43.003 Z-8.618
N15230 X43.217 Z-7.836
N15231 X43.554 Z-6.906
N15232 X43.779 Z-6.407
N15233 X44.228 Z-5.548
N15234 X44.677 Z-4.838
N15235 X45.35 Z-3.957
N15236 X45.799 Z-3.462
N15237 X46.248 Z-3.014
N15238 X46.697 Z-2.617
N15239 X47.146 Z-2.26
N15240 X47.595 Z-1.936
N15241 X48.493 Z-1.385
N15242 X49.391 Z-.942
N15243 X50.289 Z-.593
N15244 X51.187 Z-.33
N15245 X52.085 Z-.145
N15246 X52.984 Z-.036
N15247 X53.882 Z0.
N15248 Y-58.225
N15249 X52.984 Z-.036
N15250 X52.085 Z-.145
N15251 X51.187 Z-.33
N15252 X50.289 Z-.593
N15253 X49.391 Z-.942
N15254 X48.493 Z-1.385
N15255 X47.595 Z-1.936
N15256 X47.146 Z-2.26
N15257 X46.697 Z-2.617
N15258 X46.248 Z-3.014
N15259 X45.799 Z-3.462
N15260 X45.35 Z-3.957
N15261 X44.677 Z-4.839
N15262 X44.228 Z-5.548
N15263 X43.779 Z-6.407
N15264 X43.554 Z-6.906
N15265 X43.217 Z-7.836
N15266 X43.003 Z-8.618
N15267 X42.798 Z-9.748
N15268 X42.44 Z-13.521
N15269 X42.184 Z-15.229
N15270 X41.571 Z-18.178
N15271 X40.979 Z-20.339
N15272 X40.491 Z-21.866
N15273 X39.758 Z-23.846
N15274 X39.033 Z-25.551
N15275 X38.554 Z-26.583
N15276 X38.074 Z-27.548
N15277 X37.115 Z-29.312
N15278 X36.156 Z-30.898
N15279 X35.676 Z-31.638
N15280 X34.839 Z-32.859
N15281 X34.002 Z-33.989
N15282 X33.166 Z-35.047
N15283 X32.329 Z-36.043
N15284 X31.408 Z-37.073
N15285 X30.487 Z-38.035
N15286 X29.566 Z-38.941
N15287 X28.645 Z-39.796
N15288 X27.77 Z-40.565
N15289 X26.895 Z-41.292
N15290 X26.02 Z-41.981
N15291 X25.145 Z-42.634
N15292 X24.233 Z-43.278
N15293 X23.321 Z-43.886
N15294 X22.41 Z-44.462
N15295 X20.614 Z-45.507
N15296 X18.845 Z-46.427
N15297 X17.961 Z-46.848
N15298 X16.151 Z-47.634
N15299 X14.342 Z-48.323
N15300 X12.559 Z-48.913
N15301 X10.776 Z-49.418
N15302 X8.958 Z-49.849
N15303 X7.169 Z-50.192
N15304 X5.362 Z-50.46
N15305 X3.592 Z-50.648
N15306 X1.797 Z-50.761
N15307 X0. Z-50.8
N15308 X-1.797 Z-50.761
N15309 X-3.592 Z-50.648
N15310 X-5.362 Z-50.46
N15311 X-7.169 Z-50.192
N15312 X-8.958 Z-49.849
N15313 X-10.776 Z-49.418
N15314 X-12.559 Z-48.913
N15315 X-14.342 Z-48.323
N15316 X-16.151 Z-47.634
N15317 X-17.961 Z-46.848
N15318 X-19.729 Z-45.98
N15319 X-21.498 Z-45.007
N15320 X-22.41 Z-44.462
N15321 X-23.321 Z-43.886
N15322 X-24.233 Z-43.278
N15323 X-25.145 Z-42.634
N15324 X-26.02 Z-41.981
N15325 X-26.895 Z-41.292
N15326 X-27.77 Z-40.565
N15327 X-28.645 Z-39.796
N15328 X-29.566 Z-38.941
N15329 X-30.487 Z-38.035
N15330 X-31.408 Z-37.073
N15331 X-32.329 Z-36.043
N15332 X-33.166 Z-35.047
N15333 X-34.002 Z-33.989
N15334 X-34.839 Z-32.859
N15335 X-35.676 Z-31.638
N15336 X-36.635 Z-30.125
N15337 X-37.595 Z-28.455
N15338 X-38.074 Z-27.548
N15339 X-38.554 Z-26.583
N15340 X-39.033 Z-25.551
N15341 X-39.758 Z-23.846
N15342 X-40.491 Z-21.866
N15343 X-41.346 Z-19.058
N15344 X-41.98 Z-16.328
N15345 X-42.491 Z-13.111
N15346 X-42.798 Z-9.748
N15347 X-42.901 Z-9.105
N15348 X-43.105 Z-8.22
N15349 X-43.33 Z-7.496
N15350 X-43.554 Z-6.906
N15351 X-44.003 Z-5.952
N15352 X-44.452 Z-5.184
N15353 X-44.901 Z-4.527
N15354 X-45.35 Z-3.957
N15355 X-45.799 Z-3.462
N15356 X-46.248 Z-3.014
N15357 X-46.697 Z-2.617
N15358 X-47.146 Z-2.26
N15359 X-47.595 Z-1.936
N15360 X-48.493 Z-1.385
N15361 X-49.391 Z-.942
N15362 X-50.289 Z-.593
N15363 X-51.187 Z-.33
N15364 X-52.085 Z-.145
N15365 X-52.984 Z-.036
N15366 X-53.882 Z0.
N15367 Y-59.425
N15368 X-52.984 Z-.036
N15369 X-52.085 Z-.145
N15370 X-51.187 Z-.33
N15371 X-50.289 Z-.593
N15372 X-49.391 Z-.942
N15373 X-48.493 Z-1.385
N15374 X-47.595 Z-1.936
N15375 X-47.146 Z-2.26
N15376 X-46.697 Z-2.617
N15377 X-46.248 Z-3.014
N15378 X-45.799 Z-3.462
N15379 X-45.35 Z-3.957
N15380 X-44.901 Z-4.527
N15381 X-44.452 Z-5.184
N15382 X-44.003 Z-5.952
N15383 X-43.554 Z-6.906
N15384 X-43.33 Z-7.496
N15385 X-43.105 Z-8.22
N15386 X-42.901 Z-9.105
N15387 X-42.798 Z-9.748
N15388 X-42.491 Z-13.111
N15389 X-41.98 Z-16.328
N15390 X-41.346 Z-19.058
N15391 X-40.491 Z-21.866
N15392 X-39.758 Z-23.846
N15393 X-39.033 Z-25.551
N15394 X-38.554 Z-26.583
N15395 X-38.074 Z-27.548
N15396 X-37.595 Z-28.455
N15397 X-36.635 Z-30.125
N15398 X-35.676 Z-31.638
N15399 X-34.839 Z-32.859
N15400 X-34.002 Z-33.989
N15401 X-33.166 Z-35.047
N15402 X-32.329 Z-36.043
N15403 X-31.408 Z-37.073
N15404 X-30.487 Z-38.035
N15405 X-29.566 Z-38.941
N15406 X-28.645 Z-39.796
N15407 X-27.77 Z-40.565
N15408 X-26.895 Z-41.292
N15409 X-26.02 Z-41.981
N15410 X-25.145 Z-42.634
N15411 X-24.233 Z-43.278
N15412 X-23.321 Z-43.886
N15413 X-22.41 Z-44.462
N15414 X-21.498 Z-45.007
N15415 X-19.729 Z-45.98
N15416 X-17.961 Z-46.848
N15417 X-16.151 Z-47.634
N15418 X-14.342 Z-48.323
N15419 X-12.559 Z-48.913
N15420 X-10.776 Z-49.418
N15421 X-8.958 Z-49.849
N15422 X-7.169 Z-50.192
N15423 X-5.362 Z-50.46
N15424 X-3.592 Z-50.648
N15425 X-1.797 Z-50.761
N15426 X0. Z-50.8
N15427 X1.797 Z-50.761
N15428 X3.592 Z-50.648
N15429 X5.362 Z-50.46
N15430 X7.169 Z-50.192
N15431 X8.958 Z-49.849
N15432 X10.776 Z-49.418
N15433 X12.559 Z-48.913
N15434 X14.342 Z-48.323
N15435 X16.151 Z-47.634
N15436 X17.961 Z-46.848
N15437 X18.845 Z-46.427
N15438 X20.614 Z-45.507
N15439 X22.41 Z-44.462
N15440 X23.321 Z-43.886
N15441 X24.233 Z-43.278
N15442 X25.145 Z-42.634
N15443 X26.02 Z-41.981
N15444 X26.895 Z-41.292
N15445 X27.77 Z-40.565
N15446 X28.645 Z-39.796
N15447 X29.566 Z-38.941
N15448 X30.487 Z-38.035
N15449 X31.408 Z-37.073
N15450 X32.329 Z-36.043
N15451 X33.166 Z-35.047
N15452 X34.002 Z-33.989
N15453 X34.839 Z-32.859
N15454 X35.676 Z-31.638
N15455 X36.156 Z-30.898
N15456 X37.115 Z-29.312
N15457 X38.074 Z-27.548
N15458 X38.554 Z-26.583
N15459 X39.033 Z-25.551
N15460 X39.758 Z-23.846
N15461 X40.491 Z-21.866
N15462 X40.979 Z-20.339
N15463 X41.571 Z-18.178
N15464 X42.184 Z-15.229
N15465 X42.44 Z-13.521
N15466 X42.798 Z-9.748
N15467 X43.003 Z-8.618
N15468 X43.217 Z-7.836
N15469 X43.554 Z-6.906
N15470 X43.779 Z-6.407
N15471 X44.228 Z-5.548
N15472 X44.677 Z-4.839
N15473 X45.35 Z-3.957
N15474 X45.799 Z-3.462
N15475 X46.248 Z-3.014
N15476 X46.697 Z-2.617
N15477 X47.146 Z-2.26
N15478 X47.595 Z-1.936
N15479 X48.493 Z-1.385
N15480 X49.391 Z-.942
N15481 X50.289 Z-.593
N15482 X51.187 Z-.33
N15483 X52.085 Z-.145
N15484 X52.984 Z-.036
N15485 X53.882 Z0.
N15486 Y-60.625
N15487 X52.984 Z-.036
N15488 X52.085 Z-.145
N15489 X51.187 Z-.33
N15490 X50.289 Z-.593
N15491 X49.391 Z-.942
N15492 X48.493 Z-1.385
N15493 X47.595 Z-1.936
N15494 X47.146 Z-2.26
N15495 X46.697 Z-2.617
N15496 X46.248 Z-3.014
N15497 X45.799 Z-3.462
N15498 X45.35 Z-3.957
N15499 X44.677 Z-4.839
N15500 X44.228 Z-5.548
N15501 X43.779 Z-6.407
N15502 X43.554 Z-6.906
N15503 X43.217 Z-7.836
N15504 X43.003 Z-8.618
N15505 X42.798 Z-9.748
N15506 X42.44 Z-13.521
N15507 X42.184 Z-15.229
N15508 X41.571 Z-18.178
N15509 X40.979 Z-20.339
N15510 X40.491 Z-21.866
N15511 X39.758 Z-23.846
N15512 X39.033 Z-25.551
N15513 X38.554 Z-26.583
N15514 X38.074 Z-27.548
N15515 X37.115 Z-29.312
N15516 X36.156 Z-30.898
N15517 X35.676 Z-31.638
N15518 X34.839 Z-32.859
N15519 X34.002 Z-33.989
N15520 X33.166 Z-35.047
N15521 X32.329 Z-36.043
N15522 X31.408 Z-37.073
N15523 X30.487 Z-38.035
N15524 X29.566 Z-38.941
N15525 X28.645 Z-39.796
N15526 X27.77 Z-40.565
N15527 X26.895 Z-41.292
N15528 X26.02 Z-41.981
N15529 X25.145 Z-42.634
N15530 X24.233 Z-43.278
N15531 X23.321 Z-43.886
N15532 X22.41 Z-44.462
N15533 X20.614 Z-45.507
N15534 X18.845 Z-46.427
N15535 X17.961 Z-46.848
N15536 X16.151 Z-47.634
N15537 X14.342 Z-48.323
N15538 X12.559 Z-48.913
N15539 X10.776 Z-49.418
N15540 X8.958 Z-49.849
N15541 X7.169 Z-50.192
N15542 X5.362 Z-50.46
N15543 X3.592 Z-50.648
N15544 X1.797 Z-50.761
N15545 X0. Z-50.8
N15546 X-1.797 Z-50.761
N15547 X-3.592 Z-50.648
N15548 X-5.362 Z-50.46
N15549 X-7.169 Z-50.192
N15550 X-8.958 Z-49.849
N15551 X-10.776 Z-49.418
N15552 X-12.559 Z-48.913
N15553 X-14.342 Z-48.323
N15554 X-16.151 Z-47.634
N15555 X-17.961 Z-46.848
N15556 X-19.729 Z-45.98
N15557 X-21.498 Z-45.007
N15558 X-22.41 Z-44.462
N15559 X-23.321 Z-43.886
N15560 X-24.233 Z-43.278
N15561 X-25.145 Z-42.634
N15562 X-26.02 Z-41.981
N15563 X-26.895 Z-41.292
N15564 X-27.77 Z-40.565
N15565 X-28.645 Z-39.796
N15566 X-29.566 Z-38.941
N15567 X-30.487 Z-38.035
N15568 X-31.408 Z-37.073
N15569 X-32.329 Z-36.043
N15570 X-33.166 Z-35.047
N15571 X-34.002 Z-33.989
N15572 X-34.839 Z-32.859
N15573 X-35.676 Z-31.638
N15574 X-36.635 Z-30.125
N15575 X-37.595 Z-28.455
N15576 X-38.074 Z-27.548
N15577 X-38.554 Z-26.583
N15578 X-39.033 Z-25.551
N15579 X-39.758 Z-23.846
N15580 X-40.491 Z-21.866
N15581 X-41.346 Z-19.058
N15582 X-41.98 Z-16.328
N15583 X-42.491 Z-13.111
N15584 X-42.798 Z-9.748
N15585 X-42.901 Z-9.105
N15586 X-43.105 Z-8.22
N15587 X-43.33 Z-7.496
N15588 X-43.554 Z-6.906
N15589 X-44.003 Z-5.952
N15590 X-44.452 Z-5.184
N15591 X-44.901 Z-4.527
N15592 X-45.35 Z-3.957
N15593 X-45.799 Z-3.462
N15594 X-46.248 Z-3.014
N15595 X-46.697 Z-2.617
N15596 X-47.146 Z-2.26
N15597 X-47.595 Z-1.936
N15598 X-48.493 Z-1.385
N15599 X-49.391 Z-.942
N15600 X-50.289 Z-.593
N15601 X-51.187 Z-.33
N15602 X-52.085 Z-.145
N15603 X-52.984 Z-.036
N15604 X-53.882 Z0.
N15605 Y-61.825
N15606 X-52.984 Z-.036
N15607 X-52.085 Z-.145
N15608 X-51.187 Z-.33
N15609 X-50.289 Z-.593
N15610 X-49.391 Z-.942
N15611 X-48.493 Z-1.385
N15612 X-47.595 Z-1.936
N15613 X-47.146 Z-2.26
N15614 X-46.697 Z-2.617
N15615 X-46.248 Z-3.014
N15616 X-45.799 Z-3.462
N15617 X-45.35 Z-3.957
N15618 X-44.901 Z-4.527
N15619 X-44.452 Z-5.184
N15620 X-44.003 Z-5.952
N15621 X-43.554 Z-6.906
N15622 X-43.33 Z-7.496
N15623 X-43.105 Z-8.22
N15624 X-42.901 Z-9.105
N15625 X-42.798 Z-9.748
N15626 X-42.491 Z-13.111
N15627 X-41.98 Z-16.328
N15628 X-41.346 Z-19.058
N15629 X-40.491 Z-21.866
N15630 X-39.758 Z-23.846
N15631 X-39.033 Z-25.551
N15632 X-38.554 Z-26.583
N15633 X-38.074 Z-27.548
N15634 X-37.595 Z-28.455
N15635 X-36.635 Z-30.125
N15636 X-35.676 Z-31.638
N15637 X-34.839 Z-32.859
N15638 X-34.002 Z-33.989
N15639 X-33.166 Z-35.047
N15640 X-32.329 Z-36.043
N15641 X-31.408 Z-37.073
N15642 X-30.487 Z-38.035
N15643 X-29.566 Z-38.941
N15644 X-28.645 Z-39.796
N15645 X-27.77 Z-40.565
N15646 X-26.895 Z-41.292
N15647 X-26.02 Z-41.981
N15648 X-25.145 Z-42.634
N15649 X-24.233 Z-43.278
N15650 X-23.321 Z-43.886
N15651 X-22.41 Z-44.462
N15652 X-21.498 Z-45.007
N15653 X-19.729 Z-45.98
N15654 X-17.961 Z-46.848
N15655 X-16.151 Z-47.634
N15656 X-14.342 Z-48.323
N15657 X-12.559 Z-48.913
N15658 X-10.776 Z-49.418
N15659 X-8.958 Z-49.849
N15660 X-7.169 Z-50.192
N15661 X-5.362 Z-50.46
N15662 X-3.592 Z-50.648
N15663 X-1.797 Z-50.761
N15664 X0. Z-50.8
N15665 X1.797 Z-50.761
N15666 X3.592 Z-50.648
N15667 X5.362 Z-50.46
N15668 X7.169 Z-50.192
N15669 X8.958 Z-49.849
N15670 X10.776 Z-49.418
N15671 X12.559 Z-48.913
N15672 X14.342 Z-48.323
N15673 X16.151 Z-47.634
N15674 X17.961 Z-46.848
N15675 X18.845 Z-46.427
N15676 X20.614 Z-45.507
N15677 X22.41 Z-44.462
N15678 X23.321 Z-43.886
N15679 X24.233 Z-43.278
N15680 X25.145 Z-42.634
N15681 X26.02 Z-41.981
N15682 X26.895 Z-41.292
N15683 X27.77 Z-40.565
N15684 X28.645 Z-39.796
N15685 X29.566 Z-38.941
N15686 X30.487 Z-38.035
N15687 X31.408 Z-37.073
N15688 X32.329 Z-36.043
N15689 X33.166 Z-35.047
N15690 X34.002 Z-33.989
N15691 X34.839 Z-32.859
N15692 X35.676 Z-31.638
N15693 X36.156 Z-30.898
N15694 X37.115 Z-29.312
N15695 X38.074 Z-27.548
N15696 X38.554 Z-26.583
N15697 X39.033 Z-25.551
N15698 X39.758 Z-23.846
N15699 X40.491 Z-21.866
N15700 X40.979 Z-20.339
N15701 X41.571 Z-18.178
N15702 X42.184 Z-15.229
N15703 X42.44 Z-13.521
N15704 X42.798 Z-9.748
N15705 X43.003 Z-8.618
N15706 X43.217 Z-7.836
N15707 X43.554 Z-6.906
N15708 X43.779 Z-6.407
N15709 X44.228 Z-5.548
N15710 X44.677 Z-4.839
N15711 X45.35 Z-3.957
N15712 X45.799 Z-3.462
N15713 X46.248 Z-3.014
N15714 X46.697 Z-2.617
N15715 X47.146 Z-2.26
N15716 X47.595 Z-1.937
N15717 X48.493 Z-1.385
N15718 X49.391 Z-.942
N15719 X50.289 Z-.593
N15720 X51.187 Z-.33
N15721 X52.085 Z-.145
N15722 X52.984 Z-.036
N15723 X53.882 Z0.
N15724 Y-63.025
N15725 X52.984 Z-.036
N15726 X52.085 Z-.145
N15727 X51.187 Z-.33
N15728 X50.289 Z-.593
N15729 X49.391 Z-.942
N15730 X48.493 Z-1.385
N15731 X47.595 Z-1.937
N15732 X47.146 Z-2.26
N15733 X46.697 Z-2.617
N15734 X46.248 Z-3.014
N15735 X45.799 Z-3.462
N15736 X45.35 Z-3.957
N15737 X44.677 Z-4.839
N15738 X44.228 Z-5.548
N15739 X43.779 Z-6.406
N15740 X43.554 Z-6.907
N15741 X43.217 Z-7.836
N15742 X43.003 Z-8.618
N15743 X42.798 Z-9.748
N15744 X42.44 Z-13.521
N15745 X42.184 Z-15.229
N15746 X41.571 Z-18.178
N15747 X40.979 Z-20.339
N15748 X40.491 Z-21.866
N15749 X39.758 Z-23.846
N15750 X39.033 Z-25.551
N15751 X38.554 Z-26.583
N15752 X38.074 Z-27.548
N15753 X37.115 Z-29.312
N15754 X36.156 Z-30.898
N15755 X35.676 Z-31.638
N15756 X34.839 Z-32.859
N15757 X34.002 Z-33.989
N15758 X33.166 Z-35.047
N15759 X32.329 Z-36.043
N15760 X31.408 Z-37.073
N15761 X30.487 Z-38.035
N15762 X29.566 Z-38.941
N15763 X28.645 Z-39.796
N15764 X27.77 Z-40.565
N15765 X26.895 Z-41.292
N15766 X26.02 Z-41.981
N15767 X25.145 Z-42.634
N15768 X24.233 Z-43.278
N15769 X23.321 Z-43.886
N15770 X22.41 Z-44.462
N15771 X20.614 Z-45.507
N15772 X18.845 Z-46.427
N15773 X17.961 Z-46.848
N15774 X16.151 Z-47.634
N15775 X14.342 Z-48.323
N15776 X12.559 Z-48.913
N15777 X10.776 Z-49.418
N15778 X8.958 Z-49.849
N15779 X7.169 Z-50.192
N15780 X5.362 Z-50.46
N15781 X3.592 Z-50.648
N15782 X1.797 Z-50.761
N15783 X0. Z-50.8
N15784 X-1.797 Z-50.761
N15785 X-3.592 Z-50.648
N15786 X-5.362 Z-50.46
N15787 X-7.169 Z-50.192
N15788 X-8.958 Z-49.849
N15789 X-10.776 Z-49.418
N15790 X-12.559 Z-48.913
N15791 X-14.342 Z-48.323
N15792 X-16.151 Z-47.634
N15793 X-17.961 Z-46.848
N15794 X-19.729 Z-45.98
N15795 X-21.498 Z-45.007
N15796 X-22.41 Z-44.462
N15797 X-23.321 Z-43.886
N15798 X-24.233 Z-43.278
N15799 X-25.145 Z-42.634
N15800 X-26.02 Z-41.981
N15801 X-26.895 Z-41.292
N15802 X-27.77 Z-40.565
N15803 X-28.645 Z-39.796
N15804 X-29.566 Z-38.941
N15805 X-30.487 Z-38.035
N15806 X-31.408 Z-37.073
N15807 X-32.329 Z-36.043
N15808 X-33.166 Z-35.047
N15809 X-34.002 Z-33.989
N15810 X-34.839 Z-32.859
N15811 X-35.676 Z-31.638
N15812 X-36.635 Z-30.125
N15813 X-37.595 Z-28.455
N15814 X-38.074 Z-27.548
N15815 X-38.554 Z-26.583
N15816 X-39.033 Z-25.551
N15817 X-39.758 Z-23.846
N15818 X-40.491 Z-21.866
N15819 X-41.346 Z-19.058
N15820 X-41.98 Z-16.328
N15821 X-42.491 Z-13.111
N15822 X-42.798 Z-9.748
N15823 X-42.901 Z-9.106
N15824 X-43.105 Z-8.22
N15825 X-43.33 Z-7.496
N15826 X-43.554 Z-6.907
N15827 X-44.003 Z-5.952
N15828 X-44.452 Z-5.184
N15829 X-44.901 Z-4.527
N15830 X-45.35 Z-3.957
N15831 X-45.799 Z-3.462
N15832 X-46.248 Z-3.014
N15833 X-46.697 Z-2.617
N15834 X-47.146 Z-2.26
N15835 X-47.595 Z-1.937
N15836 X-48.493 Z-1.385
N15837 X-49.391 Z-.942
N15838 X-50.289 Z-.593
N15839 X-51.187 Z-.33
N15840 X-52.085 Z-.145
N15841 X-52.984 Z-.036
N15842 X-53.882 Z0.
N15843 Y-64.225
N15844 X-52.984 Z-.036
N15845 X-52.085 Z-.145
N15846 X-51.187 Z-.33
N15847 X-50.289 Z-.593
N15848 X-49.391 Z-.942
N15849 X-48.493 Z-1.385
N15850 X-47.595 Z-1.937
N15851 X-47.146 Z-2.26
N15852 X-46.697 Z-2.617
N15853 X-46.248 Z-3.014
N15854 X-45.799 Z-3.462
N15855 X-45.35 Z-3.957
N15856 X-44.901 Z-4.527
N15857 X-44.452 Z-5.184
N15858 X-44.003 Z-5.952
N15859 X-43.554 Z-6.907
N15860 X-43.33 Z-7.496
N15861 X-43.105 Z-8.22
N15862 X-42.901 Z-9.106
N15863 X-42.798 Z-9.748
N15864 X-42.491 Z-13.111
N15865 X-41.98 Z-16.328
N15866 X-41.346 Z-19.058
N15867 X-40.491 Z-21.866
N15868 X-39.758 Z-23.846
N15869 X-39.033 Z-25.551
N15870 X-38.554 Z-26.583
N15871 X-38.074 Z-27.548
N15872 X-37.595 Z-28.455
N15873 X-36.635 Z-30.125
N15874 X-35.676 Z-31.638
N15875 X-34.839 Z-32.859
N15876 X-34.002 Z-33.989
N15877 X-33.166 Z-35.047
N15878 X-32.329 Z-36.043
N15879 X-31.408 Z-37.073
N15880 X-30.487 Z-38.035
N15881 X-29.566 Z-38.941
N15882 X-28.645 Z-39.796
N15883 X-27.77 Z-40.565
N15884 X-26.895 Z-41.292
N15885 X-26.02 Z-41.981
N15886 X-25.145 Z-42.634
N15887 X-24.233 Z-43.278
N15888 X-23.321 Z-43.886
N15889 X-22.41 Z-44.462
N15890 X-21.498 Z-45.007
N15891 X-19.729 Z-45.98
N15892 X-17.961 Z-46.848
N15893 X-16.151 Z-47.634
N15894 X-14.342 Z-48.323
N15895 X-12.559 Z-48.913
N15896 X-10.776 Z-49.418
N15897 X-8.958 Z-49.849
N15898 X-7.169 Z-50.192
N15899 X-5.362 Z-50.46
N15900 X-3.592 Z-50.648
N15901 X-1.797 Z-50.761
N15902 X0. Z-50.8
N15903 X1.797 Z-50.761
N15904 X3.592 Z-50.648
N15905 X5.362 Z-50.46
N15906 X7.169 Z-50.192
N15907 X8.958 Z-49.849
N15908 X10.776 Z-49.418
N15909 X12.559 Z-48.913
N15910 X14.342 Z-48.323
N15911 X16.151 Z-47.634
N15912 X17.961 Z-46.848
N15913 X18.845 Z-46.427
N15914 X20.614 Z-45.507
N15915 X22.41 Z-44.462
N15916 X23.321 Z-43.886
N15917 X24.233 Z-43.278
N15918 X25.145 Z-42.634
N15919 X26.02 Z-41.981
N15920 X26.895 Z-41.292
N15921 X27.77 Z-40.565
N15922 X28.645 Z-39.796
N15923 X29.566 Z-38.941
N15924 X30.487 Z-38.035
N15925 X31.408 Z-37.073
N15926 X32.329 Z-36.043
N15927 X33.166 Z-35.047
N15928 X34.002 Z-33.989
N15929 X34.839 Z-32.859
N15930 X35.676 Z-31.638
N15931 X36.156 Z-30.898
N15932 X37.115 Z-29.312
N15933 X38.074 Z-27.548
N15934 X38.554 Z-26.583
N15935 X39.033 Z-25.551
N15936 X39.758 Z-23.846
N15937 X40.491 Z-21.866
N15938 X40.979 Z-20.339
N15939 X41.571 Z-18.178
N15940 X42.184 Z-15.229
N15941 X42.44 Z-13.521
N15942 X42.798 Z-9.748
N15943 X43.003 Z-8.618
N15944 X43.217 Z-7.836
N15945 X43.554 Z-6.907
N15946 X43.779 Z-6.406
N15947 X44.228 Z-5.548
N15948 X44.677 Z-4.839
N15949 X45.35 Z-3.957
N15950 X45.799 Z-3.462
N15951 X46.248 Z-3.014
N15952 X46.697 Z-2.617
N15953 X47.146 Z-2.26
N15954 X47.595 Z-1.937
N15955 X48.493 Z-1.385
N15956 X49.391 Z-.942
N15957 X50.289 Z-.593
N15958 X51.187 Z-.33
N15959 X52.085 Z-.145
N15960 X52.984 Z-.036
N15961 X53.882 Z0.
