How many hours do you have on your fadals
Hi Guys..
Just curious.. I recently purchased a used 4020 and had my tech do a once over on the machine to make sure eveything is in check.. Got an A+ from the tech and asked how many hours were on the machine.. Well its a 1999 4020 A and its shows 2200 hours of cutting time..
In my opinion, its pretty low hours..
What is your year and how many hours do you have on it ??
Would appreciate your comments..
Thanks Chips !!
Re: How many hours do you have on your fadals
HI,
I am trying to check the number of hours ran on a Fadal 4020 and Fadal 40. They have a Fadal CNC Control 88. Every time I put in the "UT" command, the Offset Utility page pops up and it does not have the "Clock" command assign to a number. Any help on how i can get how many hours the machine has ran?
This is what is displayed when I use the UT command:
OFFSET UTILITY OPTIONS:
1 TOOL SETTING CYCLE
2 FIXTURE OFFSET SETTING
3 TEST TS-20 PROBE
4 TEST MP PROBE
5 EXIT
ENTER OPTION NUMBER _
thanks
Your version of software does not have the Clocks, need a newer version
Clocks are only a reference anyways they can be reset to Zero at anytime. They are not an accurate use of the machine.
