FANUC 16-TB Tool Geom / Wear not Updating
Dear colleagues,
We have one machine here that was conventional and now we put one old (very old) FANUC 16-TB on that.
The machine is fully parametrizated as well as drives and control itself, tool changes, the machine works fine, back lash and lead screw table are setted and everything is fine. BUT
The values on Geometry and in the Wear aren't updating the absolute coordinate system. To be able to evaluate the machine geometry and make some machining tests I had to insert the Tool Geometry Values on Work Offset, and then work with just one tool.
Even the Wear isn't working. The screen is there, the measure - insert c - insert + and input are avaliable, the values are inserted correctly using the insert c, but when I program T0202 the change occurs but the values of absolute isn't working.
Need help because I think that this function is on basic software package.
If you can help me again I'll be glad.
