Hello, I need help, how to generate a nc in EdgeCAM fagor for 8055??
Printable View
I am not sure about Edgecam, I use Surfcam, but you should be able to generate the Gcode but then save it as ".pim" file, not your typical ".nc" file. You can get a program from Fagor Automation called WinDNC. With this program you can down load the ".pim" file to the controller.
Hope this helps.
obridado response,
yes, I generate the CODIGOG in the generated code needs to make some adjustments, save in 000.pim Seems magic and ready ...
hehehhe
ok
For best ease in downloading/uploading programs, I do recommend you utilize the Fagor DNC program..... it is free of charge and can be downloaded in just a few minutes from the download center at Máquina herramienta, Medición, Motion control, Energía : Fiabilidad en todo el mundo : CNC, DRO, encoders, reglas, inversores de corriente, servosistemas
That program makes uploading/downloading, plus monitoring very simple.
hope this helps
Todd