N15962 Y-65.425
N15963 X52.984 Z-.036
N15964 X52.085 Z-.145
N15965 X51.187 Z-.33
N15966 X50.289 Z-.593
N15967 X49.391 Z-.942
N15968 X48.493 Z-1.386
N15969 X47.595 Z-1.937
N15970 X47.146 Z-2.26
N15971 X46.697 Z-2.617
N15972 X46.248 Z-3.014
N15973 X45.799 Z-3.462
N15974 X45.35 Z-3.957
N15975 X44.677 Z-4.839
N15976 X44.228 Z-5.548
N15977 X43.779 Z-6.406
N15978 X43.554 Z-6.907
N15979 X43.217 Z-7.836
N15980 X43.003 Z-8.618
N15981 X42.798 Z-9.748
N15982 X42.44 Z-13.521
N15983 X42.184 Z-15.229
N15984 X41.571 Z-18.178
N15985 X40.979 Z-20.339
N15986 X40.491 Z-21.866
N15987 X39.758 Z-23.846
N15988 X39.033 Z-25.551
N15989 X38.554 Z-26.583
N15990 X38.074 Z-27.548
N15991 X37.115 Z-29.312
N15992 X36.156 Z-30.898
N15993 X35.676 Z-31.638
N15994 X34.839 Z-32.859
N15995 X34.002 Z-33.989
N15996 X33.166 Z-35.047
N15997 X32.329 Z-36.043
N15998 X31.408 Z-37.073
N15999 X30.487 Z-38.035
N16000 X29.566 Z-38.941
N16001 X28.645 Z-39.796
N16002 X27.77 Z-40.565
N16003 X26.895 Z-41.292
N16004 X26.02 Z-41.981
N16005 X25.145 Z-42.634
N16006 X24.233 Z-43.278
N16007 X23.321 Z-43.886
N16008 X22.41 Z-44.462
N16009 X20.614 Z-45.507
N16010 X18.845 Z-46.427
N16011 X17.961 Z-46.848
N16012 X16.151 Z-47.634
N16013 X14.342 Z-48.323
N16014 X12.559 Z-48.913
N16015 X10.776 Z-49.418
N16016 X8.958 Z-49.849
N16017 X7.169 Z-50.192
N16018 X5.362 Z-50.46
N16019 X3.592 Z-50.648
N16020 X1.797 Z-50.761
N16021 X0. Z-50.8
N16022 X-1.797 Z-50.761
N16023 X-3.592 Z-50.648
N16024 X-5.362 Z-50.46
N16025 X-7.169 Z-50.192
N16026 X-8.958 Z-49.849
N16027 X-10.776 Z-49.418
N16028 X-12.559 Z-48.913
N16029 X-14.342 Z-48.323
N16030 X-16.151 Z-47.634
N16031 X-17.961 Z-46.848
N16032 X-19.729 Z-45.98
N16033 X-21.498 Z-45.007
N16034 X-22.41 Z-44.462
N16035 X-23.321 Z-43.886
N16036 X-24.233 Z-43.278
N16037 X-25.145 Z-42.634
N16038 X-26.02 Z-41.981
N16039 X-26.895 Z-41.292
N16040 X-27.77 Z-40.565
N16041 X-28.645 Z-39.796
N16042 X-29.566 Z-38.941
N16043 X-30.487 Z-38.035
N16044 X-31.408 Z-37.073
N16045 X-32.329 Z-36.043
N16046 X-33.166 Z-35.047
N16047 X-34.002 Z-33.989
N16048 X-34.839 Z-32.859
N16049 X-35.676 Z-31.638
N16050 X-36.635 Z-30.125
N16051 X-37.595 Z-28.455
N16052 X-38.074 Z-27.548
N16053 X-38.554 Z-26.583
N16054 X-39.033 Z-25.551
N16055 X-39.758 Z-23.846
N16056 X-40.491 Z-21.866
N16057 X-41.346 Z-19.058
N16058 X-41.98 Z-16.328
N16059 X-42.491 Z-13.111
N16060 X-42.798 Z-9.748
N16061 X-42.901 Z-9.106
N16062 X-43.105 Z-8.22
N16063 X-43.33 Z-7.496
N16064 X-43.554 Z-6.907
N16065 X-44.003 Z-5.952
N16066 X-44.452 Z-5.184
N16067 X-44.901 Z-4.527
N16068 X-45.35 Z-3.957
N16069 X-45.799 Z-3.462
N16070 X-46.248 Z-3.014
N16071 X-46.697 Z-2.617
N16072 X-47.146 Z-2.26
N16073 X-47.595 Z-1.937
N16074 X-48.493 Z-1.385
N16075 X-49.391 Z-.942
N16076 X-50.289 Z-.593
N16077 X-51.187 Z-.33
N16078 X-52.085 Z-.145
N16079 X-52.984 Z-.036
N16080 X-53.882 Z0.
N16081 Y-66.625
N16082 X-52.984 Z-.036
N16083 X-52.085 Z-.145
N16084 X-51.187 Z-.33
N16085 X-50.289 Z-.594
N16086 X-49.391 Z-.943
N16087 X-48.493 Z-1.386
N16088 X-47.595 Z-1.937
N16089 X-47.146 Z-2.26
N16090 X-46.697 Z-2.617
N16091 X-46.248 Z-3.014
N16092 X-45.799 Z-3.462
N16093 X-45.35 Z-3.957
N16094 X-44.901 Z-4.527
N16095 X-44.452 Z-5.183
N16096 X-44.003 Z-5.952
N16097 X-43.554 Z-6.907
N16098 X-43.33 Z-7.496
N16099 X-43.105 Z-8.22
N16100 X-42.901 Z-9.106
N16101 X-42.798 Z-9.748
N16102 X-42.491 Z-13.111
N16103 X-41.98 Z-16.328
N16104 X-41.346 Z-19.058
N16105 X-40.491 Z-21.866
N16106 X-39.758 Z-23.846
N16107 X-39.033 Z-25.551
N16108 X-38.554 Z-26.583
N16109 X-38.074 Z-27.548
N16110 X-37.595 Z-28.455
N16111 X-36.635 Z-30.125
N16112 X-35.676 Z-31.638
N16113 X-34.839 Z-32.859
N16114 X-34.002 Z-33.989
N16115 X-33.166 Z-35.047
N16116 X-32.329 Z-36.043
N16117 X-31.408 Z-37.073
N16118 X-30.487 Z-38.035
N16119 X-29.566 Z-38.941
N16120 X-28.645 Z-39.796
N16121 X-27.77 Z-40.565
N16122 X-26.895 Z-41.292
N16123 X-26.02 Z-41.981
N16124 X-25.145 Z-42.634
N16125 X-24.233 Z-43.278
N16126 X-23.321 Z-43.886
N16127 X-22.41 Z-44.462
N16128 X-21.498 Z-45.007
N16129 X-19.729 Z-45.98
N16130 X-17.961 Z-46.848
N16131 X-16.151 Z-47.634
N16132 X-14.342 Z-48.323
N16133 X-12.559 Z-48.913
N16134 X-10.776 Z-49.418
N16135 X-8.958 Z-49.849
N16136 X-7.169 Z-50.192
N16137 X-5.362 Z-50.46
N16138 X-3.592 Z-50.648
N16139 X-1.797 Z-50.761
N16140 X0. Z-50.8
N16141 X1.797 Z-50.761
N16142 X3.592 Z-50.648
N16143 X5.362 Z-50.46
N16144 X7.169 Z-50.192
N16145 X8.958 Z-49.849
N16146 X10.776 Z-49.418
N16147 X12.559 Z-48.913
N16148 X14.342 Z-48.323
N16149 X16.151 Z-47.634
N16150 X17.961 Z-46.848
N16151 X18.845 Z-46.427
N16152 X20.614 Z-45.507
N16153 X22.41 Z-44.462
N16154 X23.321 Z-43.886
N16155 X24.233 Z-43.278
N16156 X25.145 Z-42.634
N16157 X26.02 Z-41.981
N16158 X26.895 Z-41.292
N16159 X27.77 Z-40.565
N16160 X28.645 Z-39.796
N16161 X29.566 Z-38.941
N16162 X30.487 Z-38.035
N16163 X31.408 Z-37.073
N16164 X32.329 Z-36.043
N16165 X33.166 Z-35.047
N16166 X34.002 Z-33.989
N16167 X34.839 Z-32.859
N16168 X35.676 Z-31.638
N16169 X36.156 Z-30.898
N16170 X37.115 Z-29.312
N16171 X38.074 Z-27.548
N16172 X38.554 Z-26.583
N16173 X39.033 Z-25.551
N16174 X39.758 Z-23.846
N16175 X40.491 Z-21.866
N16176 X40.979 Z-20.339
N16177 X41.571 Z-18.178
N16178 X42.184 Z-15.229
N16179 X42.44 Z-13.52
N16180 X42.798 Z-9.748
N16181 X43.003 Z-8.618
N16182 X43.217 Z-7.836
N16183 X43.554 Z-6.907
N16184 X43.779 Z-6.406
N16185 X44.228 Z-5.548
N16186 X44.677 Z-4.839
N16187 X45.35 Z-3.957
N16188 X45.799 Z-3.462
N16189 X46.248 Z-3.014
N16190 X46.697 Z-2.617
N16191 X47.146 Z-2.26
N16192 X47.595 Z-1.937
N16193 X48.493 Z-1.386
N16194 X49.391 Z-.943
N16195 X50.289 Z-.594
N16196 X51.187 Z-.33
N16197 X52.085 Z-.145
N16198 X52.984 Z-.036
N16199 X53.882 Z0.
N16200 Y-67.825
N16201 X52.984 Z-.036
N16202 X52.085 Z-.145
N16203 X51.187 Z-.33
N16204 X50.289 Z-.594
N16205 X49.391 Z-.943
N16206 X48.493 Z-1.386
N16207 X47.595 Z-1.937
N16208 X47.146 Z-2.26
N16209 X46.697 Z-2.618
N16210 X46.248 Z-3.014
N16211 X45.799 Z-3.462
N16212 X45.35 Z-3.957
N16213 X44.677 Z-4.839
N16214 X44.228 Z-5.548
N16215 X43.779 Z-6.406
N16216 X43.554 Z-6.907
N16217 X43.217 Z-7.836
N16218 X43.003 Z-8.618
N16219 X42.798 Z-9.748
N16220 X42.44 Z-13.52
N16221 X42.184 Z-15.229
N16222 X41.571 Z-18.178
N16223 X40.979 Z-20.339
N16224 X40.491 Z-21.866
N16225 X39.758 Z-23.846
N16226 X39.033 Z-25.551
N16227 X38.554 Z-26.583
N16228 X38.074 Z-27.548
N16229 X37.115 Z-29.312
N16230 X36.156 Z-30.898
N16231 X35.258 Z-32.259
N16232 X34.839 Z-32.859
N16233 X34.002 Z-33.989
N16234 X33.166 Z-35.047
N16235 X32.329 Z-36.043
N16236 X31.408 Z-37.073
N16237 X30.487 Z-38.035
N16238 X29.566 Z-38.941
N16239 X28.645 Z-39.796
N16240 X27.77 Z-40.565
N16241 X26.895 Z-41.292
N16242 X26.02 Z-41.981
N16243 X25.145 Z-42.634
N16244 X24.233 Z-43.278
N16245 X23.321 Z-43.886
N16246 X22.41 Z-44.462
N16247 X20.614 Z-45.507
N16248 X18.845 Z-46.427
N16249 X17.961 Z-46.848
N16250 X16.151 Z-47.634
N16251 X14.342 Z-48.323
N16252 X12.559 Z-48.913
N16253 X10.776 Z-49.418
N16254 X8.958 Z-49.849
N16255 X7.169 Z-50.192
N16256 X5.362 Z-50.46
N16257 X3.592 Z-50.648
N16258 X1.797 Z-50.761
N16259 X0. Z-50.8
N16260 X-1.797 Z-50.761
N16261 X-3.592 Z-50.648
N16262 X-5.362 Z-50.46
N16263 X-7.169 Z-50.192
N16264 X-8.958 Z-49.849
N16265 X-10.776 Z-49.418
N16266 X-12.559 Z-48.913
N16267 X-14.342 Z-48.323
N16268 X-16.151 Z-47.634
N16269 X-17.961 Z-46.848
N16270 X-19.729 Z-45.98
N16271 X-21.498 Z-45.007
N16272 X-22.41 Z-44.462
N16273 X-23.321 Z-43.886
N16274 X-24.233 Z-43.278
N16275 X-25.145 Z-42.634
N16276 X-26.02 Z-41.981
N16277 X-26.895 Z-41.292
N16278 X-27.77 Z-40.565
N16279 X-28.645 Z-39.796
N16280 X-29.566 Z-38.941
N16281 X-30.487 Z-38.035
N16282 X-31.408 Z-37.073
N16283 X-32.329 Z-36.043
N16284 X-33.166 Z-35.047
N16285 X-34.002 Z-33.989
N16286 X-34.839 Z-32.859
N16287 X-35.676 Z-31.638
N16288 X-36.635 Z-30.125
N16289 X-37.595 Z-28.455
N16290 X-38.074 Z-27.548
N16291 X-38.554 Z-26.583
N16292 X-39.033 Z-25.551
N16293 X-39.758 Z-23.846
N16294 X-40.491 Z-21.866
N16295 X-41.346 Z-19.058
N16296 X-41.98 Z-16.328
N16297 X-42.491 Z-13.111
N16298 X-42.798 Z-9.748
N16299 X-42.901 Z-9.106
N16300 X-43.105 Z-8.22
N16301 X-43.33 Z-7.496
N16302 X-43.554 Z-6.907
N16303 X-44.003 Z-5.952
N16304 X-44.452 Z-5.183
N16305 X-44.901 Z-4.527
N16306 X-45.35 Z-3.957
N16307 X-45.799 Z-3.462
N16308 X-46.248 Z-3.014
N16309 X-46.697 Z-2.617
N16310 X-47.146 Z-2.26
N16311 X-47.595 Z-1.937
N16312 X-48.493 Z-1.386
N16313 X-49.391 Z-.943
N16314 X-50.289 Z-.594
N16315 X-51.187 Z-.33
N16316 X-52.085 Z-.145
N16317 X-52.984 Z-.036
N16318 X-53.882 Z0.
N16319 Y-69.025
N16320 X-52.984 Z-.036
N16321 X-52.085 Z-.145
N16322 X-51.187 Z-.33
N16323 X-50.289 Z-.594
N16324 X-49.391 Z-.943
N16325 X-48.493 Z-1.386
N16326 X-47.595 Z-1.937
N16327 X-47.146 Z-2.26
N16328 X-46.697 Z-2.617
N16329 X-46.248 Z-3.014
N16330 X-45.799 Z-3.462
N16331 X-45.35 Z-3.957
N16332 X-44.901 Z-4.527
N16333 X-44.452 Z-5.183
N16334 X-44.003 Z-5.952
N16335 X-43.554 Z-6.907
N16336 X-43.33 Z-7.496
N16337 X-43.105 Z-8.22
N16338 X-42.901 Z-9.107
N16339 X-42.798 Z-9.748
N16340 X-42.491 Z-13.111
N16341 X-41.98 Z-16.328
N16342 X-41.346 Z-19.058
N16343 X-40.491 Z-21.866
N16344 X-39.758 Z-23.846
N16345 X-39.033 Z-25.551
N16346 X-38.554 Z-26.583
N16347 X-38.074 Z-27.548
N16348 X-37.595 Z-28.455
N16349 X-36.635 Z-30.125
N16350 X-35.676 Z-31.638
N16351 X-34.839 Z-32.859
N16352 X-34.002 Z-33.989
N16353 X-33.166 Z-35.047
N16354 X-32.329 Z-36.043
N16355 X-31.408 Z-37.073
N16356 X-30.487 Z-38.035
N16357 X-29.566 Z-38.941
N16358 X-28.645 Z-39.796
N16359 X-27.77 Z-40.565
N16360 X-26.895 Z-41.292
N16361 X-26.02 Z-41.981
N16362 X-25.145 Z-42.634
N16363 X-24.233 Z-43.278
N16364 X-23.321 Z-43.886
N16365 X-22.41 Z-44.462
N16366 X-21.498 Z-45.007
N16367 X-19.729 Z-45.98
N16368 X-17.961 Z-46.848
N16369 X-16.151 Z-47.634
N16370 X-14.342 Z-48.323
N16371 X-12.559 Z-48.913
N16372 X-10.776 Z-49.418
N16373 X-8.958 Z-49.849
N16374 X-7.169 Z-50.192
N16375 X-5.362 Z-50.46
N16376 X-3.592 Z-50.648
N16377 X-1.797 Z-50.761
N16378 X0. Z-50.8
N16379 X1.797 Z-50.761
N16380 X3.592 Z-50.648
N16381 X5.362 Z-50.46
N16382 X7.169 Z-50.192
N16383 X8.958 Z-49.849
N16384 X10.776 Z-49.418
N16385 X12.559 Z-48.913
N16386 X14.342 Z-48.323
N16387 X16.151 Z-47.634
N16388 X17.961 Z-46.848
N16389 X18.845 Z-46.427
N16390 X20.614 Z-45.507
N16391 X22.41 Z-44.462
N16392 X23.321 Z-43.886
N16393 X24.233 Z-43.278
N16394 X25.145 Z-42.634
N16395 X26.02 Z-41.981
N16396 X26.895 Z-41.292
N16397 X27.77 Z-40.565
N16398 X28.645 Z-39.796
N16399 X29.566 Z-38.941
N16400 X30.487 Z-38.035
N16401 X31.408 Z-37.073
N16402 X32.329 Z-36.043
N16403 X33.166 Z-35.047
N16404 X34.002 Z-33.989
N16405 X34.839 Z-32.859
N16406 X35.258 Z-32.259
N16407 X36.156 Z-30.898
N16408 X37.115 Z-29.312
N16409 X38.074 Z-27.548
N16410 X38.554 Z-26.583
N16411 X39.033 Z-25.551
N16412 X39.758 Z-23.846
N16413 X40.491 Z-21.866
N16414 X40.979 Z-20.339
N16415 X41.571 Z-18.178
N16416 X42.184 Z-15.229
N16417 X42.44 Z-13.52
N16418 X42.798 Z-9.748
N16419 X43.003 Z-8.618
N16420 X43.217 Z-7.836
N16421 X43.554 Z-6.907
N16422 X43.779 Z-6.406
N16423 X44.228 Z-5.548
N16424 X44.677 Z-4.839
N16425 X45.35 Z-3.957
N16426 X45.799 Z-3.462
N16427 X46.248 Z-3.014
N16428 X46.697 Z-2.618
N16429 X47.146 Z-2.259
N16430 X47.595 Z-1.937
N16431 X48.493 Z-1.386
N16432 X49.391 Z-.943
N16433 X50.289 Z-.594
N16434 X51.187 Z-.33
N16435 X52.085 Z-.145
N16436 X52.984 Z-.036
N16437 X53.882 Z0.
N16438 Y-70.225
N16439 X52.984 Z-.036
N16440 X52.085 Z-.145
N16441 X51.187 Z-.33
N16442 X50.289 Z-.594
N16443 X49.391 Z-.943
N16444 X48.493 Z-1.386
N16445 X47.595 Z-1.937
N16446 X47.146 Z-2.259
N16447 X46.697 Z-2.618
N16448 X46.248 Z-3.014
N16449 X45.799 Z-3.462
N16450 X45.35 Z-3.957
N16451 X44.677 Z-4.839
N16452 X44.228 Z-5.548
N16453 X43.779 Z-6.406
N16454 X43.554 Z-6.907
N16455 X43.217 Z-7.836
N16456 X43.003 Z-8.618
N16457 X42.798 Z-9.748
N16458 X42.44 Z-13.52
N16459 X42.184 Z-15.229
N16460 X41.571 Z-18.178
N16461 X40.979 Z-20.339
N16462 X40.491 Z-21.866
N16463 X39.758 Z-23.846
N16464 X39.033 Z-25.551
N16465 X38.554 Z-26.583
N16466 X38.074 Z-27.548
N16467 X37.115 Z-29.312
N16468 X36.156 Z-30.898
N16469 X35.676 Z-31.638
N16470 X34.839 Z-32.859
N16471 X34.002 Z-33.989
N16472 X33.166 Z-35.047
N16473 X32.329 Z-36.043
N16474 X31.408 Z-37.073
N16475 X30.487 Z-38.035
N16476 X29.566 Z-38.941
N16477 X28.645 Z-39.796
N16478 X27.77 Z-40.565
N16479 X26.895 Z-41.292
N16480 X26.02 Z-41.981
N16481 X25.145 Z-42.634
N16482 X24.233 Z-43.278
N16483 X23.321 Z-43.886
N16484 X22.41 Z-44.462
N16485 X20.614 Z-45.507
N16486 X18.845 Z-46.427
N16487 X17.961 Z-46.848
N16488 X16.151 Z-47.634
N16489 X14.342 Z-48.323
N16490 X12.559 Z-48.913
N16491 X10.776 Z-49.418
N16492 X8.958 Z-49.849
N16493 X7.169 Z-50.192
N16494 X5.362 Z-50.46
N16495 X3.592 Z-50.648
N16496 X1.797 Z-50.761
N16497 X0. Z-50.8
N16498 X-1.797 Z-50.761
N16499 X-3.592 Z-50.648
N16500 X-5.362 Z-50.46
N16501 X-7.169 Z-50.192
N16502 X-8.958 Z-49.849
N16503 X-10.776 Z-49.418
N16504 X-12.559 Z-48.913
N16505 X-14.342 Z-48.323
N16506 X-16.151 Z-47.634
N16507 X-17.961 Z-46.848
N16508 X-19.729 Z-45.98
N16509 X-21.498 Z-45.007
N16510 X-22.41 Z-44.462
N16511 X-23.321 Z-43.886
N16512 X-24.233 Z-43.278
N16513 X-25.145 Z-42.634
N16514 X-26.02 Z-41.981
N16515 X-26.895 Z-41.292
N16516 X-27.77 Z-40.565
N16517 X-28.645 Z-39.796
N16518 X-29.566 Z-38.941
N16519 X-30.487 Z-38.035
N16520 X-31.408 Z-37.073
N16521 X-32.329 Z-36.043
N16522 X-33.166 Z-35.047
N16523 X-34.002 Z-33.989
N16524 X-34.839 Z-32.859
N16525 X-35.676 Z-31.638
N16526 X-36.635 Z-30.125
N16527 X-37.595 Z-28.455
N16528 X-38.074 Z-27.548
N16529 X-38.554 Z-26.583
N16530 X-39.033 Z-25.551
N16531 X-39.758 Z-23.846
N16532 X-40.491 Z-21.866
N16533 X-41.346 Z-19.058
N16534 X-41.98 Z-16.328
N16535 X-42.491 Z-13.111
N16536 X-42.798 Z-9.748
N16537 X-42.901 Z-9.107
N16538 X-43.105 Z-8.22
N16539 X-43.33 Z-7.496
N16540 X-43.554 Z-6.907
N16541 X-44.003 Z-5.952
N16542 X-44.452 Z-5.183
N16543 X-44.901 Z-4.527
N16544 X-45.35 Z-3.957
N16545 X-45.799 Z-3.462
N16546 X-46.248 Z-3.014
N16547 X-46.697 Z-2.618
N16548 X-47.146 Z-2.26
N16549 X-47.595 Z-1.937
N16550 X-48.493 Z-1.386
N16551 X-49.391 Z-.943
N16552 X-50.289 Z-.594
N16553 X-51.187 Z-.33
N16554 X-52.085 Z-.145
N16555 X-52.984 Z-.036
N16556 X-53.882 Z0.
N16557 Y-71.425
N16558 X-52.984 Z-.036
N16559 X-52.085 Z-.145
N16560 X-51.187 Z-.33
N16561 X-50.289 Z-.594
N16562 X-49.391 Z-.943
N16563 X-48.493 Z-1.386
N16564 X-47.595 Z-1.937
N16565 X-47.146 Z-2.26
N16566 X-46.697 Z-2.618
N16567 X-46.248 Z-3.014
N16568 X-45.799 Z-3.462
N16569 X-45.35 Z-3.957
N16570 X-44.901 Z-4.527
N16571 X-44.452 Z-5.183
N16572 X-44.003 Z-5.952
N16573 X-43.554 Z-6.907
N16574 X-43.33 Z-7.496
N16575 X-43.105 Z-8.22
N16576 X-42.901 Z-9.107
N16577 X-42.798 Z-9.748
N16578 X-42.491 Z-13.111
N16579 X-41.98 Z-16.328
N16580 X-41.346 Z-19.058
N16581 X-40.491 Z-21.866
N16582 X-39.758 Z-23.846
N16583 X-39.033 Z-25.551
N16584 X-38.554 Z-26.583
N16585 X-38.074 Z-27.548
N16586 X-37.595 Z-28.455
N16587 X-36.635 Z-30.125
N16588 X-35.676 Z-31.638
N16589 X-34.839 Z-32.859
N16590 X-34.002 Z-33.989
N16591 X-33.166 Z-35.047
N16592 X-32.329 Z-36.043
N16593 X-31.408 Z-37.073
N16594 X-30.487 Z-38.035
N16595 X-29.566 Z-38.941
N16596 X-28.645 Z-39.796
N16597 X-27.77 Z-40.565
N16598 X-26.895 Z-41.292
N16599 X-26.02 Z-41.981
N16600 X-25.145 Z-42.634
N16601 X-24.233 Z-43.278
N16602 X-23.321 Z-43.886
N16603 X-22.41 Z-44.462
N16604 X-21.498 Z-45.007
N16605 X-19.729 Z-45.98
N16606 X-17.961 Z-46.848
N16607 X-16.151 Z-47.634
N16608 X-14.342 Z-48.323
N16609 X-12.559 Z-48.913
N16610 X-10.776 Z-49.418
N16611 X-8.958 Z-49.849
N16612 X-7.169 Z-50.192
N16613 X-5.362 Z-50.46
N16614 X-3.592 Z-50.648
N16615 X-1.797 Z-50.761
N16616 X0. Z-50.8
N16617 X1.797 Z-50.761
N16618 X3.592 Z-50.648
N16619 X5.362 Z-50.46
N16620 X7.169 Z-50.192
N16621 X8.958 Z-49.849
N16622 X10.776 Z-49.418
N16623 X12.559 Z-48.913
N16624 X14.342 Z-48.323
N16625 X16.151 Z-47.634
N16626 X17.961 Z-46.848
N16627 X18.845 Z-46.427
N16628 X20.614 Z-45.507
N16629 X22.41 Z-44.462
N16630 X23.321 Z-43.886
N16631 X24.233 Z-43.278
N16632 X25.145 Z-42.634
N16633 X26.02 Z-41.981
N16634 X26.895 Z-41.292
N16635 X27.77 Z-40.565
N16636 X28.645 Z-39.796
N16637 X29.566 Z-38.941
N16638 X30.487 Z-38.035
N16639 X31.408 Z-37.073
N16640 X32.329 Z-36.043
N16641 X33.166 Z-35.047
N16642 X34.002 Z-33.989
N16643 X34.839 Z-32.859
N16644 X35.676 Z-31.638
N16645 X36.156 Z-30.898
N16646 X37.115 Z-29.312
N16647 X38.074 Z-27.548
N16648 X38.554 Z-26.583
N16649 X39.033 Z-25.551
N16650 X39.758 Z-23.846
N16651 X40.491 Z-21.866
N16652 X40.979 Z-20.339
N16653 X41.571 Z-18.178
N16654 X42.184 Z-15.229
N16655 X42.44 Z-13.52
N16656 X42.798 Z-9.748
N16657 X43.003 Z-8.618
N16658 X43.217 Z-7.836
N16659 X43.554 Z-6.907
N16660 X43.779 Z-6.406
N16661 X44.228 Z-5.548
N16662 X44.677 Z-4.839
N16663 X45.35 Z-3.957
N16664 X45.799 Z-3.462
N16665 X46.248 Z-3.014
N16666 X46.697 Z-2.618
N16667 X47.146 Z-2.259
N16668 X47.595 Z-1.937
N16669 X48.493 Z-1.386
N16670 X49.391 Z-.943
N16671 X50.289 Z-.594
N16672 X51.187 Z-.33
N16673 X52.085 Z-.145
N16674 X52.984 Z-.036
N16675 X53.882 Z0.
N16676 Y-72.625
N16677 X52.984 Z-.036
N16678 X52.085 Z-.145
N16679 X51.187 Z-.33
N16680 X50.289 Z-.594
N16681 X49.391 Z-.943
N16682 X48.493 Z-1.386
N16683 X47.595 Z-1.937
N16684 X47.146 Z-2.259
N16685 X46.697 Z-2.618
N16686 X46.248 Z-3.014
N16687 X45.799 Z-3.462
N16688 X45.35 Z-3.957
N16689 X44.677 Z-4.839
N16690 X44.228 Z-5.548
N16691 X43.779 Z-6.406
N16692 X43.554 Z-6.907
N16693 X43.217 Z-7.836
N16694 X43.003 Z-8.618
N16695 X42.798 Z-9.748
N16696 X42.44 Z-13.52
N16697 X42.184 Z-15.229
N16698 X41.571 Z-18.178
N16699 X40.979 Z-20.339
N16700 X40.491 Z-21.866
N16701 X39.758 Z-23.846
N16702 X39.033 Z-25.551
N16703 X38.554 Z-26.583
N16704 X38.074 Z-27.548
N16705 X37.115 Z-29.312
N16706 X36.156 Z-30.898
N16707 X35.676 Z-31.638
N16708 X34.839 Z-32.859
N16709 X34.002 Z-33.989
N16710 X33.166 Z-35.047
N16711 X32.329 Z-36.043
N16712 X31.408 Z-37.073
N16713 X30.487 Z-38.035
N16714 X29.566 Z-38.941
N16715 X28.645 Z-39.796
N16716 X27.77 Z-40.565
N16717 X26.895 Z-41.292
N16718 X26.02 Z-41.981
N16719 X25.145 Z-42.634
N16720 X24.233 Z-43.278
N16721 X23.321 Z-43.886
N16722 X22.41 Z-44.462
N16723 X20.614 Z-45.507
N16724 X18.845 Z-46.427
N16725 X17.961 Z-46.848
N16726 X16.151 Z-47.634
N16727 X14.342 Z-48.323
N16728 X12.559 Z-48.913
N16729 X10.776 Z-49.418
N16730 X8.958 Z-49.849
N16731 X7.169 Z-50.192
N16732 X5.362 Z-50.46
N16733 X3.592 Z-50.648
N16734 X1.797 Z-50.761
N16735 X0. Z-50.8
N16736 X-1.797 Z-50.761
N16737 X-3.592 Z-50.648
N16738 X-5.362 Z-50.46
N16739 X-7.169 Z-50.192
N16740 X-8.958 Z-49.849
N16741 X-10.776 Z-49.418
N16742 X-12.559 Z-48.913
N16743 X-14.342 Z-48.323
N16744 X-16.151 Z-47.634
N16745 X-17.961 Z-46.848
N16746 X-19.729 Z-45.98
N16747 X-21.498 Z-45.007
N16748 X-22.41 Z-44.462
N16749 X-23.321 Z-43.886
N16750 X-24.233 Z-43.278
N16751 X-25.145 Z-42.634
N16752 X-26.02 Z-41.981
N16753 X-26.895 Z-41.292
N16754 X-27.77 Z-40.565
N16755 X-28.645 Z-39.796
N16756 X-29.566 Z-38.941
N16757 X-30.487 Z-38.035
N16758 X-31.408 Z-37.073
N16759 X-32.329 Z-36.043
N16760 X-33.166 Z-35.047
N16761 X-34.002 Z-33.989
N16762 X-34.839 Z-32.859
N16763 X-35.676 Z-31.638
N16764 X-36.635 Z-30.125
N16765 X-37.595 Z-28.455
N16766 X-38.074 Z-27.548
N16767 X-38.554 Z-26.583
N16768 X-39.033 Z-25.551
N16769 X-39.758 Z-23.846
N16770 X-40.491 Z-21.866
N16771 X-41.346 Z-19.058
N16772 X-41.98 Z-16.328
N16773 X-42.491 Z-13.111
N16774 X-42.798 Z-9.748
N16775 X-42.901 Z-9.107
N16776 X-43.105 Z-8.22
N16777 X-43.33 Z-7.496
N16778 X-43.554 Z-6.907
N16779 X-44.003 Z-5.953
N16780 X-44.452 Z-5.183
N16781 X-44.901 Z-4.527
N16782 X-45.35 Z-3.957
N16783 X-45.799 Z-3.462
N16784 X-46.248 Z-3.014
N16785 X-46.697 Z-2.618
N16786 X-47.146 Z-2.259
N16787 X-47.595 Z-1.937
N16788 X-48.493 Z-1.386
N16789 X-49.391 Z-.943
N16790 X-50.289 Z-.594
N16791 X-51.187 Z-.33
N16792 X-52.085 Z-.145
N16793 X-52.984 Z-.036
N16794 X-53.882 Z0.
