I would like to know if any way to get .min pap programs off disk and into comp or flash drive other than one program at a time converting to dos and transfering that way
Printable View
Why would you convert them to DOS? Right click and drag?
I have 30 some disks of programs already written but we want to back them all up at least 1500 programs only way to save them is put to dos then put in computer
You can use my program (OSP simulator). You can backup all .MIN programs to computer
OSP Floppy Disk Simulator
What control does your machine have ?
do you have MSDOS as one of the F-keys in the EDIT section ??
it is a osp-u10m and is not hooked up to rs232 so we post programsn on disk then put disk in machine save machine programs to pip and save on disk
I would think that control has the MSDOS as standard
Under the <EDIT> Fkey, then go <EXTEND> < EXTEND>
you should find an F-key saying MSDOS
This enables the floppy drive to be used with DOS formatted disks, which can then be placed into a PC & files operated normally
to do mass file copies, you can use the wildcard * symbol
ie MSCO>> MD1: *.MIN, FD0:
red is the command, green is FROM location, orange is all MIN files, blue is the TO location
link to additional info
i can do the first opp. but only one file at time sec. one not enough memory in machine to do more than one file at time
is there any other osp disk simulators out there
