NewBie to 4th axis milling
Hi people.
any help for what i'm trying to would be good, i'm new and just triling this software to see if i like it.
The problem i'm having is i'm trying to 4th axis index as the machine i am building will have XYZA axis.
i've drawn up a random part in solidworks and imported it into FeatureCAM.
i could post a pic if people need but i'll try to explain it the best for now.
it is 50.8mm (2in) round stock x 60mm (?in) long, 25 mm of it is stepped down to 25.4mm (1in).
it has 3x 6mm (?in) holes 120deg around the axis to the middle of the stock.
and also has 3 flats from the end of the step to the hole to make like a rebate kinda thing, it is 12.7mm (.5in) wide and covers the hole.
Hope this all makes sence.
The Problem i'm having is macining the step of it.
I can get the holes and slot to index and cut but cannot work out how to take the stock from the 50.8mm down to 25.4mm
Also the other thing the i get is and error when it changes from drill bit to milling cutter for the flat is before the first cut it sits just on the stock and gives warning.
Wondering if anyone can help me out or if there is any 4th axis tutorials out there that i could use to learn how to do this to try the software.
Any help would be good. Thanks For reading and hear from you soon.
1 Attachment(s)
Here are the files if anyone can help
there are 3 files: 1 is a solidwork eview
2 is the solidworks drawing
3 is the featurecam file
What I'm trying to do is 4th axis index everything in this as i don't have a lathe setup on my machine but i'm having no luck, wondering if it can be done??
Maybe someone knows some walkthoughts or tutorials???
also wouldn't mind if someone could teach me how to engrave on the 4th axis indexing side of things.
Thanks to anyone who can help
Will