N16795 Y-73.825
N16796 X-52.984 Z-.036
N16797 X-52.085 Z-.145
N16798 X-51.187 Z-.33
N16799 X-50.289 Z-.594
N16800 X-49.391 Z-.943
N16801 X-48.493 Z-1.386
N16802 X-47.595 Z-1.937
N16803 X-47.146 Z-2.259
N16804 X-46.697 Z-2.618
N16805 X-46.248 Z-3.014
N16806 X-45.799 Z-3.462
N16807 X-45.35 Z-3.957
N16808 X-44.901 Z-4.527
N16809 X-44.452 Z-5.183
N16810 X-44.003 Z-5.953
N16811 X-43.554 Z-6.907
N16812 X-43.33 Z-7.496
N16813 X-43.105 Z-8.22
N16814 X-42.901 Z-9.108
N16815 X-42.798 Z-9.748
N16816 X-42.491 Z-13.111
N16817 X-41.98 Z-16.328
N16818 X-41.346 Z-19.058
N16819 X-40.491 Z-21.866
N16820 X-39.758 Z-23.846
N16821 X-39.033 Z-25.551
N16822 X-38.554 Z-26.583
N16823 X-38.074 Z-27.548
N16824 X-37.595 Z-28.455
N16825 X-36.635 Z-30.125
N16826 X-35.676 Z-31.638
N16827 X-34.839 Z-32.859
N16828 X-34.002 Z-33.989
N16829 X-33.166 Z-35.047
N16830 X-32.329 Z-36.043
N16831 X-31.408 Z-37.073
N16832 X-30.487 Z-38.035
N16833 X-29.566 Z-38.941
N16834 X-28.645 Z-39.796
N16835 X-27.77 Z-40.565
N16836 X-26.895 Z-41.292
N16837 X-26.02 Z-41.981
N16838 X-25.145 Z-42.634
N16839 X-24.233 Z-43.278
N16840 X-23.321 Z-43.886
N16841 X-22.41 Z-44.462
N16842 X-21.498 Z-45.007
N16843 X-19.729 Z-45.98
N16844 X-17.961 Z-46.848
N16845 X-16.151 Z-47.634
N16846 X-14.342 Z-48.323
N16847 X-12.559 Z-48.913
N16848 X-10.776 Z-49.418
N16849 X-8.958 Z-49.849
N16850 X-7.169 Z-50.192
N16851 X-5.362 Z-50.46
N16852 X-3.592 Z-50.648
N16853 X-1.797 Z-50.761
N16854 X0. Z-50.8
N16855 X1.797 Z-50.761
N16856 X3.592 Z-50.648
N16857 X5.362 Z-50.46
N16858 X7.169 Z-50.192
N16859 X8.958 Z-49.849
N16860 X10.776 Z-49.418
N16861 X12.559 Z-48.913
N16862 X14.342 Z-48.323
N16863 X16.151 Z-47.634
N16864 X17.961 Z-46.848
N16865 X18.845 Z-46.427
N16866 X20.614 Z-45.507
N16867 X22.41 Z-44.462
N16868 X23.321 Z-43.886
N16869 X24.233 Z-43.278
N16870 X25.145 Z-42.634
N16871 X26.02 Z-41.981
N16872 X26.895 Z-41.292
N16873 X27.77 Z-40.565
N16874 X28.645 Z-39.796
N16875 X29.566 Z-38.941
N16876 X30.487 Z-38.035
N16877 X31.408 Z-37.073
N16878 X32.329 Z-36.043
N16879 X33.166 Z-35.047
N16880 X34.002 Z-33.989
N16881 X34.839 Z-32.859
N16882 X35.676 Z-31.638
N16883 X36.156 Z-30.898
N16884 X37.115 Z-29.312
N16885 X38.074 Z-27.548
N16886 X38.554 Z-26.583
N16887 X39.033 Z-25.551
N16888 X39.758 Z-23.846
N16889 X40.491 Z-21.866
N16890 X40.979 Z-20.339
N16891 X41.571 Z-18.178
N16892 X42.184 Z-15.229
N16893 X42.44 Z-13.52
N16894 X42.798 Z-9.748
N16895 X43.003 Z-8.618
N16896 X43.217 Z-7.836
N16897 X43.554 Z-6.907
N16898 X43.779 Z-6.405
N16899 X44.228 Z-5.548
N16900 X44.677 Z-4.839
N16901 X45.35 Z-3.957
N16902 X45.799 Z-3.462
N16903 X46.248 Z-3.014
N16904 X46.697 Z-2.618
N16905 X47.146 Z-2.259
N16906 X47.595 Z-1.937
N16907 X48.493 Z-1.386
N16908 X49.391 Z-.943
N16909 X50.289 Z-.594
N16910 X51.187 Z-.33
N16911 X52.085 Z-.145
N16912 X52.984 Z-.036
N16913 X53.882 Z0.
N16914 Y-75.025
N16915 X52.984 Z-.036
N16916 X52.085 Z-.145
N16917 X51.187 Z-.33
N16918 X50.289 Z-.594
N16919 X49.391 Z-.943
N16920 X48.493 Z-1.386
N16921 X47.595 Z-1.937
N16922 X47.146 Z-2.259
N16923 X46.697 Z-2.618
N16924 X46.248 Z-3.014
N16925 X45.799 Z-3.462
N16926 X45.35 Z-3.957
N16927 X44.677 Z-4.839
N16928 X44.228 Z-5.548
N16929 X43.779 Z-6.405
N16930 X43.554 Z-6.907
N16931 X43.217 Z-7.836
N16932 X43.003 Z-8.618
N16933 X42.798 Z-9.748
N16934 X42.44 Z-13.52
N16935 X42.184 Z-15.229
N16936 X41.571 Z-18.178
N16937 X40.979 Z-20.339
N16938 X40.491 Z-21.866
N16939 X39.758 Z-23.846
N16940 X39.033 Z-25.551
N16941 X38.554 Z-26.583
N16942 X38.074 Z-27.548
N16943 X37.115 Z-29.312
N16944 X36.156 Z-30.898
N16945 X35.676 Z-31.638
N16946 X34.839 Z-32.859
N16947 X34.002 Z-33.989
N16948 X33.166 Z-35.047
N16949 X32.329 Z-36.043
N16950 X31.408 Z-37.073
N16951 X30.487 Z-38.035
N16952 X29.566 Z-38.941
N16953 X28.645 Z-39.796
N16954 X27.77 Z-40.565
N16955 X26.895 Z-41.292
N16956 X26.02 Z-41.981
N16957 X25.145 Z-42.634
N16958 X24.233 Z-43.278
N16959 X23.321 Z-43.886
N16960 X22.41 Z-44.462
N16961 X20.614 Z-45.507
N16962 X18.845 Z-46.427
N16963 X17.961 Z-46.848
N16964 X16.151 Z-47.634
N16965 X14.342 Z-48.323
N16966 X12.559 Z-48.913
N16967 X10.776 Z-49.418
N16968 X8.958 Z-49.849
N16969 X7.169 Z-50.192
N16970 X5.362 Z-50.46
N16971 X3.592 Z-50.648
N16972 X1.797 Z-50.761
N16973 X0. Z-50.8
N16974 X-1.797 Z-50.761
N16975 X-3.592 Z-50.648
N16976 X-5.362 Z-50.46
N16977 X-7.169 Z-50.192
N16978 X-8.958 Z-49.849
N16979 X-10.776 Z-49.418
N16980 X-12.559 Z-48.913
N16981 X-14.342 Z-48.323
N16982 X-16.151 Z-47.634
N16983 X-17.961 Z-46.848
N16984 X-19.729 Z-45.98
N16985 X-21.498 Z-45.007
N16986 X-22.41 Z-44.462
N16987 X-23.321 Z-43.886
N16988 X-24.233 Z-43.278
N16989 X-25.145 Z-42.634
N16990 X-26.02 Z-41.981
N16991 X-26.895 Z-41.292
N16992 X-27.77 Z-40.565
N16993 X-28.645 Z-39.796
N16994 X-29.566 Z-38.941
N16995 X-30.487 Z-38.035
N16996 X-31.408 Z-37.073
N16997 X-32.329 Z-36.043
N16998 X-33.166 Z-35.047
N16999 X-34.002 Z-33.989
N17000 X-34.839 Z-32.859
N17001 X-35.676 Z-31.638
N17002 X-36.635 Z-30.125
N17003 X-37.595 Z-28.455
N17004 X-38.074 Z-27.548
N17005 X-38.554 Z-26.583
N17006 X-39.033 Z-25.551
N17007 X-39.758 Z-23.846
N17008 X-40.491 Z-21.866
N17009 X-41.346 Z-19.058
N17010 X-41.98 Z-16.328
N17011 X-42.491 Z-13.111
N17012 X-42.798 Z-9.748
N17013 X-42.901 Z-9.108
N17014 X-43.105 Z-8.22
N17015 X-43.33 Z-7.496
N17016 X-43.554 Z-6.907
N17017 X-44.003 Z-5.953
N17018 X-44.452 Z-5.183
N17019 X-44.901 Z-4.527
N17020 X-45.35 Z-3.957
N17021 X-45.799 Z-3.462
N17022 X-46.248 Z-3.014
N17023 X-46.697 Z-2.618
N17024 X-47.146 Z-2.259
N17025 X-47.595 Z-1.937
N17026 X-48.493 Z-1.386
N17027 X-49.391 Z-.943
N17028 X-50.289 Z-.594
N17029 X-51.187 Z-.33
N17030 X-52.085 Z-.145
N17031 X-52.984 Z-.036
N17032 X-53.882 Z0.
N17033 Y-76.225
N17034 X-52.984 Z-.036
N17035 X-52.085 Z-.145
N17036 X-51.187 Z-.33
N17037 X-50.289 Z-.594
N17038 X-49.391 Z-.943
N17039 X-48.493 Z-1.386
N17040 X-47.595 Z-1.937
N17041 X-47.146 Z-2.259
N17042 X-46.697 Z-2.618
N17043 X-46.248 Z-3.014
N17044 X-45.799 Z-3.462
N17045 X-45.35 Z-3.957
N17046 X-44.901 Z-4.527
N17047 X-44.452 Z-5.183
N17048 X-44.003 Z-5.953
N17049 X-43.554 Z-6.907
N17050 X-43.33 Z-7.496
N17051 X-43.105 Z-8.22
N17052 X-42.901 Z-9.108
N17053 X-42.798 Z-9.748
N17054 X-42.491 Z-13.111
N17055 X-41.98 Z-16.328
N17056 X-41.346 Z-19.058
N17057 X-40.491 Z-21.866
N17058 X-39.758 Z-23.846
N17059 X-39.033 Z-25.551
N17060 X-38.554 Z-26.583
N17061 X-38.074 Z-27.548
N17062 X-37.595 Z-28.455
N17063 X-36.635 Z-30.125
N17064 X-35.676 Z-31.638
N17065 X-34.839 Z-32.859
N17066 X-34.002 Z-33.989
N17067 X-33.166 Z-35.047
N17068 X-32.329 Z-36.043
N17069 X-31.408 Z-37.073
N17070 X-30.487 Z-38.035
N17071 X-29.566 Z-38.941
N17072 X-28.645 Z-39.796
N17073 X-27.77 Z-40.565
N17074 X-26.895 Z-41.292
N17075 X-26.02 Z-41.981
N17076 X-25.145 Z-42.634
N17077 X-24.233 Z-43.278
N17078 X-23.321 Z-43.886
N17079 X-22.41 Z-44.462
N17080 X-21.498 Z-45.007
N17081 X-19.729 Z-45.98
N17082 X-17.961 Z-46.848
N17083 X-16.151 Z-47.634
N17084 X-14.342 Z-48.323
N17085 X-12.559 Z-48.913
N17086 X-10.776 Z-49.418
N17087 X-8.958 Z-49.849
N17088 X-7.169 Z-50.192
N17089 X-5.362 Z-50.46
N17090 X-3.592 Z-50.648
N17091 X-1.797 Z-50.761
N17092 X0. Z-50.8
N17093 X1.797 Z-50.761
N17094 X3.592 Z-50.648
N17095 X5.362 Z-50.46
N17096 X7.169 Z-50.192
N17097 X8.958 Z-49.849
N17098 X10.776 Z-49.418
N17099 X12.559 Z-48.913
N17100 X14.342 Z-48.323
N17101 X16.151 Z-47.634
N17102 X17.961 Z-46.848
N17103 X18.845 Z-46.427
N17104 X20.614 Z-45.507
N17105 X22.41 Z-44.462
N17106 X23.321 Z-43.886
N17107 X24.233 Z-43.278
N17108 X25.145 Z-42.634
N17109 X26.02 Z-41.981
N17110 X26.895 Z-41.292
N17111 X27.77 Z-40.565
N17112 X28.645 Z-39.796
N17113 X29.566 Z-38.941
N17114 X30.487 Z-38.035
N17115 X31.408 Z-37.073
N17116 X32.329 Z-36.043
N17117 X33.166 Z-35.047
N17118 X34.002 Z-33.989
N17119 X34.839 Z-32.859
N17120 X35.676 Z-31.638
N17121 X36.156 Z-30.898
N17122 X37.115 Z-29.312
N17123 X38.074 Z-27.548
N17124 X38.554 Z-26.583
N17125 X39.033 Z-25.551
N17126 X39.758 Z-23.846
N17127 X40.491 Z-21.866
N17128 X40.979 Z-20.339
N17129 X41.571 Z-18.178
N17130 X42.184 Z-15.229
N17131 X42.44 Z-13.52
N17132 X42.798 Z-9.748
N17133 X43.003 Z-8.618
N17134 X43.217 Z-7.837
N17135 X43.554 Z-6.907
N17136 X43.779 Z-6.405
N17137 X44.228 Z-5.548
N17138 X44.677 Z-4.839
N17139 X45.35 Z-3.957
N17140 X45.799 Z-3.462
N17141 X46.248 Z-3.014
N17142 X46.697 Z-2.618
N17143 X47.146 Z-2.259
N17144 X47.595 Z-1.937
N17145 X48.493 Z-1.386
N17146 X49.391 Z-.943
N17147 X50.289 Z-.594
N17148 X51.187 Z-.33
N17149 X52.085 Z-.145
N17150 X52.984 Z-.036
N17151 X53.882 Z0.
N17152 Y-77.425
N17153 X52.984 Z-.036
N17154 X52.085 Z-.145
N17155 X51.187 Z-.33
N17156 X50.289 Z-.594
N17157 X49.391 Z-.943
N17158 X48.493 Z-1.386
N17159 X47.595 Z-1.937
N17160 X47.146 Z-2.259
N17161 X46.697 Z-2.618
N17162 X46.248 Z-3.014
N17163 X45.799 Z-3.462
N17164 X45.35 Z-3.957
N17165 X44.677 Z-4.839
N17166 X44.228 Z-5.548
N17167 X43.779 Z-6.405
N17168 X43.554 Z-6.907
N17169 X43.217 Z-7.837
N17170 X43.003 Z-8.618
N17171 X42.798 Z-9.748
N17172 X42.44 Z-13.52
N17173 X42.184 Z-15.229
N17174 X41.571 Z-18.178
N17175 X40.979 Z-20.339
N17176 X40.491 Z-21.866
N17177 X39.758 Z-23.846
N17178 X39.033 Z-25.551
N17179 X38.554 Z-26.583
N17180 X38.074 Z-27.548
N17181 X37.115 Z-29.312
N17182 X36.156 Z-30.898
N17183 X35.676 Z-31.638
N17184 X34.839 Z-32.859
N17185 X34.002 Z-33.989
N17186 X33.166 Z-35.047
N17187 X32.329 Z-36.043
N17188 X31.408 Z-37.073
N17189 X30.487 Z-38.035
N17190 X29.566 Z-38.941
N17191 X28.645 Z-39.796
N17192 X27.77 Z-40.565
N17193 X26.895 Z-41.292
N17194 X26.02 Z-41.981
N17195 X25.145 Z-42.634
N17196 X24.233 Z-43.278
N17197 X23.321 Z-43.886
N17198 X22.41 Z-44.462
N17199 X20.614 Z-45.507
N17200 X18.845 Z-46.427
N17201 X17.961 Z-46.848
N17202 X16.151 Z-47.634
N17203 X14.342 Z-48.323
N17204 X12.559 Z-48.913
N17205 X10.776 Z-49.418
N17206 X8.958 Z-49.849
N17207 X7.169 Z-50.192
N17208 X5.362 Z-50.46
N17209 X3.592 Z-50.648
N17210 X1.797 Z-50.761
N17211 X0. Z-50.8
N17212 X-1.797 Z-50.761
N17213 X-3.592 Z-50.648
N17214 X-5.362 Z-50.46
N17215 X-7.169 Z-50.192
N17216 X-8.958 Z-49.849
N17217 X-10.776 Z-49.418
N17218 X-12.559 Z-48.913
N17219 X-14.342 Z-48.323
N17220 X-16.151 Z-47.634
N17221 X-17.961 Z-46.848
N17222 X-19.729 Z-45.98
N17223 X-21.498 Z-45.007
N17224 X-22.41 Z-44.462
N17225 X-23.321 Z-43.886
N17226 X-24.233 Z-43.278
N17227 X-25.145 Z-42.634
N17228 X-26.02 Z-41.981
N17229 X-26.895 Z-41.292
N17230 X-27.77 Z-40.565
N17231 X-28.645 Z-39.796
N17232 X-29.566 Z-38.941
N17233 X-30.487 Z-38.035
N17234 X-31.408 Z-37.073
N17235 X-32.329 Z-36.043
N17236 X-33.166 Z-35.047
N17237 X-34.002 Z-33.989
N17238 X-34.839 Z-32.859
N17239 X-35.676 Z-31.638
N17240 X-36.635 Z-30.125
N17241 X-37.595 Z-28.455
N17242 X-38.074 Z-27.548
N17243 X-38.554 Z-26.583
N17244 X-39.033 Z-25.551
N17245 X-39.758 Z-23.846
N17246 X-40.491 Z-21.866
N17247 X-41.346 Z-19.058
N17248 X-41.98 Z-16.328
N17249 X-42.491 Z-13.111
N17250 X-42.798 Z-9.748
N17251 X-42.901 Z-9.108
N17252 X-43.105 Z-8.22
N17253 X-43.33 Z-7.496
N17254 X-43.554 Z-6.907
N17255 X-44.003 Z-5.953
N17256 X-44.452 Z-5.183
N17257 X-44.901 Z-4.527
N17258 X-45.35 Z-3.957
N17259 X-45.799 Z-3.462
N17260 X-46.248 Z-3.014
N17261 X-46.697 Z-2.618
N17262 X-47.146 Z-2.259
N17263 X-47.595 Z-1.937
N17264 X-48.493 Z-1.386
N17265 X-49.391 Z-.943
N17266 X-50.289 Z-.594
N17267 X-51.187 Z-.33
N17268 X-52.085 Z-.145
N17269 X-52.984 Z-.036
N17270 X-53.882 Z0.
N17271 Y-78.625
N17272 X-52.984 Z-.036
N17273 X-52.085 Z-.145
N17274 X-51.187 Z-.33
N17275 X-50.289 Z-.594
N17276 X-49.391 Z-.943
N17277 X-48.493 Z-1.386
N17278 X-47.595 Z-1.937
N17279 X-47.146 Z-2.259
N17280 X-46.697 Z-2.618
N17281 X-46.248 Z-3.014
N17282 X-45.799 Z-3.462
N17283 X-45.35 Z-3.957
N17284 X-44.901 Z-4.527
N17285 X-44.452 Z-5.183
N17286 X-44.003 Z-5.953
N17287 X-43.554 Z-6.908
N17288 X-43.33 Z-7.496
N17289 X-43.105 Z-8.22
N17290 X-42.901 Z-9.108
N17291 X-42.798 Z-9.748
N17292 X-42.491 Z-13.111
N17293 X-41.98 Z-16.328
N17294 X-41.346 Z-19.058
N17295 X-40.491 Z-21.866
N17296 X-39.758 Z-23.846
N17297 X-39.033 Z-25.551
N17298 X-38.554 Z-26.583
N17299 X-38.074 Z-27.548
N17300 X-37.595 Z-28.455
N17301 X-36.635 Z-30.125
N17302 X-35.676 Z-31.638
N17303 X-34.839 Z-32.859
N17304 X-34.002 Z-33.989
N17305 X-33.166 Z-35.047
N17306 X-32.329 Z-36.043
N17307 X-31.408 Z-37.073
N17308 X-30.487 Z-38.035
N17309 X-29.566 Z-38.941
N17310 X-28.645 Z-39.796
N17311 X-27.77 Z-40.565
N17312 X-26.895 Z-41.292
N17313 X-26.02 Z-41.981
N17314 X-25.145 Z-42.634
N17315 X-24.233 Z-43.278
N17316 X-23.321 Z-43.886
N17317 X-22.41 Z-44.462
N17318 X-21.498 Z-45.007
N17319 X-19.729 Z-45.98
N17320 X-17.961 Z-46.848
N17321 X-16.151 Z-47.634
N17322 X-14.342 Z-48.323
N17323 X-12.559 Z-48.913
N17324 X-10.776 Z-49.418
N17325 X-8.958 Z-49.849
N17326 X-7.169 Z-50.192
N17327 X-5.362 Z-50.46
N17328 X-3.592 Z-50.648
N17329 X-1.797 Z-50.761
N17330 X0. Z-50.8
N17331 X1.797 Z-50.761
N17332 X3.592 Z-50.648
N17333 X5.362 Z-50.46
N17334 X7.169 Z-50.192
N17335 X8.958 Z-49.849
N17336 X10.776 Z-49.418
N17337 X12.559 Z-48.913
N17338 X14.342 Z-48.323
N17339 X16.151 Z-47.634
N17340 X17.961 Z-46.848
N17341 X18.845 Z-46.427
N17342 X20.614 Z-45.507
N17343 X22.41 Z-44.462
N17344 X23.321 Z-43.886
N17345 X24.233 Z-43.278
N17346 X25.145 Z-42.634
N17347 X26.02 Z-41.981
N17348 X26.895 Z-41.292
N17349 X27.77 Z-40.565
N17350 X28.645 Z-39.796
N17351 X29.566 Z-38.941
N17352 X30.487 Z-38.035
N17353 X31.408 Z-37.073
N17354 X32.329 Z-36.043
N17355 X33.166 Z-35.047
N17356 X34.002 Z-33.989
N17357 X34.839 Z-32.859
N17358 X35.676 Z-31.638
N17359 X36.156 Z-30.898
N17360 X37.115 Z-29.312
N17361 X38.074 Z-27.548
N17362 X38.554 Z-26.583
N17363 X39.033 Z-25.551
N17364 X39.758 Z-23.846
N17365 X40.491 Z-21.866
N17366 X40.979 Z-20.339
N17367 X41.571 Z-18.178
N17368 X42.184 Z-15.229
N17369 X42.44 Z-13.52
N17370 X42.798 Z-9.748
N17371 X43.003 Z-8.618
N17372 X43.217 Z-7.837
N17373 X43.554 Z-6.908
N17374 X43.779 Z-6.405
N17375 X44.228 Z-5.548
N17376 X44.677 Z-4.839
N17377 X45.35 Z-3.957
N17378 X45.799 Z-3.462
N17379 X46.248 Z-3.014
N17380 X46.697 Z-2.618
N17381 X47.146 Z-2.259
N17382 X47.595 Z-1.937
N17383 X48.493 Z-1.386
N17384 X49.391 Z-.943
N17385 X50.289 Z-.594
N17386 X51.187 Z-.33
N17387 X52.085 Z-.145
N17388 X52.984 Z-.036
N17389 X53.882 Z0.
N17390 Y-79.825
N17391 X52.984 Z-.036
N17392 X52.085 Z-.145
N17393 X51.187 Z-.33
N17394 X50.289 Z-.594
N17395 X49.391 Z-.943
N17396 X48.493 Z-1.386
N17397 X47.595 Z-1.937
N17398 X47.146 Z-2.259
N17399 X46.697 Z-2.618
N17400 X46.248 Z-3.014
N17401 X45.799 Z-3.462
N17402 X45.35 Z-3.957
N17403 X44.677 Z-4.839
N17404 X44.228 Z-5.548
N17405 X43.779 Z-6.405
N17406 X43.554 Z-6.908
N17407 X43.217 Z-7.837
N17408 X43.003 Z-8.618
N17409 X42.798 Z-9.748
N17410 X42.44 Z-13.52
N17411 X42.184 Z-15.229
N17412 X41.571 Z-18.178
N17413 X40.979 Z-20.339
N17414 X40.491 Z-21.866
N17415 X39.758 Z-23.846
N17416 X39.033 Z-25.551
N17417 X38.554 Z-26.583
N17418 X38.074 Z-27.548
N17419 X37.115 Z-29.312
N17420 X36.156 Z-30.898
N17421 X35.676 Z-31.638
N17422 X34.839 Z-32.859
N17423 X34.002 Z-33.989
N17424 X33.166 Z-35.047
N17425 X32.329 Z-36.043
N17426 X31.408 Z-37.073
N17427 X30.487 Z-38.035
N17428 X29.566 Z-38.941
N17429 X28.645 Z-39.796
N17430 X27.77 Z-40.565
N17431 X26.895 Z-41.292
N17432 X26.02 Z-41.981
N17433 X25.145 Z-42.634
N17434 X24.233 Z-43.278
N17435 X23.321 Z-43.886
N17436 X22.41 Z-44.462
N17437 X20.614 Z-45.507
N17438 X18.845 Z-46.427
N17439 X17.961 Z-46.848
N17440 X16.151 Z-47.634
N17441 X14.342 Z-48.323
N17442 X12.559 Z-48.913
N17443 X10.776 Z-49.418
N17444 X8.958 Z-49.849
N17445 X7.169 Z-50.192
N17446 X5.362 Z-50.46
N17447 X3.592 Z-50.648
N17448 X1.797 Z-50.761
N17449 X0. Z-50.8
N17450 X-1.797 Z-50.761
N17451 X-3.592 Z-50.648
N17452 X-5.362 Z-50.46
N17453 X-7.169 Z-50.192
N17454 X-8.958 Z-49.849
N17455 X-10.776 Z-49.418
N17456 X-12.559 Z-48.913
N17457 X-14.342 Z-48.323
N17458 X-16.151 Z-47.634
N17459 X-17.961 Z-46.848
N17460 X-19.729 Z-45.98
N17461 X-21.498 Z-45.007
N17462 X-22.41 Z-44.462
N17463 X-23.321 Z-43.886
N17464 X-24.233 Z-43.278
N17465 X-25.145 Z-42.634
N17466 X-26.02 Z-41.981
N17467 X-26.895 Z-41.292
N17468 X-27.77 Z-40.565
N17469 X-28.645 Z-39.796
N17470 X-29.566 Z-38.941
N17471 X-30.487 Z-38.035
N17472 X-31.408 Z-37.073
N17473 X-32.329 Z-36.043
N17474 X-33.166 Z-35.047
N17475 X-34.002 Z-33.989
N17476 X-34.839 Z-32.859
N17477 X-35.676 Z-31.638
N17478 X-36.635 Z-30.125
N17479 X-37.595 Z-28.455
N17480 X-38.074 Z-27.548
N17481 X-38.554 Z-26.583
N17482 X-39.033 Z-25.551
N17483 X-39.758 Z-23.846
N17484 X-40.491 Z-21.866
N17485 X-41.346 Z-19.058
N17486 X-41.98 Z-16.328
N17487 X-42.491 Z-13.111
N17488 X-42.798 Z-9.748
N17489 X-42.901 Z-9.109
N17490 X-43.105 Z-8.22
N17491 X-43.33 Z-7.496
N17492 X-43.554 Z-6.908
N17493 X-44.003 Z-5.953
N17494 X-44.452 Z-5.183
N17495 X-44.901 Z-4.527
N17496 X-45.35 Z-3.957
N17497 X-45.799 Z-3.462
N17498 X-46.248 Z-3.014
N17499 X-46.697 Z-2.618
N17500 X-47.146 Z-2.259
N17501 X-47.595 Z-1.937
N17502 X-48.493 Z-1.386
N17503 X-49.391 Z-.943
N17504 X-50.289 Z-.594
N17505 X-51.187 Z-.33
N17506 X-52.085 Z-.145
N17507 X-52.984 Z-.036
N17508 X-53.882 Z0.
