Wanted a share my lathe conversion.
Running ballscrews, steppers, gecko 251 drives and Mach3.
Mostly cutting steel.
Next additions is adding threading, coolant and full enclosure.
Any body else converted an AL-320g?
Printable View
very good job dude,
machine looks beautiful from this side. How's the surface finish?
i see you are using reduction pulleys on steppers. why?
hook them up with 1:1 or direct drive and you get more rapids.
i have 200ipm rapids on my lathe with 300oz steppers and ballscrews. (but it has lm guides also) how much rapids you have there?
jasminder singh
Jasminder,
Like the turret, have to live with a quick change tool post for a while.
Rapids are 50ipm and good surface finish. Looking into upgrading to nema 34 steppers and direct drive for speed, but that will be a little while.
Mark.
No, but I am converting an AL54G which is a 280mm x 750mm bench lathe.
http://www.cnczone.com/forums/906804-post1.html
Will be watching your project with interest.
