Introducing the Pinnacle Series X2 mini-mill!
Introducing the Pinnacle Series X2 bench mini-mill from KDN Tool & Automation Engineering Co LLC. Built upon over two years of worldwide experience with retrofitting the Sieg X2 mini-mill, the Pinnacle Series is offered in three levels of completion. First level, the base camp, offers three-axis ball screw actuation with single pre-loaded ball nuts. Ball screws are 5/8” DIA 5TPI with a .0003”/1” lead accuracy. Ball screw thrust load is handled by a pair of grooved-race ball thrust bearings with 2000+lbs dynamic load rating each. The bearings are pre-loaded and secured with a lock nut. Ball screw to motor coupling is via one “Oldham” style anti-backlash slotted disc coupling per axis. Standard axis drive motor mounting plates mate with NEMA 23 motors and NEMA 34 motor plates are available as an option. We utilize a direct drive motor coupling arrangement that takes advantage of a stepper motors low-end torque parameters. We have teamed with the Steele Company to include a variation of their two step pulley spindle drive configuration yielding whisper quiet 0-1700 and 0-4300 RPM ranges. The stock Sieg spindle motor speed control has been replaced with an American made industrial quality speed control facilitating interface with a 0-10 VDC control signal that can be provided by cnc software. We offer an interface board that is designed to connect between DeskCNC and 0-10VDC input as well.
Mechanical Specifications:
Machine table size = 15" X 3.625"
Work envelope = 9" X 3.8" X 9"
Positional Accuracy = .0003" / 1" travel
Backlash = <= .0005"
Repeatability = .001" + step motor specs
Spindle taper = R-8
Spindle drive mechanism = two-step pulley & V–belt
Spindle Speeds = 0-1700 and 0-4300 RPM infinitely variable
Footprint = 24" D X 36" W X 30" H (including x axis travel limits & double stack motors)
Weight = @125 lbs.
Mechanical Components:
Nook Industries rolled ball screws. 5TPI 1 per axis
Single "pre-loaded" ball nuts yielding <=.0005" backlash. 1 per axis
Bearing housings custom machined from 6061 aluminum bar stock.
Grooved race ball thrust bearings. 2 per axis. 2100-LB dynamic load rated each.
Ruland brand "Oldham" style anti-backlash slotted disc couplings.
In line motor mounting exploits step motors inherent low speed torque characteristics.
Modified spindle mount casting for ball screw actuation.
Modified saddle casting for ball screw actuation.
Optional Spindle Drive Components:
Bodine "Pacesetter" .25 hp 230 VAC inverter duty rated spindle motor.
Spindle Motor Drive: 120 VAC single phase in / 230 VAC 3 phase out inverter / VFD.
Our Advantages:
Cast Iron Dovetail Construction.
Ball Screw motion components. 90% efficient
Tried & true CNC conversion design.
Top quality American made components added.
All castings are checked for fit & finish.
Sliding surfaces indicated and adjusted for proper alignment to one another.
Machine arrives broken-in and ready to run.
R-8 spindle taper offers a multitude of affordable tooling.
"Old School" machine building techniques from the heartland of the Industrial Revolution.
Introductory Price: $2500.00 + Actual Shipping costs & $50.00 Crating fee.
Options Available:
Lubrication grooves machined into castings. (W/fittings & tubes) +$175.00
One-shot lubrication system. +$ 75.00
Column indicated and pinned. +$100.00
Home switches installed. +$ 75.00
Limit switches installed. +$100.00
Optical home and limit switches. +$ 20.00 per switch
Inverter / VFD Spindle Drive. +$500.00
Precision rolled ball screws .000083”/1” accuracy +$ 75.00
We also offer step motors and drive electronics to compliment the machines. We can provide integrated cnc control software as well to produce a complete plug and play machine for you.
Kenneth Cardolino
KDN Tool & Automation Engineering Co. LLC
www.kdntool.com