N17509 Y-81.025
N17510 X-52.984 Z-.036
N17511 X-52.085 Z-.145
N17512 X-51.187 Z-.33
N17513 X-50.289 Z-.594
N17514 X-49.391 Z-.943
N17515 X-48.493 Z-1.386
N17516 X-47.595 Z-1.937
N17517 X-47.146 Z-2.259
N17518 X-46.697 Z-2.618
N17519 X-46.248 Z-3.014
N17520 X-45.799 Z-3.462
N17521 X-45.35 Z-3.957
N17522 X-44.901 Z-4.527
N17523 X-44.452 Z-5.183
N17524 X-44.003 Z-5.953
N17525 X-43.554 Z-6.908
N17526 X-43.33 Z-7.496
N17527 X-43.105 Z-8.22
N17528 X-42.901 Z-9.109
N17529 X-42.798 Z-9.748
N17530 X-42.491 Z-13.111
N17531 X-41.98 Z-16.328
N17532 X-41.346 Z-19.058
N17533 X-40.491 Z-21.866
N17534 X-39.758 Z-23.846
N17535 X-39.033 Z-25.551
N17536 X-38.554 Z-26.583
N17537 X-38.074 Z-27.548
N17538 X-37.595 Z-28.455
N17539 X-36.635 Z-30.125
N17540 X-35.676 Z-31.638
N17541 X-34.839 Z-32.859
N17542 X-34.002 Z-33.989
N17543 X-33.166 Z-35.047
N17544 X-32.329 Z-36.043
N17545 X-31.408 Z-37.073
N17546 X-30.487 Z-38.035
N17547 X-29.566 Z-38.941
N17548 X-28.645 Z-39.796
N17549 X-27.77 Z-40.565
N17550 X-26.895 Z-41.292
N17551 X-26.02 Z-41.981
N17552 X-25.145 Z-42.634
N17553 X-24.233 Z-43.278
N17554 X-23.321 Z-43.886
N17555 X-22.41 Z-44.462
N17556 X-21.498 Z-45.007
N17557 X-19.729 Z-45.98
N17558 X-17.961 Z-46.848
N17559 X-16.151 Z-47.634
N17560 X-14.342 Z-48.323
N17561 X-12.559 Z-48.913
N17562 X-10.776 Z-49.418
N17563 X-8.958 Z-49.849
N17564 X-7.169 Z-50.192
N17565 X-5.362 Z-50.46
N17566 X-3.592 Z-50.648
N17567 X-1.797 Z-50.761
N17568 X0. Z-50.8
N17569 X1.797 Z-50.761
N17570 X3.592 Z-50.648
N17571 X5.362 Z-50.46
N17572 X7.169 Z-50.192
N17573 X8.958 Z-49.849
N17574 X10.776 Z-49.418
N17575 X12.559 Z-48.913
N17576 X14.342 Z-48.323
N17577 X16.151 Z-47.634
N17578 X17.961 Z-46.848
N17579 X18.845 Z-46.427
N17580 X20.614 Z-45.507
N17581 X22.41 Z-44.462
N17582 X23.321 Z-43.886
N17583 X24.233 Z-43.278
N17584 X25.145 Z-42.634
N17585 X26.02 Z-41.981
N17586 X26.895 Z-41.292
N17587 X27.77 Z-40.565
N17588 X28.645 Z-39.796
N17589 X29.566 Z-38.941
N17590 X30.487 Z-38.035
N17591 X31.408 Z-37.073
N17592 X32.329 Z-36.043
N17593 X33.166 Z-35.047
N17594 X34.002 Z-33.989
N17595 X34.839 Z-32.859
N17596 X35.676 Z-31.638
N17597 X36.156 Z-30.898
N17598 X37.115 Z-29.312
N17599 X38.074 Z-27.548
N17600 X38.554 Z-26.583
N17601 X39.033 Z-25.551
N17602 X39.758 Z-23.846
N17603 X40.491 Z-21.866
N17604 X40.979 Z-20.339
N17605 X41.571 Z-18.178
N17606 X42.184 Z-15.229
N17607 X42.44 Z-13.52
N17608 X42.798 Z-9.748
N17609 X43.003 Z-8.618
N17610 X43.217 Z-7.837
N17611 X43.554 Z-6.908
N17612 X43.779 Z-6.405
N17613 X44.228 Z-5.548
N17614 X44.677 Z-4.839
N17615 X45.35 Z-3.957
N17616 X45.799 Z-3.462
N17617 X46.248 Z-3.014
N17618 X46.697 Z-2.618
N17619 X47.146 Z-2.259
N17620 X47.595 Z-1.937
N17621 X48.493 Z-1.386
N17622 X49.391 Z-.943
N17623 X50.289 Z-.594
N17624 X51.187 Z-.33
N17625 X52.085 Z-.145
N17626 X52.984 Z-.036
N17627 X53.882 Z0.
N17628 Y-82.225
N17629 X52.984 Z-.036
N17630 X52.085 Z-.145
N17631 X51.187 Z-.33
N17632 X50.289 Z-.594
N17633 X49.391 Z-.943
N17634 X48.493 Z-1.386
N17635 X47.595 Z-1.937
N17636 X47.146 Z-2.259
N17637 X46.697 Z-2.618
N17638 X46.248 Z-3.014
N17639 X45.799 Z-3.462
N17640 X45.35 Z-3.957
N17641 X44.677 Z-4.839
N17642 X44.228 Z-5.547
N17643 X43.779 Z-6.405
N17644 X43.554 Z-6.908
N17645 X43.217 Z-7.837
N17646 X43.003 Z-8.618
N17647 X42.798 Z-9.748
N17648 X42.44 Z-13.52
N17649 X42.184 Z-15.229
N17650 X41.571 Z-18.178
N17651 X40.979 Z-20.339
N17652 X40.491 Z-21.866
N17653 X39.758 Z-23.846
N17654 X39.033 Z-25.551
N17655 X38.554 Z-26.583
N17656 X38.074 Z-27.548
N17657 X37.115 Z-29.312
N17658 X36.156 Z-30.898
N17659 X35.676 Z-31.638
N17660 X34.839 Z-32.859
N17661 X34.002 Z-33.989
N17662 X33.166 Z-35.047
N17663 X32.329 Z-36.043
N17664 X31.408 Z-37.073
N17665 X30.487 Z-38.035
N17666 X29.566 Z-38.941
N17667 X28.645 Z-39.796
N17668 X27.77 Z-40.565
N17669 X26.895 Z-41.292
N17670 X26.02 Z-41.981
N17671 X25.145 Z-42.634
N17672 X24.233 Z-43.278
N17673 X23.321 Z-43.886
N17674 X22.41 Z-44.462
N17675 X20.614 Z-45.507
N17676 X18.845 Z-46.427
N17677 X17.961 Z-46.848
N17678 X16.151 Z-47.634
N17679 X14.342 Z-48.323
N17680 X12.559 Z-48.913
N17681 X10.776 Z-49.418
N17682 X8.958 Z-49.849
N17683 X7.169 Z-50.192
N17684 X5.362 Z-50.46
N17685 X3.592 Z-50.648
N17686 X1.797 Z-50.761
N17687 X0. Z-50.8
N17688 X-1.797 Z-50.761
N17689 X-3.592 Z-50.648
N17690 X-5.362 Z-50.46
N17691 X-7.169 Z-50.192
N17692 X-8.958 Z-49.849
N17693 X-10.776 Z-49.418
N17694 X-12.559 Z-48.913
N17695 X-14.342 Z-48.323
N17696 X-16.151 Z-47.634
N17697 X-17.961 Z-46.848
N17698 X-19.729 Z-45.98
N17699 X-21.498 Z-45.007
N17700 X-22.41 Z-44.462
N17701 X-23.321 Z-43.886
N17702 X-24.233 Z-43.278
N17703 X-25.145 Z-42.634
N17704 X-26.02 Z-41.981
N17705 X-26.895 Z-41.292
N17706 X-27.77 Z-40.565
N17707 X-28.645 Z-39.796
N17708 X-29.566 Z-38.941
N17709 X-30.487 Z-38.035
N17710 X-31.408 Z-37.073
N17711 X-32.329 Z-36.043
N17712 X-33.166 Z-35.047
N17713 X-34.002 Z-33.989
N17714 X-34.839 Z-32.859
N17715 X-35.676 Z-31.638
N17716 X-36.635 Z-30.125
N17717 X-37.595 Z-28.455
N17718 X-38.074 Z-27.548
N17719 X-38.554 Z-26.583
N17720 X-39.033 Z-25.551
N17721 X-39.758 Z-23.846
N17722 X-40.491 Z-21.866
N17723 X-41.346 Z-19.058
N17724 X-41.98 Z-16.328
N17725 X-42.491 Z-13.111
N17726 X-42.798 Z-9.748
N17727 X-42.901 Z-9.109
N17728 X-43.105 Z-8.221
N17729 X-43.33 Z-7.496
N17730 X-43.554 Z-6.908
N17731 X-44.003 Z-5.953
N17732 X-44.452 Z-5.183
N17733 X-44.901 Z-4.527
N17734 X-45.35 Z-3.957
N17735 X-45.799 Z-3.462
N17736 X-46.248 Z-3.014
N17737 X-46.697 Z-2.618
N17738 X-47.146 Z-2.259
N17739 X-47.595 Z-1.937
N17740 X-48.493 Z-1.386
N17741 X-49.391 Z-.943
N17742 X-50.289 Z-.594
N17743 X-51.187 Z-.33
N17744 X-52.085 Z-.145
N17745 X-52.984 Z-.036
N17746 X-53.882 Z0.
N17747 Y-83.425
N17748 X-52.984 Z-.036
N17749 X-52.085 Z-.145
N17750 X-51.187 Z-.33
N17751 X-50.289 Z-.594
N17752 X-49.391 Z-.943
N17753 X-48.493 Z-1.386
N17754 X-47.595 Z-1.937
N17755 X-47.146 Z-2.259
N17756 X-46.697 Z-2.618
N17757 X-46.248 Z-3.014
N17758 X-45.799 Z-3.462
N17759 X-45.35 Z-3.957
N17760 X-44.901 Z-4.527
N17761 X-44.452 Z-5.183
N17762 X-44.003 Z-5.953
N17763 X-43.554 Z-6.908
N17764 X-43.33 Z-7.496
N17765 X-43.105 Z-8.221
N17766 X-42.901 Z-9.109
N17767 X-42.798 Z-9.749
N17768 X-42.491 Z-13.111
N17769 X-41.98 Z-16.328
N17770 X-41.346 Z-19.058
N17771 X-40.491 Z-21.866
N17772 X-39.758 Z-23.846
N17773 X-39.033 Z-25.551
N17774 X-38.554 Z-26.583
N17775 X-38.074 Z-27.548
N17776 X-37.595 Z-28.455
N17777 X-36.635 Z-30.125
N17778 X-35.676 Z-31.638
N17779 X-34.839 Z-32.859
N17780 X-34.002 Z-33.989
N17781 X-33.166 Z-35.047
N17782 X-32.329 Z-36.043
N17783 X-31.408 Z-37.073
N17784 X-30.487 Z-38.035
N17785 X-29.566 Z-38.941
N17786 X-28.645 Z-39.796
N17787 X-27.77 Z-40.565
N17788 X-26.895 Z-41.292
N17789 X-26.02 Z-41.981
N17790 X-25.145 Z-42.634
N17791 X-24.233 Z-43.278
N17792 X-23.321 Z-43.886
N17793 X-22.41 Z-44.462
N17794 X-21.498 Z-45.007
N17795 X-19.729 Z-45.98
N17796 X-17.961 Z-46.848
N17797 X-16.151 Z-47.634
N17798 X-14.342 Z-48.323
N17799 X-12.559 Z-48.913
N17800 X-10.776 Z-49.418
N17801 X-8.958 Z-49.849
N17802 X-7.169 Z-50.192
N17803 X-5.362 Z-50.46
N17804 X-3.592 Z-50.648
N17805 X-1.797 Z-50.761
N17806 X0. Z-50.8
N17807 X1.797 Z-50.761
N17808 X3.592 Z-50.648
N17809 X5.362 Z-50.46
N17810 X7.169 Z-50.192
N17811 X8.958 Z-49.849
N17812 X10.776 Z-49.418
N17813 X12.559 Z-48.913
N17814 X14.342 Z-48.323
N17815 X16.151 Z-47.634
N17816 X17.961 Z-46.848
N17817 X18.845 Z-46.427
N17818 X20.614 Z-45.507
N17819 X22.41 Z-44.462
N17820 X23.321 Z-43.886
N17821 X24.233 Z-43.278
N17822 X25.145 Z-42.634
N17823 X26.02 Z-41.981
N17824 X26.895 Z-41.292
N17825 X27.77 Z-40.565
N17826 X28.645 Z-39.796
N17827 X29.566 Z-38.941
N17828 X30.487 Z-38.035
N17829 X31.408 Z-37.073
N17830 X32.329 Z-36.043
N17831 X33.166 Z-35.047
N17832 X34.002 Z-33.989
N17833 X34.839 Z-32.859
N17834 X35.676 Z-31.638
N17835 X36.156 Z-30.898
N17836 X37.115 Z-29.312
N17837 X38.074 Z-27.548
N17838 X38.554 Z-26.583
N17839 X39.033 Z-25.551
N17840 X39.758 Z-23.846
N17841 X40.491 Z-21.866
N17842 X40.979 Z-20.339
N17843 X41.571 Z-18.178
N17844 X42.184 Z-15.229
N17845 X42.44 Z-13.52
N17846 X42.798 Z-9.749
N17847 X43.003 Z-8.618
N17848 X43.217 Z-7.837
N17849 X43.554 Z-6.908
N17850 X43.779 Z-6.405
N17851 X44.228 Z-5.547
N17852 X44.677 Z-4.839
N17853 X45.35 Z-3.957
N17854 X45.799 Z-3.462
N17855 X46.248 Z-3.014
N17856 X46.697 Z-2.618
N17857 X47.146 Z-2.259
N17858 X47.595 Z-1.938
N17859 X48.493 Z-1.386
N17860 X49.391 Z-.943
N17861 X50.289 Z-.594
N17862 X51.187 Z-.33
N17863 X52.085 Z-.145
N17864 X52.984 Z-.036
N17865 X53.882 Z0.
N17866 Y-84.625
N17867 X52.984 Z-.036
N17868 X52.085 Z-.145
N17869 X51.187 Z-.33
N17870 X50.289 Z-.594
N17871 X49.391 Z-.943
N17872 X48.493 Z-1.387
N17873 X47.595 Z-1.938
N17874 X47.146 Z-2.259
N17875 X46.697 Z-2.618
N17876 X46.248 Z-3.014
N17877 X45.799 Z-3.462
N17878 X45.35 Z-3.957
N17879 X44.677 Z-4.839
N17880 X44.228 Z-5.547
N17881 X43.779 Z-6.404
N17882 X43.554 Z-6.908
N17883 X43.217 Z-7.837
N17884 X43.003 Z-8.618
N17885 X42.798 Z-9.749
N17886 X42.44 Z-13.52
N17887 X42.184 Z-15.229
N17888 X41.571 Z-18.178
N17889 X40.979 Z-20.339
N17890 X40.491 Z-21.866
N17891 X39.758 Z-23.846
N17892 X39.033 Z-25.551
N17893 X38.554 Z-26.583
N17894 X38.074 Z-27.548
N17895 X37.115 Z-29.312
N17896 X36.156 Z-30.898
N17897 X35.676 Z-31.638
N17898 X34.839 Z-32.859
N17899 X34.002 Z-33.989
N17900 X33.166 Z-35.047
N17901 X32.329 Z-36.043
N17902 X31.408 Z-37.073
N17903 X30.487 Z-38.035
N17904 X29.566 Z-38.941
N17905 X28.645 Z-39.796
N17906 X27.77 Z-40.565
N17907 X26.895 Z-41.292
N17908 X26.02 Z-41.981
N17909 X25.145 Z-42.634
N17910 X24.233 Z-43.278
N17911 X23.321 Z-43.886
N17912 X22.41 Z-44.462
N17913 X20.614 Z-45.507
N17914 X18.845 Z-46.427
N17915 X17.961 Z-46.848
N17916 X16.151 Z-47.634
N17917 X14.342 Z-48.323
N17918 X12.559 Z-48.913
N17919 X10.776 Z-49.418
N17920 X8.958 Z-49.849
N17921 X7.169 Z-50.192
N17922 X5.362 Z-50.46
N17923 X3.592 Z-50.648
N17924 X1.797 Z-50.761
N17925 X0. Z-50.8
N17926 X-1.797 Z-50.761
N17927 X-3.592 Z-50.648
N17928 X-5.362 Z-50.46
N17929 X-7.169 Z-50.192
N17930 X-8.958 Z-49.849
N17931 X-10.776 Z-49.418
N17932 X-12.559 Z-48.913
N17933 X-14.342 Z-48.323
N17934 X-16.151 Z-47.634
N17935 X-17.961 Z-46.848
N17936 X-19.729 Z-45.98
N17937 X-21.498 Z-45.007
N17938 X-22.41 Z-44.462
N17939 X-23.321 Z-43.886
N17940 X-24.233 Z-43.278
N17941 X-25.145 Z-42.634
N17942 X-26.02 Z-41.981
N17943 X-26.895 Z-41.292
N17944 X-27.77 Z-40.565
N17945 X-28.645 Z-39.796
N17946 X-29.566 Z-38.941
N17947 X-30.487 Z-38.035
N17948 X-31.408 Z-37.073
N17949 X-32.329 Z-36.043
N17950 X-33.166 Z-35.047
N17951 X-34.002 Z-33.989
N17952 X-34.839 Z-32.859
N17953 X-35.676 Z-31.638
N17954 X-36.635 Z-30.125
N17955 X-37.595 Z-28.455
N17956 X-38.074 Z-27.548
N17957 X-38.554 Z-26.583
N17958 X-39.033 Z-25.551
N17959 X-39.758 Z-23.846
N17960 X-40.491 Z-21.866
N17961 X-41.346 Z-19.058
N17962 X-41.98 Z-16.328
N17963 X-42.491 Z-13.111
N17964 X-42.798 Z-9.749
N17965 X-42.901 Z-9.11
N17966 X-43.105 Z-8.221
N17967 X-43.33 Z-7.496
N17968 X-43.554 Z-6.908
N17969 X-44.003 Z-5.953
N17970 X-44.452 Z-5.183
N17971 X-44.901 Z-4.527
N17972 X-45.35 Z-3.957
N17973 X-45.799 Z-3.462
N17974 X-46.248 Z-3.014
N17975 X-46.697 Z-2.618
N17976 X-47.146 Z-2.259
N17977 X-47.595 Z-1.938
N17978 X-48.493 Z-1.387
N17979 X-49.391 Z-.943
N17980 X-50.289 Z-.594
N17981 X-51.187 Z-.33
N17982 X-52.085 Z-.145
N17983 X-52.984 Z-.036
N17984 X-53.882 Z0.
N17985 Y-85.825
N17986 X-52.984 Z-.036
N17987 X-52.085 Z-.145
N17988 X-51.187 Z-.33
N17989 X-50.289 Z-.594
N17990 X-49.391 Z-.944
N17991 X-48.493 Z-1.387
N17992 X-47.595 Z-1.938
N17993 X-47.146 Z-2.259
N17994 X-46.697 Z-2.618
N17995 X-46.248 Z-3.014
N17996 X-45.799 Z-3.462
N17997 X-45.35 Z-3.957
N17998 X-44.901 Z-4.527
N17999 X-44.452 Z-5.183
N18000 X-44.003 Z-5.953
N18001 X-43.554 Z-6.908
N18002 X-43.33 Z-7.496
N18003 X-43.105 Z-8.221
N18004 X-42.901 Z-9.11
N18005 X-42.798 Z-9.749
N18006 X-42.491 Z-13.111
N18007 X-41.98 Z-16.328
N18008 X-41.346 Z-19.058
N18009 X-40.491 Z-21.866
N18010 X-39.758 Z-23.846
N18011 X-39.033 Z-25.551
N18012 X-38.554 Z-26.583
N18013 X-38.074 Z-27.548
N18014 X-37.595 Z-28.455
N18015 X-36.635 Z-30.125
N18016 X-35.676 Z-31.638
N18017 X-34.839 Z-32.859
N18018 X-34.002 Z-33.989
N18019 X-33.166 Z-35.047
N18020 X-32.329 Z-36.043
N18021 X-31.408 Z-37.073
N18022 X-30.487 Z-38.035
N18023 X-29.566 Z-38.941
N18024 X-28.645 Z-39.796
N18025 X-27.77 Z-40.565
N18026 X-26.895 Z-41.292
N18027 X-26.02 Z-41.981
N18028 X-25.145 Z-42.634
N18029 X-24.233 Z-43.278
N18030 X-23.321 Z-43.886
N18031 X-22.41 Z-44.462
N18032 X-21.498 Z-45.007
N18033 X-19.729 Z-45.98
N18034 X-17.961 Z-46.848
N18035 X-16.151 Z-47.634
N18036 X-14.342 Z-48.323
N18037 X-12.559 Z-48.913
N18038 X-10.776 Z-49.418
N18039 X-8.958 Z-49.849
N18040 X-7.169 Z-50.192
N18041 X-5.362 Z-50.46
N18042 X-3.592 Z-50.648
N18043 X-1.797 Z-50.761
N18044 X0. Z-50.8
N18045 X1.797 Z-50.761
N18046 X3.592 Z-50.648
N18047 X5.362 Z-50.46
N18048 X7.169 Z-50.192
N18049 X8.958 Z-49.849
N18050 X10.776 Z-49.418
N18051 X12.559 Z-48.913
N18052 X14.342 Z-48.323
N18053 X16.151 Z-47.634
N18054 X17.961 Z-46.848
N18055 X18.845 Z-46.427
N18056 X20.614 Z-45.507
N18057 X22.41 Z-44.462
N18058 X23.321 Z-43.886
N18059 X24.233 Z-43.278
N18060 X25.145 Z-42.634
N18061 X26.02 Z-41.981
N18062 X26.895 Z-41.292
N18063 X27.77 Z-40.565
N18064 X28.645 Z-39.796
N18065 X29.566 Z-38.941
N18066 X30.487 Z-38.035
N18067 X31.408 Z-37.073
N18068 X32.329 Z-36.043
N18069 X33.166 Z-35.047
N18070 X34.002 Z-33.989
N18071 X34.839 Z-32.859
N18072 X35.676 Z-31.638
N18073 X36.156 Z-30.898
N18074 X37.115 Z-29.312
N18075 X38.074 Z-27.548
N18076 X38.554 Z-26.583
N18077 X39.033 Z-25.551
N18078 X39.758 Z-23.846
N18079 X40.491 Z-21.866
N18080 X40.979 Z-20.339
N18081 X41.571 Z-18.178
N18082 X42.184 Z-15.229
N18083 X42.44 Z-13.52
N18084 X42.798 Z-9.749
N18085 X43.003 Z-8.618
N18086 X43.217 Z-7.837
N18087 X43.554 Z-6.908
N18088 X43.779 Z-6.404
N18089 X44.228 Z-5.547
N18090 X44.677 Z-4.839
N18091 X45.35 Z-3.957
N18092 X45.799 Z-3.462
N18093 X46.248 Z-3.014
N18094 X46.697 Z-2.618
N18095 X47.146 Z-2.259
N18096 X47.595 Z-1.938
N18097 X48.493 Z-1.387
N18098 X49.391 Z-.944
N18099 X50.289 Z-.594
N18100 X51.187 Z-.33
N18101 X52.085 Z-.145
N18102 X52.984 Z-.036
N18103 X53.882 Z0.
N18104 Y-87.025
N18105 X52.984 Z-.036
N18106 X52.085 Z-.145
N18107 X51.187 Z-.33
N18108 X50.289 Z-.594
N18109 X49.391 Z-.944
N18110 X48.493 Z-1.387
N18111 X47.595 Z-1.938
N18112 X47.146 Z-2.259
N18113 X46.697 Z-2.618
N18114 X46.248 Z-3.014
N18115 X45.799 Z-3.462
N18116 X45.35 Z-3.957
N18117 X44.677 Z-4.839
N18118 X44.228 Z-5.547
N18119 X43.779 Z-6.404
N18120 X43.554 Z-6.908
N18121 X43.217 Z-7.837
N18122 X43.003 Z-8.618
N18123 X42.798 Z-9.749
N18124 X42.44 Z-13.52
N18125 X42.184 Z-15.229
N18126 X41.571 Z-18.178
N18127 X40.979 Z-20.339
N18128 X40.491 Z-21.866
N18129 X39.758 Z-23.846
N18130 X39.033 Z-25.551
N18131 X38.554 Z-26.583
N18132 X38.074 Z-27.548
N18133 X37.115 Z-29.312
N18134 X36.156 Z-30.898
N18135 X35.676 Z-31.638
N18136 X34.839 Z-32.859
N18137 X34.002 Z-33.989
N18138 X33.166 Z-35.047
N18139 X32.329 Z-36.043
N18140 X31.408 Z-37.073
N18141 X30.487 Z-38.035
N18142 X29.566 Z-38.941
N18143 X28.645 Z-39.796
N18144 X27.77 Z-40.565
N18145 X26.895 Z-41.292
N18146 X26.02 Z-41.981
N18147 X25.145 Z-42.634
N18148 X24.233 Z-43.278
N18149 X23.321 Z-43.886
N18150 X22.41 Z-44.462
N18151 X20.614 Z-45.507
N18152 X18.845 Z-46.427
N18153 X17.961 Z-46.848
N18154 X16.151 Z-47.634
N18155 X14.342 Z-48.323
N18156 X12.559 Z-48.913
N18157 X10.776 Z-49.418
N18158 X8.958 Z-49.849
N18159 X7.169 Z-50.192
N18160 X5.362 Z-50.46
N18161 X3.592 Z-50.648
N18162 X1.797 Z-50.761
N18163 X0. Z-50.8
N18164 X-1.797 Z-50.761
N18165 X-3.592 Z-50.648
N18166 X-5.362 Z-50.46
N18167 X-7.169 Z-50.192
N18168 X-8.958 Z-49.849
N18169 X-10.776 Z-49.418
N18170 X-12.559 Z-48.913
N18171 X-14.342 Z-48.323
N18172 X-16.151 Z-47.634
N18173 X-17.961 Z-46.848
N18174 X-19.729 Z-45.98
N18175 X-21.498 Z-45.007
N18176 X-22.41 Z-44.462
N18177 X-23.321 Z-43.886
N18178 X-24.233 Z-43.278
N18179 X-25.145 Z-42.634
N18180 X-26.02 Z-41.981
N18181 X-26.895 Z-41.292
N18182 X-27.77 Z-40.565
N18183 X-28.645 Z-39.796
N18184 X-29.566 Z-38.941
N18185 X-30.487 Z-38.035
N18186 X-31.408 Z-37.073
N18187 X-32.329 Z-36.043
N18188 X-33.166 Z-35.047
N18189 X-34.002 Z-33.989
N18190 X-34.839 Z-32.859
N18191 X-35.676 Z-31.638
N18192 X-36.635 Z-30.125
N18193 X-37.595 Z-28.455
N18194 X-38.074 Z-27.548
N18195 X-38.554 Z-26.583
N18196 X-39.033 Z-25.551
N18197 X-39.758 Z-23.846
N18198 X-40.491 Z-21.866
N18199 X-41.346 Z-19.058
N18200 X-41.98 Z-16.328
N18201 X-42.491 Z-13.111
N18202 X-42.798 Z-9.749
N18203 X-42.901 Z-9.11
N18204 X-43.105 Z-8.221
N18205 X-43.33 Z-7.496
N18206 X-43.554 Z-6.908
N18207 X-44.003 Z-5.953
N18208 X-44.452 Z-5.183
N18209 X-44.901 Z-4.527
N18210 X-45.35 Z-3.957
N18211 X-45.799 Z-3.462
N18212 X-46.248 Z-3.014
N18213 X-46.697 Z-2.618
N18214 X-47.146 Z-2.259
N18215 X-47.595 Z-1.938
N18216 X-48.493 Z-1.387
N18217 X-49.391 Z-.944
N18218 X-50.289 Z-.594
N18219 X-51.187 Z-.33
N18220 X-52.085 Z-.146
N18221 X-52.984 Z-.036
N18222 X-53.882 Z0.
N18223 Y-88.225
N18224 X-52.984 Z-.036
N18225 X-52.085 Z-.146
N18226 X-51.187 Z-.33
N18227 X-50.289 Z-.594
N18228 X-49.391 Z-.944
N18229 X-48.493 Z-1.387
N18230 X-47.595 Z-1.938
N18231 X-47.146 Z-2.259
N18232 X-46.697 Z-2.618
N18233 X-46.248 Z-3.014
N18234 X-45.799 Z-3.462
N18235 X-45.35 Z-3.957
N18236 X-44.901 Z-4.526
N18237 X-44.452 Z-5.183
N18238 X-44.003 Z-5.953
N18239 X-43.554 Z-6.908
N18240 X-43.33 Z-7.496
N18241 X-43.105 Z-8.221
N18242 X-42.901 Z-9.11
N18243 X-42.798 Z-9.749
N18244 X-42.491 Z-13.111
N18245 X-42.082 Z-15.789
N18246 X-41.346 Z-19.058
N18247 X-40.491 Z-21.866
N18248 X-39.758 Z-23.846
N18249 X-39.033 Z-25.551
N18250 X-38.554 Z-26.583
N18251 X-38.074 Z-27.548
N18252 X-37.595 Z-28.455
N18253 X-36.635 Z-30.125
N18254 X-35.676 Z-31.638
N18255 X-34.839 Z-32.859
N18256 X-34.002 Z-33.989
N18257 X-33.166 Z-35.047
N18258 X-32.329 Z-36.043
N18259 X-31.408 Z-37.073
N18260 X-30.487 Z-38.035
N18261 X-29.566 Z-38.941
N18262 X-28.645 Z-39.796
N18263 X-27.77 Z-40.565
N18264 X-26.895 Z-41.292
N18265 X-26.02 Z-41.981
N18266 X-25.145 Z-42.634
N18267 X-24.233 Z-43.278
N18268 X-23.321 Z-43.886
N18269 X-22.41 Z-44.462
N18270 X-21.498 Z-45.007
N18271 X-19.729 Z-45.98
N18272 X-17.961 Z-46.848
N18273 X-16.151 Z-47.634
N18274 X-14.342 Z-48.323
N18275 X-12.559 Z-48.913
N18276 X-10.776 Z-49.418
N18277 X-8.958 Z-49.849
N18278 X-7.169 Z-50.192
N18279 X-5.362 Z-50.46
N18280 X-3.592 Z-50.648
N18281 X-1.797 Z-50.761
N18282 X0. Z-50.8
N18283 X1.797 Z-50.761
N18284 X3.592 Z-50.648
N18285 X5.362 Z-50.46
N18286 X7.169 Z-50.192
N18287 X8.958 Z-49.849
N18288 X10.776 Z-49.418
N18289 X12.559 Z-48.913
N18290 X14.342 Z-48.323
N18291 X16.151 Z-47.634
N18292 X17.961 Z-46.848
N18293 X18.845 Z-46.427
N18294 X20.614 Z-45.507
N18295 X22.41 Z-44.462
N18296 X23.321 Z-43.886
N18297 X24.233 Z-43.278
N18298 X25.145 Z-42.634
N18299 X26.02 Z-41.981
N18300 X26.895 Z-41.292
N18301 X27.77 Z-40.565
N18302 X28.645 Z-39.796
N18303 X29.566 Z-38.941
N18304 X30.487 Z-38.035
N18305 X31.408 Z-37.073
N18306 X32.329 Z-36.043
N18307 X33.166 Z-35.047
N18308 X34.002 Z-33.989
N18309 X34.839 Z-32.859
N18310 X35.676 Z-31.638
N18311 X36.156 Z-30.898
N18312 X37.115 Z-29.312
N18313 X38.074 Z-27.548
N18314 X38.554 Z-26.583
N18315 X39.033 Z-25.551
N18316 X39.758 Z-23.846
N18317 X40.491 Z-21.866
N18318 X40.979 Z-20.339
N18319 X41.571 Z-18.178
N18320 X42.184 Z-15.229
N18321 X42.44 Z-13.52
N18322 X42.798 Z-9.749
N18323 X43.003 Z-8.619
N18324 X43.217 Z-7.837
N18325 X43.554 Z-6.908
N18326 X43.779 Z-6.404
N18327 X44.228 Z-5.547
N18328 X44.677 Z-4.839
N18329 X45.35 Z-3.957
N18330 X45.799 Z-3.462
N18331 X46.248 Z-3.014
N18332 X46.697 Z-2.618
N18333 X47.146 Z-2.259
N18334 X47.595 Z-1.938
N18335 X48.044 Z-1.647
N18336 X48.493 Z-1.387
N18337 X49.391 Z-.944
N18338 X50.289 Z-.594
N18339 X51.187 Z-.33
N18340 X52.085 Z-.146
N18341 X52.984 Z-.036
N18342 X53.882 Z0.
