Haas TL-1 tool turret modifications
About a year ago I upgraded from the old style gear motor tool turret to the new servo driven turret. I have been fairly happy with it as far as speed goes but did not like the way the servo cover could interfere with the tail stock. I also have always wanted to add coolant through the turret so each tool had its own coolant nozzle that could be aimed to the proper point, similar to my Miyano and Daewoo turning centers.
Here are my solutions.
I started by removing the servo cover and sawing a 1.1” X 1.7” section out of it. I then removed the ends, inverted the section and welded it back in. I removed the turret from the lathe. The air solenoid needs to be moved from the tail stock side of the turret to the operator side. I milled a pocket on the operator side similar to the one on the tail stock side, drilled and tapped two 10-32 holes and mounted the air solenoid. I switched the air lines under the turret so they could route to the correct positions. I moved the wire harness mount over to the wire loom screw and tilted the harness mount it at an angle. Here are some pictures,
http://i24.photobucket.com/albums/c1...t/41c96c33.jpg
http://i24.photobucket.com/albums/c1...t/95a69555.jpg
http://i24.photobucket.com/albums/c1...t/a8a04d61.jpg
When the turret was off I removed the tool block and drilled .187" holes in each corner at a 24.5 degree angle towards the center. I then drilled for a 1/8" NPT down from the top until it met the bottom hole. I tapped the 1/8 NPT hole and mounted some Loc Line adapters. I mounted the whole turret in the mill, located the position of the coolant hole and removed the tool block. I removed the tool block milled the turret top flat at this location and drilled into the turret base for a 1/2" X 20 TPI tap. I also milled the side of the turret base flat at the same time. I then drilled in the side to meet the top hole and tapped for a 1/8" NPT. Here are some pictures,
http://i24.photobucket.com/albums/c1...t/55435892.jpg
http://i24.photobucket.com/albums/c1...t/59feb474.jpg
In the last picture you can see how I sealed the base to the turret. I made a brass threaded post that would accept an automotive valve stem seal. These seals work great and I have tons of them lying around. I just removed the metal spring around the seal and that allowed it to compress more. Here is a picture of the post,
http://i24.photobucket.com/albums/c1...t/32525ab7.jpg
Here is the almost finished product,
http://i24.photobucket.com/albums/c1...t/1f225f9a.jpg
http://i24.photobucket.com/albums/c1...t/6a316b66.jpg
I routed the coolant line through the X axis cross slide with the other lines for the turret. I put a T at the coolant pump so I can still use the original coolant line if needed.
Mark Hockett
Island Tech Enterprises
Re: Haas TL-1 tool turret modifications
Anybody know why the images are blurred out on this post? Has photo bucket changed policies?
