Would like to use FineCut consumables to cut 3/16" mild steel sheet. Is it possible?
Alright, here's my deal.
I have a DynaTorch 5x10 machine with a Hypertherm Powermax 1250 G3 and the T80M machine torch. Initial height is set using Dynatorch's ohmic sensing geehaw, and cutting height is set via arc voltage.
I cut a lot of 11 ga mild steel using the finecut consumables, and I'm happy with what I'm getting there.
However, I'm working on a new product line that will require the extensive use of 3/16" sheet (still mild steel), and I would very much like to continue being able to use the finecut stuff.
I need the reliable edge condition and definition of geometry that I get from the finecuts, but I need to use the thicker material.
Is it possible to cut 3/16" mild steel with the finecut consumables?
If it is possible, could you guys spot me some info on cutting data?
A jumping off point to tune from would be most helpful.
An answer from Jim Colt would likely make my week. :D
Thanks for your time guys.