N18343 Y-89.425
N18344 X52.984 Z-.036
N18345 X52.085 Z-.146
N18346 X51.187 Z-.33
N18347 X50.289 Z-.594
N18348 X49.391 Z-.944
N18349 X48.493 Z-1.387
N18350 X48.044 Z-1.647
N18351 X47.146 Z-2.259
N18352 X46.697 Z-2.618
N18353 X46.248 Z-3.014
N18354 X45.799 Z-3.462
N18355 X45.35 Z-3.957
N18356 X44.677 Z-4.839
N18357 X44.228 Z-5.547
N18358 X43.779 Z-6.404
N18359 X43.554 Z-6.908
N18360 X43.217 Z-7.837
N18361 X43.003 Z-8.619
N18362 X42.798 Z-9.749
N18363 X42.44 Z-13.521
N18364 X42.184 Z-15.229
N18365 X41.571 Z-18.178
N18366 X40.979 Z-20.339
N18367 X40.491 Z-21.866
N18368 X39.758 Z-23.846
N18369 X39.033 Z-25.551
N18370 X38.554 Z-26.583
N18371 X38.074 Z-27.548
N18372 X37.115 Z-29.312
N18373 X36.156 Z-30.898
N18374 X35.676 Z-31.638
N18375 X34.839 Z-32.859
N18376 X34.002 Z-33.989
N18377 X33.166 Z-35.047
N18378 X32.329 Z-36.043
N18379 X31.408 Z-37.073
N18380 X30.487 Z-38.035
N18381 X29.566 Z-38.941
N18382 X28.645 Z-39.796
N18383 X27.77 Z-40.565
N18384 X26.895 Z-41.292
N18385 X26.02 Z-41.981
N18386 X25.145 Z-42.634
N18387 X24.233 Z-43.278
N18388 X23.321 Z-43.886
N18389 X22.41 Z-44.462
N18390 X20.614 Z-45.507
N18391 X18.845 Z-46.427
N18392 X17.961 Z-46.848
N18393 X16.151 Z-47.634
N18394 X14.342 Z-48.323
N18395 X12.559 Z-48.913
N18396 X10.776 Z-49.418
N18397 X8.958 Z-49.849
N18398 X7.169 Z-50.192
N18399 X5.362 Z-50.46
N18400 X3.592 Z-50.648
N18401 X1.797 Z-50.761
N18402 X0. Z-50.8
N18403 X-1.797 Z-50.761
N18404 X-3.592 Z-50.648
N18405 X-5.362 Z-50.46
N18406 X-7.169 Z-50.192
N18407 X-8.958 Z-49.849
N18408 X-10.776 Z-49.418
N18409 X-12.559 Z-48.913
N18410 X-14.342 Z-48.323
N18411 X-16.151 Z-47.634
N18412 X-17.961 Z-46.848
N18413 X-19.729 Z-45.98
N18414 X-21.498 Z-45.007
N18415 X-22.41 Z-44.462
N18416 X-23.321 Z-43.886
N18417 X-24.233 Z-43.278
N18418 X-25.145 Z-42.634
N18419 X-26.02 Z-41.981
N18420 X-26.895 Z-41.292
N18421 X-27.77 Z-40.565
N18422 X-28.645 Z-39.796
N18423 X-29.566 Z-38.941
N18424 X-30.487 Z-38.035
N18425 X-31.408 Z-37.073
N18426 X-32.329 Z-36.043
N18427 X-33.166 Z-35.047
N18428 X-34.002 Z-33.989
N18429 X-34.839 Z-32.859
N18430 X-35.676 Z-31.638
N18431 X-36.635 Z-30.125
N18432 X-37.595 Z-28.455
N18433 X-38.074 Z-27.548
N18434 X-38.554 Z-26.583
N18435 X-39.033 Z-25.551
N18436 X-39.758 Z-23.846
N18437 X-40.491 Z-21.866
N18438 X-41.346 Z-19.058
N18439 X-42.082 Z-15.789
N18440 X-42.491 Z-13.111
N18441 X-42.798 Z-9.749
N18442 X-42.901 Z-9.111
N18443 X-43.105 Z-8.221
N18444 X-43.33 Z-7.496
N18445 X-43.554 Z-6.908
N18446 X-44.003 Z-5.953
N18447 X-44.452 Z-5.183
N18448 X-44.901 Z-4.526
N18449 X-45.35 Z-3.957
N18450 X-45.799 Z-3.462
N18451 X-46.248 Z-3.014
N18452 X-46.697 Z-2.618
N18453 X-47.146 Z-2.259
N18454 X-47.595 Z-1.938
N18455 X-48.044 Z-1.647
N18456 X-48.942 Z-1.152
N18457 X-49.391 Z-.944
N18458 X-50.289 Z-.594
N18459 X-51.187 Z-.33
N18460 X-52.085 Z-.146
N18461 X-52.984 Z-.036
N18462 X-53.882 Z0.
N18463 Y-90.625
N18464 X-52.984 Z-.036
N18465 X-52.085 Z-.146
N18466 X-51.187 Z-.33
N18467 X-50.289 Z-.594
N18468 X-49.391 Z-.944
N18469 X-48.942 Z-1.152
N18470 X-48.044 Z-1.647
N18471 X-47.146 Z-2.259
N18472 X-46.697 Z-2.618
N18473 X-46.248 Z-3.014
N18474 X-45.799 Z-3.462
N18475 X-45.35 Z-3.957
N18476 X-44.901 Z-4.526
N18477 X-44.452 Z-5.183
N18478 X-44.003 Z-5.953
N18479 X-43.554 Z-6.908
N18480 X-43.33 Z-7.496
N18481 X-43.105 Z-8.221
N18482 X-42.901 Z-9.111
N18483 X-42.798 Z-9.749
N18484 X-42.491 Z-13.111
N18485 X-42.082 Z-15.789
N18486 X-41.346 Z-19.058
N18487 X-40.491 Z-21.866
N18488 X-39.758 Z-23.846
N18489 X-39.033 Z-25.551
N18490 X-38.554 Z-26.583
N18491 X-38.074 Z-27.548
N18492 X-37.595 Z-28.455
N18493 X-36.635 Z-30.125
N18494 X-35.676 Z-31.638
N18495 X-34.839 Z-32.859
N18496 X-34.002 Z-33.989
N18497 X-33.166 Z-35.047
N18498 X-32.329 Z-36.043
N18499 X-31.408 Z-37.073
N18500 X-30.487 Z-38.035
N18501 X-29.566 Z-38.941
N18502 X-28.645 Z-39.796
N18503 X-27.77 Z-40.565
N18504 X-26.895 Z-41.292
N18505 X-26.02 Z-41.981
N18506 X-25.145 Z-42.634
N18507 X-24.233 Z-43.278
N18508 X-23.321 Z-43.886
N18509 X-22.41 Z-44.462
N18510 X-21.498 Z-45.007
N18511 X-19.729 Z-45.98
N18512 X-17.961 Z-46.848
N18513 X-16.151 Z-47.634
N18514 X-14.342 Z-48.323
N18515 X-12.559 Z-48.913
N18516 X-10.776 Z-49.418
N18517 X-8.958 Z-49.849
N18518 X-7.169 Z-50.192
N18519 X-5.362 Z-50.46
N18520 X-3.592 Z-50.648
N18521 X-1.797 Z-50.761
N18522 X0. Z-50.8
N18523 X1.797 Z-50.761
N18524 X3.592 Z-50.648
N18525 X5.362 Z-50.46
N18526 X7.169 Z-50.192
N18527 X8.958 Z-49.849
N18528 X10.776 Z-49.418
N18529 X12.559 Z-48.913
N18530 X14.342 Z-48.323
N18531 X16.151 Z-47.634
N18532 X17.961 Z-46.848
N18533 X18.845 Z-46.427
N18534 X20.614 Z-45.507
N18535 X22.41 Z-44.462
N18536 X23.321 Z-43.886
N18537 X24.233 Z-43.278
N18538 X25.145 Z-42.634
N18539 X26.02 Z-41.981
N18540 X26.895 Z-41.292
N18541 X27.77 Z-40.565
N18542 X28.645 Z-39.796
N18543 X29.566 Z-38.941
N18544 X30.487 Z-38.035
N18545 X31.408 Z-37.073
N18546 X32.329 Z-36.043
N18547 X33.166 Z-35.047
N18548 X34.002 Z-33.989
N18549 X34.839 Z-32.859
N18550 X35.676 Z-31.638
N18551 X36.156 Z-30.898
N18552 X37.115 Z-29.312
N18553 X38.074 Z-27.548
N18554 X38.554 Z-26.583
N18555 X39.033 Z-25.551
N18556 X39.758 Z-23.846
N18557 X40.491 Z-21.866
N18558 X40.979 Z-20.339
N18559 X41.571 Z-18.178
N18560 X42.184 Z-15.229
N18561 X42.44 Z-13.521
N18562 X42.798 Z-9.749
N18563 X43.003 Z-8.619
N18564 X43.217 Z-7.837
N18565 X43.554 Z-6.908
N18566 X43.779 Z-6.404
N18567 X44.228 Z-5.547
N18568 X44.677 Z-4.839
N18569 X45.35 Z-3.957
N18570 X45.799 Z-3.462
N18571 X46.248 Z-3.014
N18572 X46.697 Z-2.618
N18573 X47.146 Z-2.259
N18574 X48.044 Z-1.647
N18575 X48.493 Z-1.387
N18576 X49.391 Z-.944
N18577 X50.289 Z-.594
N18578 X51.187 Z-.33
N18579 X52.085 Z-.146
N18580 X52.984 Z-.036
N18581 X53.882 Z0.
N18582 Y-91.825
N18583 X52.984 Z-.036
N18584 X52.085 Z-.146
N18585 X51.187 Z-.33
N18586 X50.289 Z-.594
N18587 X49.391 Z-.944
N18588 X48.493 Z-1.387
N18589 X48.044 Z-1.647
N18590 X47.146 Z-2.259
N18591 X46.697 Z-2.619
N18592 X46.248 Z-3.014
N18593 X45.799 Z-3.462
N18594 X45.35 Z-3.957
N18595 X44.677 Z-4.839
N18596 X44.228 Z-5.547
N18597 X43.779 Z-6.404
N18598 X43.554 Z-6.909
N18599 X43.217 Z-7.837
N18600 X43.003 Z-8.619
N18601 X42.798 Z-9.749
N18602 X42.44 Z-13.521
N18603 X42.184 Z-15.229
N18604 X41.571 Z-18.178
N18605 X40.979 Z-20.339
N18606 X40.491 Z-21.866
N18607 X39.758 Z-23.846
N18608 X39.033 Z-25.551
N18609 X38.554 Z-26.583
N18610 X38.074 Z-27.548
N18611 X37.115 Z-29.312
N18612 X36.156 Z-30.898
N18613 X35.676 Z-31.638
N18614 X34.839 Z-32.859
N18615 X34.002 Z-33.989
N18616 X33.166 Z-35.047
N18617 X32.329 Z-36.043
N18618 X31.408 Z-37.073
N18619 X30.487 Z-38.035
N18620 X29.566 Z-38.941
N18621 X28.645 Z-39.796
N18622 X27.77 Z-40.565
N18623 X26.895 Z-41.292
N18624 X26.02 Z-41.981
N18625 X25.145 Z-42.634
N18626 X24.233 Z-43.278
N18627 X23.321 Z-43.886
N18628 X22.41 Z-44.462
N18629 X20.614 Z-45.507
N18630 X18.845 Z-46.427
N18631 X17.961 Z-46.848
N18632 X16.151 Z-47.634
N18633 X14.342 Z-48.323
N18634 X12.559 Z-48.913
N18635 X10.776 Z-49.418
N18636 X8.958 Z-49.849
N18637 X7.169 Z-50.192
N18638 X5.362 Z-50.46
N18639 X3.592 Z-50.648
N18640 X1.797 Z-50.761
N18641 X0. Z-50.8
N18642 X-1.797 Z-50.761
N18643 X-3.592 Z-50.648
N18644 X-5.362 Z-50.46
N18645 X-7.169 Z-50.192
N18646 X-8.958 Z-49.849
N18647 X-10.776 Z-49.418
N18648 X-12.559 Z-48.913
N18649 X-14.342 Z-48.323
N18650 X-16.151 Z-47.634
N18651 X-17.961 Z-46.848
N18652 X-19.729 Z-45.98
N18653 X-21.498 Z-45.007
N18654 X-22.41 Z-44.462
N18655 X-23.321 Z-43.886
N18656 X-24.233 Z-43.278
N18657 X-25.145 Z-42.634
N18658 X-26.02 Z-41.981
N18659 X-26.895 Z-41.292
N18660 X-27.77 Z-40.565
N18661 X-28.645 Z-39.796
N18662 X-29.566 Z-38.941
N18663 X-30.487 Z-38.035
N18664 X-31.408 Z-37.073
N18665 X-32.329 Z-36.043
N18666 X-33.166 Z-35.047
N18667 X-34.002 Z-33.989
N18668 X-34.839 Z-32.859
N18669 X-35.676 Z-31.638
N18670 X-36.635 Z-30.125
N18671 X-37.595 Z-28.455
N18672 X-38.074 Z-27.548
N18673 X-38.554 Z-26.583
N18674 X-39.033 Z-25.551
N18675 X-39.758 Z-23.846
N18676 X-40.491 Z-21.866
N18677 X-41.346 Z-19.058
N18678 X-42.082 Z-15.789
N18679 X-42.491 Z-13.111
N18680 X-42.798 Z-9.749
N18681 X-42.901 Z-9.111
N18682 X-43.105 Z-8.221
N18683 X-43.33 Z-7.496
N18684 X-43.554 Z-6.908
N18685 X-44.003 Z-5.953
N18686 X-44.452 Z-5.183
N18687 X-44.901 Z-4.526
N18688 X-45.35 Z-3.957
N18689 X-45.799 Z-3.462
N18690 X-46.248 Z-3.014
N18691 X-46.697 Z-2.618
N18692 X-47.146 Z-2.259
N18693 X-48.044 Z-1.647
N18694 X-48.942 Z-1.152
N18695 X-49.391 Z-.944
N18696 X-50.289 Z-.595
N18697 X-51.187 Z-.33
N18698 X-52.085 Z-.146
N18699 X-52.984 Z-.036
N18700 X-53.882 Z0.
N18701 Y-93.025
N18702 X-52.984 Z-.036
N18703 X-52.085 Z-.146
N18704 X-51.187 Z-.33
N18705 X-50.289 Z-.595
N18706 X-49.391 Z-.944
N18707 X-48.942 Z-1.152
N18708 X-48.044 Z-1.647
N18709 X-47.146 Z-2.259
N18710 X-46.697 Z-2.619
N18711 X-46.248 Z-3.014
N18712 X-45.799 Z-3.462
N18713 X-45.35 Z-3.957
N18714 X-44.901 Z-4.526
N18715 X-44.452 Z-5.183
N18716 X-44.003 Z-5.954
N18717 X-43.554 Z-6.909
N18718 X-43.33 Z-7.496
N18719 X-43.105 Z-8.221
N18720 X-42.901 Z-9.111
N18721 X-42.798 Z-9.749
N18722 X-42.491 Z-13.111
N18723 X-42.082 Z-15.789
N18724 X-41.346 Z-19.058
N18725 X-40.491 Z-21.866
N18726 X-39.758 Z-23.846
N18727 X-39.033 Z-25.551
N18728 X-38.554 Z-26.583
N18729 X-38.074 Z-27.548
N18730 X-37.595 Z-28.455
N18731 X-36.635 Z-30.125
N18732 X-35.676 Z-31.638
N18733 X-34.839 Z-32.859
N18734 X-34.002 Z-33.989
N18735 X-33.166 Z-35.047
N18736 X-32.329 Z-36.043
N18737 X-31.408 Z-37.073
N18738 X-30.487 Z-38.035
N18739 X-29.566 Z-38.941
N18740 X-28.645 Z-39.796
N18741 X-27.77 Z-40.565
N18742 X-26.895 Z-41.292
N18743 X-26.02 Z-41.981
N18744 X-25.145 Z-42.634
N18745 X-24.233 Z-43.278
N18746 X-23.321 Z-43.886
N18747 X-22.41 Z-44.462
N18748 X-21.498 Z-45.007
N18749 X-19.729 Z-45.98
N18750 X-17.961 Z-46.848
N18751 X-16.151 Z-47.634
N18752 X-14.342 Z-48.323
N18753 X-12.559 Z-48.913
N18754 X-10.776 Z-49.418
N18755 X-8.958 Z-49.849
N18756 X-7.169 Z-50.192
N18757 X-5.362 Z-50.46
N18758 X-3.592 Z-50.648
N18759 X-1.797 Z-50.761
N18760 X0. Z-50.8
N18761 X1.797 Z-50.761
N18762 X3.592 Z-50.648
N18763 X5.362 Z-50.46
N18764 X7.169 Z-50.192
N18765 X8.958 Z-49.849
N18766 X10.776 Z-49.418
N18767 X12.559 Z-48.913
N18768 X14.342 Z-48.323
N18769 X16.151 Z-47.634
N18770 X17.961 Z-46.848
N18771 X18.845 Z-46.427
N18772 X20.614 Z-45.507
N18773 X22.41 Z-44.462
N18774 X23.321 Z-43.886
N18775 X24.233 Z-43.278
N18776 X25.145 Z-42.634
N18777 X26.02 Z-41.981
N18778 X26.895 Z-41.292
N18779 X27.77 Z-40.565
N18780 X28.645 Z-39.796
N18781 X29.566 Z-38.941
N18782 X30.487 Z-38.035
N18783 X31.408 Z-37.073
N18784 X32.329 Z-36.043
N18785 X33.166 Z-35.047
N18786 X34.002 Z-33.989
N18787 X34.839 Z-32.859
N18788 X35.676 Z-31.638
N18789 X36.156 Z-30.898
N18790 X37.115 Z-29.312
N18791 X38.074 Z-27.548
N18792 X38.554 Z-26.583
N18793 X39.033 Z-25.551
N18794 X39.758 Z-23.846
N18795 X40.491 Z-21.866
N18796 X40.979 Z-20.339
N18797 X41.571 Z-18.178
N18798 X42.184 Z-15.229
N18799 X42.44 Z-13.521
N18800 X42.798 Z-9.749
N18801 X43.003 Z-8.619
N18802 X43.217 Z-7.837
N18803 X43.554 Z-6.909
N18804 X43.779 Z-6.404
N18805 X44.228 Z-5.547
N18806 X44.677 Z-4.839
N18807 X45.35 Z-3.957
N18808 X45.799 Z-3.462
N18809 X46.248 Z-3.014
N18810 X46.697 Z-2.619
N18811 X47.146 Z-2.259
N18812 X48.044 Z-1.647
N18813 X48.493 Z-1.387
N18814 X49.391 Z-.944
N18815 X50.289 Z-.595
N18816 X51.187 Z-.33
N18817 X52.085 Z-.146
N18818 X52.984 Z-.036
N18819 X53.882 Z0.
N18820 Y-94.225
N18821 X52.984 Z-.036
N18822 X52.085 Z-.146
N18823 X51.187 Z-.33
N18824 X50.289 Z-.595
N18825 X49.391 Z-.944
N18826 X48.493 Z-1.387
N18827 X48.044 Z-1.647
N18828 X47.146 Z-2.259
N18829 X46.697 Z-2.619
N18830 X46.248 Z-3.014
N18831 X45.799 Z-3.462
N18832 X45.35 Z-3.957
N18833 X44.677 Z-4.839
N18834 X44.228 Z-5.547
N18835 X43.779 Z-6.403
N18836 X43.554 Z-6.909
N18837 X43.217 Z-7.837
N18838 X43.003 Z-8.619
N18839 X42.798 Z-9.749
N18840 X42.44 Z-13.521
N18841 X42.184 Z-15.229
N18842 X41.571 Z-18.178
N18843 X40.979 Z-20.339
N18844 X40.491 Z-21.866
N18845 X39.758 Z-23.846
N18846 X39.033 Z-25.551
N18847 X38.554 Z-26.583
N18848 X38.074 Z-27.548
N18849 X37.115 Z-29.312
N18850 X36.156 Z-30.898
N18851 X35.676 Z-31.638
N18852 X34.839 Z-32.859
N18853 X34.002 Z-33.989
N18854 X33.166 Z-35.047
N18855 X32.329 Z-36.043
N18856 X31.408 Z-37.073
N18857 X30.487 Z-38.035
N18858 X29.566 Z-38.941
N18859 X28.645 Z-39.796
N18860 X27.77 Z-40.565
N18861 X26.895 Z-41.292
N18862 X26.02 Z-41.981
N18863 X25.145 Z-42.634
N18864 X24.233 Z-43.278
N18865 X23.321 Z-43.886
N18866 X22.41 Z-44.462
N18867 X20.614 Z-45.507
N18868 X18.845 Z-46.427
N18869 X17.961 Z-46.848
N18870 X16.151 Z-47.634
N18871 X14.342 Z-48.323
N18872 X12.559 Z-48.913
N18873 X10.776 Z-49.418
N18874 X8.958 Z-49.849
N18875 X7.169 Z-50.192
N18876 X5.362 Z-50.46
N18877 X3.592 Z-50.648
N18878 X1.797 Z-50.761
N18879 X0. Z-50.8
N18880 X-1.797 Z-50.761
N18881 X-3.592 Z-50.648
N18882 X-5.362 Z-50.46
N18883 X-7.169 Z-50.192
N18884 X-8.958 Z-49.849
N18885 X-10.776 Z-49.418
N18886 X-12.559 Z-48.913
N18887 X-14.342 Z-48.323
N18888 X-16.151 Z-47.634
N18889 X-17.961 Z-46.848
N18890 X-19.729 Z-45.98
N18891 X-21.498 Z-45.007
N18892 X-22.41 Z-44.462
N18893 X-23.321 Z-43.886
N18894 X-24.233 Z-43.278
N18895 X-25.145 Z-42.634
N18896 X-26.02 Z-41.981
N18897 X-26.895 Z-41.292
N18898 X-27.77 Z-40.565
N18899 X-28.645 Z-39.796
N18900 X-29.566 Z-38.941
N18901 X-30.487 Z-38.035
N18902 X-31.408 Z-37.073
N18903 X-32.329 Z-36.043
N18904 X-33.166 Z-35.047
N18905 X-34.002 Z-33.989
N18906 X-34.839 Z-32.859
N18907 X-35.676 Z-31.638
N18908 X-36.635 Z-30.125
N18909 X-37.595 Z-28.455
N18910 X-38.074 Z-27.548
N18911 X-38.554 Z-26.583
N18912 X-39.033 Z-25.551
N18913 X-39.758 Z-23.846
N18914 X-40.491 Z-21.866
N18915 X-41.346 Z-19.058
N18916 X-41.98 Z-16.328
N18917 X-42.491 Z-13.111
N18918 X-42.798 Z-9.749
N18919 X-42.901 Z-9.111
N18920 X-43.105 Z-8.221
N18921 X-43.33 Z-7.496
N18922 X-43.554 Z-6.909
N18923 X-44.003 Z-5.954
N18924 X-44.452 Z-5.183
N18925 X-44.901 Z-4.526
N18926 X-45.35 Z-3.957
N18927 X-45.799 Z-3.462
N18928 X-46.248 Z-3.014
N18929 X-46.697 Z-2.619
N18930 X-47.146 Z-2.259
N18931 X-48.044 Z-1.647
N18932 X-48.942 Z-1.152
N18933 X-49.391 Z-.944
N18934 X-50.289 Z-.595
N18935 X-51.187 Z-.33
N18936 X-52.085 Z-.146
N18937 X-52.984 Z-.036
N18938 X-53.882 Z0.
N18939 Y-95.425
N18940 X-52.984 Z-.036
N18941 X-52.085 Z-.146
N18942 X-51.187 Z-.33
N18943 X-50.289 Z-.595
N18944 X-49.391 Z-.944
N18945 X-48.942 Z-1.152
N18946 X-48.044 Z-1.647
N18947 X-47.146 Z-2.259
N18948 X-46.697 Z-2.619
N18949 X-46.248 Z-3.014
N18950 X-45.799 Z-3.462
N18951 X-45.35 Z-3.957
N18952 X-44.901 Z-4.526
N18953 X-44.452 Z-5.183
N18954 X-44.003 Z-5.954
N18955 X-43.554 Z-6.909
N18956 X-43.33 Z-7.496
N18957 X-43.105 Z-8.221
N18958 X-42.901 Z-9.112
N18959 X-42.798 Z-9.749
N18960 X-42.491 Z-13.111
N18961 X-41.98 Z-16.328
N18962 X-41.346 Z-19.058
N18963 X-40.491 Z-21.866
N18964 X-39.758 Z-23.846
N18965 X-39.033 Z-25.551
N18966 X-38.554 Z-26.583
N18967 X-38.074 Z-27.548
N18968 X-37.595 Z-28.455
N18969 X-36.635 Z-30.125
N18970 X-35.676 Z-31.638
N18971 X-34.839 Z-32.859
N18972 X-34.002 Z-33.989
N18973 X-33.166 Z-35.047
N18974 X-32.329 Z-36.043
N18975 X-31.408 Z-37.073
N18976 X-30.487 Z-38.035
N18977 X-29.566 Z-38.941
N18978 X-28.645 Z-39.796
N18979 X-27.77 Z-40.565
N18980 X-26.895 Z-41.292
N18981 X-26.02 Z-41.981
N18982 X-25.145 Z-42.634
N18983 X-24.233 Z-43.278
N18984 X-23.321 Z-43.886
N18985 X-22.41 Z-44.462
N18986 X-21.498 Z-45.007
N18987 X-19.729 Z-45.98
N18988 X-17.961 Z-46.848
N18989 X-16.151 Z-47.634
N18990 X-14.342 Z-48.323
N18991 X-12.559 Z-48.913
N18992 X-10.776 Z-49.418
N18993 X-8.958 Z-49.849
N18994 X-7.169 Z-50.192
N18995 X-5.362 Z-50.46
N18996 X-3.592 Z-50.648
N18997 X-1.797 Z-50.761
N18998 X0. Z-50.8
N18999 X1.797 Z-50.761
N19000 X3.592 Z-50.648
N19001 X5.362 Z-50.46
N19002 X7.169 Z-50.192
N19003 X8.958 Z-49.849
N19004 X10.776 Z-49.418
N19005 X12.559 Z-48.913
N19006 X14.342 Z-48.323
N19007 X16.151 Z-47.634
N19008 X17.961 Z-46.848
N19009 X18.845 Z-46.427
N19010 X20.614 Z-45.507
N19011 X22.41 Z-44.462
N19012 X23.321 Z-43.886
N19013 X24.233 Z-43.278
N19014 X25.145 Z-42.634
N19015 X26.02 Z-41.981
N19016 X26.895 Z-41.292
N19017 X27.77 Z-40.565
N19018 X28.645 Z-39.796
N19019 X29.566 Z-38.941
N19020 X30.487 Z-38.035
N19021 X31.408 Z-37.073
N19022 X32.329 Z-36.043
N19023 X33.166 Z-35.047
N19024 X34.002 Z-33.989
N19025 X34.839 Z-32.859
N19026 X35.676 Z-31.638
N19027 X36.156 Z-30.898
N19028 X37.115 Z-29.312
N19029 X38.074 Z-27.548
N19030 X38.554 Z-26.583
N19031 X39.033 Z-25.551
N19032 X39.758 Z-23.846
N19033 X40.491 Z-21.866
N19034 X40.979 Z-20.339
N19035 X41.571 Z-18.178
N19036 X42.184 Z-15.229
N19037 X42.44 Z-13.521
N19038 X42.798 Z-9.749
N19039 X43.003 Z-8.619
N19040 X43.217 Z-7.837
N19041 X43.554 Z-6.909
N19042 X43.779 Z-6.403
N19043 X44.228 Z-5.547
N19044 X44.677 Z-4.839
N19045 X45.35 Z-3.957
N19046 X45.799 Z-3.462
N19047 X46.248 Z-3.014
N19048 X46.697 Z-2.619
N19049 X47.146 Z-2.259
N19050 X48.044 Z-1.647
N19051 X48.493 Z-1.387
N19052 X49.391 Z-.944
N19053 X50.289 Z-.595
N19054 X51.187 Z-.33
N19055 X52.085 Z-.146
N19056 X52.984 Z-.036
N19057 X53.882 Z0.
N19058 Y-96.625
N19059 X52.984 Z-.036
N19060 X52.085 Z-.146
N19061 X51.187 Z-.33
N19062 X50.289 Z-.595
N19063 X49.391 Z-.944
N19064 X48.493 Z-1.387
N19065 X48.044 Z-1.647
N19066 X47.146 Z-2.259
N19067 X46.697 Z-2.619
N19068 X46.248 Z-3.014
N19069 X45.799 Z-3.462
N19070 X45.35 Z-3.957
N19071 X44.677 Z-4.839
N19072 X44.228 Z-5.547
N19073 X43.779 Z-6.403
N19074 X43.554 Z-6.909
N19075 X43.217 Z-7.837
N19076 X43.003 Z-8.619
N19077 X42.798 Z-9.749
N19078 X42.44 Z-13.521
N19079 X42.184 Z-15.229
N19080 X41.571 Z-18.178
N19081 X40.979 Z-20.339
N19082 X40.491 Z-21.866
N19083 X39.758 Z-23.846
N19084 X39.033 Z-25.551
N19085 X38.554 Z-26.583
N19086 X38.074 Z-27.548
N19087 X37.115 Z-29.312
N19088 X36.156 Z-30.898
N19089 X35.676 Z-31.638
N19090 X34.839 Z-32.859
N19091 X34.002 Z-33.989
N19092 X33.166 Z-35.047
N19093 X32.329 Z-36.043
N19094 X31.408 Z-37.073
N19095 X30.487 Z-38.035
N19096 X29.566 Z-38.941
N19097 X28.645 Z-39.796
N19098 X27.77 Z-40.565
N19099 X26.895 Z-41.292
N19100 X26.02 Z-41.981
N19101 X25.145 Z-42.634
N19102 X24.233 Z-43.278
N19103 X23.321 Z-43.886
N19104 X22.41 Z-44.462
N19105 X20.614 Z-45.507
N19106 X18.845 Z-46.427
N19107 X17.961 Z-46.848
N19108 X16.151 Z-47.634
N19109 X14.342 Z-48.323
N19110 X12.559 Z-48.913
N19111 X10.776 Z-49.418
N19112 X8.958 Z-49.849
N19113 X7.169 Z-50.192
N19114 X5.362 Z-50.46
N19115 X3.592 Z-50.648
N19116 X1.797 Z-50.761
N19117 X0. Z-50.8
N19118 X-1.797 Z-50.761
N19119 X-3.592 Z-50.648
N19120 X-5.362 Z-50.46
N19121 X-7.169 Z-50.192
N19122 X-8.958 Z-49.849
N19123 X-10.776 Z-49.418
N19124 X-12.559 Z-48.913
N19125 X-14.342 Z-48.323
N19126 X-16.151 Z-47.634
N19127 X-17.961 Z-46.848
N19128 X-19.729 Z-45.98
N19129 X-21.498 Z-45.007
N19130 X-22.41 Z-44.462
N19131 X-23.321 Z-43.886
N19132 X-24.233 Z-43.278
N19133 X-25.145 Z-42.634
N19134 X-26.02 Z-41.981
N19135 X-26.895 Z-41.292
N19136 X-27.77 Z-40.565
N19137 X-28.645 Z-39.796
N19138 X-29.566 Z-38.941
N19139 X-30.487 Z-38.035
N19140 X-31.408 Z-37.073
N19141 X-32.329 Z-36.043
N19142 X-33.166 Z-35.047
N19143 X-34.002 Z-33.989
N19144 X-34.839 Z-32.859
N19145 X-35.676 Z-31.638
N19146 X-36.635 Z-30.125
N19147 X-37.595 Z-28.455
N19148 X-38.074 Z-27.548
N19149 X-38.554 Z-26.583
N19150 X-39.033 Z-25.551
N19151 X-39.758 Z-23.846
N19152 X-40.491 Z-21.866
N19153 X-41.346 Z-19.058
N19154 X-41.98 Z-16.328
N19155 X-42.491 Z-13.111
N19156 X-42.798 Z-9.749
N19157 X-42.901 Z-9.112
N19158 X-43.105 Z-8.222
N19159 X-43.33 Z-7.496
N19160 X-43.554 Z-6.909
N19161 X-44.003 Z-5.954
N19162 X-44.452 Z-5.184
N19163 X-44.901 Z-4.526
N19164 X-45.35 Z-3.957
N19165 X-45.799 Z-3.462
N19166 X-46.248 Z-3.014
N19167 X-46.697 Z-2.619
N19168 X-47.146 Z-2.259
N19169 X-48.044 Z-1.647
N19170 X-48.942 Z-1.152
N19171 X-49.391 Z-.944
N19172 X-50.289 Z-.595
N19173 X-51.187 Z-.33
N19174 X-52.085 Z-.146
N19175 X-52.984 Z-.036
N19176 X-53.882 Z0.
N19177 Y-97.825
N19178 X-52.984 Z-.036
N19179 X-52.085 Z-.146
N19180 X-51.187 Z-.33
N19181 X-50.289 Z-.595
N19182 X-49.391 Z-.944
N19183 X-48.942 Z-1.152
N19184 X-48.044 Z-1.647
N19185 X-47.146 Z-2.259
N19186 X-46.697 Z-2.619
N19187 X-46.248 Z-3.014
N19188 X-45.799 Z-3.462
N19189 X-45.35 Z-3.957
N19190 X-44.901 Z-4.526
N19191 X-44.452 Z-5.184
N19192 X-44.003 Z-5.954
N19193 X-43.554 Z-6.909
N19194 X-43.33 Z-7.496
N19195 X-43.105 Z-8.222
N19196 X-42.901 Z-9.112
N19197 X-42.798 Z-9.749
N19198 X-42.491 Z-13.111
N19199 X-41.98 Z-16.328
N19200 X-41.346 Z-19.058
N19201 X-40.491 Z-21.866
N19202 X-39.758 Z-23.846
N19203 X-39.033 Z-25.551
N19204 X-38.554 Z-26.583
N19205 X-38.074 Z-27.548
N19206 X-37.595 Z-28.455
N19207 X-36.635 Z-30.125
N19208 X-35.676 Z-31.638
N19209 X-34.839 Z-32.859
N19210 X-34.002 Z-33.989
N19211 X-33.166 Z-35.047
N19212 X-32.329 Z-36.043
N19213 X-31.408 Z-37.073
N19214 X-30.487 Z-38.035
N19215 X-29.566 Z-38.941
N19216 X-28.645 Z-39.796
N19217 X-27.77 Z-40.565
N19218 X-26.895 Z-41.292
N19219 X-26.02 Z-41.981
N19220 X-25.145 Z-42.634
N19221 X-24.233 Z-43.278
N19222 X-23.321 Z-43.886
N19223 X-22.41 Z-44.462
N19224 X-21.498 Z-45.007
N19225 X-19.729 Z-45.98
N19226 X-17.961 Z-46.848
N19227 X-16.151 Z-47.634
N19228 X-14.342 Z-48.323
N19229 X-12.559 Z-48.913
N19230 X-10.776 Z-49.418
N19231 X-8.958 Z-49.849
N19232 X-7.169 Z-50.192
N19233 X-5.362 Z-50.46
N19234 X-3.592 Z-50.648
N19235 X-1.797 Z-50.761
N19236 X0. Z-50.8
N19237 X1.797 Z-50.761
N19238 X3.592 Z-50.648
N19239 X5.362 Z-50.46
N19240 X7.169 Z-50.192
N19241 X8.958 Z-49.849
N19242 X10.776 Z-49.418
N19243 X12.559 Z-48.913
N19244 X14.342 Z-48.323
N19245 X16.151 Z-47.634
N19246 X17.961 Z-46.848
N19247 X18.845 Z-46.427
N19248 X20.614 Z-45.507
N19249 X22.41 Z-44.462
N19250 X23.321 Z-43.886
N19251 X24.233 Z-43.278
N19252 X25.145 Z-42.634
N19253 X26.02 Z-41.981
N19254 X26.895 Z-41.292
N19255 X27.77 Z-40.565
N19256 X28.645 Z-39.796
N19257 X29.566 Z-38.941
N19258 X30.487 Z-38.035
N19259 X31.408 Z-37.073
N19260 X32.329 Z-36.043
N19261 X33.166 Z-35.047
N19262 X34.002 Z-33.989
N19263 X34.839 Z-32.859
N19264 X35.676 Z-31.638
N19265 X36.156 Z-30.898
N19266 X37.115 Z-29.312
N19267 X38.074 Z-27.548
N19268 X38.554 Z-26.583
N19269 X39.033 Z-25.551
N19270 X39.758 Z-23.846
N19271 X40.491 Z-21.866
N19272 X40.979 Z-20.339
N19273 X41.571 Z-18.178
N19274 X42.184 Z-15.229
N19275 X42.44 Z-13.521
N19276 X42.798 Z-9.749
N19277 X43.003 Z-8.619
N19278 X43.217 Z-7.837
N19279 X43.554 Z-6.909
N19280 X43.779 Z-6.403
N19281 X44.228 Z-5.547
N19282 X44.677 Z-4.839
N19283 X45.35 Z-3.957
N19284 X45.799 Z-3.462
N19285 X46.248 Z-3.014
N19286 X46.697 Z-2.619
N19287 X47.146 Z-2.259
N19288 X48.044 Z-1.647
N19289 X48.493 Z-1.387
N19290 X49.391 Z-.944
N19291 X50.289 Z-.595
N19292 X51.187 Z-.33
N19293 X52.085 Z-.146
N19294 X52.984 Z-.036
N19295 X53.882 Z0.
N19296 Y-99.025
N19297 X52.984 Z-.036
N19298 X52.085 Z-.146
N19299 X51.187 Z-.33
N19300 X50.289 Z-.595
N19301 X49.391 Z-.944
N19302 X48.493 Z-1.387
N19303 X48.044 Z-1.647
N19304 X47.146 Z-2.259
N19305 X46.697 Z-2.619
N19306 X46.248 Z-3.014
N19307 X45.799 Z-3.462
N19308 X45.35 Z-3.957
N19309 X44.677 Z-4.839
N19310 X44.228 Z-5.547
N19311 X43.779 Z-6.403
N19312 X43.554 Z-6.909
N19313 X43.217 Z-7.837
N19314 X43.003 Z-8.619
N19315 X42.798 Z-9.749
N19316 X42.44 Z-13.521
N19317 X42.184 Z-15.229
N19318 X41.571 Z-18.178
N19319 X40.979 Z-20.339
N19320 X40.491 Z-21.866
N19321 X39.758 Z-23.846
N19322 X39.033 Z-25.551
N19323 X38.554 Z-26.583
N19324 X38.074 Z-27.548
N19325 X37.115 Z-29.312
N19326 X36.156 Z-30.898
N19327 X35.676 Z-31.638
N19328 X34.839 Z-32.859
N19329 X34.002 Z-33.989
N19330 X33.166 Z-35.047
N19331 X32.329 Z-36.043
N19332 X31.408 Z-37.073
N19333 X30.487 Z-38.035
N19334 X29.566 Z-38.941
N19335 X28.645 Z-39.796
N19336 X27.77 Z-40.565
N19337 X26.895 Z-41.292
N19338 X26.02 Z-41.981
N19339 X25.145 Z-42.634
N19340 X24.233 Z-43.278
N19341 X23.321 Z-43.886
N19342 X22.41 Z-44.462
N19343 X20.614 Z-45.507
N19344 X18.845 Z-46.427
N19345 X17.961 Z-46.848
N19346 X16.151 Z-47.634
N19347 X14.342 Z-48.323
N19348 X12.559 Z-48.913
N19349 X10.776 Z-49.418
N19350 X8.958 Z-49.849
N19351 X7.169 Z-50.192
N19352 X5.362 Z-50.46
N19353 X3.592 Z-50.648
N19354 X1.797 Z-50.761
N19355 X0. Z-50.8
N19356 X-1.797 Z-50.761
N19357 X-3.592 Z-50.648
N19358 X-5.362 Z-50.46
N19359 X-7.169 Z-50.192
N19360 X-8.958 Z-49.849
N19361 X-10.776 Z-49.418
N19362 X-12.559 Z-48.913
N19363 X-14.342 Z-48.323
N19364 X-16.151 Z-47.634
N19365 X-17.961 Z-46.848
N19366 X-19.729 Z-45.98
N19367 X-21.498 Z-45.007
N19368 X-22.41 Z-44.462
N19369 X-23.321 Z-43.886
N19370 X-24.233 Z-43.278
N19371 X-25.145 Z-42.634
N19372 X-26.02 Z-41.981
N19373 X-26.895 Z-41.292
N19374 X-27.77 Z-40.565
N19375 X-28.645 Z-39.796
N19376 X-29.566 Z-38.941
N19377 X-30.487 Z-38.035
N19378 X-31.408 Z-37.073
N19379 X-32.329 Z-36.043
N19380 X-33.166 Z-35.047
N19381 X-34.002 Z-33.989
N19382 X-34.839 Z-32.859
N19383 X-35.676 Z-31.638
N19384 X-36.635 Z-30.125
N19385 X-37.595 Z-28.455
N19386 X-38.074 Z-27.548
N19387 X-38.554 Z-26.583
N19388 X-39.033 Z-25.551
N19389 X-39.758 Z-23.846
N19390 X-40.491 Z-21.866
N19391 X-41.346 Z-19.058
N19392 X-41.98 Z-16.328
N19393 X-42.491 Z-13.111
N19394 X-42.798 Z-9.749
N19395 X-42.901 Z-9.112
N19396 X-43.105 Z-8.222
N19397 X-43.33 Z-7.496
N19398 X-43.554 Z-6.909
N19399 X-44.003 Z-5.954
N19400 X-44.452 Z-5.184
N19401 X-44.901 Z-4.526
N19402 X-45.35 Z-3.957
N19403 X-45.799 Z-3.462
N19404 X-46.248 Z-3.014
N19405 X-46.697 Z-2.619
N19406 X-47.146 Z-2.259
N19407 X-48.044 Z-1.647
N19408 X-48.942 Z-1.152
N19409 X-49.391 Z-.944
N19410 X-50.289 Z-.595
N19411 X-51.187 Z-.33
N19412 X-52.085 Z-.146
N19413 X-52.984 Z-.036
N19414 X-53.882 Z0.
N19415 Y-100.225
N19416 X-52.984 Z-.036
N19417 X-52.085 Z-.146
N19418 X-51.187 Z-.331
N19419 X-50.289 Z-.595
N19420 X-49.391 Z-.944
N19421 X-48.942 Z-1.152
N19422 X-48.044 Z-1.647
N19423 X-47.146 Z-2.259
N19424 X-46.697 Z-2.619
N19425 X-46.248 Z-3.014
N19426 X-45.799 Z-3.462
N19427 X-45.35 Z-3.957
N19428 X-44.901 Z-4.526
N19429 X-44.452 Z-5.184
N19430 X-44.003 Z-5.954
N19431 X-43.554 Z-6.909
N19432 X-43.33 Z-7.496
N19433 X-43.105 Z-8.222
N19434 X-42.901 Z-9.113
N19435 X-42.798 Z-9.749
N19436 X-42.491 Z-13.111
N19437 X-41.98 Z-16.328
N19438 X-41.346 Z-19.058
N19439 X-40.491 Z-21.866
N19440 X-39.758 Z-23.846
N19441 X-39.033 Z-25.551
N19442 X-38.554 Z-26.583
N19443 X-38.074 Z-27.548
N19444 X-37.595 Z-28.455
N19445 X-36.635 Z-30.125
N19446 X-35.676 Z-31.638
N19447 X-34.839 Z-32.859
N19448 X-34.002 Z-33.989
N19449 X-33.166 Z-35.047
N19450 X-32.329 Z-36.043
N19451 X-31.408 Z-37.073
N19452 X-30.487 Z-38.035
N19453 X-29.566 Z-38.941
N19454 X-28.645 Z-39.796
N19455 X-27.77 Z-40.565
N19456 X-26.895 Z-41.292
N19457 X-26.02 Z-41.981
N19458 X-25.145 Z-42.634
N19459 X-24.233 Z-43.278
N19460 X-23.321 Z-43.886
N19461 X-22.41 Z-44.462
N19462 X-21.498 Z-45.007
N19463 X-19.729 Z-45.98
N19464 X-17.961 Z-46.848
N19465 X-16.151 Z-47.634
N19466 X-14.342 Z-48.323
N19467 X-12.559 Z-48.913
N19468 X-10.776 Z-49.418
N19469 X-8.958 Z-49.849
N19470 X-7.169 Z-50.192
N19471 X-5.362 Z-50.46
N19472 X-3.592 Z-50.648
N19473 X-1.797 Z-50.761
N19474 X0. Z-50.8
N19475 X1.797 Z-50.761
N19476 X3.592 Z-50.648
N19477 X5.362 Z-50.46
N19478 X7.169 Z-50.192
N19479 X8.958 Z-49.849
N19480 X10.776 Z-49.418
N19481 X12.559 Z-48.913
N19482 X14.342 Z-48.323
N19483 X16.151 Z-47.634
N19484 X17.961 Z-46.848
N19485 X18.845 Z-46.427
N19486 X20.614 Z-45.507
N19487 X22.41 Z-44.462
N19488 X23.321 Z-43.886
N19489 X24.233 Z-43.278
N19490 X25.145 Z-42.634
N19491 X26.02 Z-41.981
N19492 X26.895 Z-41.292
N19493 X27.77 Z-40.565
N19494 X28.645 Z-39.796
N19495 X29.566 Z-38.941
N19496 X30.487 Z-38.035
N19497 X31.408 Z-37.073
N19498 X32.329 Z-36.043
N19499 X33.166 Z-35.047
N19500 X34.002 Z-33.989
N19501 X34.839 Z-32.859
N19502 X35.676 Z-31.638
N19503 X36.156 Z-30.898
N19504 X37.115 Z-29.312
N19505 X38.074 Z-27.548
N19506 X38.554 Z-26.583
N19507 X39.033 Z-25.551
N19508 X39.758 Z-23.846
N19509 X40.491 Z-21.866
N19510 X40.979 Z-20.339
N19511 X41.571 Z-18.178
N19512 X42.184 Z-15.229
N19513 X42.44 Z-13.521
N19514 X42.798 Z-9.749
N19515 X43.003 Z-8.619
N19516 X43.217 Z-7.837
N19517 X43.554 Z-6.909
N19518 X43.779 Z-6.403
N19519 X44.228 Z-5.547
N19520 X44.677 Z-4.839
N19521 X45.35 Z-3.957
N19522 X45.799 Z-3.462
N19523 X46.248 Z-3.014
N19524 X46.697 Z-2.619
N19525 X47.146 Z-2.259
N19526 X48.044 Z-1.647
N19527 X48.493 Z-1.387
N19528 X49.391 Z-.944
N19529 X50.289 Z-.595
N19530 X51.187 Z-.33
N19531 X52.085 Z-.146
N19532 X52.984 Z-.036
N19533 X53.882 Z0.
N19534 Y-101.425
N19535 X52.984 Z-.036
N19536 X52.085 Z-.146
N19537 X51.187 Z-.331
N19538 X50.289 Z-.595
N19539 X49.391 Z-.944
N19540 X48.493 Z-1.387
N19541 X48.044 Z-1.647
N19542 X47.146 Z-2.259
N19543 X46.697 Z-2.619
N19544 X46.248 Z-3.013
N19545 X45.799 Z-3.462
N19546 X45.35 Z-3.957
N19547 X44.677 Z-4.839
N19548 X44.228 Z-5.547
N19549 X43.779 Z-6.403
N19550 X43.554 Z-6.909
N19551 X43.217 Z-7.837
N19552 X43.003 Z-8.619
N19553 X42.798 Z-9.75
N19554 X42.44 Z-13.521
N19555 X42.184 Z-15.229
N19556 X41.571 Z-18.178
N19557 X40.979 Z-20.339
N19558 X40.491 Z-21.866
N19559 X39.758 Z-23.846
N19560 X39.033 Z-25.551
N19561 X38.554 Z-26.583
N19562 X38.074 Z-27.548
N19563 X37.115 Z-29.312
N19564 X36.156 Z-30.898
N19565 X35.676 Z-31.638
N19566 X34.839 Z-32.859
N19567 X34.002 Z-33.989
N19568 X33.166 Z-35.047
N19569 X32.329 Z-36.043
N19570 X31.408 Z-37.073
N19571 X30.487 Z-38.035
N19572 X29.566 Z-38.941
N19573 X28.645 Z-39.796
N19574 X27.77 Z-40.565
N19575 X26.895 Z-41.292
N19576 X26.02 Z-41.981
N19577 X25.145 Z-42.634
N19578 X24.233 Z-43.278
N19579 X23.321 Z-43.886
N19580 X22.41 Z-44.462
N19581 X20.614 Z-45.507
N19582 X18.845 Z-46.427
N19583 X17.961 Z-46.848
N19584 X16.151 Z-47.634
N19585 X14.342 Z-48.323
N19586 X12.559 Z-48.913
N19587 X10.776 Z-49.418
N19588 X8.958 Z-49.849
N19589 X7.169 Z-50.192
N19590 X5.362 Z-50.46
N19591 X3.592 Z-50.648
N19592 X1.797 Z-50.761
N19593 X0. Z-50.8
N19594 X-1.797 Z-50.761
N19595 X-3.592 Z-50.648
N19596 X-5.362 Z-50.46
N19597 X-7.169 Z-50.192
N19598 X-8.958 Z-49.849
N19599 X-10.776 Z-49.418
N19600 X-12.559 Z-48.913
N19601 X-14.342 Z-48.323
N19602 X-16.151 Z-47.634
N19603 X-17.961 Z-46.848
N19604 X-19.729 Z-45.98
N19605 X-21.498 Z-45.007
N19606 X-22.41 Z-44.462
N19607 X-23.321 Z-43.886
N19608 X-24.233 Z-43.278
N19609 X-25.145 Z-42.634
N19610 X-26.02 Z-41.981
N19611 X-26.895 Z-41.292
N19612 X-27.77 Z-40.565
N19613 X-28.645 Z-39.796
N19614 X-29.566 Z-38.941
N19615 X-30.487 Z-38.035
N19616 X-31.408 Z-37.073
N19617 X-32.329 Z-36.043
N19618 X-33.166 Z-35.047
N19619 X-34.002 Z-33.989
N19620 X-34.839 Z-32.859
N19621 X-35.676 Z-31.638
N19622 X-36.635 Z-30.125
N19623 X-37.595 Z-28.455
N19624 X-38.074 Z-27.548
N19625 X-38.554 Z-26.583
N19626 X-39.033 Z-25.551
N19627 X-39.758 Z-23.846
N19628 X-40.491 Z-21.866
N19629 X-41.346 Z-19.058
N19630 X-41.98 Z-16.328
N19631 X-42.491 Z-13.111
N19632 X-42.798 Z-9.75
N19633 X-43.003 Z-8.619
N19634 X-43.33 Z-7.496
N19635 X-43.554 Z-6.909
N19636 X-44.003 Z-5.954
N19637 X-44.452 Z-5.184
N19638 X-44.901 Z-4.526
N19639 X-45.35 Z-3.957
N19640 X-45.799 Z-3.462
N19641 X-46.248 Z-3.014
N19642 X-46.697 Z-2.619
N19643 X-47.146 Z-2.259
N19644 X-48.044 Z-1.647
N19645 X-48.942 Z-1.152
N19646 X-49.391 Z-.944
N19647 X-50.289 Z-.595
N19648 X-51.187 Z-.331
N19649 X-52.085 Z-.146
N19650 X-52.984 Z-.036
N19651 X-53.882 Z0.
N19652 Y-102.625
N19653 X-52.984 Z-.036
N19654 X-52.085 Z-.146
N19655 X-51.187 Z-.331
N19656 X-50.289 Z-.595
N19657 X-49.391 Z-.944
N19658 X-48.942 Z-1.152
N19659 X-48.044 Z-1.647
N19660 X-47.146 Z-2.259
N19661 X-46.697 Z-2.619
N19662 X-46.248 Z-3.014
N19663 X-45.799 Z-3.462
N19664 X-45.35 Z-3.957
N19665 X-44.901 Z-4.526
N19666 X-44.452 Z-5.184
N19667 X-44.003 Z-5.954
N19668 X-43.554 Z-6.909
N19669 X-43.33 Z-7.496
N19670 X-43.003 Z-8.619
N19671 X-42.798 Z-9.75
N19672 X-42.491 Z-13.111
N19673 X-41.98 Z-16.328
N19674 X-41.346 Z-19.058
N19675 X-40.491 Z-21.866
N19676 X-39.758 Z-23.846
N19677 X-39.033 Z-25.551
N19678 X-38.554 Z-26.583
N19679 X-38.074 Z-27.548
N19680 X-37.595 Z-28.455
N19681 X-36.635 Z-30.125
N19682 X-35.676 Z-31.638
N19683 X-34.839 Z-32.859
N19684 X-34.002 Z-33.989
N19685 X-33.166 Z-35.047
N19686 X-32.329 Z-36.043
N19687 X-31.408 Z-37.073
N19688 X-30.487 Z-38.035
N19689 X-29.566 Z-38.941
N19690 X-28.645 Z-39.796
N19691 X-27.77 Z-40.565
N19692 X-26.895 Z-41.292
N19693 X-26.02 Z-41.981
N19694 X-25.145 Z-42.634
N19695 X-24.233 Z-43.278
N19696 X-23.321 Z-43.886
N19697 X-22.41 Z-44.462
N19698 X-21.498 Z-45.007
N19699 X-19.729 Z-45.98
N19700 X-17.961 Z-46.848
N19701 X-16.151 Z-47.634
N19702 X-14.342 Z-48.323
N19703 X-12.559 Z-48.913
N19704 X-10.776 Z-49.418
N19705 X-8.958 Z-49.849
N19706 X-7.169 Z-50.192
N19707 X-5.362 Z-50.46
N19708 X-3.592 Z-50.648
N19709 X-1.797 Z-50.761
N19710 X0. Z-50.8
N19711 X1.797 Z-50.761
N19712 X3.592 Z-50.648
N19713 X5.362 Z-50.46
N19714 X7.169 Z-50.192
N19715 X8.958 Z-49.849
N19716 X10.776 Z-49.418
N19717 X12.559 Z-48.913
N19718 X14.342 Z-48.323
N19719 X16.151 Z-47.634
N19720 X17.961 Z-46.848
N19721 X18.845 Z-46.427
N19722 X20.614 Z-45.507
N19723 X22.41 Z-44.462
N19724 X23.321 Z-43.886
N19725 X24.233 Z-43.278
N19726 X25.145 Z-42.634
N19727 X26.02 Z-41.981
N19728 X26.895 Z-41.292
N19729 X27.77 Z-40.565
N19730 X28.645 Z-39.796
N19731 X29.566 Z-38.941
N19732 X30.487 Z-38.035
N19733 X31.408 Z-37.073
N19734 X32.329 Z-36.043
N19735 X33.166 Z-35.047
N19736 X34.002 Z-33.989
N19737 X34.839 Z-32.859
N19738 X35.676 Z-31.638
N19739 X36.156 Z-30.898
N19740 X37.115 Z-29.312
N19741 X38.074 Z-27.548
N19742 X38.554 Z-26.583
N19743 X39.033 Z-25.551
N19744 X39.758 Z-23.846
N19745 X40.491 Z-21.866
N19746 X40.979 Z-20.339
N19747 X41.571 Z-18.178
N19748 X42.184 Z-15.229
N19749 X42.44 Z-13.521
N19750 X42.798 Z-9.75
N19751 X43.003 Z-8.619
N19752 X43.217 Z-7.838
N19753 X43.554 Z-6.909
N19754 X43.779 Z-6.403
N19755 X44.228 Z-5.547
N19756 X44.677 Z-4.839
N19757 X45.35 Z-3.957
N19758 X45.799 Z-3.462
N19759 X46.248 Z-3.013
N19760 X46.697 Z-2.619
N19761 X47.146 Z-2.259
N19762 X48.044 Z-1.647
N19763 X48.942 Z-1.152
N19764 X49.391 Z-.944
N19765 X50.289 Z-.595
N19766 X51.187 Z-.331
N19767 X52.085 Z-.146
N19768 X52.984 Z-.036
N19769 X53.882 Z0.
N19770 Y-103.825
N19771 X52.984 Z-.036
N19772 X52.085 Z-.146
N19773 X51.187 Z-.331
N19774 X50.289 Z-.595
N19775 X49.391 Z-.945
N19776 X48.942 Z-1.152
N19777 X48.044 Z-1.647
N19778 X47.146 Z-2.259
N19779 X46.697 Z-2.619
N19780 X46.248 Z-3.013
N19781 X45.799 Z-3.462
N19782 X45.35 Z-3.958
N19783 X44.677 Z-4.839
N19784 X44.228 Z-5.547
N19785 X43.779 Z-6.403
N19786 X43.554 Z-6.909
N19787 X43.217 Z-7.838
N19788 X43.003 Z-8.619
N19789 X42.798 Z-9.75
N19790 X42.44 Z-13.521
N19791 X42.184 Z-15.229
N19792 X41.571 Z-18.178
N19793 X40.979 Z-20.339
N19794 X40.491 Z-21.866
N19795 X39.758 Z-23.846
N19796 X39.033 Z-25.551
N19797 X38.554 Z-26.583
N19798 X38.074 Z-27.548
N19799 X37.115 Z-29.312
N19800 X36.156 Z-30.898
N19801 X35.676 Z-31.638
N19802 X34.839 Z-32.859
N19803 X34.002 Z-33.989
N19804 X33.166 Z-35.047
N19805 X32.329 Z-36.043
N19806 X31.408 Z-37.073
N19807 X30.487 Z-38.035
N19808 X29.566 Z-38.941
N19809 X28.645 Z-39.796
N19810 X27.77 Z-40.565
N19811 X26.895 Z-41.292
N19812 X26.02 Z-41.981
N19813 X25.145 Z-42.634
N19814 X24.233 Z-43.278
N19815 X23.321 Z-43.886
N19816 X22.41 Z-44.462
N19817 X20.614 Z-45.507
N19818 X18.845 Z-46.427
N19819 X17.961 Z-46.848
N19820 X16.151 Z-47.634
N19821 X14.342 Z-48.323
N19822 X12.559 Z-48.913
N19823 X10.776 Z-49.418
N19824 X8.958 Z-49.849
N19825 X7.169 Z-50.192
N19826 X5.362 Z-50.46
N19827 X3.592 Z-50.648
N19828 X1.797 Z-50.761
N19829 X0. Z-50.8
N19830 X-1.797 Z-50.761
N19831 X-3.592 Z-50.648
N19832 X-5.362 Z-50.46
N19833 X-7.169 Z-50.192
N19834 X-8.958 Z-49.849
N19835 X-10.776 Z-49.418
N19836 X-12.559 Z-48.913
N19837 X-14.342 Z-48.323
N19838 X-16.151 Z-47.634
N19839 X-17.961 Z-46.848
N19840 X-19.729 Z-45.98
N19841 X-21.498 Z-45.007
N19842 X-22.41 Z-44.462
N19843 X-23.321 Z-43.886
N19844 X-24.233 Z-43.278
N19845 X-25.145 Z-42.634
N19846 X-26.02 Z-41.981
N19847 X-26.895 Z-41.292
N19848 X-27.77 Z-40.565
N19849 X-28.645 Z-39.796
N19850 X-29.566 Z-38.941
N19851 X-30.487 Z-38.035
N19852 X-31.408 Z-37.073
N19853 X-32.329 Z-36.043
N19854 X-33.166 Z-35.047
N19855 X-34.002 Z-33.989
N19856 X-34.839 Z-32.859
N19857 X-35.676 Z-31.638
N19858 X-36.635 Z-30.125
N19859 X-37.595 Z-28.455
N19860 X-38.074 Z-27.548
N19861 X-38.554 Z-26.583
N19862 X-39.033 Z-25.551
N19863 X-39.758 Z-23.846
N19864 X-40.491 Z-21.866
N19865 X-41.346 Z-19.058
N19866 X-41.98 Z-16.328
N19867 X-42.491 Z-13.111
N19868 X-42.798 Z-9.75
N19869 X-43.003 Z-8.619
N19870 X-43.33 Z-7.496
N19871 X-43.554 Z-6.909
N19872 X-44.003 Z-5.954
N19873 X-44.452 Z-5.184
N19874 X-44.901 Z-4.526
N19875 X-45.35 Z-3.957
N19876 X-45.799 Z-3.462
N19877 X-46.248 Z-3.013
N19878 X-46.697 Z-2.619
N19879 X-47.146 Z-2.259
N19880 X-48.044 Z-1.647
N19881 X-48.942 Z-1.152
N19882 X-49.391 Z-.945
N19883 X-50.289 Z-.595
N19884 X-51.187 Z-.331
N19885 X-52.085 Z-.146
N19886 X-52.984 Z-.036
N19887 X-53.882 Z0.
N19888 Y-105.025
N19889 X-52.984 Z-.036
N19890 X-52.085 Z-.146
N19891 X-51.187 Z-.331
N19892 X-50.289 Z-.595
N19893 X-49.391 Z-.945
N19894 X-48.942 Z-1.152
N19895 X-48.044 Z-1.647
N19896 X-47.146 Z-2.259
N19897 X-46.697 Z-2.619
N19898 X-46.248 Z-3.013
N19899 X-45.799 Z-3.462
N19900 X-45.35 Z-3.958
N19901 X-44.901 Z-4.526
N19902 X-44.452 Z-5.184
N19903 X-44.003 Z-5.954
N19904 X-43.554 Z-6.909
N19905 X-43.33 Z-7.496
N19906 X-43.003 Z-8.619
N19907 X-42.798 Z-9.75
N19908 X-42.491 Z-13.111
N19909 X-41.98 Z-16.328
N19910 X-41.346 Z-19.058
N19911 X-40.491 Z-21.866
N19912 X-39.758 Z-23.846
N19913 X-39.033 Z-25.551
N19914 X-38.554 Z-26.583
N19915 X-38.074 Z-27.548
N19916 X-37.595 Z-28.455
N19917 X-36.635 Z-30.125
N19918 X-35.676 Z-31.638
N19919 X-34.839 Z-32.859
N19920 X-34.002 Z-33.989
N19921 X-33.166 Z-35.047
N19922 X-32.329 Z-36.043
N19923 X-31.408 Z-37.073
N19924 X-30.487 Z-38.035
N19925 X-29.566 Z-38.941
N19926 X-28.645 Z-39.796
N19927 X-27.77 Z-40.565
N19928 X-26.895 Z-41.292
N19929 X-26.02 Z-41.981
N19930 X-25.145 Z-42.634
N19931 X-24.233 Z-43.278
N19932 X-23.321 Z-43.886
N19933 X-22.41 Z-44.462
N19934 X-21.498 Z-45.007
N19935 X-19.729 Z-45.98
N19936 X-17.961 Z-46.848
N19937 X-16.151 Z-47.634
N19938 X-14.342 Z-48.323
N19939 X-12.559 Z-48.913
N19940 X-10.776 Z-49.418
N19941 X-8.958 Z-49.849
N19942 X-7.169 Z-50.192
N19943 X-5.362 Z-50.46
N19944 X-3.592 Z-50.648
N19945 X-1.797 Z-50.761
N19946 X0. Z-50.8
N19947 X1.797 Z-50.761
N19948 X3.592 Z-50.648
N19949 X5.362 Z-50.46
N19950 X7.169 Z-50.192
N19951 X8.958 Z-49.849
N19952 X10.776 Z-49.418
N19953 X12.559 Z-48.913
N19954 X14.342 Z-48.323
N19955 X16.151 Z-47.634
N19956 X17.961 Z-46.848
N19957 X18.845 Z-46.427
N19958 X20.614 Z-45.507
N19959 X22.41 Z-44.462
N19960 X23.321 Z-43.886
N19961 X24.233 Z-43.278
N19962 X25.145 Z-42.634
N19963 X26.02 Z-41.981
N19964 X26.895 Z-41.292
N19965 X27.77 Z-40.565
N19966 X28.645 Z-39.796
N19967 X29.566 Z-38.941
N19968 X30.487 Z-38.035
N19969 X31.408 Z-37.073
N19970 X32.329 Z-36.043
N19971 X33.166 Z-35.047
N19972 X34.002 Z-33.989
N19973 X34.839 Z-32.859
N19974 X35.676 Z-31.638
N19975 X36.156 Z-30.898
N19976 X37.115 Z-29.312
N19977 X38.074 Z-27.548
N19978 X38.554 Z-26.583
N19979 X39.033 Z-25.551
N19980 X39.758 Z-23.846
N19981 X40.491 Z-21.866
N19982 X40.979 Z-20.339
N19983 X41.571 Z-18.178
N19984 X42.184 Z-15.229
N19985 X42.44 Z-13.521
N19986 X42.798 Z-9.75
N19987 X43.003 Z-8.619
N19988 X43.217 Z-7.838
N19989 X43.554 Z-6.909
N19990 X43.779 Z-6.402
N19991 X44.228 Z-5.547
N19992 X44.677 Z-4.839
N19993 X45.35 Z-3.958
N19994 X45.799 Z-3.462
N19995 X46.248 Z-3.013
N19996 X46.697 Z-2.619
N19997 X47.146 Z-2.259
N19998 X48.044 Z-1.647
N19999 X48.942 Z-1.152
N20000 X49.391 Z-.945
N20001 X50.289 Z-.595
N20002 X51.187 Z-.331
N20003 X52.085 Z-.146
N20004 X52.984 Z-.036
N20005 X53.882 Z0.
N20006 Y-106.225
N20007 X52.984 Z-.036
N20008 X52.085 Z-.146
N20009 X51.187 Z-.331
N20010 X50.289 Z-.595
N20011 X49.391 Z-.945
N20012 X48.942 Z-1.152
N20013 X48.044 Z-1.647
N20014 X47.146 Z-2.258
N20015 X46.697 Z-2.619
N20016 X46.248 Z-3.013
N20017 X45.799 Z-3.462
N20018 X45.35 Z-3.958
N20019 X44.677 Z-4.839
N20020 X44.228 Z-5.547
N20021 X43.779 Z-6.402
N20022 X43.554 Z-6.91
N20023 X43.217 Z-7.838
N20024 X42.952 Z-8.853
N20025 X42.773 Z-9.981
N20026 X42.44 Z-13.521
N20027 X42.184 Z-15.229
N20028 X41.571 Z-18.178
N20029 X40.979 Z-20.339
N20030 X40.491 Z-21.866
N20031 X39.758 Z-23.846
N20032 X39.033 Z-25.551
N20033 X38.554 Z-26.583
N20034 X38.074 Z-27.548
N20035 X37.115 Z-29.312
N20036 X36.156 Z-30.898
N20037 X35.676 Z-31.638
N20038 X34.839 Z-32.859
N20039 X34.002 Z-33.989
N20040 X33.166 Z-35.047
N20041 X32.329 Z-36.043
N20042 X31.408 Z-37.073
N20043 X30.487 Z-38.035
N20044 X29.566 Z-38.941
N20045 X28.645 Z-39.796
N20046 X27.77 Z-40.565
N20047 X26.895 Z-41.292
N20048 X26.02 Z-41.981
N20049 X25.145 Z-42.634
N20050 X24.233 Z-43.278
N20051 X23.321 Z-43.886
N20052 X22.41 Z-44.462
N20053 X20.614 Z-45.507
N20054 X18.845 Z-46.427
N20055 X17.961 Z-46.848
N20056 X16.151 Z-47.634
N20057 X14.342 Z-48.323
N20058 X12.559 Z-48.913
N20059 X10.776 Z-49.418
N20060 X8.958 Z-49.849
N20061 X7.169 Z-50.192
N20062 X5.362 Z-50.46
N20063 X3.592 Z-50.648
N20064 X1.797 Z-50.761
N20065 X0. Z-50.8
N20066 X-1.797 Z-50.761
N20067 X-3.592 Z-50.648
N20068 X-5.362 Z-50.46
N20069 X-7.169 Z-50.192
N20070 X-8.958 Z-49.849
N20071 X-10.776 Z-49.418
N20072 X-12.559 Z-48.913
N20073 X-14.342 Z-48.323
N20074 X-16.151 Z-47.634
N20075 X-17.961 Z-46.848
N20076 X-19.729 Z-45.98
N20077 X-21.498 Z-45.007
N20078 X-22.41 Z-44.462
N20079 X-23.321 Z-43.886
N20080 X-24.233 Z-43.278
N20081 X-25.145 Z-42.634
N20082 X-26.02 Z-41.981
N20083 X-26.895 Z-41.292
N20084 X-27.77 Z-40.565
N20085 X-28.645 Z-39.796
N20086 X-29.566 Z-38.941
N20087 X-30.487 Z-38.035
N20088 X-31.408 Z-37.073
N20089 X-32.329 Z-36.043
N20090 X-33.166 Z-35.047
N20091 X-34.002 Z-33.989
N20092 X-34.839 Z-32.859
N20093 X-35.676 Z-31.638
N20094 X-36.635 Z-30.125
N20095 X-37.595 Z-28.455
N20096 X-38.074 Z-27.548
N20097 X-38.554 Z-26.583
N20098 X-39.033 Z-25.551
N20099 X-39.758 Z-23.846
N20100 X-40.491 Z-21.866
N20101 X-41.346 Z-19.058
N20102 X-41.98 Z-16.328
N20103 X-42.491 Z-13.111
N20104 X-42.798 Z-9.75
N20105 X-43.003 Z-8.619
N20106 X-43.33 Z-7.496
N20107 X-43.554 Z-6.91
N20108 X-44.003 Z-5.954
N20109 X-44.452 Z-5.184
N20110 X-44.901 Z-4.526
N20111 X-45.35 Z-3.958
N20112 X-45.799 Z-3.462
N20113 X-46.248 Z-3.013
N20114 X-46.697 Z-2.619
N20115 X-47.146 Z-2.259
N20116 X-48.044 Z-1.647
N20117 X-48.942 Z-1.152
N20118 X-49.84 Z-.757
N20119 X-50.289 Z-.595
N20120 X-51.187 Z-.331
N20121 X-52.085 Z-.146
N20122 X-52.984 Z-.036
N20123 X-53.882 Z0.
N20124 Y-107.425
N20125 X-52.984 Z-.036
N20126 X-52.085 Z-.146
N20127 X-51.187 Z-.331
N20128 X-50.289 Z-.595
N20129 X-49.84 Z-.757
N20130 X-48.942 Z-1.152
N20131 X-48.044 Z-1.647
N20132 X-47.146 Z-2.259
N20133 X-46.697 Z-2.619
N20134 X-46.248 Z-3.013
N20135 X-45.799 Z-3.462
N20136 X-45.35 Z-3.958
N20137 X-44.901 Z-4.526
N20138 X-44.452 Z-5.184
N20139 X-44.003 Z-5.954
N20140 X-43.554 Z-6.91
N20141 X-43.33 Z-7.496
N20142 X-43.003 Z-8.619
N20143 X-42.798 Z-9.75
N20144 X-42.491 Z-13.111
N20145 X-41.98 Z-16.329
N20146 X-41.346 Z-19.058
N20147 X-40.491 Z-21.866
N20148 X-39.758 Z-23.846
N20149 X-39.033 Z-25.551
N20150 X-38.554 Z-26.583
N20151 X-38.074 Z-27.548
N20152 X-37.595 Z-28.455
N20153 X-36.635 Z-30.125
N20154 X-35.676 Z-31.638
N20155 X-34.839 Z-32.859
N20156 X-34.002 Z-33.989
N20157 X-33.166 Z-35.047
N20158 X-32.329 Z-36.043
N20159 X-31.408 Z-37.073
N20160 X-30.487 Z-38.035
N20161 X-29.566 Z-38.941
N20162 X-28.645 Z-39.796
N20163 X-27.77 Z-40.565
N20164 X-26.895 Z-41.292
N20165 X-26.02 Z-41.981
N20166 X-25.145 Z-42.634
N20167 X-24.233 Z-43.278
N20168 X-23.321 Z-43.886
N20169 X-22.41 Z-44.462
N20170 X-21.498 Z-45.007
N20171 X-19.729 Z-45.98
N20172 X-17.961 Z-46.848
N20173 X-16.151 Z-47.634
N20174 X-14.342 Z-48.323
N20175 X-12.559 Z-48.913
N20176 X-10.776 Z-49.418
N20177 X-8.958 Z-49.849
N20178 X-7.169 Z-50.192
N20179 X-5.362 Z-50.46
N20180 X-3.592 Z-50.648
N20181 X-1.797 Z-50.761
N20182 X0. Z-50.8
N20183 X1.797 Z-50.761
N20184 X3.592 Z-50.648
N20185 X5.362 Z-50.46
N20186 X7.169 Z-50.192
N20187 X8.958 Z-49.849
N20188 X10.776 Z-49.418
N20189 X12.559 Z-48.913
N20190 X14.342 Z-48.323
N20191 X16.151 Z-47.634
N20192 X17.961 Z-46.848
N20193 X18.845 Z-46.427
N20194 X20.614 Z-45.507
N20195 X22.41 Z-44.462
N20196 X23.321 Z-43.886
N20197 X24.233 Z-43.278
N20198 X25.145 Z-42.634
N20199 X26.02 Z-41.981
N20200 X26.895 Z-41.292
N20201 X27.77 Z-40.565
N20202 X28.645 Z-39.796
N20203 X29.566 Z-38.941
N20204 X30.487 Z-38.035
N20205 X31.408 Z-37.073
N20206 X32.329 Z-36.043
N20207 X33.166 Z-35.047
N20208 X34.002 Z-33.989
N20209 X34.839 Z-32.859
N20210 X35.676 Z-31.638
N20211 X36.156 Z-30.898
N20212 X37.115 Z-29.312
N20213 X38.074 Z-27.548
N20214 X38.554 Z-26.583
N20215 X39.033 Z-25.551
N20216 X39.758 Z-23.846
N20217 X40.491 Z-21.866
N20218 X40.979 Z-20.339
N20219 X41.571 Z-18.178
N20220 X42.184 Z-15.229
N20221 X42.44 Z-13.521
N20222 X42.773 Z-9.981
N20223 X42.952 Z-8.853
N20224 X43.217 Z-7.838
N20225 X43.554 Z-6.91
N20226 X43.779 Z-6.402
N20227 X44.228 Z-5.547
N20228 X44.677 Z-4.839
N20229 X45.35 Z-3.958
N20230 X45.799 Z-3.463
N20231 X46.248 Z-3.013
N20232 X46.697 Z-2.619
N20233 X47.146 Z-2.258
N20234 X48.044 Z-1.647
N20235 X48.942 Z-1.152
N20236 X49.391 Z-.945
N20237 X50.289 Z-.595
N20238 X51.187 Z-.331
N20239 X52.085 Z-.146
N20240 X52.984 Z-.036
N20241 X53.882 Z0.
N20242 Y-108.625
N20243 X52.984 Z-.036
N20244 X52.085 Z-.146
N20245 X51.187 Z-.331
N20246 X50.289 Z-.595
N20247 X49.391 Z-.945
N20248 X48.942 Z-1.152
N20249 X48.044 Z-1.647
N20250 X47.146 Z-2.258
N20251 X46.697 Z-2.619
N20252 X46.248 Z-3.013
N20253 X45.799 Z-3.463
N20254 X45.35 Z-3.958
N20255 X44.677 Z-4.839
N20256 X44.228 Z-5.547
N20257 X43.779 Z-6.402
N20258 X43.554 Z-6.91
N20259 X43.217 Z-7.838
N20260 X42.952 Z-8.854
N20261 X42.798 Z-9.75
N20262 X42.44 Z-13.521
N20263 X42.184 Z-15.229
N20264 X41.57 Z-18.178
N20265 X40.979 Z-20.339
N20266 X40.491 Z-21.866
N20267 X39.758 Z-23.846
N20268 X39.033 Z-25.551
N20269 X38.554 Z-26.583
N20270 X38.074 Z-27.548
N20271 X37.115 Z-29.312
N20272 X36.156 Z-30.898
N20273 X35.676 Z-31.638
N20274 X34.839 Z-32.859
N20275 X34.002 Z-33.989
N20276 X33.166 Z-35.047
N20277 X32.329 Z-36.043
N20278 X31.408 Z-37.073
N20279 X30.487 Z-38.035
N20280 X29.566 Z-38.941
N20281 X28.645 Z-39.796
N20282 X27.77 Z-40.565
N20283 X26.895 Z-41.292
N20284 X26.02 Z-41.981
N20285 X25.145 Z-42.634
N20286 X24.233 Z-43.278
N20287 X23.321 Z-43.886
N20288 X22.41 Z-44.462
N20289 X20.614 Z-45.507
N20290 X18.845 Z-46.427
N20291 X17.961 Z-46.848
N20292 X16.151 Z-47.634
N20293 X14.342 Z-48.323
N20294 X12.559 Z-48.913
N20295 X10.776 Z-49.418
N20296 X8.958 Z-49.849
N20297 X7.169 Z-50.192
N20298 X5.362 Z-50.46
N20299 X3.592 Z-50.648
N20300 X1.797 Z-50.761
N20301 X0. Z-50.8
N20302 X-1.797 Z-50.761
N20303 X-3.592 Z-50.648
N20304 X-5.362 Z-50.46
N20305 X-7.169 Z-50.192
N20306 X-8.958 Z-49.849
N20307 X-10.776 Z-49.418
N20308 X-12.559 Z-48.913
N20309 X-14.342 Z-48.323
N20310 X-16.151 Z-47.634
N20311 X-17.961 Z-46.848
N20312 X-19.729 Z-45.98
N20313 X-21.498 Z-45.007
N20314 X-22.41 Z-44.462
N20315 X-23.321 Z-43.886
N20316 X-24.233 Z-43.278
N20317 X-25.145 Z-42.634
N20318 X-26.02 Z-41.981
N20319 X-26.895 Z-41.292
N20320 X-27.77 Z-40.565
N20321 X-28.645 Z-39.796
N20322 X-29.566 Z-38.941
N20323 X-30.487 Z-38.035
N20324 X-31.408 Z-37.073
N20325 X-32.329 Z-36.043
N20326 X-33.166 Z-35.047
N20327 X-34.002 Z-33.989
N20328 X-34.839 Z-32.859
N20329 X-35.676 Z-31.638
N20330 X-36.635 Z-30.125
N20331 X-37.595 Z-28.455
N20332 X-38.074 Z-27.548
N20333 X-38.554 Z-26.583
N20334 X-39.033 Z-25.551
N20335 X-39.758 Z-23.846
N20336 X-40.491 Z-21.866
N20337 X-41.346 Z-19.058
N20338 X-41.98 Z-16.329
N20339 X-42.491 Z-13.112
N20340 X-42.798 Z-9.75
N20341 X-43.003 Z-8.619
N20342 X-43.33 Z-7.496
N20343 X-43.554 Z-6.91
N20344 X-43.779 Z-6.402
N20345 X-44.228 Z-5.547
N20346 X-44.677 Z-4.839
N20347 X-45.35 Z-3.958
N20348 X-45.799 Z-3.463
N20349 X-46.248 Z-3.013
N20350 X-46.697 Z-2.619
N20351 X-47.146 Z-2.258
N20352 X-48.044 Z-1.647
N20353 X-48.942 Z-1.152
N20354 X-49.84 Z-.757
N20355 X-50.289 Z-.595
N20356 X-51.187 Z-.331
N20357 X-52.085 Z-.146
N20358 X-52.984 Z-.036
N20359 X-53.882 Z0.
N20360 Y-109.825
N20361 X-52.984 Z-.036
N20362 X-52.085 Z-.146
N20363 X-51.187 Z-.331
N20364 X-50.289 Z-.595
N20365 X-49.84 Z-.757
N20366 X-48.942 Z-1.152
N20367 X-48.044 Z-1.647
N20368 X-47.146 Z-2.258
N20369 X-46.697 Z-2.619
N20370 X-46.248 Z-3.013
N20371 X-45.799 Z-3.463
N20372 X-45.35 Z-3.958
N20373 X-44.677 Z-4.839
N20374 X-44.228 Z-5.547
N20375 X-43.779 Z-6.402
N20376 X-43.554 Z-6.91
N20377 X-43.33 Z-7.496
N20378 X-43.003 Z-8.619
N20379 X-42.798 Z-9.75
N20380 X-42.491 Z-13.112
N20381 X-41.98 Z-16.329
N20382 X-41.346 Z-19.058
N20383 X-40.491 Z-21.866
N20384 X-39.758 Z-23.846
N20385 X-39.033 Z-25.551
N20386 X-38.554 Z-26.583
N20387 X-38.074 Z-27.548
N20388 X-37.595 Z-28.455
N20389 X-36.635 Z-30.125
N20390 X-35.676 Z-31.638
N20391 X-34.839 Z-32.859
N20392 X-34.002 Z-33.989
N20393 X-33.166 Z-35.047
N20394 X-32.329 Z-36.043
N20395 X-31.408 Z-37.073
N20396 X-30.487 Z-38.035
N20397 X-29.566 Z-38.941
N20398 X-28.645 Z-39.796
N20399 X-27.77 Z-40.565
N20400 X-26.895 Z-41.292
N20401 X-26.02 Z-41.981
N20402 X-25.145 Z-42.634
N20403 X-24.233 Z-43.278
N20404 X-23.321 Z-43.886
N20405 X-22.41 Z-44.462
N20406 X-21.498 Z-45.007
N20407 X-19.729 Z-45.98
N20408 X-17.961 Z-46.848
N20409 X-16.151 Z-47.634
N20410 X-14.342 Z-48.323
N20411 X-12.559 Z-48.913
N20412 X-10.776 Z-49.418
N20413 X-8.958 Z-49.849
N20414 X-7.169 Z-50.192
N20415 X-5.362 Z-50.46
N20416 X-3.592 Z-50.648
N20417 X-1.797 Z-50.761
N20418 X0. Z-50.8
N20419 X1.797 Z-50.761
N20420 X3.592 Z-50.648
N20421 X5.362 Z-50.46
N20422 X7.169 Z-50.192
N20423 X8.958 Z-49.849
N20424 X10.776 Z-49.418
N20425 X12.559 Z-48.913
N20426 X14.342 Z-48.323
N20427 X16.151 Z-47.634
N20428 X17.961 Z-46.848
N20429 X18.845 Z-46.427
N20430 X20.614 Z-45.507
N20431 X22.41 Z-44.462
N20432 X23.321 Z-43.886
N20433 X24.233 Z-43.278
N20434 X25.145 Z-42.634
N20435 X26.02 Z-41.981
N20436 X26.895 Z-41.292
N20437 X27.77 Z-40.565
N20438 X28.645 Z-39.796
N20439 X29.566 Z-38.941
N20440 X30.487 Z-38.035
N20441 X31.408 Z-37.073
N20442 X32.329 Z-36.043
N20443 X33.166 Z-35.047
N20444 X34.002 Z-33.989
N20445 X34.839 Z-32.859
N20446 X35.676 Z-31.638
N20447 X36.156 Z-30.898
N20448 X37.115 Z-29.312
N20449 X38.074 Z-27.548
N20450 X38.554 Z-26.583
N20451 X39.033 Z-25.551
N20452 X39.758 Z-23.846
N20453 X40.491 Z-21.866
N20454 X40.979 Z-20.339
N20455 X41.57 Z-18.178
N20456 X42.184 Z-15.229
N20457 X42.44 Z-13.521
N20458 X42.798 Z-9.75
N20459 X42.952 Z-8.854
N20460 X43.217 Z-7.838
N20461 X43.554 Z-6.91
N20462 X43.779 Z-6.402
N20463 X44.228 Z-5.547
N20464 X44.677 Z-4.839
N20465 X45.35 Z-3.958
N20466 X45.799 Z-3.463
N20467 X46.248 Z-3.013
N20468 X46.697 Z-2.619
N20469 X47.146 Z-2.258
N20470 X48.044 Z-1.646
N20471 X48.942 Z-1.151
N20472 X49.391 Z-.945
N20473 X50.289 Z-.595
N20474 X51.187 Z-.331
N20475 X52.085 Z-.146
N20476 X52.984 Z-.036
N20477 X53.882 Z0.
N20478 Y-111.025
N20479 X52.984 Z-.036
N20480 X52.085 Z-.146
N20481 X51.187 Z-.331
N20482 X50.289 Z-.595
N20483 X49.391 Z-.945
N20484 X48.942 Z-1.151
N20485 X48.044 Z-1.646
N20486 X47.146 Z-2.258
N20487 X46.248 Z-3.013
N20488 X45.799 Z-3.463
N20489 X45.35 Z-3.958
N20490 X44.677 Z-4.839
N20491 X44.228 Z-5.547
N20492 X43.779 Z-6.402
N20493 X43.554 Z-6.91
N20494 X43.217 Z-7.838
N20495 X42.952 Z-8.854
N20496 X42.798 Z-9.75
N20497 X42.44 Z-13.521
N20498 X42.184 Z-15.229
N20499 X41.57 Z-18.178
N20500 X40.979 Z-20.339
N20501 X40.491 Z-21.866
N20502 X39.758 Z-23.846
N20503 X39.033 Z-25.551
N20504 X38.554 Z-26.583
N20505 X38.074 Z-27.548
N20506 X37.115 Z-29.312
N20507 X36.156 Z-30.898
N20508 X35.676 Z-31.638
N20509 X34.839 Z-32.859
N20510 X34.002 Z-33.989
N20511 X33.166 Z-35.047
N20512 X32.329 Z-36.043
N20513 X31.408 Z-37.073
N20514 X30.487 Z-38.035
N20515 X29.566 Z-38.941
N20516 X28.645 Z-39.796
N20517 X27.77 Z-40.565
N20518 X26.895 Z-41.292
N20519 X26.02 Z-41.981
N20520 X25.145 Z-42.634
N20521 X24.233 Z-43.278
N20522 X23.321 Z-43.886
N20523 X22.41 Z-44.462
N20524 X20.614 Z-45.507
N20525 X18.845 Z-46.427
N20526 X17.961 Z-46.848
N20527 X16.151 Z-47.634
N20528 X14.342 Z-48.323
N20529 X12.559 Z-48.913
N20530 X10.776 Z-49.418
N20531 X8.958 Z-49.849
N20532 X7.169 Z-50.192
N20533 X5.362 Z-50.46
N20534 X3.592 Z-50.648
N20535 X1.797 Z-50.761
N20536 X0. Z-50.8
N20537 X-1.797 Z-50.761
N20538 X-3.592 Z-50.648
N20539 X-5.362 Z-50.46
N20540 X-7.169 Z-50.192
N20541 X-8.958 Z-49.849
N20542 X-10.776 Z-49.418
N20543 X-12.559 Z-48.913
N20544 X-14.342 Z-48.323
N20545 X-16.151 Z-47.634
N20546 X-17.961 Z-46.848
N20547 X-19.729 Z-45.98
N20548 X-21.498 Z-45.007
N20549 X-22.41 Z-44.462
N20550 X-23.321 Z-43.886
N20551 X-24.233 Z-43.278
N20552 X-25.145 Z-42.634
N20553 X-26.02 Z-41.981
N20554 X-26.895 Z-41.292
N20555 X-27.77 Z-40.565
N20556 X-28.645 Z-39.796
N20557 X-29.566 Z-38.941
N20558 X-30.487 Z-38.035
N20559 X-31.408 Z-37.073
N20560 X-32.329 Z-36.043
N20561 X-33.166 Z-35.047
N20562 X-34.002 Z-33.989
N20563 X-34.839 Z-32.859
N20564 X-35.676 Z-31.638
N20565 X-36.635 Z-30.125
N20566 X-37.595 Z-28.455
N20567 X-38.074 Z-27.548
N20568 X-38.554 Z-26.583
N20569 X-39.033 Z-25.551
N20570 X-39.758 Z-23.846
N20571 X-40.491 Z-21.866
N20572 X-41.346 Z-19.058
N20573 X-41.98 Z-16.329
N20574 X-42.491 Z-13.112
N20575 X-42.798 Z-9.75
N20576 X-43.003 Z-8.619
N20577 X-43.33 Z-7.496
N20578 X-43.554 Z-6.91
N20579 X-43.779 Z-6.402
N20580 X-44.228 Z-5.547
N20581 X-44.677 Z-4.839
N20582 X-45.35 Z-3.958
N20583 X-45.799 Z-3.463
N20584 X-46.248 Z-3.013
N20585 X-46.697 Z-2.619
N20586 X-47.146 Z-2.258
N20587 X-48.044 Z-1.646
N20588 X-48.942 Z-1.151
N20589 X-49.84 Z-.757
N20590 X-50.289 Z-.595
N20591 X-51.187 Z-.331
N20592 X-52.085 Z-.146
N20593 X-52.984 Z-.036
N20594 X-53.882 Z0.
N20595 Y-112.225
N20596 X-52.984 Z-.036
N20597 X-52.085 Z-.146
N20598 X-51.187 Z-.331
N20599 X-50.289 Z-.595
N20600 X-49.84 Z-.757
N20601 X-48.942 Z-1.151
N20602 X-48.044 Z-1.646
N20603 X-47.146 Z-2.258
N20604 X-46.248 Z-3.013
N20605 X-45.799 Z-3.463
N20606 X-45.35 Z-3.958
N20607 X-44.677 Z-4.839
N20608 X-44.228 Z-5.547
N20609 X-43.779 Z-6.402
N20610 X-43.554 Z-6.91
N20611 X-43.33 Z-7.496
N20612 X-43.003 Z-8.619
N20613 X-42.798 Z-9.75
N20614 X-42.491 Z-13.112
N20615 X-41.98 Z-16.329
N20616 X-41.346 Z-19.058
N20617 X-40.491 Z-21.866
N20618 X-39.758 Z-23.846
N20619 X-39.033 Z-25.551
N20620 X-38.554 Z-26.583
N20621 X-38.074 Z-27.548
N20622 X-37.595 Z-28.455
N20623 X-36.635 Z-30.125
N20624 X-35.676 Z-31.638
N20625 X-34.839 Z-32.859
N20626 X-34.002 Z-33.989
N20627 X-33.166 Z-35.047
N20628 X-32.329 Z-36.043
N20629 X-31.408 Z-37.073
N20630 X-30.487 Z-38.035
N20631 X-29.566 Z-38.941
N20632 X-28.645 Z-39.796
N20633 X-27.77 Z-40.565
N20634 X-26.895 Z-41.292
N20635 X-26.02 Z-41.981
N20636 X-25.145 Z-42.634
N20637 X-24.233 Z-43.278
N20638 X-23.321 Z-43.886
N20639 X-22.41 Z-44.462
N20640 X-21.498 Z-45.007
N20641 X-19.729 Z-45.98
N20642 X-17.961 Z-46.848
N20643 X-16.151 Z-47.634
N20644 X-14.342 Z-48.323
N20645 X-12.559 Z-48.913
N20646 X-10.776 Z-49.418
N20647 X-8.958 Z-49.849
N20648 X-7.169 Z-50.192
N20649 X-5.362 Z-50.46
N20650 X-3.592 Z-50.648
N20651 X-1.797 Z-50.761
N20652 X0. Z-50.8
N20653 X1.797 Z-50.761
N20654 X3.592 Z-50.648
N20655 X5.362 Z-50.46
N20656 X7.169 Z-50.192
N20657 X8.958 Z-49.849
N20658 X10.776 Z-49.418
N20659 X12.559 Z-48.913
N20660 X14.342 Z-48.323
N20661 X16.151 Z-47.634
N20662 X17.961 Z-46.848
N20663 X18.845 Z-46.427
N20664 X20.614 Z-45.507
N20665 X22.41 Z-44.462
N20666 X23.321 Z-43.886
N20667 X24.233 Z-43.278
N20668 X25.145 Z-42.634
N20669 X26.02 Z-41.981
N20670 X26.895 Z-41.292
N20671 X27.77 Z-40.565
N20672 X28.645 Z-39.796
N20673 X29.566 Z-38.941
N20674 X30.487 Z-38.035
N20675 X31.408 Z-37.073
N20676 X32.329 Z-36.043
N20677 X33.166 Z-35.047
N20678 X34.002 Z-33.989
N20679 X34.839 Z-32.859
N20680 X35.676 Z-31.638
N20681 X36.156 Z-30.898
N20682 X37.115 Z-29.312
N20683 X38.074 Z-27.548
N20684 X38.554 Z-26.583
N20685 X39.033 Z-25.551
N20686 X39.758 Z-23.846
N20687 X40.491 Z-21.866
N20688 X40.979 Z-20.339
N20689 X41.57 Z-18.178
N20690 X42.184 Z-15.229
N20691 X42.44 Z-13.521
N20692 X42.798 Z-9.75
N20693 X42.952 Z-8.854
N20694 X43.217 Z-7.838
N20695 X43.554 Z-6.91
N20696 X43.779 Z-6.402
N20697 X44.228 Z-5.547
N20698 X44.677 Z-4.839
N20699 X45.35 Z-3.958
N20700 X45.799 Z-3.463
N20701 X46.248 Z-3.013
N20702 X47.146 Z-2.258
N20703 X48.044 Z-1.646
N20704 X48.942 Z-1.151
N20705 X49.391 Z-.945
N20706 X50.289 Z-.595
N20707 X51.187 Z-.331
N20708 X52.085 Z-.146
N20709 X52.984 Z-.036
N20710 X53.882 Z0.
N20711 Y-113.425
N20712 X52.984 Z-.036
N20713 X52.085 Z-.146
N20714 X51.187 Z-.331
N20715 X50.289 Z-.595
N20716 X49.391 Z-.945
N20717 X48.942 Z-1.151
N20718 X48.044 Z-1.646
N20719 X47.146 Z-2.258
N20720 X46.248 Z-3.013
N20721 X45.799 Z-3.463
N20722 X45.35 Z-3.958
N20723 X44.677 Z-4.839
N20724 X44.228 Z-5.547
N20725 X43.779 Z-6.402
N20726 X43.554 Z-6.91
N20727 X43.217 Z-7.838
N20728 X42.952 Z-8.854
N20729 X42.798 Z-9.751
N20730 X42.44 Z-13.521
N20731 X42.184 Z-15.229
N20732 X41.57 Z-18.179
N20733 X40.979 Z-20.339
N20734 X40.491 Z-21.866
N20735 X39.758 Z-23.846
N20736 X39.033 Z-25.551
N20737 X38.554 Z-26.583
N20738 X38.074 Z-27.548
N20739 X37.115 Z-29.312
N20740 X36.156 Z-30.898
N20741 X35.676 Z-31.638
N20742 X34.839 Z-32.859
N20743 X34.002 Z-33.989
N20744 X33.166 Z-35.047
N20745 X32.329 Z-36.043
N20746 X31.408 Z-37.073
N20747 X30.487 Z-38.035
N20748 X29.566 Z-38.941
N20749 X28.645 Z-39.796
N20750 X27.77 Z-40.565
N20751 X26.895 Z-41.292
N20752 X26.02 Z-41.981
N20753 X25.145 Z-42.634
N20754 X24.233 Z-43.278
N20755 X23.321 Z-43.886
N20756 X22.41 Z-44.462
N20757 X20.614 Z-45.507
N20758 X18.845 Z-46.427
N20759 X17.961 Z-46.848
N20760 X16.151 Z-47.634
N20761 X14.342 Z-48.323
N20762 X12.559 Z-48.913
N20763 X10.776 Z-49.418
N20764 X8.958 Z-49.849
N20765 X7.169 Z-50.192
N20766 X5.362 Z-50.46
N20767 X3.592 Z-50.648
N20768 X1.797 Z-50.761
N20769 X0. Z-50.8
N20770 X-1.797 Z-50.761
N20771 X-3.592 Z-50.648
N20772 X-5.362 Z-50.46
N20773 X-7.169 Z-50.192
N20774 X-8.958 Z-49.849
N20775 X-10.776 Z-49.418
N20776 X-12.559 Z-48.913
N20777 X-14.342 Z-48.323
N20778 X-16.151 Z-47.634
N20779 X-17.961 Z-46.848
N20780 X-19.729 Z-45.98
N20781 X-21.498 Z-45.007
N20782 X-22.41 Z-44.462
N20783 X-23.321 Z-43.886
N20784 X-24.233 Z-43.278
N20785 X-25.145 Z-42.634
N20786 X-26.02 Z-41.981
N20787 X-26.895 Z-41.292
N20788 X-27.77 Z-40.565
N20789 X-28.645 Z-39.796
N20790 X-29.566 Z-38.941
N20791 X-30.487 Z-38.035
N20792 X-31.408 Z-37.073
N20793 X-32.329 Z-36.043
N20794 X-33.166 Z-35.047
N20795 X-34.002 Z-33.989
N20796 X-34.839 Z-32.859
N20797 X-35.676 Z-31.638
N20798 X-36.635 Z-30.125
N20799 X-37.595 Z-28.455
N20800 X-38.074 Z-27.548
N20801 X-38.554 Z-26.583
N20802 X-39.033 Z-25.551
N20803 X-39.758 Z-23.846
N20804 X-40.491 Z-21.866
N20805 X-41.346 Z-19.058
N20806 X-41.98 Z-16.329
N20807 X-42.491 Z-13.112
N20808 X-42.798 Z-9.751
N20809 X-43.003 Z-8.619
N20810 X-43.33 Z-7.496
N20811 X-43.554 Z-6.91
N20812 X-43.779 Z-6.402
N20813 X-44.228 Z-5.547
N20814 X-44.677 Z-4.839
N20815 X-45.35 Z-3.958
N20816 X-45.799 Z-3.463
N20817 X-46.248 Z-3.013
N20818 X-47.146 Z-2.258
N20819 X-48.044 Z-1.646
N20820 X-48.942 Z-1.151
N20821 X-49.84 Z-.757
N20822 X-50.289 Z-.596
N20823 X-51.187 Z-.331
N20824 X-52.085 Z-.146
N20825 X-52.984 Z-.036
N20826 X-53.882 Z0.
N20827 Y-114.625
N20828 X-52.984 Z-.036
N20829 X-52.085 Z-.146
N20830 X-51.187 Z-.331
N20831 X-50.289 Z-.596
N20832 X-49.84 Z-.757
N20833 X-48.942 Z-1.151
N20834 X-48.044 Z-1.646
N20835 X-47.146 Z-2.258
N20836 X-46.248 Z-3.013
N20837 X-45.799 Z-3.463
N20838 X-45.35 Z-3.958
N20839 X-44.677 Z-4.839
N20840 X-44.228 Z-5.547
N20841 X-43.779 Z-6.402
N20842 X-43.554 Z-6.91
N20843 X-43.33 Z-7.496
N20844 X-43.003 Z-8.619
N20845 X-42.798 Z-9.751
N20846 X-42.491 Z-13.112
N20847 X-41.98 Z-16.329
N20848 X-41.346 Z-19.058
N20849 X-40.491 Z-21.866
N20850 X-39.758 Z-23.846
N20851 X-39.033 Z-25.551
N20852 X-38.554 Z-26.583
N20853 X-38.074 Z-27.548
N20854 X-37.595 Z-28.455
N20855 X-36.635 Z-30.125
N20856 X-35.676 Z-31.638
N20857 X-34.839 Z-32.859
N20858 X-34.002 Z-33.989
N20859 X-33.166 Z-35.047
N20860 X-32.329 Z-36.043
N20861 X-31.408 Z-37.073
N20862 X-30.487 Z-38.035
N20863 X-29.566 Z-38.941
N20864 X-28.645 Z-39.796
N20865 X-27.77 Z-40.565
N20866 X-26.895 Z-41.292
N20867 X-26.02 Z-41.981
N20868 X-25.145 Z-42.634
N20869 X-24.233 Z-43.278
N20870 X-23.321 Z-43.886
N20871 X-22.41 Z-44.462
N20872 X-21.498 Z-45.007
N20873 X-19.729 Z-45.98
N20874 X-17.961 Z-46.848
N20875 X-16.151 Z-47.634
N20876 X-14.342 Z-48.323
N20877 X-12.559 Z-48.913
N20878 X-10.776 Z-49.418
N20879 X-8.958 Z-49.849
N20880 X-7.169 Z-50.192
N20881 X-5.362 Z-50.46
N20882 X-3.592 Z-50.648
N20883 X-1.797 Z-50.761
N20884 X0. Z-50.8
N20885 X1.797 Z-50.761
N20886 X3.592 Z-50.648
N20887 X5.362 Z-50.46
N20888 X7.169 Z-50.192
N20889 X8.958 Z-49.849
N20890 X10.776 Z-49.418
N20891 X12.559 Z-48.913
N20892 X14.342 Z-48.323
N20893 X16.151 Z-47.634
N20894 X17.961 Z-46.848
N20895 X18.845 Z-46.427
N20896 X20.614 Z-45.507
N20897 X22.41 Z-44.462
N20898 X23.321 Z-43.886
N20899 X24.233 Z-43.278
N20900 X25.145 Z-42.634
N20901 X26.02 Z-41.981
N20902 X26.895 Z-41.292
N20903 X27.77 Z-40.565
N20904 X28.645 Z-39.796
N20905 X29.566 Z-38.941
N20906 X30.487 Z-38.035
N20907 X31.408 Z-37.073
N20908 X32.329 Z-36.043
N20909 X33.166 Z-35.047
N20910 X34.002 Z-33.989
N20911 X34.839 Z-32.859
N20912 X35.676 Z-31.638
N20913 X36.156 Z-30.898
N20914 X37.115 Z-29.312
N20915 X38.074 Z-27.548
N20916 X38.554 Z-26.583
N20917 X39.033 Z-25.551
N20918 X39.758 Z-23.846
N20919 X40.491 Z-21.866
N20920 X40.979 Z-20.339
N20921 X41.57 Z-18.179
N20922 X42.184 Z-15.229
N20923 X42.44 Z-13.521
N20924 X42.798 Z-9.751
N20925 X42.952 Z-8.854
N20926 X43.217 Z-7.838
N20927 X43.554 Z-6.91
N20928 X43.779 Z-6.402
N20929 X44.228 Z-5.547
N20930 X44.677 Z-4.839
N20931 X45.35 Z-3.958
N20932 X45.799 Z-3.463
N20933 X46.248 Z-3.013
N20934 X47.146 Z-2.258
N20935 X48.044 Z-1.646
N20936 X48.942 Z-1.151
N20937 X49.391 Z-.945
N20938 X50.289 Z-.596
N20939 X51.187 Z-.331
N20940 X52.085 Z-.146
N20941 X52.984 Z-.036
N20942 X53.882 Z0.
N20943 Y-115.825
N20944 X52.984 Z-.036
N20945 X52.085 Z-.146
N20946 X51.187 Z-.331
N20947 X50.289 Z-.596
N20948 X49.391 Z-.945
N20949 X48.942 Z-1.151
N20950 X48.044 Z-1.646
N20951 X47.146 Z-2.258
N20952 X46.248 Z-3.013
N20953 X45.799 Z-3.463
N20954 X45.35 Z-3.958
N20955 X44.677 Z-4.839
N20956 X44.228 Z-5.547
N20957 X43.779 Z-6.401
N20958 X43.554 Z-6.91
N20959 X43.217 Z-7.838
N20960 X42.952 Z-8.854
N20961 X42.798 Z-9.751
N20962 X42.44 Z-13.521
N20963 X42.184 Z-15.229
N20964 X41.57 Z-18.179
N20965 X40.979 Z-20.339
N20966 X40.491 Z-21.866
N20967 X39.758 Z-23.846
N20968 X39.033 Z-25.551
N20969 X38.554 Z-26.583
N20970 X38.074 Z-27.548
N20971 X37.115 Z-29.312
N20972 X36.156 Z-30.898
N20973 X35.676 Z-31.638
N20974 X34.839 Z-32.859
N20975 X34.002 Z-33.989
N20976 X33.166 Z-35.047
N20977 X32.329 Z-36.043
N20978 X31.408 Z-37.073
N20979 X30.487 Z-38.035
N20980 X29.566 Z-38.941
N20981 X28.645 Z-39.796
N20982 X27.77 Z-40.565
N20983 X26.895 Z-41.292
N20984 X26.02 Z-41.981
N20985 X25.145 Z-42.634
N20986 X24.233 Z-43.278
N20987 X23.321 Z-43.886
N20988 X22.41 Z-44.462
N20989 X20.614 Z-45.507
N20990 X18.845 Z-46.427
N20991 X17.961 Z-46.848
N20992 X16.151 Z-47.634
N20993 X14.342 Z-48.323
N20994 X12.559 Z-48.913
N20995 X10.776 Z-49.418
N20996 X8.958 Z-49.849
N20997 X7.169 Z-50.192
N20998 X5.362 Z-50.46
N20999 X3.592 Z-50.648
N21000 X1.797 Z-50.761
N21001 X0. Z-50.8
N21002 X-1.797 Z-50.761
N21003 X-3.592 Z-50.648
N21004 X-5.362 Z-50.46
N21005 X-7.169 Z-50.192
N21006 X-8.958 Z-49.849
N21007 X-10.776 Z-49.418
N21008 X-12.559 Z-48.913
N21009 X-14.342 Z-48.323
N21010 X-16.151 Z-47.634
N21011 X-17.961 Z-46.848
N21012 X-19.729 Z-45.98
N21013 X-21.498 Z-45.007
N21014 X-22.41 Z-44.462
N21015 X-23.321 Z-43.886
N21016 X-24.233 Z-43.278
N21017 X-25.145 Z-42.634
N21018 X-26.02 Z-41.981
N21019 X-26.895 Z-41.292
N21020 X-27.77 Z-40.565
N21021 X-28.645 Z-39.796
N21022 X-29.566 Z-38.941
N21023 X-30.487 Z-38.035
N21024 X-31.408 Z-37.073
N21025 X-32.329 Z-36.043
N21026 X-33.166 Z-35.047
N21027 X-34.002 Z-33.989
N21028 X-34.839 Z-32.859
N21029 X-35.676 Z-31.638
N21030 X-36.635 Z-30.125
N21031 X-37.595 Z-28.455
N21032 X-38.074 Z-27.548
N21033 X-38.554 Z-26.583
N21034 X-39.033 Z-25.551
N21035 X-39.758 Z-23.846
N21036 X-40.491 Z-21.866
N21037 X-41.346 Z-19.058
N21038 X-41.98 Z-16.329
N21039 X-42.491 Z-13.112
N21040 X-42.798 Z-9.751
N21041 X-43.003 Z-8.619
N21042 X-43.33 Z-7.496
N21043 X-43.554 Z-6.91
N21044 X-43.779 Z-6.401
N21045 X-44.228 Z-5.547
N21046 X-44.677 Z-4.839
N21047 X-45.35 Z-3.958
N21048 X-45.799 Z-3.463
N21049 X-46.248 Z-3.013
N21050 X-47.146 Z-2.258
N21051 X-48.044 Z-1.646
N21052 X-48.942 Z-1.151
N21053 X-49.84 Z-.757
N21054 X-50.289 Z-.596
N21055 X-51.187 Z-.331
N21056 X-52.085 Z-.146
N21057 X-52.984 Z-.036
N21058 X-53.882 Z0.
N21059 Y-117.025
N21060 X-52.984 Z-.036
N21061 X-52.085 Z-.146
N21062 X-51.187 Z-.331
N21063 X-50.289 Z-.596
N21064 X-49.84 Z-.757
N21065 X-48.942 Z-1.151
N21066 X-48.044 Z-1.646
N21067 X-47.146 Z-2.258
N21068 X-46.248 Z-3.013
N21069 X-45.799 Z-3.463
N21070 X-45.35 Z-3.958
N21071 X-44.677 Z-4.839
N21072 X-44.228 Z-5.547
N21073 X-43.779 Z-6.401
N21074 X-43.554 Z-6.91
N21075 X-43.33 Z-7.496
N21076 X-43.003 Z-8.619
N21077 X-42.798 Z-9.751
N21078 X-42.491 Z-13.112
N21079 X-41.98 Z-16.329
N21080 X-41.346 Z-19.058
N21081 X-40.491 Z-21.866
N21082 X-39.758 Z-23.846
N21083 X-39.033 Z-25.551
N21084 X-38.554 Z-26.583
N21085 X-38.074 Z-27.548
N21086 X-37.595 Z-28.455
N21087 X-36.635 Z-30.125
N21088 X-35.676 Z-31.638
N21089 X-34.839 Z-32.859
N21090 X-34.002 Z-33.989
N21091 X-33.166 Z-35.047
N21092 X-32.329 Z-36.043
N21093 X-31.408 Z-37.073
N21094 X-30.487 Z-38.035
N21095 X-29.566 Z-38.941
N21096 X-28.645 Z-39.796
N21097 X-27.77 Z-40.565
N21098 X-26.895 Z-41.292
N21099 X-26.02 Z-41.981
N21100 X-25.145 Z-42.634
N21101 X-24.233 Z-43.278
N21102 X-23.321 Z-43.886
N21103 X-22.41 Z-44.462
N21104 X-21.498 Z-45.007
N21105 X-19.729 Z-45.98
N21106 X-17.961 Z-46.848
N21107 X-16.151 Z-47.634
N21108 X-14.342 Z-48.323
N21109 X-12.559 Z-48.913
N21110 X-10.776 Z-49.418
N21111 X-8.958 Z-49.849
N21112 X-7.169 Z-50.192
N21113 X-5.362 Z-50.46
N21114 X-3.592 Z-50.648
N21115 X-1.797 Z-50.761
N21116 X0. Z-50.8
N21117 X1.797 Z-50.761
N21118 X3.592 Z-50.648
N21119 X5.362 Z-50.46
N21120 X7.169 Z-50.192
N21121 X8.958 Z-49.849
N21122 X10.776 Z-49.418
N21123 X12.559 Z-48.913
N21124 X14.342 Z-48.323
N21125 X16.151 Z-47.634
N21126 X17.961 Z-46.848
N21127 X18.845 Z-46.427
N21128 X20.614 Z-45.507
N21129 X22.41 Z-44.462
N21130 X23.321 Z-43.886
N21131 X24.233 Z-43.278
N21132 X25.145 Z-42.634
N21133 X26.02 Z-41.981
N21134 X26.895 Z-41.292
N21135 X27.77 Z-40.565
N21136 X28.645 Z-39.796
N21137 X29.566 Z-38.941
N21138 X30.487 Z-38.035
N21139 X31.408 Z-37.073
N21140 X32.329 Z-36.043
N21141 X33.166 Z-35.047
N21142 X34.002 Z-33.989
N21143 X34.839 Z-32.859
N21144 X35.676 Z-31.638
N21145 X36.156 Z-30.898
N21146 X37.115 Z-29.312
N21147 X38.074 Z-27.548
N21148 X38.554 Z-26.583
N21149 X39.033 Z-25.551
N21150 X39.758 Z-23.846
N21151 X40.491 Z-21.866
N21152 X40.979 Z-20.339
N21153 X41.57 Z-18.179
N21154 X42.184 Z-15.229
N21155 X42.44 Z-13.521
N21156 X42.798 Z-9.751
N21157 X42.952 Z-8.854
N21158 X43.217 Z-7.838
N21159 X43.554 Z-6.91
N21160 X43.779 Z-6.401
N21161 X44.228 Z-5.547
N21162 X44.677 Z-4.839
N21163 X45.35 Z-3.958
N21164 X45.799 Z-3.463
N21165 X46.248 Z-3.013
N21166 X47.146 Z-2.258
N21167 X48.044 Z-1.646
N21168 X48.942 Z-1.151
N21169 X49.84 Z-.757
N21170 X50.289 Z-.596
N21171 X51.187 Z-.331
N21172 X52.085 Z-.146
N21173 X52.984 Z-.036
N21174 X53.882 Z0.
N21175 Y-118.225
N21176 X52.984 Z-.036
N21177 X52.085 Z-.146
N21178 X51.187 Z-.331
N21179 X50.289 Z-.596
N21180 X49.84 Z-.757
N21181 X48.942 Z-1.151
N21182 X48.044 Z-1.646
N21183 X47.146 Z-2.258
N21184 X46.248 Z-3.013
N21185 X45.799 Z-3.463
N21186 X45.35 Z-3.958
N21187 X44.677 Z-4.839
N21188 X44.228 Z-5.547
N21189 X43.779 Z-6.401
N21190 X43.554 Z-6.911
N21191 X43.217 Z-7.839
N21192 X42.952 Z-8.854
N21193 X42.798 Z-9.751
N21194 X42.44 Z-13.521
N21195 X42.184 Z-15.23
N21196 X41.57 Z-18.179
N21197 X40.979 Z-20.339
N21198 X40.491 Z-21.866
N21199 X39.757 Z-23.846
N21200 X39.033 Z-25.551
N21201 X38.554 Z-26.583
N21202 X38.074 Z-27.548
N21203 X37.115 Z-29.312
N21204 X36.156 Z-30.898
N21205 X35.676 Z-31.638
N21206 X34.839 Z-32.859
N21207 X34.002 Z-33.989
N21208 X33.166 Z-35.047
N21209 X32.329 Z-36.043
N21210 X31.408 Z-37.073
N21211 X30.487 Z-38.035
N21212 X29.566 Z-38.941
N21213 X28.645 Z-39.796
N21214 X27.77 Z-40.565
N21215 X26.895 Z-41.292
N21216 X26.02 Z-41.981
N21217 X25.145 Z-42.634
N21218 X24.233 Z-43.278
N21219 X23.321 Z-43.886
N21220 X22.41 Z-44.462
N21221 X20.614 Z-45.507
N21222 X18.845 Z-46.427
N21223 X17.961 Z-46.848
N21224 X16.151 Z-47.634
N21225 X14.342 Z-48.323
N21226 X12.559 Z-48.913
N21227 X10.776 Z-49.418
N21228 X8.958 Z-49.849
N21229 X7.169 Z-50.192
N21230 X5.362 Z-50.46
N21231 X3.592 Z-50.648
N21232 X1.797 Z-50.761
N21233 X0. Z-50.8
N21234 X-1.797 Z-50.761
N21235 X-3.592 Z-50.648
N21236 X-5.362 Z-50.46
N21237 X-7.169 Z-50.192
N21238 X-8.958 Z-49.849
N21239 X-10.776 Z-49.418
N21240 X-12.559 Z-48.913
N21241 X-14.342 Z-48.323
N21242 X-16.151 Z-47.634
N21243 X-17.961 Z-46.848
N21244 X-19.729 Z-45.98
N21245 X-21.498 Z-45.007
N21246 X-22.41 Z-44.462
N21247 X-23.321 Z-43.886
N21248 X-24.233 Z-43.278
N21249 X-25.145 Z-42.634
N21250 X-26.02 Z-41.981
N21251 X-26.895 Z-41.292
N21252 X-27.77 Z-40.565
N21253 X-28.645 Z-39.796
N21254 X-29.566 Z-38.941
N21255 X-30.487 Z-38.035
N21256 X-31.408 Z-37.073
N21257 X-32.329 Z-36.043
N21258 X-33.166 Z-35.047
N21259 X-34.002 Z-33.989
N21260 X-34.839 Z-32.859
N21261 X-35.676 Z-31.638
N21262 X-36.635 Z-30.125
N21263 X-37.595 Z-28.455
N21264 X-38.074 Z-27.548
N21265 X-38.554 Z-26.583
N21266 X-39.033 Z-25.551
N21267 X-39.757 Z-23.846
N21268 X-40.491 Z-21.866
N21269 X-41.346 Z-19.058
N21270 X-41.98 Z-16.329
N21271 X-42.491 Z-13.112
N21272 X-42.798 Z-9.751
N21273 X-43.003 Z-8.619
N21274 X-43.33 Z-7.496
N21275 X-43.554 Z-6.911
N21276 X-43.779 Z-6.401
N21277 X-44.228 Z-5.547
N21278 X-44.677 Z-4.839
N21279 X-45.35 Z-3.958
N21280 X-45.799 Z-3.463
N21281 X-46.248 Z-3.013
N21282 X-47.146 Z-2.258
N21283 X-48.044 Z-1.646
N21284 X-48.942 Z-1.151
N21285 X-49.84 Z-.757
N21286 X-50.289 Z-.596
N21287 X-51.187 Z-.331
N21288 X-52.085 Z-.146
N21289 X-52.984 Z-.036
N21290 X-53.882 Z0.
N21291 Y-119.425
N21292 X-52.984 Z-.036
N21293 X-52.085 Z-.146
N21294 X-51.187 Z-.331
N21295 X-50.289 Z-.596
N21296 X-49.84 Z-.757
N21297 X-48.942 Z-1.151
N21298 X-48.044 Z-1.646
N21299 X-47.146 Z-2.258
N21300 X-46.248 Z-3.013
N21301 X-45.799 Z-3.463
N21302 X-45.35 Z-3.958
N21303 X-44.677 Z-4.839
N21304 X-44.228 Z-5.547
N21305 X-43.779 Z-6.401
N21306 X-43.554 Z-6.911
N21307 X-43.33 Z-7.496
N21308 X-43.133 Z-8.127
N21309 X-43.105 Z-8.134
N21310 X43.105
N21311 X43.133 Z-8.127
N21312 X43.554 Z-6.911
N21313 X43.779 Z-6.401
N21314 X44.228 Z-5.547
N21315 X44.677 Z-4.839
N21316 X45.35 Z-3.958
N21317 X45.799 Z-3.463
N21318 X46.248 Z-3.013
N21319 X47.146 Z-2.258
N21320 X48.044 Z-1.646
N21321 X48.942 Z-1.151
N21322 X49.84 Z-.757
N21323 X50.289 Z-.596
N21324 X51.187 Z-.331
N21325 X52.085 Z-.146
N21326 X52.984 Z-.036
N21327 X53.882 Z0.
N21328 Y-120.625
N21329 X52.984 Z-.036
N21330 X52.085 Z-.146
N21331 X51.187 Z-.331
N21332 X50.289 Z-.596
N21333 X49.84 Z-.757
N21334 X48.942 Z-1.151
N21335 X48.044 Z-1.646
N21336 X47.146 Z-2.258
N21337 X46.248 Z-3.013
N21338 X45.799 Z-3.463
N21339 X45.35 Z-3.958
N21340 X44.677 Z-4.839
N21341 X44.34 Z-5.361
N21342 X44.228 Z-5.374
N21343 X-44.31
N21344 X-44.335 Z-5.37
N21345 X-44.708 Z-4.794
N21346 X-45.106 Z-4.263
N21347 X-45.504 Z-3.78
N21348 X-46.299 Z-2.966
N21349 X-47.146 Z-2.258
N21350 X-48.044 Z-1.646
N21351 X-48.942 Z-1.151
N21352 X-49.84 Z-.757
N21353 X-50.289 Z-.596
N21354 X-51.187 Z-.331
N21355 X-52.085 Z-.146
N21356 X-52.984 Z-.036
N21357 X-53.882 Z0.
N21358 Y-121.825
N21359 X-52.984 Z-.036
N21360 X-52.085 Z-.146
N21361 X-51.187 Z-.331
N21362 X-50.289 Z-.596
N21363 X-49.84 Z-.757
N21364 X-48.942 Z-1.151
N21365 X-48.044 Z-1.646
N21366 X-47.146 Z-2.258
N21367 X-46.697 Z-2.62
N21368 X-45.985 Z-3.27
N21369 X-45.541 Z-3.739
N21370 X-45.452 Z-3.748
N21371 X45.519
N21372 X46.248 Z-3.013
N21373 X47.146 Z-2.258
N21374 X48.044 Z-1.646
N21375 X48.942 Z-1.151
N21376 X49.84 Z-.757
N21377 X50.289 Z-.596
N21378 X51.187 Z-.331
N21379 X52.085 Z-.146
N21380 X52.984 Z-.036
N21381 X53.882 Z0.
N21382 Y-123.025
N21383 X52.984 Z-.036
N21384 X52.085 Z-.146
N21385 X51.187 Z-.331
N21386 X50.289 Z-.596
N21387 X49.84 Z-.756
N21388 X48.942 Z-1.151
N21389 X48.044 Z-1.646
N21390 X47.595 Z-1.94
N21391 X46.697 Z-2.591
N21392 X-46.697
N21393 X-47.595 Z-1.94
N21394 X-48.044 Z-1.646
N21395 X-48.942 Z-1.151
N21396 X-49.84 Z-.757
N21397 X-50.289 Z-.596
N21398 X-51.187 Z-.331
N21399 X-52.085 Z-.146
N21400 X-52.984 Z-.036
N21401 X-53.882 Z0.
N21402 Y-124.225
N21403 X-52.984 Z-.036
N21404 X-52.085 Z-.146
N21405 X-51.187 Z-.331
N21406 X-50.289 Z-.596
N21407 X-49.84 Z-.756
N21408 X-48.942 Z-1.151
N21409 X-47.936 Z-1.713
N21410 X47.924 Z-1.716
N21411 X48.942 Z-1.151
N21412 X49.84 Z-.756
N21413 X50.289 Z-.596
N21414 X51.187 Z-.331
N21415 X52.085 Z-.146
N21416 X52.984 Z-.036
N21417 X53.882 Z0.
N21418 Y-125.425
N21419 X52.984 Z-.036
N21420 X52.085 Z-.146
N21421 X51.187 Z-.331
N21422 X50.289 Z-.596
N21423 X49.84 Z-.756
N21424 X49.167 Z-1.045
N21425 X-48.942 Z-1.06
N21426 X-49.167 Z-1.045
N21427 X-49.84 Z-.756
N21428 X-50.289 Z-.596
N21429 X-51.187 Z-.331
N21430 X-52.085 Z-.146
N21431 X-52.984 Z-.036
N21432 X-53.882 Z0.
N21433 Y-126.625
N21434 X-52.984 Z-.036
N21435 X-52.085 Z-.146
N21436 X-51.187 Z-.331
N21437 X-50.289 Z-.582
N21438 X50.289
N21439 X51.187 Z-.331
N21440 X52.085 Z-.146
N21441 X52.984 Z-.036
N21442 X53.882 Z0.
N21443 X53.817 Y-127.825
N21444 X52.92 Z-.036
N21445 X52.023 Z-.146
N21446 X51.446 Z-.241
N21447 X-51.352 Z-.244
N21448 X-52.262 Z-.112
N21449 X-53.04 Z-.028
N21450 X-53.817 Z0.
N21451 X-53.372 Y-129.025
N21452 X-51.323 Z-.056
N21453 X51.593 Z-.052
N21454 X53.372 Z0.
N21455 X50.74 Y-130.174
N21456 X-50.74
N21457 G00 Z2.6
N21458 M09
N21459 M05
N21460 G91 G28 Z0.
N21461 G91 G28 X0. Y0.
N21462 M02
N21463 M30
Thanks once more
Sven.
I would say that the M2 control cannot take a 5-digit "N" number. You must limit it to 4 digits (N9999 is max). Try that....
Okey I accept that but whot can I do
the program have more than 20000 lines?
Thank you Sven.
the use of the sequence number (aka "N word") is OPTIONAL. many people these days only use it on the tool change line to flag the tool change and leave it out. if you insist on using it, you have to start the count over once you max it out. it is using up valuable program memory without adding any value to the machining.
jim
